path: root/sound
2014-09-17ASoC: rt5640: Do not allow regmap to use bulk read-write operationsJarkko Nikula
commit f4821e8e8e957fe4c601a49b9a97b7399d5f7ab1 upstream. Debugging showed Realtek RT5642 doesn't support autoincrementing writes so driver should set the use_single_rw flag for regmap. Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17ASoC: pxa-ssp: drop SNDRV_PCM_FMTBIT_S24_LEDaniel Mack
commit 9301503af016eb537ccce76adec0c1bb5c84871e upstream. This mode is unsupported, as the DMA controller can't do zero-padding of samples. Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-by: Johannes Stezenbach <js@sig21.net> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17ASoC: pxa: pxa-ssp: small leak in probe()Dan Carpenter
commit 4548728981de259d7d37d0ae968a777b09794168 upstream. There is a small memory leak if probe() fails. Fixes: 2023c90c3a2c ('ASoC: pxa: pxa-ssp: add DT bindings') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17ASoC: max98090: Fix missing free_irqJarkko Nikula
commit 4adeb0ccf86a5af1825bbfe290dee9e60a5ab870 upstream. max98090.c doesn't free the threaded interrupt it requests. This causes an oops when doing "cat /proc/interrupts" after snd-soc-max98090.ko is unloaded. Fix this by requesting the interrupt by using devm_request_threaded_irq(). Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17ASoC: adau1701: fix adau1701_reg_read()Daniel Mack
commit 3ad80b828b2533f37c221e2df155774efd6ed814 upstream. Fix a long standing bug in the read register routing of adau1701. The bytes arrive in the buffer in big-endian, so the result has to be shifted before and-ing the bytes in the loop. Signed-off-by: Daniel Mack <zonque@gmail.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17ASoC: samsung: Correct I2S DAI suspend/resume opsSylwester Nawrocki
commit d3d4e5247b013008a39e4d5f69ce4c60ed57f997 upstream. We should save/restore relevant I2S registers regardless of the dai->active flag, otherwise some settings are being lost after system suspend/resume cycle. E.g. I2S slave mode set only during dai initialization is not preserved and the device ends up in master mode after system resume. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17ASoC: blackfin: use samples to set silenceScott Jiang
commit 30443408fd7201fd1911b09daccf92fae3cc700d upstream. The third parameter for snd_pcm_format_set_silence needs the number of samples instead of sample bytes. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17ASoC: wm_adsp: Add missing MODULE_LICENSEPraveen Diwakar
commit 0a37c6efec4a2fdc2563c5a8faa472b814deee80 upstream. Since MODULE_LICENSE is missing the module load fails, so add this for module. Signed-off-by: Praveen Diwakar <praveen.diwakar@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Reviewed-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17ASoC: pcm: fix dpcm_path_put in dpcm runtime updateQiao Zhou
commit 7ed9de76ff342cbd717a9cf897044b99272cb8f8 upstream. we need to release dapm widget list after dpcm_path_get in soc_dpcm_runtime_update. otherwise, there will be potential memory leak. add dpcm_path_put to fix it. Signed-off-by: Qiao Zhou <zhouqiao@marvell.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17ASoC: wm8994: Prevent double lock of accdet_lock mutex on wm1811Charles Keepax
commit b38314179c9ccb789e6fe967cff171fa817e8978 upstream. wm1811_micd_stop takes the accdet_lock mutex, and is called from two places, one of which is already holding the accdet_lock. This obviously causes a lock up. This patch fixes this issue by removing the lock from wm1811_micd_stop and ensuring that it is always locked externally. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-05ALSA: hda/realtek - Avoid setting wrong COEF on ALC269 & coTakashi Iwai
commit f3ee07d8b6e061bf34a7167c3f564e8da4360a99 upstream. ALC269 & co have many vendor-specific setups with COEF verbs. However, some verbs seem specific to some codec versions and they result in the codec stalling. Typically, such a case can be avoided by checking the return value from reading a COEF. If the return value is -1, it implies that the COEF is invalid, thus it shouldn't be written. This patch adds the invalid COEF checks in appropriate places accessing ALC269 and its variants. The patch actually fixes the resume problem on Acer AO725 laptop. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=52181 Tested-by: Francesco Muzio <muziofg@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-05ALSA: hda - restore the gpio led after resumeHui Wang
