path: root/sound
2017-07-27ASoC: compress: Derive substream from stream based on directionSatish Babu Patakokila
commit 01b8cedfd0422326caae308641dcadaa85e0ca72 upstream. Currently compress driver hardcodes direction as playback to get substream from the stream. This results in getting the incorrect substream for compressed capture usecase. To fix this, remove the hardcoding and derive substream based on the stream direction. Signed-off-by: Satish Babu Patakokila <sbpata@codeaurora.org> Signed-off-by: Banajit Goswami <bgoswami@codeaurora.org> Acked-By: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05ALSA: hda - set input_path bitmap to zero after moving it to new placeHui Wang
commit a8f20fd25bdce81a8e41767c39f456d346b63427 upstream. Recently we met a problem, the codec has valid adcs and input pins, and they can form valid input paths, but the driver does not build valid controls for them like "Mic boost", "Capture Volume" and "Capture Switch". Through debugging, I found the driver needs to shrink the invalid adcs and input paths for this machine, so it will move the whole column bitmap value to the previous column, after moving it, the driver forgets to set the original column bitmap value to zero, as a result, the driver will invalidate the path whose index value is the original colume bitmap value. After executing this function, all valid input paths are invalidated by a mistake, there are no any valid input paths, so the driver won't build controls for them. Fixes: 3a65bcdc577a ("ALSA: hda - Fix inconsistent input_paths after ADC reduction") Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05ALSA: hda - Fix endless loop of codec configureTakashi Iwai
commit d94815f917da770d42c377786dc428f542e38f71 upstream. azx_codec_configure() loops over the codecs found on the given controller via a linked list. The code used to work in the past, but in the current version, this may lead to an endless loop when a codec binding returns an error. The culprit is that the snd_hda_codec_configure() unregisters the device upon error, and this eventually deletes the given codec object from the bus. Since the list is initialized via list_del_init(), the next object points to the same device itself. This behavior change was introduced at splitting the HD-audio code code, and forgotten to adapt it here. For fixing this bug, just use a *_safe() version of list iteration. Fixes: d068ebc25e6e ("ALSA: hda - Move some codes up to hdac_bus struct") Reported-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14ASoC: Fix use-after-free at card unregistrationTakashi Iwai
commit 4efda5f2130da033aeedc5b3205569893b910de2 upstream. soc_cleanup_card_resources() call snd_card_free() at the last of its procedure. This turned out to lead to a use-after-free. PCM runtimes have been already removed via soc_remove_pcm_runtimes(), while it's dereferenced later in soc_pcm_free() called via snd_card_free(). The fix is simple: just move the snd_card_free() call to the beginning of the whole procedure. This also gives another benefit: it guarantees that all operations have been shut down before actually releasing the resources, which was racy until now. Reported-and-tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14ALSA: timer: Fix missing queue indices reset at SNDRV_TIMER_IOCTL_SELECTTakashi Iwai
commit ba3021b2c79b2fa9114f92790a99deb27a65b728 upstream. snd_timer_user_tselect() reallocates the queue buffer dynamically, but it forgot to reset its indices. Since the read may happen concurrently with ioctl and snd_timer_user_tselect() allocates the buffer via kmalloc(), this may lead to the leak of uninitialized kernel-space data, as spotted via KMSAN: BUG: KMSAN: use of unitialized memory in snd_timer_user_read+0x6c4/0xa10 CPU: 0 PID: 1037 Comm: probe Not tainted 4.11.0-rc5+ #2739 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:16 dump_stack+0x143/0x1b0 lib/dump_stack.c:52 kmsan_report+0x12a/0x180 mm/kmsan/kmsan.c:1007 kmsan_check_memory+0xc2/0x140 mm/kmsan/kmsan.c:1086 copy_to_user ./arch/x86/include/asm/uaccess.h:725 snd_timer_user_read+0x6c4/0xa10 sound/core/timer.c:2004 do_loop_readv_writev fs/read_write.c:716 __do_readv_writev+0x94c/0x1380 fs/read_write.c:864 do_readv_writev fs/read_write.c:894 vfs_readv fs/read_write.c:908 do_readv+0x52a/0x5d0 fs/read_write.c:934 SYSC_readv+0xb6/0xd0 fs/read_write.c:1021 SyS_readv+0x87/0xb0 fs/read_write.c:1018 This patch adds the missing reset of queue indices. Together with the previous fix for the ioctl/read race, we cover the whole problem. Reported-by: Alexander Potapenko <glider@google.com> Tested-by: Alexander Potapenko <glider@google.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14ALSA: timer: Fix race between read and ioctlTakashi Iwai
