path: root/tools/build
2016-10-05tools build: Add feature detection for g++Wang Nan
Check if g++ is available. The result will be used by builtin clang and LLVM support. Since LLVM requires C++11, this feature detector checks std::move(). Signed-off-by: Wang Nan <wangnan0@huawei.com> Cc: Alexei Starovoitov <ast@fb.com> Cc: He Kuang <hekuang@huawei.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1474874832-134786-3-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-10-05tools build: Support compiling C++ source fileWang Nan
Add new rule to compile .cpp file to .o use g++. C++ support is required for built-in clang and LLVM support. Linker side support will be introduced by following commits. Signed-off-by: Wang Nan <wangnan0@huawei.com> Cc: Alexei Starovoitov <ast@fb.com> Cc: He Kuang <hekuang@huawei.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1474874832-134786-2-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-10-03tools build: Make fixdep a hostprogJiri Olsa
It is used in the build process, so stop suppressing its build in tools cross builds. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Madhavan Srinivasan <maddy@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: linuxppc-dev@lists.ozlabs.org Link: http://lkml.kernel.org/r/20160927141846.GA6589@krava [ Use HOSTCC on the $(OUTPUT)fixdep target, it was using the x-compiler to link fixdep-in.o, that was correctly built with HOSTCC and thus failing ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-10-03tools build: Add support for host programs formatJiri Olsa
In some cases, like for fixdep and shortly for jevents, we need to build a tool to run on the host that will be used in building a tool, such as perf, that is being cross compiled, so do like the kernel and provide HOSTCC, HOSTLD and HOSTAR to do that. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Requested-by: Andi Kleen <andi@firstfloor.org> Requested-and-Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Madhavan Srinivasan <maddy@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: linuxppc-dev@lists.ozlabs.org Link: http://lkml.kernel.org/r/20160927141846.GA6589@krava Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-13perf build: Add sdt feature detectionMasami Hiramatsu
This checks whether sys/sdt.h is available or not, which is required for DTRACE_PROBE(). We can disable this feature by passing NO_SDT=1 when building. This flag will be used for SDT test case and further SDT events in perftools. Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> Cc: Brendan Gregg <brendan.d.gregg@gmail.com> Cc: Hemant Kumar <hemant@linux.vnet.ibm.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/146831795615.17065.17513820540591053933.stgit@devbox Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-12perf tools: Add feature detection for gelf_getnote()Arnaldo Carvalho de Melo
That is not present on some libelf implementations, such as the one used in Alpine Linux: libelf-0.8.13. This ends up disabling the SDT code, that relies on this function. One alternative would be to provide an weak fallback implementation or the open coded variant used by the buildid sysfs notes reading code. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> Cc: Brendan Gregg <brendan.d.gregg@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Hemant Kumar <hemant@linux.vnet.ibm.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-82lh22ybedy9b9lych8xj12g@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-04perf build: Add feature detection for libelf's elf_getshdrstrndx()Arnaldo Carvalho de Melo
That appeared after 0.140, and will be used in the SDT code, so, to avoid bisection break on older systems, add a feature detection and provide a stub with a pr_debug() to keep it building. Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> Cc: Brendan Gregg <brendan.d.gregg@gmail.com> Cc: Hemant Kumar <hemant@linux.vnet.ibm.com> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-80y0eldgweorqnwha9rvfxjr@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-05-26Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: - new option CONFIG_TRIM_UNUSED_KSYMS which does a two-pass build and unexports symbols which are not used in the current config [Nicolas Pitre] - several kbuild rule cleanups [Masahiro Yamada] - warning option adjustments for gcov etc [Arnd Bergmann] - a few more small fixes * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: (31 commits) kbuild: move -Wunused-const-variable to W=1 warning level kbuild: fix if_change and friends to consider argument order kbuild: fix adjust_autoksyms.sh for modules that need only one symbol kbuild: fix ksym_dep_filter when multiple EXPORT_SYMBOL() on the same line gcov: disable -Wmaybe-uninitialized warning gcov: disable tree-loop-im to reduce stack usage gcov: disable for COMPILE_TEST Kbuild: disable 'maybe-uninitialized' warning for CONFIG_PROFILE_ALL_BRANCHES Kbuild: change CC_OPTIMIZE_FOR_SIZE definition kbuild: forbid kernel directory to contain spaces and colons kbuild: adjust ksym_dep_filter for some cmd_* renames kbuild: Fix dependencies for final vmlinux link kbuild: better abstract vmlinux sequential prerequisites kbuild: fix call to adjust_autoksyms.sh when output directory specified kbuild: Get rid of KBUILD_STR kbuild: rename cmd_as_s_S to cmd_cpp_s_S kbuild: rename cmd_cc_i_c to cmd_cpp_i_c kbuild: drop redundant "PHONY += FORCE" kbuild: delete unnecessary "@:" kbuild: mark help target as PHONY ...
