In order to keep sndfx file in sync with audiofx header
file updating tegra_sndfx.h with structures and
definitions, made the corresponding changes in code.
Verified both playback and record are working fine.
For bug 676616
synopsis: ALSA is Broken
Change-Id: Ic3eca9e88c861169bcbcc829a621adc40ea2bea7
Reviewed-on: http://git-master/r/1158
Reviewed-by: Vijay Mali <vmali@nvidia.com>
Tested-by: Vijay Mali <vmali@nvidia.com>
Reviewed-by: Manjula Gupta <magupta@nvidia.com>
Tested-by: Manjula Gupta <magupta@nvidia.com>
Reviewed-by: Gary King <gking@nvidia.com>
Change-Id: Ibfa400fcf1b62c55f169d427ae40aa9467d13f82
Reviewed-on: http://git-master/r/1079
- Don't signal the shutdown thread until the thread
process the SNDRV_PCM_TRIGGER_STOP call. The Kthread_stop()
call is a blocking call that waits until the kthread_should_stop()
returns.
- Set the prtd->state to SNDRV_PCM_TRIGGER_STOP in pcm_common_close
specifically to ensure proper clean-up and to handle the case
where application exits without triggering the STOP call.
- wait for the buffer done notification for the buffers queued in
before setting mixer state to stop.
- For Bug 667787 [LDK/Whistler/ALSA]"arecord" app hung
with DVD quality .raw audio recording (Mono/Stereo).
Change-Id: Id9c13bbd2dd0b5f90b3c545677eddfa05849c45f
Reviewed-on: http://git-master/r/997
Add mmap callback in alsa to support mmap mode.
For Bug:66326 [LDK/Whistler/ALSA] Add the mmap
support in ALSA.
Change-Id: Iecc128374ff365ef4fb92034d6256c6378bd1f20
Reviewed-on: http://git-master/r/909
Replace NvOsSemaphore functions with linux semaphore.
Fixed repeated playback of last few samples.
Fixes bugs 652423, 652406
Change-Id: I679e67585a00884eb6169a39cb14dd5389e28ab8
Reviewed-on: http://git-master/r/706
In order to keep this file in sync with audiofx header file
replcaing all enums by #defines, for better grouping of
properties. As ALSA transoprt is tightly coupled to audiofx
transport, adding a member in middle of existing enum was
causing regressions in ALSA. #defines will allow adding new
properties without breaking existing functionality.
Change-Id: Iab57b14af3bcc318f6d83436ffecbc16808bb2ce
android-tegra-2.6.29
adding in properties namely PowerState and EndOfStream.
- Add SRC and convert pin in Standard Input Path.
- Modify the TEGRA_DEFAULT_BUFFER_SIZE to 8KB,
it fixes the breaks in 8bit Mono playback.
- Add S16_BE in supported format to support .au format.
Sample data and other fields are stored in Big endian
form in a-law(au) format.
- Fix review comments on Patch Set 1.
For Bug [LDK/Whistler/ALSA] Attempt to a-law(au)
audio record results application/device hang(9/10).
Change-Id: I8be2b8c85506ae60f10d5a0318e34a888be9e71c
Added support for all sample rates and bitrates, channels
in ALSA SoC driver. Removed unevenly configured i2s, pcm and
codec dai structures. with this change all three dais are
evenly configured and support all pcm formats for playback
and recording
For bug 651142 Cant play 8bit (44.1Khz/48Khz)WAV streams
(cherry picked from commit b0e4084126804700b34deedf6b9c496c121dc868)
Added stub audio codec in alsa soc driver Removing platform
dependent source files. ALSA driver is not doing audio codec
initilization. It happens in audiofx. Got rid of unwanted
I2C prints which were coming from wm8753 reg_write function.
For bug 650664 Getting error while booting
NvRmI2Ctransaction Failed:No I2C
Add audio SoC support for the NVIDIA Tegra SoC and the Harmony and
Whistler development platforms.
