path: root/sound
2013-02-03ASoC: wm2200: correct mixer values and textChris Rattray
commit a80cc734282805e15b5e023751a4d02f7ffbcc91 upstream. Signed-off-by: Chris Rattray <crattray@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03ASoC: arizona: Use actual rather than desired BCLK when calculating LRCLKMark Brown
commit b59e0f82aa350e380142353fbd30706092ba6312 upstream. Otherwise we'll get the wrong LRCLK if we need to pick a higher BCLK than is required. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03ALSA: hda - Fix non-snoop page handlingTakashi Iwai
commit 9ddf1aeb2134e72275c97a2c6ff2e3eb04f2f27a upstream. For non-snoop mode, we fiddle with the page attributes of CORB/RIRB and the position buffer, but also the ring buffers. The problem is that the current code blindly assumes that the buffer is contiguous. However, the ring buffers may be SG-buffers, thus a wrong vmapped address is passed there, leading to Oops. This patch fixes the handling for SG-buffers. Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=800701 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03ALSA: hda - fix inverted internal mic on Acer AOA150/ZG5David Henningsson
commit fcd8f3b1d43c645e291638bc6c80a1c680722869 upstream. This patch enables internal mic input on the machine. BugLink: https://bugs.launchpad.net/bugs/1107477 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03ALSA: hda - Add a fixup for Packard-Bell desktop with ALC880Takashi Iwai
commit 0712eea349d8e2b6d0e44b94a752d999319027fb upstream. A Packard-Bell desktop machine gives no proper pin configuration from BIOS. It's almost equivalent with the 6stack+fp standard config, just take the existing fixup. Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=901846 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03ALSA: usb-audio: fix invalid length check for RME and other UAC 2 devicesClemens Ladisch
commit d56268fb108c7c21e19933588ca4d94652585183 upstream. Commit 23caaf19b11e (ALSA: usb-mixer: Add support for Audio Class v2.0) forgot to adjust the length check for UAC 2.0 feature unit descriptors. This would make the code abort on encountering a feature unit without per-channel controls, and thus prevented the driver to work with any device having such a unit, such as the RME Babyface or Fireface UCX. Reported-by: Florian Hanisch <fhanisch@uni-potsdam.de> Tested-by: Matthew Robbetts <wingfeathera@gmail.com> Tested-by: Michael Beer <beerml@sigma6audio.de> Cc: Daniel Mack <daniel@caiaq.de> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27ALSA: hda - Add Conexant CX20755/20756/20757 codec IDsTakashi Iwai
commit 42c364ace52ae6b4699105b39f2559c256b6cd4c upstream. These are just compatible with other CX2075x codecs. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27ALSA: hda - Fix mute led for another HP machineDavid Henningsson
commit e04340375a314166e14519fca9e5b9e9394b2d7a upstream. This machine also has the "HP_Mute_LED_0_A" string in DMI information. BugLink: https://bugs.launchpad.net/bugs/1096789 Tested-by: Tammy Yang <tammy.yang@canonical.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21ALSA: usb - fix race in creation of M-Audio Fast track pro driverDavid Henningsson
commit b98ae2729dea161edc96c9d177459b6c28bcbba5 upstream. A patch in the 3.2 kernel caused regression with hotplugging the M-Audio Fast track pro, or sound after suspend. I don't have the device so I haven't done a full analysis, but it seems userspace (both udev and pulseaudio) got confused when a card was created, immediately destroyed, and then created again. However, at least one person in the bug report (martin djfun) reports that this patch resolves the issue for him. It also leaves a message in the log: "snd-usb-audio: probe of 1-1.1:1.1 failed with error -5" which is a bit misleading. It is better than non-working audio, but maybe there's a more elegant solution? BugLink: https://bugs.launchpad.net/bugs/1095315 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: CAI Qian <caiqian@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21ALSA: hda/hdmi - Work around "alsactl restore" errorsTakashi Iwai
