commit ed697e1aaf7237b1a62af39f64463b05c262808d upstream.
When the process is sleeping at the SNDRV_PCM_STATE_PAUSED
state from the wait_for_avail function, the sleep process will be woken by
timeout(10 seconds). Even if the sleep process wake up by timeout, by this
patch, the process will continue with sleep and wait for the other state.
Signed-off-by: JongHo Kim <furmuwon@gmail.com>
commit f0199bc5e3a3ec13f9bc938556517ec430b36437 upstream.
When wm8904 work in DSP mode B, we still need to configure it to
work in DSP mode. Or else, it will work in Right Justified mode.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
commit b4af6ef99a60c5b56df137d7accd81ba1ee1254e upstream.
According to WM8731 "PD, Rev 4.9 October 2012" datasheet, when it
works in DSP mode A, LRP = 1, while works in DSP mode B, LRP = 0.
So, fix LRP for DSP mode as the datesheet specification.
commit 2ab2b74277a86afe0dd92976db695a2bb8b93366 upstream.
Otherwise we'll skip sync on resume.
commit 9ad54547cf6f4410eba83bb95dfd2a0966718d6d upstream.
Set the missing pcbeep default amp for ALC668.
Signed-off-by: Kailang Yang <kailang@realtek.com>
commit afed4dbe3a043dbd833a53b6b4951e155708afd2 upstream.
Fixes: 4b2ffc205cb9 ('ASoC: Blackfin I2S: add 8-bit sample support')
Reported-by: David Binderman
commit 50bfcf2df2fadf77e143d6099150e6fa7ef4d78c upstream.
It's safer to turn on regcache_cache_only before disabling regulator since
the driver will turn off the regcache_cache_only after enabling regulator.
If we remain cache_only false, some command like 'amixer cset' would get
failure if being run before wm8962_resume().
Signed-off-by: Nicolin Chen <b42378@freescale.com>
commit 7b5bfb82882b9b1c8423ce0ed6852ca3762d967a upstream.
If you record the sound during playback,
the playback sound becomes silent.
Modify so that the codec driver does not clear
SG_SL1::DACL bit which is controlled under widget
Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com>
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
commit 092f9cd16aac7d054af1755c945f37c1b33399e6 upstream.
msnd_pinnacle.c is used for both snd-msnd-pinnacle and
snd-msnd-classic drivers, and both should have different driver
names. Using the same driver name results in the sysfs warning for
duplicated entries like
kobject: 'msnd-pinnacle.7' (cec33408): kobject_release, parent (null) (delayed)
kobject: 'msnd-pinnacle' (cecd4980): kobject_release, parent cf3ad9b0 (delayed)
WARNING: CPU: 0 PID: 1 at fs/sysfs/dir.c:486 sysfs_warn_dup+0x7d/0xa0()
sysfs: cannot create duplicate filename '/bus/isa/drivers/msnd-pinnacle'
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
commit 9b389a8a022110b4bc055a19b888283544d9eba6 upstream.
The probe code of snd-usb-6fire driver overrides the devices[] pointer
wrongly without checking whether it's already occupied or not. This
would screw up the device disconnection later.
Spotted by coverity CID 141423.
commit 8b8d654b55648561287bd8baca0f75f964a17038 upstream.
The codes to initialize work struct or create a proc interface should
be called only once and never although it's called many times through
the init callback. Move that stuff into patch_generic_hdmi() so that
it's called only once.
BugLink: https://bugs.launchpad.net/bugs/1212160
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit ff18620c2157671a8ee21ebb8e6a3520ea209b1f upstream.
... due to a copy & paste error.
Spotted by coverity CID 710923.
commit 268ff14525edba31da29a12a9dd693cdd6a7872e upstream.
Spotted by coverity CID 115170.
commit a4461f41b94cb52e0141af717dcf4ef6558c8e2e upstream.
