path: root/tools/build
2018-08-24tools: build: Use HOSTLDFLAGS with fixdepLaura Abbott
[ Upstream commit 8b247a92ebd0cda7dec49a6f771d9c4950f3d3ad ] The final link of fixdep uses LDFLAGS but not the existing HOSTLDFLAGS. Fix this. Signed-off-by: Laura Abbott <labbott@redhat.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-17tools build: fix # escaping in .cmd files for future MakePaul Menzel
commit 9feeb638cde083c737e295c0547f1b4f28e99583 upstream. In 2016 GNU Make made a backwards incompatible change to the way '#' characters were handled in Makefiles when used inside functions or macros: http://git.savannah.gnu.org/cgit/make.git/commit/?id=c6966b323811c37acedff05b57 Due to this change, when attempting to run `make prepare' I get a spurious make syntax error: /home/earnest/linux/tools/objtool/.fixdep.o.cmd:1: *** missing separator. Stop. When inspecting `.fixdep.o.cmd' it includes two lines which use unescaped comment characters at the top: \# cannot find fixdep (/home/earnest/linux/tools/objtool//fixdep) \# using basic dep data This is because `tools/build/Build.include' prints these '\#' characters: printf '\# cannot find fixdep (%s)\n' $(fixdep) > $(dot-target).cmd; \ printf '\# using basic dep data\n\n' >> $(dot-target).cmd; \ This completes commit 9564a8cf422d ("Kbuild: fix # escaping in .cmd files for future Make"). Link: https://bugzilla.kernel.org/show_bug.cgi?id=197847 Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: stable@vger.kernel.org Signed-off-by: Paul Menzel <pmenzel@molgen.mpg.de> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-11Kbuild: fix # escaping in .cmd files for future MakeRasmus Villemoes
commit 9564a8cf422d7b58f6e857e3546d346fa970191e upstream. I tried building using a freshly built Make (4.2.1-69-g8a731d1), but already the objtool build broke with orc_dump.c: In function ‘orc_dump’: orc_dump.c:106:2: error: ‘elf_getshnum’ is deprecated [-Werror=deprecated-declarations] if (elf_getshdrnum(elf, &nr_sections)) { Turns out that with that new Make, the backslash was not removed, so cpp didn't see a #include directive, grep found nothing, and -DLIBELF_USE_DEPRECATED was wrongly put in CFLAGS. Now, that new Make behaviour is documented in their NEWS file: * WARNING: Backward-incompatibility! Number signs (#) appearing inside a macro reference or function invocation no longer introduce comments and should not be escaped with backslashes: thus a call such as: foo := $(shell echo '#') is legal. Previously the number sign needed to be escaped, for example: foo := $(shell echo '\#') Now this latter will resolve to "\#". If you want to write makefiles portable to both versions, assign the number sign to a variable: C := \# foo := $(shell echo '$C') This was claimed to be fixed in 3.81, but wasn't, for some reason. To detect this change search for 'nocomment' in the .FEATURES variable. This also fixes up the two make-cmd instances to replace # with $(pound) rather than with \#. There might very well be other places that need similar fixup in preparation for whatever future Make release contains the above change, but at least this builds an x86_64 defconfig with the new make. Link: https://bugzilla.kernel.org/show_bug.cgi?id=197847 Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-28tools build tests: Don't hardcode gcc nameDavid Carrillo-Cisneros
Use $(CC) instead of harcoded gcc binary name. Signed-off-by: David Carrillo-Cisneros <davidcc@google.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Paul Turner <pjt@google.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/20170827075442.108534-2-davidcc@google.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2017-08-10Merge branch 'perf/urgent' into perf/core, to pick up fixesIngo Molnar
2017-08-04bpf, s390: fix build for libbpf and selftest suiteDaniel Borkmann
The BPF feature test as well as libbpf is missing the __NR_bpf define for s390 and currently refuses to compile (selftest suite depends on libbpf as well). Similar issue was fixed some time ago via b0c47807d31d ("bpf: Add sparc support to tools and samples."), just do the same and add definitions. Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-07-30Merge branch 'perf/urgent' into perf/core, to pick up latest fixes and ↵Ingo Molnar
