path: root/sound
2007-01-03[SOUND] Sparc CS4231: Use 64 for period_bytes_minDavid S. Miller
This matches what the ISA cs4231 driver uses. Tested by Georg Chini. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-03[SOUND] Sparc CS4231: Fix IRQ return value and initialization.Georg Chini
SBUS: Change IRQ-handler return value from 0 to IRQ_HANDLED and fix some initialisation problems. Change period_bytes_min from 4096 to 256 to allow driver to work with low latency (VOIP) applications. Hope this does not break EBUS. Signed-off-by: Georg Chini <georg.chini@triaton-webhosting.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-01[PATCH] sound: hda: detect ALC883 on MSI K9A Platinum motherboards (MS-7280)Leonard Norrgård
Recognize the Realtek ALC883 chip on MSI K9A Platinum motherboards (model no. MS-7280), enabling full sound capabilities. Signed-off-by: Leonard Norrgård <leonard.norrgard@refactor.fi> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-20[ALSA] ac97: Identify CMI9761 chips.James Courtier-Dutton
Signed-off-by: James Courtier-Dutton <James@superbug.co.uk> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] ac97_codec - trivial fix for bit update functionsJames C Georgas
This patch fixes a couple of bit update functions in alsa-kernel/pci/ac97/ac97_codec.c, which could possibly corrupt bits not in the given mask. Specifically, it'll clobber unset bits in the target that are not in the mask, when the corresponding bit in the given new value is set. Signed-off-by: James C Georgas <jgeorgas@rogers.com> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] snd-ca0106: Fix typos.James Courtier-Dutton
2006-12-20[ALSA] snd-ca0106: Add new card variant.James Courtier-Dutton
Fixed ALSA bug#2326 Signed-off-by: James Courtier-Dutton <James@superbug.co.uk> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] sound: fix PCM substream listAkinobu Mita
If snd_pcm_new_stream() fails to initalize a substream (if snd_pcm_substream_proc_init() returns error), snd_pcm_new_stream() immediately return without unlinking that kfree()d substram. It causes oops when snd_pcm_free() iterates the list of substream to free them by invalid reference. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] sound: initialize rawmidi substream listAkinobu Mita
If snd_rawmidi_new() failed to allocate substreams for input (snd_rawmidi_alloc_substreams() failed to populate a &rmidi->streams[SNDRV_RAWMIDI_STREAM_INPUT]), it will try to free rawmidi instance by snd_rawmidi_free(). But it will cause oops because snd_rawmidi_free() tries to free both of substreams list but list for output (&rmidi->streams[SNDRV_RAWMIDI_STREAM_OUTPUT]) is not initialized yet. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] snd_hda_intel 3stack mode for ASUS P5P-L2Nickolay V. Shmyrev
I have ASUS P5PL2 motherboard and it's embedded sound card requires the following patch which sets '3stack' model to operate properly: 00:1b.0 0403: 8086:27d8 (rev 01) Subsystem: 1043:817f Flags: bus master, fast devsel, latency 0, IRQ 177 Memory at dfdf8000 (64-bit, non-prefetchable) [size=16K] Capabilities: [50] Power Management version 2 Capabilities: [60] Message Signalled Interrupts: 64bit+ Queue=0/0 Enable- Capabilities: [70] Express Unknown type IRQ 0 Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] Remove IRQF_DISABLED for shared PCI irqsTakashi Iwai
Fix IRQ flags for PCI devices. The shared IRQs for PCI devices shouldn't be allocated with IRQF_DISABLED. Also, when MSI is enabled, IRQF_SHARED shouldn't be used. The patch removes unnecessary cast in request_irq and free_irq, too. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] Fix invalid assignment of PCI revisionTakashi Iwai
Fix the type of PCI revision to char from int and avoid invalid assignment with pointer cast. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] Fix races in PCM OSS emulationTakashi Iwai
Fixed the race among multiple threads accessing the OSS PCM instance concurrently by simply introducing a mutex for protecting a setup of the PCM. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] hda-codec - fix typo in PCI IDsChristian Hesse
my notebook is a Samsung X11 of course... The attached patch fixes the typo. Signed-off-by: Christian Hesse <mail@earthworm.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] ac97 - Fix potential negative array indexTakashi Iwai
