This is a backport for stable. The original commit SHA is
338cae565c53755de9f87d6a801517940d2d56f7.
On this machine, DAC on node 0x03 seems to give mono output.
Also, it needs additional patches for headset mic support.
It supports CTIA style headsets only.
Alsa-info available at the bug link below.
BugLink: https://bugs.launchpad.net/bugs/1236228
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit 88cfcf86aa3ada84d97195bcad74f4dadb4ae23b upstream.
The external mic showed up with a precense detect of "always present",
essentially disabling the internal mic. Therefore turn off presence
detection for this pin.
Note: The external mic seems not yet working, but an internal mic is
certainly better than no mic at all.
BugLink: https://bugs.launchpad.net/bugs/1227093
commit c6cc3d58b4042f5cadae653ff8d3df26af1a0169 upstream.
ASUS N56VZ needs a fixup for the bass speaker pin, which was already
provided via model=asus-mode4.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=841645
commit 39edac70e9aedf451fccaa851b273ace9fcca0bd upstream.
Currently hdmi_setup_audio_infoframe() reprograms the HDA channel
mapping only when the infoframe is not up-to-date or the non-PCM flag
has changed.
However, when just the channel map has been changed, the infoframe may
still be up-to-date and non-PCM flag may not have changed, so the new
channel map is not actually programmed into the HDA codec.
Notably, this failing case is also always triggered when the device is
already in a prepared state and a new channel map is configured while
changing only the channel positions (for example, plain
"speaker-test -c2 -m FR,FL").
Fix that by always programming the channel map in
hdmi_setup_audio_infoframe(). Tested on Intel HDMI.
Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi>
commit a9d14bc0b188a822e42787d01e56c06fe9750162 upstream.
The frame check in i_usX2Y_urb_complete() and
i_usX2Y_usbpcm_urb_complete() is bogus and produces false positives as
described in this LAU thread:
http://linuxaudio.org/mailarchive/lau/2013/5/20/200177
This patch removes the check code entirely.
Cc: fzu@wemgehoertderstaat.de
Reported-by: Dr Nicholas J Bailey <nicholas.bailey@glasgow.ac.uk>
Suggested-by: Takashi Iwai <tiwai@suse.de>
Signed-off-by: Daniel Mack <zonque@gmail.com>
commit 4a4370442c996be0fd08234a167c8a127c2488bb upstream.
Acer Aspire 3830TG seems requiring GPIO bit 0 as the primary mute
control. When a machine is booted after Windows 8, the GPIO pin is
turned off and it results in the silent output.
This patch adds the manual fixup of GPIO bit 0 for this model.
Reported-by: Christopher <DIDI2002@web.de>
commit d63733aed90b432e5cc489ddfa28e342f91b4652 upstream.
If the user passes an invalid value it leads to an info leak when we
print the error message or it could oops. This is called with user
supplied data from snd_ctl_elem_write().
Signed-off-by: Mark Brown <broonie@linaro.org>
commit d967967e8d1116fb38bad25e58714b5dddd03cca upstream.
This is called from snd_ctl_elem_write() with user supplied data so we
need to add some bounds checking.
commit f8d7b13e14357ed19d2ca2799539600418dc3939 upstream.
The ->put() function are called from snd_ctl_elem_write() with user
supplied data. The limit checks here could underflow leading to a
crash.
commit 4028b6c4c03f213260e9290ff3a6b5439aad07ce upstream.
snd_unregister_device() should return the device type and not stream
direction.
Signed-off-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Acked-by: Vinod Koul <vinod.koul@intel.com>
Tested-by: Vinod Koul <vinod.koul@intel.com>
commit 83f72151352791836a1b9c1542614cc9bf71ac61 upstream.
Toshiba Satellite C870 shows interrupt problems occasionally when
certain mixer controls like "Mic Switch" is toggled. This seems
worked around by not using MSI.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=833585
commit 18e391862cceaf43ddb8eb5cca05e1a83abdebaa upstream.
hdmi_channel_allocation() tries to find a HDMI channel allocation that
matches the number channels in the playback stream and contains only
speakers that the HDMI sink has reported as available via EDID. If no
such allocation is found, 0 (stereo audio) is used.
Using CA 0 causes the audio causes the sink to discard everything except
the first two channels (front left and front right).
However, the sink may be capable of receiving more channels than it has
speakers (and then perform downmix or discard the extra channels), in
which case it is preferable to use a CA that contains extra channels
than to use CA 0 which discards all the non-stereo channels.
Additionally, it seems that HBR (HD) passthrough output does not work on
Intel HDMI codecs when CA is set to 0 (possibly the codec zeroes
channels not present in CA). This happens with all receivers that report
a 5.1 speaker mask since a HBR stream is carried on 8 channels to the
codec.