commit f475371aa65de84fa483a998ab7594531026b9d9 upstream. On some HP laptops, the mute led is controlled by codec gpio. When some machine resume from s3/s4, the codec gpio data will be cleared to 0 by BIOS: Before suspend: IO[3]: enable=1, dir=1, wake=0, sticky=0, data=1, unsol=0 After resume: IO[3]: enable=1, dir=1, wake=0, sticky=0, data=0, unsol=0 To skip the AFG node to enter D3 can't fix this problem. A workaround is to restore the gpio data when the system resume back from s3/s4. It is safe even on the machines without this problem. BugLink: https://bugs.launchpad.net/bugs/1358116 Tested-by: Franz Hsieh <franz.hsieh@canonical.com> Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-05ALSA: hda - Add mute LED pin quirk for HP 15 touchsmartDavid Henningsson
commit 423044744aa4c250058e976474856a7a41972182 upstream. This makes the mute LED work on a HP 15 touchsmart machine. BugLink: https://bugs.launchpad.net/bugs/1334950 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-05ALSA: usb-audio: fix BOSS ME-25 MIDI regressionClemens Ladisch
commit 53da5ebfef66ea6e478ad9c6add3781472b79475 upstream. The BOSS ME-25 turns out not to have any useful descriptors in its MIDI interface, so its needs a quirk entry after all. Reported-and-tested-by: Kees van Veen <kees.vanveen@gmail.com> Fixes: 8e5ced83dd1c ("ALSA: usb-audio: remove superfluous Roland quirks") Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-05ALSA: hda/ca0132 - Don't try loading firmware at resume when already failedTakashi Iwai
commit e24aa0a4c5ac92a171d9dd74a8d3dbf652990d36 upstream. CA0132 driver tries to reload the firmware at resume. Usually this works since the firmware loader core caches the firmware contents by itself. However, if the driver failed to load the firmwares (e.g. missing files), reloading the firmware at resume goes through the actual file loading code path, and triggers a kernel WARNING like: WARNING: CPU: 10 PID:11371 at drivers/base/firmware_class.c:1105 _request_firmware+0x9ab/0x9d0() For avoiding this situation, this patch makes CA0132 skipping the f/w loading at resume when it failed at probe time. Reported-and-tested-by: Janek Kozicki <cosurgi@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-05ALSA: virtuoso: add Xonar Essence STX II supportClemens Ladisch
commit f42bb22243d2ae264d721b055f836059fe35321f upstream. Just add the PCI ID for the STX II. It appears to work the same as the STX, except for the addition of the not-yet-supported daughterboard. Tested-by: Mario <fugazzi99@gmail.com> Tested-by: corubba <corubba@gmx.de> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-05ALSA: usb-audio: Adjust Gamecom 780 volume levelPaul S McSpadden
commit 542baf94ec3c5526955b4c9fd899c7f30fae4ebe upstream. Original patch fixed the original problem, but the sound was far too low for most users. This patch references a compare matrix to allow the volume levels to act normally. I personally tested this patch myself, and volume levels returned to normal. Please see this discussion for more details: https://bugzilla.kernel.org/show_bug.cgi?id=65251 Signed-off-by: Paul S McSpadden <fisch602@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-05ALSA: hda - fix an external mic jack problem on a HP machineHui Wang
commit 7440850c20b69658f322119d20a94dc914127cc7 upstream. ON the machine, two pin complex (0xb and 0xe) are both routed to the same external right-side mic jack, this makes the jack can't work. To fix this problem, set the 0xe to "not connected". BugLink: https://bugs.launchpad.net/bugs/1350148 Tested-by: Franz Hsieh <franz.hsieh@canonical.com> Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-28ALSA: hda - initialize audio InfoFrame to be all zeroMengdong Lin
