path: root/sound
2007-11-20[ALSA] emu10k1 - Check value ranges in ctl callbacksTakashi Iwai
Check value ranges in ctl callbacks properly. This fixes the unexpected crash due to wrong value assignment. Also, remove invalid comments in the last patch. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-11-20[ALSA] emu10k1: Add mixer controls parameter checking.James Courtier-Dutton
Signed-off-by: James Courtier-Dutton <James@superbug.co.uk> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-11-20[ALSA] fix private data pointer calculation in CS4270 driverTimur Tabi
Fix the calculation of the private_data pointer in the CS4270 driver. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-11-20[ALSA] portman2x4 - Fix probe errorTakashi Iwai
Reported by Ingo Molnar, when booting an allyesconfig bzImage kernel the bootup hangs in the portman2x4 driver (on a box that does not have this hardware), at: Pid: 1, comm: swapper EIP: 0060:[<c02f763c>] CPU: 0 EIP is at parport_pc_read_status+0x4/0x8 EFLAGS: 00000202 Not tainted (2.6.23-rc9 #904) EAX: f7e57a7f EBX: 00000010 ECX: c2b808c0 EDX: 00000379 ESI: f7cb8230 EDI: 00000010 EBP: f7cb8230 DS: 007b ES: 007b FS: 0000 CR0: 8005003b CR2: fff9c000 CR3: 007ec000 CR4: 00000690 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 DR6: ffff0ff0 DR7: 00000400 [<c04613de>] portman_flush_input+0xde/0x12c [<c0461a24>] snd_portman_probe+0x368/0x484 [<c02fbb8c>] __device_attach+0x0/0x8 [<c02fce68>] platform_drv_probe+0xc/0x10 [<c02fba6c>] driver_probe_device+0x74/0x194 [<c0587174>] klist_next+0x38/0x70 [<c02fbb8c>] __device_attach+0x0/0x8 [<c02faea1>] bus_for_each_drv+0x35/0x68 [<c02fbc22>] device_attach+0x72/0x78 the reason is due to an inconsistent error return code of 1 or 2, while snd_portman_probe only realizes negative error codes. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-11-20[ALSA] ca0106 - Fix write proc assignmentTakashi Iwai
The driver assigns the write proc callback to read wrongly. Fixed now. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-11-20[ALSA] s3c2443-ac97: compilation fixKrzysztof Helt
The Samsung S3C24xx uses new architecture file layout in the post 2.6.23 kernel. This patch fixes include path for the s3c2443-ac97.c. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-11-20[ALSA] hda-codec - Revert volume knob controls in STAC codecsTakashi Iwai
Volume knob controls with STAC codecs seem to cause problems with some devices. Volumes change very slowly or silent suddenly. It's likely due to conflict between the software and the hardware volume knob setup. Since we'll have a virtual master control in future, it's safer to remove this control completely right now. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-11-19[ALSA] ca0106 - Check value range in ctl callbacksTakashi Iwai
Check the value ranges in ctl put callbacks properly. Some callbacks may access a wrong pointer depending on the value passed. Also, fixed the access to the wrong field for enum values, and fixed some callbacks to return the proper error code. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-11-19[ALSA] hda-codec - Check PINCAP only for PIN widgetsTakashi Iwai
The recent addition of checking PINCAP for EAPD seems to break some systems due to unexpected response from the codec chip. We shouldn't issue GET_PINCAP verb to non-PIN widgets. Now checks the widget type before checking EAPD bit. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-11-19[ALSA] mpu401: fix recursive locking in timerClemens Ladisch
When the output and input ports are used at the same time, the timer can be interrupted by the hardware interrupt, so we have to disable interrupts when we take a lock in the timer. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-11-19[ALSA] cmipci: fix FLINKON/OFF bitsClemens Ladisch
Fix the definitions of the CM_FLINKON/CM_FLINKOFF register bits that were garbled in the last 'update register definitions' patch. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-11-19[ALSA] hda-codec - Disable shared stream on AD1986ATakashi Iwai
AD1986A has a hardware problem that it cannot share a stream with multiple pins properly. The problem occurs e.g. when a volume is changed during playback. So far, hda-intel driver unconditionally assigns the stream to multiple output pins in copy-front mode, and this should be avoided for AD1986A codec. The original fix patch was by zhejiang <zhe.jiang@intel.com>. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-27duplicate initializer in sound/pci/hda/patch_realtek.cAl Viro
2007-10-23[PARPORT] Remove unused 'irq' argument from parport irq functionsJeff Garzik