Add a fallback in the CA selection so that the CA channel count at least
matches the stream channel count, even if the stream contains channels
not present in the sink speaker descriptor.
Thanks to GrimGriefer at OpenELEC forums for discovering that changing
the sink speaker mask allowed HBR output.
Reported-by: GrimGriefer
Reported-by: Ashecrow
Reported-by: Frank Zafka <kafkaesque1978@gmail.com>
Reported-by: Peter Frühberger <fritsch@xbmc.org>
commit b054087dbacee30a9dddaef2c9a96312146be04e upstream.
When the transcoder:port mapping on Haswell HDMI/DP audio is changed
during the stream playback, the sound gets lost. Typically this
problem is seen when the user switches the graphics mode from eDP+DP
to DP-only configuration, where CRTC 1 is used for DP in the former
while CRTC 0 is used for the latter.
The graphics controller notifies the change via the normal ELD update
procedure, so we get the intrinsic event. For enabling the sound
again, the HDMI audio driver needs to reset the pin and set up the
audio infoframe again.
This patch achieves it by:
- keep the current status of channels and info frame setup in per_pin
struct,
- check the reconnection in the intrinsic event handler,
- reset the pin and the re-invoke hdmi_setup_audio_infoframe()
accordingly.
The hdmi_setup_audio_infoframe() function has been changed, too, so
that it can be invoked without passing the substream instance.
The patch is mostly based on the work by Mengdong Lin.
Cc: Mengdong Lin <mengdong.lin@intel.com>
commit 9f6f0afbb9fdabf6dcac642dfec457f28981e3f8 upstream.
The MC13783 Chip Errata, Rev. 4 says, that depending on SPI clock
and main audio clock speed, the Audio Codec or Stereo DAC do sometimes
not start when programmed to do so. This is due to an internal clock
timing issue related to the loading of the SPI bits into the audio block.
On an i.MX27 based system, this issue lead to switched audio channels under
certain circumstances: RTC + Touch + Audio are used and loaded at startup.
The mentioned workaround of writing registers 40 and 41 two times is implemented
here.
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
commit 85fa532b6ef920b32598df86b194571a7059a77c upstream.
Bit 9 of PLL2,3 and 4 is reserved as '0'. The 24bit fractional part
should be split across each register in 8bit chunks.
Signed-off-by: Mike Dyer <mike.dyer@md-soft.co.uk>
commit fb615499f0ad28ed74201c1cdfddf9e64e205424 upstream.
The recent commit to delay the release of kobject triggered NULL
dereferences of opti9xx drivers. The cause is that all
snd-opti92x-ad1848, snd-opti92x-cs4231 and snd-opti93x drivers
register the PnP card driver with the very same name, and also
snd-opti92x-ad1848 and -cs4231 drivers register the ISA driver with
the same name, too. When these drivers are built in, quick
"register-release-and-re-register" actions occur, and this results in
Oops because of the same name is assigned to the kobject.
The fix is simply to assign individual names. As a bonus, by using
KBUILD_MODNAME, the patch reduces more lines than it adds.
The fix is based on the suggestion by Russell King.
Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com>
commit d3d3835ce919438c00c5d1270d6f9d6ffea59d03 upstream.
Yet another entry, just use the existing fixup for this machine, too.
Reported-by: "Nathanael D. Noblet" <nathanael@gnat.ca>
commit 2ca320e294a738c9134a71b5029de05edbfc7aad upstream.
Without the dynamic minor assignment, HDMI codec may have less PCM
instances than the number of pins, which eventually leads to Oops.
Reported-by: Stratos Karafotis <stratosk@semaphore.gr>
commit 1801928e0f99d94c55e33c584c5eb2ff5e246ee6 upstream.
Gateway LT27 needs a fixup for the inverted digital mic.
commit db8a38e5063a4daf61252e65d47ab3495c705f4c upstream.
Correct the pins for a line-in and a headphone on LG LW25 laptop with
ALC880 codec. Other pins seem fine.
Reported-and-tested-by: Joonas Saarinen <jonskunator@gmail.com>
commit f69910ddbd8c29391958cf82b598dd78fe5c8640 upstream.
We've added a fake mute control (setting the amp volume to zero) for
CX5051 at commit [3868137e: ALSA: hda - Add a fake mute feature], but
this feature was overlooked in the generic parser implementation. Now
the driver lacks of mute controls on these codecs.
The fix is just to check both AC_AMPCAP_MUTE and AC_AMPCAP_MIN_MUTE
bits in each place checking the amp capabilities.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=59001
commit 4c2aee0032b70083dafebd733ed9c774633b2fa3 upstream.
