path: root/tools/lib
2015-07-09tools: Copy lib/hweight.c from the kernel sourcesArnaldo Carvalho de Melo
Instead of accessing it directly, as it uses EXPORT_SYMBOL, that has no meaning in tools/perf and because we removed the stubs for it, i.e. we removed the tools/include/linux/export.h file. This fixes the build for the detached tarball sources cases and removes one more source of entanglement with the kernel sources. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-oyqx541o7apa2cskjhcxi6nx@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-08tools lib: Improve clean targetRiku Voipio
The clean targets miss some .cmd and .d files. Signed-off-by: Riku Voipio <riku.voipio@linaro.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: linux-kbuild@vger.kernel.org Link: http://lkml.kernel.org/r/1434631938-12681-1-git-send-email-riku.voipio@linaro.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-05tools: Copy lib/rbtree.c to tools/lib/Arnaldo Carvalho de Melo
So that we can remove kernel specific stuff we've been stubbing out via a tools/include/linux/export.h that gets removed in this patch and to avoid breakages in the future like the one fixed recently where rcupdate.h started being used in rbtree.h. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-rxuzfsozpb8hv1emwpx06rm6@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-06-08tools lib traceevent: Ignore libtrace-dynamic-list fileHe Kuang
The libtrace-dynamic-list file is used to export symbols used by traceevent plugins. Signed-off-by: He Kuang <hekuang@huawei.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/1432819735-35040-2-git-send-email-hekuang@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-06-08tools lib traceevent: Export dynamic symbols used by traceevent pluginsHe Kuang
Traceevent plugins need dynamic symbols exported from libtraceevent.a, otherwise a dlopen error will occur during plugins loading. This patch uses dynamic-list-file to export dynamic symbols which will be used in plugins to perf executable. The problem is covered up if feature-libpython is enabled, because PYTHON_EMBED_LDOPTS contains '-Xlinker --export-dynamic' which adds all symbols to the dynamic symbol table. So we should reproduce the problem by setting NO_LIBPYTHON=1. Before this patch: (Prepare plugins) $ ls /root/.traceevent/plugins/ plugin_sched_switch.so plugin_function.so ... $ perf record -e 'ftrace:function' ls $ perf script Warning: could not load plugin '/mnt/data/root/.traceevent/plugins/plugin_sched_switch.so' /root/.traceevent/plugins/plugin_sched_switch.so: undefined symbol: pevent_unregister_event_handler Warning: could not load plugin '/root/.traceevent/plugins/plugin_function.so' /root/.traceevent/plugins/plugin_function.so: undefined symbol: warning ... :1049 1049 [000] 9666.754487: ftrace:function: ffffffff8118bc50 <-- ffffffff8118c5b3 :1049 1049 [000] 9666.754487: ftrace:function: ffffffff818e2440 <-- ffffffff8118bc75 :1049 1049 [000] 9666.754487: ftrace:function: ffffffff8106eee0 <-- ffffffff811212e2 After this patch: $ perf record -e 'ftrace:function' ls $ perf script :1049 1049 [000] 9666.754487: ftrace:function: __set_task_comm :1049 1049 [000] 9666.754487: ftrace:function: _raw_spin_lock :1049 1049 [000] 9666.754487: ftrace:function: task_tgid_nr_ns ... Signed-off-by: He Kuang <hekuang@huawei.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/1432819735-35040-1-git-send-email-hekuang@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-05-27Merge branch 'perf/urgent' into perf/core, before applying dependent patchesIngo Molnar
2015-05-18tools lib traceevent: Install libtraceevent.a into libdirWang Nan
Before this patch, 'make install' installs libraries into bindir: $ make install DESTDIR=./tree INSTALL trace_plugins INSTALL libtraceevent.a INSTALL libtraceevent.so $ find ./tree ./tree/ ./tree/usr ./tree/usr/local ./tree/usr/local/bin ./tree/usr/local/bin/libtraceevent.a ./tree/usr/local/bin/libtraceevent.so ... /usr/local/lib( or lib64) should be a better place. This patch replaces 'bin' with libdir. For __LP64__ building, libraries are installed to /usr/local/lib64. For other building, to /usr/local/lib instead. After applying this patch: $ make install DESTDIR=./tree INSTALL trace_plugins INSTALL libtraceevent.a INSTALL libtraceevent.so $ find ./tree ./tree ./tree/usr ./tree/usr/local ./tree/usr/local/lib64 ./tree/usr/local/lib64/libtraceevent.a ./tree/usr/local/lib64/traceevent ./tree/usr/local/lib64/traceevent/plugins ./tree/usr/local/lib64/traceevent/plugins/plugin_mac80211.so ./tree/usr/local/lib64/traceevent/plugins/plugin_hrtimer.so ... ./tree/usr/local/lib64/libtraceevent.so Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: Brendan Gregg <brendan.d.gregg@gmail.com> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: David Ahern <dsahern@gmail.