path: root/sound
2012-08-21ALSA: snd-als100: fix suspend/resumeOndrej Zary
snd_card_als100_probe() does not set pcm field in struct snd_sb. As a result, PCM is not suspended and applications don't know that they need to resume the playback. Tested with Labway A381-F20 card (ALS120). Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-20ALSA: hda - Fix leftover codec->power_transitionTakashi Iwai
When the codec turn-on operation is canceled by the immediate power-on, the driver left the power_transition flag as is. This caused the persistent avoidance of power-save behavior. Cc: <stable@vger.kernel.org> [v3.5+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-20Merge tag 'asoc-3.6' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Additional updates for 3.6 A batch more bugfixes, all driver-specific and fairly small and unremarkable in a global context. The biggest batch are for the newly added Arizona drivers.
2012-08-20Merge branch 'topic/ca0132-fix' into for-linusTakashi Iwai
This is a series of fixes for CA0132, especially the missing SPDIF I/O and the mixer build errors.
2012-08-20ALSA: hda - don't create dysfunctional mixer controls for ca0132David Henningsson
It's possible that these amps are settable somehow, e g through secret codec verbs, but for now, don't create the controls (as they won't be working anyway, and cause errors in amixer). Cc: stable@kernel.org BugLink: https://bugs.launchpad.net/bugs/1038651 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-20ALSA: sound/ppc/snd_ps3.c: fix error return codeJulia Lawall
Initialize ret before returning on failure, as done elsewhere in the function. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> ( if@p1 (\(ret < 0\|ret != 0\)) { ... return ret; } | ret@p1 = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-20ALSA: sound/pci/rme9652/hdspm.c: fix error return codeJulia Lawall
Convert a nonnegative error return code to a negative one, as returned elsewhere in the function. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> ( if@p1 (\(ret < 0\|ret != 0\)) { ... return ret; } | ret@p1 = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-20ALSA: sound/pci/sis7019.c: fix error return codeJulia Lawall
Initialize rc before returning on failure, as done elsewhere in the function. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> ( if@p1 (\(ret < 0\|ret != 0\)) { ... return ret; } | ret@p1 = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-20ALSA: sound/pci/ctxfi/ctatc.c: fix error return codeJulia Lawall
Initialize err before returning on failure, as done elsewhere in the function. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> ( if@p1 (\(ret < 0\|ret != 0\)) { ... return ret; } | ret@p1 = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-20ALSA: sound/atmel/ac97c.c: fix error return codeJulia Lawall
In the first case, the second test of whether retval is negative is redundant. It is dropped and the previous and subsequent tests are combined. In the second case, add an initialization of retval on failure of ioremap. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> ( if@p1 (\(ret < 0\|ret != 0\)) { ... return ret; } | ret@p1 = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-20ALSA: sound/atmel/abdac.c: fix error return codeJulia Lawall
Initialize retval before returning from a failed call to ioremap. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> ( if@p1 (\(ret < 0\|ret != 0\)) { ... return ret; } | ret@p1 = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-20sound: oss/sb_audio: prevent divide by zero bugDan Carpenter
Speed comes from get_user() in audio_ioctl(). We use it to set the "s" variable before clamping it to valid values so it could lead to a divide by zero bug. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-17ASoC: wm9712: Fix inverted capture volumeMark Brown
The capture volume increases with the register value so it shouldn't be flagged as inverted. Reported-by: Christoph Fritz <chf.fritz@googlemail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-08-17ASoC: wm9712: Fix microphone source selectionMark Brown
Currently the microphone input source is not selectable as while there is a DAPM widget it's not connected to anything so it won't be properly instantiated. Add something more correct for the input structure to get things going, even though it's not hooked into the rest of the routing map and so won't actually achieve anything except allowing the relevant register bits to be written. Reported-by: Christop Fritz <chf.fritz@googlemail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2012-08-17ASoC: wm5102: Remove DRC2Mark Brown
It will be removed from future device revisions. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-08-16ALSA: hda - Don't send invalid volume knob command on IDT 92hd75bxxDavid Henningsson
Instead of blindly initializing a volume knob widget, first check that there actually is a volume knob widget. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-16ALSA: usb-audio: Fix scheduling-while-atomic bug in PCM capture streamTakashi Iwai
