path: root/sound
2018-02-13ASoC: rsnd: avoid duplicate free_irq()Kuninori Morimoto
commit e0936c3471a8411a5df327641fa3ffe12a2fb07b upstream. commit 1f8754d4daea5f ("ASoC: rsnd: don't call free_irq() on Parent SSI") fixed Parent SSI duplicate free_irq(). But on Renesas Sound, not only Parent SSI but also Multi SSI have same issue. This patch avoid duplicate free_irq() if it was not pure SSI. Fixes: 1f8754d4daea5f ("ASoC: rsnd: don't call free_irq() on Parent SSI") Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: thongsyho <thong.ho.px@rvc.renesas.com> Signed-off-by: Nhan Nguyen <nhan.nguyen.yb@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-13ASoC: rsnd: don't call free_irq() on Parent SSIKuninori Morimoto
commit 1f8754d4daea5f257370a52a30fcb22798c54516 upstream. If SSI uses shared pin, some SSI will be used as parent SSI. Then, normal SSI's remove and Parent SSI's remove (these are same SSI) will be called when unbind or remove timing. In this case, free_irq() will be called twice. This patch solve this issue. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Tested-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Reported-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: thongsyho <thong.ho.px@rvc.renesas.com> Signed-off-by: Nhan Nguyen <nhan.nguyen.yb@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-13ASoC: simple-card: Fix misleading error messageJulian Scheel
commit 7ac45d1635a4cd2e99a4b11903d4a2815ca1b27b upstream. In case cpu could not be found the error message would always refer to /codec/ not being found in DT. Fix this by catching the cpu node not found case explicitly. Signed-off-by: Julian Scheel <julian@jusst.de> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: thongsyho <thong.ho.px@rvc.renesas.com> Signed-off-by: Nhan Nguyen <nhan.nguyen.yb@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-13ASoC: pcm512x: add missing MODULE_DESCRIPTION/AUTHOR/LICENSEJesse Chan
commit 0cab20cec0b663b7be8e2be5998d5a4113647f86 upstream. This change resolves a new compile-time warning when built as a loadable module: WARNING: modpost: missing MODULE_LICENSE() in sound/soc/codecs/snd-soc-pcm512x-spi.o see include/linux/module.h for more information This adds the license as "GPL v2", which matches the header of the file. MODULE_DESCRIPTION and MODULE_AUTHOR are also added. Signed-off-by: Jesse Chan <jc@linux.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23ALSA: hda - Apply the existing quirk to iMac 14,1Takashi Iwai
commit 031f335cda879450095873003abb03ae8ed3b74a upstream. iMac 14,1 requires the same quirk as iMac 12,2, using GPIO 2 and 3 for headphone and speaker output amps. Add the codec SSID quirk entry (106b:0600) accordingly. BugLink: http://lkml.kernel.org/r/CAEw6Zyteav09VGHRfD5QwsfuWv5a43r0tFBNbfcHXoNrxVz7ew@mail.gmail.com Reported-by: Freaky <freaky2000@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23ALSA: hda - Apply headphone noise quirk for another Dell XPS 13 variantTakashi Iwai
commit e4c9fd10eb21376f44723c40ad12395089251c28 upstream. There is another Dell XPS 13 variant (SSID 1028:082a) that requires the existing fixup for reducing the headphone noise. This patch adds the quirk entry for that. BugLink: http://lkml.kernel.org/r/CAHXyb9ZCZJzVisuBARa+UORcjRERV8yokez=DP1_5O5isTz0ZA@mail.gmail.com Reported-and-tested-by: Francisco G. <frangio.1@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23ALSA: pcm: Remove yet superfluous WARN_ON()Takashi Iwai
commit 23b19b7b50fe1867da8d431eea9cd3e4b6328c2c upstream. muldiv32() contains a snd_BUG_ON() (which is morphed as WARN_ON() with debug option) for checking the case of 0 / 0. This would be helpful if this happens only as a logical error; however, since the hw refine is performed with any data set provided by user, the inconsistent values that can trigger such a condition might be passed easily. Actually, syzbot caught this by passing some zero'ed old hw_params ioctl. So, having snd_BUG_ON() there is simply superfluous and rather harmful to give unnecessary confusions. Let's get rid of it. Reported-by: syzbot+7e6ee55011deeebce15d@syzkaller.appspotmail.com Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23ALSA: seq: Make ioctls race-freeTakashi Iwai
