path: root/sound
2016-10-27ALSA: usb-audio: Add quirk for Syntek STK1160Marcel Hasler
The stk1160 chip needs QUIRK_AUDIO_ALIGN_TRANSFER. This patch resolves the issue reported on the mailing list (http://marc.info/?l=linux-sound&m=139223599126215&w=2) and also fixes bug 180071 (https://bugzilla.kernel.org/show_bug.cgi?id=180071). Signed-off-by: Marcel Hasler <mahasler@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2016-10-25ALSA: seq: Fix time account regressionTakashi Iwai
The recent rewrite of the sequencer time accounting using timespec64 in the commit [3915bf294652: ALSA: seq_timer: use monotonic times internally] introduced a bad regression. Namely, the time reported back doesn't increase but goes back and forth. The culprit was obvious: the delta is stored to the result (cur_time = delta), instead of adding the delta (cur_time += delta)! Let's fix it. Fixes: 3915bf294652 ('ALSA: seq_timer: use monotonic times internally') Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=177571 Reported-by: Yves Guillemot <yc.guillemot@wanadoo.fr> Cc: <stable@vger.kernel.org> # v4.8+ Signed-off-by: Takashi Iwai <tiwai@suse.de>
2016-10-25ALSA: hda - Fix surround output pins for ASRock B150M moboTakashi Iwai
ASRock B150M Pro4/D3 mobo with ALC892 codec doesn't seem to provide proper pins for the surround outputs, hence we need to specify the pincfgs manually with a couple of other corrections. Reported-and-tested-by: Benjamin Valentin <benpicco@googlemail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2016-10-20ALSA: hda - Fix headset mic detection problem for two Dell laptopsHui Wang
They uses the codec ALC255, and have the different pin cfg definition from the ones in the existing pin quirk table. Now adding them into the table to fix the problem. Cc: stable@vger.kernel.org Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2016-10-18ALSA: asihpi: fix kernel memory disclosureVlad Tsyrklevich
Some elements in hr are not cleared before being copied to user space, leaking kernel heap memory to user space. For example, this happens in the error handling code for the HPI_ADAPTER_DELETE case. Zero the memory before it's copied. Signed-off-by: Vlad Tsyrklevich <vlad@tsyrklevich.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2016-10-18ALSA: hda - Adding a new group of pin cfg into ALC295 pin quirk tableHui Wang
We have a new Dell laptop model which uses ALC295, the pin definition is different from the existing ones in the pin quirk table, to fix the headset mic detection and mic mute led's problem, we need to add the new pin defintion into the pin quirk table. Cc: stable@vger.kernel.org Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2016-10-18ALSA: hda - allow 40 bit DMA mask for NVidia devicesArd Biesheuvel
Commit 49d9e77e72cf ("ALSA: hda - Fix system panic when DMA > 40 bits for Nvidia audio controllers") simply disabled any DMA exceeding 32 bits for NVidia devices, even though they are capable of performing DMA up to 40 bits. On some architectures (such as arm64), system memory is not guaranteed to be 32-bit addressable by PCI devices, and so this change prevents NVidia devices from working on platforms such as AMD Seattle. Since the original commit already mentioned that up to 40 bits of DMA is supported, and given that the code has been updated in the meantime to support a 40 bit DMA mask on other devices, revert commit 49d9e77e72cf and explicitly set the DMA mask to 40 bits for NVidia devices. Fixes: 49d9e77e72cf ('ALSA: hda - Fix system panic when DMA > 40 bits...') Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2016-10-15Merge tag 'sound-fix-4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Just a few trivial small fixes" * tag 'sound-fix-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: line6: fix a crash in line6_hwdep_write() ALSA: seq: fix passing wrong pointer in function call of compatibility layer ALSA: hda - Fix a failure of micmute led when having multi adcs ALSA: line6: Fix POD X3 Live audio input
2016-10-12ALSA: line6: fix a crash in line6_hwdep_write()Dan Carpenter
The error checking here is messed up so we could end up dereferencing -EFAULT. Fixes: a16039cbf1a1 ('ALSA: line6: Add hwdep interface to access the POD control messages') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2016-10-12ALSA: seq: fix passing wrong pointer in function call of compatibility layerTakashi Sakamoto
