path: root/tools/hv
2012-10-17tools/hv: Fix exit() error codeBen Hutchings
commit 6bb22fea25624ab593eee376fa5fb82d1b13f45a upstream. Linux native exit codes are 8-bit unsigned values. exit(-1) results in an exit code of 255, which is usually reserved for shells reporting 'command not found'. Use the portable value EXIT_FAILURE. (Not that this matters much for a daemon.) Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> [bwh: Backported to 3.2: drop changes to exit() calls not in this version]
2012-07-04Tools: hv: verify origin of netlink connector messageOlaf Hering
commit bcc2c9c3fff859e0eb019fe6fec26f9b8eba795c upstream. The SuSE security team suggested to use recvfrom instead of recv to be certain that the connector message is originated from kernel. CVE-2012-2669 Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Marcus Meissner <meissner@suse.de> Signed-off-by: Sebastian Krahmer <krahmer@suse.de> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2011-10-10Staging: hv: move hyperv code out of staging directoryGreg Kroah-Hartman
After many years wandering the desert, it is finally time for the Microsoft HyperV code to move out of the staging directory. Or at least the core hyperv bus code, and the utility driver, the rest still have some review to get through by the various subsystem maintainers. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