Fix the case cidx2 >= 0 and cidx2 < 0 which may result in negative array index. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] hda-codec - Verbose proc output for PCM parametersTakashi Iwai
Make the output for PCM parameters more verbose, showing each rate, bits and format. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] hda-codec - Fix detection of supported sample ratesTakashi Iwai
Don't include 9.6kHz in the list of supported sample rates. Since this rate isn't indicated in AC_PAR_PCM parameter, the driver might guess wrongly as if it's available. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] hda-codec - Fix model for ASUS V1j laptopTakashi Iwai
Add a proper model entry (laptop-eapd) for ASUS V1j laptop with AD1986A codec. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] sound/core/control.c: remove dead codeAdrian Bunk
This patch removes some obviously dead code spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] hda-codec - Add model for HP q965Takashi Iwai
Added a model entry (HP_BPC) for HP q965 with ALC262 codec. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] pcm core: fix silence_start calculationsClemens Ladisch
The case where silence_size < boundary was broken because different parts of the snd_pcm_playback_silence() function disagreed about whether silence_start should point to the start or to the end of the buffer part to be silenced. This patch changes the code to always use to the start, which also simplifies several calculations. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] hda-codec - Fix a typoTakashi Iwai
Fixed a typo in proc file. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] hdsp: precise_ptr control switched off by defaultRemy Bruno
precise_ptr option causes dysfunction with hdsp driver. Turn it off as default. Signed-off-by: Remy Bruno <remy.bruno@trinnov.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] hda-codec - Don't return error at initialization of modem codecTakashi Iwai
Some modem codec seem to fail in the initialization, and this stopped loading of the whole module although the audio is OK. Since it's usually a non-fatal issue, the driver tries to proceed to initialize now. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] hda-codec - Fix wrong error checks in patch_{realtek,analog}.cTakashi Iwai
Fix wrong error checks of *_ch_mode_put() in patch_realtek.c and patch_analog.c. snd_hda_ch_mode_put() could return a positive value for success, too. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] ymfpci: fix swap_rear for S/PDIF passthroughGlen Masgai
This patch fixes incorrect assignment of swap_rear, which was broken since patch 'ymfpci - make rear channel swap optional' It removes module_param rear_swap. Signed-off-by: Glen Masgai <mimosius@gmx.de> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] use the roundup macroClemens Ladisch
Use the roundup macro instead of manual calculations. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] use the ALIGN macroClemens Ladisch
Use the ALIGN macro instead of manual calculations. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] ac97_codec (ALC655): add EAPD hack for MSI L725 laptopJaroslav Kysela
New PCI ID described and tested Spectr <spectr@gmail.com> . Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] sound: Don't include i2c-dev.hJean Delvare
Don't include <linux/i2c-dev.h> as it's not needed. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] sound/usb/usbaudio: Handle return value of usb_register()Tobias Klauser
Handle the return value of usb_register() in the module_init function. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] via82xx: add __devinitdataAndreas Mohr
add __devinitdata to struct whitelist, since it's used within a __devinit function. Add const attribute to iterator variable, too. Compile-tested (no section warnings etc.) and run-tested on vt8233, 2.6.18-mm3 (hopefully applies well to current ALSA). Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-17[PATCH] more work_struct fixes: tas300x sound driversAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: Fix inotify maintainers entry Fix typo in new debug options. Jon needs a new shift key. fs: Convert kmalloc() + memset() to kzalloc() in fs/. configfs.h: Remove dead macro definitions. kconfig: Standardize "depends" -> "depends on" in Kconfig files e100: replace kmalloc with kcalloc um: replace kmalloc+memset with kzalloc fix typo in net/ipv4/ip_fragment.c include/linux/compiler.h: reject gcc 3 < gcc 3.2 Kconfig: fix spelling error in config KALLSYMS help text Remove duplicate "have to" in comment Fix small typo in drivers/serial/icom.c Use consistent casing in help message EXT{2,3,4}_FS: remove outdated part of the help text