refresh the tree Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-07-18tools build: Add test for setns()Arnaldo Carvalho de Melo
And provide an alternative implementation to keep perf building on older distros as we're about to add initial support for namespaces. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Krister Johansen <kjlx@templeofstupid.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-bqdwijunhjlvps1ardykhw1i@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2017-06-06kbuild: simplify silent build (-s) detectionMasahiro Yamada
This allows to detect -s (--silent) option without checking GNU Make version. As commit e36aaea28972 ("kbuild: Fix silent builds with make-4") pointed out, GNU Make 4.x changed the way/order it presents the command line options into MAKEFLAGS. In Make 3.8x, 's' is always the first in a group of short options. The group may be prefixed with '-' in some cases. In Make 4.x, 's' is always the last in a group of short options. As commit e6ac89fabd03 ("kbuild: Correctly deal with make options which contain an 's'") addressed, we also need to deal with long options that contain 's', like --warn-undefined-variables. Test cases: [1] command line input: make --silent -> MAKEFLAGS for Make 3.8x: s -> MAKEFLAGS for Make 4.x : s [2] command line input: make -srR -> MAKEFLAGS for Make 3.8x: sRr -> MAKEFLAGS for Make 4.x : rRs [3] command line input: make -s -rR --warn-undefined-variables -> MAKEFLAGS for Make 3.8x: --warn-undefined-variables -sRr -> MAKEFLAGS for Make 4.x : rRs --warn-undefined-variables My idea to cater to all the cases more easily is to filter out long options (--%), then search 's' with $(findstring ...). This way will be more future-proof even if future versions of Make put 's' in the middle of the group. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-05-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Track alignment in BPF verifier so that legitimate programs won't be rejected on !CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS architectures. 2) Make tail calls work properly in arm64 BPF JIT, from Deniel Borkmann. 3) Make the configuration and semantics Generic XDP make more sense and don't allow both generic XDP and a driver specific instance to be active at the same time. Also from Daniel. 4) Don't crash on resume in xen-netfront, from Vitaly Kuznetsov. 5) Fix use-after-free in VRF driver, from Gao Feng. 6) Use netdev_alloc_skb_ip_align() to avoid unaligned IP headers in qca_spi driver, from Stefan Wahren. 7) Always run cleanup routines in BPF samples when we get SIGTERM, from Andy Gospodarek. 8) The mdio phy code should bring PHYs out of reset using the shared GPIO lines before invoking bus->reset(). From Florian Fainelli. 9) Some USB descriptor access endian fixes in various drivers from Johan Hovold. 10) Handle PAUSE advertisements properly in mlx5 driver, from Gal Pressman. 11) Fix reversed test in mlx5e_setup_tc(), from Saeed Mahameed. 12) Cure netdev leak in AF_PACKET when using timestamping via control messages. From Douglas Caetano dos Santos. 13) netcp doesn't support HWTSTAMP_FILTER_ALl, reject it. From Miroslav Lichvar. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (52 commits) ldmvsw: stop the clean timer at beginning of remove ldmvsw: unregistering netdev before disable hardware net: netcp: fix check of requested timestamping filter ipv6: avoid dad-failures for addresses with NODAD qed: Fix uninitialized data in aRFS infrastructure mdio: mux: fix device_node_continue.cocci warnings net/packet: fix missing net_device reference release net/mlx4_core: Use min3 to select number of MSI-X vectors macvlan: Fix performance issues with vlan tagged packets net: stmmac: use correct pointer when printing normal descriptor ring net/mlx5: Use underlay QPN from the root name space net/mlx5e: IPoIB, Only support regular RQ for now net/mlx5e: Fix setup TC ndo net/mlx5e: Fix ethtool pause support and advertise reporting net/mlx5e: Use the correct pause values for ethtool advertising vmxnet3: ensure that adapter is in proper state during force_close sfc: revert changes to NIC revision numbers net: ch9200: add missing USB-descriptor endianness conversions net: irda: irda-usb: fix firmware name on big-endian hosts net: dsa: mv88e6xxx: add default case to switch ...