commit caaf5ef9493f72390905f1e97b310b8906d32dac upstream. This patch initialized the local audio InfoFrame variable 'ai' to be all zero, thus the data bytes will indicate "Refer to Stream Header" by default. Signed-off-by: Mengdong Lin <mengdong.lin@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-28ALSA: hda - Fix broken PM due to incomplete i915 initializationTakashi Iwai
commit 4da63c6fc426023d1a20e45508c47d7d68c6a53d upstream. When the initialization of Intel HDMI controller fails due to missing i915 kernel symbols (e.g. HD-audio is built in while i915 is module), the driver discontinues the probe. However, since the probe was done asynchronously, the driver object still remains, thus the relevant PM ops are still called at suspend/resume. This results in the bad access to the incomplete audio card object, eventually leads to Oops or stall at PM. This patch adds the missing checks of chip->init_failed flag at each PM callback in order to fix the problem above. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=79561 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09ALSA: usb-audio: Prevent printk ratelimiting from spamming kernel log while ↵Sander Eikelenboom
DEBUG not defined commit b7a7723513dc89f83d6df13206df55d4dc26e825 upstream. This (widely used) construction: if(printk_ratelimit()) dev_dbg() Causes the ratelimiting to spam the kernel log with the "callbacks suppressed" message below, even while the dev_dbg it is supposed to rate limit wouldn't print anything because DEBUG is not defined for this device. [ 533.803964] retire_playback_urb: 852 callbacks suppressed [ 538.807930] retire_playback_urb: 852 callbacks suppressed [ 543.811897] retire_playback_urb: 852 callbacks suppressed [ 548.815745] retire_playback_urb: 852 callbacks suppressed [ 553.819826] retire_playback_urb: 852 callbacks suppressed So use dev_dbg_ratelimited() instead of this construction. Signed-off-by: Sander Eikelenboom <linux@eikelenboom.it> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09ALSA: usb-audio: Suppress repetitive debug messages from retire_playback_urb()Tim Gardner
commit a5065eb6da55b226661456e6a7435f605df98111 upstream. BugLink: http://bugs.launchpad.net/bugs/1305133 Malfunctioning or slow devices can cause a flood of dmesg SPAM. I've ignored checkpatch.pl complaints about the use of printk_ratelimit() in favour of prior art in sound/usb/pcm.c. WARNING: Prefer printk_ratelimited or pr_<level>_ratelimited to printk_ratelimit + if (printk_ratelimit() && Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: Eldad Zack <eldad@fogrefinery.com> Cc: Daniel Mack <zonque@gmail.com> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06ALSA: hda - hdmi: call overridden init on resumePierre Ossman
commit a283368382c50345dff61525f493ea307f21ec9b upstream. We need to call the proper init function in case it has been overridden, as it might restore things that the generic routing doesn't know anything about. E.g. AMD cards have special verbs that need resetting. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=77901 Fixes: 5a61358433b1 ('ALSA: hda - hdmi: Add ATI/AMD multi-channel audio support') Signed-off-by: Pierre Ossman <pierre@ossman.eu> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06ALSA: usb-audio: Fix races at disconnection and PCM closingTakashi Iwai
commit 92a586bdc06de6629dae1b357dac221253f55ff8 upstream. When a USB-audio device is disconnected while PCM is still running, we still see some race: the disconnect callback calls snd_usb_endpoint_free() that calls release_urbs() and then kfree() while a PCM stream would be closed at the same time and calls stop_endpoints() that leads to wait_clear_urbs(). That is, the EP object might be deallocated while a PCM stream is syncing with wait_clear_urbs() with the same EP. Basically calling multiple wait_clear_urbs() would work fine, also calling wait_clear_urbs() and release_urbs() would work, too, as wait_clear_urbs() just reads some fields in ep. The problem is the succeeding kfree() in snd_pcm_endpoint_free(). This patch moves out the EP deallocation into the later point, the destructor callback. At this stage, all PCMs must have been already closed, so it's safe to free the objects. Reported-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26ALSA: control: Make sure that id->index does not overflowLars-Peter Clausen