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: pi3orama@163.com Cc: Zefan Li <lizefan@huawei.com> Link: http://lkml.kernel.org/r/1431860222-61636-4-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-05-15Merge branch 'liblockdep-fixes' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/sashal/linux into perf/urgent Pull liblockdep fixes from Sasha Levin: "two fixes that deal with compilation errors in liblockdep." Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-14tools lib traceevent: Provide le16toh define for older systemsArnaldo Carvalho de Melo
Where such macro is not present, so just copy its definition from glibc's endian.h and define it if not already. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/n/tip-4j90i2na07ppidt0z6cbuxr7@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-05-13tools/liblockdep: Fix compilation errorEunbong Song
Recent changes to kernel/locking/lockdep.c broke the liblockdep build. Fix that. Signed-off-by: Eunbong Song <eunb.song@samsung.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-13tools/liblockdep: Fix linker error in case of cross compileEunbong Song
If we try to cross compile liblockdep, even if we set the CROSS_COMPILE variable the linker error can occur because LD is not set with CROSS_COMPILE. This patch adds "LD" can be set automatically with CROSS_COMPILE variable so fixes linker error problem. Signed-off-by: Eunbong Song <eunb.song@samsung.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-11Merge branch 'perf/urgent' into perf/core, to resolve conflictsIngo Molnar
Conflicts: tools/perf/builtin-kmem.c Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-06Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Mostly tooling fixes, but also an uncore PMU driver fix and an uncore PMU driver hardware-enablement addition" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf probe: Fix segfault if passed with ''. perf report: Fix -T/--threads option to work again perf bench numa: Fix immediate meeting of convergence condition perf bench numa: Fixes of --quiet argument perf bench futex: Fix hung wakeup tasks after requeueing perf probe: Fix bug with global variables handling perf top: Fix a segfault when kernel map is restricted. tools lib traceevent: Fix build failure on 32-bit arch perf kmem: Fix compiles on RHEL6/OL6 tools lib api: Undefine _FORTIFY_SOURCE before setting it perf kmem: Consistently use PRIu64 for printing u64 values perf trace: Disable events and drain events when forked workload ends perf trace: Enable events when doing system wide tracing and starting a workload perf/x86/intel/uncore: Move PCI IDs for IMC to uncore driver perf/x86/intel/uncore: Add support for Intel Haswell ULT (lower power Mobile Processor) IMC uncore PMUs perf/x86/intel: Add cpu_(prepare|starting|dying) for core_pmu
2015-05-06Merge tag 'perf-core-for-mingo-3' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/core Pull perf/core improvements and fixes from Arnaldo Carvalho de Melo: User visible changes: - Improve --filter support for 'perf probe', allowing using its arguments on other commands, as --add, --del, etc (Masami Hiramatsu) - Show warning when running 'perf kmem stat' on a unsuitable perf.data file, i.e. one with events that are not the ones required for the stat variant used (Namhyung Kim). Infrastructure changes: - Auxtrace support patches, paving the way to support Intel PT and BTS (Adrian Hunter) - hists browser (top, report) refactorings (Namhyung Kim) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-04-29tools lib traceevent: Add alias field to struct format_fieldJiri Olsa
Introduce an 'alias' field to 'struct format_field' to be able to use alternative name for the field. It is initialized with same string pointer as 'name' field. The free logic checks the 'alias' pointer being reset by user and frees it. This will be handy when converting data into CTF, where each field within event needs to have a unique name (while this is not required for tracepoint). Converter can easily assign unique name into the format_field struct. Suggested-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: He Kuang <hekuang@huawei.com> Cc: Jeremie Galarneau <jgalar@efficios.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-qwyq8blnfkg6s5vlbrvn1en3@git.kernel.org Link: http://lkml.kernel.org/r/1429372220-6406-6-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-04-24tools lib traceevent: Fix build failure on 32-bit archNamhyung Kim
