Adding TI codec aic3262 soc driver code.
Change-Id: I2557666d5704f9857d2f5e5238eb67d55ebc89d5
Reviewed-on: http://git-master/r/56080
Reviewed-by: Vinod Gopalakrishnakurup <vinodg@nvidia.com>
Tested-by: Vinod Gopalakrishnakurup <vinodg@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Onboard d-mic as well as mic jack for headset mic
are available. Both mics can be supported
simultaneously and one of them will be selected as
per application request and availability of
headset mic.
BUG 834328
Change-Id: Ie4fce8944d6219bfba2f26d6d0092c715142d740
Reviewed-on: http://git-master/r/54974
Tested-by: Sayak Choudhury <sayakc@nvidia.com>
In hdmi_pcm_open(), the evaluated PCM hw parameters are stored in
hinfo, but these aren't properly set back to the current runtime
record since these have been set beforehand in azx_pcm_open().
This patch fixes the behavior.
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
(cherry picked from commit 639cef0eb6df05d5516520aa89b0c9fe62ee2d3b)
Bug 879658
Change-Id: I63abb615bc5cc087efc6c391e3cb528058c04cc0
Reviewed-on: http://git-master/r/54280
Tested-by: Sumit Bhattacharya <sumitb@nvidia.com>
Set HDMI audio frequency source from HDA driver during
hotplug-in of HDMI device instead of restarting HDA alsa
stream.
Bug 861185
Change-Id: I36dc7a0debd5caebbf1287e5cf5cedfd1cd36dbf
Reviewed-on: http://git-master/r/49868
increase gain for digital mic
Bug 865954
Change-Id: I832a0703ffba27eb8d8b665edf432239c7628711
Reviewed-on: http://git-master/r/49138
Tested-by: Nikesh Oswal <noswal@nvidia.com>
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
bt-sco was broken because i2s dai was wrongly configured in
machine driver and there were also issues with setting i2s bit
clock
Bug 864984
Change-Id: I950bc92633c884180c0d48bc3654d576b8529734
Reviewed-on: http://git-master/r/48883
fixes bug 861141
Change-Id: I3b2d68c3a1d999edce0b228b99c3b633addaedab
Reviewed-on: http://git-master/r/48125
Tested-by: Ravindra Lokhande <rlokhande@nvidia.com>
Reviewed-by: Nikesh Oswal <noswal@nvidia.com>
azx chip should be stopped during HDA suspend and during
resume NV HDA controller should be initialized first
before initializing azx chip.
Bug 827122
Change-Id: Ifdfb5d041571eab00cad44d8609f8c80af939bc3
Reviewed-on: http://git-master/r/48167
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
1. add code for bt-sco voice call support
2. also disable the earlier bt-sco playback
path which directly connected apbif->i2s
instead playback path is changed to
apbif->dam->i2s, it would help in mixing
system sound and it also simplifies connection
issues during and after voice call
Bug 864984
Change-Id: I46195c250a99ecae8e1066d9b60deaf6d480e7ad
Reviewed-on: http://git-master/r/47552
add code for bt-sco playback and record support
Bug 864984
Change-Id: I003b58f333bcba371129a9069c2b453e1e8380c0
Reviewed-on: http://git-master/r/46084
Hardcode I2s bit clock to 2.8224 MHz for HIFI playback/capture
and to 512 kHz for Voice codec playback/capture to prevent
playback audio noise issue.
Fix the headphone detection reporting code.
Add all dai link connections supported by whistler in WM8753
dai link table.
Bug 864892
Change-Id: I4e3ed93c4f100aa7c7703ee6f505c51016a4e26b
Reviewed-on: http://git-master/r/47564
Disable/enable wired jack interrupts while going into
suspend/resume.
Bug 854830
(cherry picked from commit 281195dd5892134bb1fe174c0f2955dbe926412b)
Change-Id: Ie9197cf709f78e5e8e3d6ac2038b9bf0425dfc30
Reviewed-on: http://git-master/r/47308
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Add code to pas spdif init information from soc
Cleanup the code for checking the device type before
calling das function.
Change-Id: I2261dc51c1e231ba350dd92e2aa60981523311fc
Reviewed-on: http://git-master/r/47157
Bug 862023
Change-Id: Ib8fd1f35889d7f6a081b47df51b66c3d06e53f8d
Reviewed-on: http://git-master/r/46618
Reviewed-by: Nitin Pai <npai@nvidia.com>
The jack detection irq line was kept alive after suspend
command has been issued to the max98088 and caused device
to fail to enter suspend mode.
BUG 859822
Change-Id: I9407508788aa5aafa82774d4930653caa9a5b5b1
Reviewed-on: http://git-master/r/44884
added new pcm device with dummy cpu dai and Hifi codec dai for voice
call.
