path: root/sound
2012-08-01Merge tag 'sound-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "A collection of small fixes that have been found recently. Most of the commits are regression fixes in HD-audio and some other random drivers." * tag 'sound-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: snd-usb: fix clock source validity index ALSA: hda - Fix mute-LED GPIO initialization for IDT codecs ALSA: hda - Add descriptions for missing IDT 92HD83x models ALSA: hda - Fix polarity of mute LED on HP Mini 210 ALSA: es1688 - freeup resources on init failure ALSA: hda - Workaround for silent output on VAIO Z with ALC889 ALSA: hda - Fix WARNING from HDMI/DP parser ALSA: hda - Detach from converter at closing in patch_hdmi.c ALSA: hda - Fix mute-LED GPIO setup for HP Mini 210 ALSA: mpu401: Fix missing initialization of irq field ALSA: hda - Fix invalid D3 of headphone DAC on VT202x codecs
2012-08-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull second vfs pile from Al Viro: "The stuff in there: fsfreeze deadlock fixes by Jan (essentially, the deadlock reproduced by xfstests 068), symlink and hardlink restriction patches, plus assorted cleanups and fixes. Note that another fsfreeze deadlock (emergency thaw one) is *not* dealt with - the series by Fernando conflicts a lot with Jan's, breaks userland ABI (FIFREEZE semantics gets changed) and trades the deadlock for massive vfsmount leak; this is going to be handled next cycle. There probably will be another pull request, but that stuff won't be in it." Fix up trivial conflicts due to unrelated changes next to each other in drivers/{staging/gdm72xx/usb_boot.c, usb/gadget/storage_common.c} * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (54 commits) delousing target_core_file a bit Documentation: Correct s_umount state for freeze_fs/unfreeze_fs fs: Remove old freezing mechanism ext2: Implement freezing btrfs: Convert to new freezing mechanism nilfs2: Convert to new freezing mechanism ntfs: Convert to new freezing mechanism fuse: Convert to new freezing mechanism gfs2: Convert to new freezing mechanism ocfs2: Convert to new freezing mechanism xfs: Convert to new freezing code ext4: Convert to new freezing mechanism fs: Protect write paths by sb_start_write - sb_end_write fs: Skip atime update on frozen filesystem fs: Add freezing handling to mnt_want_write() / mnt_drop_write() fs: Improve filesystem freezing handling switch the protection of percpu_counter list to spinlock nfsd: Push mnt_want_write() outside of i_mutex btrfs: Push mnt_want_write() outside of i_mutex fat: Push mnt_want_write() outside of i_mutex ...
2012-08-01ALSA: snd-usb: fix clock source validity indexDaniel Mack
uac_clock_source_is_valid() uses the control selector value to access the bmControls bitmap of the clock source unit. This is wrong, as control selector values start from 1, while the bitmap uses all available bits. In other words, "Clock Validity Control" is stored in D3..2, not D5..4 of the clock selector unit's bmControls. Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-by: Andreas Koch <andreas@akdesigninc.com> Cc: stable@kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-31Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull second set of media updates from Mauro Carvalho Chehab: - radio API: add support to work with radio frequency bands - new AM/FM radio drivers: radio-shark, radio-shark2 - new Remote Controller USB driver: iguanair - conversion of several drivers to the v4l2 core control framework - new board additions at existing drivers - the remaining (and vast majority of the patches) are due to drivers/DocBook fixes/cleanups. * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (154 commits) [media] radio-tea5777: use library for 64bits div [media] tlg2300: Declare MODULE_FIRMWARE usage [media] lgs8gxx: Declare MODULE_FIRMWARE usage [media] xc5000: Add MODULE_FIRMWARE statements [media] s2255drv: Add MODULE_FIRMWARE statement [media] dib8000: move dereference after check for NULL [media] Documentation: Update cardlists [media] bttv: add support for Aposonic W-DVR [media] cx25821: Remove bad strcpy to read-only char* [media] pms.c: remove duplicated include [media] smiapp-core.c: remove duplicated include [media] via-camera: pass correct format settings to sensor [media] rtl2832.c: minor cleanup [media] Add support for the IguanaWorks USB IR Transceiver [media] Minor cleanups for MCE USB [media] drivers/media/dvb/siano/smscoreapi.c: use list_for_each_entry [media] Use a named union in struct v4l2_ioctl_info [media] mceusb: Add Twisted Melon USB IDs [media] staging/media/solo6x10: use module_pci_driver macro [media] staging/media/dt3155v4l: use module_pci_driver macro ... Conflicts: Documentation/feature-removal-schedule.txt
2012-07-31ALSA: hda - Fix mute-LED GPIO initialization for IDT codecsTakashi Iwai
The IDT codecs initializes the GPIO setup for mute LEDs via snd_hda_sync_vmaster_hook(). This works in most cases except for the very first call, which is called before PCM and control creations. Thus before Master switch is set manually via alsactl, the mute LED may show the wrong state, depending on the polarity. Now it's fixed by calling the LED-status update function manually when no vmaster is set yet. Cc: <stable@vger.kernel.org> [v3.4+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-31ALSA: hda - Fix polarity of mute LED on HP Mini 210Takashi Iwai