commit b3defb791b26ea0683a93a4f49c77ec45ec96f10 upstream. The ALSA sequencer ioctls have no protection against racy calls while the concurrent operations may lead to interfere with each other. As reported recently, for example, the concurrent calls of setting client pool with a combination of write calls may lead to either the unkillable dead-lock or UAF. As a slightly big hammer solution, this patch introduces the mutex to make each ioctl exclusive. Although this may reduce performance via parallel ioctl calls, usually it's not demanded for sequencer usages, hence it should be negligible. Reported-by: Luo Quan <a4651386@163.com> Reviewed-by: Kees Cook <keescook@chromium.org> Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17ALSA: aloop: Fix racy hw constraints adjustmentTakashi Iwai
commit 898dfe4687f460ba337a01c11549f87269a13fa2 upstream. The aloop driver tries to update the hw constraints of the connected target on the cable of the opened PCM substream. This is done by adding the extra hw constraints rules referring to the substream runtime->hw fields, while the other substream may update the runtime hw of another side on the fly. This is, however, racy and may result in the inconsistent values when both PCM streams perform the prepare concurrently. One of the reason is that it overwrites the other's runtime->hw field; which is not only racy but also broken when it's called before the open of another side finishes. And, since the reference to runtime->hw isn't protected, the concurrent write may give the partial value update and become inconsistent. This patch is an attempt to fix and clean up: - The prepare doesn't change the runtime->hw of other side any longer, but only update the cable->hw that is referred commonly. - The extra rules refer to the loopback_pcm object instead of the runtime->hw. The actual hw is deduced from cable->hw. - The extra rules take the cable_lock to protect against the race. Fixes: b1c73fc8e697 ("ALSA: snd-aloop: Fix hw_params restrictions and checking") Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17ALSA: aloop: Fix inconsistent format due to incomplete ruleTakashi Iwai
commit b088b53e20c7d09b5ab84c5688e609f478e5c417 upstream. The extra hw constraint rule for the formats the aloop driver introduced has a slight flaw, where it doesn't return a positive value when the mask got changed. It came from the fact that it's basically a copy&paste from snd_hw_constraint_mask64(). The original code is supposed to be a single-shot and it modifies the mask bits only once and never after, while what we need for aloop is the dynamic hw rule that limits the mask bits. This difference results in the inconsistent state, as the hw_refine doesn't apply the dependencies fully. The worse and surprisingly result is that it causes a crash in OSS emulation when multiple full-duplex reads/writes are performed concurrently (I leave why it triggers Oops to readers as a homework). For fixing this, replace a few open-codes with the standard snd_mask_*() macros. Reported-by: syzbot+3902b5220e8ca27889ca@syzkaller.appspotmail.com Fixes: b1c73fc8e697 ("ALSA: snd-aloop: Fix hw_params restrictions and checking") Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17ALSA: aloop: Release cable upon open error pathTakashi Iwai
commit 9685347aa0a5c2869058ca6ab79fd8e93084a67f upstream. The aloop runtime object and its assignment in the cable are left even when opening a substream fails. This doesn't mean any memory leak, but it still keeps the invalid pointer that may be referred by the another side of the cable spontaneously, which is a potential Oops cause. Clean up the cable assignment and the empty cable upon the error path properly. Fixes: 597603d615d2 ("ALSA: introduce the snd-aloop module for the PCM loopback") Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17ALSA: pcm: Allow aborting mutex lock at OSS read/write loopsTakashi Iwai
