[ Upstream commit c9a4c63888dbb79ce4d068ca1dd8b05bc3f156b1 ]
The kernel may spew a WARNING with UBSAN undefined behavior at
handling ALSA sequencer ioctl SNDRV_SEQ_IOCTL_QUERY_NEXT_CLIENT:
UBSAN: Undefined behaviour in sound/core/seq/seq_clientmgr.c:2007:14
signed integer overflow:
2147483647 + 1 cannot be represented in type 'int'
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x122/0x1c8 lib/dump_stack.c:113
ubsan_epilogue+0x12/0x86 lib/ubsan.c:159
handle_overflow+0x1c2/0x21f lib/ubsan.c:190
__ubsan_handle_add_overflow+0x2a/0x31 lib/ubsan.c:198
snd_seq_ioctl_query_next_client+0x1ac/0x1d0 sound/core/seq/seq_clientmgr.c:2007
snd_seq_ioctl+0x264/0x3d0 sound/core/seq/seq_clientmgr.c:2144
It happens only when INT_MAX is passed there, as we're incrementing it
unconditionally. So the fix is trivial, check the value with
INT_MAX. Although the bug itself is fairly harmless, it's better to
fix it so that fuzzers won't hit this again later.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=200211
commit 3acd3e3bab95ec3622ff98da313290ee823a0f68 upstream.
The endian conversions used in vxp_dma_read() and vxp_dma_write() are
superfluous and even wrong on big-endian machines, as inw() and outw()
already do conversions. Kill them.
Cc: <stable@vger.kernel.org>
commit dfef01e150824b0e6da750cacda8958188d29aea upstream.
snd_dma_alloc_pages_fallback() tries to allocate pages again when the
allocation fails with reduced size. But the first try actually
*increases* the size to power-of-two, which may give back a larger
chunk than the requested size. This confuses the callers, e.g. sgbuf
assumes that the size is equal or less, and it may result in a bad
loop due to the underflow and eventually lead to Oops.
The code of this function seems incorrectly assuming the usage of
get_order(). We need to decrease at first, then align to
power-of-two.
Reported-and-tested-by: he, bo <bo.he@intel.com>
Reported-by: zhang jun <jun.zhang@intel.com>
commit 8e82a728792bf66b9f0a29c9d4c4b0630f7b9c79 upstream.
I added the subsys product-id for the HDMI HDA device rather then for
the PCH one, this commit fixes this.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1525104
Cc: stable@vger.kernel.org
commit 69756930f2de0457d51db7d505a1e4f40e9fd116 upstream.
One place in cs5535audio_build_dma_packets() does an extra conversion
via cpu_to_le32(); namely jmpprd_addr is passed to setup_prd() ops,
which writes the value via cs_writel(). That is, the callback does
the conversion by itself, and we don't need to convert beforehand.
This patch fixes that bogus conversion.
commit 50e9ffb1996a5d11ff5040a266585bad4ceeca0a upstream.
The virmidi output trigger tries to parse the all available bytes and
process sequencer events as much as possible. In a normal situation,
this is supposed to be relatively short, but a program may give a huge
buffer and it'll take a long time in a single spin lock, which may
eventually lead to a soft lockup.
This patch simply adds a workaround, a cond_resched() call in the loop
if applicable. A better solution would be to move the event processor
into a work, but let's put a duct-tape quickly at first.
Reported-and-tested-by: Dae R. Jeong <threeearcat@gmail.com>
Reported-by: syzbot+619d9f40141d826b097e@syzkaller.appspotmail.com
commit fff71a4c050ba46e305d910c837b99ba1728135e upstream.
The endian conversions used in vx2_dma_read() and vx2_dma_write() are
superfluous and even wrong on big-endian machines, as inl() and outl()
Spotted by sparse, a warning like:
sound/pci/vx222/vx222_ops.c:278:30: warning: incorrect type in argument 1 (different base types)
commit d77a4b4a5b0b2ebcbc9840995d91311ef28302ab upstream.
As an equivalent codec with CX20724,
CX8200 is also subject to the reboot bug.
Late 2017 and 2018 LG Gram and some HP Spectre laptops are known victims
to this issue, causing extremely loud noises upon reboot.
Now that we know that this bug is subject to multiple codecs,
fix the comment as well.
Signed-off-by: Park Ju Hyung <qkrwngud825@gmail.com>
commit f59cf9a0551dd954ad8b752461cf19d9789f4b1d upstream.
