path: root/tools/firewire/nosy-dump.h
2010-07-27tools/firewire: nosy-dump: use linux/firewire-constants.hStefan Richter
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2010-07-27tools/firewire: nosy-dump: change to kernel coding styleStefan Richter
This changes only - whitespace - C99 initializers - comment style - order of #includes - if { } else { } bracing Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2010-07-27tools/firewire: nosy-dump: fix it on x86-64Stefan Richter
Replace 'unsigned long' and the (unaffected) 'unsigned int' by uint32_t if they represent quadlets. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2010-07-27tools/firewire: add userspace front-end of nosyStefan Richter
This adds nosy-dump, the userspace part of nosy, the IEEE 1394 traffic sniffer for Texas Instruments PCILynx/ PCILynx2 based cards. Author is Kristian Høgsberg. The files added here are taken from git://anongit.freedesktop.org/~krh/nosy commit ee29be97 (2009-11-10) with the following changes by Stefan Richter: - Parts pertaining to the kernel module removed from Makefile. - dist target removed from the Makefile. - Mentioned nosy-dump in the Kconfig help to nosy's kernel component. - Add copyright notice to nosy-dump.c. This is a duplicate of the respective notice in the kernel component nosy.c except for a time span of 2002 - 2006, according to Kristian's git log. "git shortlog decode-fcp.c list.h nosy-dump.[ch]" from nosy's git repository: Jonathan Woithe (1): Save logs on Ctrl-C Kristian Høgsberg (11): Pull over nosy from mercurial repo. Remove some fields from default view, add logging feature. Use infinite time out for poll(), mark more detail fields. Fix byte ordering macro. Add decoding of iso data and lock packets. Add flag to indicate data length field. Add cycle start packet decoding, add --iso and --cycle-start flags. Distinguish between phy-packets and 0-length iso data. Fix transaction and stats view. Add simple AV/C decoder. Don't break down on big payloads. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Kristian Høgsberg <krh@bitplanet.net>