This commit is a fix for Linux 4.9-rc1. In former commit, a function call of compatibility layer for ALSA sequencer core was obsoleted by an alternative. Although, the alternative gets a pointer to kernel stack due to mis-programming. As a result, ALSA sequencer core unexpectedly refers over kernel stack. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Fixes: 8ce8eb601c71 ("ALSA: seq: add an alternative way to handle ioctl requests") Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2016-10-12ALSA: hda - Fix a failure of micmute led when having multi adcsHui Wang
On a Dell laptop, there is no global adcs for all input devices, so the input devices use the different adc, as a result, dyn_adc_switch is set to true. In this situation, it is safe to control the micmute led according to user's choice of muting/unmuting the current input device, since only current input device path is active, while other input device paths are inactive and powered down. Fixes: 00ef99408b6c ('ALSA: hda - add mic mute led hook for dell machines') Cc: <stable@vger.kernel.org> Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2016-10-11treewide: remove redundant #include <linux/kconfig.h>Masahiro Yamada
Kernel source files need not include <linux/kconfig.h> explicitly because the top Makefile forces to include it with: -include $(srctree)/include/linux/kconfig.h This commit removes explicit includes except the following: * arch/s390/include/asm/facilities_src.h * tools/testing/radix-tree/linux/kernel.h These two are used for host programs. Link: http://lkml.kernel.org/r/1473656164-11929-1-git-send-email-yamada.masahiro@socionext.com Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11kthread: kthread worker API cleanupPetr Mladek
A good practice is to prefix the names of functions by the name of the subsystem. The kthread worker API is a mix of classic kthreads and workqueues. Each worker has a dedicated kthread. It runs a generic function that process queued works. It is implemented as part of the kthread subsystem. This patch renames the existing kthread worker API to use the corresponding name from the workqueues API prefixed by kthread_: __init_kthread_worker() -> __kthread_init_worker() init_kthread_worker() -> kthread_init_worker() init_kthread_work() -> kthread_init_work() insert_kthread_work() -> kthread_insert_work() queue_kthread_work() -> kthread_queue_work() flush_kthread_work() -> kthread_flush_work() flush_kthread_worker() -> kthread_flush_worker() Note that the names of DEFINE_KTHREAD_WORK*() macros stay as they are. It is common that the "DEFINE_" prefix has precedence over the subsystem names. Note that INIT() macros and init() functions use different naming scheme. There is no good solution. There are several reasons for this solution: + "init" in the function names stands for the verb "initialize" aka "initialize worker". While "INIT" in the macro names stands for the noun "INITIALIZER" aka "worker initializer". + INIT() macros are used only in DEFINE() macros + init() functions are used close to the other kthread() functions. It looks much better if all the functions use the same scheme. + There will be also kthread_destroy_worker() that will be used close to kthread_cancel_work(). It is related to the init() function. Again it looks better if all functions use the same naming scheme. + there are several precedents for such init() function names, e.g. amd_iommu_init_device(), free_area_init_node(), jump_label_init_type(), regmap_init_mmio_clk(), + It is not an argument but it was inconsistent even before. [arnd@arndb.de: fix linux-next merge conflict] Link: http://lkml.kernel.org/r/20160908135724.1311726-1-arnd@arndb.de Link: http://lkml.kernel.org/r/1470754545-17632-3-git-send-email-pmladek@suse.com Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Petr Mladek <pmladek@suse.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Borislav Petkov <bp@suse.de> Cc: Michal Hocko <mhocko@suse.cz> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-10ALSA: line6: Fix POD X3 Live audio inputAndrej Krutak