On rare occasions, we are still noticing that the internal speaker
spitting out spurious noises even after adding the problematic codec
to the list.
Adding a 10ms artificial delay before rebooting fixes the issue entirely.
Patch for Realtek codecs also adds the same amount of delay after
entering D3.
commit 3bbda5a38601f7675a214be2044e41d7749e6c7b upstream.
If the ts3a227e audio accessory detection hardware is present and its
driver probed, the jack needs to be created before enabling jack
detection in the ts3a227e driver. With this patch, the jack is
instantiated in the max98090 headset init function if the ts3a227e is
present. This fixes a null pointer dereference as the jack detection
enabling function in the ts3a driver was called before the jack is
created.
[minor correction to keep error handling on jack creation the same
as before by Pierre Bossart]
Signed-off-by: Thierry Escande <thierry.escande@collabora.com>
Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Acked-By: Vinod Koul <vinod.koul@intel.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
[ Upstream commit 8e142e9e628975b0dddd05cf1b095331dff6e2de ]
DECLARE_TLV_DB_SCALE (alias of SNDRV_CTL_TLVD_DECLARE_DB_SCALE) is used but
tlv.h is not included. This causes build failure when local macro is
defined by comment-out.
This commit fixes the bug. At the same time, the alias macro is replaced
with a destination macro added at a commit 46e860f76804 ("ALSA: rename
TLV-related macros so that they're friendly to user applications")
Reported-by: Connor McAdams <conmanx360@gmail.com>
Fixes: 44f0c9782cc6 ('ALSA: hda/ca0132: Add tuning controls')
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
[ Upstream commit 377a879d9832f4ba69bd6a1fc996bb4181b1e504 ]
retire_capture_urb() may print warning messages when the given URB
doesn't align, and this may flood the system log easily.
Put the rate limit to the message for avoiding it.
Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=1093485
[ Upstream commit 11d42c81036324697d367600bfc16f6dd37636fd ]
The error messages at sanity checks of memory pages tend to repeat too
many times once when it hits, and without the rate limit, it may flood
and become unreadable. Replace such messages with the *_ratelimited()
variant.
Bugzilla: http://bugzilla.opensuse.org/show_bug.cgi?id=1093027
[ Upstream commit 9c0ac70ad24d76b873c1551e27790c7f6a815d5c ]
In case, one BE is used by two FE1/FE2
FE1--->BE-->
FE2----]
when FE1/FE2 call dpcm_be_dai_hw_free() together
the BE users will be 2 (> 1), hence cannot be hw_free
the be state will leave at, ex. SND_SOC_DPCM_STATE_STOP
later FE1/FE2 call dpcm_be_dai_shutdown(),
will be skip due to wrong state.
leaving the BE not being hw_free and shutdown.
The BE dai will be hw_free later when calling
dpcm_be_dai_shutdown() if still in invalid state.
Signed-off-by: KaiChieh Chuang <kaichieh.chuang@mediatek.com>
[ Upstream commit ef1ffbe7889e99f5b5cccb41c89e5c94f50f3218 ]
When snd_ctl_add fails, the lack of error-handling code may
cause unexpected results.
This patch adds error-handling code after calling snd_ctl_add.
Signed-off-by: Zhouyang Jia <jiazhouyang09@gmail.com>
Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
[ Upstream commit 6d531e7b972cb62ded011c2dfcc2d9f72ea6c421 ]
commit 39675f7a7c7e7702f7d5341f1e0d01db746543a0 upstream.
The SNDRV_RAWMIDI_IOCTL_PARAMS ioctl may resize the buffers and the
current code is racy. For example, the sequencer client may write to
buffer while it being resized.
As a simple workaround, let's switch to the resized buffer inside the
stream runtime lock.
Reported-by: syzbot+52f83f0ea8df16932f7f@syzkaller.appspotmail.com
commit aaa23f86001bdb82d2f937c5c7bce0a1e11a6c5b upstream.
Obtaining the runtime pm wakeref can fail, especially in a hotplug
scenario where i915.ko has been unloaded. If we do not catch the
failure, we end up with an unbalanced pm.
v2 additions by tiwai:
hdmi_present_sense() checks the return value and handle only a
negative error case and bails out only if it's really still suspended.
Also, snd_hda_power_down() is called at the error path so that the
refcount is balanced.
Along with it, the spec->pcm_lock is taken outside
hdmi_present_sense() in the caller side, so that it won't cause
deadlock at reentrace via runtime resume.
v3 fix by tiwai:
Missing linux/pm_runtime.h is included.
