path: root/sound
2005-10-24[PATCH] ALSA: Fix Oops of suspend/resume with generic driversTakashi Iwai
The patch fixes Oops from sound drivers using generic platform device but have no suspend/resume callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-07[ALSA] usb-audio: add MIDI quirk for Hercules DJ ConsoleClemens Ladisch
USB generic driver Add a quirk entry for the external MIDI ports of the Windows Edition of the Hercules DJ Console. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-10-07[ALSA] usb-audio: add another ID for Hercules DJ ConsoleClemens Ladisch
USB generic driver Add a mixer quirk entry for the Hercules DJ Console (Windows Edition) that uses a different USB product ID. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-10-07[ALSA] ali5451 - Don't build non-existing modem PCMTakashi Iwai
ALI5451 driver Don't build the modem PCM if the corresponding codec isn't detected. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-07[ALSA] emu10k1 - Fix handling of ac97_chip=2Takashi Iwai
EMU10K1/EMU10K2 driver Fixed the handling of ac97_chip=2 capability type. The error occurs in snd_ac97_mixer(), not in snd_ac97_bus(). Also, release the unnecessary ac97_bus object in the error path. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-07[ALSA] korg1212: fix typoClemens Ladisch
KORG1212 driver Add a missing comma that made the stateName array one entry too short. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-10-07[ALSA] emu10k1 - Fix loading of SBLive Game boardTakashi Iwai
EMU10K1/EMU10K2 driver Fixed the error at loading SBLive Game board (and possible other models). The PCI SSIDs of this board conflicts with SB Live 5.1 Platinum, which has no AC97 chip. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-07[ALSA] via82xx - dxs_support entry for an ASUS moboTakashi Iwai
VIA82xx driver Addded a dxs_support entry for an ASUS mobo. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-07[ALSA] Fix confliction of capture controls on ALC880 test modelTakashi Iwai
HDA Codec driver Fixed the confliction of capture controls on ALC880 'test' model. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-07[ALSA] fix HD audio ALC882 lfe (un)muteJohn W. Linville
HDA Codec driver Mark the ALC882 'LFE Playback Switch' as an input, like the other playback switch settings. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-07[ALSA] fix alc880_test_mixer typoJohn W. Linville
HDA Codec driver Fix a typo (cut & paste) in the alc880_test_mixer structure. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-07[ALSA] fix HD audio ALC260 mono (un)muteJohn W. Linville
HDA Codec driver The ALC260 'Mono Playback Switch' is marked as an output in patch_realtek.c. It actually does not work unless it is marked as an input. Go figure... This was tested and confirmed on an HP xw4300. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-07[ALSA] usb-audio: increase max buffer sizeClemens Ladisch
USB generic driver Increase the maximum PCM buffer size to 1 MB. The USB driver doesn't have any inherent buffer size limit, and big multichannel interfaces may benefit from this. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-10-07[ALSA] usb-audio: add another ID for the TerraTec PHASE26Clemens Ladisch
USB generic driver There is another revision of the PHASE26 with a different product ID; add a quirk entry for that, too. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-10-07[ALSA] usb-audio: add more Yamaha USB MIDI devicesClemens Ladisch
USB generic driver Add quirk entries for four unknown Yamaha USB MIDI devices. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-10-07[ALSA] Add iBook 1.33GHz supportTakashi Iwai
PPC PMAC driver Added the support of iBook 1.33GHz. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-07[ALSA] usb-audio: add Roland RD-700SX supportClemens Ladisch
USB generic driver Add a quirk entry for the Roland RD-700SX. This should work for the RD-300SX, too. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-10-07[ALSA] via82xx - Add a dxs whitelist entryTakashi Iwai
VIA82xx driver Added a dxs whitelist entry for an ECS mobo. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-07[ALSA] clean suspend/resume calls for ac97_bus_typeNicolas Pitre
AC97 Codec A single call to the driver suspend/resume method for each device is enough. The level and SUSPEND_*/RESUME_* arguments are deprecated and said to be removed eventually anyway (no other subsystem are using them anymore except platform devices). Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-07[ALSA] remove redundent assignment to the ac97 device structureNicolas Pitre
AC97 Codec Don't use dev.platform_data to store a reference to the containing ac97_t structure. Such assignment is redundent since we can deduce the ac97_t structure location from the contained device structure. This sets platform_data free for other purposes. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-07[ALSA] remove bogus match method for ac97_busNicolas Pitre