In my i386 build, it failed like this: CC event-parse.o event-parse.c: In function 'print_str_arg': event-parse.c:3868:5: warning: format '%lu' expects argument of type 'long unsigned int', but argument 3 has type 'uint64_t' [-Wformat] Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Javi Merino <javi.merino@arm.com> Link: http://lkml.kernel.org/r/20150424020218.GF1905@sejong Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-04-23tools lib api: Undefine _FORTIFY_SOURCE before setting itBobby Powers
Some toolchains (like Hardened Gentoo) define _FORTIFY_SOURCE in the built-in, default args. This causes perf builds to fail with: <command-line>:0:0: error: "_FORTIFY_SOURCE" redefined [-Werror] <built-in>: note: this is the location of the previous definition cc1: all warnings being treated as errors To avoid this, undefine _FORTIFY_SOURCE before (possibly re-)defining it in tools/lib/api. v2 applies cleanly on top of already pulled kbuild changes for 4.1-rc1. Signed-off-by: Bobby Powers <bobbypowers@gmail.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Dirk Gouders <dirk@gouders.net> Cc: Michal Marek <mmarek@suse.cz> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: linux-kbuild@vger.kernel.org Link: http://lkml.kernel.org/r/1429658381-3039-1-git-send-email-bobbypowers@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-04-14Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf changes from Ingo Molnar: "Core kernel changes: - One of the more interesting features in this cycle is the ability to attach eBPF programs (user-defined, sandboxed bytecode executed by the kernel) to kprobes. This allows user-defined instrumentation on a live kernel image that can never crash, hang or interfere with the kernel negatively. (Right now it's limited to root-only, but in the future we might allow unprivileged use as well.) (Alexei Starovoitov) - Another non-trivial feature is per event clockid support: this allows, amongst other things, the selection of different clock sources for event timestamps traced via perf. This feature is sought by people who'd like to merge perf generated events with external events that were measured with different clocks: - cluster wide profiling - for system wide tracing with user-space events, - JIT profiling events etc. Matching perf tooling support is added as well, available via the -k, --clockid <clockid> parameter to perf record et al. (Peter Zijlstra) Hardware enablement kernel changes: - x86 Intel Processor Trace (PT) support: which is a hardware tracer on steroids, available on Broadwell CPUs. The hardware trace stream is directly output into the user-space ring-buffer, using the 'AUX' data format extension that was added to the perf core to support hardware constraints such as the necessity to have the tracing buffer physically contiguous. This patch-set was developed for two years and this is the result. A simple way to make use of this is to use BTS tracing, the PT driver emulates BTS output - available via the 'intel_bts' PMU. More explicit PT specific tooling support is in the works as well - will probably be ready by 4.2. (Alexander Shishkin, Peter Zijlstra) - x86 Intel Cache QoS Monitoring (CQM) support: this is a hardware feature of Intel Xeon CPUs that allows the measurement and allocation/partitioning of caches to individual workloads. These kernel changes expose the measurement side as a new PMU driver, which exposes various QoS related PMU events. (The partitioning change is work in progress and is planned to be merged as a cgroup extension.) (Matt Fleming, Peter Zijlstra; CPU feature detection by Peter P Waskiewicz Jr) - x86 Intel Haswell LBR call stack support: this is a new Haswell feature that allows the hardware recording of call chains, plus tooling support. To activate this feature you have to enable it via the new 'lbr' call-graph recording option: perf record --call-graph lbr perf report or: perf top --call-graph lbr This hardware feature is a lot faster than stack walk or dwarf based unwinding, but has some limitations: - It reuses the current LBR facility, so LBR call stack and branch record can not be enabled at the same time. - It is only available for user-space callchains. (Yan, Zheng) - x86 Intel Broadwell CPU support and various event constraints and event table fixes for earlier models. (Andi Kleen) - x86 Intel HT CPUs event scheduling workarounds. This is a complex CPU bug affecting the SNB,IVB,HSW