2017-05-12Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates/fixes from Ingo Molnar: "Mostly tooling updates, but also two kernel fixes: a call chain handling robustness fix and an x86 PMU driver event definition fix" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/callchain: Force USER_DS when invoking perf_callchain_user() tools build: Fixup sched_getcpu feature test perf tests kmod-path: Don't fail if compressed modules aren't supported perf annotate: Fix AArch64 comment char perf tools: Fix spelling mistakes perf/x86: Fix Broadwell-EP DRAM RAPL events perf config: Refactor a duplicated code for obtaining config file name perf symbols: Allow user probes on versioned symbols perf symbols: Accept symbols starting at address 0 tools lib string: Adopt prefixcmp() from perf and subcmd perf units: Move parse_tag_value() to units.[ch] perf ui gtk: Move gtk .so name to the only place where it is used perf tools: Move HAS_BOOL define to where perl headers are used perf memswap: Split the byteswap memory range wrappers from util.[ch] perf tools: Move event prototypes from util.h to event.h perf buildid: Move prototypes from util.h to build-id.h
2017-05-11bpf: Add strict alignment flag for BPF_PROG_LOAD.David S. Miller
Add a new field, "prog_flags", and an initial flag value BPF_F_STRICT_ALIGNMENT. When set, the verifier will enforce strict pointer alignment regardless of the setting of CONFIG_EFFICIENT_UNALIGNED_ACCESS. The verifier, in this mode, will also use a fixed value of "2" in place of NET_IP_ALIGN. This facilitates test cases that will exercise and validate this part of the verifier even when run on architectures where alignment doesn't matter. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Daniel Borkmann <daniel@iogearbox.net>
2017-05-04tools build: Fixup sched_getcpu feature testArnaldo Carvalho de Melo
We have tools/build/feature/test-all.c to speed up feature testing, doing all tests at once, but then all tests in this file should normally pass. That is not the case with the sched-getcpu one, that wasn't passing when included from test-all.c because it needs to have _GNU_SOURCE defined before including sched.h, but _GNU_SOURCE is defined by a header included from another feature test included earlier in test-all.d, test-libpython.c, resulting in: $ cat /tmp/build/perf/feature/test-all.make.output In file included from test-all.c:121:0: test-sched_getcpu.c:1:0: error: "_GNU_SOURCE" redefined [-Werror] #define _GNU_SOURCE In file included from /usr/include/python2.7/pyconfig.h:6:0, from /usr/include/python2.7/Python.h:8, from test-libpython.c:1, from test-all.c:13: /usr/include/python2.7/pyconfig-64.h:1177:0: note: this is the location of the previous definition #define _GNU_SOURCE 1 cc1: all warnings being treated as errors Which would trigger testing the tests individually, when that _GNU_SOURCE redefinition would not take place, and the whole process would continue, just slower... Fix it. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Fixes: 120010cb1eea ("tools build: Add test for sched_getcpu()") Link: http://lkml.kernel.org/n/tip-3qp1it69xsc4w8gnuu1e9ayh@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2017-05-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Millar: "Here are some highlights from the 2065 networking commits that happened this development cycle: 1) XDP support for IXGBE (John Fastabend) and thunderx (Sunil Kowuri) 2) Add a generic XDP driver, so that anyone can test XDP even if they lack a networking device whose driver has explicit XDP support (me). 3) Sparc64 now has an eBPF JIT too (me) 4) Add a BPF program testing framework via BPF_PROG_TEST_RUN (Alexei Starovoitov) 5) Make netfitler network namespace teardown less expensive (Florian Westphal) 6) Add symmetric hashing support to nft_hash (Laura Garcia Liebana) 7) Implement NAPI and GRO in netvsc driver (Stephen Hemminger) 8) Support TC flower offload statistics in mlxsw (Arkadi Sharshevsky) 9) Multiqueue support in stmmac driver (Joao Pinto) 10) Remove TCP timewait recycling, it never really could possibly work well in the real world and timestamp randomization really zaps any hint of usability this feature had (Soheil Hassas Yeganeh) 11) Support level3 vs level4 ECMP route hashing in ipv4 (Nikolay Aleksandrov) 12) Add socket busy poll support to epoll (Sridhar Samudrala) 13) Netlink extended ACK support (Johannes Berg, Pablo Neira Ayuso, and several others) 14) IPSEC hw offload infrastructure (Steffen Klassert)" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2065 commits) tipc: refactor function tipc_sk_recv_stream() tipc: refactor function tipc_sk_recvmsg() net: thunderx: Optimize page recycling for XDP net: thunderx: Support for XDP header adjustment net: thunderx: Add support for XDP_TX net: thunderx: Add support for XDP_DROP net: thunderx: Add basic XDP support net: thunderx: Cleanup receive buffer allocation net: thunderx: Optimize CQE_TX handling net: thunderx: Optimize RBDR descriptor handling net: thunderx: Support for page recycling ipx: call ipxitf_put() in ioctl error path net: sched: add helpers to handle extended actions qed*: Fix issues in the ptp filter config implementation. qede: Fix concurrency issue in PTP Tx path processing. stmmac: Add support for SIMATIC IOT2000 platform net: hns: fix ethtool_get_strings overflow in hns driver tcp: fix wraparound issue in tcp_lp bpf, arm64: fix jit branch offset related to ldimm64 bpf, arm64: implement jiting of BPF_XADD ...