commit 6f54c361329dbb67dac9de174e938992651d12d7 upstream. When "alsactl restore" is performed on HDMI codecs, it tries to restore the channel map value since the channel map controls are writable. But hdmi_chmap_ctl_put() returns -EBADFD when no PCM stream is assigned yet, and this results in an error message from alsactl. Although the error is harmless, it's certainly ugly and can be regarded as a regression. As a workaround, this patch changes the return code in such a case to be zero for making others happy. (A slight excuse is: when the chmap is changed through the proper alsa-lib API, the PCM status is checked there anyway, so we don't have to be too strict in the kernel side.) Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ALSA: pxa27x: fix ac97 warm resetMike Dunn
commit 3b4bc7bccc7857274705b05cf81a0c72cfd0b0dd upstream. This patch fixes some code that implements a work-around to a hardware bug in the ac97 controller on the pxa27x. A bug in the controller's warm reset functionality requires that the mfp used by the controller as the AC97_nRESET line be temporarily reconfigured as a generic output gpio (AF0) and manually held high for the duration of the warm reset cycle. This is what was done in the original code, but it was broken long ago by commit fb1bf8cd ([ARM] pxa: introduce processor specific pxa27x_assert_ac97reset()) which changed the mfp to a GPIO input instead of a high output. The fix requires the ac97 controller to obtain the gpio via gpio_request_one(), with arguments that configure the gpio as an output initially driven high. Tested on a palm treo 680 machine. Reportedly, this broken code only prevents a warm reset on hardware that lacks a pull-up on the line, which appears to be the case for me. Signed-off-by: Mike Dunn <mikedunn@newsguy.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ALSA: pxa27x: fix ac97 cold resetMike Dunn
commit 41b645c8624df6ace020a8863ad1449d69140f7d upstream. Cold reset on the pxa27x currently fails and pxa2xx_ac97_try_cold_reset: cold reset timeout (GSR=0x44) appears in the kernel log. Through trial-and-error (the pxa270 developer's manual is mostly incoherent on the topic of ac97 reset), I got cold reset to complete by setting the WARM_RST bit in the GCR register (and later noticed that pxa3xx does this for cold reset as well). Also, a timeout loop is needed to wait for the reset to complete. Tested on a palm treo 680 machine. Signed-off-by: Mike Dunn <mikedunn@newsguy.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ALSA: hda - Disable runtime D3 for Intel CPT & coTakashi Iwai
commit d7dab4dbbb2d1b0c903378d6bade2e4ae161804e upstream. We've got a few bug reports that the runtime D3 results in the dead HD-audio controller. It seems that the problem is in a deeper level than the sound driver itself, so as a temporal solution, disable the feature for these controllers again. Reported-and-tested-by: Vincent Blut <vincent.debian@free.fr> Reported-and-tested-by: Maurizio Avogadro <mavoga@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17Revert "ALSA: hda - Shut up pins at power-saving mode with Conexnat codecs"David Henningsson
commit 7ed4165e2d01bdbbb4c1086eb73eadf0f64cbbf0 upstream. This reverts commit 697c373e34613609cb5450f98b91fefb6e910588. The original patch was meant to remove clicking, but in fact caused even more clicking instead. Thanks to c4pp4 for doing most of the work with this bug. BugLink: https://bugs.launchpad.net/bugs/886975 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ASoC: wm5100: Remove DSP B and left justified formatsMark Brown
commit 5f960294e2031d12f10c8488c3446fecbf59628d upstream. These are not supported Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ASoC: pcm: allow backend hardware to be freed in pause statePatrick Lai
