commit 297d6b6e56c2977fc504c61bbeeaa21296923f89 upstream.
While reading in more than one block (50) of KVP records, the allocation
goes per block, but the reads used the total number of allocated records
(without resetting the pointer/stream). This causes the records buffer to
overrun when the refresh reads more than one block over the previous
capacity (e.g. reading more than 100 KVP records whereas the in-memory
database was empty before).
Fix this by reading the correct number of KVP records from file each time.
Signed-off-by: Paul Meyer <Paul.Meyer@microsoft.com>
Signed-off-by: Long Li <longli@microsoft.com>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
commit 26840437cbd6d3625ea6ab34e17cd34bb810c861 upstream.
KVP daemon does fork()/exec() (with popen()) so we need to close our fds
to avoid sharing them with child processes. The immediate implication of
not doing so I see is SELinux complaining about 'ip' trying to access
'/dev/vmbus/hv_kvp'.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
[ Upstream commit b4ed5d1682c6613988c2eb1de55df5ac9988afcc ]
Currently some "Unspecified error 0x80004005" is reported on the Windows
side if something fails. Handle the ENOSPC case and return
ERROR_DISK_FULL, which allows at least Copy-VMFile to report a meaning
full error.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
commit 50fe6dd10069e7c062e27f29606f6e91ea979399 upstream.
Use the local uapi headers to keep in sync with "recently" added #define's
(e.g. VSS_OP_REGISTER1).
Fixes: 3eb2094c59e8 ("Adding makefile for tools/hv")
Signed-off-by: Kamal Mostafa <kamal@canonical.com>
commit a689d2510f188e75391dbebacbddfd74d42f2a7e upstream.
Fix the write()'s argument in the daemon code.
Cc: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: "K. Y. Srinivasan" <kys@microsoft.com>
Signed-off-by: Dexuan Cui <decui@microsoft.com>
By default lsvmbus lists all the devices in the VMBus.
With -v or -vv, more information is printed, including the VMBus
Rel_ID, class ID, device ID and which channel is bound to which
virtual processor, etc.
Introduce FCOPY_VERSION_1 to support kernel replying to the negotiation
message with its own version.
Tested-by: Alex Ng <alexng@microsoft.com>
Introduce VSS_OP_REGISTER1 to support kernel replying to the negotiation
Use /dev/vmbus/hv_vss instead of netlink.
Use /dev/vmbus/hv_kvp instead of netlink.
If freeze fails, vss_operate will re-enter itself to thaw. But it forgets
to call endmntent() before it recalls setmntent() again.
Signed-off-by: Vaughan Cao <vaughan.cao@oracle.com>
Without this patch, hv_fcopy_daemon's hv_copy_data() -> pwrite()
will fail for >2GB file offset.
The current char-next branch is broken and this patch fixes
the bug.
Signed-off-by: Alex Ng <alexng@microsoft.com>
Cc: K. Y. Srinivasan <kys@microsoft.com>
We don't need to add additional '/' to smsg->path_name as snprintf("%s/%s")
does the right thing. Without the patch we get doubled '//' in the log message.
This patch addresses two types of compiler warnings:
... warning: unused variable .fd. [-Wunused-variable]
and
... warning: format .%s. expects argument of type .char *., but argument 5 has type .__u16 *. [-Wformat=]
... warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
and
... warning: pointer targets in passing argument N of .kvp_.... differ in signedness [-Wpointer-sign]
fwrite() does not actually return the number of bytes written and
this value is being ignored anyway and ferror() is being called to
check for an error. As we assign to this variable and never use it
we get the following compile-time warning:
hv_kvp_daemon.c:149:9: warning: variable .bytes_written. set but not used [-Wunused-but-set-variable]
Remove bytes_written completely.
In the case the host only injects an IPv6 address, the dhcp_enabled flag is
true (it's only for IPv4 according to Hyper-V host team), but we still need to
proceed to parse the IPv6 information.
Reviewed-By: Vitaly Kuznetsov <vkuznets@redhat.com>
hv_fcopy_daemon is not mentioned in Makefile so it must be built
manually. Add hv_fcopy_daemon to Makefile.
Signed-off-by: Matej Muzila <mmuzila@redhat.com>
Under high memory pressure and very high KVP R/W test pressure, the netlink
recvfrom() may transiently return ENOBUFS to the daemon -- we found this
during a 2-week stress test.
We'd better not terminate the daemon on the failure, because a typical KVP
user will re-try the R/W and hopefully it will succeed next time.
We can also ignore the errors on sending.
Reviewed-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Instead of making a list of exceptions for readonly filesystems
in addition to iso9660 we already have it is better to skip freeze
operation for all readonly-mounted filesystems.
Acked-by: Dexuan Cui <decui@microsoft.com>
When ioctl(fd, FIFREEZE, 0) results in an error we cannot report it
to syslog instantly since that can cause write to a frozen disk.
However, the name of the filesystem which caused the error and errno
are valuable and we would like to get a nice human-readable message
in the log. Save errno before calling vss_operate(VSS_OP_THAW) and
report the error right after.
Unfortunately, FITHAW errors cannot be reported the same way as we
need to finish thawing all filesystems before calling syslog().
We should also avoid calling endmntent() for the second time in
case we encountered an error during freezing of '/' as it usually
results in SEGSEGV.
All tools/hv daemons do mandatory daemon() on startup. However, no pidfile
is created, this make it difficult for an init system to track such daemons.
Modern linux distros use systemd as their init system. It can handle the
daemonizing by itself, however, it requires a daemon to stay in foreground
for that. Some distros already carry distro-specific patch for hv tools
which switches off daemon().
Introduce -n/--no-daemon option for all 3 daemons in hv/tools. Parse options
with getopt() to make this part easily expandable.