2017-04-22bpf: Add sparc support to tools and samples.David S. Miller
2017-04-13tools build: Fix feature detection redefinion of build flagsDavid Carrillo-Cisneros
This change is a follow up of https://lkml.org/lkml/2017/2/2/16 The patch above avoided redefining CC, CXX and PKG_CONFIG in feature detection. The patch was not merged due to a unsolved concern with the -MD flag. Later, commit c8c188679ccf ("tools build: Use the same CC for feature detection and actual build") did the change for CC and CXX but not PKG_CONFIG. This patch makes PKG_CONFIG consistent with CC and CXX and moves the -MD to CFLAGS, as suggested by Jiri in the thread above. Signed-off-by: David Carrillo-Cisneros <davidcc@google.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: He Kuang <hekuang@huawei.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Paul Turner <pjt@google.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Simon Que <sque@chromium.org> Cc: Stephane Eranian <eranian@google.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/20170412064919.92449-3-davidcc@google.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2017-04-12perf tools: Pass PYTHON config to feature detectionDavid Carrillo-Cisneros
( This is a rebased version of https://lkml.org/lkml/2017/2/7/662 ) Python's CC and link Makefile variables were not passed to feature detection, causing feature detection to use system's Python rather than PYTHON_CONFIG's one. This created a mismatch between the detected Python support and the one actually used by perf when PYTHON_CONFIG is specified. Fix it by moving Python's variable initialization to before feature detection and pass FLAGS_PYTHON_EMBED to Python's feature detection's build target. Signed-off-by: David Carrillo-Cisneros <davidcc@google.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: He Kuang <hekuang@huawei.com> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Paul Turner <pjt@google.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Simon Que <sque@chromium.org> Cc: Stephane Eranian <eranian@google.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/20170412064919.92449-2-davidcc@google.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2017-03-03tools build: Use the same CC for feature detection and actual buildArnaldo Carvalho de Melo
When build with: 'make CC=clang' we were not using that CC to do feature detection, which resulted in features being detected with gcc and then the actual tools being built with clang. Most of the time these compilers are compatible enough, so no problem was being noticed. As soon as a system with an old enough clang, one that hasn't the cpuid.h header is used, and a gcc with it, the "get_cpuid" feature will be found available but then code that will use can't be compiled. Noticed with this combination: / $ gcc --version | head -1 gcc (Alpine 6.3.0) 6.3.0 / $ clang --version | head -1 clang version 3.8.1 (tags/RELEASE_381/final) / $ cat /etc/alpine-release 3.5.0 / $ Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-60q18nvlvgpyfv7e2qqgx4ou@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2017-03-03tools build: Add test for sched_getcpu()Arnaldo Carvalho de Melo
Instead of trying to go on adding more ifdef conditions, do a feature test and define HAVE_SCHED_GETCPU_SUPPORT instead, then use it to provide the prototype. No need to change the stub, as it is already a __weak symbol. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-yge89er9g90sc0v6k0a0r5tr@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2017-02-17perf build: Add special fixdep cleaning ruleJiri Olsa
Ingo reported following build failure: On Sat, Feb 11, 2017 at 12:12:34PM +0100, Ingo Molnar wrote: > > So I had this oldish 32-bit 15.10 Ubuntu installation around (fully updated), and > trying to build perf gave me: > > deimos:~/tip/tools/perf> make > BUILD: Doing 'make -j4' parallel build > make[3]: *** No rule to make target '/usr/include/x86_64-linux-gnu/sys/types.h', needed by 'fixdep.o'. Stop. > Makefile:42: recipe for target 'fixdep-in.o' failed > make[2]: *** [fixdep-in.o] Error 2 > /home/mingo/tip/tools/build/Makefile.include:4: recipe for target 'fixdep' failed > make[1]: *** [fixdep] Error 2 > Makefile:68: recipe for target 'all' failed > make: *** [all] Error 2 > > Now this got a bit better after I did a 'make mrproper' in the kernel tree: > > deimos:~/tip/tools/perf> make > BUILD: Doing 'make -j4' parallel build > HOSTCC fixdep.o > /home/mingo/tip/tools/build/fixdep: 1: /home/mingo/tip/tools/build/fixdep: Syntax error: "(" unexpected > /home/mingo/tip/tools/build/Makefile.build:101: recipe for target 'fixdep.o' failed > make[3]: *** [fixdep.o] Error 2 > Makefile:42: recipe for target 'fixdep-in.o' failed > make[2]: *** [fixdep-in.o] Error 2 > /home/mingo/tip/tools/build/Makefile.include:4: recipe for target 'fixdep' failed > make[1]: *** [fixdep] Error 2 > Makefile:68: recipe for target 'all' failed > make: *** [all] Error 2 > > After some digging it turns out that my 'fixdep' binary was 64-bit: > > deimos:~/tip/tools/perf> file /home/mingo/tip/tools/build/fixdep > /home/mingo/tip/tools/build/fixdep: ELF 64-bit LSB executable, x86-64, version 1 > (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux > 2.6.32, BuildID[sha1]=d527f736b57b5ba47210fbcb562a3b52867d21c1, not stripped > > But it did not get cleaned out by 'make clean'. > > Only after I did a 'make clean' in tools/ itself, did it get built properly. It shows we don't clean up properly the fixdep objects, so adding special rule for that. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Reported-by: Ingo Molnar <mingo@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1487340058-10496-2-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2017-01-26tools build: Add tools tree support for 'make -s'Josh Poimboeuf