2016-05-11perf build: Add build-test for debug-frame on arm/arm64He Kuang
Debug-frame for remote platforms is not related to the host platform, so we should test each platform separately. Signed-off-by: He Kuang <hekuang@huawei.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ekaterina Tumanova <tumanova@linux.vnet.ibm.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Kan Liang <kan.liang@intel.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/1462866037-30382-5-git-send-email-hekuang@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-05-11perf build: Add build-test for libunwind cross-platforms supportHe Kuang
Currently only test for local libunwind. We should check all supported platforms so we can use them to parse perf.data with callchain info on different machines. Signed-off-by: He Kuang <hekuang@huawei.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ekaterina Tumanova <tumanova@linux.vnet.ibm.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Kan Liang <kan.liang@intel.com> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/1462866037-30382-4-git-send-email-hekuang@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-04-28bpf tools: Fix syscall argumentFlorian Fainelli
Coverity flagged this under CID 1354884 as a sizeof mismatch, it turns out that the argument "attr" passed to syscall should have been a pointer to attr in the first place. Reported-by: coverity (CID 1354884) Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Acked-by: Wang Nan <wangnan0@huawei.com> Cc: Jiri Olsa <jolsa@kernel.org> Fixes: 8f9e05fb298f ("perf tools: Fix PowerPC native building") Link: http://lkml.kernel.org/r/1461551694-5512-3-git-send-email-f.fainelli@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-04-28bpf tools: Remove expression with no effectFlorian Fainelli
Assigning "attr" to "attr" does not have any effect, but was caught by Coverity, so let's remove this. Reported-by: coverity (CID 1354720) Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Tested-by: Wang Nan <wangnan0@huawei.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Cc: Jiri Olsa <jolsa@kernel.org> Fixes: 1b76c13e4b36 ("bpf tools: Introduce 'bpf' library and add bpf feature check") Link: http://lkml.kernel.org/r/1461551694-5512-2-git-send-email-f.fainelli@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-04-20kbuild: rename cmd_cc_i_c to cmd_cpp_i_cMasahiro Yamada
This command just preprocesses .c files into .i files, so cmd_cpp_i_c seems more suitable. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.com>
2016-04-06perf probe: Check if dwarf_getlocations() is availableArnaldo Carvalho de Melo
If not, tell the user that: config/Makefile:273: Old libdw.h, finding variables at given 'perf probe' point will not work, install elfutils-devel/libdw-dev >= 0.157 And return -ENOTSUPP in die_get_var_range(), failing features that need it, like the one pointed out above. This fixes the build on older systems, such as Ubuntu 12.04.5. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Vinson Lee <vlee@freedesktop.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-9l7luqkq4gfnx7vrklkq4obs@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-03-03tools build: Use .s extension for preprocessed assembler codeMasahiro Yamada
The "man gcc" says .i extension represents the file is C source code that should not be preprocessed. Here, .s should be used. For clarification, .c ---(preprocess)---> .i .S ---(preprocess)---> .s Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Aaro Koskinen <aaro.koskinen@nokia.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Lukas Wunner <lukas@wunner.de> Link: http://lkml.kernel.org/r/1454263140-19670-1-git-send-email-yamada.masahiro@socionext.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-02-05perf build: Add libcrypto feature detectionStephane Eranian
Will be used to generate build-ids in the jitdump code. Signed-off-by: Stephane Eranian <eranian@google.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Carl Love <cel@us.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: John McCutchan <johnmccutchan@google.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sonny Rao <sonnyrao@chromium.org> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1448874143-7269-3-git-send-email-eranian@google.com [ tools/perf/Makefile.perf comment about NO_LIBCRYPTO and added it to tests/make ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-01-28perf build: Fix feature-dump checks, we need to test all featuresJiri Olsa
