commit 40aa7030e5213a43e9e0554fd7f95534ea310bf3 upstream.
Remember to free the temporary register-cache.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
commit dc99be47667c56046555e89e62f1ac17fa06329a upstream.
This patch fixes the aut-mute setup on HP T5735 with ALC262 codec.
Instead of wrong amp, use pin control toggling for muting the speaker now.
Tested-by: Lee Trager <lee.trager@hp.com>
commit 23033b2bce4361f2859ee0331f97c9056dae7091 upstream.
Realtek codecs may have "PCM" and "Line-Out" playback switches, and
they can be slaves for vmaster.
commit 2fef62c825f09e29d2f52dc187ddf6f99e28c7f1 upstream.
Works fine with the auto-parser.
Reference: Novell bnc#564940
https://bugzilla.novell.com/show_bug.cgi?id=564940
commit 739b47f1e5aa3b36eadd7906cc6b41f0175c6ed1 upstream.
An earlier patch merely adds id for 0x80862804.
It has 2/3 cvt/pin nodes and shall be tied to the IbexPeak handler.
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
commit 50d40f187f9182ee8caa1b83f80a0e11e2226baa upstream.
Add proper suspend/resume code for Juli@ cards. Based on ice1724
suspend/resume work of Igor Chernyshev.
Fixes bug https://bugtrack.alsa-project.org/alsa-bug/view.php?id=4413
Tested on linux-2.6.31.6
Signed-off-by: Aleksey Kunitskiy <alexey.kv@gmail.com>
commit 6dd7dc767e35cfbb38f8c63a50b1c27acad25920 upstream.
Signed-off-by: Stefan Ringel <stefan.ringel@arcor.de>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit c7a8eb103248a110cdbe0530d8c5ce987f099eee upstream.
The capture-related mixer elements are missing with ALC861/ALC660 codecs
when quirks are present, due to missing call of set_capture_mixer().
Reference: Novell bnc#567340
http://bugzilla.novell.com/show_bug.cgi?id=567340
commit 5ee518ecbcb5934e284ea51a19a939c891f5f7ea upstream.
We need to set the LRCLK inversion bit to select DSP mode.
commit dfb12eeb0f04b37e5eb3858864d074af4ecd2ac7 upstream.
BugLink: https://bugs.launchpad.net/ubuntu/+bug/498863
This mainboard needs ac97_codec=0.
Tested-by: Apoorv Parle <apparle@yahoo.co.in>
Signed-off-by: Daniel T Chen <crimsun@ubuntu.com>
commit af9a75dd1a1f8a9aa406466cc8bb16208120488a upstream.
This model needs both 'Headphone Jack Sense' and 'Line Jack Sense' muted
for audible playback, so just add it to the ad1981 jack sense blacklist.
Tested-by: Pete <x41215201@gmail.com>
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
commit 9c0afc861a7228f718cb6a79fa7f9d46bf9ff300 upstream.
The capture source or input source mixer element wasn't created properly
for ALC861-VD codec due to the wrong NID passed to
alc_auto_create_input_ctls().
References: Novell bnc#568305
http://bugzilla.novell.com/show_bug.cgi?id=568305
commit b3172f222ab5afdc91ea058bd11c42cf169728f3 upstream.
Sevelar ASoC codec drivers wrongly assume, that the params_rate() macro
returns one of SNDRV_PCM_RATE_* defines instead of the actual numerical
sampling rate. Fix them.
commit 48e3cbb3f67a27d9c2db075f3d0f700246c40caa upstream.
This patch fixes a bug where "virtual" registers were being written to the ac97
bus. This was causing unrelated registers to become corrupted (headphone 0x04,
touchscreen 0x78, etc).
This patch duplicates protection that was included in the wm9713 driver.
Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com>
commit 035eb0cff0671ada49ba9f3e5c9e7b0cb950efea upstream.
Some model quirks missed the corresponding capsrc_nids. This resulted in
non-working capture source selection.
commit 3e85fd614c7b6bb7f33bb04a0dcb5a3bfca4c0fe upstream.
When allocating the PCM buffer, use vmalloc_user() instead of vmalloc().
Otherwise, it would be possible for applications to play the previous
contents of the kernel memory to the speakers, or to read it directly if
the buffer is exported to userspace.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit 48c03ce72f2665f79a3fe54fc6d71b8cc3d30803 upstream.
The wm8974 datasheet defines BUFIOEN as bit 2.
commit 396087eaead95fcb29eb36f1e59517aeb58c545e upstream.
Confirmed from vendor and tests in RedHat bugzilla #536782 .
commit fcfdebe70759c74e2e701f69aaa7f0e5e32cf5a6 upstream.
The timer stop callback can be called from snd_timer_interrupt(), which
is called from the hrtimer callback. Since hrtimer_cancel() waits for
the callback completion, this eventually results in a lock-up.
This patch fixes the problem by just toggling a flag at stop callback
and call hrtimer_cancel() later.
Reported-and-tested-by: Wojtek Zabolotny <W.Zabolotny@elka.pw.edu.pl>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: AACI: fix recording bug
ALSA: AACI: fix AC97 multiple-open bug
ASoC: AIC23: Fixing infinite loop in resume path
ASoC: Fix suspend with active audio streams
pcm->r[1].slots is the double rate slot information, not the
capture information. For capture, 'pcm' will already be the
capture ac97 pcm structure.
