path: root/sound
2012-04-05Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge batch of fixes from Andrew Morton: "The simple_open() cleanup was held back while I wanted for laggards to merge things. I still need to send a few checkpoint/restore patches. I've been wobbly about merging them because I'm wobbly about the overall prospects for success of the project. But after speaking with Pavel at the LSF conference, it sounds like they're further toward completion than I feared - apparently davem is at the "has stopped complaining" stage regarding the net changes. So I need to go back and re-review those patchs and their (lengthy) discussion." * emailed from Andrew Morton <akpm@linux-foundation.org>: (16 patches) memcg swap: use mem_cgroup_uncharge_swap fix backlight: add driver for DA9052/53 PMIC v1 C6X: use set_current_blocked() and block_sigmask() MAINTAINERS: add entry for sparse checker MAINTAINERS: fix REMOTEPROC F: typo alpha: use set_current_blocked() and block_sigmask() simple_open: automatically convert to simple_open() scripts/coccinelle/api/simple_open.cocci: semantic patch for simple_open() libfs: add simple_open() hugetlbfs: remove unregister_filesystem() when initializing module drivers/rtc/rtc-88pm860x.c: fix rtc irq enable callback fs/xattr.c:setxattr(): improve handling of allocation failures fs/xattr.c:listxattr(): fall back to vmalloc() if kmalloc() failed fs/xattr.c: suppress page allocation failure warnings from sys_listxattr() sysrq: use SEND_SIG_FORCED instead of force_sig() proc: fix mount -t proc -o AAA
2012-04-05simple_open: automatically convert to simple_open()Stephen Boyd
Many users of debugfs copy the implementation of default_open() when they want to support a custom read/write function op. This leads to a proliferation of the default_open() implementation across the entire tree. Now that the common implementation has been consolidated into libfs we can replace all the users of this function with simple_open(). This replacement was done with the following semantic patch: <smpl> @ open @ identifier open_f != simple_open; identifier i, f; @@ -int open_f(struct inode *i, struct file *f) -{ ( -if (i->i_private) -f->private_data = i->i_private; | -f->private_data = i->i_private; ) -return 0; -} @ has_open depends on open @ identifier fops; identifier open.open_f; @@ struct file_operations fops = { ... -.open = open_f, +.open = simple_open, ... }; </smpl> [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-02Merge remote-tracking branch 'kumar/next' into mergeBenjamin Herrenschmidt
2012-03-30Merge tag 'for-linus-3.4' of git://git.infradead.org/mtd-2.6Linus Torvalds
Pull MTD changes from David Woodhouse: - Artem's cleanup of the MTD API continues apace. - Fixes and improvements for ST FSMC and SuperH FLCTL NAND, amongst others. - More work on DiskOnChip G3, new driver for DiskOnChip G4. - Clean up debug/warning printks in JFFS2 to use pr_<level>. Fix up various trivial conflicts, largely due to changes in calling conventions for things like dmaengine_prep_slave_sg() (new inline wrapper to hide new parameter, clashing with rewrite of previously last parameter that used to be an 'append' flag, and is now a bitmap of 'unsigned long flags'). (Also some header file fallout - like so many merges this merge window - and silly conflicts with sparse fixes) * tag 'for-linus-3.4' of git://git.infradead.org/mtd-2.6: (120 commits) mtd: docg3 add protection against concurrency mtd: docg3 refactor cascade floors structure mtd: docg3 increase write/erase timeout mtd: docg3 fix inbound calculations mtd: nand: gpmi: fix function annotations mtd: phram: fix section mismatch for phram_setup mtd: unify initialization of erase_info->fail_addr mtd: support ONFI multi lun NAND mtd: sm_ftl: fix typo in major number. mtd: add device-tree support to spear_smi mtd: spear_smi: Remove default partition information from driver mtd: Add device-tree support to fsmc_nand mtd: fix section mismatch for doc_probe_device mtd: nand/fsmc: Remove sparse warnings and errors mtd: nand/fsmc: Add DMA support mtd: nand/fsmc: Access the NAND device word by word whenever possible mtd: nand/fsmc: Use dev_err to report error scenario mtd: nand/fsmc: Use devm routines mtd: nand/fsmc: Modify fsmc driver to accept nand timing parameters via platform mtd: fsmc_nand: add pm callbacks to support hibernation ...