families that results in counter value corruption. The mitigation code is automatically enabled and is transparent. (Maria Dimakopoulou, Stephane Eranian) The perf tooling side had a ton of changes in this cycle as well, so I'm only able to list the user visible changes here, in addition to the tooling changes outlined above: User visible changes affecting all tools: - Improve support of compressed kernel modules (Jiri Olsa) - Save DSO loading errno to better report errors (Arnaldo Carvalho de Melo) - Bash completion for subcommands (Yunlong Song) - Add 'I' event modifier for perf_event_attr.exclude_idle bit (Jiri Olsa) - Support missing -f to override perf.data file ownership. (Yunlong Song) - Show the first event with an invalid filter (David Ahern, Arnaldo Carvalho de Melo) User visible changes in individual tools: 'perf data': New tool for converting perf.data to other formats, initially for the CTF (Common Trace Format) from LTTng (Jiri Olsa, Sebastian Siewior) 'perf diff': Add --kallsyms option (David Ahern) 'perf list': Allow listing events with 'tracepoint' prefix (Yunlong Song) Sort the output of the command (Yunlong Song) 'perf kmem': Respect -i option (Jiri Olsa) Print big numbers using thousands' group (Namhyung Kim) Allow -v option (Namhyung Kim) Fix alignment of slab result table (Namhyung Kim) 'perf probe': Support multiple probes on different binaries on the same command line (Masami Hiramatsu) Support unnamed union/structure members data collection. (Masami Hiramatsu) Check kprobes blacklist when adding new events. (Masami Hiramatsu) 'perf record': Teach 'perf record' about perf_event_attr.clockid (Peter Zijlstra) Support recording running/enabled time (Andi Kleen) 'perf sched': Improve the performance of 'perf sched replay' on high CPU core count machines (Yunlong Song) 'perf report' and 'perf top': Allow annotating entries in callchains in the hists browser (Arnaldo Carvalho de Melo) Indicate which callchain entries are annotated in the TUI hists browser (Arnaldo Carvalho de Melo) Add pid/tid filtering to 'report' and 'script' commands (David Ahern) Consider PERF_RECORD_ events with cpumode == 0 in 'perf top', removing one cause of long term memory usage buildup, i.e. not processing PERF_RECORD_EXIT events (Arnaldo Carvalho de Melo) 'perf stat': Report unsupported events properly (Suzuki K. Poulose) Output running time and run/enabled ratio in CSV mode (Andi Kleen) 'perf trace': Handle legacy syscalls tracepoints (David Ahern, Arnaldo Carvalho de Melo) Only insert blank duration bracket when tracing syscalls (Arnaldo Carvalho de Melo) Filter out the trace pid when no threads are specified (Arnaldo Carvalho de Melo) Dump stack on segfaults (Arnaldo Carvalho de Melo) No need to explicitely enable evsels for workload started from perf, let it be enabled via perf_event_attr.enable_on_exec, removing some events that take place in the 'perf trace' before a workload is really started by it. (Arnaldo Carvalho de Melo) Allow mixing with tracepoints and suppressing plain syscalls. (Arnaldo Carvalho de Melo) There's also been a ton of infrastructure work done, such as the split-out of perf's build system into tools/build/ and other changes - see the shortlog and changelog for details" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (358 commits) perf/x86/intel/pt: Clean up the control flow in pt_pmu_hw_init() perf evlist: Fix type for references to data_head/tail perf probe: Check the orphaned -x option perf probe: Support multiple probes on different binaries perf buildid-list: Fix segfault when show DSOs with hits perf tools: Fix cross-endian analysis perf tools: Fix error path to do closedir() when synthesizing threads perf tools: Fix synthesizing fork_event.ppid for non-main thread perf tools: Add 'I' event modifier for exclude_idle bit perf report: Don't call map__kmap if map is NULL. perf tests: Fix attr tests perf probe: Fix ARM 32 building error perf tools: Merge all perf_event_attr print functions perf record: Add clockid parameter perf sched replay: Use replay_repeat to calculate the runavg of cpu usage instead of the default value 10 perf sched replay: Support using -f to override perf.data file ownership perf sched replay: Fix the EMFILE error caused by the limitation of the maximum open files perf sched replay: Handle the dead halt of sem_wait when create_tasks() fails for any task perf sched replay: Fix the segmentation fault problem caused by pr_err in threads perf sched replay: Realloc the memory of pid_to_task stepwise to adapt to the different pid_max configurations ...