commit d11662f4f798b50d8c8743f433842c3e40fe3378 upstream. The read from ALSA timer device, the function snd_timer_user_tread(), may access to an uninitialized struct snd_timer_user fields when the read is concurrently performed while the ioctl like snd_timer_user_tselect() is invoked. We have already fixed the races among ioctls via a mutex, but we seem to have forgotten the race between read vs ioctl. This patch simply applies (more exactly extends the already applied range of) tu->ioctl_lock in snd_timer_user_tread() for closing the race window. Reported-by: Alexander Potapenko <glider@google.com> Tested-by: Alexander Potapenko <glider@google.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07ALSA: hda - apply STAC_9200_DELL_M22 quirk for Dell Latitude D430Alexander Tsoy
commit 1fc2e41f7af4572b07190f9dec28396b418e9a36 upstream. This model is actually called 92XXM2-8 in Windows driver. But since pin configs for M22 and M28 are identical, just reuse M22 quirk. Fixes external microphone (tested) and probably docking station ports (not tested). Signed-off-by: Alexander Tsoy <alexander@tsoy.me> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14ALSA: hda - Fix deadlock of controller device lock at unbindingTakashi Iwai
commit ab949d519601880fd46e8bc1445d6a453bf2dc09 upstream. Imre Deak reported a deadlock of HD-audio driver at unbinding while it's still in probing. Since we probe the codecs asynchronously in a work, the codec driver probe may still be kicked off while the controller itself is being unbound. And, azx_remove() tries to process all pending tasks via cancel_work_sync() for fixing the other races (see commit [0b8c82190c12: ALSA: hda - Cancel probe work instead of flush at remove]), now we may meet a bizarre deadlock: Unbind snd_hda_intel via sysfs: device_release_driver() -> device_lock(snd_hda_intel) -> azx_remove() -> cancel_work_sync(azx_probe_work) azx_probe_work(): codec driver probe() -> __driver_attach() -> device_lock(snd_hda_intel) This deadlock is caused by the fact that both device_release_driver() and driver_probe_device() take both the device and its parent locks at the same time. The codec device sets the controller device as its parent, and this lock is taken before the probe() callback is called, while the controller remove() callback gets called also with the same lock. In this patch, as an ugly workaround, we unlock the controller device temporarily during cancel_work_sync() call. The race against another bind call should be still suppressed by the parent's device lock. Reported-by: Imre Deak <imre.deak@intel.com> Fixes: 0b8c82190c12 ("ALSA: hda - Cancel probe work instead of flush at remove") Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-08ALSA: ppc/awacs: shut up maybe-uninitialized warningArnd Bergmann
commit b268c34e5ee92a4cc3099b0caaf26e6bfbdf0f18 upstream. The awacs sound driver produces a false-positive warning in ppc64_defconfig: sound/ppc/awacs.c: In function 'snd_pmac_awacs_init': include/sound/control.h:219:9: warning: 'master_vol' may be used uninitialized in this function [-Wmaybe-uninitialized] I haven't come up with a good way to rewrite the code to avoid the warning, so here is a bad one: I initialize the variable before the conditionall initialization so gcc no longer has to worry about it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-08ASoC: intel: Fix PM and non-atomic crash in bytcr driversTakashi Iwai