- single-link rpc dai driver to audio processor
- basic machine driver for harmony and whistler platforms
supports basic playback and record.
Change-Id: Ifad3b503f1bfa0000440c9473f0a932f406a7731
MAINTAINERS
arch/arm/Kconfig
arch/arm/Makefile
arch/arm/boot/compressed/head.S
arch/arm/common/Makefile
arch/arm/configs/realview-smp_defconfig
arch/arm/configs/realview_defconfig
arch/arm/configs/versatile_defconfig
arch/arm/include/asm/elf.h
arch/arm/include/asm/uaccess.h
arch/arm/kernel/module.c
arch/arm/kernel/signal.c
arch/arm/mach-realview/Kconfig
arch/arm/mach-realview/Makefile
arch/arm/mach-realview/core.c
arch/arm/mach-realview/core.h
arch/arm/mach-realview/include/mach/board-pba8.h
arch/arm/mach-realview/include/mach/debug-macro.S
arch/arm/mach-realview/include/mach/hardware.h
arch/arm/mach-realview/include/mach/irqs.h
arch/arm/mach-realview/include/mach/memory.h
arch/arm/mach-realview/include/mach/uncompress.h
arch/arm/mach-realview/localtimer.c
arch/arm/mach-realview/platsmp.c
arch/arm/mach-realview/realview_eb.c
arch/arm/mach-realview/realview_pb1176.c
arch/arm/mach-realview/realview_pb11mp.c
arch/arm/mach-realview/realview_pba8.c
arch/arm/mm/Kconfig
arch/arm/mm/copypage-v6.c
arch/arm/mm/dma-mapping.c
arch/arm/mm/proc-v7.S
arch/arm/oprofile/op_model_mpcore.c
arch/arm/tools/mach-types
arch/arm/vfp/vfpmodule.c
drivers/mtd/maps/integrator-flash.c
drivers/net/smsc911x.c
drivers/net/smsc911x.h
Subject: [PATCH] aaci: ARM1176 aaci-pl041 AC97 register read timeout
After a reboot on an ARM1176 which amounts to a softreset, it has been
noted that the ALSA driver does not get registered and the probe fails
with the error "aaci-pl041 fpga:04: ac97 read back fail". In the process
of reading from a register the SL1TxBusy bit is set indicating that the
transceiver is busy and remains so until the default timeout occurs.
Set the Power down register 0x26 to an arbitrary value as specified in
the PL041 manual (page: 3-18) so that AACISL1TX/AACISL2TX registers take
their default state.
Signed-off-by: Philby John <pjohn@in.mvista.com>
In snd_free_sgbuf_pags(), vunmap() is called after releasing the SG
pages, and it causes errors on Xen as Xen manages the pages
differently. Although no significant errors have been reported on
the actual hardware, this order should be fixed other way round,
first vunmap() then free pages.
Cc: Jan Beulich <jbeulich@novell.com>
Cc: <stable@kernel.org>
There is an omitted unlock in one snd_mixart_hw_params fail path. Fix it.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
s/mutex_lock/mutex_unlock/ on 2 fail paths in snd_pcm_oss_proc_write.
Probably a typo, lock should be unlocked when leaving the function.
At the time of initialization, SNDRV_MIXER_OSS_PRESENT_PVOLUME bit is not
set for MIC (slot 7).
So, the same should not be checked when an application tries to do gain
control for audio recording devices.
Just check slot->present for SNDRV_MIXER_OSS_PRESENT_CVOLUME independently.
Verified with a simple application which opens /dev/dsp for recording and
/dev/mixer for volume control.
Have tested two usb audio mic devices.
Signed-off-by: Viral Mehta <viral.mehta@einfochips.com>
The position-buffer on ATI controllers are unreliable as well as
on VIA chips, thus the same workaround for DMA position reading as
VIA is useful for ATI.