2015-04-08tools lib traceevent: Honor operator priorityNamhyung Kim
Currently it ignores operator priority and just sets processed args as a right operand. But it could result in priority inversion in case that the right operand is also a operator arg and its priority is lower. For example, following print format is from new kmem events. "page=%p", REC->pfn != -1UL ? (((struct page *)(0xffffea0000000000UL)) + (REC->pfn)) : ((void *)0) But this was treated as below: REC->pfn != ((null - 1UL) ? ((struct page *)0xffffea0000000000UL + REC->pfn) : (void *) 0) In this case, the right arg was '?' operator which has lower priority. But it just sets the whole arg so making the output confusing - page was always 0 or 1 since that's the result of logical operation. With this patch, it can handle it properly like following: ((REC->pfn != (null - 1UL)) ? ((struct page *)0xffffea0000000000UL + REC->pfn) : (void *) 0) Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/1428298576-9785-10-git-send-email-namhyung@kernel.org [ Replaced 'swap' with 'rotate' in a comment as requested by Steve and agreed by Namhyung ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-03-26tools lib traceevent: Zero should not be considered "not found" in eval_flag()Steven Rostedt
Guilherme Cox found that: There is, however, a potential bug if there is an item with code zero that is not the first one in the symbol list, since eval_flag(..) returns 0 when it doesn't find anything. That is, if you have the following enums: enum { FOO_START = 0, FOO_GO = 1, FOO_END = 2 } and then have: __print_symbolic(foo, FOO_GO, "go", FOO_START, "start", FOO_END, "end") If none of the enums are known to pevent, then eval_flag() will return zero, and it will match it to the first item in the list, which would be FOO_GO, which is not zero. Luckily, in most cases, the first element would be zero, and the parsing would match out of sheer luck. Reported-by: Guilherme Cox <cox@computer.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20150324145813.0bfe95ba@gandalf.local.home Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-03-25tracing: %pF is only for function pointersScott Wood
Use %pS for actual addresses, otherwise you'll get bad output on arches like ppc64 where %pF expects a function descriptor. Link: http://lkml.kernel.org/r/1426130037-17956-22-git-send-email-scottwood@freescale.com Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-03-24tools lib traceevent: Add support for __print_array()Javi Merino
Since 6ea22486ba46 ("tracing: Add array printing helper") trace can generate traces with variable element size arrays. Add support to parse them. Signed-off-by: Javi Merino <javi.merino@arm.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1427195239-15730-1-git-send-email-javi.merino@arm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-03-24tools lib traceevent: Free filter tokens in process_filter()Steven Rostedt (Red Hat)
valgrind showed that the filter token wasn't being freed properly in process_filter(). Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20150324135923.817723903@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-03-24tools lib traceevent: Add way to find sub buffer boundarySteven Rostedt (Red Hat)
For debugging purposes, it may be helpful for the kbuffer library to flag when crossing a sub buffer. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20150324135923.650983637@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-03-24tools lib traceevent kbuffer: Remove extra update to data pointer in PADDINGSteven Rostedt (Red Hat)
When a event PADDING is hit (a deleted event that is still in the ring buffer), translate_data() sets the length of the padding and also updates the data pointer which is passed back to the caller. This is unneeded because the caller also updates the data pointer with the passed back length. translate_data() should not update the pointer, only set the length. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: stable@vger.kernel.org # 3.12+ Link: http://lkml.kernel.org/r/20150324135923.461431960@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-03-24tools lib traceevent: Make plugin options either string or booleanSteven Rostedt
When a plugin option is defined, by default it is a boolean (true or false). If the option is something else, then it needs to set its "value" field to a default string other than NULL (can be just ""). If the value is not set then the option is considered boolean, and the updating of the option value will be handled accordingly. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20150324135923.308372986@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-03-24tools lib traceevent: Add pevent_data_pid_from_comm()Steven Rostedt (Red Hat)
There is a pevent_data_comm_from_pid() that returns the cmdline stored for a given pid in order for users to map pids to comms, but there's no method to convert a comm back to a pid. This is useful for filters that specify a comm instead of a PID (it's faster than searching each individual event). Add a way to retrieve a comm from a pid. Since there can be more than one pid associated to a comm, it returns a data structure that lets the user iterate over all the saved comms for a given pid. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20150324135923.001103479@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-03-24tools lib traceevent: Handle %z in bprint formatSteven Rostedt (Red Hat)
The %z printf specifier was not handled making trace_printk()s in the kernel that used this break on output. Reported-by: Shawn Bohrer <shawn.bohrer@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Shawn Bohrer <shawn.bohrer@gmail.com> Link: http://lkml.kernel.org/r/20150324135922.844361717@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-03-24tools lib traceevent: Copy trace_clock and free itSteven Rostedt (Red Hat)