The commit c039aaa77a7d1d9375665a8b59ec16dc7d23e259 was incomplete, missing part of the setup for Live. This makes also audio input work, in addition to audio output. Fixes: c039aaa77a7d1d9375665a8b59ec16dc7d23e259 Reported-by: Eddi De Pieri <eddi@depieri.net> Signed-off-by: Andrej Krutak <dev@andree.sk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2016-10-07Merge tag 'powerpc-4.9-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc updates from Michael Ellerman: "Highlights: - Major rework of Book3S 64-bit exception vectors (Nicholas Piggin) - Use gas sections for arranging exception vectors et. al. - Large set of TM cleanups and selftests (Cyril Bur) - Enable transactional memory (TM) lazily for userspace (Cyril Bur) - Support for XZ compression in the zImage wrapper (Oliver O'Halloran) - Add support for bpf constant blinding (Naveen N. Rao) - Beginnings of upstream support for PA Semi Nemo motherboards (Darren Stevens) Fixes: - Ensure .mem(init|exit).text are within _stext/_etext (Michael Ellerman) - xmon: Don't use ld on 32-bit (Michael Ellerman) - vdso64: Use double word compare on pointers (Anton Blanchard) - powerpc/nvram: Fix an incorrect partition merge (Pan Xinhui) - powerpc: Fix usage of _PAGE_RO in hugepage (Christophe Leroy) - powerpc/mm: Update FORCE_MAX_ZONEORDER range to allow hugetlb w/4K (Aneesh Kumar K.V) - Fix memory leak in queue_hotplug_event() error path (Andrew Donnellan) - Replay hypervisor maintenance interrupt first (Nicholas Piggin) Various performance optimisations (Anton Blanchard): - Align hot loops of memset() and backwards_memcpy() - During context switch, check before setting mm_cpumask - Remove static branch prediction in atomic{, 64}_add_unless - Only disable HAVE_EFFICIENT_UNALIGNED_ACCESS on POWER7 little endian - Set default CPU type to POWER8 for little endian builds Cleanups & features: - Sparse fixes/cleanups (Daniel Axtens) - Preserve CFAR value on SLB miss caused by access to bogus address (Paul Mackerras) - Radix MMU fixups for POWER9 (Aneesh Kumar K.V) - Support for setting used_(vsr|vr|spe) in sigreturn path (for CRIU) (Simon Guo) - Optimise syscall entry for virtual, relocatable case (Nicholas Piggin) - Optimise MSR handling in exception handling (Nicholas Piggin) - Support for kexec with Radix MMU (Benjamin Herrenschmidt) - powernv EEH fixes (Russell Currey) - Suprise PCI hotplug support for powernv (Gavin Shan) - Endian/sparse fixes for powernv PCI (Gavin Shan) - Defconfig updates (Anton Blanchard) - KVM: PPC: Book3S HV: Migrate pinned pages out of CMA (Balbir Singh) - cxl: Flush PSL cache before resetting the adapter (Frederic Barrat) - cxl: replace loop with for_each_child_of_node(), remove unneeded of_node_put() (Andrew Donnellan) - Fix HV facility unavailable to use correct handler (Nicholas Piggin) - Remove unnecessary syscall trampoline (Nicholas Piggin) - fadump: Fix build break when CONFIG_PROC_VMCORE=n (Michael Ellerman) - Quieten EEH message when no adapters are found (Anton Blanchard) - powernv: Add PHB register dump debugfs handle (Russell Currey) - Use kprobe blacklist for exception handlers & asm functions (Nicholas Piggin) - Document the syscall ABI (Nicholas Piggin) - MAINTAINERS: Update cxl maintainers (Michael Neuling) - powerpc: Remove all usages of NO_IRQ (Michael Ellerman) Minor cleanups: - Andrew Donnellan, Christophe Leroy, Colin Ian King, Cyril Bur, Frederic Barrat, Pan Xinhui, PrasannaKumar Muralidharan, Rui Teng, Simon Guo" * tag 'powerpc-4.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (156 commits) powerpc/bpf: Add support for bpf constant blinding powerpc/bpf: Implement support for tail calls powerpc/bpf: Introduce accessors for using the tmp local stack space powerpc/fadump: Fix build break when CONFIG_PROC_VMCORE=n powerpc: tm: Enable transactional memory (TM) lazily for userspace powerpc/tm: Add TM Unavailable Exception powerpc: Remove do_load_up_transact_{fpu,altivec} powerpc: tm: Rename transct_(*) to ck(\1)_state powerpc: tm: Always use fp_state and vr_state to store live registers selftests/powerpc: Add checks for transactional VSXs in signal contexts selftests/powerpc: Add checks for transactional VMXs in signal contexts selftests/powerpc: Add checks for transactional FPUs in signal contexts selftests/powerpc: Add checks for transactional GPRs in signal contexts selftests/powerpc: Check that signals always get delivered selftests/powerpc: Add TM tcheck helpers in C selftests/powerpc: Allow tests to extend their kill timeout selftests/powerpc: Introduce GPR asm helper header file selftests/powerpc: Move VMX stack frame macros to header file selftests/powerpc: Rework FPU stack placement macros and move to header file selftests/powerpc: Check for VSX preservation across userspace preemption ...