2012-03-30Merge branch 'dunlap' (Randy's Documentation patches)Linus Torvalds
Merge Documentation fixes from Randy Dunlap. Fixed up several small annoyances (bad changelogs and corrupted utf8 names), I need to try to convince people to do things right. * emailed from Randy Dunlap <rdunlap@xenotime.net>: Documentation: fix typo in ABI/stable/sysfs-driver-usb-usbtmc Documentation: replace install commands with softdeps Documentation: remove references to /etc/modprobe.conf Documentation: input.txt: clarify mousedev 'cat' command syntax Documentation: CodingStyle: add inline assembly guidelines Documentation: sysrq: Crutcher Dunnavant is unavailable Documentation: mention scripts/diffconfig tool Documentation: remove 'mach' from dontdiff file
2012-03-30Documentation: remove references to /etc/modprobe.confLucas De Marchi
Usage of /etc/modprobe.conf file was deprecated by module-init-tools and is no longer parsed by new kmod tool. References to this file are replaced in Documentation, comments and Kconfig according to the context. There are also some references to the old /etc/modules.conf from 2.4 kernels that are being removed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-30Merge tag 'sound-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "A collection of small fixes for 3.4-rc1, including - mic-recording regression fix for Realtek codec - clean-up of dmaengine parameter mess - WM8894 calibration tweak - minor fixes for asihpi and some bool module parms" * tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: fix isa/opti9xx module param type sound: fix oss/msnd_pinnacle module param type ALSA: asihpi - fix return type of hpios_locked_mem_alloc() ASoC: dmaengine_pcm: use dmaengine cyclic wrapper ASoC: Add extra parameter to device_prep_dma_cyclic ALSA: hda/realtek - Fix ADC assignment with a shared HP/Mic pin ASoC: wm8994: Update WM8994 DCS calibration
2012-03-29Merge tag 'cleanup2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: cleanups of io includes" from Olof Johansson: "Rob Herring has done a sweeping change cleaning up all of the mach/io.h includes, moving some of the oft-repeated macros to a common location and removing a bunch of boiler plate. This is another step closer to a common zImage for multiple platforms." Fix up various fairly trivial conflicts (<mach/io.h> removal vs changes around it, tegra localtimer.o is *still* gone, yadda-yadda). * tag 'cleanup2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits) ARM: tegra: Include assembler.h in sleep.S to fix build break ARM: pxa: use common IOMEM definition ARM: dma-mapping: convert ARCH_HAS_DMA_SET_COHERENT_MASK to kconfig symbol ARM: __io abuse cleanup ARM: create a common IOMEM definition ARM: iop13xx: fix missing declaration of iop13xx_init_early ARM: fix ioremap/iounmap for !CONFIG_MMU ARM: kill off __mem_pci ARM: remove bunch of now unused mach/io.h files ARM: make mach/io.h include optional ARM: clps711x: remove unneeded include of mach/io.h ARM: dove: add explicit include of dove.h to addr-map.c ARM: at91: add explicit include of hardware.h to uncompressor ARM: ep93xx: clean-up mach/io.h ARM: tegra: clean-up mach/io.h ARM: orion5x: clean-up mach/io.h ARM: davinci: remove unneeded mach/io.h include [media] davinci: remove includes of mach/io.h ARM: OMAP: Remove remaining includes for mach/io.h ARM: msm: clean-up mach/io.h ...
2012-03-29Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull more ARM updates from Russell King. This got a fair number of conflicts with the <asm/system.h> split, but also with some other sparse-irq and header file include cleanups. They all looked pretty trivial, though. * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (59 commits) ARM: fix Kconfig warning for HAVE_BPF_JIT ARM: 7361/1: provide XIP_VIRT_ADDR for no-MMU builds ARM: 7349/1: integrator: convert to sparse irqs ARM: 7259/3: net: JIT compiler for packet filters ARM: 7334/1: add jump label support ARM: 7333/2: jump label: detect %c support for ARM ARM: 7338/1: add support for early console output via semihosting ARM: use set_current_blocked() and block_sigmask() ARM: exec: remove redundant set_fs(USER_DS) ARM: 7332/1: extract out code patch function from kprobes ARM: 7331/1: extract out insn generation code from ftrace ARM: 7330/1: ftrace: use canonical Thumb-2 wide instruction format ARM: 7351/1: ftrace: remove useless memory checks ARM: 7316/1: kexec: EOI active and mask all interrupts in kexec crash path ARM: Versatile Express: add NO_IOPORT ARM: get rid of asm/irq.h in asm/prom.h ARM: 7319/1: Print debug info for SIGBUS in user faults ARM: 7318/1: gic: refactor irq_start assignment ARM: 7317/1: irq: avoid NULL check in for_each_irq_desc loop ARM: 7315/1: perf: add support for the Cortex-A7 PMU ...
