path: root/sound
2011-04-14sound: oss: midi_synth: check get_user() return valueKulikov Vasiliy
commit b3390ceab95601afc12213c3ec5551d3bc7b638f upstream. get_user() may fail, if so return -EFAULT. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-14sound/oss: remove offset from load_patch callbacksDan Rosenberg
commit b769f49463711205d57286e64cf535ed4daf59e9 upstream. Was: [PATCH] sound/oss/midi_synth: prevent underflow, use of uninitialized value, and signedness issue The offset passed to midi_synth_load_patch() can be essentially arbitrary. If it's greater than the header length, this will result in a copy_from_user(dst, src, negative_val). While this will just return -EFAULT on x86, on other architectures this may cause memory corruption. Additionally, the length field of the sysex_info structure may not be initialized prior to its use. Finally, a signed comparison may result in an unintentionally large loop. On suggestion by Takashi Iwai, version two removes the offset argument from the load_patch callbacks entirely, which also resolves similar issues in opl3. Compile tested only. v3 adjusts comments and hopefully gets copy offsets right. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-14ALSA: ens1371: fix Creative Ectiva supportClemens Ladisch
commit 6ebb8a4a43e34f999ab36f27f972f3cd751cda4f upstream. To make the EV1938 chip work, add a magic bit and an extra delay. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Tested-by: Tino Schmidt <mailtinoshomepage@gmx.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-14sound/oss/opl3: validate voice and channel indexesDan Rosenberg
commit 4d00135a680727f6c3be78f8befaac009030e4df upstream. User-controllable indexes for voice and channel values may cause reading and writing beyond the bounds of their respective arrays, leading to potentially exploitable memory corruption. Validate these indexes. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-14ALSA: Fix yet another race in disconnectionTakashi Iwai
commit a45e3d6b13e97506b616980c0f122c3389bcefa4 upstream. This patch fixes a race between snd_card_file_remove() and snd_card_disconnect(). When the card is added to shutdown_files list in snd_card_disconnect(), but it's freed in snd_card_file_remove() at the same time, the shutdown_files list gets corrupted. The list member must be freed in snd_card_file_remove() as well. Reported-and-tested-by: Russ Dill <russ.dill@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-14ALSA: hda - Fix SPDIF out regression on ALC889Takashi Iwai
commit 20b67dddcc5f29d3d0c900225d85e0ac655bc69d upstream. The commit 5a8cfb4e8ae317d283f84122ed20faa069c5e0c4 ALSA: hda - Use ALC_INIT_DEFAULT for really default initialization changed to use the default initialization method for ALC889, but this caused a regression on SPDIF output on some machines. This seems due to the COEF setup included in the default init procedure. For making SPDIF working again, the COEF-setup has to be avoided for the id 0889. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=24342 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23ALSA: ctxfi - Clear input settings before initializationPrzemyslaw Bruski
commit efed5f26664f93991c929d5bb343e65f900d72bc upstream. Clear input settings before initialization. Signed-off-by: Przemyslaw Bruski <pbruskispam@op.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23ALSA: ctxfi - Fix SPDIF status retrievalPrzemyslaw Bruski
commit f164753a263bfd2daaf3e0273b179de7e099c57d upstream. SDPIF status retrieval always returned the default settings instead of the actual ones. Signed-off-by: Przemyslaw Bruski <pbruskispam@op.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23ALSA: ctxfi - Fix incorrect SPDIF status bit maskPrzemyslaw Bruski
commit 4c1847e884efddcc3ede371f7839e5e65b25c34d upstream. SPDIF status mask creation was incorrect. Signed-off-by: Przemyslaw Bruski <pbruskispam@op.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23ALSA: hda - fix digital mic selection in mixer on 92HD8X codecsVitaliy Kulikov
commit 094a42452abd5564429045e210281c6d22e67fca upstream. When the mux for digital mic is different from the mux for other mics, the current auto-parser doesn't handle them in a right way but provides only one mic. This patch fixes the issue. Signed-off-by: Vitaliy Kulikov <Vitaliy.Kulikov@idt.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02ALSA: caiaq - Fix possible string-buffer overflowTakashi Iwai