The commit a3e199732b made the LED working again on HP Mini 210 but with a wrong polarity. This patch fixes the polarity for this machine, and also introduce a new model string "hp-inv-led". Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=772923 Cc: <stable@vger.kernel.org> [v3.3+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-30Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "This is the first part of the media patches for v3.6. This patch series contain: - new DVB frontend: rtl2832 - new video drivers: adv7393 - some unused files got removed - a selection API cleanup between V4L2 and V4L2 subdev API's - a major redesign at v4l-ioctl2, in order to clean it up - several driver fixes and improvements." * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (174 commits) v4l: Export v4l2-common.h in include/linux/Kbuild media: Revert "[media] Terratec Cinergy S2 USB HD Rev.2" [media] media: Use pr_info not homegrown pr_reg macro [media] Terratec Cinergy S2 USB HD Rev.2 [media] v4l: Correct conflicting V4L2 subdev selection API documentation [media] Feature removal: V4L2 selections API target and flag definitions [media] v4l: Unify selection flags documentation [media] v4l: Unify selection flags [media] v4l: Common documentation for selection targets [media] v4l: Unify selection targets across V4L2 and V4L2 subdev interfaces [media] v4l: Remove "_ACTUAL" from subdev selection API target definition names [media] V4L: Remove "_ACTIVE" from the selection target name definitions [media] media: dvb-usb: print mac address via native %pM [media] s5p-tv: Use module_i2c_driver in sii9234_drv.c file [media] media: gpio-ir-recv: add allowed_protos for platform data [media] s5p-jpeg: Use module_platform_driver in jpeg-core.c file [media] saa7134: fix spelling of detach in label [media] cx88-blackbird: replace ioctl by unlocked_ioctl [media] cx88: don't use current_norm [media] cx88: fix a number of v4l2-compliance violations ...
2012-07-30Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge Andrew's first set of patches: "Non-MM patches: - lots of misc bits - tree-wide have_clk() cleanups - quite a lot of printk tweaks. I draw your attention to "printk: convert the format for KERN_<LEVEL> to a 2 byte pattern" which looks a bit scary. But afaict it's solid. - backlight updates - lib/ feature work (notably the addition and use of memweight()) - checkpatch updates - rtc updates - nilfs updates - fatfs updates (partial, still waiting for acks) - kdump, proc, fork, IPC, sysctl, taskstats, pps, etc - new fault-injection feature work" * Merge emailed patches from Andrew Morton <akpm@linux-foundation.org>: (128 commits) drivers/misc/lkdtm.c: fix missing allocation failure check lib/scatterlist: do not re-write gfp_flags in __sg_alloc_table() fault-injection: add tool to run command with failslab or fail_page_alloc fault-injection: add selftests for cpu and memory hotplug powerpc: pSeries reconfig notifier error injection module memory: memory notifier error injection module PM: PM notifier error injection module cpu: rewrite cpu-notifier-error-inject module fault-injection: notifier error injection c/r: fcntl: add F_GETOWNER_UIDS option resource: make sure requested range is included in the root range include/linux/aio.h: cpp->C conversions fs: cachefiles: add support for large files in filesystem caching pps: return PTR_ERR on error in device_create taskstats: check nla_reserve() return sysctl: suppress kmemleak messages ipc: use Kconfig options for __ARCH_WANT_[COMPAT_]IPC_PARSE_VERSION ipc: compat: use signed size_t types for msgsnd and msgrcv ipc: allow compat IPC version field parsing if !ARCH_WANT_OLD_COMPAT_IPC ipc: add COMPAT_SHMLBA support ...
2012-07-30sound: use printk_get_level and printk_skip_levelJoe Perches
Make the output logging routine independent of the KERN_<LEVEL> style. Signed-off-by: Joe Perches <joe@perches.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30[media] snd_tea575x: Add a cannot_mute flagHans de Goede
Some devices which use the tea575x tuner chip don't allow direct control over the IO pins, and thus cannot mute the audio output. Signed-off-by: Hans de Goede <hdegoede@redhat.com> CC: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-07-30[media] snd_tea575x: Add write_/read_val operationsHans de Goede
Some devices which use the tea575x tuner chip don't allow bit banging the lines, instead they offer a method to directly set / get the contents of the 25 bit shift-register in the chip. Notably the Griffin radioSHARK USB radio receiver does this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> CC: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-07-30Merge tag 'mfd-3.6-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFD bits from Samuel Ortiz: "We have support for a few new drivers: - Samsung s2mps11 - Wolfson Microelectronics wm5102 and wm5110 - Marvell 88PM800 and 88PM805 - TI twl6041 We also have our regular driver improvements: - Device tree and IRQ domain support for STE AB8500 - Regmap and devm_* API conversion for TI tps6586x - Device tree support for Samsung max77686 - devm_* API conversion for STE AB3100 Besides that, quite a lot of fixing and cleanup for mc13xxx, tps65910, tps65090, da9052 and twl-core." Fix up mostly trivial conflicts, with the exception of drivers/usb/host/ehci-omap.c in particular, which had some re-organization of the reset sequence (commit 1a49e2ac9651: "EHCI: centralize controller initialization") that clashed with commit 2761a6394516 ("mfd: USB: Fix the omap-usb EHCI ULPI PHY reset fix issues"). In particular, commit 2761a6394516 moved the usb_add_hcd() to the *middle* of the reset sequence, which clashes fairly badly with the reset sequence re-organization (although it could have been done inside the new omap_ehci_init() function). I left that part of commit 2761a6394516 just undone. * tag 'mfd-3.6-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (110 commits) mfd: Ensure AB8500 platform data is passed through db8500-prcmu to MFD Core mfd: Arizone core should select MFD_CORE mfd: Fix arizona-irq.c build by selecting REGMAP_IRQ mfd: Add debug trace on entering and leaving arizone runtime suspend mfd: Correct tps65090 cell names mfd: Remove gpio support from tps6586x core driver ARM: tegra: defconfig: Enable tps6586x gpio gpio: tps6586x: Add gpio support through platform driver mfd: Cache tps6586x register through regmap mfd: Use regmap for tps6586x register access. mfd: Use devm managed resources for tps6586x input: Add onkey support for 88PM80X PMIC mfd: Add support for twl6041 mfd: Fix twl6040 revision information mfd: Matches should be NULL when populate anatop child devices input: ab8500-ponkey: Create AB8500 domain IRQ mapping mfd: Add missing out of memory check for pcf50633 Documentation: Describe the AB8500 Device Tree bindings mfd: Add tps65910 32-kHz-crystal-input init mfd: Drop modifying mc13xxx driver's id_table in probe ...