2012-03-29Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine update from Vinod Koul: "This includes the cookie cleanup by Russell, the addition of context parameter for dmaengine APIs, more arm dmaengine driver cleanup by moving code to dmaengine, this time for imx by Javier and pl330 by Boojin along with the usual driver fixes." Fix up some fairly trivial conflicts with various other cleanups. * 'next' of git://git.infradead.org/users/vkoul/slave-dma: (67 commits) dmaengine: imx: fix the build failure on x86_64 dmaengine: i.MX: Fix merge of cookie branch. dmaengine: i.MX: Add support for interleaved transfers. dmaengine: imx-dma: use 'dev_dbg' and 'dev_warn' for messages. dmaengine: imx-dma: remove 'imx_dmav1_baseaddr' and 'dma_clk'. dmaengine: imx-dma: remove unused arg of imxdma_sg_next. dmaengine: imx-dma: remove internal structure. dmaengine: imx-dma: remove 'resbytes' field of 'internal' structure. dmaengine: imx-dma: remove 'in_use' field of 'internal' structure. dmaengine: imx-dma: remove sg member from internal structure. dmaengine: imx-dma: remove 'imxdma_setup_sg_hw' function. dmaengine: imx-dma: remove 'imxdma_config_channel_hw' function. dmaengine: imx-dma: remove 'imxdma_setup_mem2mem_hw' function. dmaengine: imx-dma: remove dma_mode member of internal structure. dmaengine: imx-dma: remove data member from internal structure. dmaengine: imx-dma: merge old dma-v1.c with imx-dma.c dmaengine: at_hdmac: add slave config operation dmaengine: add context parameter to prep_slave_sg and prep_dma_cyclic dmaengine/dma_slave: introduce inline wrappers dma: imx-sdma: Treat firmware messages as warnings instead of erros ...
2012-03-29ALSA: fix isa/opti9xx module param typeRandy Dunlap
Fix module parameter data type to eliminate build warnings. sound/isa/opti9xx/opti92x-ad1848.c:87:1: warning: return from incompatible pointer type sound/isa/opti9xx/opti92x-ad1848.c:87:1: warning: return from incompatible pointer type Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-03-29sound: fix oss/msnd_pinnacle module param typeRandy Dunlap
Fix module parameter data type to eliminate build warning. sound/oss/msnd_pinnacle.c:1727:1: warning: return from incompatible pointer type Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-03-29Merge tag 'asoc-3.4' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: A few more updates for 3.4 The cleanup of the dmaengine parameter messup and a tweak to some callibration values for WM1811.
2012-03-29powerpc/8xxx: remove 85xx/86xx restrictions from fsl_guts.hTimur Tabi
Remove the check for CONFIG_PPC_85xx and CONFIG_PPC_86xx from fsl_guts.h. The check was originally intended to allow the same header file to be used on 85xx and 86xx systems, even though the Global Utilities register could be different. It turns out that they're not actually different, and so the check is not necessary. In addition, neither macro is defined for 64-bit e5500 kernels, so that causes a build break. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-28ALSA: asihpi - fix return type of hpios_locked_mem_alloc()Dan Carpenter
This function returns zero or -ENOMEM, but because it's type is u16, the -ENOMEM gets changed to 65524. None of the callers care, but lets fix it anyway as a cleanup. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-03-27Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: driver specific updates" from Arnd Bergmann: "These are all specific to some driver. They are typically the platform side of a change in the drivers directory, such as adding a new driver or extending the interface to the platform. In cases where there is no maintainer for the driver, or the maintainer prefers to have the platform changes in the same branch as the driver changes, the patches to the drivers are included as well. A much smaller set of driver updates that depend on other branches getting merged first will be sent later. The new export of tegra_chip_uid conflicts with other changes in fuse.c. In rtc-sa1100.c, the global removal of IRQF_DISABLED conflicts with the cleanup of the interrupt handling of that driver. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fixed up aforementioned trivial conflicts. * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits) ARM: SAMSUNG: change the name from s3c-sdhci to exynos4-sdhci mmc: sdhci-s3c: add platform data for the second capability ARM: SAMSUNG: support the second capability for samsung-soc ARM: EXYNOS: add support DMA for EXYNOS4X12 SoC ARM: EXYNOS: Add apb_pclk clkdev entry for mdma1 ARM: EXYNOS: Enable MDMA driver regulator: Remove bq24022 regulator driver rtc: sa1100: add OF support pxa: magician/hx4700: Convert to gpio-regulator from bq24022 ARM: OMAP3+: SmartReflex: fix error handling ARM: OMAP3+: SmartReflex: fix the use of debugfs_create_* API ARM: OMAP3+: SmartReflex: micro-optimization for sanity check ARM: OMAP3+: SmartReflex: misc cleanups ARM: OMAP3+: SmartReflex: move late_initcall() closer to its argument ARM: OMAP3+: SmartReflex: add missing platform_set_drvdata() ARM: OMAP3+: hwmod: add SmartReflex IRQs ARM: OMAP3+: SmartReflex: clear ERRCONFIG_VPBOUNDINTST only on a need ARM: OMAP3+: SmartReflex: Fix status masking in ERRCONFIG register ARM: OMAP3+: SmartReflex: Add a shutdown hook ARM: OMAP3+: SmartReflex Class3: disable errorgen before disable VP ... Conflicts: arch/arm/mach-tegra/Makefile arch/arm/mach-tegra/fuse.c drivers/rtc/rtc-sa1100.c
