We were using 'fd' locally, but there was a global 'fd' too, so
when converting from open to fopen the test made against fd
should be made against 'fp', but since we have that global
it didnt get discovered ...
Reported-by: Ulrich Drepper <drepper@redhat.com>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <20090814182632.GF3490@ghostprotocols.net>
While we can enable the perf sample records per tracepoint
counter, we may also want to enable this option for every
tracepoint counters to open, so that we don't need to add a
:record flag for all of them.
Add the -R, --raw-samples options for this purpose.
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <1250152039-7284-2-git-send-email-fweisbec@gmail.com>
Add a new flag field while opening a tracepoint perf counter:
-e tracepoint_subsystem:tracepoint_name:flags
This is intended to be generic although for now it only supports the
r[e[c[o[r[d]]]]] flag:
./perf record -e workqueue:workqueue_insertion:record
will have the same effect: enabling the raw samples record for
the given tracepoint counter.
In the future, we may want to support further flags, separated
by commas.
LKML-Reference: <1250152039-7284-1-git-send-email-fweisbec@gmail.com>
perf top supports a -C for setting the profile CPU, but perf
record does not. This adds the same option for perf record,
allowing the user to specify a specific target profile CPU.
LKML-Reference: <20090812091801.GC12579@kernel.dk>
Noticed when trying to record events for a firefox thread. We
were synthesizing both .tid and .pid with the pid passed via
--pid.
Fix it by reading /proc/PID/status and getting the tgid
to use in .pid, .tid gets the specified "pid".
Cc: Frédéric Weisbecker <fweisbec@gmail.com>
LKML-Reference: <20090811192200.GF18061@ghostprotocols.net>
1. Ignore the -A argument if there is no perf.data file
2. Treat an empty file like a non existent file.
Else, perf will try to read the perf.data header, and fail with
an error.
Treating an empty file like a non-existent file makes sense,
since an interupted (as in SIGKILLed) perf could leave such
files around, and you don't want to annoy the user with errors
for files with no data in it.
Signed-off-by: Pierre Habouzit <pierre.habouzit@intersec.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
This patch implements the kernel side support for ftrace event
record sampling.
A new counter sampling attribute is added:
PERF_SAMPLE_TP_RECORD
which requests ftrace events record sampling. In this case
if a PERF_TYPE_TRACEPOINT counter is active and a tracepoint
fires, we emit the tracepoint binary record to the
perfcounter event buffer, as a sample.
Result, after setting PERF_SAMPLE_TP_RECORD attribute from perf
record:
perf record -f -F 1 -a -e workqueue:workqueue_execution
perf report -D
0x21e18 [0x48]: event: 9
. ... raw event: size 72 bytes
. 0000: 09 00 00 00 01 00 48 00 d0 c7 00 81 ff ff ff ff ......H........
. 0010: 0a 00 00 00 0a 00 00 00 21 00 00 00 00 00 00 00 ........!......
. 0020: 2b 00 01 02 0a 00 00 00 0a 00 00 00 65 76 65 6e +...........eve
. 0030: 74 73 2f 31 00 00 00 00 00 00 00 00 0a 00 00 00 ts/1...........
. 0040: e0 b1 31 81 ff ff ff ff .......
0x21e18 [0x48]: PERF_EVENT_SAMPLE (IP, 1): 10: 0xffffffff8100c7d0 period: 33
The raw ftrace binary record starts at offset 0020.
Translation:
struct trace_entry {
type = 0x2b = 43;
flags = 1;
preempt_count = 2;
pid = 0xa = 10;
tgid = 0xa = 10;
thread_comm = "events/1"
thread_pid = 0xa = 10;
func = 0xffffffff8131b1e0 = flush_to_ldisc()
What will come next?
- Userspace support ('perf trace'), 'flight data recorder' mode
for perf trace, etc.
- The unconditional copy from the profiling callback brings
some costs however if someone wants no such sampling to
occur, and needs to be fixed in the future. For that we need
to have an instant access to the perf counter attribute.
This is a matter of a flag to add in the struct ftrace_event.
- Take care of the events recursivity! Don't ever try to record
a lock event for example, it seems some locking is used in
the profiling fast path and lead to a tracing recursivity.
That will be fixed using raw spinlock or recursivity
protection.
- Profit! :-)
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Tom Zanussi <tzanussi@gmail.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Gabriel Munteanu <eduard.munteanu@linux360.ro>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
perf stat and perf record currently look for all options on the command
line. This can lead to some confusion:
# perf stat ls -l
Error: unknown switch `l'
While we can work around this by adding '--' before the command, the git
option parsing code can stop at the first non option:
# perf stat ls -l
Performance counter stats for 'ls -l':
LKML-Reference: <20090722130412.GD9029@kryten>
Add the -d or --data option to log event addresses (eg page
faults).
LKML-Reference: <20090716104817.697698033@samba.org>
perf record synthesizes mmap events for the running process.
Right now it just catches file mappings, but we can check for
the vdso symbol and add that too.
LKML-Reference: <20090716104817.517264409@samba.org>
Enable -Wextra. This found a few real bugs plus a number
of signed/unsigned type mismatches/uncleanlinesses. It
also required a few annotations
All things considered it was still worth it so lets try with
this enabled for now.
LKML-Reference: <new-submission>
Building latest perfcounter fails on the following error:
builtin-record.c: In function ‘create_counter’:
builtin-record.c:451: erreur: ignoring return value of ‘read’, declared with attribute warn_unused_result
make: *** [builtin-record.o] Erreur 1
Just check if we successfully read the perf file descriptor.