2012-07-30ALSA: es1688 - freeup resources on init failureFengguang Wu
This will fix the following oops: [ 6.169981] genirq: Flags mismatch irq 5. 00000000 (ES1688) vs. 00000000 (ES1688) [ 6.170851] Pid: 1, comm: swapper Not tainted 3.5.0-00004-gceee0e9 #14 [ 6.170851] Call Trace: [ 6.170851] [<c1062237>] ? __setup_irq+0x3c7/0x420 [ 6.170851] [<c1062486>] ? request_threaded_irq+0x76/0x140 [ 6.170851] [<c1290220>] ? snd_es1688_ioctl+0x10/0x10 [ 6.170851] [<c10624c2>] ? request_threaded_irq+0xb2/0x140 [ 6.170851] [<c1291196>] ? snd_es1688_create+0x96/0x330 [ 6.170851] [<c138365d>] ? snd_gusextreme_probe+0x18d/0x5a2 [ 6.170851] [<c11c9d80>] ? __driver_attach+0x80/0x80 [ 6.170851] [<c10db22f>] ? sysfs_create_link+0xf/0x20 [ 6.170851] [<c11c9d80>] ? __driver_attach+0x80/0x80 [ 6.170851] [<c11d1502>] ? isa_bus_probe+0x12/0x20 [ 6.170851] [<c11c9b95>] ? driver_probe_device+0x55/0x1c0 [ 6.170851] [<c13ae04f>] ? _raw_spin_unlock+0xf/0x30 [ 6.170851] [<c13705ea>] ? klist_next+0x6a/0xe0 [ 6.170851] [<c11d15c1>] ? isa_bus_match+0x21/0x40 [ 6.170851] [<c11c8a24>] ? bus_for_each_drv+0x34/0x70 [ 6.170851] [<c11c9e4b>] ? device_attach+0x7b/0x90 [ 6.170851] [<c11c9d80>] ? __driver_attach+0x80/0x80 [ 6.170851] [<c11c8bff>] ? bus_probe_device+0x5f/0x80 [ 6.170851] [<c11c7493>] ? device_add+0x573/0x620 [ 6.170851] [<c1042820>] ? complete_all+0x40/0x60 [ 6.170851] [<c13ae08a>] ? _raw_spin_unlock_irqrestore+0x1a/0x30 [ 6.170851] [<c11d16c6>] ? isa_register_driver+0xb6/0x150 [ 6.170851] [<c15c9002>] ? alsa_card_gusmax_init+0xf/0xf [ 6.170851] [<c15a99bc>] ? do_one_initcall+0x7f/0x12b [ 6.170851] [<c15a9b7a>] ? kernel_init+0x112/0x1a9 [ 6.170851] [<c15a9423>] ? do_early_param+0x77/0x77 [ 6.170851] [<c15a9a68>] ? do_one_initcall+0x12b/0x12b [ 6.170851] [<c13aefbe>] ? kernel_thread_helper+0x6/0xd [ 6.190170] es1688: can't grab IRQ 5 [ 6.190613] genirq: Flags mismatch irq 5. 00000000 (ES1688) vs. 00000000 (ES1688) [ 6.191566] Pid: 1, comm: swapper Not tainted 3.5.0-00004-gceee0e9 #14 [ 6.192394] Call Trace: [ 6.192685] [<c1062237>] ? __setup_irq+0x3c7/0x420 [ 6.193342] [<c1062486>] ? request_threaded_irq+0x76/0x140 [ 6.194081] [<c1290220>] ? snd_es1688_ioctl+0x10/0x10 [ 6.194607] [<c10624c2>] ? request_threaded_irq+0xb2/0x140 [ 6.194607] [<c1291196>] ? snd_es1688_create+0x96/0x330 [ 6.194607] [<c138365d>] ? snd_gusextreme_probe+0x18d/0x5a2 [ 6.194607] [<c11c9d80>] ? __driver_attach+0x80/0x80 [ 6.194607] [<c10db22f>] ? sysfs_create_link+0xf/0x20 [ 6.194607] [<c11c9d80>] ? __driver_attach+0x80/0x80 [ 6.194607] [<c11d1502>] ? isa_bus_probe+0x12/0x20 [ 6.194607] [<c11c9b95>] ? driver_probe_device+0x55/0x1c0 [ 6.194607] [<c13ae04f>] ? _raw_spin_unlock+0xf/0x30 [ 6.194607] [<c13705ea>] ? klist_next+0x6a/0xe0 [ 6.194607] [<c11d15c1>] ? isa_bus_match+0x21/0x40 [ 6.194607] [<c11c8a24>] ? bus_for_each_drv+0x34/0x70 [ 6.194607] [<c11c9e4b>] ? device_attach+0x7b/0x90 [ 6.194607] [<c11c9d80>] ? __driver_attach+0x80/0x80 [ 6.194607] [<c11c8bff>] ? bus_probe_device+0x5f/0x80 [ 6.194607] [<c11c7493>] ? device_add+0x573/0x620 [ 6.194607] [<c1042820>] ? complete_all+0x40/0x60 [ 6.194607] [<c13ae08a>] ? _raw_spin_unlock_irqrestore+0x1a/0x30 [ 6.194607] [<c11d16c6>] ? isa_register_driver+0xb6/0x150 [ 6.194607] [<c15c9002>] ? alsa_card_gusmax_init+0xf/0xf [ 6.194607] [<c15a99bc>] ? do_one_initcall+0x7f/0x12b [ 6.194607] [<c15a9b7a>] ? kernel_init+0x112/0x1a9 [ 6.194607] [<c15a9423>] ? do_early_param+0x77/0x77 [ 6.194607] [<c15a9a68>] ? do_one_initcall+0x12b/0x12b [ 6.194607] [<c13aefbe>] ? kernel_thread_helper+0x6/0xd [ 6.210779] es1688: can't grab IRQ 5 [ 6.211305] gusextreme: probe of gusextreme.0 failed with error -16 Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-29sound_firmware: don't pass crap to filp_close()Al Viro
2012-07-29ALSA: hda - Workaround for silent output on VAIO Z with ALC889Takashi Iwai