2012-03-27Merge tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: board specific updates" from Arnd Bergmann/Olof Johansson: "These changes are all specific to one board only. We're trying to keep the number of board files low, but generally board level updates are ok on platforms that are working on moving towards DT based probing, which will eventually lead to removing them. The board-ams-delta.c board file gets a conflict between the removal of ams_delta_config and the addition of a lot of other data. The Kconfig file has two changes in the same line, and in exynos, the power domain cleanup conflicts with the addition of the image sensor device. Signed-off-by: Arnd Bergmann <arnd@arndb.de> [olof: Amended a fix for a mismerge to board-omap4panda.c] Signed-off-by: Olof Johansson <olof@lixom.net>" Fixed up some fairly trivial conflicts manually. * tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (82 commits) i.MX35-PDK: Add Camera support ARM : mx35: 3ds-board: add framebuffer device pxa/hx4700: Remove pcmcia platform_device structure ARM: pxa/hx4700: Reduce sleep mode battery discharge by 35% ARM: pxa/hx4700: Remove unwanted request for GPIO105 ARM: EXYNOS: support Exynos4210-bus Devfreq driver on Nuri board ARM: EXYNOS: Register JPEG on nuri ARM: EXYNOS: Register JPEG on universal_c210 ARM: S5PV210: Enable JPEG on SMDKV210 ARM: S5PV210: Add JPEG board definition ARM: EXYNOS: Enable JPEG on Origen ARM: EXYNOS: Enable JPEG on SMDKV310 ARM: EXYNOS: Add __init attribute to universal_camera_init() ARM: EXYNOS: Add __init attribute to nuri_camera_init() ARM: S5PV210: Enable FIMC on SMDKC110 ARM: S5PV210: Enable FIMC on SMDKV210 ARM: S5PV210: Enable MFC on SMDKC110 ARM: S5PV210: Enable MFC on SMDKV210 ARM: EXYNOS: Enable G2D on SMDKV310 ARM: tegra: update defconfig ...
2012-03-27Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: global cleanups" from Arnd Bergmann: "Quite a bit of code gets removed, and some stuff moved around, mostly the old samsung s3c24xx stuff. There should be no functional changes in this series otherwise. Some cleanups have dependencies on other arm-soc branches and will be sent in the second round. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fixed up trivial conflicts mainly due to #include's being changes on both sides. * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (121 commits) ep93xx: Remove unnecessary includes of ep93xx-regs.h ep93xx: Move EP93XX_SYSCON defines to SoC private header ep93xx: Move crunch code to mach-ep93xx directory ep93xx: Make syscon access functions private to SoC ep93xx: Configure GPIO ports in core code ep93xx: Move peripheral defines to local SoC header ep93xx: Convert the watchdog driver into a platform device. ep93xx: Use ioremap for backlight driver ep93xx: Move GPIO defines to gpio-ep93xx.h ep93xx: Don't use system controller defines in audio drivers ep93xx: Move PHYS_BASE defines to local SoC header file ARM: EXYNOS: Add clock register addresses for EXYNOS4X12 bus devfreq driver ARM: EXYNOS: add clock registers for exynos4x12-cpufreq PM / devfreq: update the name of EXYNOS clock registers that were omitted PM / devfreq: update the name of EXYNOS clock register ARM: EXYNOS: change the prefix S5P_ to EXYNOS4_ for clock ARM: EXYNOS: use static declaration on regarding clock ARM: EXYNOS: replace clock.c for other new EXYNOS SoCs ARM: OMAP2+: Fix build error after merge ARM: S3C24XX: remove call to s3c24xx_setup_clocks ...
2012-03-27Merge tag 'asoc-3.4' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into next/boards The asoc branch that was already merged into v3.4 contains some board-level changes that conflict with patches we already have here, so pull in that branch to resolve the conflicts. Conflicts: arch/arm/mach-imx/mach-imx27_visstrim_m10.c arch/arm/mach-omap2/board-omap4panda.c Signed-off-by: Arnd Bergmann <arnd@arndb.de> [olof: Amended fix for mismerge as reported by Kevin Hilman] Signed-off-by: Olof Johansson <olof@lixom.net>
2012-03-27mxs-dma : move the mxs dma.h to a more common placeHuang Shijie
Move the header to a more common place. The mxs dma engine is not only used in mx23/mx28, but also used in mx50/mx6q. It will also be used in the future chips. Rename it to mxs-dma.h, and create a new folder include/linux/fsl/ to store the Freescale's header files. change mxs-dma driver, mxs-mmc driver, gpmi-nand driver, mxs-saif driver to the new header file. Acked-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Huang Shijie <b32955@freescale.com> Acked-by: Vinod Koul <vinod.koul@linux.intel.com> Acked-by: Chris Ball <cjb@laptop.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-03-26ASoC: dmaengine_pcm: use dmaengine cyclic wrapperVinod Koul