commit 6e4cac23c5a648d50b107d1b53e9c4e1120c7943 upstream. The FE setups of Intel SST bytcr_rt5640 and bytcr_rt5651 drivers carry the ignore_suspend flag, and this prevents the suspend/resume working properly while the stream is running, since SST core code has the check of the running streams and returns -EBUSY. Drop these superfluous flags for fixing the behavior. Also, the bytcr_rt5640 driver lacks of nonatomic flag in some FE definitions, which leads to the kernel Oops at suspend/resume like: BUG: scheduling while atomic: systemd-sleep/3144/0x00000003 Call Trace: dump_stack+0x5c/0x7a __schedule_bug+0x55/0x70 __schedule+0x63c/0x8c0 schedule+0x3d/0x90 schedule_timeout+0x16b/0x320 ? del_timer_sync+0x50/0x50 ? sst_wait_timeout+0xa9/0x170 [snd_intel_sst_core] ? sst_wait_timeout+0xa9/0x170 [snd_intel_sst_core] ? remove_wait_queue+0x60/0x60 ? sst_prepare_and_post_msg+0x275/0x960 [snd_intel_sst_core] ? sst_pause_stream+0x9b/0x110 [snd_intel_sst_core] .... This patch addresses these appropriately, too. [tiwai: applied only to bytcr_rt5640 as bytcr_rt5651 isn't present in 4.4.x yet] Signed-off-by: Takashi Iwai <tiwai@suse.de> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: <stable@vger.kernel.org> # v4.1+ Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02ALSA: seq: Don't break snd_use_lock_sync() loop by timeoutTakashi Iwai
commit 4e7655fd4f47c23e5249ea260dc802f909a64611 upstream. The snd_use_lock_sync() (thus its implementation snd_use_lock_sync_helper()) has the 5 seconds timeout to break out of the sync loop. It was introduced from the beginning, just to be "safer", in terms of avoiding the stupid bugs. However, as Ben Hutchings suggested, this timeout rather introduces a potential leak or use-after-free that was apparently fixed by the commit 2d7d54002e39 ("ALSA: seq: Fix race during FIFO resize"): for example, snd_seq_fifo_event_in() -> snd_seq_event_dup() -> copy_from_user() could block for a long time, and snd_use_lock_sync() goes timeout and still leaves the cell at releasing the pool. For fixing such a problem, we remove the break by the timeout while still keeping the warning. Suggested-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02ALSA: firewire-lib: fix inappropriate assignment between signed/unsigned typeTakashi Sakamoto
commit dfb00a56935186171abb5280b3407c3f910011f1 upstream. An abstraction of asynchronous transaction for transmission of MIDI messages was introduced in Linux v4.4. Each driver can utilize this abstraction to transfer MIDI messages via fixed-length payload of transaction to a certain unit address. Filling payload of the transaction is done by callback. In this callback, each driver can return negative error code, however current implementation assigns the return value to unsigned variable. This commit changes type of the variable to fix the bug. Reported-by: Julia Lawall <Julia.Lawall@lip6.fr> Fixes: 585d7cba5e1f ("ALSA: firewire-lib: add helper functions for asynchronous transactions to transfer MIDI messages") Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-08ASoC: atmel-classd: fix audio clock rateSongjun Wu
commit cd3ac9affc43b44f49d7af70d275f0bd426ba643 upstream. Fix the audio clock rate according to the datasheet. Reported-by: Dushara Jayasinghe <dushara@successful.com.au> Signed-off-by: Songjun Wu <songjun.wu@microchip.com> Acked-by: Nicolas Ferre <nicolas.ferre@microchip.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-08ALSA: hda - fix a problem for lineout on a Dell AIO machineHui Wang
commit 2f726aec19a9d2c63bec9a8a53a3910ffdcd09f8 upstream. On this Dell AIO machine, the lineout jack does not work. We found the pin 0x1a is assigned to lineout on this machine, and in the past, we applied ALC298_FIXUP_DELL1_MIC_NO_PRESENCE to fix the heaset-set mic problem for this machine, this fixup will redefine the pin 0x1a to headphone-mic, as a result the lineout doesn't work anymore. After consulting with Dell, they told us this machine doesn't support microphone via headset jack, so we add a new fixup which only defines the pin 0x18 as the headset-mic. [rearranged the fixup insertion position by tiwai in order to make the merge with other branches easier -- tiwai] Fixes: 59ec4b57bcae ("ALSA: hda - Fix headset mic detection problem for two dell machines") Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-08ALSA: seq: Fix race during FIFO resizeTakashi Iwai
commit 2d7d54002e396c180db0c800c1046f0a3c471597 upstream. When a new event is queued while processing to resize the FIFO in snd_seq_fifo_clear(), it may lead to a use-after-free, as the old pool that is being queued gets removed. For avoiding this race, we need to close the pool to be deleted and sync its usage before actually deleting it. The issue was spotted by syzkaller. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-30ALSA: hda - Adding a group of pin definition to fix headset problemHui Wang