ATI controllers (at least some SB0600 models) appear buggy to handle
64bit DMA. As a workaround, reset GCAP bit0 and let the driver to
use only 32bit DMA on these controllers.
Fix the OOPS during a opl3sa2 card suspend
and resume if the driver is loaded but the card
is not found.
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'fix/hda' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: hda - Fix headphone-detect regression with multiple HP jacks
ALSA: hda - Fix typos in slave controls in patch_sigmatel.c
The recent changes over the DAC detection mechanism in patch_sigmatel.c
breaks the HP detection on the machines with multiple HP jacks.
It's basically because of the workaround to support the multi-channel
output. Since the HP detection is more important feature, disable
the HP-swap workaroud temporarily.
Reference: Novell bnc#482052
https://bugzilla.novell.com/show_bug.cgi?id=482052
"Headphone Playback ..." appears twice in slave_vols[] and slave_sws[].
They should be "Headphone Playback2 ..."
ALSA: hda - Add probe_mask default for Toshiba laptop with ALC268
ALSA: hda - Add quirk for new HP xw series
ALSA: hda - Fix digital mic on dell-m4-1 and dell-m4-3
Some Toshiba laptops have another ALC268 codec on slot#3 that conflicts
with the primary codec. The codec#3 is for the digital I/O, and should
be fixed by the driver, but it'd need a bunch of changes.
So, let's fix the probe problem temporarily by setting the default
probe_mask value.
Reference: kernel bugzilla #12735
http://bugzilla.kernel.org/show_bug.cgi?id=12735
Tested-by: Alexey Dobriyan <adobriyan@gmail.com>
Added model=hp-bpc for new HP xw series (103c:170b).
Fix num_dmuxes initialization for dell-m4-1 and dell-m4-3 models
of IDT 92HD71bxx codec, which was wrongly set to zero.
Fix the inverted logic of shared spdif switch.
Reference: Novell bnc#478496
https://bugzilla.novell.com/show_bug.cgi?id=478496
The Acer Aspire 6530G needs the 4930G "model" for the front mic to
work properly.
Reference: Ubuntu bug #33245
https://bugs.launchpad.net/bugs/332456
Signed-off-by: Luke Yelavich <themuso@ubuntu.com>
Incorrect variable was used to get the next sample which caused S2
to be stuck with the same value resulting in loud background noise.
Signed-off-by: Steve Chen <schen at mvista.com>
Audiowerk2 driver snd-aw2 is bound to any saa7146 device as it does not
check subsystem ids. Many DVB devices are saa7146 based, so aw2 driver
grabs them as well.
According to http://lkml.org/lkml/2008/10/15/311 aw2 devices have the
subsystem ids set to 0, the saa7146 default.
Fix conflicts with DVB devices by checking for subsystem ids = 0
specifically.
Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com>
http://kisskb.ellerman.id.au/kisskb/buildresult/72115/:
| net/mac80211/ieee80211_i.h:327: error: syntax error before 'volatile'
| net/mac80211/ieee80211_i.h:350: error: syntax error before '}' token
| net/mac80211/ieee80211_i.h:455: error: field 'sta' has incomplete type
| distcc[19430] ERROR: compile net/mac80211/main.c on sprygo/32 failed
This is caused by
| # define mfp ((*(volatile struct MFP*)MFP_BAS))
in arch/m68k/include/asm/atarihw.h, which conflicts with the new "mfp" enum in
net/mac80211/ieee80211_i.h.
Rename "mfp" to "st_mfp", as it's a way too generic name for a global #define.
Fixed the parse of init_verbs hwdep sysfs entry.
Simplieied using sscanf.