A PCM capture stream on usb-audio causes a scheduling-while-atomic BUG, as reported in the bugzilla entry below. It's because snd_usb_endpoint_start() is called at first at trigger START for a capture stream, and this function contains the left-over EP deactivation codes. The problem doesn't happen for a playback stream because the function is called at PCM prepare time, which can sleep. This patch fixes the BUG by moving the EP deactivation code into the PCM prepare callback. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=46011 Cc: <stable@vger.kernel.org> [v3.5+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-14ALSA: lx6464es: Add a missing error checkTakashi Iwai
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=44541 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-14ALSA: hda - Fix 'Beep Playback Switch' with no underlying mute switchDavid Henningsson
Some Conexant devices (e g CX20590) have no mute capability on their Beep widgets. This patch makes sure we don't try setting mutes on those widgets. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-13ASoC: jack: Always notify full jack statusMark Brown
Don't just notify for the bits we've updated, notify the full state of the jack otherwise users might get confused by misleading reports. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-08-13ASoC: wm5110: Add missing input PGA routesMark Brown
2012-08-13ASoC: wm5102: Add missing input PGA routesMark Brown
2012-08-13ALSA: hda - fix Copyright debug messageWang Xingchao
As spec said, 1 indicates no copyright is asserted. Signed-off-by: Wang Xingchao <xingchao.wang@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-10ASoC: Samsung: Fix build errorSachin Kamat
Fixes the following build error: In file included from arch/arm/mach-exynos/include/mach/dma.h:24:0, from arch/arm/plat-samsung/include/plat/dma-ops.h:17, from arch/arm/plat-samsung/include/plat/dma.h:128, from sound/soc/samsung/pcm.c:23: arch/arm/plat-samsung/include/plat/dma-pl330.h:106:8: error: redefinition of ‘struct s3c2410_dma_client’ arch/arm/plat-samsung/include/plat/dma.h:40:8: note: originally defined here make[3]: *** [sound/soc/samsung/pcm.o] Error 1 Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Sachin Kamat <sachin.kamat@samsung.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-08-10ALSA : hda - bug fix on checking the supported power states of a codecMengdong Lin
The return value of snd_hda_param_read() is -1 for an error, otherwise it's the supported power states of a codec. The supported power states is a 32-bit value. Bit 31 will be set to 1 if the codec supports EPSS, thus making "sup" negative. And the bit 28:5 is reserved as "0". So a negative value other than -1 shall be further checked. Please refer to High-Definition spec 7.3.4.12 "Supported Power States", thanks! Signed-off-by: Mengdong Lin <mengdong.lin@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-10ALSA: hda - Fix panned "Beep Playback Switch"David Henningsson
When "Beep Playback Switch" had a different value on left and right channels (such as muting left but not right, or vice versa), this could result in the right channel being ignored. This patch enables beep to be sounding from right channel only, and also give correct result back to userspace (e g amixer). Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-10ALSA: cs46xx - signedness bug in snd_cs46xx_codec_read()Dan Carpenter
This function returns its own error codes instead of normal negative error codes. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-09ASoC: core: Upgrade the severity of probe deferral errors to dev_err()Mark Brown
In the past when ASoC had a custom probe deferral mechanism people complained about the logspam it generated and didn't want to know about the fact that we were doing probe deferral so all the error messages for it were at dev_dbg(), making diagnostics hard. Now that we have probe deferral as an accepted thing and it's generating log messages anyway there's no need to worry about this so upgrade the severity of all the probe deferral sources to dev_err() so that they are displayed by default. Also add one for missing aux_devs since there wasn't one. Reported-by: Russell King <linux@arm.linux.org.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-08-09ALSA: hda_intel: Add Device IDs for Intel Lynx Point-LP PCHJames Ralston
This patch adds the Intel HD Audio Device IDs for the Intel Lynx Point-LP PCH Signed-off-by: James Ralston <james.d.ralston@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-09ALSA: platform: Check CONFIG_PM_SLEEP instead of CONFIG_PMTakashi Iwai
When CONFIG_PM is set but CONFIG_PM_SLEEP is unset, SIMPLE_DEV_PM_OPS() ignores the given functions, and this leads to compile warnings. For avoiding this, simply check CONFIG_PM_SLEEP instead of CONFIG_PM. Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-09ASoC: wm8994: Add missing dapm routes for WM8958 rev AChris Rattray
Signed-off-by: Chris Rattray <crattray@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-08-09ASoC: wm8962: Don't duplicate bias level management in resumeMark Brown
The core will bring the bias level up for us since we use idle_bias_off, duplicating this may be harmful. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-08-09ASoC: bfin: fix memory leak in sport3 controller driverScott Jiang
Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-08-09ASoC: Davinci: McASP: Flush the FIFO before enablingVaibhav Bedia