commit eaae55dac6b64c0616046436b294e69fc5311581 upstream. Use strlcpy() to assure not to overflow the string array sizes by too long USB device name string. Reported-by: Rafa <rafa@mwrinfosecurity.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-02ALSA: HDA: Add position_fix quirk for an Asus deviceDavid Henningsson
commit b540afc2b3d6e4cd1d1f137ef6d9e9c78d67fecd upstream. The bug reporter claims that position_fix=1 is needed for his microphone to work. The controller PCI vendor-id is [1002:4383] (rev 40). Reported-by: Kjell L. BugLink: http://bugs.launchpad.net/bugs/718402 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17ASoC: Blackfin AC97: fix build error after multi-component updateMike Frysinger
commit e9c2048915048d605fd76539ddd96f00d593e1eb upstream. We need to tweak how we query the active capture/playback state after the recent overhauls of common code. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17ASoC: WM8990: msleep() takes milliseconds not jiffiesDimitris Papastamos
commit 7ebcf5d6021a696680ee77d9162a2edec2d671dd upstream. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17ALSA: hrtimer: handle delayed timer interruptsClemens Ladisch
commit b1d4f7f4bdcf9915c41ff8cfc4425c84dabb1fde upstream. If a timer interrupt was delayed too much, hrtimer_forward_now() will forward the timer expiry more than once. When this happens, the additional number of elapsed ALSA timer ticks must be passed to snd_timer_interrupt() to prevent the ALSA timer from falling behind. This mostly fixes MIDI slowdown problems on highly-loaded systems with badly behaved interrupt handlers. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Reported-and-tested-by: Arthur Marsh <arthur.marsh@internode.on.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17ALSA: hda - Fix memory leaks in conexant jack arraysTakashi Iwai
commit 70f7db11c45a313b23922cacf248c613c3b2144c upstream. The Conexant codec driver adds the jack arrays in init callback which may be called also in each PM resume. This results in the addition of new jack element at each time. The fix is to check whether the requested jack is already present in the array. Reference: Novell bug 668929 https://bugzilla.novell.com/show_bug.cgi?id=668929 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17ALSA: HDA: Fix dmesg output of HDMI supported bitsDavid Henningsson
commit d757534ed15387202e322854cd72dc58bbb975de upstream. This typo caused the dmesg output of the supported bits of HDMI to be cut off early. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17ALSA : au88x0 - Limit number of channels to fix Oops via OSS emuRaymond Yau
commit d9ab344336f74c012f6643ed3d1ad8ca0136de3b upstream. Fix playback/capture channels patch to change supported playback channels of au8830 to 1,2,4 and capture channels to 1,2. This prevent oops when oss emulation use SNDCTL_DSP_CHANNELS to set 3 Channels Signed-off-by: Raymond Yau <superquad.vortex2@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17ALSA: snd-usb-us122l: Fix missing NULL checksKarsten Wiese
commit cdce2db74e156fbd9a2dc3c7b246166f8b70955b upstream. Fix missing NULL checks in usb_stream_hwdep_poll() and usb_stream_hwdep_ioctl(). Wake up poll waiters before returning from usb_stream_hwdep_ioctl(). Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07ALSA: hda: Use LPIB quirk for Dell Inspiron m101z/1120Daniel T Chen
commit e03fa055bc126e536c7f65862e08a9b143138ea9 upstream. Sjoerd Simons reports that, without using position_fix=1, recording experiences overruns. Work around that by applying the LPIB quirk for his hardware. Reported-and-tested-by: Sjoerd Simons <sjoerd@debian.org> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07ALSA: hda: Use LPIB for Dell Latitude 131LDaniel T Chen
commit 9919c7619c52d01e89103bca405cc3d4a2b1ac31 upstream. BugLink: https://launchpad.net/bugs/530346 The OR has verified that position_fix=1 is necessary to work around errors on his machine. Reported-by: Tom Louwrier Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-01-07sound: Prevent buffer overflow in OSS load_mixer_volumesDan Rosenberg
commit d81a12bc29ae4038770e05dce4ab7f26fd5880fb upstream. The load_mixer_volumes() function, which can be triggered by unprivileged users via the SOUND_MIXER_SETLEVELS ioctl, is vulnerable to a buffer overflow. Because the provided "name" argument isn't guaranteed to be NULL terminated at the expected 32 bytes, it's possible to overflow past the end of the last element in the mixer_vols array. Further exploitation can result in an arbitrary kernel write (via subsequent calls to load_mixer_volumes()) leading to privilege escalation, or arbitrary kernel reads via get_mixer_levels(). In addition, the strcmp() may leak bytes beyond the mixer_vols array. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07ALSA: hda: Use model=lg quirk for LG P1 Express to enable playback and captureDaniel T Chen