When doing a kernel build with 'make -s', everything is silenced except the objtool build. That's because the tools tree support for silent builds is some combination of missing and broken. Three changes are needed to fix it: - Makefile: propagate '-s' to the sub-make's MAKEFLAGS variable so the tools Makefiles can see it. - tools/scripts/Makefile.include: fix the tools Makefiles' ability to recognize '-s'. The MAKE_VERSION and MAKEFLAGS checks are copied from the top-level Makefile. This silences the "DESCEND objtool" message. - tools/build/Makefile.build: add support to the tools Build files for recognizing '-s'. Again the MAKE_VERSION and MAKEFLAGS checks are copied from the top-level Makefile. This silences all the object compile/link messages. Reported-and-Tested-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Michal Marek <mmarek@suse.com> Link: http://lkml.kernel.org/r/e8967562ef640c3ae9a76da4ae0f4e47df737c34.1484799200.git.jpoimboe@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-12-17Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: - prototypes for x86 asm-exported symbols (Adam Borowski) and a warning about missing CRCs (Nick Piggin) - asm-exports fix for LTO (Nicolas Pitre) - thin archives improvements (Nick Piggin) - linker script fix for CONFIG_LD_DEAD_CODE_DATA_ELIMINATION (Nick Piggin) - genksyms support for __builtin_va_list keyword - misc minor fixes * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: x86/kbuild: enable modversions for symbols exported from asm kbuild: fix scripts/adjust_autoksyms.sh* for the no modules case scripts/kallsyms: remove last remnants of --page-offset option make use of make variable CURDIR instead of calling pwd kbuild: cmd_export_list: tighten the sed script kbuild: minor improvement for thin archives build kbuild: modpost warn if export version crc is missing kbuild: keep data tables through dead code elimination kbuild: improve linker compatibility with lib-ksyms.o build genksyms: Regenerate parser kbuild/genksyms: handle va_list type kbuild: thin archives for multi-y targets kbuild: kallsyms allow 3-pass generation if symbols size has changed
2016-12-11make use of make variable CURDIR instead of calling pwdUwe Kleine-König
make already provides the current working directory in a variable, so make use of it instead of forking a shell. Also replace usage of PWD by CURDIR. PWD is provided by most shells, but not all, so this makes the build system more robust. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Michal Marek <mmarek@suse.com>
2016-12-06perf build: Check LLVM version in feature checkWang Nan
Cancel builtin llvm and clang support when LLVM version is less than 3.9.0: following commits uses newer API. Since Clang/LLVM's API is not guaranteed to be stable, add a test-llvm-version.cpp feature checker, issue warning if LLVM found in compiling environment is not tested yet. Committer Notes: Testing it: Environment: $ cat /etc/fedora-release Fedora release 25 (Twenty Five) $ rpm -q llvm-devel clang-devel llvm-devel-3.8.0-1.fc25.x86_64 clang-devel-3.8.0-2.fc25.x86_64 $ Before: $ make -k LIBCLANGLLVM=1 O=/tmp/build/perf -C tools/perf install-bin make: Entering directory '/home/acme/git/linux/tools/perf' BUILD: Doing 'make -j4' parallel build Warning: tools/include/uapi/linux/bpf.h differs from kernel Warning: tools/arch/arm/include/uapi/asm/kvm.h differs from kernel INSTALL GTK UI LINK /tmp/build/perf/perf /tmp/build/perf/libperf.a(libperf-in.o): In function `perf::createCompilerInvocation(llvm::SmallVector<char const*, 16u>, llvm::StringRef&, clang::DiagnosticsEngine&)': /home/acme/git/linux/tools/perf/util/c++/clang.cpp:56: undefined reference to `clang::tooling::newInvocation(clang::DiagnosticsEngine*, llvm::SmallVector<char const*, 16u> const&)' /tmp/build/perf/libperf.a(libperf-in.o): In function `perf::getModuleFromSource(llvm::SmallVector<char const*, 16u>, llvm::StringRef, llvm::IntrusiveRefCntPtr<clang::vfs::FileSystem>)': /home/acme/git/linux/tools/perf/util/c++/clang.cpp:68: undefined reference to `clang::CompilerInstance::CompilerInstance(std::shared_ptr<clang::PCHContainerOperations>, bool)' /home/acme/git/linux/tools/perf/util/c++/clang.cpp:69: undefined reference to `clang::CompilerInstance::createDiagnostics(clang::DiagnosticConsumer*, bool)' <SNIP> After: Makefile.config:807: No suitable libLLVM found, disabling builtin clang and llvm support. Please install llvm-dev(el) (>= 3.9.0) Updating the environment to a locally built LLVM 4.0 + clang 3.9 (forgot to git pull, duh) combo, all works as expected, it is properly detected and built into the resulting perf binary. Signed-off-by: Wang Nan <wangnan0@huawei.com> Reported-and-Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Alexei Starovoitov <ast@fb.com> Cc: He Kuang <hekuang@huawei.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Joe Stringer <joe@ovn.org> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/20161206072230.7651-1-wangnan0@huawei.com [ Change the warning message a bit (add 'suitable' and 'builtin'), clarifying it, see committer notes above ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-12-05tools build: Move tabs to spaces where suitableJiri Olsa