If a partition appears mounted more than once in /proc/mounts, vss_do_freeze()
succeeds only for the first time and gets EBUSY (on freeze) or EINVAL (on
thaw) for the second time. The patch ignores these to make the backup feature
work.
Also improved the error handling in case a freeze operation fails.
Reviewed-by: K. Y. Srinivasan <kys@microsoft.com>
hv_fcopy_daemon fails to overwrite a file if the target file already
exits.
Add O_TRUNC flag on opening.
Signed-off-by: Yue Zhang <yuezha@microsoft.com>
Return the appropriate error code and handle the case when the target
file exists correctly. This fixes a bug.
Cc: <stable@vger.kernel.org> [3.14]
Implement the file copy service for Linux guests on Hyper-V. This permits the
host to copy a file (over VMBUS) into the guest. This facility is part of
"guest integration services" supported on the Windows platform.
Here is a link that provides additional details on this functionality:
http://technet.microsoft.com/en-us/library/dn464282.aspx
In V1 version of the patch I have addressed comments from
Olaf Hering <olaf@aepfle.de> and Dan Carpenter <dan.carpenter@oracle.com>
In V2 version of this patch I did some minor cleanup (making some globals
static). In V4 version of the patch I have addressed all of Olaf's
most recent set of comments/concerns.
In V5 version of the patch I had addressed Greg's most recent comments.
I would like to thank Greg for suggesting that I use misc device; it has
significantly simplified the code.
In V6 version of the patch I have cleaned up error message based on Olaf's
comments. I have also rebased the patch based on the current tip.
In this version of the patch, I have addressed the latest comments from Greg.
If the guest has a FAT file system mounted, skip it during the FREEZE
operation. With this change we can support host initiated backup of
the guest even when the guest may have FAT file systems mounted.
Currently, there is no makefile for the Hyper-V tools.
This patch adds the missing makefile, and adds it to the main tools makefile.
Signed-off-by: Bjarke Istrup Pedersen <gurligebis@gentoo.org>
With very old libc headers the inclusion of sys/types.h causes conflicts
with linux/types.h. Since the latter is not required anyway, remove it
from the source files. If any of the headers really needs linux/types.h
it has to include it itself.
send_buffer is used only once during registration. To reduce runtime
memory usage reuse the recv_buffer for registration. Also use
NLMSG_LENGTH instead of NLMSG_HDRLEN to take alignment into account.
kvp_daemon does some operations which take an unpredicable amount of
time. In addition the kernel driver gives the kvp_daemon a 5 second
timeout to respond to message from the host. If an operation such as
getaddrinfo takes a long time and the timeout triggers then netlink
errors occour. As a result of such errors the daemon just terminates and
the service becomes unavailable.
Idendifying and fixing these shortcomings in the kernel-userland
communication protocol will be done in separate patches. This change
fixes just one obvious timeout bug.
Update kvp_get_domain_name to not return a value, better diagnostic for
the consumer of the hostname string, remove trailing newline in error
case, use snprintf to not overrun output buffer, get hostname only once
and return the cached result.
There is no need to have a nlmsghdr pointer to another temporary buffer.
Instead use a full struct nlmsghdr.
netlink_send is supposed to send just the cn_msg+hv_kvp_msg via netlink.
Currently it sets an incorrect iovec size, as reported by valgrind.
In the case of registering with the kernel the allocated buffer is large
enough to hold nlmsghdr+cn_msg+hv_kvp_msg, no overrun happens. In the
case of responding to the kernel the cn_msg is located in the middle of
recv_buffer, after the nlmsghdr. Currently the code in netlink_send adds
also the size of nlmsghdr to the payload. But nlmsghdr is a separate
iovec. This leads to an (harmless) out-of-bounds access when the kernel
processes the iovec. Correct the iovec size of the cn_msg to be just
cn_msg + its payload.
hv_kvp_daemon.c: In function 'main':
hv_kvp_daemon.c:1441:8: warning: ignoring return value of 'daemon', declared with attribute warn_unused_result [-Wunused-result]
... to simplify error path in upcoming changes.
hv_kvp_daemon fails to start in current openSuSE 13.1 snapshots because
the kvp_send_buffer is too small to hold cn_msg+hv_kvp_msg, the very
first sendmsg returns with EFAULT. In addition it fixes the Network info
tab in Windows Server 2012R2 in SLES11.
Adjust the code in kvp and vss daemon to allocate the needed buffers at
runtime. To keep the code simple, the buffer_len includes also the
nlmsghdr, although only the recv_buffer needs this extra space.
This resolves a merge issue with:
drivers/misc/mei/init.c
Check return value of setsockopt call and if it fails print error to the
system log and exit with non-zero value.
Signed-off-by: Tomas Hozza <thozza@redhat.com>
Check return value of poll call and if it fails print error to the
system log. If errno is EINVAL then exit with non-zero value otherwise
continue the while loop and call poll again.
Use errno and strerror() when logging errors to provide more
information.
Each subnet string needs to be separated with a semicolon. Fix this bug.
Cc: Stable <stable@vger.kernel.org>
more information.
Close "fd" file descriptor when is goes out of scope so it does
not leak.
Acked-by: K. Y. Srinivasan <kys@microsoft.com>
Check return value of strchr call and dereference it only if it is
not NULL.
to the system log. If errno is EINVAL then exit with non-zero
value otherwise continue the while loop and call poll again.
to the system log and exit with non-zero value.
Fix a checkpatch warning.
fsreeze does not work for iso9660 filesystems. A ENOSUPP may be caught
in the freeze case, but the subsequent thaw call would fail and leads to
a false error.
As suggested by Paolo Bonzini, use ioctl instead of calling fsfreeze.