commit 77c4d5cdb81d25a45fbdfb84dd3348121219a072 upstream. BugLink: https://launchpad.net/bugs/595482 The original reporter states that audible playback from the internal speaker is inaudible despite the hardware being properly detected. To work around this symptom, he uses the model=lg quirk to properly enable both playback, capture, and jack sense. Another user corroborates this workaround on separate hardware. Add this PCI SSID to the quirk table to enable it for further LG P1 Expresses. Reported-and-tested-by: Philip Peitsch <philip.peitsch@gmail.com> Tested-by: nikhov Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09ALSA: hda: Use "alienware" model quirk for another SSIDDaniel T Chen
commit 0defe09ca70daccdc83abd9c3c24cd89ae6a1141 upstream. BugLink: https://launchpad.net/bugs/683695 The original reporter states that headphone jacks do not appear to work. Upon inspecting his codec dump, and upon further testing, it is confirmed that the "alienware" model quirk is correct. Reported-and-tested-by: Cody Thierauf Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09ALSA: HDA: Add an extra DAC for Realtek ALC887-VDDavid Henningsson
commit cc1c452e509aefc28f7ad2deed75bc69d4f915f7 upstream. The patch enables ALC887-VD to use the DAC at nid 0x26, which makes it possible to use this DAC for e g Headphone volume. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09ALSA: ac97: Apply quirk for Dell Latitude D610 binding Master and Headphone ↵Daniel T Chen
controls commit 0613a59456980161d0cd468bae6c63d772743102 upstream. BugLink: https://launchpad.net/bugs/669279 The original reporter states: "The Master mixer does not change the volume from the headphone output (which is affected by the headphone mixer). Instead it only seems to control the on-board speaker volume. This confuses PulseAudio greatly as the Master channel is merged into the volume mix." Fix this symptom by applying the hp_only quirk for the reporter's SSID. The fix is applicable to all stable kernels. Reported-and-tested-by: Ben Gamari <bgamari@gmail.com> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-28ALSA: rawmidi: fix oops (use after free) when unloading a driver moduleClemens Ladisch
commit aa73aec6c385e2c797ac25cc7ccf0318031de7c8 upstream. When a driver module is unloaded and the last still open file is a raw MIDI device, the card and its devices will be actually freed in the snd_card_file_remove() call when that file is closed. Afterwards, rmidi and rmidi->card point into freed memory, so the module pointer is likely to be garbage. (This was introduced by commit 9a1b64caac82aa02cb74587ffc798e6f42c6170a.) Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Reported-by: Krzysztof Foltman <wdev@foltman.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-28ALSA: prevent heap corruption in snd_ctl_new()Dan Rosenberg
commit 5591bf07225523600450edd9e6ad258bb877b779 upstream. The snd_ctl_new() function in sound/core/control.c allocates space for a snd_kcontrol struct by performing arithmetic operations on a user-provided size without checking for integer overflow. If a user provides a large enough size, an overflow will occur, the allocated chunk will be too small, and a second user-influenced value will be written repeatedly past the bounds of this chunk. This code is reachable by unprivileged users who have permission to open a /dev/snd/controlC* device (on many distros, this is group "audio") via the SNDRV_CTL_IOCTL_ELEM_ADD and SNDRV_CTL_IOCTL_ELEM_REPLACE ioctls. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-28ALSA: hda - Add Dell Latitude E6400 model quirkLuke Yelavich
commit 0f9f1ee9d1412d45a22bfd69dfd4d4324b506e9e upstream. BugLink: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/643891 Set the Dell Latitude E6400 (1028:0233) SSID to use AD1984_DELL_DESKTOP Signed-off-by: Luke Yelavich <luke.yelavich@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-28ALSA: oxygen: fix analog capture on Claro halo cardsErik J. Staab
commit 0873a5ae747847ee55a63db409dff3476e45bcd9 upstream. On the HT-Omega Claro halo card, the ADC data must be captured from the second I2S input. Using the default first input, which isn't connected to anything, would result in silence. Signed-off-by: Erik J. Staab <ejs@insightbb.com> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-28ALSA: sound/pci/rme9652: prevent reading uninitialized stack memoryDan Rosenberg