I see problem with test-all case speedup, because it does not comprise checks for 32bits compilations, fix it. The problem could be noticed by calling: make -C tools/perf feature-dump That would end up misdetecting the feature-compile-x32, that, building using 'gcc -mx32' needs stub headers not present in a fedora 23 devel machine and thus fail to compile, but ended up appearing as detected, i.e. present in tools/perf/FEATURE-DUMP as 'feature-compile-x32=1'. With this fix it correctly appears as 'feature-compile-x32=0' and if we uninstall the libc devel files for 32 bits (glibc-devel.i686), then the relevant variable is flipped from 'feature-compile-32=1' to 'feature-compile-32=0'. The same things happened for bionic and libbabeltrace, that were misdetected because the are no tested in test-all.c Reported-and-Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-u0sjaddf1r9m8icpd98ry7fz@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-01-27tools build: Check basic headers for test-compile feature checkerWang Nan
An i386 binary can be linked correctly even without correct headers. Which causes problem. For exmaple: $ mv /tmp/oxygen_root/usr/include/gnu/stubs-32.h{,.bak} $ make tools/perf Auto-detecting system features: ... dwarf: [ on ] [SNIP] GEN common-cmds.h CC perf-read-vdso32 In file included from /tmp/oxygen_root/usr/include/features.h:388:0, from /tmp/oxygen_root/usr/include/stdio.h:27, from perf-read-vdso.c:1: /tmp/oxygen_root/usr/include/gnu/stubs.h:7:27: fatal error: gnu/stubs-32.h: No such file or directory # include <gnu/stubs-32.h> ^ compilation terminated. ... In this patch we checks not only compiler and linker, but also basic headers in test-compile test case, make it fail on a platform lacking correct headers. Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Link: http://lkml.kernel.org/r/1453893742-20603-1-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-01-26tools build: Allow subprojects select all feature checkersWang Nan
Put feature checkers not in original FEATURE_TESTS to a new list and allow subproject select all feature checkers by setting FEATURE_TESTS to 'all'. Signed-off-by: Wang Nan <wangnan0@huawei.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Brendan Gregg <brendan.d.gregg@gmail.com> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: He Kuang <hekuang@huawei.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Will Deacon <will.deacon@arm.com> Link: http://lkml.kernel.org/r/1453715801-7732-4-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-01-11tools build: Add BPF feature check to test-allWang Nan
The test-all.c file doesn't check BPF related features. For an environment with all other features enabled, BPF would be considered enabled without doing real feature check. This patch adds test-bpf.c into test-all.c. Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1452520124-2073-11-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-01-11perf tools: Fix PowerPC native buildingWang Nan
Checks BPF syscall number, turn off libbpf building on platform doesn't correctly support sys_bpf instead of blocking compiling. Reported-and-Tested-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1452520124-2073-7-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-01-06tools build feature: Use value assignment form for FEATURE-DUMP fileJiri Olsa
Changing the contents of the FEATURE-DUMP file, so it looks like: feature-backtrace=1 feature-dwarf=0 feature-fortify-source=1 feature-sync-compare-and-swap=0 This way it could get included in sub projects, so they won't be forced to redo features detection. Also now storing the complete set of features. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Wang Nan <wangnan0@huawei.com> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama <pi3orama@163.com> Link: http://lkml.kernel.org/r/1450893514-9158-5-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-01-06tools build feature: Introduce feature_assign macroJiri Olsa
The feature_assign macro generates feature value assignment for name, like: $(call feature_assign,dwarf) == feature-dwarf=1 This will be used more in following patches. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Wang Nan <wangnan0@huawei.com> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama <pi3orama@163.com> Link: http://lkml.kernel.org/r/1450893514-9158-4-git-send-email-jolsa@kernel.org [ Rename it to feature_assign, the original shorter name was misleading, to say the least ;-) ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-01-06tools build feature: Move dwarf post unwind choice output into perfJiri Olsa