References: 222bde03881c ("ALSA: hda - Fix mutex deadlock at HDMI/DP hotplug")
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
commit 275ec0cb946cb75ac8977f662e608fce92f8b8a8 upstream.
Fujitsu Seimens ESPRIMO Mobile U9210 requires the same fixup as H270
for the correct pin configs.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=200107
commit d5a6cabf02210b896a60eee7c04c670ee9ba6dca upstream.
Some Lenovo laptops, e.g. Lenovo P50, showed the pop noise at resume
or runtime resume. It turned out to be reduced by applying
alc_no_shutup() just like TPT440 quirk does.
Since there are many Lenovo models showing the same behavior, put this
workaround in ALC269_FIXUP_THINKPAD_ACPI entry so that it's applied
commonly to all such Lenovo machines.
Reported-by: Hans de Goede <hdegoede@redhat.com>
Tested-by: Benjamin Berg <bberg@redhat.com>
commit 5d302ed3cc80564fb835bed5fdba1e1250ecc9e5 upstream.
According to "EP93xx User’s Guide", I2STXLinCtrlData and I2SRXLinCtrlData
registers actually have different format. The only currently used bit
(Left_Right_Justify) has different position. Fix this and simplify the
whole setup taking into account the fact that both registers have zero
default value.
The practical effect of the above is repaired SND_SOC_DAIFMT_RIGHT_J
support (currently unused).
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@gmail.com>
commit 2d534113be9a2aa532a1ae127a57e83558aed358 upstream.
The bit responsible for LRCLK polarity is i2s_tlrs (0), not i2s_trel (2)
(refer to "EP93xx User's Guide").
Previously card drivers which specified SND_SOC_DAIFMT_NB_IF actually got
SND_SOC_DAIFMT_NB_NF, an adaptation is necessary to retain the old
behavior.
commit ff2faf1289c1f81b5b26b9451dd1c2006aac8db8 upstream.
dapm_kcontrol_data is freed as part of dapm_kcontrol_free(), leaving the
paths pointer dangling in the list.
This leads to system crash when we try to unload and reload sound card.
I hit this bug during ADSP crash/reboot test case on Dragon board DB410c.
Without this patch, on SLAB Poisoning enabled build, kernel crashes with
"BUG kmalloc-128 (Tainted: G W ): Poison overwritten"
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
commit 7eef32c1ef895a3a96463f9cbd04203007cd5555 upstream.
This patch adds missing initialisation for HP 2013 UltraSlim Dock
Line-In/Out PINs and activates keyboard mute/micmute leds
for HP ProBook 640 G4
Signed-off-by: Dennis Wassenberg <dennis.wassenberg@secunet.com>
commit 2861751f67b91e1d24e68010ced96614fb3140f4 upstream.
for HP EliteBook 830 G5
commit a3aa60d511746bd6c0d0366d4eb90a7998bcde8b upstream.
When 'kzalloc()' fails in 'snd_hda_attach_pcm_stream()', a new pcm instance is
created without setting its operators via 'snd_pcm_set_ops()'. Following
operations on the new pcm instance can trigger kernel null pointer dereferences
and cause kernel oops.
This bug was found with my work on building a gray-box fault-injection tool for
linux-kernel-module binaries. A kernel null pointer dereference was confirmed
from line 'substream->ops->open()' in function 'snd_pcm_open_substream()' in
file 'sound/core/pcm_native.c'.
This patch fixes the bug by calling 'snd_device_free()' in the error handling
path of 'kzalloc()', which removes the new pcm instance from the snd card before
returns with an error code.
Signed-off-by: Bo Chen <chenbo@pdx.edu>
commit f429e7e494afaded76e62c6f98211a635aa03098 upstream.
Add new support for ALC257 codec.
[ It's supposed to be almost equivalent with other ALC25x variants,
just adding another type and id -- tiwai ]
Signed-off-by: Kailang Yang <kailang@realtek.com>
Tested-by: Pali Rohár <pali.rohar@gmail.com>
commit 271ef65b5882425d500e969e875c98e47a6b0c86 upstream.
The pointer dma_dev_name is assigned but never read, it is redundant
and can therefore be removed.