commit 900498a34a3ac9c611e9b425094c8106bdd7dc1c upstream. PCM OSS read/write loops keep taking the mutex lock for the whole read/write, and this might take very long when the exceptionally high amount of data is given. Also, since it invokes with mutex_lock(), the concurrent read/write becomes unbreakable. This patch tries to address these issues by replacing mutex_lock() with mutex_lock_interruptible(), and also splits / re-takes the lock at each read/write period chunk, so that it can switch the context more finely if requested. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17ALSA: pcm: Abort properly at pending signal in OSS read/write loopsTakashi Iwai
commit 29159a4ed7044c52e3e2cf1a9fb55cec4745c60b upstream. The loops for read and write in PCM OSS emulation have no proper check of pending signals, and they keep processing even after user tries to break. This results in a very long delay, often seen as RCU stall when a huge unprocessed bytes remain queued. The bug could be easily triggered by syzkaller. As a simple workaround, this patch adds the proper check of pending signals and aborts the loop appropriately. Reported-by: syzbot+993cb4cfcbbff3947c21@syzkaller.appspotmail.com Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17ALSA: pcm: Add missing error checks in OSS emulation plugin builderTakashi Iwai
commit 6708913750344a900f2e73bfe4a4d6dbbce4fe8d upstream. In the OSS emulation plugin builder where the frame size is parsed in the plugin chain, some places miss the possible errors returned from the plugin src_ or dst_frames callback. This patch papers over such places. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17ALSA: pcm: Remove incorrect snd_BUG_ON() usagesTakashi Iwai
commit fe08f34d066f4404934a509b6806db1a4f700c86 upstream. syzkaller triggered kernel warnings through PCM OSS emulation at closing a stream: WARNING: CPU: 0 PID: 3502 at sound/core/pcm_lib.c:1635 snd_pcm_hw_param_first+0x289/0x690 sound/core/pcm_lib.c:1635 Call Trace: .... snd_pcm_hw_param_near.constprop.27+0x78d/0x9a0 sound/core/oss/pcm_oss.c:457 snd_pcm_oss_change_params+0x17d3/0x3720 sound/core/oss/pcm_oss.c:969 snd_pcm_oss_make_ready+0xaa/0x130 sound/core/oss/pcm_oss.c:1128 snd_pcm_oss_sync+0x257/0x830 sound/core/oss/pcm_oss.c:1638 snd_pcm_oss_release+0x20b/0x280 sound/core/oss/pcm_oss.c:2431 __fput+0x327/0x7e0 fs/file_table.c:210 .... This happens while it tries to open and set up the aloop device concurrently. The warning above (invoked from snd_BUG_ON() macro) is to detect the unexpected logical error where snd_pcm_hw_refine() call shouldn't fail. The theory is true for the case where the hw_params config rules are static. But for an aloop device, the hw_params rule condition does vary dynamically depending on the connected target; when another device is opened and changes the parameters, the device connected in another side is also affected, and it caused the error from snd_pcm_hw_refine(). That is, the simplest "solution" for this is to remove the incorrect assumption of static rules, and treat such an error as a normal error path. As there are a couple of other places using snd_BUG_ON() incorrectly, this patch removes these spurious snd_BUG_ON() calls. Reported-by: syzbot+6f11c7e2a1b91d466432@syzkaller.appspotmail.com Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02ALSA: hda - fix headset mic detection issue on a Dell machineHui Wang
commit 285d5ddcffafa5d5e68c586f4c9eaa8b24a2897d upstream. It has the codec alc256, and add its pin definition to pin quirk table to let it apply ALC255_FIXUP_DELL1_MIC_NO_PRESENCE. Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02ALSA: hda: Drop useless WARN_ON()Takashi Iwai
commit a36c2638380c0a4676647a1f553b70b20d3ebce1 upstream. Since the commit 97cc2ed27e5a ("ALSA: hda - Fix yet another i915 pointer leftover in error path") cleared hdac_acomp pointer, the WARN_ON() non-NULL check in snd_hdac_i915_register_notifier() may give a false-positive warning, as the function gets called no matter whether the component is registered or not. For fixing it, let's get rid of the spurious WARN_ON(). Fixes: 97cc2ed27e5a ("ALSA: hda - Fix yet another i915 pointer leftover in error path") Reported-by: Kouta Okamoto <kouta.okamoto@toshiba.co.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02ASoC: tlv320aic31xx: Fix GPIO1 register definitionAndrew F. Davis