We decide what dwarf unwind to choose way after the Makefile.feature makefile is included. The $(dwarf-post-unwind) is not even set at that time. For the same reason it was never included in FEATURE-DUMP file. Moving it into perf VF=1 verbose display. $ make VF=1 BUILD: Doing 'make -j4' parallel build Auto-detecting system features: ... dwarf: [ on ] ... ... LIBUNWIND_DIR: ... LIBDW_DIR: ... DWARF post unwind library: libunwind ... Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Wang Nan <wangnan0@huawei.com> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama <pi3orama@163.com> Link: http://lkml.kernel.org/r/1450893514-9158-3-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-01-06tools build feature: Fix feature_check_display_code typoJiri Olsa
This function is cursed.. ;-) Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Wang Nan <wangnan0@huawei.com> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama <pi3orama@163.com> Link: http://lkml.kernel.org/r/1450893514-9158-2-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-12-16tools build: Fix feature Makefile issues with 'O='Josh Poimboeuf
When building perf binaries outside the source tree with 'make O=<dir>', the auto-detected features get re-tested for every build, which is unnecessary and inconsistent with the behavior seen when building directly in the source tree. Another issue is that 'make O=<dir> clean' doesn't remove the feature files from the object tree. Fix these problems by looking for the binaries in the $(OUTPUT) directory. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/113bd01530e9761778c60a75a96c65fc59860f68.1450193761.git.jpoimboe@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-12-14perf build: Remove unnecessary line in Makefile.featureJosh Poimboeuf
This line always silently fails because it doesn't add the 'test-' prefix to the .bin file. And it seems to be unnecessary anyway: the line immediately after it does all the individual feature checks. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/554a05c18af564ba015c9e68f25730126e0f4acb.1449965119.git.jpoimboe@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-11-26tools build: Use fixdep with OUTPUT path prefixJiri Olsa
Adding OUTPUT path prefix for fixdep target so we use it properly in out of tree builds. If the fixdep already existed in the tree, the out of tree build would see it already exist and did not build the out of tree version, as reported by Arnaldo: [acme@zoo linux]$ make O=/tmp/build/perf -C tools/perf make: Entering directory '/home/git/linux/tools/perf' BUILD: Doing 'make -j4' parallel build make[2]: Nothing to be done for 'fixdep'. make: Leaving directory '/home/git/linux/tools/perf' Reported-and-Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/20151126185055.GC19410@krava.brq.redhat.com [ Fixed conflict with 5725dd8fa888 ("tools build: Clean CFLAGS and LDFLAGS for fixdep") ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-11-25tools build: Clean CFLAGS and LDFLAGS for fixdepWang Nan
Sometimes passing variables to tools/build is dangerous. For example, on my platform there is a gcc problem (gcc 4.8.1): It passes the stackprotector-all feature check: $ gcc -fstack-protector-all -c ./test.c $ echo $? 0 But requires LDFLAGS support if separate compiling and linking: $ gcc -fstack-protector-all -c ./test.c $ gcc ./test.o ./test.o: In function `main': test.c:(.text+0xb): undefined reference to `__stack_chk_guard' test.c:(.text+0x21): undefined reference to `__stack_chk_guard' collect2: error: ld returned 1 exit status $ gcc -fstack-protector-all ./test.o $ echo $? 0 $ gcc ./test.o -lssp $ echo $? 0 $ In this environment building perf throws an error: $ make BUILD: Doing 'make -j24' parallel build config/Makefile:344: No libunwind found. Please install libunwind-dev[el] >= 1.1 and/or set LIBUNWIND_DIR config/Makefile:403: No libaudit.h found, disables 'trace' tool, please install audit-libs-devel or libaudit-dev config/Makefile:418: slang not found, disables TUI support. Please install slang-devel or libslang-dev config/Makefile:432: GTK2 not found, disables GTK2 support. Please install gtk2-devel or libgtk2.0-dev config/Makefile:564: No bfd.h/libbfd found, please install binutils-dev[el]/zlib-static/libiberty-dev to gain symbol demangling config/Makefile:606: No numa.h found, disables 