path: root/sound
2006-11-03[PATCH] ALSA: snd_rtctimer: handle RTC interrupts with a taskletClemens Ladisch
The calls to rtc_control() from inside the interrupt handler can deadlock the RTC code, so move our interrupt handling code to a tasklet. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-11-03[PATCH] ALSA: Fix re-use of va_listTakashi Iwai
The va_list is designed to be used only once. The current code may pass va_list arguments multiple times and may cause Oops. Copy/release the arguments temporarily to avoid this problem. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-11-03[PATCH] ALSA: Repair snd-usb-usx2y for usb 2.6.18Karsten Wiese
ALSA: Repair snd-usb-usx2y for usb 2.6.18 urb->start_frame rolls over beyond MAX_INT now. This is for stable kernel and stable alsa. From: Karsten Wiese <annabellesgarden@yahoo.de> Signed-off-by: Karsten Wiese <annabellesgarden@yahoo.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-11-03[PATCH] ALSA: Fix bug in snd-usb-usx2y's usX2Y_pcms_lock_check()Karsten Wiese
Fix bug in snd-usb-usx2y's usX2Y_pcms_lock_check() substream can be NULL...... in mainline, bug was introduced by: 2006-06-22 [ALSA] Add O_APPEND flag support to PCM From: Karsten Wiese <annabellesgarden@yahoo.de> Signed-off-by: Karsten Wiese <annabellesgarden@yahoo.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-11-03[PATCH] ALSA: Dereference after free in snd_hwdep_release()Florin Malita
snd_card_file_remove() may free hw->card so we can't dereference hw->card->module after that. Coverity ID 1420. This bug actually causes an Oops at usb-disconnection, especially with CONFIG_PREEMPT. From: Florin Malita <fmalita@gmail.com> Signed-off-by: Florin Malita <fmalita@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-11-03[PATCH] sound/pci/au88x0/au88x0.c: ioremap balanced with iounmapAmol Lad
From: Amol Lad <amol@verismonetworks.com> Signed-off-by: Amol Lad <amol@verismonetworks.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-11-03[PATCH] ALSA: powermac - Fix Oops when conflicting with aoa driverTakashi Iwai
Fixed Oops when conflictin with aoa driver due to lack of i2c initialization. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-11-03[PATCH] ALSA: emu10k1: Fix outl() in snd_emu10k1_resume_regs()Arnaud Patard
The emu10k1 driver saves the A_IOCFG and HCFG register on suspend and restores it on resumes. Unfortunately, this doesn't work as the arguments to outl() are reversed. From: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-10-13ALSA: Fix initiailization of user-space controlsTakashi Iwai
ALSA: Fix initiailization of user-space controls Fix an assertion when accessing a user-defined control due to lack of initialization (appears only when CONFIG_SND_DEBUg is enabled). ALSA sound/core/control.c:660: BUG? (info->access == 0) Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-01[PATCH] ALSA: ac97: correct some Mic mixer elementsTakashi Iwai
Revert the mixer element names of some Mic controls to the state of 2.6.17. This should fix the name mismatch in alsactl. Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-01[PATCH] schedule obsolete OSS drivers for removal, 2nd roundAdrian Bunk
This patch schedules obsolete OSS drivers (with ALSA drivers that support the same hardware) for removal. A rationale of the patch is in http://lkml.org/lkml/2006/7/11/186 Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-08V4L/DVB (4371b): Fix V4L1 dependencies at drivers under sound/oss and sound/pciMauro Carvalho Chehab
TVMixer and FM801 Tea5757 are still using V4L1 API. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-08-03[ALSA] Don't reject O_RDWR at opening PCM OSS with read/write-only deviceTakashi Iwai
Accept O_RDWR at opening a PCM OSS device that is read- or write-only, just for the compatibility with the behavior of older versions. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-08-03[ALSA] snd-emu10k1: Implement support for Audigy 2 ZS [SB0353]James Courtier-Dutton
Fixes ALSA bug#1365. Signed-off-by: James Courtier-Dutton <James@superbug.co.uk> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-08-03[ALSA] aoa: platform function gpio: ignore errors from functions that don't ↵Johannes Berg
exist Sometimes we simply want to turn off or on everything, and when recently a warning was added when a certain platform function can't be called, this triggered all the time in those cases. This patch shows the warning only if the error was different from the function not existing. The alternative would be to not even try calling the function when it doesn't exist by first checking which exist and then only calling those that do, but that adds complexity that isn't necessary. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-08-03[ALSA] make snd-powermac load even when it can't bind the deviceJohannes Berg