2016-09-30Merge tag 'asoc-v4.9' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next ASoC: Updates for v4.9 Apart from the cleanups done by Morimoto-san this has very much been a driver focused release with very little generic change: - A big factoring out of the simple-card code to allow it to be shared more with the rcar generic card from Kuninori Morimoto. - Removal of some operations duplicated on the CODEC level, again by Kuninori Morimoto. - Lots more machine support for x86 systems. - New drivers for Nuvoton NAU88C10, Realtek RT5660 and RT5663.
2016-09-29Merge remote-tracking branches 'asoc/topic/tpa6130a2', 'asoc/topic/ux500', ↵Mark Brown
'asoc/topic/wm8960', 'asoc/topic/wm8962' and 'asoc/topic/wm8991' into asoc-next
2016-09-29Merge remote-tracking branches 'asoc/topic/tas5086', 'asoc/topic/tegra', ↵Mark Brown
'asoc/topic/tlv320aic31xx', 'asoc/topic/tlv320dac33' and 'asoc/topic/topology' into asoc-next
2016-09-29Merge remote-tracking branches 'asoc/topic/sgtl5000', 'asoc/topic/simple', ↵Mark Brown
'asoc/topic/stac9766', 'asoc/topic/sti' and 'asoc/topic/sunxi' into asoc-next
2016-09-29Merge remote-tracking branches 'asoc/topic/rt5659', 'asoc/topic/rt5660', ↵Mark Brown
'asoc/topic/rt5677' and 'asoc/topic/samsung' into asoc-next
2016-09-29Merge remote-tracking branches 'asoc/topic/qcom', 'asoc/topic/rockchip' and ↵Mark Brown
'asoc/topic/rt5616' into asoc-next
2016-09-29Merge remote-tracking branches 'asoc/topic/nau8810', 'asoc/topic/of-bool', ↵Mark Brown
'asoc/topic/omap' and 'asoc/topic/platform-drvdata' into asoc-next
2016-09-29Merge remote-tracking branches 'asoc/topic/max98371', 'asoc/topic/max9867', ↵Mark Brown
'asoc/topic/max98926' and 'asoc/topic/mtk' into asoc-next
2016-09-29Merge remote-tracking branches 'asoc/topic/dwc', 'asoc/topic/fsl', ↵Mark Brown
'asoc/topic/gpio-chip' and 'asoc/topic/hdmi' into asoc-next
2016-09-29Merge remote-tracking branches 'asoc/topic/da7218', 'asoc/topic/da7219' and ↵Mark Brown
'asoc/topic/dpcm' into asoc-next
2016-09-29Merge remote-tracking branches 'asoc/topic/cs35l30', 'asoc/topic/cs42l73', ↵Mark Brown
'asoc/topic/cs53l30' and 'asoc/topic/da7213' into asoc-next
2016-09-29Merge remote-tracking branches 'asoc/topic/ac97', 'asoc/topic/ak4104', ↵Mark Brown
'asoc/topic/arizona', 'asoc/topic/atmel' and 'asoc/topic/codec-component' into asoc-next
2016-09-29Merge remote-tracking branch 'asoc/topic/rcar' into asoc-nextMark Brown
2016-09-29Merge remote-tracking branch 'asoc/topic/pcm' into asoc-nextMark Brown
2016-09-29Merge remote-tracking branch 'asoc/topic/intel' into asoc-nextMark Brown
2016-09-29Merge remote-tracking branch 'asoc/topic/dapm' into asoc-nextMark Brown
2016-09-29Merge remote-tracking branch 'asoc/fix/tpa6130a2' into asoc-linusMark Brown
2016-09-29Merge remote-tracking branches 'asoc/fix/arizona', 'asoc/fix/da7219', ↵Mark Brown
'asoc/fix/nau8825', 'asoc/fix/rt5514' and 'asoc/fix/shift' into asoc-linus
2016-09-29Merge remote-tracking branch 'asoc/fix/intel' into asoc-linusMark Brown
2016-09-29Merge remote-tracking branch 'asoc/fix/dapm' into asoc-linusMark Brown
2016-09-29ASoC: fsl: Fix lockups with recent cache changesMark Brown
The recent series of changes to the caching in the SSI driver have caused a number of problems to appear in some test systems. These are still not fully understood but we're coming up to the merge window so for now let's revert commit 7de2763d9b3 (ASoC: fsl_ssi: Remove .num_reg_defaults_raw from regmap_config) as backing that out seems to resolve the problem on affected systems. Reported-by: Maciej S. Szmigiero" <mail@maciej.szmigiero.name> Signed-off-by: Mark Brown <broonie@kernel.org> Reviewed-by: Marek Vasut <marex@denx.de>