'perf bench numa mem' benchmark, please install numactl-devel/libnuma-devel/libnuma-dev CC fixdep.o LD fixdep-in.o LINK fixdep fixdep-in.o: In function `parse_dep_file': /kernel/tools/build/fixdep.c:47: undefined reference to `__stack_chk_guard' /kernel/tools/build/fixdep.c:117: undefined reference to `__stack_chk_guard' fixdep-in.o: In function `main': /kernel-hydrogen/tools/build/fixdep.c:156: undefined reference to `__stack_chk_guard' /kernel/tools/build/fixdep.c:168: undefined reference to `__stack_chk_guard' collect2: error: ld returned 1 exit status make[2]: *** [fixdep] Error 1 make[1]: *** [fixdep] Error 2 make: *** [all] Error 2 This is because the CFLAGS used in building perf pollutes the CFLAGS used for fixdep, passing -fstack-protector-all to buiold fixdep which is obviously not required. Since fixdep is a small host side tool, we should keep its CFLAGS/LDFLAGS simple and clean. This patch clears the CFLAGS and LDFLAGS passed when building fixdep, so such gcc problem won't block the perf build process. Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1448372181-151723-2-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-10-29tools build: Fix libiberty feature detectionRabin Vincent
Any CFLAGS or LDFLAGS set by the user need to be passed to the feature build command. This many include for example -I or -L to point to libraries and include files in custom paths. In most of the test-*.bin rules in build/feature/Makefile, we use the BUILD macro which always sends in CFLAGS and LDFLAGS. The libiberty build line however doesn't use the BUILD macro and thus needs to send in CFLAGS and LDFLAGS explicitly. Without this, when using custom CFLAGS/LDFLAGS, libiberty fails to be detected and the perf link fails with something like: LINK perf libbfd.a(bfd.o): In function `bfd_errmsg': bfd.c:(.text+0x168): undefined reference to `xstrerror' bbfd.a(opncls.o): In function `_bfd_new_bfd': opncls.c:(.text+0xe8): undefined reference to `objalloc_create' ... Signed-off-by: Rabin Vincent <rabin.vincent@axis.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Rabin Vincent <rabinv@axis.com> Link: http://lkml.kernel.org/r/1446104978-26429-2-git-send-email-rabin.vincent@axis.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-10-28perf tools: Make perf depend on libbpfWang Nan
By adding libbpf into perf's Makefile, this patch enables perf to build libbpf if libelf is found and neither NO_LIBELF nor NO_LIBBPF is set. The newly introduced code is similar to how libapi and libtraceevent are wired into Makefile.perf. MANIFEST is also updated for 'make perf-*-src-pkg'. Append make_no_libbpf to tools/perf/tests/make. The 'bpf' feature check is appended into default FEATURE_TESTS and FEATURE_DISPLAY, so perf will check the API version of bpf in /path/to/kernel/include/uapi/linux/bpf.h. Which should not fail except when we are trying to port this code to an old kernel. Error messages are also updated to notify users about the lack of BPF support in 'perf record' if libelf is missing or the BPF API check failed. tools/lib/bpf is added to TAG_FOLDERS to allow us to navigate libbpf files when working on perf using tools/perf/tags. Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Cc: Brendan Gregg <brendan.d.gregg@gmail.com> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: David Ahern <dsahern@gmail.com> Cc: He Kuang <hekuang@huawei.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Kaixu Xia <xiakaixu@huawei.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1444826502-49291-2-git-send-email-wangnan0@huawei.com [ Document NO_LIBBPF in Makefile.perf, noted by Jiri Olsa ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-10-20perf build: Add fixdep to .gitignoreYunlong Song
Commit 7c422f5572667fef0db38d2046ecce69dcf0afc8 ("tools build: Build fixdep helper from perf and basic libs") dynamically creates fixdep during the perf building. Add it to .gitignore. Signed-off-by: Yunlong Song <yunlong.song@huawei.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Alexei Starovoitov <ast@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Wang Nan <wangnan0@huawei.com> Fixes: 7c422f557266 ("tools build: Build fixdep helper from perf and basic libs") Link: http://lkml.kernel.org/r/1444899116-8220-1-git-send-email-yunlong.song@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-10-13tools build: Fix cross compile buildJiri Olsa
