path: root/sound
2010-06-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: sound/spi: patch for the unuseful variable removal ALSA: hda - Add SSID table for iMac7,1. ALSA: hda - Add SSID table for MacBookAir1,1 ALSA: hda - Add SSID table for MacBookAir2,1 ALSA: atmel: set "channel A event" output to debug
2010-06-10Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6164/1: Add kto and kfrom to input operands list. ARM: 6166/1: Proper prefetch abort handling on pre-ARMv6 ARM: 6165/1: trap overflows on highmem pages from kmap_atomic when debugging ARM: 6152/1: ux500 make it possible to disable localtimers [ARM] pxa/spitz: Correctly register WM8750 [ARM] pxa/palmtc: storage class should be before const qualifier ARM: 6146/1: sa1111: Prevent deadlock in resume path ARM: 6145/1: ux500 MTU clockrate correction ARM: 6144/1: TCM memory bug freeing bug ARM: VFP: Fix vfp_put_double() for d16-d31
2010-06-10Merge branch 'fix/misc' into for-linusTakashi Iwai
2010-06-08ALSA: sound/spi: patch for the unuseful variable removalWan ZongShun
The '*bitclk' of structure 'snd_at73c213' seems no use, so I make a patch to remove the unnecessary variable. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-08ALSA: hda - Add SSID table for iMac7,1.Justin P. Mattock
This patch add's the iMac7,1 SSID entry to patch_realtek.c which adds sound support. bug entry: https://bugs.launchpad.net/mactel-support/+bug/360866 Note:I do not have this machine on hand only codec#0 file for the machine so please test if you have the appropriate equipment. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-08ALSA: hda - Add SSID table for MacBookAir1,1Justin P. Mattock
This patch add's the MacBookAir1,1 SSID entry to patch_realtek.c which adds sound support. bug entry: https://bugs.launchpad.net/mactel-support/+bug/268301 Note:I do not have this machine on hand only codec#0 file for the machine so please test if you have the appropriate equipment. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-08ALSA: hda - Add SSID table for MacBookAir2,1Justin P. Mattock
This adds the SSID number to snd_pci_quirk for the MacBookAir2,1 taken from codec#0 at: http://launchpadlibrarian.net/49455483/Card0.Codecs.codec.0.txt keep in mind I do not have one of these machines on hand so please if you do have this machine please test for me.. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-08ALSA: atmel: set "channel A event" output to debugYegor Yefremov
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: hda-intel - fix wallclk variable update and condition ALSA: asihpi - Fix uninitialized variable ALSA: hda: Use LPIB for ASUS M2V usb/gadget: Replace the old USB audio FU definitions in f_audio.c ASoC: MX31ads sound support should depend on MACH_MX31ADS_WM1133_EV1 ASoC: Add missing Kconfig entry for Phytec boards ALSA: usb-audio: export UAC2 clock selectors as mixer controls ALSA: usb-audio: clean up find_audio_control_unit() ALSA: usb-audio: add UAC2 sepecific Feature Unit controls ALSA: usb-audio: unify constants from specification ALSA: usb-audio: parse clock topology of UAC2 devices ALSA: usb-audio: fix selector unit string index accessor include/linux/usb/audio-v2.h: add more UAC2 details ALSA: usb-audio: support partially write-protected UAC2 controls ALSA: usb-audio: UAC2: clean up parsing of bmaControls ALSA: hda: Use LPIB for another mainboard ALSA: hda: Use mb31 quirk for an iMac model ALSA: hda: Use LPIB for an ASUS device
2010-06-02Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-06-02Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-06-02Merge branch 'for-2.6.35' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound-2.6 into fix/asoc
2010-06-02Merge branch 'master' of git.alsa-project.org:alsa-kernel into fix/hdaTakashi Iwai
2010-06-02ALSA: hda-intel - fix wallclk variable update and conditionJaroslav Kysela
This patch fixes thinko introduced in "last minutes" before commiting of the last wallclk patch. It also fixes the condition checking if the first period after last wallclk update is processed. There is a little rounding error in period_wallclk. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-06-02ALSA: asihpi - Fix uninitialized variableTakashi Iwai
Initialize prev_ctl properly before reference: sound/pci/asihpi/asihpi.c: In function ‘snd_card_asihpi_mixer_new’: sound/pci/asihpi/asihpi.c:2568:30: warning: ‘prev_ctl.dst_node_index’ may be used uninitialized in this function Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-02powerpc/macio: Fix probing of macio devices by using the right of match tableBenjamin Herrenschmidt
Grant patches added an of mach table to struct device_driver. However, while he changed the macio device code to use that, he left the match table pointer in struct macio_driver and didn't update drivers to use the "new" one, thus breaking the probing. This completes the change by moving all drivers to setup the "new" one, removing all traces of the old one, and while at it (since it changes the exact same locations), I also remove two other duplicates from struct driver which are the name and owner fields. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-06-01ALSA: hda: Use LPIB for ASUS M2VDaniel T Chen
BugLink: https://launchpad.net/bugs/587546 Symptom: On the reporter's ASUS M2V, using PulseAudio in Ubuntu 10.04 LTS results in the PA daemon crashing shortly after attempting playback of an audio file. Test case: Using Ubuntu 10.04 LTS (Linux 2.6.32.12), Linux 2.6.33, or Linux 2.6.34, attempt playback of an audio file while PulseAudio is active. Resolution: add SSID for this machine to the position_fix quirk table, explicitly specifying the LPIB method. Reported-and-Tested-By: D Tangman Cc: <stable@kernel.org> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-31ASoC: MX31ads sound support should depend on MACH_MX31ADS_WM1133_EV1Sascha Hauer
Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-05-31ASoC: Add missing Kconfig entry for Phytec boardsSascha Hauer
2010-05-31ALSA: usb-audio: export UAC2 clock selectors as mixer controlsDaniel Mack
The UAC2 clock selectors are fortunately compatible with UAC1 audio selector units, so we can simply reuse the same approach to get all the linked units. Requests to this control need a different CS value though. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-31ALSA: usb-audio: clean up find_audio_control_unit()Daniel Mack
Use a struct to parse the audio units, and return usable descriptors for all types. There's no need to limit the result set, except for some kind of sanity check. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-31ALSA: usb-audio: add UAC2 sepecific Feature Unit controlsDaniel Mack
The bits to enable them are always 0 for UAC1 devices, so no additional checks are required. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-31ALSA: usb-audio: unify constants from specificationDaniel Mack
Move more definitions from private enums to appropriate header files. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-31ALSA: usb-audio: parse clock topology of UAC2 devicesDaniel Mack
Audio devices which comply to the UAC2 standard can export complex clock topologies in its descriptors and set up links between them. The entities that are defined are - clock sources, which define the end-leafs. - clock selectors, which act as switch to select one out of many possible clocks sources. - clock multipliers, which have an input clock source, and act as clock source again. They can be used to derive one clock from another. All sample rate changes, clock validity queries and the like must go to clock source elements, while clock selectors and multipliers can be used as terminal clock source. The following patch adds a parser for these elements and functions to iterate over the tree and find the leaf nodes (clock sources). The samplerate set functions were moved to the new clock.c file. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-31ALSA: usb-audio: support partially write-protected UAC2 controlsDaniel Mack
So far, UAC2 controls are marked read-only if any of the channels are marked read-only in the descriptors. Change this behaviour and - mark them writeable unless all channels are read-only - store the read-only mask in usb_mixer_elem_info and - check the mask again in set_cur_mix_value(), and bail out for write-protected channels. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-31ALSA: usb-audio: UAC2: clean up parsing of bmaControlsDaniel Mack
Introduce two new static inline functions for a more readable parsing of UAC2 bmaControls. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-31ALSA: hda: Use LPIB for another mainboardDaniel T Chen
BugLink: https://launchpad.net/bugs/580749 Symptom: on the original reporter's VIA VT1708-based board, the PulseAudio daemon dies shortly after the user attempts to play an audio file. Test case: boot from Ubuntu 10.04 LTS live cd; attempt to play an audio file. Resolution: add SSID for the original reporter's hardware to the position_fix quirk table, explicitly specifying the LPIB method. Reported-and-Tested-By: Harald Cc: <stable@kernel.org> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-31ALSA: hda: Use mb31 quirk for an iMac modelDaniel T Chen
BugLink: https://launchpad.net/bugs/542550 Symptom: On the reporter's iMac, in Ubuntu 10.04 LTS neither playback nor capture appear audible out-of-the-box. Test case: Boot from an Ubuntu 10.04 LTS live cd or from an installed configuration and attempt to play or capture audio. Resolution: Specify the mb31 quirk for this machine in the codec SSID table. Reported-and-Tested-By: f3a97 Cc: <stable@kernel.org> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-31ALSA: hda: Use LPIB for an ASUS deviceDaniel T Chen
BugLink: https://launchpad.net/bugs/465942 Symptom: On the reporter's ASUS device, using PulseAudio in Ubuntu 10.04 LTS results in the PA daemon crashing shortly after attempting to select capture or to configure the audio hardware profile. Test case: Using Ubuntu 10.04 LTS (Linux 2.6.32.12), Linux 2.6.33, or Linux 2.6.34, adjust the HDA device's capture volume with PulseAudio. Resolution: add SSID for this machine to the position_fix quirk table, explicitly specifying the LPIB method. Reported-and-Tested-By: Irihapeti Cc: <stable@kernel.org> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-31[ARM] pxa/spitz: Correctly register WM8750Marek Vasut
This patch registers the WM8750 codec on a proper place on the SPITZ machine after the WM8750 driver was converted to new API. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-05-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (26 commits) ALSA: snd-usb-caiaq: Bump version number to 1.3.21 ALSA: Revert "ALSA: snd-usb-caiaq: Set default input mode of A4DJ" ALSA: snd-usb-caiaq: Simplify single case to an 'if' ALSA: snd-usb-caiaq: Restore 'Control vinyl' input mode on A4DJ ALSA: hda: Use LPIB for a Shuttle device ALSA: hda: Add support for another Lenovo ThinkPad Edge in conexant codec ALSA: hda: Use LPIB for Sony VPCS11V9E ALSA: usb-audio: fix feature unit parser for UAC2 ALSA: asihpi - Minor code cleanup ALSA: asihpi - Add support for new ASI8800 family ALSA: asihpi - Fix bug preventing outstream_write preload from happening ALSA: asihpi - Fix imbalanced lock path in hw_message ALSA: asihpi - Remove support for old ASI8800 family ALSA: asihpi - Add hd radio blend functions ALSA: asihpi - Remove unused io map functions ALSA: usb-audio: add support for UAC2 pitch control ALSA: usb-audio: parse UAC2 endpoint descriptors correctly ALSA: usb-audio: fix return values ALSA: usb-audio: parse more format descriptors with structs sound: Add missing spin_unlock ...