commit 737e0b7b67bdfe24090fab2852044bb283282fc5 upstream. GPIO1 control register is number 51, fix this here. Fixes: bafcbfe429eb ("ASoC: tlv320aic31xx: Make the register values human readable") Signed-off-by: Andrew F. Davis <afd@ti.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02ASoC: twl4030: fix child-node lookupJohan Hovold
commit 15f8c5f2415bfac73f33a14bcd83422bcbfb5298 upstream. Fix child-node lookup during probe, which ended up searching the whole device tree depth-first starting at the parent rather than just matching on its children. To make things worse, the parent codec node was also prematurely freed, while the child node was leaked. Fixes: 2d6d649a2e0f ("ASoC: twl4030: Support for DT booted kernel") Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02ASoC: fsl_ssi: AC'97 ops need regmap, clock and cleaning up on failureMaciej S. Szmigiero
commit 695b78b548d8a26288f041e907ff17758df9e1d5 upstream. AC'97 ops (register read / write) need SSI regmap and clock, so they have to be set after them. We also need to set these ops back to NULL if we fail the probe. Signed-off-by: Maciej S. Szmigiero <mail@maciej.szmigiero.name> Acked-by: Nicolin Chen <nicoleotsuka@gmail.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02ASoC: da7218: fix fix child-node lookupJohan Hovold
commit bc6476d6c1edcb9b97621b5131bd169aa81f27db upstream. Fix child-node lookup during probe, which ended up searching the whole device tree depth-first starting at the parent rather than just matching on its children. To make things worse, the parent codec node was also prematurely freed. Fixes: 4d50934abd22 ("ASoC: da7218: Add da7218 codec driver") Signed-off-by: Johan Hovold <johan@kernel.org> Acked-by: Adam Thomson <Adam.Thomson.Opensource@diasemi.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02ASoC: wm_adsp: Fix validation of firmware and coeff lengthsBen Hutchings
commit 50dd2ea8ef67a1617e0c0658bcbec4b9fb03b936 upstream. The checks for whether another region/block header could be present are subtracting the size from the current offset. Obviously we should instead subtract the offset from the size. The checks for whether the region/block data fit in the file are adding the data size to the current offset and header size, without checking for integer overflow. Rearrange these so that overflow is impossible. Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Acked-by: Charles Keepax <ckeepax@opensource.cirrus.com> Tested-by: Charles Keepax <ckeepax@opensource.cirrus.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-29ALSA: usb-audio: Fix the missing ctl name suffix at parsing SUTakashi Iwai
commit 5a15f289ee87eaf33f13f08a4909ec99d837ec5f upstream. The commit 89b89d121ffc ("ALSA: usb-audio: Add check return value for usb_string()") added the check of the return value from snd_usb_copy_string_desc(), which is correct per se, but it introduced a regression. In the original code, either the "Clock Source", "Playback Source" or "Capture Source" suffix is added after the terminal string, while the commit changed it to add the suffix only when get_term_name() is failing. It ended up with an incorrect ctl name like "PCM" instead of "PCM Capture Source". Also, even the original code has a similar bug: when the ctl name is generated from snd_usb_copy_string_desc() for the given iSelector, it also doesn't put the suffix. This patch addresses these issues: the suffix is added always when no static mapping is found. Also the patch tries to put more comments and cleans up the if/else block for better readability in order to avoid the same pitfall again. Fixes: 89b89d121ffc ("ALSA: usb-audio: Add check return value for usb_string()") Reported-and-tested-by: Mauro Santos <registo.mailling@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-29ALSA: usb-audio: Add native DSD support for Esoteric D-05XJussi Laako