None of the drivers with a struct pardevice's ->irq_func() hook ever used the 'irq' argument passed to it, so remove it. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-23[ALSA] hda-codec - Fix possible array overflowTakashi Iwai
dac_nids arrays in each codec support code may have up to 5 items when assigned from the auto-configurator. Some codec codes have less numbers than the possible max. This patch defines the constant and fixes the array definitions. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-23[ALSA] sound/core/control.c: hard-irq-safe -> hard-irq-unsafe lock warningBorislav Petkov
The lock grabbed in snd_ctl_empty_read_queue() is hardirq-unsafe but we hold an hardirq-safe one already, so make the &ctl->read_lock also hard-irq-safe. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-23[ALSA] usb-audio: Another USB mic quirk for Logitech Communicator webcamDawid Wrobel
The patch adds the USB microphone quirk for Logitech Communicator (046d:08f5 Logitech, Inc.) webcam. Signed-off-by: Dawid Wrobel <dawid@klej.net> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-23[ALSA] hda-codec - Fix build without CONFIG_SND_HDA_GENERICTakashi Iwai
Fixed the build error from patch_sigmatel.c when built without CONFIG_SND_HDA_GENERIC by defining a dummy function to return error. Also, clean up hda_codec.c by removing unneeded ifdefs (the compiler will optimize out). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-23[ALSA] hda-codec - Fix Conexant 5045 volumesTakashi Iwai
Fixed the init verbs and added the missing volume controls so that the driver works again with Conexant 5045 codec chip. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-23[ALSA] hda-codec - Fix conflict of Master volume in STAC92xx codecTakashi Iwai
The addition of volume knob as Master volume resulted in conflict with the existing one by stac92xx_auto_create_hp_ctls(). This patch fixes the conflict, and still keeps the Master control for codecs without volume knob as much as possible. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-23[ALSA] snd-bt87x: Make the load_all option work correctlyTrent Piepho
If the load_all option was turned on all cards would be treated as unknown, even those which are in the database. Of course, if the card is in the database there is no reason to use the load_all option. It's there to force loading when the card isn't in the database. But there are out of date wikis that say to do this and some distros might turn this option on by default. So, we keep the load_all option from turning known cards into unknown cards. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-23[ALSA] protect Dreamcast PCM driver (AICA) from G2 bus effectsAdrian McMenamin
The G2 bus on the SEGA Dreamcast connects both the maple peripheral bus and the AICA sound memory. DMA requests on one can cause the other to timeout on memory operations. This patch prevents maple interrupts from causing hiccoughs in the AICA sound (maple bus code will land in 2.6.24). There are other cleanups for this (AICA) code - but this is in effect a regression fix rather than a cleanup. Signed-off-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-23[ALSA] bt87x - Fix section mismatchTakashi Iwai
const and __devinit aren't a good pair, resulting in a section mismatch error. Let's remove const as a temporary solution. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-23[ALSA] hda-codec - Fix AD1986A Lenovo auto-muteTakashi Iwai
The jack detection bit on AD1986A Lenovo N100 seems inverse from the standard definition. Now fixed the detection properly. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-23[ALSA] This simplifies and fixes waiting loops of the mce_down()Krzysztof Helt
function after Trent Piepho's patch for AD1848. It also makes busy_wait() function call not atomic. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-22V4L/DVB (6320): v4l core: remove the unused .hardware V4L1 fieldMauro Carvalho Chehab
struct video_device used to define a .hardware field. While initialized on severl drivers, this field is never used inside V4L. However, drivers using it need to include the old V4L1 header. This seems to cause compilation troubles with some random configs. Better just to remove it from all drivers. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19get rid of input BIT* duplicate definesJiri Slaby