commit 883a1d49f0d77d30012f114b2e19fc141beb3e8e upstream. The ALSA control code expects that the range of assigned indices to a control is continuous and does not overflow. Currently there are no checks to enforce this. If a control with a overflowing index range is created that control becomes effectively inaccessible and unremovable since snd_ctl_find_id() will not be able to find it. This patch adds a check that makes sure that controls with a overflowing index range can not be created. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26ALSA: control: Handle numid overflowLars-Peter Clausen
commit ac902c112d90a89e59916f751c2745f4dbdbb4bd upstream. Each control gets automatically assigned its numids when the control is created. The allocation is done by incrementing the numid by the amount of allocated numids per allocation. This means that excessive creation and destruction of controls (e.g. via SNDRV_CTL_IOCTL_ELEM_ADD/REMOVE) can cause the id to eventually overflow. Currently when this happens for the control that caused the overflow kctl->id.numid + kctl->count will also over flow causing it to be smaller than kctl->id.numid. Most of the code assumes that this is something that can not happen, so we need to make sure that it won't happen Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26ALSA: control: Don't access controls outside of protected regionsLars-Peter Clausen
commit fd9f26e4eca5d08a27d12c0933fceef76ed9663d upstream. A control that is visible on the card->controls list can be freed at any time. This means we must not access any of its memory while not holding the controls_rw_lock. Otherwise we risk a use after free access. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26ALSA: control: Fix replacing user controlsLars-Peter Clausen
commit 82262a46627bebb0febcc26664746c25cef08563 upstream. There are two issues with the current implementation for replacing user controls. The first is that the code does not check if the control is actually a user control and neither does it check if the control is owned by the process that tries to remove it. That allows userspace applications to remove arbitrary controls, which can cause a user after free if a for example a driver does not expect a control to be removed from under its feed. The second issue is that on one hand when a control is replaced the user_ctl_count limit is not checked and on the other hand the user_ctl_count is increased (even though the number of user controls does not change). This allows userspace, once the user_ctl_count limit as been reached, to repeatedly replace a control until user_ctl_count overflows. Once that happens new controls can be added effectively bypassing the user_ctl_count limit. Both issues can be fixed by instead of open-coding the removal of the control that is to be replaced to use snd_ctl_remove_user_ctl(). This function does proper permission checks as well as decrements user_ctl_count after the control has been removed. Note that by using snd_ctl_remove_user_ctl() the check which returns -EBUSY at beginning of the function if the control already exists is removed. This is not a problem though since the check is quite useless, because the lock that is protecting the control list is released between the check and before adding the new control to the list, which means that it is possible that a different control with the same settings is added to the list after the check. Luckily there is another check that is done while holding the lock in snd_ctl_add(), so we'll rely on that to make sure that the same control is not added twice. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26ALSA: control: Protect user controls against concurrent accessLars-Peter Clausen
commit 07f4d9d74a04aa7c72c5dae0ef97565f28f17b92 upstream. The user-control put and get handlers as well as the tlv do not protect against concurrent access from multiple threads. Since the state of the control is not updated atomically it is possible that either two write operations or a write and a read operation race against each other. Both can lead to arbitrary memory disclosure. This patch introduces a new lock that protects user-controls from concurrent access. Since applications typically access controls sequentially than in parallel a single lock per card should be fine. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26ALSA: hda - Add quirk for external mic on Lifebook U904David Henningsson