commit 866f7ed7d67936dcdbcddc111c8af878c918fe7c upstream. Adds VID:PID of Esoteric D-05X to the TEAC device id's. Renames the is_teac_50X_dac() function to is_teac_dsd_dac() to cover broader device family from the same corporation sharing the same USB audio implementation. Signed-off-by: Jussi Laako <jussi@sonarnerd.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-29ALSA: rawmidi: Avoid racy info ioctl via ctl deviceTakashi Iwai
commit c1cfd9025cc394fd137a01159d74335c5ac978ce upstream. The rawmidi also allows to obtaining the information via ioctl of ctl API. It means that user can issue an ioctl to the rawmidi device even when it's being removed as long as the control device is present. Although the code has some protection via the global register_mutex, its range is limited to the search of the corresponding rawmidi object, and the mutex is already unlocked at accessing the rawmidi object. This may lead to a use-after-free. For avoiding it, this patch widens the application of register_mutex to the whole snd_rawmidi_info_select() function. We have another mutex per rawmidi object, but this operation isn't very hot path, so it shouldn't matter from the performance POV. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25ASoC: img-parallel-out: Add pm_runtime_get/put to set_fmt callbackEd Blake
[ Upstream commit c70458890ff15d858bd347fa9f563818bcd6e457 ] Add pm_runtime_get_sync and pm_runtime_put calls to set_fmt callback function. This fixes a bus error during boot when CONFIG_SUSPEND is defined when this function gets called while the device is runtime disabled and device registers are accessed while the clock is disabled. Signed-off-by: Ed Blake <ed.blake@sondrel.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25ASoC: STI: Fix reader substream pointer setArnaud Pouliquen
[ Upstream commit 3c9d3f1bc2defd418b5933bbc928096c9c686d3b ] reader->substream is used in IRQ handler for error case but is never set. Set value to pcm substream on DAI startup and clean it on dai shutdown. Signed-off-by: Arnaud Pouliquen <arnaud.pouliquen@st.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25ALSA: hda - add support for docking station for HP 840 G3Jaroslav Kysela
[ Upstream commit cc3a47a248d7791ef0d2c81a35c46769e55e4c6c ] This tested patch adds missing initialization for Line-In/Out PINs for the docking station for HP 840 G3. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25ALSA: hda - add support for docking station for HP 820 G2Jaroslav Kysela
[ Upstream commit 04d5466a976b096364a39a63ac264c1b3a5f8fa1 ] This tested patch adds missing initialization for Line-In/Out PINs for the docking station for HP 820 G2. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20ASoC: rsnd: rsnd_ssi_run_mods() needs to care ssi_parent_modKuninori Morimoto
[ Upstream commit 21781e87881f9c420871b1d1f3f29d4cd7bffb10 ] SSI parent mod might be NULL. ssi_parent_mod() needs to care about it. Otherwise, it uses negative shift. This patch fixes it. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20ASoC: Intel: Skylake: Fix uuid_module memory leak in failure casePankaj Bharadiya
[ Upstream commit f8e066521192c7debe59127d90abbe2773577e25 ] In the loop that adds the uuid_module to the uuid_list list, allocated memory is not properly freed in the error path free uuid_list whenever any of the memory allocation in the loop fails to avoid memory leak. Signed-off-by: Pankaj Bharadiya <pankaj.laxminarayan.bharadiya@intel.com> Signed-off-by: Guneshwor Singh <guneshwor.o.singh@intel.com> Acked-By: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20ASoC: rcar: clear DE bit only in PDMACHCR when it stopsKuninori Morimoto
[ Upstream commit 62a10498afb27370ec6018e9d802b74850fd8d9a ] R-Car datasheet indicates "Clear DE in PDMACHCR" for transfer stop, but current code clears all bits in PDMACHCR. Because of this, DE bit might never been cleared, and it causes CMD overflow. This patch fixes this issue. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Tested-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20ASoC: rsnd: fix sound route path when using SRC6/SRC9Hiroyuki Yokoyama