get rid of input BIT* duplicate defines use newly global defined macros for input layer. Also remove includes of input.h from non-input sources only for BIT macro definiton. Define the macro temporarily in local manner, all those local definitons will be removed further in this patchset (to not break bisecting). BIT macro will be globally defined (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: <dtor@mail.ru> Acked-by: Jiri Kosina <jkosina@suse.cz> Cc: <lenb@kernel.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: <perex@suse.cz> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: <vernux@us.ibm.com> Cc: <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18Add missing newlines to some uses of dev_<level> messagesJoe Perches
Found these while looking at printk uses. Add missing newlines to dev_<level> uses Add missing KERN_<level> prefixes to multiline dev_<level>s Fixed a wierd->weird spelling typo Added a newline to a printk Signed-off-by: Joe Perches <joe@perches.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Cc: Roland Dreier <rolandd@cisco.com> Cc: Tilman Schmidt <tilman@imap.cc> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Smart <James.Smart@Emulex.Com> Cc: Andrew Vasquez <andrew.vasquez@qlogic.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18The next round of scheduled OSS code removalAdrian Bunk
This patch contains the next round of scheduled OSS code removal. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16[ALSA] Fix thinko in cs4231 mce down checkTakashi Iwai
The last patches to replace with schedule_timeout() don't work as expected. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] sun-cs4231: improved waiting after MCE downKrzysztof Helt
This patch sync sparc driver with x86 isa cs4231 driver patches. It fixes wrong waiting for the auto calibration bit and makes further waiting use much finer granularity. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] sun-cs4231: use cs4231-regs.hKrzysztof Helt
This patch replaces cs4231 registers definitions with common include. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] This patch adds support for a wavetable chip onKrzysztof Helt
the BTC 1817DW board. The QS1000 is connected through the digital input to the Opti931 chip. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] This patch removes open_mutex from the ad1848-lib asKrzysztof Helt
open and close operations are called only from pcm layer and mutexed there with pcm->open_mutex. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] fix bootup crash in snd_gus_interrupt()Ingo Molnar
when simulating a storm of fake GUS interrupts (without actually owning this venerable piece of ISA hardware) the driver falls over (crashes) in two ways: 1) spinlocks being initialized too late: INFO: trying to register non-static key. the code is fine but needs lockdep annotation. turning off the locking correctness validator. [<401058ca>] show_trace_log_lvl+0x1a/0x30 [<401064b2>] show_trace+0x12/0x20 [<401064d6>] dump_stack+0x16/0x20 [<4014a72b>] __lock_acquire+0xcfb/0x1030 [<4014aac0>] lock_acquire+0x60/0x80 [<40721a68>] _spin_lock_irqsave+0x38/0x50 [<4058fc12>] snd_gf1_i_look8+0x22/0x60 [<405906fe>] snd_gus_interrupt+0x13e/0x270 [<401548e8>] handle_IRQ_event+0x28/0x60 [<40155cc1>] handle_fasteoi_irq+0x71/0xe0 [<40107238>] do_IRQ+0x48/0xa0 [<401051fe>] common_interrupt+0x2e/0x40 [<40156822>] register_handler_proc+0x92/0xf0 [<401550c2>] setup_irq+0xe2/0x190 [<40155224>] request_irq+0xb4/0xd0 [<4058f524>] snd_gus_create+0x124/0x3c0 [<40aa4087>] snd_gusclassic_probe+0x2a7/0x4b0 [<403f5eff>] isa_bus_probe+0x1f/0x30 [<403f1944>] driver_probe_device+0x84/0x190 [<403f1a58>] __device_attach+0x8/0x10 [<403f0e63>] bus_for_each_drv+0x53/0x80 [<403f1b1b>] device_attach+0x8b/0x90 [<403f0dd8>] bus_attach_device+0x48/0x80 [<403efdbd>] device_add+0x45d/0x5a0 [<403eff12>] device_register+0x12/0x20 [<403f60c3>] isa_register_driver+0xb3/0x140 [<40aa3dd2>] alsa_card_gusclassic_init+0x12/0x20 [<40a665c3>] kernel_init+0x133/0x310 [<401054a7>] kernel_thread_helper+0x7/0x10 ======================= 2) callback functions not being filled in yet: BUG: unable to handle kernel NULL pointer dereference at virtual address 00000000 printing eip: 00000000 *pde = 00000000 Oops: 0000 [#1] SMP DEBUG_PAGEALLOC CPU: 0 EIP: 0060:[<00000000>] Not tainted VLI EFLAGS: 00010002 (2.6.23 #37) EIP is at 0x0 eax: 7fe94000 ebx: 7fe94000 ecx: 00000000 edx: 00000226 esi: 00000000 edi: 00000005 ebp: 7ff87c28 esp: 7ff87bf4 ds: 007b es: 007b fs: 00d8 gs: 0000 ss: 0068 Process swapper (pid: 1, ti=7ff86000 task=7ff84000 task.ti=7ff86000) Stack: 40590683 408424a9 408db87c 00000029 40787406 00000064 00000046 ff000000 000000ff 00000001 7faefaf0 00000000 00000005 7ff87c40 401548e8 00000000 40a52000 7faefaf0 00000005 7ff87c58 40155cc1 40a52030 00000005 00000000 Call Trace: [<401058ca>] show_trace_log_lvl+0x1a/0x30 [<4010598b>] show_stack_log_lvl+0xab/0xd0 [<40105b7c>] show_registers+0x1cc/0x2d0 [<40105d96>] die+0x116/0x240 [<4011d7bb>] do_page_fault+0x18b/0x670 [<40721d22>] error_code+0x72/0x80 [<401548e8>] handle_IRQ_event+0x28/0x60 [<40155cc1>] handle_fasteoi_irq+0x71/0xe0 [<40107238>] do_IRQ+0x48/0xa0 [<401051fe>] common_interrupt+0x2e/0x40 [<401a344e>] proc_create+0x3e/0x120 [<401a3733>] proc_mkdir_mode+0x23/0x50 [<401a376f>] proc_mkdir+0xf/0x20 [<40156864>] register_handler_proc+0xd4/0xf0 [<401550c2>] setup_irq+0xe2/0x190 [<40155224>] request_irq+0xb4/0xd0 [<4058f524>] snd_gus_create+0x124/0x3c0 [<40aa4087>] snd_gusclassic_probe+0x2a7/0x4b0 [<403f5eff>] isa_bus_probe+0x1f/0x30 [<403f1944>] driver_probe_device+0x84/0x190 [<403f1a58>] __device_attach+0x8/0x10 [<403f0e63>] bus_for_each_drv+0x53/0x80 [<403f1b1b>] device_attach+0x8b/0x90 [<403f0dd8>] bus_attach_device+0x48/0x80 [<403efdbd>] device_add+0x45d/0x5a0 [<403eff12>] device_register+0x12/0x20 [<403f60c3>] isa_register_driver+0xb3/0x140 [<40aa3dd2>] alsa_card_gusclassic_init+0x12/0x20 [<40a665c3>] kernel_init+0x133/0x310 [<401054a7>] kernel_thread_helper+0x7/0x10 ======================= Code: Bad EIP value. EIP: [<00000000>] 0x0 SS:ESP 0068:7ff87bf4 Kernel panic - not syncing: Fatal exception in interrupt with these things fixed, i get the expected 'no such hardware' result from the driver initialization: Calling initcall 0x40aa3dc0: alsa_card_gusclassic_init+0x0/0x20() ALSA sound/isa/gus/gusclassic.c:136: [0x220] check 1 failed - 0xff initcall 0x40aa3dc0: alsa_card_gusclassic_init+0x0/0x20() returned 0. initcall 0x40aa3dc0 ran for 133 msecs: alsa_card_gusclassic_init+0x0/0x20() Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] hda-codec - Fix SKU ID function for realtek codecsKailang Yang
Fixed SKU ID function for realtek codecs. It's used by the automatic BIOS configuration mode. Now it supports the correct jack-detection mechanism, too. Signed-off-by: Kailang Yang <kailang@realtek.com.tw> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Support ASUS P701 eeepc [0x1043 0x82a1] supportKailang Yang
2007-10-16[ALSA] hda-codec - Add array terminator for dmic in STAC codecTakashi Iwai
Reported by Jan-Marek Glogowski. The dmic array is passed to snd_hda_parse_pin_def_config() and should be zero-terminated. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] hdsp - Fix zero divisionTakashi Iwai
Fix zero-division bug in the calculation dds offset. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] usb-audio - Fix double commentTakashi Iwai
Remove superfluous comment line (maybe a merge failure). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] hda-codec - Fix STAC922x volume knob controlTakashi Iwai
Reported by zhejiang <zhe.jiang@intel.com> 'I found that STAC_VOLKNOB hardwired the KNOB nid to 0x24. It is okay for stac9205 and stac927x. But the VolumeKnob nid of stac9220-9221 is 0x16.' Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-10-16[ALSA] hda-codec - Fix for Fujitsu Lifebook C1410Takashi Iwai
Fixed ALC262 fujitsu model to support Fujitsu Lifebook C1410 properly. It requires EAPD and has separate int/ext mic inputs (which was missing in the current driver). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] mpu-401: remove MPU401_INFO_UART_ONLY flagClemens Ladisch
Since the last patch made the ENTER_UART command optional, the enter_uart option and its corresponding flag have become superfluous. The uart_enter option remains for backward compatibility but just prints a warning when used. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] mpu-401: do not require an ACK byte for the ENTER_UART commandClemens Ladisch
The original MPU-401 does not send an ACK byte after processing the ENTER_UART command, so we better do not try to wait for it. Many clones get this wrong and do send an ACK, but when interpreting it as MIDI, it is just a harmless Active Sensing message, and it is likely to be read and discarded by the interrupt handler before the MIDI input device is triggered. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] via82xx - Add DXS quirk for Shuttle AK31v2Takashi Iwai
Shuttle AK31v2 works well with dxs_support=5 (ALSA bug#2926). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-codec - Fix input_mux numbers for vaio stac92xxTakashi Iwai
My bad, I forgot to update the num_items field when added a new item to vaio_mux items table, so the last item 'PCM' disappeared. Now it has the right number 3. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] hda-codec - Re-add quirk support for Dell XPS 1330 and Inspiron 1420Tim Gardner
Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] pcxhr - Fix dB level informationTakashi Iwai
Some dB level information is wrong in pcxhr driver according to the datasheet. Fixed now. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