The usage and comments make it clear values of 1/0 were intended
rather than -1/0
Noticed by sparse:
sound/pci/pcxhr/pcxhr.h:100:20: error: dubious one-bit signed bitfield
sound/pci/pcxhr/pcxhr.h:101:22: error: dubious one-bit signed bitfield
sound/pci/pcxhr/pcxhr.h:102:24: error: dubious one-bit signed bitfield
sound/pci/pcxhr/pcxhr.h:103:21: error: dubious one-bit signed bitfield
sound/pci/pcxhr/pcxhr.h:104:25: error: dubious one-bit signed bitfield
sound/pci/pcxhr/pcxhr.h:105:20: error: dubious one-bit signed bitfield
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This reverts commit 7e86c0e6850504ec9516b953f316a47277825e33 ("do not
overwrite EEPROM on Xonar D2/D2X") because it did not actually help with
the problem.
More user reports show that the overwriting of the EEPROM is not
triggered by using this driver but by installing Linux, and that the
installation of any other operating system (even one without any CMI8788
driver) has the same effect. In other words, the presence of this
driver does not have any effect on the occurrence of the error. (So
far, the available evidence seems to point to a BIOS bug.)
Furthermore, it turns out that the EEPROM chip is protected against
stray write commands by the command format and by requiring a separate
write-enable command, so the error scenario in the previous commit (that
SPI writes can be misinterpreted as an EEPROM write command) is not even
theoretically possible.
The mixer control that was removed as a consequence of the previous
commit can only be partially emulated in userspace, which also means it
cannot be seen be the in-kernel OSS API emulation, so it is better to
revert that change.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Currently the jack layer refers to card->longname as a part of
its input device name string. However, longname is often really long
and way too ugly as an identifier, such as,
"HDA Intel at 0xf8400000 irq 21".
This patch changes the code to use card->shortname instead.
The shortname string contains usually the h/w vendor and product
names but without messy I/O port or IRQ numbers.
The CM6207 incorrectly advertises its 96 kHz playback setting as 48 kHz
in its USB device descriptor. This patch extends an existing workaround
in usbaudio.c to also cover the CM6207.
This resolves issue 0004249 in the ALSA bug tracker.
Signed-off-by: Joris van Rantwijk <jorispubl@xs4all.nl>
The detection of non-continuous rates (given via rate tables) isn't
processed properly (e.g. for type II).
This patch fixes and simplifies the detection code.
Tested-by: Joris van Rantwijk <jorispubl@xs4all.nl>
Fix the snd_usbmidi_create_endpoints_midiman() function, which forgot to
set the out_interval member of the endpoint info structure for Midiman/
M-Audio devices. Since kernel 2.6.24, any non-zero value makes the
driver use interrupt transfers instead of bulk transfers. With EHCI
controllers, these random interval values result in unbearably large
latencies for output MIDI transfers.
Reported-by: David <devurandom@foobox.com>
Tested-by: David <devurandom@foobox.com>
This reverts commit 32e176c14d7a425b681ef003c9061001ddb7fc7b.
That commit caused a regression with suspend on Thinkpad SL300.
Reference: kernel bug#12711
http://bugzilla.kernel.org/show_bug.cgi?id=12711
Tested-by: Alexandre Rostovtsev <tetromino@gmail.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ASoC: Only register AC97 bus if it's not done already
ALSA: hda - Add snd_hda_multi_out_dig_cleanup()
ALSA: hda - Add missing terminator in slave dig-out array
ALSA: hda - Change HP dv7 (103c:30f4) quirk from hp-m4 to hp-dv5 model
ALSA: hda - Register (new) devices at reconfig
ALSA: mtpav - Fix initial value for input hwport
ALSA: hda - add id for Intel IbexPeak integrated HDMI codec
ALSA: hda - compute checksum in HDMI audio infoframe
ALSA: hda - enable HDMI audio pin out at module loading time
ALSA: hda - allow multi-channel HDMI audio playback when ELD is not present
ASoC: Update SDP3430 machine driver for snd_soc_card
ALSA: hda - Add quirk for Asus z37e (1043:8284)
sound: Remove OSSlib stuff from linux/soundcard.h
ASoC: WM8990: Fix kcontrol's private value use in put callback
ASoC: TLV320AIC3X: Fix kcontrol's private value use in put callback