Cleans up clang warning:
sound/soc/intel/common/sst-firmware.c:288:3: warning: Value stored to
'dma_dev_name' is never read
Acked-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
[ Upstream commit 2e2c177ca84aff092c3c96714b0f6a12900f3946 ]
In slave_update() of vmaster code ignores the error from the slave
get() callback and copies the values. It's not only about the missing
error code but also that this may potentially lead to a leak of
uninitialized variables when the slave get() don't clear them.
This patch fixes slave_update() not to copy the potentially
uninitialized values when an error is returned from the slave get()
callback, and to propagate the error value properly.
[ Upstream commit c469652bb5e8fb715db7d152f46d33b3740c9b87 ]
The commit ffcd28d88e4f ("ALSA: hda - Select INPUT for Realtek
HD-audio codec") introduced the reverse-selection of CONFIG_INPUT for
Realtek codec in order to avoid the mess with dependency between
built-in and modules. Later on, we obtained IS_REACHABLE() macro
exactly for this kind of problems, and now we can remove th INPUT
selection in Kconfig and put IS_REACHABLE(INPUT) to the appropriate
places in the code, so that the driver doesn't need to select other
subsystem forcibly.
Fixes: ffcd28d88e4f ("ALSA: hda - Select INPUT for Realtek HD-audio codec")
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Acked-by: Randy Dunlap <rdunlap@infradead.org> # and build-tested
commit 3ae180972564846e6d794e3615e1ab0a1e6c4ef9 upstream.
Commit f65e0d299807 ("ALSA: timer: Call notifier in the same spinlock")
combined the start/continue and stop/pause functions, and in doing so
changed the event code for the pause case to SNDRV_TIMER_EVENT_CONTINUE.
Change it back to SNDRV_TIMER_EVENT_PAUSE.
Fixes: f65e0d299807 ("ALSA: timer: Call notifier in the same spinlock")
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
[ Upstream commit 647d04f8e07afc7c3b7a42b3ee01a8b28db29631 ]
If the RCLK mux clock configuration is specified in DT and no set_sysclk()
callback is used in the sound card driver the sclk_srcrate field will remain
set to 0, leading to an incorrect PSR divider setting.
To fix this the frequency value is retrieved from the CLK_I2S_RCLK_SRC clock,
so the actual RCLK mux selection is taken into account.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
[ Upstream commit bde8b3887add8368ecf0ca71117baf2fd56a6fc9 ]
This patch adds the change required to create the TLV data
for dapm widget kcontrols from topology. This also fixes the following
TLV read error shown in amixer while showing the card control contents.
"amixer: Control hw:1 element TLV read error: No such device or address"
Signed-off-by: Ranjani Sridharan <ranjani.sridharan@linux.intel.com>
[ Upstream commit 123af9043e93cb6f235207d260d50f832cdb5439 ]
The loop timeout doesn't work because it's a post op and ends with "tmo"
set to -1. I changed it from a post-op to a pre-op and I changed the
initial the starting value from 5 to 6 so we still iterate 5 times. I
left the other as it was because it's a large number.
Fixes: b3c70c9ea62a ("ASoC: Alchemy AC97C/I2SC audio support")
[ Upstream commit 71426535f49fe6034d0e0db77608b91a0c1a022d ]
Add native DSD support quirk for Luxman DA-06 DAC, by adding the
PID/VID 1852:5065.
Rename "is_marantz_denon_dac()" function to "is_itf_usb_dsd_2alts_dac()"
to cover broader device family sharing the same USB audio
implementation(*).
For the same reason, rename "is_teac_dsd_dac()" function to
"is_itf_usb_dsd_3alts_dac()".
These devices have the same USB controller "ITF-USB DSD", supplied by
INTERFACE Co., Ltd.
"ITF-USB DSD" USB controller has two patterns,
Pattern 1. (2 altsets version)
- Altset 0: for control
- Altset 1: for stream (S32)
- Altset 2: for stream (S32, DSD_U32)
Pattern 2. (3 altsets version)
- Altset 1: for stream (S16)
- Altset 2: for stream (S32)
- Altset 3: for stream (S32, DSD_U32)
"is_itf_usb_dsd_2alts_dac()" returns true, if the DAC has "Pattern 1"
USB controller, and "is_itf_usb_dsd_3alts_dac()" returns true, if
"Pattern2".
Signed-off-by: Nobutaka Okabe <nob77413@gmail.com>
commit 3f12888dfae2a48741c4caa9214885b3aaf350f9 upstream.
In snd_ctl_elem_add_compat(), the fields of the struct 'data' need to be
copied from the corresponding fields of the struct 'data32' in userspace.