commit 08b27848da620f206a8b6d80f26184485dd7aa40 upstream. When front-end PCM session is in paused state, back-end PCM session will be put in paused state as well if given front-end PCM session is the only client of given back-end. Then, application closes front-end PCM session, DPCM framework will not allow back-end enters HW_FREE state so back-end will never get shutdown completely. Signed-off-by: Patrick Lai <plai@codeaurora.org> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ASoC: sta529: Fix update register bits in sta529_set_dai_fmtAxel Lin
commit ad1937cdd59c412097ec2bb8f38c12a5640f1f9a upstream. Both the mask and mode settings are wrong in current code. According to the datasheet: S2PCFG0 (0x0A) BIT[3:1] DATA_FORMAT serial interface protocol format: 000: left Justified 001: I2S (default) 010: right justified 100: PCM no delay 101: PCM delay 111: DSP Thus fixes the defines for LEFT_J_DATA_FORMAT, I2S_DATA_FORMAT, and RIGHT_J_DATA_FORMAT. Also adds define for DATA_FORMAT_MSK. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Rajeev Kumar <rajeev-dlh.kumar@st.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ASoC: wm2200: Remove DSP B and left justified AIF modesMark Brown
commit 0cc411b934c4317b363d1af993549f391852b980 upstream. These are not supported. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ASoC: wm2200: Fix setting dai format in wm2200_set_fmtAxel Lin
commit 2a5f431592343b78896013b055582f94c12a5049 upstream. According to the defines in wm2200.h: /* * R1284 (0x504) - Audio IF 1_5 */ We should not left shift 1 bit for fmt_val when setting dai format. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ASoC: wm2000: Fix sense of speech clarity enableMark Brown
commit 267f8fa2e1eef0612b2007e1f1846bcbc35cc1fa upstream. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ASoC: arizona: Remove DSP B and left justified AIF modesMark Brown
commit d71753e22b24548911b377db28f80870cf50d07b upstream. These are not supported. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ASoC: arizona: Do proper shift for setting AIF rateAxel Lin
commit 7110a287ff2b1f3780905d1686a1a4edccb95133 upstream. ARIZONA_AIF1_RATE_MASK is 0x7800 /* AIF1_RATE - [14:11] */ Thus we need left shift ARIZONA_AIF1_RATE_SHIFT when setting aif1 rate. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ASoC: arizona: Correct FLL source definitionsMark Brown
commit a8c02db029385fb4426e0396e108ab23cd08f384 upstream. The FLL source constants were numbered as a simple enumeration but were being used in the code as direct values to be written to the registers. Renumber the constants to reflect the usage. Reported-by: Ryo Tsutsui <Ryo.Tsutsui@wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ASoC: sigmadsp: Fix endianness conversion issueLars-Peter Clausen
commit a3adb1432d7a3ad86bb17a1638e44414537e4118 upstream. The 'addr' field of the sigma_action struct is stored as big endian in the firmware file. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ASoC: wm8994: Use the same DCS codes for all WM1811 variantsMark Brown
commit 72222be39afbd39c16eb180646b0ac44bb1ba460 upstream. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ALSA: hda - add mute LED for HP Pavilion 17 (Realtek codec)David Henningsson
commit 6d3cd5d444223c41eabb70dccff14fae4e8cb8b1 upstream. The mute LED is in this case connected to the Mic1 VREF. The machine also exposes the following string in BIOS: "HP_Mute_LED_0_A", so if more machines are coming, it probably makes sense to try to do something more generic, like for the IDT codec. BugLink: https://bugs.launchpad.net/bugs/1096789 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ALSA: hda - Fix pin configuration of HP Pavilion dv7Takashi Iwai
commit 8ae5865ec77c22462c736846a0679947a6953548 upstream. Fix the quirk entry for HP Pavilion dv7 in order to make the bass speaker working. Reported-and-tested-by: Tomas Pospisek <tpo2@sourcepole.ch> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ALSA: hda - Fix the wrong pincaps set in ALC861VD dallas/hp fixupTakashi Iwai
commit b78562b10fa66175e30b76073e32a0ad8d92aa83 upstream. The workaround to force VREF50 for dallas/hp model with ALC861VD was introduced in commit 8fdcb6fe4204bdb4c6991652717ab5063751414e, but it contained wrong pincap override bits. This patch fixes to exclude VREF80 pincap bit correctly. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ALSA: hda - Always turn on pins for HDMI/DPTakashi Iwai