Unable to handle kernel NULL pointer dereference at virtual address 00000008
pgd = d5300000
[00000008] *pgd=0d265831, *pte=00000000, *ppte=00000000
Internal error: Oops: 17 [#1] PREEMPT ARM
CPU: 0 PID: 2295 Comm: vlc Not tainted 3.11.0+ #755
task: dee74800 ti: e213c000 task.ti: e213c000
PC is at snd_pcm_info+0xc8/0xd8
LR is at 0x30232065
pc : [<c031b52c>] lr : [<30232065>] psr: a0070013
sp : e213dea8 ip : d81cb0d0 fp : c05f7678
r10: c05f7770 r9 : fffffdfd r8 : 00000000
r7 : d8a968a8 r6 : d8a96800 r5 : d8a96200 r4 : d81cb000
r3 : 00000000 r2 : d81cb000 r1 : 00000001 r0 : d8a96200
Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c5387d Table: 15300019 DAC: 00000015
Process vlc (pid: 2295, stack limit = 0xe213c248)
[<c031b52c>] (snd_pcm_info) from [<c031b570>] (snd_pcm_info_user+0x34/0x9c)
[<c031b570>] (snd_pcm_info_user) from [<c03164a4>] (snd_pcm_control_ioctl+0x274/0x280)
[<c03164a4>] (snd_pcm_control_ioctl) from [<c0311458>] (snd_ctl_ioctl+0xc0/0x55c)
[<c0311458>] (snd_ctl_ioctl) from [<c00eca84>] (do_vfs_ioctl+0x80/0x31c)
[<c00eca84>] (do_vfs_ioctl) from [<c00ecd5c>] (SyS_ioctl+0x3c/0x60)
[<c00ecd5c>] (SyS_ioctl) from [<c000e500>] (ret_fast_syscall+0x0/0x48)
Code: e1a00005 e59530dc e3a01001 e1a02004 (e5933008)
---[ end trace cb3d9bdb8dfefb3c ]---
This is provoked when the ASoC front end is open along with its backend,
(which causes the backend to have a runtime assigned to it) and then the
SNDRV_CTL_IOCTL_PCM_INFO is requested for the (visible) backend device.
Resolve this by ensuring that ASoC internal backend devices are not
visible to userspace, just as the commentry for snd_pcm_new_internal()
says it should be.
Acked-by: Mark Brown <broonie@linaro.org>
commit 6fc16e58adf50c0f1e4478538983fb5ff6f453d4 upstream.
ASUS N76VZ needs the same fixup as N56VZ for supporting the boost
speaker.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=846529
commit c6cc3d58b4042f5cadae653ff8d3df26af1a0169 upstream.
ASUS N56VZ needs a fixup for the bass speaker pin, which was already
provided via model=asus-mode4.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=841645
commit a9d14bc0b188a822e42787d01e56c06fe9750162 upstream.
The frame check in i_usX2Y_urb_complete() and
i_usX2Y_usbpcm_urb_complete() is bogus and produces false positives as
described in this LAU thread:
http://linuxaudio.org/mailarchive/lau/2013/5/20/200177
This patch removes the check code entirely.
Cc: fzu@wemgehoertderstaat.de
Reported-by: Dr Nicholas J Bailey <nicholas.bailey@glasgow.ac.uk>
Suggested-by: Takashi Iwai <tiwai@suse.de>
Signed-off-by: Daniel Mack <zonque@gmail.com>
commit d967967e8d1116fb38bad25e58714b5dddd03cca upstream.
This is called from snd_ctl_elem_write() with user supplied data so we
need to add some bounds checking.
commit f8d7b13e14357ed19d2ca2799539600418dc3939 upstream.
The ->put() function are called from snd_ctl_elem_write() with user
supplied data. The limit checks here could underflow leading to a
crash.
commit 4028b6c4c03f213260e9290ff3a6b5439aad07ce upstream.
snd_unregister_device() should return the device type and not stream
direction.
Signed-off-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Acked-by: Vinod Koul <vinod.koul@intel.com>
Tested-by: Vinod Koul <vinod.koul@intel.com>
commit 83f72151352791836a1b9c1542614cc9bf71ac61 upstream.
Toshiba Satellite C870 shows interrupt problems occasionally when
certain mixer controls like "Mic Switch" is toggled. This seems
worked around by not using MSI.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=833585
commit 85fa532b6ef920b32598df86b194571a7059a77c upstream.
Bit 9 of PLL2,3 and 4 is reserved as '0'. The 24bit fractional part
should be split across each register in 8bit chunks.
Signed-off-by: Mike Dyer <mike.dyer@md-soft.co.uk>
commit fb615499f0ad28ed74201c1cdfddf9e64e205424 upstream.
The recent commit to delay the release of kobject triggered NULL
dereferences of opti9xx drivers. The cause is that all
snd-opti92x-ad1848, snd-opti92x-cs4231 and snd-opti93x drivers
register the PnP card driver with the very same name, and also
snd-opti92x-ad1848 and -cs4231 drivers register the ISA driver with
the same name, too. When these drivers are built in, quick
"register-release-and-re-register" actions occur, and this results in
Oops because of the same name is assigned to the kobject.
The fix is simply to assign individual names. As a bonus, by using
KBUILD_MODNAME, the patch reduces more lines than it adds.