2010-05-29Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-05-29Merge branch 'fix/misc' into for-linusTakashi Iwai
2010-05-29Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-05-29ALSA: snd-usb-caiaq: Bump version number to 1.3.21Mark Hills
Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Mark Hills <mark@pogo.org.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-29ALSA: Revert "ALSA: snd-usb-caiaq: Set default input mode of A4DJ"Mark Hills
Do not explicity set the default input mode. Use the hardware default of mode 0 ('Control vinyl'), which is now available. This reverts commit e3ca4c9. Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Mark Hills <mark@pogo.org.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-29ALSA: snd-usb-caiaq: Simplify single case to an 'if'Mark Hills
After removing code, only one case remains. So use an 'if' instead. Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Mark Hills <mark@pogo.org.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-29ALSA: snd-usb-caiaq: Restore 'Control vinyl' input mode on A4DJMark Hills
This feature was undocumented on early A4DJ units. It is indicated by lighting both the 'line' and 'phono' lamps at the same time. Newer units document this and the newer Windows drivers enable this for all units, so restore the functionality. This patch simplifies the code and changes the mode mapping to match the A8DJ, favouring simpler code and consistency over keeping the existing mapping. Both 'Control vinyl' and 'Phono' input modes enable the hardware preamp. The difference is the input impedance. This reverts commit 9a9527e. Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Mark Hills <mark@pogo.org.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-29ALSA: hda: Use LPIB for a Shuttle deviceDaniel T Chen
BugLink: https://launchpad.net/bugs/551949 Symptom: On the reporter's Shuttle device, using PulseAudio in Ubuntu 10.04 LTS results in "popping clicking" audio with the PA crashing shortly thereafter. Test case: Using Ubuntu 10.04 LTS (Linux 2.6.32.12), Linux 2.6.33, or Linux 2.6.34, adjust the HDA device's volume with PulseAudio. Resolution: add SSID for this machine to the position_fix quirk table, explicitly specifying the LPIB method. Reported-and-Tested-By: Christian Mehlis <mehlis@inf.fu-berlin.de> Cc: <stable@kernel.org> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-28ALSA: hda: Add support for another Lenovo ThinkPad Edge in conexant codecAndreas Herrmann
On a Thinkpad Edge 13 "01972NG" I had the problem that speakers played sound although headphones were plugged in. Using model=ideapad with latest alsa-git kernel fixed this. So adding this quirk to use ideapad for another Thinkpad Edge variant seems sensible. Cc: Jerone Young <jerone.young@canonical.com> Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-28ALSA: hda: Use LPIB for Sony VPCS11V9EDaniel T Chen
BugLink: https://launchpad.net/bugs/586347 Symptom: On the Sony VPCS11V9E, using GStreamer-based applications with PulseAudio in Ubuntu 10.04 LTS results in stuttering audio. It appears to worsen with increased I/O. Test case: use Rhythmbox under increased I/O pressure. This symptom is reproducible in the current daily stable alsa-driver snapshots (at least up until 21 May 2010; later snapshots fail to build from source due to missing preprocessor directives when compiled against 2.6.32). Resolution: add SSID for this machine to the position_fix quirk table, explicitly specifying the LPIB method. Reported-and-Tested-By: Lauri Kainulainen <lauri@sokkelo.net> Cc: <stable@kernel.org> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-28ALSA: usb-audio: fix feature unit parser for UAC2Daniel Mack
Fix a small off-by-one bug which causes the feature unit to announce a wrong number of channels. This leads to illegal requests sent to the firmware eventually. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-27ALSA: asihpi - Minor code cleanupEliot Blennerhassett
Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-27ALSA: asihpi - Add support for new ASI8800 familyEliot Blennerhassett
2010-05-27ALSA: asihpi - Fix bug preventing outstream_write preload from happeningEliot Blennerhassett
2010-05-27ALSA: asihpi - Fix imbalanced lock path in hw_messageEliot Blennerhassett
2010-05-27ALSA: asihpi - Remove support for old ASI8800 familyEliot Blennerhassett
2010-05-27ALSA: asihpi - Add hd radio blend functionsEliot Blennerhassett
Add hd radio blend functions. HPI version inc to 4.03.25. Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-27ALSA: asihpi - Remove unused io map functionsEliot Blennerhassett