This is achieved by invoking copy_from_user() and get_user() functions. The
problem here is that the 'type' field is copied twice. One is by
copy_from_user() and one is by get_user(). Given that the 'type' field is
not used between the two copies, the second copy is *completely* redundant
and should be removed for better performance and cleanup. Also, these two
copies can cause inconsistent data: as the struct 'data32' resides in
userspace and a malicious userspace process can race to change the 'type'
field between the two copies to cause inconsistent data. Depending on how
the data is used in the future, such an inconsistency may cause potential
security risks.
For above reasons, we should take out the second copy.
Signed-off-by: Wenwen Wang <wang6495@umn.edu>
commit c8beccc19b92f5172994c0732db689c08f4f98e5 upstream.
Power-saving is causing loud plops on the Lenovo C50 All in one, add it
to the blacklist.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1572975
commit 21493316a3c4598f308d5a9fa31cc74639c4caff upstream.
Currently it's not possible to set volume lower than 26% (it just mutes).
Also fixes this warning:
Warning! Unlikely big volume range (=9472), cval->res is probably wrong.
[13] FU [PCM Playback Volume] ch = 2, val = -9473/-1/1
, and volume works fine for full range.
Signed-off-by: Federico Cuello <fedux@fedux.com.ar>
commit 76b3421b39bd610546931fc923edcf90c18fa395 upstream.
Some control API callbacks in aloop driver are too lazy to take the
loopback->cable_lock and it results in possible races of cable access
while it's being freed. It eventually lead to a UAF, as reported by
fuzzer recently.
This patch covers such control API callbacks and add the proper mutex
locks.
Reported-by: DaeRyong Jeong <threeearcat@gmail.com>
commit 306a4f3ca7f3c7dfa473ebd19d66e40e59d99734 upstream.
Show paused ALSA aloop device as inactive, i.e. the control
"PCM Slave Active" set as false. Notification sent upon state change.
This makes it possible for client capturing from aloop device to know if
data is expected. Without it the client expects data even if playback
is paused.
Signed-off-by: Robert Rosengren <robert.rosengren@axis.com>
commit 8f22e52528cc372b218b5f100457469615c733ce upstream.
The sequencer virmidi code has an open race at its output trigger
callback: namely, virmidi keeps only one event packet for processing
while it doesn't protect for concurrent output trigger calls.
snd_virmidi_output_trigger() tries to process the previously
unfinished event before starting encoding the given MIDI stream, but
this is done without any lock. Meanwhile, if another rawmidi stream
starts the output trigger, this proceeds further, and overwrites the
event package that is being processed in another thread. This
eventually corrupts and may lead to the invalid memory access if the
event type is like SYSEX.
The fix is just to move the spinlock to cover both the pending event
and the new stream.
The bug was spotted by a new fuzzer, RaceFuzzer.
BugLink: http://lkml.kernel.org/r/20180426045223.GA15307@dragonet.kaist.ac.kr
commit f13876e2c33a657a71bcbb10f767c0951b165020 upstream.
Since snd_pcm_ioctl_xfern_compat() has no PCM state check, it may go
further and hit the sanity check pcm_sanity_check() when the ioctl is
called right after open. It may eventually spew a kernel warning, as
triggered by syzbot, depending on kconfig.
The lack of PCM state check there was just an oversight. Although
it's no real crash, the spurious kernel warning is annoying, so let's
add the proper check.
Reported-by: syzbot+1dac3a4f6bc9c1c675d4@syzkaller.appspotmail.com
commit c656941df9bc80f7ec65b92ca73c42f8b0b62628 upstream.
When the desired ratio is less than 256, the savesub (tolerance)
in the calculation would become 0. This will then fail the loop-
search immediately without reporting any errors.
But if the ratio is smaller enough, there is no need to calculate
the tolerance because PM divisor alone is enough to get the ratio.
So a simple fix could be just to set PM directly instead of going
into the loop-search.
Reported-by: Marek Vasut <marex@denx.de>
Signed-off-by: Nicolin Chen <nicoleotsuka@gmail.com>
Tested-by: Marek Vasut <marex@denx.de>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
commit ea04a1dbf8b1d6af759d58e705636fde48583f8f upstream.
Fill COEF to change EAPD to verb control.
Assigned codec type.
This is an additional fix over 92f974df3460 ("ALSA: hda/realtek - New
vendor ID for ALC233").