On recent kernels, Realtek codec parser tries to optimize the routing aggressively and take the headphone output as primary at first. This caused a regression on VAIO Z with ALC889, the silent output from the speaker. The problem seems that the speaker pin must be connected to the first DAC (0x02) on this machine by some reason although the codec itself advertises the flexible routing with any DACs. This patch adds a fix-up for choosing the speaker pin as the primary so that the right DAC is assigned on this device. Reported-and-tested-by: Adam Williamson <awilliam@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-27ALSA: hda - Fix WARNING from HDMI/DP parserTakashi Iwai
The recent fix to converter detaching timing in patch_hdmi.c leads to a kernel WARNING due to a sanity check when the debug option is set. Add a workaround by setting a dummy hinfo->nid. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-26Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "A mixed bag of fixes, some for merge window fallout (tegra, MXS), and a short series of fixes for marvell platforms that didn't make it in before 3.5." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: mxs: fix compile error caused by prom_update_property change ARM: dt: tegra trimslice: enable USB2 port ARM: dt: tegra trimslice: add vbus-gpio property ARM: vt8500: Add maintainer for VT8500 architecture ARM: Kirkwood: Replace mrvl with marvell ARM: Orion: fix driver probe error handling with respect to clk ARM: Dove: Fixup ge00 initialisation ARM: Kirkwood: Fix PHY disable clk problems ARM: Kirkwood: Ensure runit clock always ticks. ARM: versatile: Don't use platform clock for Integrator & VE ARM: tegra: harmony: add regulator supply name and its input supply
2012-07-26ALSA: hda - Detach from converter at closing in patch_hdmi.cTakashi Iwai
The generic HDMI code detaches the converter from the stream when unused, but it must be done rather in the close callback instead of the cleanup callback. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-26ALSA: hda - Fix mute-LED GPIO setup for HP Mini 210Takashi Iwai
BIOS on HP Mini 210 doesn't provide the proper "HP_Mute_LED" DMI string, thus the driver doesn't initialize the GPIO, too. In the earlier kernel, the driver falls back to GPIO1, but since 3.3 we've stopped this due to other wrongly advertised machines. For fixing this particular case, add a new model type to specify the default polarity explicitly so that the fallback to GPIO1 is handled. Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=772923 Cc: <stable@vger.kernel.org> [v3.3+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-25Merge branch 'v3.5-rc7-fixes' of git://github.com/lunn/linux into fixesArnd Bergmann
From Andrew Lunn <andrew@lunn.ch>: * 'v3.5-rc7-fixes' of git://github.com/lunn/linux: ARM: Kirkwood: Replace mrvl with marvell ARM: Orion: fix driver probe error handling with respect to clk ARM: Dove: Fixup ge00 initialisation ARM: Kirkwood: Fix PHY disable clk problems ARM: Kirkwood: Ensure runit clock always ticks. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-07-25ARM: Orion: fix driver probe error handling with respect to clkSimon Baatz
The clk patches added code to get and enable clocks in the respective driver probe functions. If the probe function failed for some reason after enabling the clock, the clock was not disabled again in many cases. Signed-off-by: Simon Baatz <gmbnomis@gmail.com> Signed-off-by: Andrew Lumm <andrew@lunn.ch>
2012-07-25ALSA: mpu401: Fix missing initialization of irq fieldTakashi Iwai
The irq field of struct snd_mpu401 is supposed to be initialized to -1. Since it's set to zero as of now, a probing error before the irq installation results in a kernel warning "Trying to free already-free IRQ 0". Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=44821 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-25ALSA: hda - Fix invalid D3 of headphone DAC on VT202x codecsTakashi Iwai