commit 4a163c82 added extra parameter to device_prep_dma_cyclic this is not required if we use the wrapper over cyclic API. This is split from Alexedre's patch Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-03-25ARM: pxa: use common IOMEM definitionRob Herring
pxa was missed in the moving of IOMEM to a common definition, so lots of IOMEM redefined warnings were introduced. So remove pxa IOMEM definition and fix all the fallout. Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Haojian Zhuang <haojian.zhuang@marvell.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: rtc-linux@googlegroups.com Cc: alsa-devel@alsa-project.org
2012-03-24Merge tag 'device-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull <linux/device.h> avoidance patches from Paul Gortmaker: "Nearly every subsystem has some kind of header with a proto like: void foo(struct device *dev); and yet there is no reason for most of these guys to care about the sub fields within the device struct. This allows us to significantly reduce the scope of headers including headers. For this instance, a reduction of about 40% is achieved by replacing the include with the simple fact that the device is some kind of a struct. Unlike the much larger module.h cleanup, this one is simply two commits. One to fix the implicit <linux/device.h> users, and then one to delete the device.h includes from the linux/include/ dir wherever possible." * tag 'device-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: device.h: audit and cleanup users in main include dir device.h: cleanup users outside of linux/include (C files)
2012-03-23Merge branch 'amba' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull #2 ARM updates from Russell King: "Further ARM AMBA primecell updates which aren't included directly in the previous commit. I wanted to keep these separate as they're touching stuff outside arch/arm/." * 'amba' of git://git.linaro.org/people/rmk/linux-arm: ARM: 7362/1: AMBA: Add module_amba_driver() helper macro for amba_driver ARM: 7335/1: mach-u300: do away with MMC config files ARM: 7280/1: mmc: mmci: Cache MMCICLOCK and MMCIPOWER register ARM: 7309/1: realview: fix unconnected interrupts on EB11MP ARM: 7230/1: mmc: mmci: Fix PIO read for small SDIO packets ARM: 7227/1: mmc: mmci: Prepare for SDIO before setting up DMA job ARM: 7223/1: mmc: mmci: Fixup use of runtime PM and use autosuspend ARM: 7221/1: mmc: mmci: Change from using legacy suspend ARM: 7219/1: mmc: mmci: Change vdd_handler to a generic ios_handler ARM: 7218/1: mmc: mmci: Provide option to configure bus signal direction ARM: 7217/1: mmc: mmci: Put power register deviations in variant data ARM: 7216/1: mmc: mmci: Do not release spinlock in request_end ARM: 7215/1: mmc: mmci: Increase max_segs from 16 to 128
2012-03-23Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - V4L2 API additions to better support JPEG compression control - media API additions to properly support MPEG decoders - V4L2 API additions for image crop/scaling - a few other V4L2 API DocBook fixes/improvements - two new DVB frontend drivers: m88rs2000 and rtl2830 - two new DVB drivers: az6007 and rtl28xxu - a framework for ISA drivers, that removed lots of common code found at the ISA radio drivers - a new FM transmitter driver (radio-keene) - a GPIO-based IR receiver driver - a new sensor driver: mt9m032 - some new video drivers: adv7183, blackfin, mx2_emmaprp, sii9234_drv, vs6624 - several new board additions, driver fixes, improvements and cleanups. * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (295 commits) [media] update CARDLIST.em28xx [media] partially reverts changeset fa5527c [media] stb0899: fix the limits for signal strength values [media] em28xx: support for 2304:0242 PCTV QuatroStick (510e) [media] em28xx: support for 2013:0251 PCTV QuatroStick nano (520e) [media] -EINVAL -> -ENOTTY [media] gspca - sn9c20x: Cleanup source [media] gspca - sn9c20x: Simplify register write for capture start/stop [media] gspca - sn9c20x: Add automatic JPEG compression mechanism [media] gspca - sn9c20x: Greater delay in case of sensor no response [media] gspca - sn9c20x: Optimize the code of write sequences [media] gspca - sn9c20x: Add the JPEG compression quality control [media] gspca - sn9c20x: Add a delay after Omnivision sensor reset [media] gspca - sn9c20x: Propagate USB errors to higher level [media] gspca - sn9c20x: Use the new video control mechanism [media] gspca - sn9c20x: Fix loss of frame start [media] gspca - zc3xx: Lack of register 08 value for sensor cs2102k [media] gspca - ov534_9: Add brightness to OmniVision 5621 sensor [media] gspca - zc3xx: Add V4L2_CID_JPEG_COMPRESSION_QUALITY control support [media] pvrusb2: fix 7MHz & 8MHz DVB-T tuner support for HVR1900 rev D1F5 ...