[ Upstream commit a1c2ff53726907aff5feb37e4cfd45c1ff626431 ] This patch fixes the problem that the missing value of the route path setting table and incorrect values are set in the CMD_ROUTE_SELECT register. Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> [Kuninori: shared data on MIX and non-MIX case] Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14ASoC: rcar: avoid SSI_MODEx settings for SSI8Kuninori Morimoto
[ Upstream commit 4b30eebfc35c67771b5f58d9274d3e321b72d7a8 ] SSI8 is is sharing pin with SSI7, and nothing to do for SSI_MODEx. It is special pin and it needs special settings whole system, but we can't confirm it, because we never have SSI8 available board. This patch fixup SSI_MODEx settings error for SSI8 on connection test, but should be confirmed behavior on real board in the future. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Tested-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14ALSA: usb-audio: Add check return value for usb_string()Jaejoong Kim
commit 89b89d121ffcf8d9546633b98ded9d18b8f75891 upstream. snd_usb_copy_string_desc() returns zero if usb_string() fails. In case of failure, we need to check the snd_usb_copy_string_desc()'s return value and add an exception case Signed-off-by: Jaejoong Kim <climbbb.kim@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14ALSA: usb-audio: Fix out-of-bound errorJaejoong Kim
commit 251552a2b0d454badc8f486e6d79100970c744b0 upstream. The snd_usb_copy_string_desc() retrieves the usb string corresponding to the index number through the usb_string(). The problem is that the usb_string() returns the length of the string (>= 0) when successful, but it can also return a negative value about the error case or status of usb_control_msg(). If iClockSource is '0' as shown below, usb_string() will returns -EINVAL. This will result in '0' being inserted into buf[-22], and the following KASAN out-of-bound error message will be output. AudioControl Interface Descriptor: bLength 8 bDescriptorType 36 bDescriptorSubtype 10 (CLOCK_SOURCE) bClockID 1 bmAttributes 0x07 Internal programmable Clock (synced to SOF) bmControls 0x07 Clock Frequency Control (read/write) Clock Validity Control (read-only) bAssocTerminal 0 iClockSource 0 To fix it, check usb_string()'return value and bail out. ================================================================== BUG: KASAN: stack-out-of-bounds in parse_audio_unit+0x1327/0x1960 [snd_usb_audio] Write of size 1 at addr ffff88007e66735a by task systemd-udevd/18376 CPU: 0 PID: 18376 Comm: systemd-udevd Not tainted 4.13.0+ #3 Hardware name: LG Electronics 15N540-RFLGL/White Tip Mountain, BIOS 15N5 Call Trace: dump_stack+0x63/0x8d print_address_description+0x70/0x290 ? parse_audio_unit+0x1327/0x1960 [snd_usb_audio] kasan_report+0x265/0x350 __asan_store1+0x4a/0x50 parse_audio_unit+0x1327/0x1960 [snd_usb_audio] ? save_stack+0xb5/0xd0 ? save_stack_trace+0x1b/0x20 ? save_stack+0x46/0xd0 ? kasan_kmalloc+0xad/0xe0 ? kmem_cache_alloc_trace+0xff/0x230 ? snd_usb_create_mixer+0xb0/0x4b0 [snd_usb_audio] ? usb_audio_probe+0x4de/0xf40 [snd_usb_audio] ? usb_probe_interface+0x1f5/0x440 ? driver_probe_device+0x3ed/0x660 ? build_feature_ctl+0xb10/0xb10 [snd_usb_audio] ? save_stack_trace+0x1b/0x20 ? init_object+0x69/0xa0 ? snd_usb_find_csint_desc+0xa8/0xf0 [snd_usb_audio] snd_usb_mixer_controls+0x1dc/0x370 [snd_usb_audio] ? build_audio_procunit+0x890/0x890 [snd_usb_audio] ? snd_usb_create_mixer+0xb0/0x4b0 [snd_usb_audio] ? kmem_cache_alloc_trace+0xff/0x230 ? usb_ifnum_to_if+0xbd/0xf0 snd_usb_create_mixer+0x25b/0x4b0 [snd_usb_audio] ? snd_usb_create_stream+0x255/0x2c0 [snd_usb_audio] usb_audio_probe+0x4de/0xf40 [snd_usb_audio] ? snd_usb_autosuspend.part.7+0x30/0x30 [snd_usb_audio] ? __pm_runtime_idle+0x90/0x90 ? kernfs_activate+0xa6/0xc0 ? usb_match_one_id_intf+0xdc/0x130 ? __pm_runtime_set_status+0x2d4/0x450 usb_probe_interface+0x1f5/0x440 Signed-off-by: Jaejoong Kim <climbbb.kim@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14ALSA: seq: Remove spurious WARN_ON() at timer checkTakashi Iwai
