path: root/sound
2010-04-01Add support for WM8753 codec on the CCWMX51Justin Waters
2010-03-25ENGR00119104 MX23 ALSA: Resolve the problem of record from line-inLionel Xu
Resolve the line-in record problem. Signed-off-by: Lionel Xu <r63889@freescale.com>
2010-03-25ENGR00119150 Bluetooth: Handsfree audio has noiseWallace Wang
When bluetooth handsfree is enabled, sgtl5000 and bt sound cards are both opened. BT sound card playback can't use IRAM as sgtl5000 has used IRAM. The bt audio platform data - ext_ram is not set when kernel porting to 2.6.31. Signed-off-by: Wallace Wang <r59996@freescale.com>
2010-03-25ENGR00119005 ASRC: Remove unsupported sample rates from mixerWallace Wang
ASRC minmal output sample rate is 32000. When ASRC is used as ASRC-ESAI per_2_per mode, the unsupported sample rates should not be included in ASRC mixer. Signed-off-by: Wallace Wang <r59996@freescale.com>
2010-03-25ENGR00118544 iMX23 Clear dangerous macro stmp3xxx_setl(clearl)Frank.Li
No all regiser use _SCT. stmp3xxx_setl may write to wrong address. please use __raw_write (value, REG_XXX_SET) to write date to SCT register. Only REG_XXX_SCT is defined when it exist at hardware. Signed-off-by: Frank.Li <Frank.Li@freescale.com>
2010-03-25ENGR00118790 ASoC AC97 codec driverWallace Wang
Add ac97 mode support for SSI module Signed-off-by: Wallace Wang <r59996@freescale.com>
2010-03-25ENGR00117456: fix dac_get_volswAlan Tull
Fix shift direction. Don't return left channel value for both channels. Signed-off-by: Alan Tull <r80115@freescale.com>
2010-03-25ENGR00118701 MX25:Fix headphone plug-in caused system hangGuoqing Jiang
To keep system runs well after plugin headphone, replace disable_irq with disable_irq_nosync. Signed-off-by: Guoqing Jiang <b22156@freescale.com>
2010-03-25ENGR00118736 Mx35 ASoc: Trying to free already-free IRQ 240William Lai
Trying to free already-free IRQ 240 causes the warning dumped out when boot up the kernel. Return the error code in the probe function, which indicats the failure of the platform driver probing. Then the platform driver remove function will not be called, avoiding of freeing an already-free IRQ again. Signed-off-by: William Lai <b04597@freescale.com>
2010-03-25ENGR00118226 MX35 PM: System crashes when try to wake up from standbyWilliam Lai
The ak4647_codec is not initialized as there is no ak4647 codec existing on MX35 board. In the 31 kernel, the card and codec drivers are registered separately, and there is no check whether the codec is probed successfully or not. On MX35 board, the card is sucessfully registered, but there is no ak4647 codec. In this case, the system will crash if the system try to invoke the codec's resume function. To resolve the problem, add a check in registering the card. If the codec does not exist, give up registering the card either. Signed-off-by: William Lai <b04597@freescale.com>
2010-03-25ENGR00118016-3 wm8580: update to 2.6.31Alan Tull
wm8580 is using regulators that can't change state. The regulator driver doesn't handle this case well so it crashes during regulator_bulk_enable. Eventually this will be fixed in the regulator driver. For now, remove regulators from list in wm8580 driver. Fix spi_rw err. hw_write needs to return transferred data length. Signed-off-by: Alan Tull <r80115@freescale.com> Signed-off-by: Wallace Wang <r59996@freescale.com>
2010-03-25ENGR00118016-2 wm8350: update to 2.6.31Alan Tull
In WM8350_FLL_CONTROL_1, keep FLL_RATE at default. Don't mute outputs by default. Signed-off-by: Alan Tull <r80115@freescale.com>
2010-03-25ENGR00118016-1 ASoC : upgrade audio support to 2.6.31Alan Tull
Move regulator control into codec drivers. Move codec platform data to machine layer. Remove unused fields from mxc_audio_platform_data. soc multiple audio cards support: dai_list is a list for all registered codec/cpu dais. One codec/cpu dais can't be registered twice, so move the cpu dai registering into imx-ssi.c/imx-esai.c Fix ak4647_read_reg error. Put ssi/esai mode in the cpu_dai private_data. sgtl5000: Fix the power for MX35 1. MX35 vddio and vddd are directly connected to external 3V3. It has no regulator control. 2. sgtl5000 needs some time to be ready after vdda is switched on so msleep(1) is added before regiter read/write. 3. On MX35 platform, vdda is from VCAM. Signed-off-by: Alan Tull <r80115@freescale.com> Signed-off-by: Wallace Wang <r59996@freescale.com>