Patch makes midi output buffer DMA-able by allocating it separately.
Signed-off-by: Torsten Schenk <torsten.schenk@zoho.com>
commit 5ece263f1d93fba8d992e67e3ab8a71acf674db9 upstream.
Patch makes pcm buffers DMA-able by allocating each one separately.
commit 140d37de62ffe8405282a1d6498f3b4099006384 upstream.
Add the volume control quirk for avoiding the kernel warning
for the Logitech HD Webcam C525
as in the similar commit 36691e1be6ec551eef4a5225f126a281f8c051c2
for the Logitech HD Webcam C310.
Reported-by: Maksim Boyko <maksim.a.boyko@gmail.com>
Tested-by: Maksim Boyko <maksim.a.boyko@gmail.com>
Signed-off-by: Maksim Boyko <maksim.a.boyko@gmail.com>
commit c90c0d7a96e634a73ef1580f1d20993606545647 upstream.
The Tegra30 I2S driver was writing the AHUB interface parameters to the
playback path register rather than the capture path register. This
caused the capture parameters not to be configured at all, so if
capturing using non-HW-default parameters (e.g. 16-bit stereo rather
than 8-bit mono) the audio would be corrupted.
With this fixed, audio capture from an analog microphone works correctly
on the Cardhu board.
commit e2c98a8bba958045bde861fe1d66be54315c7790 upstream.
Beep Volume Min/Max was backwards.
Change to SOC_SONGLE_SX_TLV for correct volume representation
Signed-off-by: Brian Austin <brian.austin@cirrus.com>
commit fe581391147cb3d738d961d0f1233d91a9e1113c upstream.
list_first_entry() will always return a valid pointer, even if the list is
empty. So the check whether path is NULL will always be false. So we end up
calling dapm_create_or_share_mixmux_kcontrol() with a path struct that points
right in the middle of the widget struct and by trying to modify the path the
widgets memory will become corrupted. Fix this by using list_emtpy() to check if
the widget doesn't have any paths.
commit ddb6b5a964371e8e52e696b2b258bda144c8bd3f upstream.
Patch fixes 6fire not to use stack as URB transfer_buffer. URB buffers need to
be DMA-able, which stack is not. Furthermore, transfer_buffer should not be
allocated as part of larger device structure because DMA coherency issues and
patch fixes this issue too.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
Tested-by: Torsten Schenk <torsten.schenk@zoho.com>
commit 57e6dae1087bbaa6b33d3dd8a8e90b63888939a3 upstream.
The driver used to assume that the streaming endpoint's wMaxPacketSize
value would be an indication of how much data the endpoint expects or
sends, and compute the number of packets per URB using this value.
However, the Focusrite Scarlett 2i4 declares a value of 1024 bytes,
while only about 88 or 44 bytes are be actually used. This discrepancy
would result in URBs with far too few packets, which would not work
correctly on the EHCI driver.
To get correct URBs, use wMaxPacketSize only as an upper limit on the
packet size.
Reported-by: James Stone <jamesmstone@gmail.com>
Tested-by: James Stone <jamesmstone@gmail.com>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit a8d30608eaed6cc759b8e2e8a8bbbb42591f797f upstream.
the return value of SNDRV_COMPRESS_VERSION always return default -ENOTTY as the
return value was never updated for this call
assign return value from put_user()
Reported-by: Haynes <hgeorge@codeaurora.org>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit 697aebab78a88c6b164cfb74d19b86817d2ccd82 upstream.
A fixup for Apple Mac Mini was lost during the adaption to the generic
parser because the fallback for the generic ID 8384:7680 was dropped,
and it resulted in the silence output (and maybe other problems).
Unfortunately, just adding the missing subsystem ID wasn't enough, in
this case. The subsystem ID of this machine is 0000:0100 (what Apple
thought...?), and since snd_hda_pick_fixup() doesn't take the vendor
id zero into account, the driver ignored this entry. Now it's fixed
to regard the vendor id zero as a valid value.
Reported-and-tested-by: Linus Torvalds <torvalds@linux-foundation.org>
commit 2e7ee15ced914e109a1a5b6dfcd463d846a13bd5 upstream.
Also fix return values for headphone switch updates.
Signed-off-by: Nicolin Chen <b42378@freescale.com>
commit 647ab784c507763bfda79155f125b6edd1244806 upstream.
The errors were caused by copy/paste mistake in below commit
since v3.10:
3489d50 ASoC: tegra: Use common DAI DMA data struct
It also corrects slave_id initialization in tegra20_ac97 driver.