commit 43a3542870328601be02fcc9d27b09db467336ef upstream. The use of snd_BUG_ON() in ALSA sequencer timer may lead to a spurious WARN_ON() when a slave timer is deployed as its backend and a corresponding master timer stops meanwhile. The symptom was triggered by syzkaller spontaneously. Since the NULL timer is valid there, rip off snd_BUG_ON(). Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14ALSA: pcm: prevent UAF in snd_pcm_infoRobb Glasser
commit 362bca57f5d78220f8b5907b875961af9436e229 upstream. When the device descriptor is closed, the `substream->runtime` pointer is freed. But another thread may be in the ioctl handler, case SNDRV_CTL_IOCTL_PCM_INFO. This case calls snd_pcm_info_user() which calls snd_pcm_info() which accesses the now freed `substream->runtime`. Note: this fixes CVE-2017-0861 Signed-off-by: Robb Glasser <rglasser@google.com> Signed-off-by: Nick Desaulniers <ndesaulniers@google.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-30ASoC: wm_adsp: Don't overrun firmware file buffer when reading region dataRichard Fitzgerald
[ Upstream commit 1cab2a84f470e15ecc8e5143bfe9398c6e888032 ] Protect against corrupt firmware files by ensuring that the length we get for the data in a region actually lies within the available firmware file data buffer. Signed-off-by: Richard Fitzgerald <rf@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-30ASoC: rsnd: don't double free kctrlColin Ian King
[ Upstream commit 0ea617a298dcdc2251b4e10f83ac3f3e627b66e3 ] On an error, snd_ctl_add already free's kctrl, so calling snd_ctl_free_one to free it again leads to a double free error. Fix this by removing the extraneous snd_ctl_free_one call. Issue found using static analysis with CoverityScan, CID 1372908 Signed-off-by: Colin Ian King <colin.king@canonical.com> Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-30ALSA: hda - Apply ALC269_FIXUP_NO_SHUTUP on HDA_FIXUP_ACT_PROBEGabriele Mazzotta
[ Upstream commit 972aa2c708703c21f14eb958b37e82aae2530e44 ] Setting shutup when the action is HDA_FIXUP_ACT_PRE_PROBE might not have the desired effect since it could be overridden by another more generic shutup function. Prevent this by setting the more specific shutup function on HDA_FIXUP_ACT_PROBE. Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-30ALSA: hda/realtek - Fix ALC700 family no sound issueKailang Yang
commit 2d7fe6185722b0817bb345f62ab06b76a7b26542 upstream. It maybe the typo for ALC700 support patch. To fix the bit value on this patch. Fixes: 6fbae35a3170 ("ALSA: hda/realtek - Add support for new codecs ALC700/ALC701/ALC703") Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-30ALSA: hda: Fix too short HDMI/DP chmap reportingTakashi Iwai
commit c2432466f583cb719b35a41e757da587d9ab1d00 upstream. We got a regression report about the HD-audio HDMI chmap, where some surround channels are reported as UNKNOWN. The git bisection pointed the culprit at the commit 9b3dc8aa3fb1 ("ALSA: hda - Register chmap obj as priv data instead of codec"). The story behind scene is like this: - While moving the code out of the legacy HDA to the HDA common place, the patch modifies the code to obtain the chmap array indirectly in a byte array, and it expands it to kctl value array. - At the latter operation, the size of the array is wrongly passed by sizeof() to the pointer. - It can be 4 on 32bit arch, thus too short for 6+ channels. (And that's the reason why it didn't hit other persons; it's 8 on 64bit arch, thus it's usually enough.) The code was further changed meanwhile, but the problem persisted. Let's fix it by correctly evaluating the array size. Fixes: 9b3dc8aa3fb1 ("ALSA: hda - Register chmap obj as priv data instead of codec") Reported-by: VDR User <user.vdr@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-30ALSA: timer: Remove kernel warning at compat ioctl error pathsTakashi Iwai