2016-09-29ASoC: Intel: Skylake: fix memory leak of module on error exit pathColin Ian King
Currently there is a memory leak of module on a ENOMEM return path. Fix this by kfree'ing module before returning. Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-09-29ASoC: rsnd: add SNDRV_PCM_TRIGGER_SUSPEND/RESUMEKuninori Morimoto
This patch adds SNDRV_PCM_TRIGGER_SUSPEND/RESUME. Otherwise, it breaks rsnd driver internal start/stop counter when suspend/resume. This issue was reported/tested by Hiep Tested-by: Hiep Cao Minh <cm-hiep@jinso.co.jp> Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-09-29Merge branch 'for-linus' into for-nextTakashi Iwai
2016-09-28ASoC: wm8960: remove usage of obsoleted TLV-related macroTakashi Sakamoto
TLV_DB_RANGE_HEAD macro was obsoleted by commit bf1d1c9b6179 ("ALSA: tlv: add DECLARE_TLV_DB_RANGE()"). This commit removes usage of the macro, with the obsoleting macro renamed to SNDRV_CTL_TLVD_DECLARE_DB_RANGE(). Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-09-28ASoC: rt5616: remove usage of obsoleted TLV-related macroTakashi Sakamoto
TLV_DB_RANGE_HEAD macro was obsoleted by commit bf1d1c9b6179 ("ALSA: tlv: add DECLARE_TLV_DB_RANGE()"). This commit removes usage of the macro, with the obsoleting macro renamed to SNDRV_CTL_TLVD_DECLARE_DB_RANGE(). Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-09-28ASoC: max9867: remove usage of obsoleted TLV-related macroTakashi Sakamoto
2016-09-28ASoC: trivial: system spelling fixMarek Vasut
Do s/ststem/system/ . Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-09-27ASoC: da7219: fix inappropriate condition statementTakashi Sakamoto
Sparse reports a below warning. sound/soc/codecs/da7219.c:804:57: warning: dubious: x & !y The line includes a condition statement; '(a < b) & !c'. Practically, the evaluated value of this statement equals to the value of '(a < b) && !c'. Although, it's not an usual way to use bitwise operations as logical operations to several conditions. This commit fixes the bug. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Adam Thomson <Adam.Thomson.Opensource@diasemi.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-09-27ASoC: tlv320aic31xx: do not declare support for mono DAINikita Yushchenko
This hardware supports only 2-channel DAI, even mono ADC digital output has two channels with the same data. Having min_channels=1 results in broken playback of mono files in setups where CPU DAI supports mono. Signed-off-by: Nikita Yushchenko <nikita.yoush@cogentembedded.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-09-27ASoC: stac9766: fix wrong usage of DECLARE_TLV_DB_LINEAR()Takashi Sakamoto
As long as reading datasheet of STAC9766/9767, this driver includes wrong usage of DECLARE_TLV_DB_LINEAR(). In "8.1.2. Master Volume Registers", attenuation of lineout volumes is represented in 5 bits by -1.5 dB/step from 0 to -46.5 dB. Thus, 'master_tlv' should be dB step representation. In "8.1.14. Record Gain", gain of volumes is represented in 4 bits by 1.5 dB/step from 0 to 22.5 dB. Thus, 'record_tlv' should be dB step representation. In "8.1.5. PC BEEP Volume", attenuation of volume is represented in 4 bits by -3 dB/step from 0 to 45 dB. Thus, 'beep_tlv' should be dB step representation. In "8.1.7. Stereo or Mic Volume" and so on, gain of volumes is represented in 5 bits by -1.5 dB from 12 to -34.5 dB. Thus, 'mix_tlv' should be dB step representation. Totally, current implementation includes misuse of TLV-related macro. This commit replaces usage of DECLARE_TLV_DB_LINEAR() with SNDRV_CTL_TLVD_DECLARE_DB_SCALE(), to give proper information to applications in user land. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-09-27ASoC: wm8991: remove unused variableTakashi Sakamoto