AC97 Codec The bus_id is initialized with a generic identifier string which is not really useful for proper driver matching. Let the driver decide what it needs via its probe method instead. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-07[ALSA] usb-audio: ignore Hercules DJ Console mixer errorsClemens Ladisch
USB generic driver Add a quirk entry for the Hercules DJ Console to ignore timeouts on some mixer control transfers. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-10-07[ALSA] Fix pm_message_t in PXA2XX-AC97 driverDirk Opfer
ARM PXA2XX driver Fix pm_message_t in PXA2XX-AC97 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-07[ALSA] hda-intel - Disable DMA position auto-correctionTakashi Iwai
HDA Intel driver Disable the auto-correction of DMA position temporarily. It doesn't work as expected yet... Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-07[ALSA] hda-codec - 'empty' generic mfg-only codecSasha Khapyorsky
HDA generic driver This creates 'empty' hda generic for unknown MFG-only codecs. Signed-off-by: Sasha Khapyorsky <sashak@smlink.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-07[ALSA] no templated index for si3036 modem controlsSasha Khapyorsky
AC97 Codec No index is templated for si3036 modem controls. Signed-off-by: Sasha Khapyorsky <sashak@smlink.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-07[ALSA] no templated index for mc97 controlsSasha Khapyorsky
AC97 Codec No index is templated for mdoem controls. Signed-off-by: Sasha Khapyorsky <sashak@smlink.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-07[ALSA] snd_opl3sa2: add missing pnp_unregister_driver() callsDaniel Ritz
OPL3SA2 driver Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-22[PATCH] oss: don't concatenate __FUNCTION__ with stringsClemens Buchacher
It's deprecated. Use "%s", __FUNCTION__ instead. Signed-off-by: Clemens Buchacher <drizzd@aon.at> Signed-off-by: Maximilian Attems <janitor@sternwelten.at> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] atiixp_modem printk fixesChuck Ebbert
Correctly identify atiixp_modem in its error messages. Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Cc: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-21[SPARC] cs4231: Fix SBUS support in this driver.Christopher Zimmermann
From: Christopher Zimmermann <madroach@zakweb.de> This patch enables SBus support for the cs4231 sound driver. It is tested on an Ultra2. Capture and playback both work. I experienced lags and crashes using certain threaded players like ogg123 and mp3blaster, while the former is lagging far more. This behavior may be specific to SMP systems. It is reproducable using the dummy sound card driver. Sox works flawlessly. Setting up the calculation of ptr in snd_cs4231_playback_pointer was a bit strange. I got it to work by not incrementing the [pc]_periods_sent counter when starting DMA the first time in cs4231_dma_trigger. Therefore this dummy thing. [ I did some minor cleanups -DaveM ] Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-17[PATCH] Fix up some pm_message_t typesRichard Purdie
Fix up some pm_message_t types Signed-Off-By: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-14[PATCH] add PCI IDs so RME32 and RME96 drivers buildRoland Dreier
While doing an allyesconfig build, I noticed that the commit commit 8cdfd2519c6c9a1e6057dc5970b2542b35895738 Author: Takashi Iwai <tiwai@suse.de> Date: Wed Sep 7 14:08:11 2005 +0200 [ALSA] Remove superfluous PCI ID definitions broke the RME32 and RME96 drivers, since the PCI IDs they use seem to have changed names. Here's a patch to fix this -- compile tested only, since I have no idea what the hardware even is. Fix the build of the RME32 and RME96 drivers by having them use the PCI_DEVICE_ID_RME_xxx names defined in <linux/pci_ids.h> instead of the PCI_DEVICE_ID_xxx names that they used to define themselves. Also fix the typo in the id PCI_DEVICE_IDRME__DIGI96_8_PAD_OR_PST so the name is PCI_DEVICE_ID_RME_DIGI96_8_PAD_OR_PST. Signed-off-by: Roland Dreier <rolandd@cisco.com> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-12[ALSA] set owner field in struct pci_driverClemens Ladisch
AD1889 driver,ALS4000 driver,ATIIXP driver,ATIIXP-modem driver AZT3328 driver,BT87x driver,CMIPCI driver,CS4281 driver ENS1370/1+ driver,ES1938 driver,ES1968 driver,FM801 driver Intel8x0 driver,Intel8x0-modem driver,Maestro3 driver,RME32 driver RME96 driver,SonicVibes driver,VIA82xx driver,VIA82xx-modem driver ALI5451 driver,au88x0 driver,CS46xx driver,EMU10K1/EMU10K2 driver HDA Intel driver,ICE1712 driver,ICE1724 driver,KORG1212 driver MIXART driver,NM256 driver,RME HDSP driver,RME9652 driver Trident driver,Digigram VX222 driver,YMFPCI driver Set the module owner field in each driver's struct pci_driver to get the driver symlink in the sysfs device directory. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-09-12[ALSA] Several fixes for the Sun DBRI driverMartin Habets