Signed-off-by: Richard Zhao <rizhao@nvidia.com>
Acked-by: Lucas Stach <dev@lynxeye.de>
commit cb6f66a2d278e57a6c9d8fb59bd9ebd8ab3965c2 upstream.
The registers of max98088 are 8 bits, not 16 bits. This bug causes the
contents of registers to be overwritten with bad values when the codec
is suspended and then resumed.
Signed-off-by: Chih-Chung Chang <chihchung@chromium.org>
Signed-off-by: Dylan Reid <dgreid@chromium.org>
commit 016fcab8ff46fca29375d484226ec91932aa4a07 upstream.
According to the sgtl5000 reference manual, the default value of CHIP_SSS_CTRL
is 0x10.
Reported-by: Oskar Schirmer <oskar@scara.com>
commit cd6fb6793a33e2b02af6e05a8d3f735f7c88a943 upstream.
Add two more machines that need quirks for headset mics to work.
Tested-by: Shawn Wang <shawn.wang@canonical.com>
BugLink: https://bugs.launchpad.net/bugs/1195636
commit 6c29d68a82ec68db18241b818d03e7864c052be9 upstream.
This quirk is needed for the headset mic to work on this Dell
machine.
BugLink: https://bugs.launchpad.net/bugs/1195597
commit 1ea9a69d1a36a5b62bf281ba8bb304fcac656dad upstream.
The EAPD GPIO is dynamically turned on/off for some machines with
Sigmatel codecs, but this didn't work as expected, and it resulted in
spontaneous lost of speaker outputs per HP plugging or power-saving.
This patch fixes the bug by simply including spec->eapd_mask into
spec->gpio_mask and spec->gpio_data bits.
Reported-and-tested-by: Eric Shattow <lucent@gmail.com>
commit be2f93a4c4981b3646b6f98f477154411b8516cb upstream.
Return SNDRV_PCM_POS_XRUN (snd_pcm_uframes_t) instead of
SNDRV_PCM_STATE_XRUN (snd_pcm_state_t) from the pointer
function of 6fire, as expected by snd_pcm_update_hw_ptr0().
Caught by sparse.
Signed-off-by: Eldad Zack <eldad@fogrefinery.com>
commit f3e351eef3a7fd1e36a3e18d4f2f069b00deb23c upstream.
The quirk for Dell laptops with STAC9228 overrides the pin default
config of NID 0x0f to the value with AC_DEFCFG_MISC_NO_PRESENCE bit
on. I'm not quite sure why this was done so, but can guess that this
was introduced for avoiding this to be muted by another headphone
plug. Now, after transition to the generic parser, this workaround
rather causes a problem (notably as unexpected speaker mutes) because
the pin is seen as if it's always plugged in.
Since the generic parser can handle multiple headphone plugging
gracefully, we can get rid of this override now.
commit 5c78dfe87ea04b501ee000a7f03b9432ac9d008c upstream.
SGTL5000_PLL_FRAC_DIV_MASK is used to mask bits 0-10 (11 bits in total) of
register CHIP_PLL_CTRL, so fix the mask to accomodate all this bit range.
commit 571185717f8d7f2a088a7ac38d94a9ad5fd9da5c upstream.
snd_pcm_stop() must be called in the PCM substream lock context.
Acked-by: Mark Brown <broonie@linaro.org>
commit 61be2b9a18ec70f3cbe3deef7a5f77869c71b5ae upstream.
commit 5be1efb4c2ed79c3d7c0cbcbecae768377666e84 upstream.
commit 60478295d6876619f8f47f6d1a5c25eaade69ee3 upstream.
commit cc7282b8d5abbd48c81d1465925d464d9e3eaa8f upstream.
commit 46f6c1aaf790be9ea3c8ddfc8f235a5f677d08e2 upstream.
commit 9538aa46c2427d6782aa10036c4da4c541605e0e upstream.
Acked-by: Clemens Ladisch <clemens@ladisch.de>
commit 5b9ab3f7324a1b94a5a5a76d44cf92dfeb3b5e80 upstream.
commit 256ca9c3ad5013ff8a8f165e5a82fab437628c8e upstream.
We've got bug reports that the module loading stuck on Debian system
with 3.10 kernel. The debugging session revealed that the initial
registration of OSS sequencer clients stuck at module loading time,
which involves again with request_module() at the init phase. This is
triggered only by special --install stuff Debian is using, but it's
still not good to have such loops.
As a workaround, call the registration part asynchronously. This is a
better approach irrespective of the hang fix, in anyway.
Reported-and-tested-by: Philipp Matthias Hahn <pmhahn@pmhahn.de>