2006-12-12kconfig: Standardize "depends" -> "depends on" in Kconfig filesRobert P. J. Day
Standardize the miniscule percentage of occurrences of "depends" in Kconfig files to "depends on", and update kconfig-language.txt to reflect that. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-12[PATCH] remove config ordering/dependency between ucb1400-ts and sound subsystemNicolas Pitre
Commit 2d4ba4a3b9aef95d328d74a17ae84f8d658059e2 introduced a dependency that was never meant to exist when the ac97_bus.c module was created. Move ac97_bus.c up the directory hierarchy to make sure it is built when selected even if sound is configured out so things work as originally intended. Signed-off-by: Nicolas Pitre <nico@cam.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert soundJosef Sipek
2006-12-07[PATCH] make 1-bit bitfields unsignedMariusz Kozlowski
Keeps sparse happy. Signed-of-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] The scheduled removal of some OSS optionsAdrian Bunk
The scheduled removal of the OSS drivers depending on OSS_OBSOLETE_DRIVER. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] sound/oss/emu10k1: handle userspace copy errorsJeff Garzik
Propagate copy_to/from_user() errors back through callers. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] sound/oss/btaudio.c: ioremap balanced with iounmapAmol Lad
ioremap must be balanced by an iounmap and failing to do so can result in a memory leak. Signed-off-by: Amol Lad <amol@verismonetworks.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] mm: incorrect VM_FAULT_OOM returns from driversNick Piggin
Some drivers are returning OOM when it is not in response to a memory shortage. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Dave Airlie <airlied@linux.ie> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-06Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/pcmcia/ds.c Fix up merge failures with Linus's head and fix new compile failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/ata/libata-scsi.c include/linux/libata.h Futher merge of Linus's head and compilation fixups. Signed-Off-By: David Howells <dhowells@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-04[PATCH] pcmcia: conf.ConfigBase and conf.Present consolidationDominik Brodowski
struct pcmcia_device *p_dev->conf.ConfigBase and .Present are set in almost all PCMICA driver right at the beginning, using the same calls but slightly different implementations. Unfiy this in the PCMCIA core. Includes a small bugfix ("drivers/net/pcmcia/xirc2ps_cs.c: remove unused label") from and Signed-off-by Adrian Bunk <bunk@stusta.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-12-04[PATCH] pcmcia: IDs for Elan serial PCMCIA devciesTony Olech
Add IDs for Elan serial PCMCIA devices. In addition, move the pdaudio_cf driver from matching based on manf_id and card_id to the more specific prod_id1 and prod_id2 to avoid false positives. Signed-off-by: Tony Olech <tony.olech@elandigitalsystems.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-12-04[PATCH] severing poll.h -> mm.hAl Viro
2006-12-01Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6: (103 commits) usbcore: remove unused argument in autosuspend USB: keep count of unsuspended children USB hub: simplify remote-wakeup handling USB: struct usb_device: change flag to bitflag OHCI: make autostop conditional on CONFIG_PM USB: Add autosuspend support to the hub driver EHCI: Fix root-hub and port suspend/resume problems USB: create a new thread for every USB device found during the probe sequence USB: add driver for the USB debug devices USB: added dynamic major number for USB endpoints USB: pegasus error path not resetting task's state USB: endianness fix for asix.c USB: build the appledisplay driver USB serial: replace kmalloc+memset with kzalloc USB: hid-core: canonical defines for Apple USB device IDs USB: idmouse cleanup USB: make drivers/usb/core/driver.c:usb_device_match() static USB: lh7a40x_udc remove double declaration USB: pxa2xx_udc recognizes ixp425 rev b0 chip usbtouchscreen: add support for DMC TSC-10/25 devices ...