commit 2041d56464a067461d7cc21734a0f024587ed2ff upstream. According to the bug reporter (Данило Шеган), the external mic starts to work and has proper jack detection if only pin 0x19 is marked properly as an external headset mic. AlsaInfo at https://bugs.launchpad.net/ubuntu/+source/pulseaudio/+bug/1328587/+attachment/4128991/+files/AlsaInfo.txt BugLink: https://bugs.launchpad.net/bugs/1328587 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26ALSA: hda/realtek - Add more entry for enable HP mute ledKailang Yang
commit 8a02b164d4bfac108bfe37e98108bff1e062bd3d upstream. More HP machine need mute led support. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26ALSA: hda/realtek - Add support of ALC891 codecKailang Yang
commit b6c5fbad16aa5026f508093a8d651c25e1cb6179 upstream. New codec support for ALC891. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26ASoC: tlv320aci3x: Fix custom snd_soc_dapm_put_volsw_aic3x() functionPeter Ujfalusi
commit e6c111fac4464e3f4bf7b3802b517dafc80f8e0f upstream. For some unknown reason the parameters for snd_soc_test_bits() were in wrong order: It was: snd_soc_test_bits(codec, val, mask, reg); /* WRONG!!! */ while it should be: snd_soc_test_bits(codec, reg, mask, val); Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26ASoC: max98090: Fix reset at resume timeLiam Girdwood
commit 25b4ab430f8e166c9b63f4db28e7e812d5a59396 upstream. Reset needs to wait 20ms before other codec IO is performed. This wait was not being performed. Fix this by making sure the reset register is not restored with the cache, but use the manual reset method in resume with the wait. Signed-off-by: Liam Girdwood <liam.r.girdwood@linux.intel.com> Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26ASoC: dapm: Make sure to always update the DAPM graph in _put_volsw()Lars-Peter Clausen
commit c9e065c27fe9b81e5d6e7681d77a24f7b9616675 upstream. When using auto-muted controls it may happen that the register value will not change when changing a control from enabled to disabled (since the control might be physically disabled due to the auto-muting). We have to make sure to still update the DAPM graph and disconnect the mixer input. Fixes: commit 5729507 ("ASoC: dapm: Implement mixer input auto-disable") Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11ALSA: hda/realtek - Fix COEF widget NID for ALC260 replacer fixupTakashi Iwai
commit 192a98e280e560510a62aca8cfa83b4ae7c095bb upstream. The conversion to a fixup table for Replacer model with ALC260 in commit 20f7d928 took the wrong widget NID for COEF setups. Namely, NID 0x1a should have been used instead of NID 0x20, which is the common node for all Realtek codecs but ALC260. Fixes: 20f7d928fa6e ('ALSA: hda/realtek - Replace ALC260 model=replacer with the auto-parser') Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11ALSA: hda/realtek - Correction of fixup codes for PB V7900 laptopRonan Marquet
commit e30cf2d2bed3aed74a651c64de323ba26e4ff7d0 upstream. Correcion of wrong fixup entries add in commit ca8f0424 to replace static model quirk for PB V7900 laptop (will model). [note: the removal of ALC260_FIXUP_HP_PIN_0F chain is also needed as a part of the fix; otherwise the pin is set up wrongly as a headphone, and user-space (PulseAudio) may be wrongly trying to detect the jack state -- tiwai] Fixes: ca8f04247eaa ('ALSA: hda/realtek - Add the fixup codes for ALC260 model=will') Signed-off-by: Ronan Marquet <ronan.marquet@orange.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11ALSA: hda/analog - Fix silent output on ASUS A8JNTakashi Iwai
commit 598e306184d26fa1d546334f2eb370b4d94a4ad3 upstream. ASUS A8JN with AD1986A codec seems following the normal EAPD in the normal order (0 = off, 1 = on) unlike other machines with AD1986A. Apply the workaround used for Toshiba laptop that showed the same problem. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=75041 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ASoC: wm8962: Update register CLASS_D_CONTROL_1 to be non-volatileCharles Keepax