commit 3f307834e695f59dac4337a40316bdecfb9d0508 upstream. A new Dell laptop needs to apply ALC269_FIXUP_DELL1_MIC_NO_PRESENCE to fix the headset problem, and the pin definiton of this machine is not in the pin quirk table yet, now adding it to the table. Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-30ALSA: ctxfi: Fix the incorrect check of dma_set_mask() callTakashi Iwai
commit f363a06642f28caaa78cb6446bbad90c73fe183c upstream. In the commit [15c75b09f8d1: ALSA: ctxfi: Fallback DMA mask to 32bit], I forgot to put "!" at dam_set_mask() call check in cthw20k1.c (while cthw20k2.c is OK). This patch fixes that obvious bug. (As a side note: although the original commit was completely wrong, it's still working for most of machines, as it sets to 32bit DMA mask in the end. So the bug severity is low.) Fixes: 15c75b09f8d1 ("ALSA: ctxfi: Fallback DMA mask to 32bit") Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-30ALSA: seq: Fix racy cell insertions during snd_seq_pool_done()Takashi Iwai
commit c520ff3d03f0b5db7146d9beed6373ad5d2a5e0e upstream. When snd_seq_pool_done() is called, it marks the closing flag to refuse the further cell insertions. But snd_seq_pool_done() itself doesn't clear the cells but just waits until all cells are cleared by the caller side. That is, it's racy, and this leads to the endless stall as syzkaller spotted. This patch addresses the racy by splitting the setup of pool->closing flag out of snd_seq_pool_done(), and calling it properly before snd_seq_pool_done(). BugLink: http://lkml.kernel.org/r/CACT4Y+aqqy8bZA1fFieifNxR2fAfFQQABcBHj801+u5ePV0URw@mail.gmail.com Reported-and-tested-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12ALSA: hda - Fix micmute hotkey problem for a lenovo AIO machineHui Wang
commit 29693efcea0f38cf40d0055d2401490a4f9bf8be upstream. On this machine, the micmute button is connected to Line2 of the codec and the micmute led is connected to GPIO2 of the codec. After applying this quirk, both hotkey and led work well. Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12ALSA: hda - Add subwoofer support for Dell Inspiron 17 7000 GamingTakashi Iwai
commit 493de342748cc6f52938096f5480cf291da58a0b upstream. Dell Inspiron 17 7000 Gaming laptop needs a similar quirk like Inspiron 7599 to support its subwoofer speaker. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=194191 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12ALSA: seq: Fix link corruption by event error handlingTakashi Iwai
commit f3ac9f737603da80c2da3e84b89e74429836bb6d upstream. The sequencer FIFO management has a bug that may lead to a corruption (shortage) of the cell linked list. When a sequencer client faces an error at the event delivery, it tries to put back the dequeued cell. When the first queue was put back, this forgot the tail pointer tracking, and the link will be screwed up. Although there is no memory corruption, the sequencer client may stall forever at exit while flushing the pending FIFO cells in snd_seq_pool_done(), as spotted by syzkaller. This patch addresses the missing tail pointer tracking at snd_seq_fifo_cell_putback(). Also the patch makes sure to clear the cell->enxt pointer at snd_seq_fifo_event_in() for avoiding a similar mess-up of the FIFO linked list. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12ALSA: ctxfi: Fallback DMA mask to 32bitTakashi Iwai
commit 15c75b09f8d190f89ab4db463b87d411ca349dfe upstream. Currently ctxfi driver tries to set only the 64bit DMA mask on 64bit architectures, and bails out if it fails. This causes a problem on some platforms since the 64bit DMA isn't always guaranteed. We should fall back to the default 32bit DMA when 64bit DMA fails. Fixes: 6d74b86d3c0f ("ALSA: ctxfi - Allow 64bit DMA") Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12ALSA: timer: Reject user params with too small ticksTakashi Iwai
commit 71321eb3f2d0df4e6c327e0b936eec4458a12054 upstream. When a user sets a too small ticks with a fine-grained timer like hrtimer, the kernel tries to fire up the timer irq too frequently. This may lead to the condensed locks, eventually the kernel spinlock lockup with warnings. For avoiding such a situation, we define a lower limit of the resolution, namely 1ms. When the user passes a too small tick value that results in less than that, the kernel returns -EINVAL now. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12ALSA: hda - fix Lewisburg audio issueJaroslav Kysela