commit e68d3b316ab7b02a074edc4f770e6a746390cb7d upstream. The SNDRV_HDSP_IOCTL_GET_CONFIG_INFO and SNDRV_HDSP_IOCTL_GET_CONFIG_INFO ioctls in hdspm.c and hdsp.c allow unprivileged users to read uninitialized kernel stack memory, because several fields of the hdsp{m}_config_info structs declared on the stack are not altered or zeroed before being copied back to the user. This patch takes care of it. Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20ALSA: hda - Handle pin NID 0x1a on ALC259/269Takashi Iwai
commit b08b1637ce1c0196970348bcabf40f04b6b3d58e upstream. The pin NID 0x1a should be handled as well as NID 0x1b. Also added comments. Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20ALSA: hda - Handle missing NID 0x1b on ALC259 codecTakashi Iwai
commit 5d4abf93ea3192cc666430225a29a4978c97c57d upstream. Since ALC259/269 use the same parser of ALC268, the pin 0x1b was ignored as an invalid widget. Just add this NID to handle properly. This will add the missing mixer controls for some devices. Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20ALSA: seq/oss - Fix double-free at error path of snd_seq_oss_open()Takashi Iwai
commit 27f7ad53829f79e799a253285318bff79ece15bd upstream. The error handling in snd_seq_oss_open() has several bad codes that do dereferecing released pointers and double-free of kmalloc'ed data. The object dp is release in free_devinfo() that is called via private_free callback. The rest shouldn't touch this object any more. The patch changes delete_port() to call kfree() in any case, and gets rid of unnecessary calls of destructors in snd_seq_oss_open(). Fixes CVE-2010-3080. Reported-and-tested-by: Tavis Ormandy <taviso@cmpxchg8b.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20ALSA: hda - Fix auto-parser of ALC269vb for HP pin NID 0x21Kailang Yang
commit 531d8791accf1464bc6854ff69d08dd866189d17 upstream. ALC269vb has an alternative HP pin 0x21 in addition. Fix the parser to recognize it. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20ALSA: hda - Rename iMic to Int Mic on Lenovo NB0763David Henningsson
commit 150b432f448281d5518f5229d240923f9a9c5459 upstream. The non-standard name "iMic" makes PulseAudio ignore the microphone. BugLink: https://launchpad.net/bugs/605101 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26ALSA: intel8x0: Mute External Amplifier by default for ThinkPad X31Daniel T Chen
commit 9c77b846ec8b4e0c7107dd7f820172462dc84a61 upstream. BugLink: https://bugs.launchpad.net/bugs/619439 This ThinkPad model needs External Amplifier muted for audible playback, so set the inv_eapd quirk for it. Reported-and-tested-by: Dennis Bell <dennis.bell@parkerg.co.uk> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26ALSA: hda - Fix missing stream for second ADC on Realtek ALC260 HDA codecJonathan Woithe
commit 53bacfbbb2ddd981287b58a511c8b8f5df179886 upstream. I discovered tonight that ALSA no longer sets up a stream for the second ADC provided by the Realtek ALC260 HDA codec. At some point alc_build_pcms() started using stream_analog_alt_capture when constructing the second ADC stream, but patch_alc260() was never updated accordingly. I have no idea when this regression occurred. The trivial patch to patch_alc260() given below fixes the problem as far as I can tell. The patch is against 2.6.35. Signed-off-by: Jonathan Woithe <jwoithe@physics.adelaide.edu.au> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26ALSA: emu10k1 - delay the PCM interrupts (add pcm_irq_delay parameter)Jaroslav Kysela
commit 56385a12d9bb9e173751f74b6c430742018cafc0 upstream. With some hardware combinations, the PCM interrupts are acknowledged before the period boundary from the emu10k1 chip. The midlevel PCM code gets confused and the playback stream is interrupted. It seems that the interrupt processing shift by 2 samples is enough to fix this issue. This default value does not harm other, non-affected hardware. More information: Kernel bugzilla bug#16300 [A copmile warning fixed by tiwai] Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26ALSA: riptide - Fix detection / load of firmware filesTakashi Iwai
commit a5ba6beb839cfa288960c92cd2668a2601c24dda upstream. The detection and loading of firmeware on riptide driver has been broken due to rewrite of some codes, checking the presense wrongly. This patch fixes the logic again. Reference: kernel bug 16596 https://bugzilla.kernel.org/show_bug.cgi?id=16596 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26ASoC: Remove DSP mode support for WM8776Mark Brown