Cc: <stable@kernel.org>
This patch fixes two issues:
a) Infinite loop in resume function
b) Writes to non-existing registers in resume function
Cc: stable@kernel.org
Signed-off-by: Anuj Aggarwal <anuj.aggarwal@ti.com>
When we get a stream suspend event force the power down since otherwise
the stream would remain marked as active. In future we'll probably want
to make this stream-specific and add an interface to make the power down
of other widgets optional in order to support leaving bypass paths
active while suspending the processor.
Reported-by: Joonyoung Shim <jy0922.shim@samsung.com>
Tested-by: Joonyoung Shim <jy0922.shim@samsung.com>
ASoC: tlv320aic23 fix rate selection
ASoC: OMAP3 Pandora: update for TWL4030 codec changes
ASoC: Modifying the license string GPLv2 for OMAP3 EVM
ALSA: hda - Fix quirk for VAIO type G
ALSA: usb - Quirk to disable master volume control in PCM2702
Fix the ordering of sr_valid_mask array.
The lower bit of the index represents USB
not bosr.
Reported-by: Anuj Aggarwal <anuj.aggarwal@ti.com>
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
A while ago TWL4030 had it's playback stream name changed, but
pandora needs it for it's playback path. Update to correct stream
name so that playback works again.
Also mark VIBRA output as not connected.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Correcting the license string from GPLv2 -> GPL v2.
Found the problem while building OMAP3 ASoC driver as
module.
ALSA: ice1724 - make some bitfields unsigned
ALSA: hda - Dell Studio 1557 hd-audio quirk
ALSA: ice1724 - Fix section mismatch in prodigy_hd2_resume()
ALSA: hda - Add another Nvidia HDMI codec id (10de:0005)
ALSA: hda: Use model=mb5 for MacBookPro 5,2
git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc
* 'hostprogs-wmissing-prototypes' of git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc:
Makefile: Add -Wmising-prototypes to HOSTCFLAGS
oss: Mark loadhex static in hex2hex.c
dtc: Mark various internal functions static
dtc: Set "noinput" in the lexer to avoid an unused function
drm: radeon: Mark several functions static in mkregtable
arch/sparc/boot/*.c: Mark various internal functions static
arch/powerpc/boot/addRamDisk.c: Mark several internal functions static
arch/alpha/boot/tools/objstrip.c: Mark "usage" static
Documentation/vm/page-types.c: Declare checked_open static
genksyms: Mark is_reserved_word static
kconfig: Mark various internal functions static
kconfig: Make zconf.y work with current bison
Vaio type G laptop doesn't work with the current quirk setup.
After some tests, it turned out that it should be model=auto as default.
Reported-by: Mattia Dongili <malattia@linux.it>
Disable the master volume control in the PCM2702 chipset.
The datasheet documents two independent channel volume controls, one
master mute control and one master volume control. All controls are
fully functional except for the master volume control, which returns
USB stalls on all GET requests.
Signed-off-by: Javier Kohen <jkohen@users.sourceforge.net>
This is a clean up and doesn't change the behavior.
Bit fields should always be unsigned. Otherwise pm_suspend_enabled will
be -1 when you want it to be 1. The other bad thing is that the sparse
checker will complain 36 times if they aren't unsigned.
The other bitfields in that struct are unsigned already.
Nothing outside of hex2hex.c references loadhex.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Add the Dell Studio 15 (model 1557, Core i7) laptop to the hd-audio
quirk list, enabling audio.
Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com>
Remove invlid __devinit prefix from the suspend callback.
Found on Nvidia 9800M GTS.
Reported-by: Chris Balcum <sherl0k@gmail.com>
BugLink: https://bugs.launchpad.net/bugs/462098
Until we can look closer at the verbs, let's use ALC885_MB5 for
codec SSID 0x106b4600 to enable playback and capture for MacBookPro
5,2s.
The test of index `i' is after the read - too late - and
unsafe: if snd_hda_get_connections() fails in the last
iteration a read beyond the array is possible.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Commit 9a1b64caac82aa02cb74587ffc798e6f42c6170a in 2.6.30 broke the
error handling code in rawmidi_open_priv().
If only the output substream of a RawMIDI device has been opened and
if this device is then opened with O_RDWR | O_APPEND and if the
initialization of the input substream fails (either because of low
memory or because the device driver's open callback fails), then the
runtime structure of the already open output substream will be freed
and all following writes through the first handle will cause
snd_rawmidi_write() to use the NULL runtime pointer.
Commit 9a1b64caac82aa02cb74587ffc798e6f42c6170a in 2.6.30 dropped the
check that a substream must already have been opened with O_APPEND to be
able to open it a second time.
This would make it possible for a substream to be switched to append
mode, which would mean that non-atomic writes would fail unexpectedly.
Commit 9a1b64caac82aa02cb74587ffc798e6f42c6170a in 2.6.30 moved the
substream initialization code to where it would be executed every time
the substream is opened.
This had the consequence that any further opening would drop and leak
the data in the existing buffer, and that the device driver's open
callback would be called multiple times, unexpectedly.
The present quirk for HP dc5750 seems broken and maps the pins wrongly.
Since the auto-parser works well for this device, set the default entry
to use model=auto.
Reference: Novell bnc#552154
https://bugzilla.novell.com/show_bug.cgi?id=552154
Our contacts at Conexant suggested that we reduce the external
microphone bias to 50% in order to center the input signal with
the DC input range of the codec. This is because the microphone
port is DC coupled for potential use with sensors.
Signed-off-by: Daniel Drake <dsd@laptop.org>
BugLink: https://bugs.launchpad.net/bugs/478309
The internal microphone on this VAIO model does not work unless the
"auto" quirk is used.