commit e7480b34ad1ab84a63540b2c884cb92c0764ab74 upstream. Like for Sunrise Point, the total stream number of Lewisburg's input and output stream exceeds 15 (GCAP is 0x9701), which will cause some streams do not work because of the overflow on SDxCTL.STRM field if using the legacy stream tag allocation method. Fixes: 5cf92c8b3dc5 ("ALSA: hda - Add Intel Lewisburg device IDs Audio") Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12ALSA: hda/realtek - Cannot adjust speaker's volume on a Dell AIOKai-Heng Feng
commit 9f1bc2c4c58fcb2d86e0e26437dc8f3a18ac3276 upstream. The issue is the same as "dd9aa335c880 ALSA: hda/realtek - Can't adjust speaker's volume on a Dell AIO", the output requires to connect to a node with Amp-out capability. Applying the same fixup "ALC298_FIXUP_SPK_VOLUME" can fix the issue. Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14ALSA: seq: Don't handle loop timeout at snd_seq_pool_done()Takashi Iwai
commit 37a7ea4a9b81f6a864c10a7cb0b96458df5310a3 upstream. snd_seq_pool_done() syncs with closing of all opened threads, but it aborts the wait loop with a timeout, and proceeds to the release resource even if not all threads have been closed. The timeout was 5 seconds, and if you run a crazy stuff, it can exceed easily, and may result in the access of the invalid memory address -- this is what syzkaller detected in a bug report. As a fix, let the code graduate from naiveness, simply remove the loop timeout. BugLink: http://lkml.kernel.org/r/CACT4Y+YdhDV2H5LLzDTJDVF-qiYHUHhtRaW4rbb4gUhTCQB81w@mail.gmail.com Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14ALSA: seq: Fix race at creating a queueTakashi Iwai
commit 4842e98f26dd80be3623c4714a244ba52ea096a8 upstream. When a sequencer queue is created in snd_seq_queue_alloc(),it adds the new queue element to the public list before referencing it. Thus the queue might be deleted before the call of snd_seq_queue_use(), and it results in the use-after-free error, as spotted by syzkaller. The fix is to reference the queue object at the right time. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-15ALSA: usb-audio: Add a quirk for Plantronics BT600Dennis Kadioglu
commit 2e40795c3bf344cfb5220d94566205796e3ef19a upstream. Plantronics BT600 does not support reading the sample rate which leads to many lines of "cannot get freq at ep 0x1" and "cannot get freq at ep 0x82". This patch adds the USB ID of the BT600 to quirks.c and avoids those error messages. Signed-off-by: Dennis Kadioglu <denk@post.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-15ALSA: firewire-tascam: Fix to handle error from initialization of stream dataTakashi Sakamoto
commit 6a2a2f45560a9cb7bc49820883b042e44f83726c upstream. This module has a bug not to return error code in a case that data structure for transmitted packets fails to be initialized. This commit fixes the bug. Fixes: 35efa5c489de ("ALSA: firewire-tascam: add streaming functionality") Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-12ASoC: samsung: i2s: Fixup last IRQ unsafe spin lock callCharles Keepax
commit 5faf071d08ddd1c1be66deaa93a09ccf43f5b538 upstream. Unfortunately, I seem to have missed a case where an IRQ safe spinlock was required, in samsung_i2s_dai_remove, when I fixed up the other calls in this patch: 316fa9e09ad7 ("ASoC: samsung: Use IRQ safe spin lock calls") This causes a lockdep warning when unbinding and rebinding the audio card: [ 104.357664] CPU0 CPU1 [ 104.362174] ---- ---- [ 104.366692] lock(&(&pri_dai->spinlock)->rlock); [ 104.371372] local_irq_disable(); [ 104.377283] lock(&(&substream->self_group.lock)->rlock); [ 104.385259] lock(&(&pri_dai->spinlock)->rlock); [ 104.392469] <Interrupt> [ 104.395072] lock(&(&substream->self_group.lock)->rlock); [ 104.400710] [ 104.400710] *** DEADLOCK *** Fixes: ce8bcdbb61d9 ("ASoC: samsung: i2s: Protect more registers with a spinlock") Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Reviewed-by: Krzysztof Kozlowski <krzk@kernel.org> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-12ALSA: usb-audio: Fix bogus error return in snd_usb_create_stream()Takashi Iwai