2012-03-22Merge tag 'regmap-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap Pull regmap updates from Mark Brown: "Things are really quieting down with the regmap API, while we're still seeing a trickle of new features coming in they're getting much smaller than they were. It's also nice to have some features which support other subsystems building infrastructure on top of regmap. Highlights include: - Support for padding between the register and the value when interacting with the device, sometimes needed for fast interfaces. - Support for applying register updates to the device when restoring the register state. This is intended to be used to apply updates supplied by manufacturers for tuning the performance of the device (many of which are to undocumented registers which aren't otherwise covered). - Support for multi-register operations on cached registers. - Support for syncing only part of the register cache. - Stubs and parameter query functions intended to make it easier for other subsystems to build infrastructure on top of the regmap API. plus a few driver updates making use of the new features which it was easier to merge via this tree." * tag 'regmap-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap: (41 commits) regmap: Fix future missing prototype of devres_alloc() and friends regmap: Rejig struct declarations for stubbed API regmap: Fix rbtree block base in sync regcache: Make sure we sync register 0 in an rbtree cache regmap: delete unused module.h from drivers/base/regmap files regmap: Add stub for regcache_sync_region() mfd: Improve performance of later WM1811 revisions regmap: Fix x86_64 breakage regmap: Allow drivers to sync only part of the register cache regmap: Supply ranges to the sync operations regmap: Add tracepoints for cache only and cache bypass regmap: Mark the cache as clean after a successful sync regmap: Remove default cache sync implementation regmap: Skip hardware defaults for LZO caches regmap: Expose the driver name in debugfs mfd: wm8400: Convert to devm_regmap_init_i2c() mfd: wm831x: Convert to devm_regmap_init() mfd: wm8994: Convert to devm_regmap_init() mfd/ASoC: Convert WM8994 driver to use regmap patches mfd: Add __devinit and __devexit annotations in wm8994 ...
2012-03-22Merge tag 'firewire-updates' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394 Pull IEEE 1394 (FireWire) subsystem updates post v3.3 from Stefan Richter: - Some SBP-2 initiator fixes, side product from ongoing work on a target. - Reintroduction of an isochronous I/O feature of the older ieee1394 driver stack (flush buffer completions); it was evidently rarely used but not actually unused. Matching libraw1394 code is already available. - Be sure to prefix all kernel log messages with device name or card name, and other logging related cleanups. - Misc other small cleanups, among them a small API change that affects sound/firewire/ too. Clemens Ladisch is aware of it. * tag 'firewire-updates' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394: (26 commits) firewire: allow explicit flushing of iso packet completions firewire: prevent dropping of completed iso packet header data firewire: ohci: factor out iso completion flushing code firewire: ohci: simplify iso header pointer arithmetic firewire: ohci: optimize control bit checks firewire: ohci: remove unused excess_bytes field firewire: ohci: copy_iso_headers(): make comment match the code firewire: cdev: fix IR multichannel event documentation firewire: ohci: fix too-early completion of IR multichannel buffers firewire: ohci: move runtime debug facility out of #ifdef firewire: tone down some diagnostic log messages firewire: sbp2: replace a GFP_ATOMIC allocation firewire: sbp2: Fix SCSI sense data mangling firewire: sbp2: Ignore SBP-2 targets on the local node firewire: sbp2: Take into account Unit_Unique_ID firewire: nosy: Use the macro DMA_BIT_MASK(). firewire: core: convert AR-req handler lock from _irqsave to _bh firewire: core: fix race at address_handler unregistration firewire: core: remove obsolete comment firewire: core: prefix log messages with card name ...
2012-03-22Merge tag 'sound-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull updates of sound stuff from Takashi Iwai: "Here is the first big update chunk of sound stuff for 3.4-rc1. In the common sound infrastructure, there are a few changes for dynamic PCM support (used in ASoC) and a few clean-ups. Majority of changes are found, as usual, in HD-audio and ASoC. Some highlights of HD-audio changes: - All the long-standing static quirk codes for Realtek codec were finally removed by fixing and extending the Realtek auto-parser. - The mute-LED control is standardized over all HD-audio codec drivers using the extended vmaster hook. - The vmaster slave mixer elements are initialized to 0dB as default so that the user won't be annoyed by the silent output after updates, e.g. due to the additions of new elements. - Other many fix-ups for the misc HD-audio devices. In the ASoC side, this is a very active release, including a quite a few framework enhancements. Some highlights: - Support for widgets not associated with a CODEC, an important part of the dynamic PCM framework. - A library factoring out the common code shared by dmaengine based DMA drivers contributed by Lars-Peter Clausen. This will save a lot of code and make it much easier to deploy enhancements to dmaengine. - Support for binary controls, used for providing runtime configuration of algorithm coefficients. - A new DAPM widget type for regulator supplies allowing drivers for devices that can power down unused supplies while active to do without any per-driver code. - DAPM widgets for DAIs, initially giving a speed boost for playback startup and shutdown and also the basis for CODEC<->CODEC DAI link support. - Support for specifying the number of significant bits on audio interfaces, useful for allowing applications to know how much effort to put into generating data for a larger sample format. - Conversion of the FSI driver used on some SH processors to DMAEngine. - Conversion of EP93xx drivers to DMAEngine. - New CODEC drivers for Maxim MAX9768 and Wolfson Microelectronics WM2200. - Move audmux driver from arc/arm to sound/soc - McBSP move from arch/ to sound/ and updates Also, a few small updates and fixes for other drivers like au88x0, ymfpci, USB 6fire, USB usx2yaudio are included." * tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (446 commits) ASoC: wm8994: Provide VMID mode control and fix default sequence ASoC: wm8994: Add missing break in resume ASoC: wm_hubs: Don't actively manage LINEOUT_VMID_BUF ASoC: pxa-ssp: atomically set stream active masks ASoC: fsl: p1022ds: tell the WM8776 codec driver that it's the master ASoC: Samsung: Added to support mono recording ALSA: hda - Fix build with CONFIG_PM=n ALSA: au88x0 - Avoid possible Oops at unbinding ALSA: usb-audio - Fix build error by consitification of rate list ASoC: core: Fix obscure leak of runtime array ALSA: pcm - Avoid GFP_ATOMIC in snd_pcm_link() ALSA: pcm: Constify the list in snd_pcm_hw_constraint_list ASoC: wm8996: Add 44.1kHz support ALSA: hda - Fix build of patch_sigmatel.c without CONFIG_SND_HDA_POWER_SAVE ASoC: mx27vis-aic32x4: Convert it to platform driver ALSA: hda - fix printing of high HDMI sample rates ALSA: ymfpci - Fix legacy registers on S3/S4 resume ALSA: control - Fixe a trailing white space error ALSA: hda - Add expose_enum_ctl flag to snd_hda_add_vmaster_hook() ALSA: hda - Add "Mute-LED Mode" enum control ...