He Kuang the new fixdep tool breaks cross compiling. The reason is it wouldn't get compiled under host arch, but under cross arch and failed to run. We need to add support for host side tools build, meanwhile disabling fixdep usage for cross arch builds. Reported-by: He Kuang <hekuang@huawei.com> Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/20151013124358.GB9467@krava.brq.redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-28tools build: Build fixdep helper from perf and basic libsJiri Olsa
Adding the fixdep target into the Makefile.include to ease up building of fixdep helper, that needs to be built before we dive in to the build itself. The user can invoke the fixdep target to build the helper. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1443004442-32660-8-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-28tools build: Make the fixdep helper part of the build processJiri Olsa
Making the fixdep helper to be invoked within dep-cmd. Each user of the build framework needs to make sure fixdep exists before executing the build itself. If the build doesn't find fixdep, it falls back to the old style dependency tracking. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1443004442-32660-6-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-28tools build: Move dependency copy into functionJiri Olsa
So it's easier to add more functionality in the following commit. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1443004442-32660-5-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-28tools build: Add fixdep dependency helperJiri Olsa
For dependency tracking we currently use targets that fall out of the gcc -MD command. We store this info in the .cmd file and include as makefile during the build. This format put object as target and all the c and header files as dependencies, like: util/abspath.o: util/abspath.c /usr/include/stdc-predef.h util/cache.h \ /usr/include/bits/wordsize.h /usr/include/gnu/stubs.h \ ... If any of those dependency header files (krava.h below) is removed the build fails on: make[1]: *** No rule to make target 'krava.h', needed by 'inc.o'. Stop. This patch adds fixdep helper, that is used by kbuild to alter the shape of the object dependencies like: source_util/abspath.o := util/abspath.c deps_util/abspath.o := \ /usr/include/stdc-predef.h \ util/cache.h \ ... util/abspath.o: $(deps_util/abspath.o) $(deps_util/abspath.o): With this format the header removal won't make the build fail, because it'll be picked up by the last empty target defined for each header. As previously mentioned the fixdep tool is taken from kbuild. It's not complete backport, only the part that alters the standard dependency info was taken, the part that adds the CONFIG_* dependency logic will be probably taken later on. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Kai Germaschewski <kai.germaschewski@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1443004442-32660-4-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-28tools build: Add test for missing includeJiri Olsa
The current build framework fails to cope with header file removal. The reason is that the removed header file stays in the .cmd file target rule and forces the build to fail. This issue is fixed and explained in the following patches. Adding a new build test that simulates header removal. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1443004442-32660-3-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-28tools build: Add Makefile.includeJiri Olsa
To ease up build framework code setup for users. More shared code will be added in the following patches. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1443004442-32660-2-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-22tools build: Allow setting the feature detection userArnaldo Carvalho de Melo
We will use the tools/build/ autodetection in the eBPF patchkit and it is currently sharing the output directory with perf, that also uses the feature detection logic. As we keep state in the output directory, so that we can avoid running all the tests again, we need to have different filenames for the files used in this state, allow doing that via the FEATURE_USER variable, to be set alongside the existing FEATURE_{TEST,DISPLAY} variables. v2: Fix comment describing the FEATURE_DUMP filename to make sure where it is created, precisely at $(OUTPUT)FEATURE-DUMP$(FEATURE_USER). Pointed out by Jiri. Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Cc: Wang Nan <wangnan0@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/n/tip-fdbev0vrn3x6idqc3ajbnvcb@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-22tools build: Fixup feature detection display function nameArnaldo Carvalho de Melo