commit 4763601a56f155ddf94ef35fc2c41504a2de15f5 upstream. The function returns -EINVAL even if it builds the stream properly. The bogus error code sneaked in during the code refactoring, but it wasn't noticed until now since the returned error code itself is ignored in anyway. Kill it here, but there is no behavior change by this patch, obviously. Fixes: e5779998bf8b ('ALSA: usb-audio: refactor code') Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-12ALSA: usb-audio: Fix irq/process data synchronizationIoan-Adrian Ratiu
commit 1d0f953086f090a022f2c0e1448300c15372db46 upstream. Commit 16200948d83 ("ALSA: usb-audio: Fix race at stopping the stream") was incomplete causing another more severe kernel panic, so it got reverted. This fixes both the original problem and its fallout kernel race/crash. The original fix is to move the endpoint member NULL clearing logic inside wait_clear_urbs() so the irq triggering the urb completion doesn't call retire_capture/playback_urb() after the NULL clearing and generate a panic. However this creates a new race between snd_usb_endpoint_start()'s call to wait_clear_urbs() and the irq urb completion handler which again calls retire_capture/playback_urb() leading to a new NULL dereference. We keep the EP deactivation code in snd_usb_endpoint_start() because removing it will break the EP reference counting (see [1] [2] for info), however we don't need the "can_sleep" mechanism anymore because a new function was introduced (snd_usb_endpoint_sync_pending_stop()) which synchronizes pending stops and gets called inside the pcm prepare callback. It also makes sense to remove can_sleep because it was also removed from deactivate_urbs() signature in [3] so we benefit from more simplification. [1] commit 015618b90 ("ALSA: snd-usb: Fix URB cancellation at stream start") [2] commit e9ba389c5 ("ALSA: usb-audio: Fix scheduling-while-atomic bug in PCM capture stream") [3] commit ccc1696d5 ("ALSA: usb-audio: simplify endpoint deactivation code") Fixes: f8114f8583bb ("Revert "ALSA: usb-audio: Fix race at stopping the stream"") Signed-off-by: Ioan-Adrian Ratiu <adi@adirat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-12ALSA: hda - Apply asus-mode8 fixup to ASUS X71SLTakashi Iwai
commit c7efff9284dfde95a11aaa811c9d8ec8167f0f6e upstream. Although the old quirk table showed ASUS X71SL with ALC663 codec being compatible with asus-mode3 fixup, the bugzilla reporter explained that asus-model8 fits better for the dual headphone controls. So be it. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=191781 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-12ALSA: hda - Fix up GPIO for ASUS ROG RangerTakashi Iwai
commit 85bcf96caba8b4a7c0805555638629ba3c67ea0c upstream. ASUS ROG Ranger VIII with ALC1150 codec requires the extra GPIO pin to up for the front panel. Just use the existing fixup for setting up the GPIO pins. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=189411 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06ASoC: intel: Fix crash at suspend/resume without card registrationTakashi Iwai
commit 2fc995a87f2efcd803438f07bfecd35cc3d90d32 upstream. When ASoC Intel SST Medfield driver is probed but without codec / card assigned, it causes an Oops and freezes the kernel at suspend/resume, PM: Suspending system (freeze) Suspending console(s) (use no_console_suspend to debug) BUG: unable to handle kernel NULL pointer dereference at 0000000000000018 IP: [<ffffffffc09d9409>] sst_soc_prepare+0x19/0xa0 [snd_soc_sst_mfld_platform] Oops: 0000 [#1] PREEMPT SMP CPU: 0 PID: 1552 Comm: systemd-sleep Tainted: G W 4.9.0-rc6-1.g5f5c2ad-default #1 Call Trace: [<ffffffffb45318f9>] dpm_prepare+0x209/0x460 [<ffffffffb4531b61>] dpm_suspend_start+0x11/0x60 [<ffffffffb40d3cc2>] suspend_devices_and_enter+0xb2/0x710 [<ffffffffb40d462e>] pm_suspend+0x30e/0x390 [<ffffffffb40d2eba>] state_store+0x8a/0x90 [<ffffffffb43c670f>] kobj_attr_store+0xf/0x20 [<ffffffffb42b0d97>] sysfs_kf_write+0x37/0x40 [<ffffffffb42b02bc>] kernfs_fop_write+0x11c/0x1b0 [<ffffffffb422be68>] __vfs_write+0x28/0x140 [<ffffffffb43728a8>] ? apparmor_file_permission+0x18/0x20 [<ffffffffb433b2ab>] ? security_file_permission+0x3b/0xc0 [<ffffffffb422d095>] vfs_write+0xb5/0x1a0 [<ffffffffb422e3d6>] SyS_write+0x46/0xa0 [<ffffffffb4719fbb>] entry_SYSCALL_64_fastpath+0x1e/0xad Add proper NULL checks in the PM code of mdfld driver. Signed-off-by: Takashi Iwai <tiwai@suse.de> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06ALSA: hda: when comparing pin configurations, ignore assoc in addition to seqKai-Heng Feng