The pevent->trace_clock should not be a direct pointer to what was given. It should be copied and freed. Note, valgrind pointed this out when a caller passed in a pointer that needed to be freed and it never was. Ideally, pevent should copy it (which this change does), and free the copy. It's up to the caller to free the clock string passed in. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20150324135922.695906738@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-03-24tools lib traceevent: Handle NULL comm nameJosef Bacik
It is possible that a pid has no associated comm attached to it, although it can still be passed to pevent_register_comm(). But if comm is NULL, it will cause strdup() to segfault. To prevent this from happening, if comm is NULL use the default "<...>" name for the pid. Signed-off-by: Josef Bacik <jbacik@fb.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20150324135922.549965495@goodmis.org Link: http://lkml.kernel.org/p/1403799732-30308-1-git-send-email-jbacik@fb.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-03-24tools lib traceevent: Factor out allocating and processing argsJavi Merino
The sequence of allocating the print_arg field, calling process_arg() and verifying that the next event delimiter is repeated twice in process_hex() and will also be used for process_int_array(). Factor it out to a function to avoid writing the same code again and again. Signed-off-by: Javi Merino <javi.merino@arm.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1426875176-30244-2-git-send-email-javi.merino@arm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-03-21tools lib traceevent: Add destructor for format_fieldDavid Ahern
Move the calls that frees the resources allocated for a struct format_field to a separate routine. Signed-off-by: David Ahern <dsahern@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1426790181-19118-1-git-send-email-dsahern@gmail.com [ Split this part from a larger patch, added pevent_ prefix as requested by Steven ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-26Merge tag 'v4.0-rc1' into perf/core, to refresh the treeIngo Molnar
2015-02-12tools lib lockdep: Use tools build frameworkJiri Olsa
Move the lockdep library building under tools build framework. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: Alexis Berlemont <alexis.berlemont@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: S. Lockwood-Childs <sjl@vctlabs.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-i0t25buqyo5jfvzpw2347h1h@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-12tools lib traceevent: Use tools build frameworkJiri Olsa
Move the libtraceevent library building under tools build framework. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Alexis Berlemont <alexis.berlemont@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/n/tip-opvx59tcawlmm916lg4aff4h@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-12tools lib api: Rename libapikfs.a to libapi.aJiri Olsa
Renaming libapikfs.a to libapi.a, because it's not just 'fs' specific library now. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Alexis Berlemont <alexis.berlemont@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-g1mk5oj2ayq4vn653ovfg3gv@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-12tools lib api: Use tools build frameworkJiri Olsa
Move the libapikfs library building under tools build framework. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Alexis Berlemont <alexis.berlemont@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-xjo8r7nuqy9mvlfrmx9zcfwb@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-09Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Kernel side changes: - AMD range breakpoints support: Extend breakpoint tools and core to support address range through perf event with initial backend support for AMD extended breakpoints. The syntax is: perf record -e mem:addr/len:type For example set write breakpoint from 0x1000 to 0x1200 (0x1000 + 512) perf record -e mem:0x1000/512:w - event throttling/rotating fixes - various event group handling fixes, cleanups and general paranoia code to be more robust against bugs in the future. - kernel stack overhead fixes User-visible tooling side changes: - Show precise number of samples in at the end of a 'record' session, if processing build ids, since we will then traverse the whole perf.data file and see all the PERF_RECORD_SAMPLE records, otherwise stop showing the previous off-base heuristicly counted number of "samples" (Namhyung Kim). - Support to read compressed module from build-id cache (Namhyung Kim) - Enable sampling loads and stores simultaneously in 'perf mem' (Stephane Eranian) - 'perf diff' output improvements (Namhyung Kim) - Fix error reporting for evsel pgfault constructor (Arnaldo Carvalho de Melo) Tooling side infrastructure changes: - Cache eh/debug frame offset for dwarf unwind (Namhyung Kim) - Support parsing parameterized events (Cody P Schafer) - Add support for IP address formats in libtraceevent (David Ahern) Plus other misc fixes" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (48 commits) perf: Decouple unthrottling and rotating perf: Drop module reference on event init failure perf: Use POLLIN instead of POLL_IN for perf poll data in flag perf: Fix put_event() ctx lock perf: Fix move_group() order perf: Fix event->ctx locking perf: Add a bit of paranoia perf symbols: Convert lseek + read to pread perf tools: Use perf_data_file__fd() consistently perf symbols: Support to read compressed module from build-id cache perf evsel: Set attr.task bit for a tracking event perf header: Set header version correctly perf record: Show precise number of samples perf tools: Do not use __perf_session__process_events() directly perf callchain: Cache eh/debug frame offset for dwarf unwind perf tools: Provide stub for missing pthread_attr_setaffinity_np perf evsel: Don't rely on malloc working for sz 0 tools lib traceevent: Add support for IP address formats perf ui/tui: Show fatal error message only if exists perf tests: Fix typo in sample-parsing.c ...