We've got a bug report about the silent output from the headphone on a mobo with VT2021, and spotted out that this was because of the wrong D3 state on the DAC for the headphone output. The bug is triggered by the incomplete check for this DAC in set_widgets_power_state_vt1718S(). It checks only the connectivity of the primary output (0x27) but doesn't consider the path from the headphone pin (0x28). Now this patch fixes the problem by checking both pins for DAC 0x0b. Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-24Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull first round of SCSI updates from James Bottomley: "The most important feature of this patch set is the new async infrastructure that makes sure async_synchronize_full() synchronizes all domains and allows us to remove all the hacks (like having scsi_complete_async_scans() in the device base code) and means that the async infrastructure will "just work" in future. The rest is assorted driver updates (aacraid, bnx2fc, virto-scsi, megaraid, bfa, lpfc, qla2xxx, qla4xxx) plus a lot of infrastructure work in sas and FC. Signed-off-by: James Bottomley <JBottomley@Parallels.com>" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (97 commits) [SCSI] Revert "[SCSI] fix async probe regression" [SCSI] cleanup usages of scsi_complete_async_scans [SCSI] queue async scan work to an async_schedule domain [SCSI] async: make async_synchronize_full() flush all work regardless of domain [SCSI] async: introduce 'async_domain' type [SCSI] bfa: Fix to set correct return error codes and misc cleanup. [SCSI] aacraid: Series 7 Async. (performance) mode support [SCSI] aha152x: Allow use on 64bit systems [SCSI] virtio-scsi: Add vdrv->scan for post VIRTIO_CONFIG_S_DRIVER_OK LUN scanning [SCSI] bfa: squelch lockdep complaint with a spin_lock_init [SCSI] qla2xxx: remove unnecessary reads of PCI_CAP_ID_EXP [SCSI] qla4xxx: remove unnecessary read of PCI_CAP_ID_EXP [SCSI] ufs: fix incorrect return value about SUCCESS and FAILED [SCSI] ufs: reverse the ufshcd_is_device_present logic [SCSI] ufs: use module_pci_driver [SCSI] usb-storage: update usb devices for write cache quirk in quirk list. [SCSI] usb-storage: add support for write cache quirk [SCSI] set to WCE if usb cache quirk is present. [SCSI] virtio-scsi: hotplug support for virtio-scsi [SCSI] virtio-scsi: split scatterlist per target ...
2012-07-24Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine update from Vinod Koul: "This time we have a new dmaengine driver from the tegra folks. Also we have Guennadi's cleanup of sh drivers which incudes a library for sh drivers. And the usual odd fixes in bunch of drivers and some nice cleanup of dw_dmac from Andy." Fix up conflicts in drivers/mmc/host/sh_mmcif.c * 'next' of git://git.infradead.org/users/vkoul/slave-dma: (46 commits) dmaengine: Cleanup logging messages mmc: sh_mmcif: switch to the new DMA channel allocation and configuration dma: sh: provide a migration path for slave drivers to stop using .private dma: sh: use an integer slave ID to improve API compatibility dmaengine: shdma: prepare to stop using struct dma_chan::private sh: remove unused DMA device pointer from SIU platform data ASoC: siu: don't use DMA device for channel filtering dmaengine: shdma: (cosmetic) simplify a static function dmaengine: at_hdmac: add a few const qualifiers dw_dmac: use 'u32' for LLI structure members, not dma_addr_t dw_dmac: mark dwc_dump_lli inline dma: mxs-dma: Export missing symbols from mxs-dma.c dma: shdma: convert to the shdma base library ASoC: fsi: prepare for conversion to the shdma base library usb: renesas_usbhs: prepare for conversion to the shdma base library ASoC: siu: prepare for conversion to the shdma base library serial: sh-sci: prepare for conversion to the shdma base library mmc: sh_mobile_sdhi: prepare for conversion to the shdma base library mmc: sh_mmcif: remove unneeded struct sh_mmcif_dma, prepare to shdma conversion dma: shdma: prepare for conversion to the shdma base library ...