2010-03-25ASoC: Regulator support for WM8580Mark Brown
Add basic support for integration with the regulator API to WM8580. Since the core cannot yet disable biases when the CODEC is idle we simply request and enable the regulators for the entire time the driver is active. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-03-25ASoC: Fix WM835x Out4 capture enumerationMark Brown
It's the 8th enum of a zero indexed array. This is why I don't let new drivers use these arrays of enums... Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2010-03-25ASoC: Automatically manage WM8350 sloping stopband filterMark Brown
For best performance the DAC sloping stopband filter should be enabled below 24kHz and not enabled above that so remove the user visible control for this and do it autonomously in the driver. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-03-25ASoC: WM8350 capture PGA mutes are invertedMark Brown
2010-03-25ENGR00116479: Ported DVFS-CORE and audio pop issue from Apollo project.Ranjani Vaidyanathan-RA5478
Fix the audio pop issue that is caused whenever the system enters and exits LP-APM mode. Added some more working points for DVFS-CORE. Signed-off-by: Ranjani Vaidyanathan-RA5478 <Ranjani.Vaidyanathan@freescale.com>
2010-03-25ENGR00117389 Port 5.0.0 release to 2.6.31Rob Herring
This is i.MX BSP 5.0.0 release ported to 2.6.31 Signed-off-by: Rob Herring <r.herring@freescale.com> Signed-off-by: Alan Tull <r80115@freescale.com> Signed-off-by: Xinyu Chen <xinyu.chen@freescale.com>
2010-03-25soc: add wm8580 spi supportWallace Wang
Add spi interface support to wm8580 codec. Signed-off-by: Wallace Wang <r59996@freescale.com>
2009-09-05Merge branch 'fix/oxygen' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'fix/oxygen' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: sound: oxygen: handle cards with missing EEPROM sound: oxygen: fix MCLK rate for 192 kHz playback
2009-09-03sound: oxygen: handle cards with missing EEPROMClemens Ladisch
The card model detection code introduced in 2.6.30 that tries to work around partially broken EEPROM contents by reading the EEPROM directly does not handle cards where the EEPROM has been omitted. In this case, we have to use the default ID to allow the driver to load. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Reported-and-tested-by: Ozan Çağlayan <ozan@pardus.org.tr> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-09-01sound: oxygen: fix MCLK rate for 192 kHz playbackClemens Ladisch
Do not forget to program the MCLK ratio for the I2S output. Otherwise, the master clock frequency can be too high for the DACs at sample frequencies above 96 kHz. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-31Merge branch 'fix/hda' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'fix/hda' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: hda - Fix MacBookPro 3,1/4,1 quirk with ALC889A ALSA: hda - Add missing mux check for VT1708
2009-08-31ALSA: hda - Fix MacBookPro 3,1/4,1 quirk with ALC889ATakashi Iwai
This patch fixes the wrong headphone output routing for MacBookPro 3,1/4,1 quirk with ALC889A codec, which caused the silent headphone output. Also, this gives the individual Headphone and Speaker volume controls. Reference: kernel bug#14078 http://bugzilla.kernel.org/show_bug.cgi?id=14078 Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: <stable@kernel.org>
2009-08-31ALSA: hda - Add missing mux check for VT1708Takashi Iwai
In patch_vt1708(), the check of MUX nids is missing and this results in the -EINVAL error in accessing Input Source mixer element. Simpliy adding the call of get_mux_nids() fixes the problem. Reference: Novell bnc#534904 https://bugzilla.novell.com/show_bug.cgi?id=534904 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-25Merge branch 'fix/misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'fix/misc' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: sound: pcm_lib: fix unsorted list constraint handling sound: vx222: fix input level control range check ALSA: ali5451: fix timeout handling in snd_ali_{codecs,timer}_ready()