The fix is based on the suggestion by Russell King.
Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com>
commit a62ee234a572b4c98fe98cf5fb18e4e8b0f6e43d upstream.
Commit d4702b189c ("sound: Fix make allmodconfig on MIPS") added a
(negative) dependency on ISA_DMA_SUPPORT_BROKEN. Since that Kconfig
symbol doesn't exist, this dependency will always evaluate to true.
Apparently GENERIC_ISA_DMA_SUPPORT_BROKEN was meant to be used here.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
commit d4702b189c6b951c1cb3260036ff998f719bfb62 upstream.
The compile of soundcard.c is broken on MIPS when allmodconfig is used
because of the missing MAX_DMA_CHANNELS definition. As a simple
workaround, just add a Kconfig dependency.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
commit a8d30608eaed6cc759b8e2e8a8bbbb42591f797f upstream.
the return value of SNDRV_COMPRESS_VERSION always return default -ENOTTY as the
return value was never updated for this call
assign return value from put_user()
Reported-by: Haynes <hgeorge@codeaurora.org>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit 2e7ee15ced914e109a1a5b6dfcd463d846a13bd5 upstream.
Also fix return values for headphone switch updates.
commit cb6f66a2d278e57a6c9d8fb59bd9ebd8ab3965c2 upstream.
The registers of max98088 are 8 bits, not 16 bits. This bug causes the
contents of registers to be overwritten with bad values when the codec
is suspended and then resumed.
Signed-off-by: Chih-Chung Chang <chihchung@chromium.org>
Signed-off-by: Dylan Reid <dgreid@chromium.org>
commit be2f93a4c4981b3646b6f98f477154411b8516cb upstream.
Return SNDRV_PCM_POS_XRUN (snd_pcm_uframes_t) instead of
SNDRV_PCM_STATE_XRUN (snd_pcm_state_t) from the pointer
function of 6fire, as expected by snd_pcm_update_hw_ptr0().
Caught by sparse.
Signed-off-by: Eldad Zack <eldad@fogrefinery.com>
commit 5c78dfe87ea04b501ee000a7f03b9432ac9d008c upstream.
SGTL5000_PLL_FRAC_DIV_MASK is used to mask bits 0-10 (11 bits in total) of
register CHIP_PLL_CTRL, so fix the mask to accomodate all this bit range.
Reported-by: Oskar Schirmer <oskar@scara.com>
commit 342cda29343a6272c630f94ed56810a76740251b upstream.
When the Android firmware enables the audio interfaces in accessory
mode, it always declares in the control interface's baInterfaceNr array
that interfaces 0 and 1 belong to the audio function. However, the
accessory interface itself, if also enabled, already is at index 0 and
shifts the actual audio interface numbers to 1 and 2, which prevents the
PCM streaming interface from being seen by the host driver.
To get the PCM interface interface to work, detect when the descriptors
point to the (for this driver useless) accessory interface, and redirect
to the correct one.
Reported-by: Jeremy Rosen <jeremy.rosen@openwide.fr>
Tested-by: Jeremy Rosen <jeremy.rosen@openwide.fr>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit 36691e1be6ec551eef4a5225f126a281f8c051c2 upstream.
Just like the previous fix for LogitechHD Webcam c270 in commit
11e7064f35bb87da8f427d1aa4bbd8b7473a3993, c310 model also requires the
same workaround for avoiding the kernel warning.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=59741
commit 11e7064f35bb87da8f427d1aa4bbd8b7473a3993 upstream.
USB audio driver spews an error message when probing Logitech HD
webcam c270:
ALSA mixer.c:1300 usb_audio: Warning! Unlikely big volume range (=6144), cval->res is probably wrong.
ALSA mixer.c:1304 usb_audio: [5] FU [Mic Capture Volume] ch = 1, val = 1536/7680/1
Obviously the device needs a fixed volume resolution (cval->res = 384)
like other Logitech devices.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=821735
Reported-and-tested-by: Cristian RodrÃguez <crrodriguez@opensuse.org>
commit 8eafc0a161123d90617c9ca2eddfe87b382b1b89 upstream.
... instead of applying to all interfaces.
Reference: http://forums.gentoo.org/viewtopic-p-6886404.html
commit a0c6d309c6df14655f9962f666d1da96318b0b7c upstream.
Commit 927c9423dd5f2d1c0b93d5e694ab84b4a5559713 (ALSA: usb-audio: add
Edirol UM-3G support) used a wrong quirk type, which would make the
driver refuse to attach with the error message "MIDIStreaming interface
descriptor not found".
commit 2195b063f6609e4c6268f291683902f25eaf9aa6 upstream.