commit 6169b673618bf0b2518ce413b54925782a603f06 upstream. We've seen the broken HDMI *video* output on some machines with GM965, and the debugging session pointed that the culprit is the disabled audio output pins. Toggling these pins dynamically on demand caused flickering of HDMI TV. This patch changes the behavior to keep the pin ON constantly. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=51421 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ALSA: hda - Add stereo-dmic fixup for Acer Aspire One 522Takashi Iwai
commit 63a077e27648b4043b1ca1b4e29f0c42d99616b6 upstream. Acer Aspire One 522 has the infamous digital mic unit that needs the phase inversion fixup for stereo. Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=715737 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ALSA: hda - Move runtime PM check to runtime_idle callbackTakashi Iwai
commit 6eb827d23577a4efec2b10a9c4cc9ded268a1d1c upstream. The runtime_idle callback is the right place to check the suspend capability, but currently we do it wrongly in the runtime_suspend callback. This leads to a kernel error message like: pci_pm_runtime_suspend(): azx_runtime_suspend+0x0/0x50 [snd_hda_intel] returns -11 and the runtime PM core would even repeat the attempts. Reported-and-tested-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ALSA: usb-audio: Fix missing autopm for MIDI inputTakashi Iwai
commit f5f165418cabf2218eb466c0e94693b8b1aee88b upstream. The commit [88a8516a: ALSA: usbaudio: implement USB autosuspend] added the support of autopm for USB MIDI output, but it didn't take the MIDI input into account. This patch adds the following for fixing the autopm: - Manage the URB start at the first MIDI input stream open, instead of the time of instance creation - Move autopm code to the common substream_open() - Make snd_usbmidi_input_start/_stop() more robust and add the running state check Reviewd-by: Clemens Ladisch <clemens@ladisch.de> Tested-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ALSA: usb-audio: Avoid autopm calls after disconnectionTakashi Iwai
commit 59866da9e4ae54819e3c4e0a8f426bdb0c2ef993 upstream. Add a similar protection against the disconnection race and the invalid use of usb instance after disconnection, as well as we've done for the USB audio PCM. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=51201 Reviewd-by: Clemens Ladisch <clemens@ladisch.de> Tested-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-24ALSA: hda - Fix build without CONFIG_PMTakashi Iwai
I forgot this again... codec->in_pm is in #ifdef CONFIG_PM Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-11-22ALSA: snd-usb: properly initialize the sync endpointDaniel Mack
Jeffrey Barish reported an obvious bug in the pcm part of the usb-audio driver which causes the code to not initialize the sync endpoint from configure_endpoint(). Reported-by: Jeffrey Barish <jeff_barish@earthlink.net> Signed-off-by: Daniel Mack <zonque@gmail.com> Cc: stable@kernel.org [3.5+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-11-21ALSA: hda - Cirrus: Correctly clear line_out_pins when moving to speakerDavid Henningsson
If this array is not cleared, the jack related code later might fail to create "Internal Speaker Phantom Jack" on Dell Inspiron 3420 and Dell Vostro 2420. BugLink: https://bugs.launchpad.net/bugs/1076840 Cc: stable@vger.kernel.org (3.6+) Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-11-21ALSA: hda - Add support for Realtek ALC292David Henningsson
We found a new codec ID 292, and that just a simple quirk would enable sound output/input on this ALC292 chip. BugLink: https://bugs.launchpad.net/bugs/1081466 Cc: stable@vger.kernel.org Tested-by: Acelan Kao <acelan.kao@canonical.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-11-21Merge tag 'asoc-3.7' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Fixes for v3.7 The biggest batch of fixes here is the Kirkwood DMA fixes, plus a couple of other small fixes.