2009-08-25sound: pcm_lib: fix unsorted list constraint handlingClemens Ladisch
snd_interval_list() expected a sorted list but did not document this, so there are drivers that give it an unsorted list. To fix this, change the algorithm to work with any list. This fixes the "Slave PCM not usable" error with USB devices that have multiple alternate settings with sample rates in decreasing order, such as the Philips Askey VC010 WebCam. http://bugzilla.kernel.org/show_bug.cgi?id=14028 Reported-and-tested-by: Andrzej <adkadk@gmail.com> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-24sound: vx222: fix input level control range checkClemens Ladisch
Fix a logic error in the range check of the input level control that would prevent setting any volume less than the maximum. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-23ALSA: ali5451: fix timeout handling in snd_ali_{codecs,timer}_ready()Bartlomiej Zolnierkiewicz
Modify loops in such way that the register value is checked also after the timeout condition, just in case the heavy interrupt load etc. caused the thread to sleep for the time period exceeding the timeout value. While at it remove an extra ALI_STIMER read from snd_ali_stimer_ready(). Reported-by: Jack Byer <ojbyer@usa.net> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-20Merge branch 'fix/hda' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'fix/hda' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: hda - Fix probe of Toshiba laptops with ALC268 codec ALSA: hda: add model for Intel DG45ID/DG45FC boards ALSA: hda: enable speaker output for Compaq 6530s/6531s
2009-08-19ALSA: hda - Fix probe of Toshiba laptops with ALC268 codecTakashi Iwai
There are many variants of Toshiba laptops with ALC268 codec, and it seems that a few of them don't work with model=toshiba preset since they have the secondary ALC268 codec just for HDMI output. This is a regression due to the previous clean-up work to merge all Toshiba quirk entries into a single check. This patch adds the identification of such laptops to apply the standard BIOS-probing method. Unfortunately, Toshiba laptops have all the same PCI SSID, so we need to check the codec SSID to identify each device. Tested-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-19ALSA: hda: add model for Intel DG45ID/DG45FC boardsWu Fengguang
The BIOS pin configs are in fact correct and shall not be overwritten. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-19ALSA: hda: enable speaker output for Compaq 6530s/6531sWu Fengguang
HP Compaq 6530s and 6531s internal speaker is silence or becomes silence within 1 minute after fresh boot. It is found that pin 0x1c must be set to PIN_OUT mode to make the speaker work. This is weird - line-in pin 0x1c and speaker pin 0x16 seem to be unrelated. The codec differences before/after patch are: @@ Node 0x17 [Pin Complex] wcaps 0x40020b: Pin Default 0x41a6e130: [N/A] Mic at Ext Rear Conn = Digital, Color = White DefAssociation = 0x3, Sequence = 0x0 Misc = NO_PRESENCE - Pin-ctls: 0x24: IN + Pin-ctls: 0x40: OUT @@ Node 0x1c [Pin Complex] wcaps 0x40018d: Pin Default 0x41813021: [N/A] Line In at Ext Rear Conn = 1/8, Color = Blue DefAssociation = 0x2, Sequence = 0x1 - Pin-ctls: 0x24: IN VREF_80 + Pin-ctls: 0x40: OUT VREF_HIZ Unsolicited: tag=00, enabled=0 Connection: 1 0x24 Tests show that it won't impact (external) Mic recording. Reported-by: "Lin, Ming M" <ming.m.lin@intel.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-12Merge branch 'fix/hda' into for-linusTakashi Iwai
* fix/hda: ALSA: hda - Don't override ADC definitions for ALC codecs ALSA: hda - Add missing vmaster initialization for ALC269
2009-08-12Merge branch 'fix/asoc' into for-linusTakashi Iwai
* fix/asoc: ASoC: Add missing DRV_NAME definitions for fsl/* drivers
2009-08-11ALSA: hda - Don't override ADC definitions for ALC codecsTakashi Iwai
