Initial patch by Ben Hutchings <ben@decadent.org.uk>
Standard C strings are arrays of char, not __u8 (unsigned char).
Declare variables and parameters accordingly, and add the necessary
casts.
Signed-off-by: Tomas Hozza <thozza@redhat.com>
Acked-by: K. Y. Srinivasan <kys@microsoft.com>
The source code without this patch caused hypervkvpd to exit when it processed
a spoofed Netlink packet which has been sent from an untrusted local user.
Now Netlink messages with a non-zero nl_pid source address are ignored
and a warning is printed into the syslog.
Don't return loopback addresses and further don't terminate
the IP address strings with a semicolon. This is the current
behavior of Windows guests.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com>
Reported-by: Claudio Latini <claudio.latini@live.com>
Currently, we are returning the same string for both OSBuildNumber
and OSVersion keys. Return the full uts string for the OSBuild
key since Windows does not impose any restrictions on this.
There is a new convention, used by systemd and supported by most
distributions, to put basic OS release information in /etc/os-release.
Added some additional error checking on strdup()
hv_kvp_daemon currently does not check whether fread() or fwrite()
succeed. Add the necessary checks. Also, remove the incorrect use of
feof() before fread().
Cc: stable@vger.kernel.org
Linux native exit codes are 8-bit unsigned values. exit(-1) results
in an exit code of 255, which is usually reserved for shells reporting
'command not found'. Use the portable value EXIT_FAILURE. (Not that
this matters much for a daemon.)
Match up each fopen() with an fclose().
Now implement the KVP verb - KVP_OP_GET_IP_INFO. This operation retrieves IP
information for the specified interface.
Rename the function kvp_get_ip_address() to better reflect the functionality
being implemented.
Implement the KVP verb - KVP_OP_SET_IP_INFO. This operation configures the
specified interface based on the given configuration. Since configuring
an interface is very distro specific, we invoke an external (Distro specific)
script to configure the interface.
Collect information on dhcp setting for the specified interface.
We invoke an external (Distro specific) script to get this information.
Now, gather DNS information. Invoke an external script (that can be
distro dependent) to gather the DNS information.
Correctly type character strings.
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Get rid of unused variables.
Gather information on the default gateways - ipv4/ipv6.
Transform ipv6 subnet information to CIDR notation.
Now, gather sub-net information for the specified interface.
Now, gather address family information for the specified interface.
In preparation for making kvp_get_ip_address() more generic, factor out
the code for handling IP addresses.
kvp_get_ip_address() implemented the functionality to retrieve IP address info.
Make this function more generic so that we could retrieve additional
per-interface information.
In preparation to implementing IP injection, cleanup the way we propagate
and handle errors both in the driver as well as in the user level daemon.
Reviewed-by: Olaf Hering <olaf@aepfle.de>
Reviewed-by: Ben Hutchings <ben@decadent.org.uk>
Add the necessary definitions for supporting the IP injection functionality.
The SuSE security team suggested to use recvfrom instead of recv to be
certain that the connector message is originated from kernel.
CVE-2012-2669
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Signed-off-by: Marcus Meissner <meissner@suse.de>
Signed-off-by: Sebastian Krahmer <krahmer@suse.de>
Cc: stable <stable@vger.kernel.org>
We have only supported enumeration only from the AUTO pool. Now support
enumeration from all the available pools.
Reviewed-by: Dan Carpenter <dan.carpenter@oracle.com>
Now fully support the new KVP messages in the user level daemon. Hyper-V defines
multiple persistent pools to which the host can write/read/modify KVP tuples.
In this patch we implement a file for each specified pool, where the KVP tuples
will be stored in the guest.
Support the newly defined KVP message types. It turns out that the host
pushes a set of standard key value pairs as soon as the guest opens the KVP channel.
Since we cannot handle these tuples until the user level daemon loads up, defer
reading the KVP channel until the user level daemon is launched.
Add additional KVP (Key Value Pair) protocol messages to
enhance KVP functionality for Linux guests on Hyper-V. As part of this,
patch define an explicit version negoitiation message.
Now, cleanup the user/kernel KVP protocol by using the same structure
definition that is used for host/guest KVP protocol. This simplifies the code.
Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com>
Now use hyperv.h to get the KVP defines in the KVP user-mode code.
The current KVP code carries some private connector related defines.
Update connector.h to have all the KVP defines. As part of this patch
get rid of some unused defines.
After many years wandering the desert, it is finally time for the
Microsoft HyperV code to move out of the staging directory. Or at least
the core hyperv bus code, and the utility driver, the rest still have
some review to get through by the various subsystem maintainers.