The interrupt handler azx_interrupt will call azx_update_rirb,
which may call snd_hda_queue_unsol_event, snd_hda_queue_unsol_event
will dereference chip->bus pointer.
The problem is we alloc chip->bus in azx_codec_create
which will be called after we enable IRQ and enable unsolicited
event in azx_probe.
This will cause Oops due dereference NULL pointer. I meet it, good luck:)
[Rearranged the NULL check before the tracepoint and added another
NULL check of bus->workq -- tiwai]
Signed-off-by: Wang YanQing <udknight@gmail.com>
commit 4495e46fe18f198366961bb2b324a694ef8a9b44 upstream.
The missing break here means that we always return early and the
function is a no-op.
commit 98682063549bedd6e2d2b6b7222f150c6fbce68c upstream.
The hardware revision of the codec is based at 0x40. Subtract that
before convering to ASCII. The same as it is done for 98095.
commit 60af3d037eb8c670dcce31401501d1271e7c5d95 upstream.
We've got strange errors in get_ctl_value() in mixer.c during
probing, e.g. on Hercules RMX2 DJ Controller:
ALSA mixer.c:352 cannot get ctl value: req = 0x83, wValue = 0x201, wIndex = 0xa00, type = 4
ALSA mixer.c:352 cannot get ctl value: req = 0x83, wValue = 0x200, wIndex = 0xa00, type = 4
It turned out that the culprit is autopm: snd_usb_autoresume() returns
-ENODEV when called during card->probing = 1.
Since the call itself during card->probing = 1 is valid, let's fix the
return value of snd_usb_autoresume() as success.
Reported-and-tested-by: Daniel Schürmann <daschuer@mixxx.org>
commit cbc200bca4b51a8e2406d4b654d978f8503d430b upstream.
Commit 88a8516a2128 (ALSA: usbaudio: implement USB autosuspend)
introduced autopm for all USB audio/MIDI devices. However, many MIDI
devices, such as synthesizers, do not merely transmit MIDI messages but
use their MIDI inputs to control other functions. With autopm, these
devices would get powered down as soon as the last MIDI port device is
closed on the host.
Even some plain MIDI interfaces could get broken: they automatically
send Active Sensing messages while powered up, but as soon as these
messages cease, the receiving device would interpret this as an
accidental disconnection.
Commit f5f165418cab (ALSA: usb-audio: Fix missing autopm for MIDI input)
introduced another regression: some devices (e.g. the Roland GAIA SH-01)
are self-powered but do a reset whenever the USB interface's power state
changes.
To work around all this, just disable autopm for all USB MIDI devices.
Reported-by: Laurens Holst
commit ebfc594c02148b6a85c2f178cf167a44a3c3ce10 upstream.
The USB_DT_CS_ENDPOINT class-specific endpoint descriptor is usually
stuffed directly after the standard USB endpoint descriptor, and this is
where the driver currently expects it to be.
There are, however, devices in the wild that have it the other way
around in their descriptor sets, so the USB_DT_CS_ENDPOINT comes
*before* the standard enpoint. Devices known to implement it that way
are "Sennheiser BTD-500" and Plantronics USB headsets.
When the driver can't find the USB_DT_CS_ENDPOINT, it won't be able to
change sample rates, as the bitmask for the validity of this command is
storen in bmAttributes of that descriptor.
Fix this by searching the entire interface instead of just the extra
bytes of the first endpoint, in case the latter fails.
Reported-and-tested-by: Torstein Hegge <hegge@resisty.net>
Reported-and-tested-by: Yves G <alsa-user@vivigatt.com>
commit 0fe09a45c4848b5b5607b968d959fdc1821c161d upstream.
This is my example conversion of a few existing mmap users. The pcm
mmap case is one of the more straightforward ones.
Acked-by: Takashi Iwai <tiwai@suse.de>
commit f1ca493b0b5e8f42d3b2dc8877860db2983f47b6 upstream.
The Charge Pump needs the DSP clock to work properly, without it the
bypass to HP/LINEOUT is not working properly. This requirement is not
mentioned in the datasheet but has been confirmed by Mark Brown from
Wolfson.
Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de>
commit 889d66848b12d891248b03abcb2a42047f8e172a upstream.
The usb_control_msg() function expects __u16 types and performs
the endianness conversions by itself.