Cut'n'paste mistake, it should eval the name of the function defined right next to it, in the next line, fix it. Before: $ make -C tools/lib/bpf/ make: Entering directory '/home/git/linux/tools/lib/bpf' Auto-detecting system features: ... libelf: [ on ] ... libelf-getphdrnum: [ on ] ... libelf-mmap: [ on ] ... bpf: [ on ] <SNIP> After: $ make -C tools/lib/bpf/ make: Entering directory '/home/git/linux/tools/lib/bpf' Auto-detecting system features: ... libelf: [ on ] ... libelf-getphdrnum: [ OFF ] ... libelf-mmap: [ OFF ] ... bpf: [ on ] <SNIP> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Cc: Wang Nan <wangnan0@huawei.com> Cc: pi3orama@163.com Fixes: 58d4f00ff13f ("perf build: Fix feature_check name clash") Link: http://lkml.kernel.org/n/tip-dzu1c4sruukgfq5d5b1c4r30@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-17tools build: Add test for presence of __get_cpuid() gcc builtinArnaldo Carvalho de Melo
The auxtrace code needed by Intel PT uses the __get_cpuid() gcc builtin, that is not present in old systems, breaking the build. Add a test to check for that builtin and disable AUXTRACE in those systems. [acme@rhel5 linux]$ make NO_LIBPERL=1 -C tools/perf O=/tmp/build/perf install-bin make: Entering directory `/home/acme/git/linux/tools/perf' BUILD: Doing 'make -j2' parallel build Auto-detecting system features: <SNIP> ... lzma: [ on ] ... get_cpuid: [ OFF ] <SNIP> config/Makefile:630: Your gcc lacks the __get_cpuid() builtin, disables support for auxtrace/Intel PT, please install a newer gcc MKDIR /tmp/build/perf/util/ <SNIP> This fixes the build on old systems such as RHEL/CentOS 5.11. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: "Naveen N. Rao" <naveen.n.rao@linux.vnet.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Stephane Eranian <eranian@google.com> Cc: Victor Kamensky <victor.kamensky@linaro.org> Cc: Vinson Lee <vlee@twopensource.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-d4puslul0jltoodzpx9r4sje@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-17tools build: Add test for presence of numa_num_possible_cpus() in libnumaArnaldo Carvalho de Melo
The existing numa test checks only if numa.h and numa_available() are present, but that can be satisfied with an old libnuma that is not enough for the 'perf bench numa' entry, so add a test to check for that: [acme@rhel5 linux]$ make NO_AUXTRACE=1 NO_LIBPERL=1 -C tools/perf O=/tmp/build/perf install-bin make: Entering directory `/home/acme/git/linux/tools/perf' BUILD: Doing 'make -j2' parallel build Auto-detecting system features: ... libelf: [ on ] ... libnuma: [ on ] ... numa_num_possible_cpus: [ OFF ] ... libperl: [ on ] <SNIP> config/Makefile:577: Old numa library found, disables 'perf bench numa mem' benchmark, please install numactl-devel/libnuma-devel/libnuma-dev >= 2.0.8 INSTALL binaries <SNIP> This fixes the build on old systems such as RHEL/CentOS 5.11. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: "Naveen N. Rao" <naveen.n.rao@linux.vnet.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Stephane Eranian <eranian@google.com> Cc: Victor Kamensky <victor.kamensky@linaro.org> Cc: Vinson Lee <vlee@twopensource.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-zqriqkezppi2de2iyjin1tnc@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-08-26tools build: Allow duplicate objects in the object listJiri Olsa
It's sometimes useful to specify the object affiliation to multiple config options like: libperf-$(CONFIG_X86) += tsc.o libperf-$(CONFIG_AUXTRACE) += tsc.o while the object itself is linked only once. Adding the support for this and ignoring duplicate objects in the object list. Suggested-by: Arnaldo Carvalho de Melo <acme@kernel.org> Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/20150826130103.GF22670@krava.redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-08-17perf tools: Add Intel PT instruction decoderAdrian Hunter
Add support for decoding instructions for Intel Processor Trace. The kernel x86 instruction decoder is copied for this. This essentially provides intel_pt_get_insn() which takes a binary buffer, uses the kernel's x86 instruction decoder to get details of the instruction and then categorizes it for consumption by an Intel PT decoder. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1439450095-30122-1-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-08-13perf tools: Support static linking with libdwAndi Kleen