FIFO should be flushed before it is enabled for the first time. This fixes the I/O errors reported by the ASoC core on a fresh boot Signed-off-by: Vaibhav Bedia <vaibhav.bedia@ti.com> Signed-off-by: Hebbar, Gururaja <gururaja.hebbar@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-08-09ALSA: hda - Fix pop noise in headphones on S3 for Asus X55A, X55VDavid Henningsson
To turn off pin control for the pin was tested, and helped against this issue. BugLink: https://bugs.launchpad.net/bugs/1034779 Tested-by: Chih-Hsyuan Ho <chih.ho@canonical.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-08ALSA: hda - Add missing SPDIF I/O setup for CA0132Takashi Iwai
CA0132 driver had some codes to handle the S/PDIF I/O, but the actual setups of pins and converters were missing. Now the pins are added. Also, fixed a few points triggering invalid codec verbs and mixer elements since the digital I/O audio widgets on CA0132 have no amp. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-08ALSA: hda - Use the standard PCM ops for CA0132Takashi Iwai
Now with the workaround using codec->pcm_format_first flag, we can clean up the home-baked codes in patch_ca0132.c. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-08ALSA: hda - Fix superfluous "-in" suffix from CA0132 capture itemsTakashi Iwai
2012-08-08ALSA: hda - Add codec->pcm_format_first flagTakashi Iwai
Introduced a new flag to set up the PCM stream format at first before the stream_id and channel tag. Some codecs (e.g. CA0132) seem preferring this over stream_id -> format order. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-08ASoC: imx-ssi: Remove mono supportFabio Estevam
Playing a mono track results in incorrect playback rate, ie, the audio is played at a faster rate. Remove mono support in the driver by setting 'channes_min' to dual-channel and this allows mono tracks to be played correctly. Reported-by: Gaëtan Carlier <gcembed@gmail.com> Tested-by: Gaëtan Carlier <gcembed@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-08-08ASoC: mxs: Fix the name of the SoC familyFabio Estevam
SND_SOC_MXS_SGTL5000 is used on MXS boards, so fix the SoC family name. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-08-08ALSA: hda - Fix double quirk for Quanta FL1 / Lenovo IdeapadDavid Henningsson
The same ID is twice in the quirk table, so the second one is not used. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Cc: <stable@vger.kernel.org> [v3.2+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-07ALSA: hda - Fix ugly debug prints with CONFIG_SND_VERBOSE_PRINTK=yTakashi Iwai
When CONFIG_SND_VERBOSE_PRINTK=y is set, the debug print in hda_auto_parser.c looks really ugly like: ALSA sound/pci/hda/hda_auto_parser.c:331 mono: mono_out=0x0 ALSA sound/pci/hda/hda_auto_parser.c:334 dig-out=0x12/0x0 ALSA sound/pci/hda/hda_auto_parser.c:335 inputs: ALSA sound/pci/hda/hda_auto_parser.c:339 Mic=0x11ALSA sound/pci/hda/hda_auto_parser.c:339 Line=0x10 ALSA sound/pci/hda/hda_auto_parser.c:341 ALSA sound/pci/hda/hda_auto_parser.c:343 dig-in=0x13 Better to put one item at each line. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-07ASoC: omap-mcbsp: Fix 6pin mux configurationPeter Ujfalusi
The check for the mux_signal callback was wrong which prevents us to configure the 6pin port's FSR/CLKR signal mux. Reported-by: CF Adad <cfadad@rocketmail.com> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org (3.4+)
2012-08-07ALSA: hda - remove redundant auto quirks for conexant 506xDavid Henningsson
Now that the auto model is the default, these quirks are redundant and can be removed. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-07ALSA: hda - remove quirk for Dell Vostro 1015David Henningsson
This computer is confirmed working with model=auto on kernel 3.2. Also, parsing fails with hda-emu with the current model. Cc: stable@kernel.org (3.2+) Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-07ALSA: hda - add dock support for Thinkpad X230Felix Kaechele
As with the ThinkPad Models X230 Tablet and T530 the X230 needs a qurik to correctly set up the pins for the dock port. Signed-off-by: Felix Kaechele <felix@fetzig.org> Cc: <stable@vger.kernel.org> [v3.2+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-06ALSA: hda - Fix regression of HDMI codec probingTakashi Iwai
The commit c4bfe94a causes a regression on some codecs at probing. Since this was just a workaround to shut up a kernel warning, it'd be better to revert and fix properly. So we ended up with re-adding the cleanup callback. Tested-and-reported-by: Matt Horan <matt@matthoran.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-06ALSA: hda - add dock support for Thinkpad T430sPhilipp A. Mohrenweiser
Add a model/fixup string "lenovo-dock", for Thinkpad T430s, to allow sound in docking station. Tested on Lenovo T430s with ThinkPad Mini Dock Plus Series 3 Cc: stable@kernel.org Signed-off-by: Philipp A. Mohrenweiser <phiamo@googlemail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-03Merge tag 'asoc-3.6' of ↵Mark Brown
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-3.6 ASoC: Additional updates for 3.6 A few updates for issues discovered during the merge window, the main one being the fix for the issues with defaulting to use of regmap without properly checking if there was I/O in place already.
