path: root/tools/perf/builtin-trace.c
2009-10-06perf trace: Remove unused code in builtin-trace.cTom Zanussi
And some minor whitespace cleanup. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: rostedt@goodmis.org Cc: lizf@cn.fujitsu.com Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1254808849-7829-2-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-03perf trace: Fix parsing of perf.dataIngo Molnar
We started parsing perf.data at head 0. This caused -D to segfault and it could possibly also case incorrect trace entries to be displayed. Parse it at data_offset instead. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-03perf trace: Sample timestamps as wellIngo Molnar
Before: perf-21082 [013] 0.000000: sched_wakeup_new: task perf:21083 [120] success=1 [015] perf-21082 [013] 0.000000: sched_migrate_task: task perf:21082 [120] from: 13 to: 15 perf-21082 [013] 0.000000: sched_process_fork: parent perf:21082 child perf:21083 true-21083 [015] 0.000000: sched_wakeup: task migration/15:33 [0] success=1 [015] perf-21082 [013] 0.000000: sched_switch: task perf:21082 [120] (S) ==> swapper:0 [140] true-21083 [015] 0.000000: sched_switch: task perf:21083 [120] (R) ==> migration/15:33 [0] true-21083 [011] 0.000000: sched_process_exit: task true:21083 [120] After: perf-21082 [013] 14674.797613: sched_wakeup_new: task perf:21083 [120] success=1 [015] perf-21082 [013] 14674.797506: sched_migrate_task: task perf:21082 [120] from: 13 to: 15 perf-21082 [013] 14674.797610: sched_process_fork: parent perf:21082 child perf:21083 true-21083 [015] 14674.797725: sched_wakeup: task migration/15:33 [0] success=1 [015] perf-21082 [013] 14674.797722: sched_switch: task perf:21082 [120] (S) ==> swapper:0 [140] true-21083 [015] 14674.797729: sched_switch: task perf:21083 [120] (R) ==> migration/15:33 [0] true-21083 [011] 14674.798159: sched_process_exit: task true:21083 [120] Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-02perf trace: Sample the CPU tooIngo Molnar
Sample, record, parse and print the CPU field - it had all zeroes before. Before (watch the second column, the CPU values): perf-32685 [000] 0.000000: sched_wakeup_new: task perf:32686 [120] success=1 [011] perf-32685 [000] 0.000000: sched_migrate_task: task perf:32685 [120] from: 1 to: 11 perf-32685 [000] 0.000000: sched_process_fork: parent perf:32685 child perf:32686 true-32686 [000] 0.000000: sched_wakeup: task migration/11:25 [0] success=1 [011] true-32686 [000] 0.000000: sched_wakeup: task distccd:12793 [125] success=1 [015] true-32686 [000] 0.000000: sched_wakeup: task distccd:12793 [125] success=1 [015] perf-32685 [000] 0.000000: sched_switch: task perf:32685 [120] (S) ==> swapper:0 [140] true-32686 [000] 0.000000: sched_switch: task perf:32686 [120] (R) ==> migration/11:25 [0] true-32686 [000] 0.000000: sched_switch: task perf:32686 [120] (R) ==> distccd:12793 [125] true-32686 [000] 0.000000: sched_switch: task true:32686 [120] (R) ==> distccd:12793 [125] true-32686 [000] 0.000000: sched_process_exit: task true:32686 [120] true-32686 [000] 0.000000: sched_stat_wait: task: distccd:12793 wait: 6767985949080 [ns] true-32686 [000] 0.000000: sched_stat_wait: task: distccd:12793 wait: 6767986139446 [ns] true-32686 [000] 0.000000: sched_stat_sleep: task: distccd:12793 sleep: 132844 [ns] true-32686 [000] 0.000000: sched_stat_sleep: task: distccd:12793 sleep: 131724 [ns] After: perf-32685 [001] 0.000000: sched_wakeup_new: task perf:32686 [120] success=1 [011] perf-32685 [001] 0.000000: sched_migrate_task: task perf:32685 [120] from: 1 to: 11 perf-32685 [001] 0.000000: sched_process_fork: parent perf:32685 child perf:32686 true-32686 [011] 0.000000: sched_wakeup: task migration/11:25 [0] success=1 [011] true-32686 [015] 0.000000: sched_wakeup: task distccd:12793 [125] success=1 [015] true-32686 [015] 0.000000: sched_wakeup: task distccd:12793 [125] success=1 [015] perf-32685 [001] 0.000000: sched_switch: task perf:32685 [120] (S) ==> swapper:0 [140] true-32686 [011] 0.000000: sched_switch: task perf:32686 [120] (R) ==> migration/11:25 [0] true-32686 [015] 0.000000: sched_switch: task perf:32686 [120] (R) ==> distccd:12793 [125] true-32686 [015] 0.000000: sched_switch: task true:32686 [120] (R) ==> distccd:12793 [125] true-32686 [015] 0.000000: sched_process_exit: task true:32686 [120] true-32686 [015] 0.000000: sched_stat_wait: task: distccd:12793 wait: 6767985949080 [ns] true-32686 [015] 0.000000: sched_stat_wait: task: distccd:12793 wait: 6767986139446 [ns] true-32686 [015] 0.000000: sched_stat_sleep: task: distccd:12793 sleep: 132844 [ns] true-32686 [015] 0.000000: sched_stat_sleep: task: distccd:12793 sleep: 131724 [ns] So we can now see how this workload migrated between CPUs. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-31perf tools: Resolve idle thread cmdline for perf traceFrederic Weisbecker
The cmd-trace tool used the cmdline file and resolved the idle thread using a hardcoded check for the 0 task pid. Now we have a centralized way to do that from perf using register_idle_thread() API. Before: :0-0 [000] 0.000000: irq_handler_entry: irq=0 handler=name :0-0 [000] 0.000000: irq_handler_entry: irq=0 handler=name After: [idle]-0 [000] 0.000000: irq_handler_entry: irq=0 handler=name [idle]-0 [000] 0.000000: irq_handler_entry: irq=0 handler=name Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1251693921-6579-2-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-21perf trace: Add OPT_END to option array of perf-traceMasami Hiramatsu
Add OPT_END to option array of perf-trace for fixing a SEGV bug when showing perf-trace help message. Without this patch; ./perf trace -h usage: perf trace [<options>] <command> -D, --dump-raw-trace dump raw trace in ASCII -v, --verbose be more verbose (show symbol address, etc) -f, Segmentation fault With this patch: ./perf trace -h usage: perf trace [<options>] <command> -D, --dump-raw-trace dump raw trace in ASCII -v, --verbose be more verbose (show symbol address, etc) Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Cc: Zhaolei <zhaolei@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <20090821185603.11039.62109.stgit@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-18perf tools: Warn while running perf trace without sampleFrederic Weisbecker
When a user runs perf trace using an input with logged counters without PERF_SAMPLE_RAW attribute, warn by giving a nice tip. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1250543271-8383-2-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-17perf tools: Add perf traceFrederic Weisbecker
This adds perf trace into the set of perf tools. It is written to fetch the tracepoint samples from perf events and display them, according to the events information given by the debugfs files through the util/trace* tools. It is a rough first shot and doesn't yet handle the cpu, timestamps fields and some other things. Example: perf record -f -e workqueue:workqueue_execution:record -F 1 -a perf trace kblockd/0-236 [000] 0.000000: workqueue_execution: thread=:236 func=cfq_kick_queue+0x0 kondemand/0-360 [000] 0.000000: workqueue_execution: thread=:360 func=do_dbs_timer+0x0 kondemand/0-360 [000] 0.000000: workqueue_execution: thread=:360 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 Todo: - A lot of things! Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: "Luis Claudio R. Goncalves" <lclaudio@uudg.org> Cc: Clark Williams <williams@redhat.com> Cc: Jon Masters <jonathan@jonmasters.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Christoph Hellwig <hch@infradead.org> Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Cc: Zhaolei <zhaolei@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Jiaying Zhang <jiayingz@google.com> Cc: Anton Blanchard <anton@samba.org> LKML-Reference: <1250518688-7207-4-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