commit 44330ab516c15dda8a1e660eeaf0003f84e43e3f upstream. The register CLASS_D_CONTROL_1 is marked as volatile because it contains a bit, DAC_MUTE, which is also mirrored in the ADC_DAC_CONTROL_1 register. This causes problems for the "Speaker Switch" control, which will report an error if the CODEC is suspended because it relies on a volatile register. To resolve this issue mark CLASS_D_CONTROL_1 as non-volatile and manually keep the register cache in sync by updating both bits when changing the mute status. Reported-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ASoC: dapm: Skip CODEC<->CODEC links in connect_dai_link_widgets()Lars-Peter Clausen
commit ca5106ae3da0179dcee3ae21f3ea94f62e9fdb0c upstream. For CODEC to CODEC DAI links the paths are created in snd_soc_dapm_new_pcm(). Also for CODEC to CODEC links the widgets are connected cross-over via a DAI link widget, meaning that the capture widget of one CODEC will be connected to the playback widget of the other and vice versa. Whereas snd_soc_dapm_connect_dai_link_widgets() directly connects the playback widget of the CPU DAI to the playback widget of the CODEC DAI and the capture widget of the CPU DAI to the capture widget of the CODEC DAI. So not skipping CODEC<->CODEC links in snd_soc_dapm_connect_dai_link_widgets() will create incorrect connections between the two CODECs which will cause DAPM to detect active paths where there are none and unnecessarily power up widgets. Fixes: b893ea5 ("ASoC: sapm: Automatically connect DAI link widgets in DAPM graph.") Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ALSA: hda - Fix onboard audio on Intel H97/Z97 chipsetsTakashi Iwai
commit 77f07800cb456bed6e5c345e6e4e83e8eda62437 upstream. The recent Intel H97/Z97 chipsets need the similar setups like other Intel chipsets for snooping, etc. Especially without snooping, the audio playback stutters or gets corrupted. This fix patch just adds the corresponding PCI ID entry with the proper flags. Reported-and-tested-by: Arthur Borsboom <arthurborsboom@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ALSA: hda - hdmi: Set converter channel count even without sinkAnssi Hannula
commit f06ab794af7055d0949b09885f79f8b493deec64 upstream. Since commit 1df5a06a ("ALSA: hda - hdmi: Fix programmed active channel count") channel count is no longer being set if monitor_present is 0. This is because setting the count was moved after the CA value is determined, which is only after the monitor_present check in hdmi_setup_audio_infoframe(). Unfortunately, in some cases, such as with a non-spec-compliant codec or with a problematic video driver, monitor_present is always 0. As a specific example, this seems to happen with gen1 ATV (SiI1390 codec), causing left-channel-only stereo playback (multi-channel playback has apparently never worked with this codec despite it reporting 8 channels, reason unknown). Simply setting converter channel count without setting the pin infoframe and channel mapping as well does not theoretically make much sense as this will just mean they are out-of-sync and multichannel playback will have a wrong channel mapping. However, adding back just setting the converter channel count even in no-monitor case is the safest change which at least fixes the stereo playback regression on SiI1390 codec. Do that. Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi> Reported-by: Stephan Raue <stephan@openelec.tv> Tested-by: Stephan Raue <stephan@openelec.tv> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ALSA: usb-audio: work around corrupted TEAC UD-H01 feedback dataClemens Ladisch
commit 7040b6d1febfdbd9c1595efb751d492cd2503f96 upstream. The TEAC UD-H01 firmware sends wrong feedback frequency values, thus causing the PC to send the samples at a wrong rate, which results in clicks and crackles in the output. Add a workaround to detect and fix the corruption. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> [mick37@gmx.de: use sender->udh01_fb_quirk rather than ep->udh01_fb_quirk in snd_usb_handle_sync_urb()] Reported-and-tested-by: Mick <mick37@gmx.de> Reported-and-tested-by: Andrea Messa <andr.messa@tiscali.it> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-13ASoC: dapm: Fix widget double free with auto-disable DAPM kcontrolJarkko Nikula