This driver has some unused variables. They should be removed. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-09-27ASoC: wm8991: fix wrong usage of DECLARE_TLV_DB_LINEAR()Takashi Sakamoto
As long as reading datasheet of WM8991, this driver includes wrong usage of DECLARE_TLV_DB_LINEAR(). In "Table 6 Input PGA Volume Range", volume is represented in 5 bits by 1.5 dB/step between -16.5/30.0 dB. Thus, 'in_pga_tlv' should be dB step representation. In "Table 34 LOMIX and ROMIX Volume Range", volume is represented in three bits by -3 dB/step from 0 to -21 dB. Thus, 'out_mix_tlv' should be dB step represenation. In "Table 36 LOPGA, ROPGA, LOUT, ROUT and SPKVOL Volume Range", volume is represented in 7 bits by 1 dB/step from -73 to 6 dB, including mute. Thus, 'out_pga_tlv' should be dB step representation. In "Table 26 Digital Volume Range", volume is represented in 8 bits by 3/8 dB/step from -71.625 to 0 dB. Thus, 'out_dac_tlv' should be dB step representation. In "Table 16 ADC Digital Volume Range", volume is represented in 8 bits by 3/8 dB/step from -71.625 to 17.625 dB. Thus, 'in_adc_tlv' should be dB step representation. In "Table 23 Digital Sidetone Volume", volume is represented in 5 bits by 3 dB/step from -36 to 0 dB. Thus, 'out_sidetone_tlv' should be dB step representation. In "Table 12 Left Input Mixer Volume Control", volume is represented in 3 bits by 3 dB/step from -12 to 6 dB Totally, current implementation includes misuse of TLV-related macro. This commit replaces usage of DECLARE_TLV_DB_LINEAR() with proper macros, to give proper information to applications in user land. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-09-27ASOC: tpa6130a2: add static qualifier for file local symbolsTakashi Sakamoto
Sparse reports a below warning. tpa6130a2.c:193:33: warning: symbol 'tpa6130a2_component_driver' was not declared. Should it be static? The symbol is just used inner the file. Forthermore, it's constant. Thus, it's better to add static and const qualifier. This commit adds it. Fixes: cb7e62256e99 (ASoC: tpa6130a2: Register component) Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-09-27ASoC: sst-bxt-rt298: fix obsoleted initializers for arrayTakashi Sakamoto
Sparse reports below warnings. bxt_rt298.c:275:9: warning: obsolete array initializer, use C99 syntax bxt_rt298.c:290:9: warning: obsolete array initializer, use C99 syntax bxt_rt298.c:304:9: warning: obsolete array initializer, use C99 syntax bxt_rt298.c:317:9: warning: obsolete array initializer, use C99 syntax bxt_rt298.c:331:9: warning: obsolete array initializer, use C99 syntax bxt_rt298.c:344:9: warning: obsolete array initializer, use C99 syntax bxt_rt298.c:357:9: warning: obsolete array initializer, use C99 syntax There's no need to use obsoleted way. This commit fixes it. Fixes: 76016322ec56 (ASoC: Intel: Add Broxton-P machine driver) Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Mark Brown <broonie@kernel.org>