LKML-Reference: <1245961287-5327-1-git-send-email-fweisbec@gmail.com>
Now that we can collect per task statistics, add modes that
make use of that facility.
Create a structured file format that includes the full
perf_counter_attr and all its relevant counter IDs so that
the reporting program has full information.
Looking backward for the first space from the end of a line in
/proc/pid/maps does not find the start of the pathname of the mapped
file if it contains a space.
Since the only slashes we have in this file occur in the (absolute!)
pathname column of file mappings, looking for the first slash in a
line is a safe method to find the name.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Stefani Seibold <stefani@seibold.net>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
LKML-Reference: <20090624190835.GA25548@cmpxchg.org>
Building perfcounter tools raises the following warnings:
builtin-record.c: In function ‘atexit_header’:
builtin-record.c:464: erreur: ignoring return value of ‘pwrite’, declared with attribute warn_unused_result
builtin-record.c: In function ‘__cmd_record’:
builtin-record.c:503: erreur: ignoring return value of ‘read’, declared with attribute warn_unused_result
builtin-report.c: In function ‘__cmd_report’:
builtin-report.c:1403: erreur: ignoring return value of ‘read’, declared with attribute warn_unused_result
This patch handles these IO return values.
LKML-Reference: <1245456100-5477-1-git-send-email-fweisbec@gmail.com>
On 64-bit powerpc, __u64 is defined to be unsigned long rather than
unsigned long long. This causes compiler warnings every time we
print a __u64 value with %Lx.
Rather than changing __u64, we define our own u64 to be unsigned long
long on all architectures, and similarly s64 as signed long long.
For consistency we also define u32, s32, u16, s16, u8 and s8. These
definitions are put in a new header, types.h, because these definitions
are needed in util/string.h and util/symbol.h.
The main change here is the mechanical change of __[us]{64,32,16,8}
to remove the "__". The other changes are:
* Create types.h
* Include types.h in perf.h, util/string.h and util/symbol.h
* Add types.h to the LIB_H definition in Makefile
* Added (u64) casts in process_overflow_event() and print_sym_table()
to kill two remaining warnings.
Cc: benh@kernel.crashing.org
LKML-Reference: <19003.33494.495844.956580@cargo.ozlabs.ibm.com>
Add a data file header so we can transfer data between record and report.
Make use of the new ->data_tail mechanism to tell kernel-space
about user-space draining the data stream. Emit lost events
(and display them) if they happen.
Recording with -a (or with -p) can race with tasks going away:
couldn't open /proc/8440/maps
Causing an early exit() and no recording done.
Do not abort the recording session - instead just skip that task.
Also, only print the warnings under -v.
Add the first steps of call-graph profiling:
- add the -c (--call-graph) option to perf record
- parse the call-graph record and printout out under -D (--dump-trace)
The call-graph data is not put into the histogram yet, but it
can be seen that it's being processed correctly:
0x3ce0 [0x38]: event: 35
. ... raw event: size 56 bytes
. 0000: 23 00 00 00 05 00 38 00 d4 df 0e 81 ff ff ff ff #.....8........
. 0010: 60 0b 00 00 60 0b 00 00 03 00 00 00 01 00 02 00 `...`..........
. 0020: d4 df 0e 81 ff ff ff ff a0 61 ed 41 36 00 00 00 .........a.A6..
. 0030: 04 92 e6 41 36 00 00 00 .a.A6..
0x3ce0 [0x38]: PERF_EVENT (IP, 5): 2912: 0xffffffff810edfd4 period: 1
... chain: u:2, k:1, nr:3
..... 0: 0xffffffff810edfd4
..... 1: 0x3641ed61a0
..... 2: 0x3641e69204
... thread: perf:2912
...... dso: [kernel]
This shows a 3-entry call-graph: with 1 kernel-space and two user-space
entries
Cc: Arjan van de Ven <arjan@infradead.org>
Up until now record has worked on the assumption that type=0, config=0
was a suitable configuration - which it is. Lets make this a little more
explicit and more readable via the use of proper symbols.
[ Impact: cleanup ]
Pure renames only, to PERF_COUNT_HW_* and PERF_COUNT_SW_*.
A build error slipped in:
builtin-report.c: In function ‘hist_entry__fprintf’:
builtin-report.c:711: error: format ‘%12d’ expects type ‘int’, but argument 3 has type ‘uint64_t’
Because we got a bit sloppy with those types. uint64_t really sucks,
because there's no printf format for it. So standardize on __u64
instead - for all types that go to or come from the ABI (which is __u64),
or for values that need to be large enough even on 32-bit.
When we use variable period sampling, add the period to the sample
data and use that to normalize the samples.
Currently report and stat catch SIGINT (and others) without altering
their exit state. This means that things like:
while :; do perf stat ./foo ; done
Loops become hard-to-interrupt, because bash never sees perf terminate
due to interruption. Fix this.
Create the counter in a disabled state and only enable it after we
mmap() the buffer, this allows us to see the first few samples (and
observe the frequency ramp).
Furthermore, print the period in the verbose report.
If perf is run on a !CONFIG_PERF_COUNTER kernel right now it
bails out with no messages or with confusing messages.
Standardize this case some more and explain the situation.
On architectures/CPUs without PMU support but with perfcounters
enabled 'perf record' currently fails because it cannot create a
cycle based hw-perfcounter.
Fall back to the cpu-clock-tick sw-perfcounter in this case, which
is hrtimer based and will always work (as long as perfcounters
are enabled).
Several people have suggested that 'perf' has become a full-fledged
tool that should be moved out of Documentation/. Move it to the
(new) tools/ directory.