[ More notes:
according to Kailang, the chip is 10ec:0235 bonding for ALC233b,
which is equivalent with ALC255. It's only used for Lenovo.
The chip needs no alc_process_coef_fw() for headset unlike ALC255. ]
commit 69fa6f19b95597618ab30438a27b67ad93daa7c7 upstream.
As recently Smatch suggested, one place in HD-audio hwdep ioctl codes
may expand the array directly from the user-space value with
speculation:
sound/pci/hda/hda_local.h:467 get_wcaps() warn: potential spectre issue 'codec->wcaps'
As get_wcaps() itself is a fairly frequently called inline function,
and there is only one single call with a user-space value, we replace
only the latter one to open-code locally with array_index_nospec()
hardening in this patch.
BugLink: https://marc.info/?l=linux-kernel&m=152411496503418&w=2
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
commit 8d218dd8116695ecda7164f97631c069938aa22e upstream.
As Smatch recently suggested, a few places in OSS sequencer codes may
expand the array directly from the user-space value with speculation,
namely there are a significant amount of references to either
info->ch[] or dp->synths[] array:
sound/core/seq/oss/seq_oss_event.c:315 note_on_event() warn: potential spectre issue 'info->ch' (local cap)
sound/core/seq/oss/seq_oss_event.c:362 note_off_event() warn: potential spectre issue 'info->ch' (local cap)
sound/core/seq/oss/seq_oss_synth.c:470 snd_seq_oss_synth_load_patch() warn: potential spectre issue 'dp->synths' (local cap)
sound/core/seq/oss/seq_oss_event.c:293 note_on_event() warn: potential spectre issue 'dp->synths'
sound/core/seq/oss/seq_oss_event.c:353 note_off_event() warn: potential spectre issue 'dp->synths'
sound/core/seq/oss/seq_oss_synth.c:506 snd_seq_oss_synth_sysex() warn: potential spectre issue 'dp->synths'
sound/core/seq/oss/seq_oss_synth.c:580 snd_seq_oss_synth_ioctl() warn: potential spectre issue 'dp->synths'
Although all these seem doing only the first load without further
reference, we may want to stay in a safer side, so hardening with
array_index_nospec() would still make sense.
We may put array_index_nospec() at each place, but here we take a
different approach:
- For dp->synths[], change the helpers to retrieve seq_oss_synthinfo
pointer directly instead of the array expansion at each place
- For info->ch[], harden in a normal way, as there are only a couple
of places
As a result, the existing helper, snd_seq_oss_synth_is_valid() is
replaced with snd_seq_oss_synth_info(). Also, we cover MIDI device
where a similar array expansion is done, too, although it wasn't
reported by Smatch.
commit f5e94b4c6ebdabe0f602d796e0430180927521a0 upstream.
When get_synthdev() is called for a MIDI device, it returns the fixed
midi_synth_dev without the use refcounting. OTOH, the caller is
supposed to unreference unconditionally after the usage, so this would
lead to unbalanced refcount.
This patch corrects the behavior and keep up the refcount balance also
for the MIDI synth device.
commit f853dcaae2f5bbe021161e421bd1576845bae8f6 upstream.
It looks like a simple mistake that this struct member
was forgotten.
Audio_tstamp isn't used much, and on some archs (such as x86) this
ioctl is not used by default, so that might be the reason why this
has slipped for so long.
Fixes: 4eeaaeaea1ce ("ALSA: core: add hooks for audio timestamps")
Signed-off-by: David Henningsson <diwic@ubuntu.com>
Reviewed-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
Cc: <stable@vger.kernel.org> # v3.8+
commit f526afcd8f71945c23ce581d7864ace93de8a4f7 upstream.
As recently Smatch suggested, one place in RME9652 driver may expand
the array directly from the user-space value with speculation:
sound/pci/rme9652/rme9652.c:2074 snd_rme9652_channel_info() warn: potential spectre issue 'rme9652->channel_map' (local cap)
This patch puts array_index_nospec() for hardening against it.
commit 10513142a7114d251670361ad40cba2c61403406 upstream.
As recently Smatch suggested, a couple of places in HDSP MADI driver
speculation:
sound/pci/rme9652/hdspm.c:5717 snd_hdspm_channel_info() warn: potential spectre issue 'hdspm->channel_map_out' (local cap)
sound/pci/rme9652/hdspm.c:5734 snd_hdspm_channel_info() warn: potential spectre issue 'hdspm->channel_map_in' (local cap)
This patch puts array_index_nospec() for hardening against them.