commit 5e0ad0d8747f3e4803a9c3d96d64dd7332506d3c upstream. Commit [64047d7f4912 ALSA: hda - ignore the assoc and seq when comparing pin configurations] intented to ignore both seq and assoc at pin comparing, but it only ignored seq. So that commit may still fail to match pins on some machines. Change the bitmask to also ignore assoc. v2: Use macro to do bit masking. Thanks to Hui Wang for the analysis. Fixes: 64047d7f4912 ("ALSA: hda - ignore the assoc and seq when comparing...") Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06ALSA: hda - Gate the mic jack on HP Z1 Gen3 AiOTakashi Iwai
commit f73cd43ac3b41c0f09a126387f302bbc0d9c726d upstream. HP Z1 Gen3 AiO with Conexant codec doesn't give an unsolicited event to the headset mic pin upon the jack plugging, it reports only to the headphone pin. It results in the missing mic switching. Let's fix up by simply gating the jack event. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06ALSA: hda - fix headset-mic problem on a Dell laptopHui Wang
commit 989dbe4a30728c047316ab87e5fa8b609951ce7c upstream. This group of new pins is not in the pin quirk table yet, adding them to the pin quirk table to fix the headset-mic problem. Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06ALSA: hda - ignore the assoc and seq when comparing pin configurationsHui Wang
commit 64047d7f4912de1769d1bf0d34c6322494b13779 upstream. More and more pin configurations have been adding to the pin quirk table, lots of them are only different from assoc and seq, but they all apply to the same QUIRK_FIXUP, if we don't compare assoc and seq when matching pin configurations, it will greatly reduce the pin quirk table size. We have tested this change on a couple of Dell laptops, it worked well. Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06ALSA: hda/ca0132 - Add quirk for Alienware 15 R2 2016Sven Hahne
commit b5337cfe067e96b8a98699da90c7dcd2bec21133 upstream. I'm using an Alienware 15 R2 and had to use the alienware quirks to get my headphone output working. I fixed it by adding, SND_PCI_QUIRK(0x1028, 0x0708, "Alienware 15 R2 2016", QUIRK_ALIENWARE) to the patch. Signed-off-by: Sven Hahne <hahne@zeitkunst.eu> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06ALSA: hiface: Fix M2Tech hiFace driver sampling rate changeJussi Laako
commit 995c6a7fd9b9212abdf01160f6ce3193176be503 upstream. Sampling rate changes after first set one are not reflected to the hardware, while driver and ALSA think the rate has been changed. Fix the problem by properly stopping the interface at the beginning of prepare call, allowing new rate to be set to the hardware. This keeps the hardware in sync with the driver. Signed-off-by: Jussi Laako <jussi@sonarnerd.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06ALSA: usb-audio: Add QuickCam Communicate Deluxe/S7500 to volume_control_quirksCon Kolivas
commit 82ffb6fc637150b279f49e174166d2aa3853eaf4 upstream. The Logitech QuickCam Communicate Deluxe/S7500 microphone fails with the following warning. [ 6.778995] usb 2-1.2.2.2: Warning! Unlikely big volume range (=3072), cval->res is probably wrong. [ 6.778996] usb 2-1.2.2.2: [5] FU [Mic Capture Volume] ch = 1, val = 4608/7680/1 Adding it to the list of devices in volume_control_quirks makes it work properly, fixing related typo. Signed-off-by: Con Kolivas <kernel@kolivas.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-08ALSA: pcm : Call kill_fasync() in stream lockTakashi Iwai
commit 3aa02cb664c5fb1042958c8d1aa8c35055a2ebc4 upstream. Currently kill_fasync() is called outside the stream lock in snd_pcm_period_elapsed(). This is potentially racy, since the stream may get released even during the irq handler is running. Although snd_pcm_release_substream() calls snd_pcm_drop(), this doesn't guarantee that the irq handler finishes, thus the kill_fasync() call outside the stream spin lock may be invoked after the substream is detached, as recently reported by KASAN. As a quick workaround, move kill_fasync() call inside the stream lock. The fasync is rarely used interface, so this shouldn't have a big impact from the performance POV. Ideally, we should implement some sync mechanism for the proper finish of stream and irq handler. But this oneliner should suffice for most cases, so far. Reported-by: Baozeng Ding <sploving1@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-18ASoC: sun4i-codec: return error code instead of NULL when create_card failsChen-Yu Tsai