commit 2697e4fb9209dfe1d1b24c92d254158f63d4bc8e upstream. Commit 9e1fda4ae158 ("ASoC: dapm: Implement mixer input auto-disable") is trying to free the widget it allocated by snd_soc_dapm_new_control() call in dapm_kcontrol_data_alloc() by adding kfree(data->widget) to dapm_kcontrol_free(). This is causing a widget double free with auto-disabled DAPM kcontrols in sound card unregistration because widgets are already freed before dapm_kcontrol_free() is called. Reason for that is all widgets are added into dapm->card->widgets list in snd_soc_dapm_new_control() and freed in dapm_free_widgets() during execution of snd_soc_dapm_free(). Now snd_soc_dapm_free() calls for different DAPM contexts happens before snd_card_free() call from where the call chain to dapm_kcontrol_free() begins: soc_cleanup_card_resources() soc_remove_dai_links() soc_remove_link_dais() snd_soc_dapm_free(&cpu_dai->dapm) soc_remove_link_components() soc_remove_platform() snd_soc_dapm_free(&platform->dapm) soc_remove_codec() snd_soc_dapm_free(&codec->dapm) snd_soc_dapm_free(&card->dapm) snd_card_free() snd_card_do_free() snd_device_free_all() snd_device_free() snd_ctl_dev_free() snd_ctl_remove() snd_ctl_free_one() dapm_kcontrol_free() This wasn't making harm with ordinary DAPM kcontrols since data->widget is NULL for them. Fixes: 9e1fda4ae158 (ASoC: dapm: Implement mixer input auto-disable) Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06ALSA: hda/realtek - Add headset Mic support for Dell machineKailang Yang
commit 8dc9abb93dde94e7f2bc719032fe16f5713df05c upstream. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06ALSA: hda/realtek - Add support of ALC288 codecKailang Yang
commit 7c66593286bcd153e4868383e675673a27071bd5 upstream. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06ALSA: hda - Fix silent speaker output due to mute LED fixupTakashi Iwai
commit 415d555e6b398b00fc1733f0113065a54df9106a upstream. The recent fixups for HP laptops to support the mute LED made the speaker output silent on some machines. It turned out that they use the NID 0x18 for the speaker while it's also used for controlling the LED via VREF bits although the current driver code blindly assumes that such a node is a mic pin (where 0x18 is usually so). This patch fixes the problem by only changing the VREF bits and keeping the other pin ctl bits. Reported-and-tested-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06ALSA: ice1712: Fix boundary checks in PCM pointer opsTakashi Iwai
commit 4f8e940095536bc002a81666a4107a581c84e9b9 upstream. PCM pointer callbacks in ice1712 driver check the buffer size boundary wrongly between bytes and frames. This leads to PCM core warnings like: snd_pcm_update_hw_ptr0: 105 callbacks suppressed ALSA pcm_lib.c:352 BUG: pcmC3D0c:0, pos = 5461, buffer size = 5461, period size = 2730 This patch fixes these checks to be placed after the proper unit conversions. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06ALSA: hda - Enable beep for ASUS 1015EW. Trevor King
commit a4b7f21d7b42b33609df3f86992a8deff80abfaf upstream. The `lspci -nnvv` output contains (wrapped for line length): 00:1b.0 Audio device [0403]: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller [8086:1e20] (rev 04) Subsystem: ASUSTeK Computer Inc. Device [1043:115d] Signed-off-by: W. Trevor King <wking@tremily.us> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06ALSA: hda - add headset mic detect quirks for three Dell laptopsHui Wang
commit a870593bab179ca402ead455f45af6e4404a2a7f upstream. When we plug a 3-ring headset on the Dell machines (VID: 0x10ec0255, SID: 0x10280632; VID: 0x10ec0293, SID: 0x1028062c; VID: 0x10ec0293, SID: 0x1028062e), the headset mic can't be detected, after apply this patch, the headset mic can work well. BugLink: https://bugs.launchpad.net/bugs/1297581 Cc: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