Removed unused functions and pins from machine driver file.
fixes bug 857654, 857636
Change-Id: Ib90db22a1482af6afdf7ff76c6ff8e859bcd6790
Reviewed-on: http://git-master/r/44571
Fixes toggling between digital and analog mike
Bug 857654
Change-Id: I87eecf1168a4e8c4358dedc0fa643ec8756b57db
Reviewed-on: http://git-master/r/44340
Add support for I2S slave mode to alsa driver
Change-Id: Id463cb22f57db64f7d6f5859f87ece91424be8cb
Reviewed-on: http://git-master/r/43099
Add a control to the max89088 driver to
control enabling the digital mic.
Change-Id: Idd654a8c7bd369e3d5d0b4166ebf1fe9084d52d1
Reviewed-on: http://git-master/r/44145
Tested-by: Scott Peterson <speterson@nvidia.com>
Add support for Generic Codec Driver
Add support for Generic Codec SOC Driver
Signed-off-by: Nitin Pai <npai@nvidia.com>
Change-Id: I3fbe2fbe8a559dbfa1de6d73bec0c5035681051a
Reviewed-on: http://git-master/r/43946
Tested-by: Nitin Pai <npai@nvidia.com>
Reviewed-by: Songhee Baek <sbaek@nvidia.com>
When device doesnt play audio power off codec and
disable extern1 clock to save power.
Bug 853161
Change-Id: I4392dc56e5f597566075f99a034e697bf56176ab
Reviewed-on: http://git-master/r/43980
Tested-by: Chandrakanth Gorantla <cgorantla@nvidia.com>
If HDMI driver is restarted in middle of audio playback due
to display resolution change or any other reason HDA goes
to bad state causing audio to be muted. Whenever HDA driver
gets hotplug notification in middle of audio playback
restart alsa pcm playback stream.
Bug 854284
Change-Id: Ia5af1e503faa7e501287a714c371df073cc31f2e
Reviewed-on: http://git-master/r/43233
Added suspend for tegra_wired_jack.
Disable tegra_wired_jack GPIO interrupts while going into suspend
and enable in resume.
Bug 827709
Change-Id: I1f5fd0e0adb437de883a5f897acd22c514e172cb
Reviewed-on: http://git-master/r/40363
Reviewed-on: http://git-master/r/42534
Tested-by: Shridhar Rasal <srasal@nvidia.com>
if headset is connected during bootup then it was not detected,
need to call handler function first time inorder to get status of
jack detection during bootup.
Change-Id: I39537ac071413717c34e0b13c8527a040c82521e
Reviewed-on: http://git-master/r/43063
Tested-by: Gerrit_Virtual_Submit
Added DAS functions to do custom connections where routing is not involved.
Added support for the tegra_pcm_tdm_hardware for handling the latency.
Addded support for the tegra_soc driver for AD1937 Codec
Made generic codec dais to be common for all platform of Tegra
Change-Id: I20a513f27f39273064ce90b973014c418e6d1362
Reviewed-on: http://git-master/r/42360
added headset and headphone detection logic
for maxim 98088 codec on enterprise board
Bug: 836629
Change-Id: I5405b52fbd81042816bc2a1d288f5fc32274f2b5
Reviewed-on: http://git-master/r/40774
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Acquire wake_lock from alsa kernel when pcm playback/capture
starts and hold it until playack/capture ends. It is needed
to prevent device from going into suspend state in middle
of audio playback.
Bug 827122
Change-Id: I25359f24dafda657756a3c2904d46e14b6675e7c
Reviewed-on: http://git-master/r/42336
Fix issue of right channel remains silent while stereo
recording through camera app.
Bug 851206
Change-Id: Ia6e4410ad9fea8ed14b7891ee6f66e602f782d47
Reviewed-on: http://git-master/r/41821
Tested-by: Manoj Gangwal <mgangwal@nvidia.com>
Reviewed-by: Viraj Karandikar <vkarandikar@nvidia.com>
corrected pin connection. Removed unused pins. Added missing sample
rates for i2s.
Change-Id: Ib12e9f5ee65c77b091e1d38107a83218c52f87d5
Reviewed-on: http://git-master/r/41550
Disable HDA related clocks when device is not connected
to HDMI. HDA clocks will be enabled from HDMI driver when
HDMI device is hot plugged.
Also register a reboot notifier so that HDA clocks can
be enabled during device reboot since HDA driver needs to
stop the azx chip during reboot.