commit 3d4e8303f2c747c8540a0a0126d0151514f6468b upstream. Some timer compat ioctls have NULL checks of timer instance with snd_BUG_ON() that bring up WARN_ON() when the debug option is set. Actually the condition can be met in the normal situation and it's confusing and bad to spew kernel warnings with stack trace there. Let's remove snd_BUG_ON() invocation and replace with the simple checks. Also, correct the error code to EBADFD to follow the native ioctl error handling. Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-30ALSA: usb-audio: Add sanity checks in v2 clock parsersTakashi Iwai
commit 0a62d6c966956d77397c32836a5bbfe3af786fc1 upstream. The helper functions to parse and look for the clock source, selector and multiplier unit may return the descriptor with a too short length than required, while there is no sanity check in the caller side. Add some sanity checks in the parsers, at least, to guarantee the given descriptor size, for avoiding the potential crashes. Fixes: 79f920fbff56 ("ALSA: usb-audio: parse clock topology of UAC2 devices") Reported-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-30ALSA: usb-audio: Fix potential out-of-bound access at parsing SUTakashi Iwai
commit f658f17b5e0e339935dca23e77e0f3cad591926b upstream. The usb-audio driver may trigger an out-of-bound access at parsing a malformed selector unit, as it checks the header length only after evaluating bNrInPins field, which can be already above the given length. Fix it by adding the length check beforehand. Fixes: 99fc86450c43 ("ALSA: usb-mixer: parse descriptors with structs") Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-30ALSA: usb-audio: Add sanity checks to FE parserTakashi Iwai
commit d937cd6790a2bef2d07b500487646bd794c039bb upstream. When the usb-audio descriptor contains the malformed feature unit description with a too short length, the driver may access out-of-bounds. Add a sanity check of the header size at the beginning of parse_audio_feature_unit(). Fixes: 23caaf19b11e ("ALSA: usb-mixer: Add support for Audio Class v2.0") Reported-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-30ALSA: pcm: update tstamp only if audio_tstamp changedHenrik Eriksson
commit 20e3f985bb875fea4f86b04eba4b6cc29bfd6b71 upstream. commit 3179f6200188 ("ALSA: core: add .get_time_info") had a side effect of changing the behaviour of the PCM runtime tstamp. Prior to this change tstamp was not updated by snd_pcm_update_hw_ptr0() unless the hw_ptr had moved, after this change tstamp was always updated. For an application using alsa-lib, doing snd_pcm_readi() followed by snd_pcm_status() to estimate the age of the read samples by subtracting status->avail * [sample rate] from status->tstamp this change degraded the accuracy of the estimate on devices where the pcm hw does not provide a granular hw_ptr, e.g., devices using soc-generic-dmaengine-pcm.c and a dma-engine with residue_granularity DMA_RESIDUE_GRANULARITY_DESCRIPTOR. The accuracy of the estimate depended on the latency between the PCM hw completing a period and the driver called snd_pcm_period_elapsed() to notify ALSA core, typically determined by interrupt handling latency. After the change the accuracy of the estimate depended on the latency between the PCM hw completing a period and the application calling snd_pcm_status(), determined by the scheduling of the application process. The maximum error of the estimate is one period length in both cases, but the error average and variance is smaller when it depends on interrupt latency. Instead of always updating tstamp, update it only if audio_tstamp changed. Fixes: 3179f6200188 ("ALSA: core: add .get_time_info") Suggested-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Signed-off-by: Henrik Eriksson <henrik.eriksson@axis.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-30ALSA: hda: Add Raven PCI IDVijendar Mukunda
commit 9ceace3c9c18c67676e75141032a65a8e01f9a7a upstream. This commit adds PCI ID for Raven platform Signed-off-by: Vijendar Mukunda <Vijendar.Mukunda@amd.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-21ALSA: hda/realtek - Add new codec ID ALC299Kailang Yang
[ Upstream commit 28f1f9b26cee161ddd3985b3eb78e3ffada08dda ] ALC299 was similar as ALC225. Add headset support for ALC299. ALC3271 was for Dell rename. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
