path: root/tools/perf/builtin-timechart.c
2009-10-20perf timechart: Fix the wakeup-arrows that point to non-visible processesArjan van de Ven
The timechart wakeup arrows currently show no process information when the waker/wakee are processes that are not actually chosen to be shown on the timechart. This patch fixes this oversight, by looking through all processes (after giving preference to visible processes) as well as falling back to just showing the PID if no name for the process can be resolved. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091020064649.0e4959b2@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-01perf timechart: Add a power-only modeArjan van de Ven
For doing work on the Linux power management components, I need to make long (30+ seconds) traces. Currently, this then results in a HUGE svg file, with mostly process data that isn't interesting. This patch adds a --power-only mode to perf timechart that only outputs the CPU power section of the SVG; this significantly reduces the size of the SVG file, making even 30+ second traces viewable with inkscape. As a minor tweak for the same effect, the minimum text size is decreased; current inkscape cannot zoom in deep enough to show text this small, but it reduces inkscape compute time. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: peterz@infradead.org LKML-Reference: <20090924154013.0675ab71@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-20perf util: Make the timechart SVG width dynamicArjan van de Ven
This patch adds a command line option for timechart that allows the user to specify the width of the SVG file. This patch also makes sure that each second of recording has at least 200 units (pixels at 96 DPI) of width. This impacts recordings longer than 5 seconds; recordings shorter than 5 second will scale up to have a width of 1000 units for the whole recording (as before). Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090920181416.69570c5d@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-20perf timechart: Show the duration of scheduler delays in the SVGArjan van de Ven
Given that scheduler latencies are the hot thing nowadays, show the duration of said latencies in the SVG in text form. In addition, if the latency is more than 10 msec, pick a brighter yellow color as a way to point these long delays out. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090920181353.796f4509@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-20perf timechart: Show the name of the waker/wakee in timechartArjan van de Ven
Timechart currently shows thin green lines for sending or receiving wakeups. This patch also prints (in a very small font) the name of the process that is being woken/wakes up this process. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090920181328.68baa978@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19perf timechart: Add "perf timechart record"Arjan van de Ven
Add a command line option to record a trace, similar to "perf sched record". Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: fweisbec@gmail.com Cc: peterz@infradead.org Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <20090919133442.0dc2c7f5@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19perf: Add the timechart toolArjan van de Ven
timechart is a tool to visualize what is going on in the system. The user makes a trace of what is going on with > perf record --timechart /usr/bin/some_command and then can turn the output of this into an svg file > perf timechart which then can be viewed with any SVG view; inkscape works well enough for me. The idea behind timechart is to create a "infinitely zoomable" picture; something that has high level information on a 1:1 zoom level, but which exposes more details every time you zoom into a specific area. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090912130713.6a77bbc0@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