2012-07-25mfd: Fix twl6040 revision informationPeter Ujfalusi
twl6040 ES1.1 and ES1.2 have the same revid (0x01). ES1.3 of twl6040 REVID is 0x02. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-24Merge tag 'sound-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound update from Takashi Iwai: "This is a fairly quiet release in all sound area. Only a little bit of changes in the core side while most of changes are seen in the drivers. HD-audio: - A few new codec additions for Nvidia, Realtek and VIA - Intel Haswell audio support - Support for "phantom" jacks for consistent jack reporting - Major clean-ups in HDMI/DP driver codes - A workaround for inverted digital-mic pins with Realtek codecs - Removal of beep_mode=2 option ASoC: - Added the ability to add and remove DAPM paths dynamically, mostly for reparenting on clock changes - New machine drivers for Marvell Brownstone, ST-Ericsson Ux500 reference platform and ttc-dkp - New CPU drivers for Blackfin BF6xx SPORTs in I2S mode, Marvell MMP, Synopsis Designware I2S controllers, and SPEAr DMA and S/PDIF - New CODEC drivers for Dialog DA732x, ST STA529, ST-Ericsson AB8500, TI Isabelle and Wolfson Microelectronics WM5102 and WM5110 - DAPM fixes for the recent locking changes - Fix for _PRE and _POST widgets (which have been broken for a few releases now) - A couple of minor driver updates Misc - Conversion to new dev_pm_ops in platform and PCI drivers - LTC support and some fixes in PCXHR driver - A few fixes and PM support for ISA OPti9xx and WSS cards - Some TLV code cleanup - Move driver-specific headers from include/sound to local dirs" * tag 'sound-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (212 commits) ASoC: dapm: Fix _PRE and _POST events for DAPM performance improvements ALSA: hda - add dock support for Thinkpad X230 Tablet ALSA: hda - Turn on PIN_OUT from hdmi playback prepare. ASoC imx-audmux: add MX31_AUDMUX_PORT7_SSI_PINS_7 define ASoC: littlemill: Add userspace control of the WM1250 I/O ASoC: wm8994: Update micdet for irqdomain conversion ALSA: hda - make sure alc268 does not OOPS on codec parse ALSA: hda - Add support for Realtek ALC282 ALSA: hda - Fix index number conflicts of phantom jacks ALSA: opti9xx: Fix section mismatch by PM support ALSA: snd-opti9xx: Implement suspend/resume ALSA: hda - Add new GPU codec ID to snd-hda ALSA: hda - Fix driver type of Haswell controller to AZX_DRIVER_SCH ALSA: hda - add Haswell HDMI codec id ALSA: hda - Add DeviceID for Haswell HDA ALSA: wss_lib: Fix resume on Yamaha OPL3-SAx ALSA: wss_lib: fix suspend/resume ALSA: es1938: replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE ALSA: tlv: add DECLARE_TLV_DB_RANGE() ALSA: tlv: add DECLARE_TLV_CONTAINER() ...
2012-07-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Trivial updates all over the place as usual." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (29 commits) Fix typo in include/linux/clk.h . pci: hotplug: Fix typo in pci iommu: Fix typo in iommu video: Fix typo in drivers/video Documentation: Add newline at end-of-file to files lacking one arm,unicore32: Remove obsolete "select MISC_DEVICES" module.c: spelling s/postition/position/g cpufreq: Fix typo in cpufreq driver trivial: typo in comment in mksysmap mach-omap2: Fix typo in debug message and comment scsi: aha152x: Fix sparse warning and make printing pointer address more portable. Change email address for Steve Glendinning Btrfs: fix typo in convert_extent_bit via: Remove bogus if check netprio_cgroup.c: fix comment typo backlight: fix memory leak on obscure error path Documentation: asus-laptop.txt references an obsolete Kconfig item Documentation: ManagementStyle: fixed typo mm/vmscan: cleanup comment error in balance_pgdat mm: cleanup on the comments of zone_reclaim_stat ...
2012-07-23Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Benjamin Herrenschmidt: "Notable highlights: - iommu improvements from Anton removing the per-iommu global lock in favor of dividing the DMA space into pools, each with its own lock, and hashed on the CPU number. Along with making the locking more fine grained, this gives significant improvements in multiqueue networking scalability. - Still from Anton, we know provide a vdso based variant of getcpu which makes sched_getcpu with the appropriate glibc patch something like 18 times faster. - More anton goodness (he's been busy !) in other areas such as a faster __clear_user and copy_page on P7, various perf fixes to improve sampling quality, etc... - One more step toward removing legacy i2c interfaces by using new device-tree based probing of platform devices for the AOA audio drivers - A nice series of patches from Michael Neuling that helps avoiding confusion between register numbers and litterals in assembly code, trying to enforce the use of "%rN" register names in gas rather than plain numbers. - A pile of FSL updates - The usual bunch of small fixes, cleanups etc... You may spot a change to drivers/char/mem. The patch got no comment or ack from outside, it's a trivial patch to allow the architecture to skip creating /dev/port, which we use to disable it on ppc64 that don't have a legacy brige. On those, IO ports 0...64K are not mapped in kernel space at all, so accesses to /dev/port cause oopses (and yes, distros -still- ship userspace that bangs hard coded ports such as kbdrate)." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (106 commits) powerpc/mpic: Create a revmap with enough entries for IPIs and timers Remove stale .rej file powerpc/iommu: Fix iommu pool initialization powerpc/eeh: Check handle_eeh_events() return value powerpc/85xx: Add phy nodes in SGMII mode for MPC8536/44/72DS & P2020DS powerpc/e500: add paravirt QEMU platform powerpc/mpc85xx_ds: convert to unified PCI init powerpc/fsl-pci: get PCI init out of board files powerpc/85xx: Update corenet64_smp_defconfig powerpc/85xx: Update corenet32_smp_defconfig powerpc/85xx: Rename P1021RDB-PC device trees to be consistent powerpc/watchdog: move booke watchdog param related code to setup-common.c sound/aoa: Adapt to new i2c probing scheme i2c/powermac: Improve detection of devices from device-tree powerpc: Disable /dev/port interface on systems without an ISA bridge of: Improve prom_update_property() function powerpc: Add "memory" attribute for mfmsr() powerpc/ftrace: Fix assembly trampoline register usage powerpc/hw_breakpoints: Fix incorrect pointer access powerpc: Put the gpr save/restore functions in their own section ...