SPARC DBRI driver This patch contains the following fixes to the Alsa DBRI driver: - Remove 2.6.13 build warning on the prom_getproperty() call. - Rework command synchronization: send a sequence number with D_WAIT, and check it in the completion interrupt. Move synchronization delays from _cmdsend() to _cmdlock() allowing the CPU to do other usefull things while the DBRI is processing the commands. - Fix first argument of printk() calls. - Enable burst transfers for DBRI. Original 2.4 patch from Krzysztof Helt - Make dbri_debug module parameter writable from sysfs. Remove obsolete write access to the /proc debug file. - Replace udelay() with msleep_interruptible() where possible. - Update documentation comments. Signed-off-by: Martin Habets <errandir_news@mph.eclipse.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] snd-emu10k1: ALSA bug#1297: Fix a error recognising the SB Live Platinum.James Courtier-Dutton
EMU10K1/EMU10K2 driver The card does not have an AC97 chip. .subsystem = 0x80611102 Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
2005-09-12[ALSA] Replace with kzalloc() - othersTakashi Iwai
Documentation,SA11xx UDA1341 driver,Generic drivers,MPU401 UART,OPL3 OPL4,Digigram VX core,I2C cs8427,I2C lib core,I2C tea6330t,L3 drivers AK4114 receiver,AK4117 receiver,PDAudioCF driver,PPC PMAC driver SPARC AMD7930 driver,SPARC cs4231 driver,Synth,Common EMU synth USB generic driver,USB USX2Y Replace kcalloc(1,..) with kzalloc(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Replace with kzalloc() - pci stuffTakashi Iwai
AD1889 driver,ATIIXP driver,ATIIXP-modem driver,AZT3328 driver BT87x driver,CMIPCI driver,CS4281 driver,ENS1370/1+ driver ES1938 driver,ES1968 driver,FM801 driver,Intel8x0 driver Intel8x0-modem driver,Maestro3 driver,SonicVibes driver,VIA82xx driver VIA82xx-modem driver,AC97 Codec,AK4531 codec,au88x0 driver CA0106 driver,CS46xx driver,EMU10K1/EMU10K2 driver,HDA Codec driver HDA generic driver,HDA Intel driver,ICE1712 driver,ICE1724 driver KORG1212 driver,MIXART driver,NM256 driver,Trident driver,YMFPCI driver Replace kcalloc(1,..) with kzalloc(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Replace with kzalloc() - isa stuffTakashi Iwai
ES18xx driver,OPL3SA2 driver,AD1816A driver,AD1848 driver,CS4231 driver ES1688 driver,GUS Library,Opti9xx drivers,EMU8000 driver SB16/AWE driver,SB drivers Replace kcalloc(1,..) with kzalloc(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Replace with kzalloc() - seq stuffTakashi Iwai
ALSA sequencer,Instrument layer,ALSA<-OSS sequencer Replace kcalloc(1,..) with kzalloc(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Replace with kzalloc() - core stuffTakashi Iwai
Control Midlevel,ALSA Core,HWDEP Midlevel,PCM Midlevel,RawMidi Midlevel Timer Midlevel,ALSA<-OSS emulation Replace kcalloc(1,..) with kzalloc(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] hda-codec - Added ASUS A6Takashi Iwai
HDA Codec driver Added ASUS A6 support for ALC880 codec. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] intel8x0 - Add buggy_semaphore optionTakashi Iwai
Documentation,Intel8x0 driver Added buggy_semaphore module option to snd-intel8x0 driver for a workaround for hardwards with buggy codec semaphores. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] pcm-oss - Add bugg-yptr optionTakashi Iwai
Documentation,ALSA<-OSS emulation Added 'buggy-ptr' proc option to switch the behavior of GETOPTR ioctl. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] powermac - Add AUTO_DRC configTakashi Iwai
PPC,PPC Tumbler driver Added AUTO_DRC kernel config to enable/disable the auto-DRC-toggle feature on tumbler/snapper. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] hda-intel - Fix modem PCM creationTakashi Iwai
HDA Intel driver Fix a bug of modem PCM creation (due to a typo). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] pci_find_device removeJiri Slaby
Memalloc module,CS46xx driver,VIA82xx driver,ALI5451 driver au88x0 driver Replace pci_find_device() with pci_get_device() and pci_dev_put(). Signed-off-by: Jiri Slaby <xslaby@fi.muni.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Remove superfluous PCI ID definitionsTakashi Iwai
CS46xx driver,EMU10K1/EMU10K2 driver,PCM Midlevel,Trident driver YMFPCI driver,BT87x driver,CMIPCI driver,CS4281 driver ENS1370/1+ driver,ES1938 driver,ES1968 driver,Intel8x0 driver Intel8x0-modem driver,Maestro3 driver,RME32 driver,RME96 driver SonicVibes driver,VIA82xx driver,ALI5451 driver,ICE1712 driver ICE1724 driver,NM256 driver,RME HDSP driver,RME9652 driver Remove superfluous PCI ID definitions. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Fix DocBook warningsTakashi Iwai
PCM Midlevel,RawMidi Midlevel Fix DocBook warnings. Signed-off-by: Takashi Iwai <tiwai@suse.de>