However, in three places, a conversion is performed before it is
handed over to usb_control_msg(), which leads to a double conversion
(= no conversion):
* snd_usb_nativeinstruments_boot_quirk()
* snd_nativeinstruments_control_get()
* snd_nativeinstruments_control_put()
Caught by sparse:
sound/usb/mixer_quirks.c:512:38: warning: incorrect type in argument 6 (different base types)
sound/usb/mixer_quirks.c:512:38: expected unsigned short [unsigned] [usertype] index
sound/usb/mixer_quirks.c:512:38: got restricted __le16 [usertype] <noident>
sound/usb/mixer_quirks.c:543:35: warning: incorrect type in argument 5 (different base types)
sound/usb/mixer_quirks.c:543:35: expected unsigned short [unsigned] [usertype] value
sound/usb/mixer_quirks.c:543:35: got restricted __le16 [usertype] <noident>
sound/usb/mixer_quirks.c:543:56: warning: incorrect type in argument 6 (different base types)
sound/usb/mixer_quirks.c:543:56: expected unsigned short [unsigned] [usertype] index
sound/usb/mixer_quirks.c:543:56: got restricted __le16 [usertype] <noident>
sound/usb/quirks.c:502:35: warning: incorrect type in argument 5 (different base types)
sound/usb/quirks.c:502:35: expected unsigned short [unsigned] [usertype] value
sound/usb/quirks.c:502:35: got restricted __le16 [usertype] <noident>
Acked-by: Daniel Mack <zonque@gmail.com>
commit aeb3a97222832e5457c4b72d72235098ce4bfe8d upstream.
Rename "Digitial In" to "Digital In". This function is only used for
proc output, so should not cause any problems to change.
commit 1d87caa69c04008e09f5ff47b5e6acb6116febc7 upstream.
* Added the device ID to the modalias list and assinged ALC662 patches
for it
* Added 4 port support for the device ID 0671 in alc662_parse_auto_config
Signed-off-by: Rainer Koenig <Rainer.Koenig@ts.fujitsu.com>
commit 2ef5692efad330b67a234e2c49edad38538751e7 upstream.
In function snd_hdmi_get_eld(), the variable 'ret' should be initialized to 0.
Otherwise it will be returned uninitialized as non-zero after ELD info is got
successfully. Thus hdmi_present_sense() will always assume ELD info is invalid
by mistake, and /proc file system cannot show the proper ELD info.
Signed-off-by: Mengdong Lin <mengdong.lin@intel.com>
Acked-by: David Henningsson <david.henningsson@canonical.com>
commit 417a1178f1bf3cdc606376b3ded3a22489fbb3eb upstream.
The dma-sh7760 currently fails with the following compile error:
sound/soc/sh/dma-sh7760.c:346:2: error: unknown field 'pcm_ops' specified in initializer
sound/soc/sh/dma-sh7760.c:346:2: warning: initialization from incompatible pointer type
sound/soc/sh/dma-sh7760.c:347:2: error: unknown field 'pcm_new' specified in initializer
sound/soc/sh/dma-sh7760.c:347:2: warning: initialization makes integer from pointer without a cast
sound/soc/sh/dma-sh7760.c:348:2: error: unknown field 'pcm_free' specified in initializer
sound/soc/sh/dma-sh7760.c:348:2: warning: initialization from incompatible pointer type
sound/soc/sh/dma-sh7760.c: In function 'sh7760_soc_platform_probe':
sound/soc/sh/dma-sh7760.c:353:2: warning: passing argument 2 of 'snd_soc_register_platform' from incompatible pointer type
include/sound/soc.h:368:5: note: expected 'struct snd_soc_platform_driver *' but argument is of type 'struct snd_soc_platform *'
This is due the misnaming of the snd_soc_platform_driver type name and 'ops'
field. The issue was introduced in commit f0fba2a("ASoC: multi-component - ASoC
Multi-Component Support").
commit 83ea5d18d74f032a760fecde78c0210f66f7f70c upstream.
Creation of individual mixer controls may fail, but that shouldn't cause
the entire mixer creation to fail. Even worse, if the mixer creation
fails, that will error out the entire device probing.
All the functions called by parse_audio_unit() should return -EINVAL if
they find descriptors that are unsupported or believed to be malformed,
so we can safely handle this error code as a non-fatal condition in
snd_usb_mixer_controls().
That fixes a long standing bug which is commonly worked around by
adding quirks which make the driver ignore entire interfaces. Some of
them might now be unnecessary.
Reported-and-tested-by: Rodolfo Thomazelli <pe.soberbo@gmail.com>
commit 4d7b86c98e445b075c2c4c3757eb6d3d6efbe72e upstream.
In check_input_term() and parse_audio_feature_unit(), propagate the
error value that has been returned by a failing function instead of
-EINVAL. That helps cleaning up the error pathes in the mixer.