This patch makes snd-powermac load when it can't bind the device right away. That's the expected behaviour for hotplugging, but fixes an important problem I was seeing with doing a modprobe snd-powermac with a version that refuses loading on machines with layout-id: snd-powermac would create a bunch of uevents and then refuse to load, the uevents causing udev to reload it again, ad eternum. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-08-03[ALSA] aoa: fix toonie codecJohannes Berg
This patch fixes the toonie codec to be actually usable. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-08-03[ALSA] aoa: feature gpio layer: fix IRQ accessJohannes Berg
The IRQ rework caused some hiccups here, in some cases we call get_irq without a device node. This patch makes it catch that case and return NO_IRQ when it happens, along with changing the place where the irq is checked to check for NO_IRQ instead of -1. Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-08-03[ALSA] Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
sound: Conversions from kmalloc+memset to k(c|z)alloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-08-03[ALSA] snd-emu10k1: Fixes ALSA bug#2190James Courtier-Dutton
Fixes ALSA bug#2190 System hangs on unplugging Audigy 2 ZS Notebook CardBus card. Signed-off-by: James Courtier-Dutton <James@superbug.co.uk> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] Fix undefined (missing) references in ISA MIRO sound driverRandy Dunlap
WARNING: /lib/modules/2.6.18-rc1-mm1/kernel/sound/isa/opti9xx/snd-miro.ko needs unknown symbol snd_cs4231_create WARNING: /lib/modules/2.6.18-rc1-mm1/kernel/sound/isa/opti9xx/snd-miro.ko needs unknown symbol snd_cs4231_pcm WARNING: /lib/modules/2.6.18-rc1-mm1/kernel/sound/isa/opti9xx/snd-miro.ko needs unknown symbol snd_cs4231_timer WARNING: /lib/modules/2.6.18-rc1-mm1/kernel/sound/isa/opti9xx/snd-miro.ko needs unknown symbol snd_cs4231_mixer WARNING: /lib/modules/2.6.18-rc1-mm1/kernel/fs/reiser4/reiser4.ko needs unknown symbol generic_file_read Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] make sound/isa/gus/gusextreme.c:devices staticAdrian Bunk
'devices' is not a good name for a global variable. Thankfully, it can become static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] hda-codec - Fix missing array terminators in AD1988 codec supportTakashi Iwai
Fixed the missing array terminators in AD1988 codec support code. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] Fix a deadlock in snd-rtctimerTakashi Iwai
Fix a occasional deadlock occuring with snd-rtctimer driver, added irqsave to the lock in tasklet (ALSA bug#952). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] Fix section mismatch errors in ALSA PCI driversTakashi Iwai
Fixed 'section mismatch' errors in ALSA PCI drivers: - removed invalid __devinitdata from pci id tables - fix/remove __devinit of functions called in suspend/resume Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] remove unused snd_minor.name fieldClemens Ladisch
Drop the snd_minor structure's name field that was just a helper for devfs device deregistration. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] Fix no mpu401 interface can cause hard freezeRandy Dunlap
This patch fixes the remaining instances in our tree where a non- existent mpu401 interface can cause a hard freeze when i/o is issued. This commit closes Malone #34831. Bug: https://launchpad.net/distros/ubuntu/+source/linux-source-2.6.15/+bug/34831 patch location: http://www.kernel.org/git/?p=linux/kernel/git/bcollins/ubuntu-dapper.git;a=commitdiff;h=b422309cdd980cfefe99379796c04e961d3c1544 From: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] wavefront: fix __init/__devinit confusionClemens Ladisch
The wavefront driver used __init in some places referenced by __devinit functions. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] Fix workaround for AD1988A rev2 codecTakashi Iwai
Fix the workaround for AD1988A rev2 codec not to apply to AD1988B codec chips. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] trivial: Code clean up of i2c/cs8427.cTakashi Iwai
- Fix spaces, wrap lines in 80 columns. - Move EXPORT_SYMBOL() adjacent to each function. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] sound/i2c/cs8427.c: don't export a static functionAdrian Bunk
Static functions shouldn't be exported. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] intel8x0 - Add ac97 quirk for Tyan Thunder K8WE boardTakashi Iwai
Added the default ac97 quirk (hp_only) for Tyan Thunder K8WE board. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] Reduce the string length of Terratec Aureon 7.1 UniverseTakashi Iwai
Fix the driver string name for Terratec Aureon 7.1 Universe to fit in 15 letters to avoid the overflow. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] sound/pci/Kconfig - fix broken indenting for SND_FM801_TEA575XJaroslav Kysela
2006-07-12[ALSA] fix the SND_FM801_TEA575X dependenciesAdrian Bunk