ALC269 and ALC861-VD parsers override the ADC definitions unconditionally without checking the spec definition. This causes the problem when any inconsistent ADC is set up in the device quirk (like ALC272 with digital-mic). This patch avoids the overriding by adding the proper checks. Reference: Novell bnc#529467 https://bugzilla.novell.com/show_bug.cgi?id=529467 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-10ALSA: hda - Add missing vmaster initialization for ALC269Takashi Iwai
Without the initialization of vmaster NID, the dB information got confused for ALC269 codec. Reference: Novell bnc#527361 https://bugzilla.novell.com/show_bug.cgi?id=527361 Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: <stable@kernel.org>
2009-08-07ASoC: Add missing DRV_NAME definitions for fsl/* driversTakashi Iwai
Module builds are broken due to missing DRV_NAME for efika-audio-fabric and pcm030-audio-fabric. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-04Merge branch 'fix/hda' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'fix/hda' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: hda - Read buffer overflow ALSA: hda: Correct EAPD for Dell Inspiron 1525 ALSA: hda: warn on spurious response ALSA: hda: remember last command for each codec ALSA: hda: read CORBWP inside reg_lock ALSA: hda: take reg_lock in azx_init_cmd_io/azx_free_cmd_io ALSA: hda: take cmd_mutex in probe_codec() ALSA: hda: track CIRB/CORB command/response states for each codec ALSA: hda - Fix quirk for Toshiba Satellite A135-S4527
2009-08-03ALSA: hda - Read buffer overflowRoel Kluin
Check whether index is within bounds before testing the element. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-03ALSA: hda: Correct EAPD for Dell Inspiron 1525Chengu Wang
The commit 24918b61b55c21e09a3e07cd82e1b3a8154782dc statically changes the model from dell-bios to dell-3stack to solve the sound decreasing regression (http://lkml.org/lkml/2008/9/12/203), however it leads to another problem that the 2nd headphone jack doesn't work (https://bugtrack.alsa-project.org/alsa-bug/view.php?id=3987). So I think the commit 249**2dc is just a workaround. I would like to give a true solution here. The datasheet for STAC9228 says, GPIO2 is the same pin as VOL DOWN, and the EAPD pin is GPIO0. This is why the sound decreases if we set EAPD as GPIO2. This patch changes EAPD to GPIO0 to solve the problem. Signed-off-by: Chengu Wang <wangchengu@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-03ALSA: hda: warn on spurious responseWu Fengguang
To help disclose hardware bugs. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-03ALSA: hda: remember last command for each codecWu Fengguang
2009-08-03ALSA: hda: read CORBWP inside reg_lockWu Fengguang
This converts the last CORBWP access outside of reg_lock. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-03ALSA: hda: take reg_lock in azx_init_cmd_io/azx_free_cmd_ioWu Fengguang
Just for safety. azx_init_cmd_io() and azx_free_cmd_io() may be called when switching to single command mode. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-03ALSA: hda: take cmd_mutex in probe_codec()Wu Fengguang
Now that each codec will have its own module, it is possible for the user to load one codec while another one is running. So cmd_mutex would be a safe addition to probe_codec(). Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-03ALSA: hda: track CIRB/CORB command/response states for each codecWu Fengguang
Recently we hit a bug in our dev board, whose HDMI codec#3 may emit redundant/spurious responses, which were then taken as responses to command for another onboard Realtek codec#2, and mess up both codecs. Extend the azx_rb.cmds and azx_rb.res to array and track each codec's commands/responses separately. This helps keep good codec safe from broken ones. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-03ALSA: hda - Fix quirk for Toshiba Satellite A135-S4527Takashi Iwai
Use model=lenovo instead of model=dallas for Toshiba Satellite A135-S4527 with ALC861-VD codec. Reference: Novell bnc#526325 https://bugzilla.novell.com/show_bug.cgi?id=526325 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-07-31Merge branch 'fix/oss' into for-linusTakashi Iwai
* fix/oss: sound: mpu401.c: Buffer overflow sound: aedsp16: Buffer overflow