2012-03-22ASoC: Add extra parameter to device_prep_dma_cyclicFabio Estevam
Since commit 185ecb5 (dmaengine: add context parameter to prep_slave_sg and prep_dma_cyclic) prep_dma_cyclic() got an extra context parameter. Add this new parameter in order to fix the following build error (mxs_defconfig and imx_v4_v5_defconfig): sound/soc/soc-dmaengine-pcm.c:149:3: error: too few arguments to function 'chan->device->device_prep_dma_cyclic' Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-03-22ALSA: hda/realtek - Fix ADC assignment with a shared HP/Mic pinTakashi Iwai
The recent Realtek driver tries to assign an extra input via the headphone plug when only a single input source is found. The code worked on Samsung Q1, but it broke ASUS 1015 where the mic is a digital-mic and only a specific ADC works. This patch fixes the assignment of ADC in the shared mic/hp case. Instead of assuming the single ADC at first, reduce the ADCs after trying to assign both mic and HP pins. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42973 Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-03-21dmaengine/dma_slave: introduce inline wrappersAlexandre Bounine
Add inline wrappers for device_prep_slave_sg() and device_prep_dma_cyclic() interfaces to hide new parameter from current users of affected interfaces. Convert current users to use new wrappers instead of direct calls. Suggested by Russell King [https://lkml.org/lkml/2012/2/3/269]. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
2012-03-21ASoC: wm8994: Update WM8994 DCS calibrationMark Brown
Based on latest production information. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2012-03-21Merge tag 'asoc-3.4' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus Last minute ASoC updates for 3.4 There's a couple of small features here that were added late on but have been in -next in my tree and some bug fixes. The wm_hubs stuff is actually bug fixes - the stuff that's currently in 3.4 is a half way house between the two solutions that the latest change allows the machine to select between.
2012-03-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "It's indeed trivial -- mostly documentation updates and a bunch of typo fixes from Masanari. There are also several linux/version.h include removals from Jesper." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (101 commits) kcore: fix spelling in read_kcore() comment constify struct pci_dev * in obvious cases Revert "char: Fix typo in viotape.c" init: fix wording error in mm_init comment usb: gadget: Kconfig: fix typo for 'different' Revert "power, max8998: Include linux/module.h just once in drivers/power/max8998_charger.c" writeback: fix fn name in writeback_inodes_sb_nr_if_idle() comment header writeback: fix typo in the writeback_control comment Documentation: Fix multiple typo in Documentation tpm_tis: fix tis_lock with respect to RCU Revert "media: Fix typo in mixer_drv.c and hdmi_drv.c" Doc: Update numastat.txt qla4xxx: Add missing spaces to error messages compiler.h: Fix typo security: struct security_operations kerneldoc fix Documentation: broken URL in libata.tmpl Documentation: broken URL in filesystems.tmpl mtd: simplify return logic in do_map_probe() mm: fix comment typo of truncate_inode_pages_range power: bq27x00: Fix typos in comment ...