2012-07-23Merge tag 'clk' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc clk changes from Arnd Bergmann: "Clock support is moving to the clk subsystem. These tegra, omap and imx changes are for code that is still platform specific and not (yet) part of that subsystem." Fix up conflicts in arch/arm/mach-{imx/clk-imx51-imx53.c,omap2/Makefile} * tag 'clk' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits) ARM: imx: clk-imx31: Fix clock id for rnga driver ARM: imx: add missing item to the list of clock event modes ARM: i.MX5x CSPI: Fixed clock name for CSPI ARM: i.MX5x clocks: Fix GPT clocks ARM: i.MX5x clocks: Fix parent for PWM clocks ARM: i.MX5x clocks: Add EPIT support ARM: mx27: Reenable silicon version print ARM: clk-imx27: Fix rtc clock id ARM: tegra: Provide clock for only one PWM controller ARM: tegra: Fix PWM clock programming ARM: OMAP3+: clock33xx: Add AM33XX clock tree data ARM: OMAP3+: clock: Move common clksel_rate & clock data to common file ARM: tegra: dma: rename driver name for clock to "tegra-apbdma" ARM: tegra: Remove second instance of uart clk crypto: add clk_prepare/clk_unprepare ASoC: tegra: add clk_prepare/clk_unprepare staging: nvec: add clk_prepare/clk_unprepare spi/tegra: add clk_prepare/clk_unprepare Input: tegra-kbc - add clk_prepare/clk_unprepare USB: ehci-tegra: add clk_prepare/clk_unprepare ...
2012-07-23Merge tag 'irq' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc sparse IRQ conversion from Arnd Bergmann: "The I.MX platform is getting converted to use sparse IRQs. We are doing this for all platforms over time, because this is one of the requirements for building a multiplatform kernel, and generally a good idea." * tag 'irq' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: imx: select USE_OF ARM: imx: Fix build error due to missing irqs.h include ARM: imx: enable SPARSE_IRQ for imx platform ARM: fiq: change FIQ_START to a variable tty: serial: imx: remove the use of MXC_INTERNAL_IRQS ARM: imx: remove unneeded mach/irq.h inclusion i2c: imx: remove unneeded mach/irqs.h inclusion ARM: imx: add a legacy irqdomain for mx31ads ARM: imx: add a legacy irqdomain for 3ds_debugboard ARM: imx: pass gpio than irq number into mxc_expio_init ARM: imx: leave irq_base of wm8350_platform_data uninitialized dma: ipu: remove the use of ipu_platform_data ARM: imx: move irq_domain_add_legacy call into avic driver ARM: imx: move irq_domain_add_legacy call into tzic driver gpio/mxc: move irq_domain_add_legacy call into gpio driver ARM: imx: eliminate macro IRQ_GPIOx() ARM: imx: eliminate macro IOMUX_TO_IRQ() ARM: imx: eliminate macro IMX_GPIO_TO_IRQ()
2012-07-23Merge tag 'dma' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull samsung arm-soc dma changes from Arnd Bergmann: "Some platforms are not yet converted to use the dmaengine framework, including some of the samsung SoCs. In the meantime, we treat this as platform code and merge the patches through the arm-soc tree." * tag 'dma' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: SAMSUNG: Fix compiler warning in dma-ops.c file ASoC: follow the updated samsung DMA common operations spi/s3c64xx: Add the use of DMA config operation ARM: SAMSUNG: Add config() function in DMA common operations
2012-07-23Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull general arm-soc cleanups from Arnd Bergmann: "These are all boring changes, moving stuff around or renaming things mostly, and also getting rid of stuff that is duplicate or should not be there to start with. Platform-wise this is all over the place, mainly omap, samsung, at91, imx and tegra." Resolve trivial conflict in arch/arm/mach-omap2/clockdomains3xxx_data.c * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits) ARM: clps711x: Remove the setting of the time ARM: clps711x: Removed superfluous transform virt_to_bus and related functions ARM: clps711x/p720t: Replace __initcall by .init_early call ARM: S3C24XX: Remove unused GPIO definitions for Openmoko GTA02 board ARM: S3C24XX: Remove unused GPIO definitions for port J ARM: S3C24XX: Remove unused GPA, GPE, GPH bank GPIO aliases ARM: S3C24XX: Convert the touchscreen setup code to common GPIO API ARM: S3C24XX: Convert the PM code to gpiolib API ARM: S3C24XX: Convert QT2410 board file to the gpiolib API ARM: S3C24XX: Convert SMDK board file to the gpiolib API ARM: S3C24XX: Free the backlight gpio requested in Mini2440 board code ARM: imx: remove unused pdata from device macros ARM: imx: Kconfig: Remove IMX_HAVE_PLATFORM_IMX_SSI from MACH_MX25_3DS ARM: at91: fix new build errors ARM: at91: add AIC5 support ARM: at91: remove mach/irqs.h ARM: at91: sparse irq support ARM: at91: at91 based machines specify their own irq handler at run time ARM: at91: remove static irq priorities for sam9x5 ARM: at91: add of irq priorities support ...
2012-07-23Merge tag 'asoc-3.6' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next ASoC: Additional updates for 3.6 A few more fixes for 3.6, some of which are relatively important - they've all been in -next for at least some time. - DAPM fixes for the recent locking changes. - Fix for _PRE and _POST widgets (which have been broken for a few releases now). - A couple of minor driver updates.