We've been hit several times by a Makefile bug where line indented by tab was falsely considered as target command. We prevent this by always using space indentation for everything except for the target commands. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1480884178-8072-3-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-12-05tools build: Make the .cmd file more readableJiri Olsa
Putting extra line between dependencies and cmd_* definition to make it more readable. Before: $ cat .builtin-top.o.cmd ... /home/jolsa/kernel/linux-perf/tools/include/linux/stringify.h \ /home/jolsa/kernel/linux-perf/tools/include/linux/time64.h cmd_builtin-top.o := gcc -Wp,-MD,./.builtin-top.o.d -Wp,-MT,builtin-... ... After: $ cat .builtin-top.o.cmd ... /home/jolsa/kernel/linux-perf/tools/include/linux/stringify.h \ /home/jolsa/kernel/linux-perf/tools/include/linux/time64.h cmd_builtin-top.o := gcc -Wp,-MD,./.builtin-top.o.d -Wp,-MT,builtin-... ... Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1480884178-8072-2-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-12-05tools build: Add feature detection for clangWang Nan
Check if basic clang compiling environment is ready. Doesn't like 'llvm-config --libs' which can returns llvm libraries in right order and duplicates some libraries if necessary, there's no correspondence for clang libraries (-lclangxxx). to avoid extra complexity and to avoid new clang breaking libraries ordering, use --start-group and --end-group. In this test case, manually identify required clang libs and hope it to be stable. Putting all clang libraries here is possible (use make's wildcard), but then feature checking becomes very slow. Signed-off-by: Wang Nan <wangnan0@huawei.com> Cc: Alexei Starovoitov <ast@fb.com> Cc: He Kuang <hekuang@huawei.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Joe Stringer <joe@ovn.org> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/20161126070354.141764-9-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-12-05tools build: Add feature detection for LLVMWang Nan
Check if basic LLVM compiling environment is ready. Use llvm-config to detect include and library directories. Avoid using 'llvm-config --cxxflags' because its result contain some unwanted flags like --sysroot (if LLVM is built by yocto). Use '?=' to set LLVM_CONFIG, so explicitly passing LLVM_CONFIG to make would override it. Use 'llvm-config --libs BPF' to check if BPF backend is compiled in. Since now BPF bytecode is the only required backend, no need to waste time linking llvm and clang if BPF backend is missing. This also introduce an implicit requirement that LLVM should be new enough. Old LLVM doesn't support BPF backend. Signed-off-by: Wang Nan <wangnan0@huawei.com> Cc: Alexei Starovoitov <ast@fb.com> Cc: He Kuang <hekuang@huawei.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Joe Stringer <joe@ovn.org> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/20161126070354.141764-8-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-12-05tools build: Fix objtool build with clangPeter Foley
Clang doesn't support multiple arguments being passed to -Wp, so split them. Fixes this error: HOSTCC tools/objtool/fixdep.o cat: tools/objtool/.fixdep.o.d: No such file or directory Signed-off-by: Peter Foley <pefoley2@pefoley.com> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/20161128024346.17371-1-pefoley2@pefoley.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-12-05tools build: Make fixdep parsing wait for last targetJiri Olsa
The fixdep tool, among other things, replaces the target of the object in the gcc generated dependency output file. The parsing code assumes there's only single target in the rule but this is not always the case as described in here: https://gcc.gnu.org/ml/gcc-help/2016-11/msg00099.html Make the fixdep code smart enough to skip all the possible targets. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Peter Foley <pefoley2@pefoley.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/20161201130025.GA16430@krava Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-11-14tools build: Add jvmti feature detection supportJiri Olsa
Adding support to detect jvmti support. It is not plugged into the FEATURE_TESTS machinery, because it's quite rare and will be used separately from perf via feature_check call. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Stephane Eranian <eranian@google.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: William Cohen <wcohen@redhat.com> Link: http://lkml.kernel.org/r/1478093749-5602-3-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-11-14tools build: Add CFLAGS_REMOVE_* supportJiri Olsa
Adding support to remove options from final CFLAGS for both object file and build target. It's now possible to remove CFLAGS options like: CFLAGS_REMOVE_krava.o += -Wstrict-prototypes Committer notes: This comes from the kernel's kbuild infrastructure, the subset that is supported in tools/ is being documented at tools/build/Documentation/Build.txt. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Stephane Eranian <eranian@google.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: William Cohen <wcohen@redhat.com> Link: http://lkml.kernel.org/r/1478093749-5602-2-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-10-05tools build: Add feature detection for g++Wang Nan