commit b2c1e07b81a126e5846dfc3d36f559d861df59f4 upstream. This is not supported by current hardware revisions. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26ASoC: Fix inverted mute controls for WM8580Mark Brown
commit 4f0ed9a51bc8ef16c2589112fdb110479e4b0df1 upstream. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02ALSA: Echoaudio, fix Guru Meditation #00000005.48454C50Giuliano Pochini
commit b721e68bdc5b39c51bf6a1469f8d3663fbe03243 upstream. This patch fixes a division by zero error in the irq handler. There is a small window between the hw_params() callback and when runtime->frame_bits is set by ALSA middle layer. When another substream is already running, if an interrupt is delivered during that window the irq handler calls pcm_pointer() which does a division by zero. The patch below makes the irq handler skip substreams that are initialized but not started yet. Cc to Clemens Ladisch because he proposed an alternate fix. For more information, please read the original thread in the linux-kernel mailing list: http://lkml.org/lkml/2010/2/2/187 Signed-off-by: Giuliano Pochini <pochini@shiny.it> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02ASoC: Remove duplicate AUX definition from WM8776Mark Brown
commit 3c0709396df0869786f83e4b2d2d687c70ee886d upstream. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02ALSA: hda - Add Macbook 5,2 quirkLuke Yelavich
commit 3bfea98ff73d377ffce0d4c7f938b7ef958cdb35 upstream. BugLink: https://bugs.launchpad.net/bugs/463178 Set Macbook 5,2 (106b:4a00) hardware to use ALC885_MB5 Signed-off-by: Luke Yelavich <luke.yelavich@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05ALSA: hda: Use LPIB for ASUS M2VDaniel T Chen
commit 9f75c1b12c5ef392ddcea575b13560842c28b1b3 upstream. BugLink: https://launchpad.net/bugs/587546 Symptom: On the reporter's ASUS M2V, using PulseAudio in Ubuntu 10.04 LTS results in the PA daemon crashing shortly after attempting playback of an audio file. Test case: Using Ubuntu 10.04 LTS (Linux 2.6.32.12), Linux 2.6.33, or Linux 2.6.34, attempt playback of an audio file while PulseAudio is active. Resolution: add SSID for this machine to the position_fix quirk table, explicitly specifying the LPIB method. Reported-and-Tested-By: D Tangman Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05ALSA: hda: Use LPIB for another mainboardDaniel T Chen
commit b90c076424da8166797bdc34187660fd0124f530 upstream. BugLink: https://launchpad.net/bugs/580749 Symptom: on the original reporter's VIA VT1708-based board, the PulseAudio daemon dies shortly after the user attempts to play an audio file. Test case: boot from Ubuntu 10.04 LTS live cd; attempt to play an audio file. Resolution: add SSID for the original reporter's hardware to the position_fix quirk table, explicitly specifying the LPIB method. Reported-and-Tested-By: Harald Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05ALSA: hda: Use mb31 quirk for an iMac modelDaniel T Chen
commit 26fd74fc01991a18f0e3bd54f8b1b75945ee3dbb upstream. BugLink: https://launchpad.net/bugs/542550 Symptom: On the reporter's iMac, in Ubuntu 10.04 LTS neither playback nor capture appear audible out-of-the-box. Test case: Boot from an Ubuntu 10.04 LTS live cd or from an installed configuration and attempt to play or capture audio. Resolution: Specify the mb31 quirk for this machine in the codec SSID table. Reported-and-Tested-By: f3a97 Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05ALSA: hda: Use LPIB for an ASUS deviceDaniel T Chen
commit dd37f8e8659bc617c3f2a84e007a4824ccdac458 upstream. BugLink: https://launchpad.net/bugs/465942 Symptom: On the reporter's ASUS device, using PulseAudio in Ubuntu 10.04 LTS results in the PA daemon crashing shortly after attempting to select capture or to configure the audio hardware profile. Test case: Using Ubuntu 10.04 LTS (Linux 2.6.32.12), Linux 2.6.33, or Linux 2.6.34, adjust the HDA device's capture volume with PulseAudio. Resolution: add SSID for this machine to the position_fix quirk table, explicitly specifying the LPIB method. Reported-and-Tested-By: Irihapeti Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05ASoC: Fix dB scales for WM8990Mark Brown
commit f68596c6d8711650722b2a54328a088a2c21bc5b upstream. These should be regular, not linear. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