2015-02-07tools lib api fs: Add {tracefs,debugfs}_configured() functionsSteven Rostedt (Red Hat)
Add tracefs_configured() to return true if tracefs is configured in the kernel (succeeds to find tracefs), and debugfs_configured() if debugfs is configured in the kernel (succeeds to find debugfs). Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20150202193553.190606690@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-07tools lib api debugfs: Add DEBUGFS_DEFAULT_PATH macroSteven Rostedt (Red Hat)
Instead of hard coding "/sys/kernel/debug" everywhere, create a macro to hold where the default path exists. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20150202193553.032117017@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-07tools lib api fs: Add tracefs mount helper functionsSteven Rostedt (Red Hat)
Since tracefs will now hold the event directory for perf, and even though by default, debugfs still mounts tracefs on the debugfs/tracing directory, the system admin may now choose to not mount debugfs and instead just mount tracefs instead. Having tracefs helper functions will facilitate having perf look for tracefs first, and then try debugfs as a fallback. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20150202193552.898934751@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-07tools lib fs: Add helper to find mounted file systemsSteven Rostedt (Red Hat)
In preparation for adding tracefs for perf to use, create a findfs helper utility that find_debugfs uses instead of hard coding the search in the code. This will allow for a find_tracefs to be used as well. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20150202193552.735023362@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-07perf tools: Do not check debugfs MAGIC for tracing filesSteven Rostedt (Red Hat)
It's rather strange to be checking the debugfs MAGIC number for the tracing directory. A system admin may want to have a custom set of events to trace and it should be allowed to let the admin make a temp file (even for tracing virtual boxes, this is useful). Also with the coming tracefs, the files may not even be under debugfs, so checking the debugfs MAGIC number is pointless. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20150202193552.546175764@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-06tools lib traceevent: Introduce trace_seq_do_fprintf functionArnaldo Carvalho de Melo
So that we can specify a FILE object where to direct the formatted output. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/n/tip-a49bhdrx8851f04hppn8bqxq@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-01-29tools/liblockdep: don't include host headersBaruch Siach
Adding host headers to include path may cause unexpected surprises when cross compiling. Remove /usr/local/include from the default include path. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-01-29tools/liblockdep: ignore generated .so fileBaruch Siach
2015-01-26tools lib traceevent: Add support for IP address formatsDavid Ahern
Add helpers for the following kernel formats: %pi4 print an IPv4 address with leading zeros %pI4 print an IPv4 address without leading zeros %pi6 print an IPv6 address without colons %pI6 print an IPv6 address with colons %pI6c print an IPv6 address in compressed form with colons %pISpc print an IP address from a sockaddr Allows these formats to be used in tracepoints. Quite a bit of this is adapted from code in lib/vsprintf.c. v4: - fixed pI6c description in git commit message per Valdis' comment v3: - use of 'c' and 'p' requires 'I' v2: - pass ptr+1 to print_ip_arg per Namhyung's comments - added field length checks to sockaddr function Signed-off-by: David Ahern <dsahern@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1418955071-36241-1-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-01-22tools lib fs debugfs: Check if debugfs is mounted when handling ENOENTArnaldo Carvalho de Melo
If debugfs was already mounted, then its a matter of not finding the tracepoint, tell the user that perhaps a CONFIG_ setting is not enabled. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-6chfytoflyx3jwfqm7ebltu0@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-01-22tools lib fs debugfs: Introduce debugfs__strerror_open_tpArnaldo Carvalho de Melo
There will be other cases where not just a tracepoint event is being opened below the debugfs mountpoint, but it is rather common, so provide one helper for that. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-q6e6zct49ql6nbcw8kkg0lbj@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-01-22tools lib fs: Pass filename to debugfs__strerror_openArnaldo Carvalho de Melo
It was hardcoded for one specific tracepoint, leftover from its initial user: 'perf trace'. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-j1jicvwljy5qx1nah4mkmyke@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