Check if g++ is available. The result will be used by builtin clang and LLVM support. Since LLVM requires C++11, this feature detector checks std::move(). Signed-off-by: Wang Nan <wangnan0@huawei.com> Cc: Alexei Starovoitov <ast@fb.com> Cc: He Kuang <hekuang@huawei.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1474874832-134786-3-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-10-05tools build: Support compiling C++ source fileWang Nan
Add new rule to compile .cpp file to .o use g++. C++ support is required for built-in clang and LLVM support. Linker side support will be introduced by following commits. Signed-off-by: Wang Nan <wangnan0@huawei.com> Cc: Alexei Starovoitov <ast@fb.com> Cc: He Kuang <hekuang@huawei.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1474874832-134786-2-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-10-03tools build: Make fixdep a hostprogJiri Olsa
It is used in the build process, so stop suppressing its build in tools cross builds. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Madhavan Srinivasan <maddy@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: linuxppc-dev@lists.ozlabs.org Link: http://lkml.kernel.org/r/20160927141846.GA6589@krava [ Use HOSTCC on the $(OUTPUT)fixdep target, it was using the x-compiler to link fixdep-in.o, that was correctly built with HOSTCC and thus failing ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-10-03tools build: Add support for host programs formatJiri Olsa
In some cases, like for fixdep and shortly for jevents, we need to build a tool to run on the host that will be used in building a tool, such as perf, that is being cross compiled, so do like the kernel and provide HOSTCC, HOSTLD and HOSTAR to do that. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Requested-by: Andi Kleen <andi@firstfloor.org> Requested-and-Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Madhavan Srinivasan <maddy@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: linuxppc-dev@lists.ozlabs.org Link: http://lkml.kernel.org/r/20160927141846.GA6589@krava Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-13perf build: Add sdt feature detectionMasami Hiramatsu
This checks whether sys/sdt.h is available or not, which is required for DTRACE_PROBE(). We can disable this feature by passing NO_SDT=1 when building. This flag will be used for SDT test case and further SDT events in perftools. Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> Cc: Brendan Gregg <brendan.d.gregg@gmail.com> Cc: Hemant Kumar <hemant@linux.vnet.ibm.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/146831795615.17065.17513820540591053933.stgit@devbox Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-12perf tools: Add feature detection for gelf_getnote()Arnaldo Carvalho de Melo
That is not present on some libelf implementations, such as the one used in Alpine Linux: libelf-0.8.13. This ends up disabling the SDT code, that relies on this function. One alternative would be to provide an weak fallback implementation or the open coded variant used by the buildid sysfs notes reading code. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> Cc: Brendan Gregg <brendan.d.gregg@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Hemant Kumar <hemant@linux.vnet.ibm.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-82lh22ybedy9b9lych8xj12g@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-04perf build: Add feature detection for libelf's elf_getshdrstrndx()Arnaldo Carvalho de Melo
That appeared after 0.140, and will be used in the SDT code, so, to avoid bisection break on older systems, add a feature detection and provide a stub with a pr_debug() to keep it building. Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> Cc: Brendan Gregg <brendan.d.gregg@gmail.com> Cc: Hemant Kumar <hemant@linux.vnet.ibm.com> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-80y0eldgweorqnwha9rvfxjr@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-05-26Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: - new option CONFIG_TRIM_UNUSED_KSYMS which does a two-pass build and unexports symbols which are not used in the current config [Nicolas Pitre] - several kbuild rule cleanups [Masahiro Yamada] - warning option adjustments for gcov etc [Arnd Bergmann] - a few more small fixes * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: (31 commits) kbuild: move -Wunused-const-variable to W=1 warning level kbuild: fix if_change and friends to consider argument order kbuild: fix adjust_autoksyms.sh for modules that need only one symbol kbuild: fix ksym_dep_filter when multiple EXPORT_SYMBOL() on the same line gcov: disable -Wmaybe-uninitialized warning gcov: disable tree-loop-im to reduce stack usage gcov: disable for COMPILE_TEST Kbuild: disable 'maybe-uninitialized' warning for CONFIG_PROFILE_ALL_BRANCHES Kbuild: change CC_OPTIMIZE_FOR_SIZE definition kbuild: forbid kernel directory to contain spaces and colons kbuild: adjust ksym_dep_filter for some cmd_* renames kbuild: Fix dependencies for final vmlinux link kbuild: better abstract vmlinux sequential prerequisites kbuild: fix call to adjust_autoksyms.sh when output directory specified kbuild: Get rid of KBUILD_STR kbuild: rename cmd_as_s_S to cmd_cpp_s_S kbuild: rename cmd_cc_i_c to cmd_cpp_i_c kbuild: drop redundant "PHONY += FORCE" kbuild: delete unnecessary "@:" kbuild: mark help target as PHONY ...