Bug 820213
Change-Id: Ib962ac418edf25c5681f108b9a80577dc55c42af
Reviewed-on: http://git-master/r/40543
Split Headset to Headset Out and Headset In
Use IN1L for Int mic and Headset (for WM8903)
Remove unused variables and warning
Bug 846205
Reviewed-on: http://git-master/r/30142
Tested-by: Viraj Karandikar <vkarandikar@nvidia.com>
Reviewed-by: Manjula Gupta <magupta@nvidia.com>
Tested-by: Anssi Kalliolahti <akalliolahti@nvidia.com>
Reviewed-by: Vijay Mali <vmali@nvidia.com>
(cherry picked from commit 170ccc20d6227faaf196a920e7812792c305e2ff)
Change-Id: Iccf1736c4ba0d273c3c832d563374fc0afc63616
Reviewed-on: http://git-master/r/39374
This reverts commit c242bcd738fa47f833822f618eff4dbff092bde7.
Bug 820213
Bug 839572
Change-Id: I268a8c099ef75cd38b84aa31e35ab6417745cc10
Reviewed-on: http://git-master/r/40031
DAM rx1 is used for playback path.
DAM is added as default so for voicecall no need to teardown the
existing connection that is being used.
Needed for bug 804696
Change-Id: Iba4cec350595a32dfd71ede9e224620ebe84b1ba
Reviewed-on: http://git-master/r/38676
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
Use continuous single DMA mode instead of continuous double
to reduce the number of CPU interrupts during audio playback.
bug 840372
Change-Id: Id15dac5e2b29c612f4851b6b1d2e675b79ca047c
Reviewed-on: http://git-master/r/39855
Bug 820213
Change-Id: I4e6839aab0dc5277b11c415cbb495766f72442b8
Reviewed-on: http://git-master/r/36517
Reviewed-by: Niranjan Wartikar <nwartikar@nvidia.com>
This reverts commit ba038f38e6c0edd77dc65c28324ddd18185389fb.
It caused regression in camcoder usecase.
fixes bug 835818
Change-Id: I008a27d70b4e7066ec12f7d66d9d60e66ace0447
Reviewed-on: http://git-master/r/35434
Reviewed-by: Zhijun He <zhhe@nvidia.com>
bug 804696
DAM ch1 is added to default playback and record path.
Change-Id: Iecfa01a8d55d13928ee2ae6bd490eb3d28b679c3
Reviewed-on: http://git-master/r/32479
Change-Id: Ib0662de97f4f98461f1003747340bb9e16f96ebb
Reviewed-on: http://git-master/r/34258
Tested-by: Thomas Cherry <tcherry@nvidia.com>
Change-Id: Ie8c616482017c869cd46b8100f0428c1f92a3bcf
Reviewed-on: http://git-master/r/34238
Spdif driver resume was causing issue on resume stage.
Change-Id: I25c0d52889c4ff1b029053f744bee32023cf1a8f
Reviewed-on: http://git-master/r/32070
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Audio manager common interfaces are defined to be called from
SOC code. Audio manager will make the decision which all modules to
be controlled based on use case connection.
Correction added to the speaker amp and i2c gpio is provided for
controlling the speaker amplification. Removed the speakersetting call.
Change-Id: Id2c7f953fc78f66bee2e1d4773e03548de0ba5b4
Reviewed-on: http://git-master/r/30891
Exposed the baseband i2s port for cardhu.
Added separate audio init function.
Change-Id: I9ff38f101c5540ad6e2365ed93a8c88373164ea3
Reviewed-on: http://git-master/r/30087
Added the control code to enable/disable I2S Loopback accordingly.
Bug 725009
Change-Id: I3f172ef303dd4c6ac5bc41277e13e5405234a77e
Reviewed-on: http://git-master/r/30221
fixes bug 822278
Change-Id: I4444e3786660ab1402469543c0bc04020d4c5021
Reviewed-on: http://git-master/r/30234
Add max98088 codec driver what backported from 2.6.38 kernel.
Bug 816789
Change-Id: I5a0f6cfa0b29bd1f469ceb1e1d1d9e6634f7bed5
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/30337
added support for audio BT sco usecase. For BT sco, i2s is
programmed in pcm mode.
Change-Id: Iffcfb707cd2c025b78b82e70ba35f89d47a21263
Reviewed-on: http://git-master/r/30042
bug 820773
Fix the audio issue resulted from code merge.
Change-Id: I37999fabec7de077eac337db33eb2b01939349fc
Reviewed-on: http://git-master/r/29684
Original: http://git-master/r/28520
Change-Id: Ic6258c9a745e83595510789a6ed4c71c317ce1ba
Reviewed-on: http://git-master/r/29577
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Tested-by: Daniel Willemsen <dwillemsen@nvidia.com>
Change-Id: I25391126c593bd4738800c03bf3a65a0aa62ba92
Change-Id: Ieaa90cf40a7a5e190b73f83b6a17f43908377af4