The Fedora 22 version of libdw requires a couple of extra libraries to link. With a dynamic link the dependencies are pulled in automatically, but this doesn't work for static linking. Add the needed libraries explicitely to the feature probe and the Makefile. v2: Explicitly check for static linking and only add the dependencies when -static is set. This is to avoid regressions on Arnaldo's system. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Jiri Olsa <jolsa@kernel.org> Link: http://lkml.kernel.org/r/1439419717-20601-1-git-send-email-andi@firstfloor.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-08-07bpf tools: Introduce 'bpf' library and add bpf feature checkWang Nan
This is the first patch of libbpf. The goal of libbpf is to create a standard way for accessing eBPF object files. This patch creates 'Makefile' and 'Build' for it, allows 'make' to build libbpf.a and libbpf.so, 'make install' to put them into proper directories. Most part of Makefile is borrowed from traceevent. Before building, it checks the existence of libelf in Makefile, and deny to build if not found. Instead of throwing an error if libelf not found, the error raises in a phony target "elfdep". This design is to ensure 'make clean' still workable even if libelf is not found. Because libbpf requires 'kern_version' field set for 'union bpf_attr' (bpfdep" is used for that dependency), Kernel BPF API is also checked by intruducing a new feature check 'bpf' into tools/build/feature, which checks the existence and version of linux/bpf.h. When building libbpf, it searches that file from include/uapi/linux in kernel source tree (controlled by FEATURE_CHECK_CFLAGS-bpf). Since it searches kernel source tree it reside, installing of newest kernel headers is not required, except we are trying to port these files to an old kernel. To avoid checking that file when perf building, the newly introduced 'bpf' feature check doesn't added into FEATURE_TESTS and FEATURE_DISPLAY by default in tools/build/Makefile.feature, but added into libbpf's specific. Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Cc: Brendan Gregg <brendan.d.gregg@gmail.com> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: David Ahern <dsahern@gmail.com> Cc: He Kuang <hekuang@huawei.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Kaixu Xia <xiakaixu@huawei.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Zefan Li <lizefan@huawei.com> Bcc: pi3orama@163.com Link: http://lkml.kernel.org/r/1435716878-189507-4-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-08-05perf tools: Fix build errors with mipsel-linux-uclibc compilerPetri Gynther
linux/tools$ make ARCH=mips CROSS_COMPILE=mipsel-linux- perf ... config/Makefile:256: *** No gnu/libc-version.h found, please install glibc-dev[el]. Stop. make[1]: *** [all] Error 2 make: *** [perf] Error 2 ... In file included from builtin-sched.c:13:0: util/cloexec.h:8:12: error: redundant redeclaration of ‘sched_getcpu’ [-Werror=redundant-decls] extern int sched_getcpu(void) __THROW; mipsel-buildroot-linux-uclibc/sysroot/usr/include/bits/sched.h:88:12: note: previous declaration of ‘sched_getcpu’ was here extern int sched_getcpu (void) __THROW; uclibc info: sysroot/usr/include/bits/uClibc_config.h __UCLIBC_MAJOR__ 0 __UCLIBC_MINOR__ 9 __UCLIBC_SUBLEVEL__ 33 sysroot/usr/include/features.h __UCLIBC__ 1 __GLIBC__ 2 __GLIBC_MINOR__ 2 Signed-off-by: Petri Gynther <pgynther@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1438735081-24131-1-git-send-email-pgynther@google.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-01perf tools: Create config.detected into OUTPUT directoryAaro Koskinen
Create config.detected into OUTPUT directory instead of source directory. This fixes parallel builds that share the same source directory. Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1435751683-18500-1-git-send-email-aaro.koskinen@nokia.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-06-22Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "These are the left over fixes from the v4.1 cycle" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf tools: Fix build breakage if prefix= is specified perf/x86: Honor the architectural performance monitoring version perf/x86/intel: Fix PMI handling for Intel PT perf/x86/intel/bts: Fix DS area sharing with x86_pmu events perf/x86: Add more Broadwell model numbers perf: Fix ring_buffer_attach() RCU sync, again