2012-03-19ASoC: wm8994: Provide VMID mode control and fix default sequenceMark Brown
The optimal management of VMID depends on a number of factors which vary dynamically at runtime, for example the connection to a system docking station. In some circumstances it is desirable to keep VMID enabled all the time, in others it is desirable to aggressively power it up and down. Provide a callback allowing machine driver to configure either the normal power up/down mode (WM8994_VMID_MODE_NORMAL) or to maintain VMID even when idle (WM8994_VMID_MODE_FORCE). This callback, wm8994_vmid_mode(), should be called with the CODEC lock. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-03-19ASoC: wm8994: Add missing break in resumeMark Brown
2012-03-19ASoC: wm_hubs: Don't actively manage LINEOUT_VMID_BUFMark Brown
It can just be enabled all the time with no impact. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-03-19Merge tag 'v3.3' into staging/for_v3.4Mauro Carvalho Chehab
* tag 'v3.3': (1646 commits) Linux 3.3 Don't limit non-nested epoll paths netfilter: ctnetlink: fix race between delete and timeout expiration ipv6: Don't dev_hold(dev) in ip6_mc_find_dev_rcu. nilfs2: fix NULL pointer dereference in nilfs_load_super_block() nilfs2: clamp ns_r_segments_percentage to [1, 99] afs: Remote abort can cause BUG in rxrpc code afs: Read of file returns EBADMSG C6X: remove dead code from entry.S wimax/i2400m: fix erroneous NETDEV_TX_BUSY use net/hyperv: fix erroneous NETDEV_TX_BUSY use net/usbnet: reserve headroom on rx skbs bnx2x: fix memory leak in bnx2x_init_firmware() bnx2x: fix a crash on corrupt firmware file sch_sfq: revert dont put new flow at the end of flows ipv6: fix icmp6_dst_alloc() MAINTAINERS: Add Serge as maintainer of capabilities drivers/video/backlight/s6e63m0.c: fix corruption storing gamma mode MAINTAINERS: add entry for exynos mipi display drivers MAINTAINERS: fix link to Gustavo Padovans tree ...
2012-03-19[media] tea575x: fix HW seekHans Verkuil
Fix HW seek in TEA575x to work properly: - a delay must be present after search start and before first register read or the seek does weird things - when the search stops, the new frequency is not available immediately, we must wait until it appears in the register (fortunately, we can clear the frequency bits when starting the search as it starts at the frequency currently set, not from the value written) - sometimes, seek remains on the current frequency (or moves only a little), so repeat it until it moves by at least 50 kHz Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-19[media] tea575x-tuner: update to latest V4L2 framework requirementsHans Verkuil
The tea575x-tuner module has been updated to use the latest V4L2 framework functionality. This also required changes in the drivers that rely on it. The tea575x changes are: - The drivers must provide a v4l2_device struct to the tea module. - The radio_nr module parameter must be part of the actual radio driver, and not of the tea module. - Changed the frequency range to the normal 76-108 MHz range instead of 50-150. - Add hardware frequency seek support. - Fix broken rxsubchans/audmode handling. - The application can now select between stereo and mono. - Support polling for control events. - Add V4L2 priority handling. And radio-sf16fmr2.c now uses the isa bus kernel framework. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Thanks-to: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-19ASoC: pxa-ssp: atomically set stream active masksDaniel Mack
PXA's SSP engine fails to take its current channel phase into account when enabling a stream while the engine is already running. This results in randomly swapped left/right channels on either the record or the playback side, depending on which one was enabled first. The following patch fixes this by factoring out the bit field modifications in question to a separate function that pauses the engine temporarily, modifies the bits and kicks it off again afterwards. Appearantly, a transition of SSCR0_SSE syncs both directions properly. The patch has been rolled out to quite a number of devices over the last weeks and seems to fix the issue reliably. Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-and-tested-by: Sven Neumann <s.neumann@raumfeld.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2012-03-18Merge branch 'topic/jack' into for-linusTakashi Iwai
2012-03-18Merge branch 'topic/asoc' into for-linusTakashi Iwai
2012-03-18Merge branch 'topic/misc' into for-linusTakashi Iwai
2012-03-18Merge branch 'topic/hda' into for-linusTakashi Iwai
2012-03-17ASoC: fsl: p1022ds: tell the WM8776 codec driver that it's the masterTimur Tabi
The WM8776 codec driver requires the machine driver to set one of the SND_SOC_DAIFMT_CBx_xxx values. The P1022DS machine driver should be setting SND_SOC_DAIFMT_CBM_CFM, but since that value was zero, no one noticed. Commit 75d9ac46 ("ASoC: Allow DAI formats to be specified in the dai_link"), however, changed the value of SND_SOC_DAIFMT_CBM_CFM from zero to a non-zero value, which means that it now needs to be specifically set by the machine driver. We also set SND_SOC_DAIFMT_NB_NF, for the same reason. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2012-03-16ARM: 7362/1: AMBA: Add module_amba_driver() helper macro for amba_driverviresh kumar
For simple modules that contain a single amba_driver without any additional setup code then ends up being a block of duplicated boilerplate. This patch adds a new macro, module_amba_driver(), which replaces the module_init()/module_exit() registrations with template functions. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-16ASoC: Samsung: Added to support mono recordingSangsu Park
The dma size will be changed by requested number of channel(mono/stereo) from platform. For mono recording, channels_min value should be 1. Signed-off-by: Sangsu Park <sangsu4u.park@samsung.com> Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