2016-05-11perf build: Add build-test for debug-frame on arm/arm64He Kuang
Debug-frame for remote platforms is not related to the host platform, so we should test each platform separately. Signed-off-by: He Kuang <hekuang@huawei.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ekaterina Tumanova <tumanova@linux.vnet.ibm.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Kan Liang <kan.liang@intel.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/1462866037-30382-5-git-send-email-hekuang@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-05-11perf build: Add build-test for libunwind cross-platforms supportHe Kuang
Currently only test for local libunwind. We should check all supported platforms so we can use them to parse perf.data with callchain info on different machines. Signed-off-by: He Kuang <hekuang@huawei.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ekaterina Tumanova <tumanova@linux.vnet.ibm.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Kan Liang <kan.liang@intel.com> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/1462866037-30382-4-git-send-email-hekuang@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-04-28bpf tools: Fix syscall argumentFlorian Fainelli
Coverity flagged this under CID 1354884 as a sizeof mismatch, it turns out that the argument "attr" passed to syscall should have been a pointer to attr in the first place. Reported-by: coverity (CID 1354884) Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Acked-by: Wang Nan <wangnan0@huawei.com> Cc: Jiri Olsa <jolsa@kernel.org> Fixes: 8f9e05fb298f ("perf tools: Fix PowerPC native building") Link: http://lkml.kernel.org/r/1461551694-5512-3-git-send-email-f.fainelli@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-04-28bpf tools: Remove expression with no effectFlorian Fainelli
Assigning "attr" to "attr" does not have any effect, but was caught by Coverity, so let's remove this. Reported-by: coverity (CID 1354720) Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Tested-by: Wang Nan <wangnan0@huawei.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Cc: Jiri Olsa <jolsa@kernel.org> Fixes: 1b76c13e4b36 ("bpf tools: Introduce 'bpf' library and add bpf feature check") Link: http://lkml.kernel.org/r/1461551694-5512-2-git-send-email-f.fainelli@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-04-20kbuild: rename cmd_cc_i_c to cmd_cpp_i_cMasahiro Yamada
This command just preprocesses .c files into .i files, so cmd_cpp_i_c seems more suitable. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.com>
2016-04-06perf probe: Check if dwarf_getlocations() is availableArnaldo Carvalho de Melo
If not, tell the user that: config/Makefile:273: Old libdw.h, finding variables at given 'perf probe' point will not work, install elfutils-devel/libdw-dev >= 0.157 And return -ENOTSUPP in die_get_var_range(), failing features that need it, like the one pointed out above. This fixes the build on older systems, such as Ubuntu 12.04.5. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Vinson Lee <vlee@freedesktop.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-9l7luqkq4gfnx7vrklkq4obs@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-03-03tools build: Use .s extension for preprocessed assembler codeMasahiro Yamada
The "man gcc" says .i extension represents the file is C source code that should not be preprocessed. Here, .s should be used. For clarification, .c ---(preprocess)---> .i .S ---(preprocess)---> .s Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Aaro Koskinen <aaro.koskinen@nokia.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Lukas Wunner <lukas@wunner.de> Link: http://lkml.kernel.org/r/1454263140-19670-1-git-send-email-yamada.masahiro@socionext.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-02-05perf build: Add libcrypto feature detectionStephane Eranian
Will be used to generate build-ids in the jitdump code. Signed-off-by: Stephane Eranian <eranian@google.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Carl Love <cel@us.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: John McCutchan <johnmccutchan@google.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sonny Rao <sonnyrao@chromium.org> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1448874143-7269-3-git-send-email-eranian@google.com [ tools/perf/Makefile.perf comment about NO_LIBCRYPTO and added it to tests/make ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-01-28perf build: Fix feature-dump checks, we need to test all featuresJiri Olsa
I see problem with test-all case speedup, because it does not comprise checks for 32bits compilations, fix it. The problem could be noticed by calling: make -C tools/perf feature-dump That would end up misdetecting the feature-compile-x32, that, building using 'gcc -mx32' needs stub headers not present in a fedora 23 devel machine and thus fail to compile, but ended up appearing as detected, i.e. present in tools/perf/FEATURE-DUMP as 'feature-compile-x32=1'. With this fix it correctly appears as 'feature-compile-x32=0' and if we uninstall the libc devel files for 32 bits (glibc-devel.i686), then the relevant variable is flipped from 'feature-compile-32=1' to 'feature-compile-32=0'. The same things happened for bionic and libbabeltrace, that were misdetected because the are no tested in test-all.c Reported-and-Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-u0sjaddf1r9m8icpd98ry7fz@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