commit 85915b63ad8b796848f431b66c9ba5e356e722e5 upstream. When sun4i_codec_create_card fails, we do not assign a proper error code to the return value. The return value would be 0 from the previous function call, or we would have bailed out sooner. This would confuse the driver core into thinking the device probe succeeded, when in fact it didn't, leaving various devres based resources lingering. Make the create_card function pass back a meaningful error code, and assign it to the return value. Fixes: 45fb6b6f2aa3 ("ASoC: sunxi: add support for the on-chip codec on early Allwinner SoCs") Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-18ASoC: cs4270: fix DAPM stream name mismatchmurray foster
commit aa5f920993bda2095952177eea79bc8e58ae6065 upstream. Mismatching stream names in DAPM route and widget definitions are causing compilation errors. Fixing these names allows the cs4270 driver to compile and function. [Errors must be at probe time not compile time -- broonie] Signed-off-by: Murray Foster <mrafoster@gmail.com> Acked-by: Paul Handrigan <Paul.Handrigan@cirrus.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-18ALSA: info: Limit the proc text input sizeTakashi Iwai
commit 027a9fe6835620422b6713892175716f3613dd9d upstream. The ALSA proc handler allows currently the write in the unlimited size until kmalloc() fails. But basically the write is supposed to be only for small inputs, mostly for one line inputs, and we don't have to handle too large sizes at all. Since the kmalloc error results in the kernel warning, it's better to limit the size beforehand. This patch adds the limit of 16kB, which must be large enough for the currently existing code. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-18ALSA: info: Return error for invalid read/writeTakashi Iwai
commit 6809cd682b82dfff47943850d1a8c714f971b5ca upstream. Currently the ALSA proc handler allows read or write even if the proc file were write-only or read-only. It's mostly harmless, does thing but allocating memory and ignores the input/output. But it doesn't tell user about the invalid use, and it's confusing and inconsistent in comparison with other proc files. This patch adds some sanity checks and let the proc handler returning an -EIO error when the invalid read/write is performed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10ALSA: hda - Fix headset mic detection problem for two Dell laptopsHui Wang
commit 6aecd8715802d23dc6a0859b50c62d2b0a99de3a upstream. They uses the codec ALC255, and have the different pin cfg definition from the ones in the existing pin quirk table. Now adding them into the table to fix the problem. Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10ALSA: hda - Adding a new group of pin cfg into ALC295 pin quirk tableHui Wang
commit f771d5bb71d4df9573d12386400540516672208b upstream. We have a new Dell laptop model which uses ALC295, the pin definition is different from the existing ones in the pin quirk table, to fix the headset mic detection and mic mute led's problem, we need to add the new pin defintion into the pin quirk table. Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10ALSA: hda - allow 40 bit DMA mask for NVidia devicesArd Biesheuvel
commit 3ab7511eafdd5c4f40d2832f09554478dfbea170 upstream. Commit 49d9e77e72cf ("ALSA: hda - Fix system panic when DMA > 40 bits for Nvidia audio controllers") simply disabled any DMA exceeding 32 bits for NVidia devices, even though they are capable of performing DMA up to 40 bits. On some architectures (such as arm64), system memory is not guaranteed to be 32-bit addressable by PCI devices, and so this change prevents NVidia devices from working on platforms such as AMD Seattle. Since the original commit already mentioned that up to 40 bits of DMA is supported, and given that the code has been updated in the meantime to support a 40 bit DMA mask on other devices, revert commit 49d9e77e72cf and explicitly set the DMA mask to 40 bits for NVidia devices. Fixes: 49d9e77e72cf ('ALSA: hda - Fix system panic when DMA > 40 bits...') Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