2012-11-21Merge branches 'fix/arizona', 'fix/cs4271', 'fix/kirkwood' and 'fix/samsung' ↵Mark Brown
of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into tmp
2012-11-21ASoC: kirkwood-i2s: more pause-mode fixesRussell King
Don't even momentarily set the pause status when starting the channel; if we do, we should check the busy bit to ensure that we comply with the spec. In any case, it isn't necessary; we will not active on a START event so there is no need to pause the DMA. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-21ASoC: kirkwood-i2s: fix DMA underrunsRussell King
Stress testing the driver with multiple start/stop events causes kirkwood-dma to report underrun errors (which used to cause the kernel to lock up solidly). This is because kirkwood-i2s is not respecting the restrictions imposed on clearing the 'pause' bit. Follow what the spec says; the busy bit must be read as being clear twice before the pause bit can be released. This solves the underruns. However, it has been noticed that the busy bit occasionally does not clear itself, hence the waiting is bounded to 5ms maximum to avoid a new reason for the kernel to lockup. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-21ASoC: kirkwood-i2s: fix DCO lock detectionRussell King
This is part of a patch found in Rabeeh Khoury's git tree for the cubox, which is further attributed to Sebastian Hesselbrath. Rather than masking the KIRKWOOD_DCO_SPCR_STATUS register contents against the registers virtual address, let's actually use the bit definition for the locked status, as required in the documentation. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-21ASoC: kirkwood-dma: don't ignore other irq causes on errorRussell King
Ignoring the real cause of the interrupt is not a good idea; this behaviour has been observed to bring Dove platforms to silently lockup. Instead, on error fall through to the normal interrupt processing. This is especially important on Dove platforms as errors are handled separately, and allows us to clear down the real cause of the interrupt. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-21ASoC: kirkwood-dma: fix use of virt_to_phys()Russell King
This is part of a patch found in Rabeeh Khoury's git tree for the cubox. You can not use virt_to_phys() on the address returned from dma_alloc_coherent(); it may not be part of the kernel direct-mapped memory. Fix this to use the DMA address instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-19ALSA: hda - Limit runtime PM support only to known Intel chipsTakashi Iwai
We've got a report that the runtime PM may make the codec the unresponsive on AMD platforms. Since the feature has been tested only on the recent Intel platforms, it's safer to limit the support to such devices for now. This patch adds a new DCAPS bit flag indicating the runtime PM support, and mark it for Intel controllers. Reported-and-tested-by: Julian Wollrath <jwollrath@web.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-11-19ALSA: hda - Fix recursive suspend/resume callTakashi Iwai
When the bus reset is performed during the suspend/resume (including the power-saving too), it calls snd_hda_suspend() and snd_hda_resume() again, and deadlocks eventually. For avoiding the recursive call, add a new flag indicating that the PM is being performed, and don't go to the bus reset mode when it's on. Reported-and-tested-by: Julian Wollrath <jwollrath@web.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-11-19Merge branch 'usb-midi-fix-3.7' of git://git.alsa-project.org/alsa-kprivate ↵Takashi Iwai
into for-linus Merge a regression fix for USB MIDI on non-standard usb-audio drivers by Clemens.
2012-11-18ALSA: ua101, usx2y: fix broken MIDI outputClemens Ladisch
Commit 88a8516a2128 (ALSA: usbaudio: implement USB autosuspend) added autosuspend code to all files making up the snd-usb-audio driver. However, midi.c is part of snd-usb-lib and is also used by other drivers, not all of which support autosuspend. Thus, calls to usb_autopm_get_interface() could fail, and this unexpected error would result in the MIDI output being completely unusable. Make it work by ignoring the error that is expected with drivers that do not support autosuspend. Reported-by: Colin Fletcher <colin.m.fletcher@googlemail.com> Reported-by: Devin Venable <venable.devin@gmail.com> Reported-by: Dr Nick Bailey <nicholas.bailey@glasgow.ac.uk> Reported-by: Jannis Achstetter <jannis_achstetter@web.de> Reported-by: Rui Nuno Capela <rncbc@rncbc.org> Cc: Oliver Neukum <oliver@neukum.org> Cc: 2.6.39+ <stable@vger.kernel.org> Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2012-11-16ASoC: arizona: Fix typo - Swap value in 48k_rates[] and 44k1_rates[]Dimitris Papastamos
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2012-11-16ASoC: bells: Fix up git patch application failureMark Brown
It seems git has been getting confused by the very similar contexts for the speaker DAIs and has been applying patches to the wrong places causing all sorts of confusion. Fix this up by hand. Reported-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
