commit 7a759cd8e8272ee18922838ee711219c7c796a31 upstream.
With commit: 0a943cb10ce78 (tools build: Add HOSTARCH Makefile variable)
when building for ARCH=x86_64, ARCH=x86_64 is passed to perf instead of
ARCH=x86, so the perf build process searchs header files from
tools/arch/x86_64/include, which doesn't exist.
The following build failure is seen:
In file included from util/event.c:2:0:
tools/include/uapi/linux/mman.h:4:27: fatal error: uapi/asm/mman.h: No such file or directory
compilation terminated.
Fix this issue by using SRCARCH instead of ARCH in perf, just like the
main kernel Makefile and tools/objtool's.
Signed-off-by: Jiada Wang <jiada_wang@mentor.com>
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Acked-by: Jiri Olsa <jolsa@kernel.org>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Eugeniu Rosca <erosca@de.adit-jv.com>
Cc: Jan Stancek <jstancek@redhat.com>
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
Cc: Rui Teng <rui.teng@linux.vnet.ibm.com>
Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com>
Cc: Wang Nan <wangnan0@huawei.com>
Fixes: 0a943cb10ce7 ("tools build: Add HOSTARCH Makefile variable")
Link: http://lkml.kernel.org/r/1491793357-14977-2-git-send-email-jiada_wang@mentor.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Tuomas Tynkkynen <tuomas@tuxera.com>
commit 621cb4e7837e39d25a5af5a785ad282cdd2b4ce8 upstream.
This patch modifies the build dependencies on the jitdump support in
perf. As it stands jitdump was wrongfully made dependent 100% on using
DWARF. However, the dwarf dependency, only exist if generating the
source line table in genelf_debug.c. The rest of the support does not
need DWARF.
This patch removes the dependency on DWARF for the entire jitdump
support. It keeps it only for the genelf_debug.c support.
Signed-off-by: Maciej Debski <maciejd@google.com>
Reviewed-by: Stephane Eranian <eranian@google.com>
Cc: Anton Blanchard <anton@ozlabs.org>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/1476356383-30100-3-git-send-email-eranian@google.com
Fixes: e12b202f8fb9 ("perf jitdump: Build only on supported archs")
[ Make it build only if NO_LIBELF isn't defined, as jitdump.o will only be built in that case ]
The __get_cpuid() test is only valid when compiling for x86. When
compiling for other architectures like ARM/ARM64 the test fails event if
the functionality is not required.
This patch isolate the build-in feature check to x86 platform, allowing
the compilation and usage of PMUs that use the AUXTRACE infrastructure
on other architectures (i.e ARM CoreSight).
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Link: http://lkml.kernel.org/r/1474041004-13956-2-git-send-email-mathieu.poirier@linaro.org
There's no reason to keep it in separate directory now when we moved out
the rest of the files.
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Cc: David Ahern <dsahern@gmail.com>
Link: http://lkml.kernel.org/r/1470074555-24889-6-git-send-email-jolsa@kernel.org