2012-07-23Merge branch 'for-3.5' into for-3.6Mark Brown
2012-07-23ASoC: dapm: Fix _PRE and _POST events for DAPM performance improvementsMark Brown
Ever since the DAPM performance improvements we've been marking all widgets as not dirty after each DAPM run. Since _PRE and _POST events aren't part of the DAPM graph this has rendered them non-functional, they will never be marked dirty again and thus will never be run again. Fix this by skipping them when marking widgets as not dirty. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com> Cc: stable@vger.kernel.org
2012-07-20ALSA: hda - add dock support for Thinkpad X230 TabletDavid Henningsson
Also add a model/fixup string "lenovo-dock", so that other Thinkpad users will be able to test this fixup easily, to see if it enables dock I/O for them as well. Cc: stable@kernel.org BugLink: https://bugs.launchpad.net/bugs/1026953 Tested-by: John McCarron <john.mccarron@canonical.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-20[SCSI] async: introduce 'async_domain' typeDan Williams
This is in preparation for teaching async_synchronize_full() to sync all pending async work, and not just on the async_running domain. This conversion is functionally equivalent, just embedding the existing list in a new async_domain type. The .registered attribute is used in a later patch to distinguish between domains that want to be flushed by async_synchronize_full() versus those that only expect async_synchronize_{full|cookie}_domain to be used for flushing. [jejb: add async.h to scsi_priv.h for struct async_domain] Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Tested-by: Eldad Zack <eldad@fogrefinery.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-07-20ASoC: siu: don't use DMA device for channel filteringGuennadi Liakhovetski
DMA channels are filtered based on slave IDs, no need to additionally filter on DMA device. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
2012-07-20ALSA: hda - Turn on PIN_OUT from hdmi playback prepare.Dylan Reid
Turn on the pin widget's PIN_OUT bit from playback prepare. The pin is enabled in open, but is disabled in hdmi_init_pin which is called during system resume. This causes a system suspend/resume during playback to mute HDMI/DP. Enabling the pin in prepare instead of open allows calling snd_pcm_prepare after a system resume to restore audio. Signed-off-by: Dylan Reid <dgreid@chromium.org> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-19Merge branch 'topic/pm-convert' into for-nextTakashi Iwai
This merges the changes for converting to new PM ops for platform and some other drivers. Also move some header files to local places from the public include/sound.
2012-07-19Merge tag 'asoc-3.6' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next ASoC: Updates for 3.6 This has been a pretty quiet release - very little activity in framework terms, mostly just a few new drivers and updates: - Added the ability to add and remove DAPM paths dynamically, mostly for reparenting on clock changes. - New machine drivers for Marvell Brownstone, ST-Ericsson Ux500 reference platform and ttc-dkp. - New CPU drivers for Blackfin BF6xx SPORTs in I2S mode, Marvell MMP, Synopsis Designware I2S controllers, and SPEAr DMA and S/PDIF - New CODEC drivers for Dialog DA732x, ST STA529, ST-Ericsson AB8500, TI Isabelle and Wolfson Microelectronics WM5102 and WM5110
2012-07-18ASoC imx-audmux: add MX31_AUDMUX_PORT7_SSI_PINS_7 defineTorben Hohn
The MX31 Audmux also has 7 Ports. This patch adds the missing define, and makes the debugfs code iterate over that port too. Signed-off-by: Torben Hohn <torbenh@linutronix.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-07-18ASoC: littlemill: Add userspace control of the WM1250 I/OMark Brown
2012-07-18ASoC: wm8994: Update micdet for irqdomain conversionMark Brown
The conversion of the core driver to irqdomains means that we don't need and irq_base to have working interrupts so use wm8994_request_irq() to deal with looking up the interrupt number for the micdet IRQ. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-07-18ALSA: hda - make sure alc268 does not OOPS on codec parseDavid Henningsson
A recent commit made patch_alc268 call snd_hda_pick_fixup with NULL quirk pointer. Make sure we do not reference that NULL pointer. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-18Merge branch 'topic/misc' into for-nextTakashi Iwai
Generic updates for sound 3.6
2012-07-18Merge branch 'topic/hda' into for-nextTakashi Iwai
This is a large chunk merge for 3.6 HD-audio things
2012-07-18ALSA: hda - Add support for Realtek ALC282David Henningsson
This codec has a separate dmic path (separate dmic only ADC), and thus it looks mostly like ALC275. Cc: stable@kernel.org BugLink: https://bugs.launchpad.net/bugs/1025377 Tested-by: Ray Chen <ray.chen@canonical.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-17Merge tag 'imx-clk' of git://git.pengutronix.de/git/imx/linux-2.6 into next/clkArnd Bergmann
From Sascha Hauer <s.hauer@pengutronix.de>: i.MX clk noncritical fixes and updates * tag 'imx-clk' of git://git.pengutronix.de/git/imx/linux-2.6: ARM: imx: clk-imx31: Fix clock id for rnga driver ARM: imx: add missing item to the list of clock event modes ARM: i.MX5x CSPI: Fixed clock name for CSPI ARM: i.MX5x clocks: Fix GPT clocks ARM: i.MX5x clocks: Fix parent for PWM clocks ARM: i.MX5x clocks: Add EPIT support ARM: mx27: Reenable silicon version print ARM: clk-imx27: Fix rtc clock id Signed-off-by: Arnd Bergmann <arnd@arndb.de>