CONFIG_SND_FM801=y, CONFIG_SND_FM801_TEA575X=m resulted in the following compile error: <-- snip --> ... LD vmlinux sound/built-in.o: In function 'snd_fm801_free': fm801.c:(.text+0x3c15b): undefined reference to 'snd_tea575x_exit' sound/built-in.o: In function 'snd_card_fm801_probe': fm801.c:(.text+0x3cfde): undefined reference to 'snd_tea575x_init' make: *** [vmlinux] Error 1 <-- snip --> This patch fixes kernel Bugzilla #6458. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] Memory leak in sound/pcmcia/pdaudiocf/pdaudiocf.cEric Sesterhenn
if one of the first three CS_CHECKS fails, we goto cs_failed: In this case parse we donr kfree() parse. Since the the last three CS_CHECKS might also fail, i moved the kfree() below all the CS_CHECKs and added one in the error path. This fixes coverity bug id #1099 Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-10x86 MacMini: make built-in speaker sound actually workLinus Torvalds
The MacMini board table seems to largely look like any bog-standard Intel 945 board. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa: tas: add missing bass/treble controlsJohannes Berg
This patch adds the bass/treble controls to snd-aoa that snd-powermac always had for tas3004 based machines. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa: layout fabric: add missing module aliasesJohannes Berg
The layout fabric gained support for all IDs when I extracted those from the OSX description file. But apparently I had forgotten to add them all as module aliases so the module will also load. This patch adds them. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa: tas: surface DRC control againJohannes Berg
This patch makes the DRC control visible again for TAS chips. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa: tas: fix initialisation/resetBenjamin Herrenschmidt
This patch fixes the initialisation and reset of the tas codec. The tas will often reset if the i2s clocks go away so it needs to be completely re-initialised when clocks come back. Also, this patch adds some code for DRC that will be exploited later to add a DRC control again, fixing a regression over snd-powermac. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa: tas: change PCM1 name to PCMJohannes Berg
This patch changes the PCM1 control name to PCM to make it play nice with the softvol plugin (which will then go away if it sees a proper PCM slider) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa fabric layout: clean up messagesBenjamin Herrenschmidt
This patch cleans up the printk's in the layout fabric and also makes it display which type of GPIO access it is going to use. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa: pmf gpio: report if function calling failsBenjamin Herrenschmidt
This patch makes the pmf GPIO layer in aoa report if calling a platform function failed. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa: i2sbus: revamp control layerBenjamin Herrenschmidt
This patch revamps the i2sbus control layer by using the macio/keylargo functions instead of directly mapping. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa: fix when all is built into the kernelBenjamin Herrenschmidt
This patch fixes initialisation issues when all of aoa is built into the kernel by re-ordering the link order in the Makefile and making the soundbus use subsys_initcall so it is initialised earlier. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa: i2sbus: fix for PowerMac7,2 and 7,3Benjamin Herrenschmidt
This patch cleans up the resource handling in i2sbus and adds workarounds for the broken device trees on the PowerMac7,2 and 7,3. Some of this code will later move again when macio_asic is going to export all the sub-nodes too. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa: i2sbus: move module parameter declaration upBenjamin Herrenschmidt
This patch moves the i2sbus 'force' module parameter declaration to the top of the file. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] Fix snd-aoa irq conversionAndreas Schwab
Use proper irq mapping interface for snd-aoa-i2sbus. Signed-off-by: Andreas Schwab <schwab@suse.de> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-04[PATCH] fix AB-BA deadlock inversion at cs46xx_dsp_remove_scbArjan van de Ven
There is a code sequence where the locking is substream->self_group.lock -> ins->scbs[index].lock substream->self_group.lock is interrupt safe, and taken from irq context as well (trace is snipped for brevity) so what can happen is cpu 0 cpu 1 user context user context take ins->scbs[index].lock without disabling interrupts get substream->self_group.lock (irqsafe) try to get ins->scbs[index].lock (spins) interrupt happens try to get substream->self_group.lock (spins) which is an obvious AB-BA deadlock fix is to just take the lock with _irqsafe Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Jaroslav Kysela <perex@suse.cz> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
