path: root/tools/perf/builtin.h
2010-05-02perf: add perf-inject builtinTom Zanussi
Currently, perf 'live mode' writes build-ids at the end of the session, which isn't actually useful for processing live mode events. What would be better would be to have the build-ids sent before any of the samples that reference them, which can be done by processing the event stream and retrieving the build-ids on the first hit. Doing that in perf-record itself, however, is off-limits. This patch introduces perf-inject, which does the same job while leaving perf-record untouched. Normal mode perf still records the build-ids at the end of the session as it should, but for live mode, perf-inject can be injected in between the record and report steps e.g.: perf record -o - ./hackbench 10 | perf inject -v -b | perf report -v -i - perf-inject reads a perf-record event stream and repipes it to stdout. At any point the processing code can inject other events into the event stream - in this case build-ids (-b option) are read and injected as needed into the event stream. Build-ids are just the first user of perf-inject - potentially anything that needs userspace processing to augment the trace stream with additional information could make use of this facility. Cc: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frédéric Weisbecker <fweisbec@gmail.com> LKML-Reference: <1272696080-16435-3-git-send-email-tzanussi@gmail.com> Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-04-29perf test: Initial regression testing commandArnaldo Carvalho de Melo
First an example with the first internal test: [acme@doppio linux-2.6-tip]$ perf test 1: vmlinux symtab matches kallsyms: Ok So it run just one test, that is "vmlinux symtab matches kallsyms", and it was successful. If we run it in verbose mode, we'll see details about errors and extra warnings for non-fatal problems: [acme@doppio linux-2.6-tip]$ perf test -v 1: vmlinux symtab matches kallsyms: --- start --- Looking at the vmlinux_path (5 entries long) No build_id in vmlinux, ignoring it No build_id in /boot/vmlinux, ignoring it No build_id in /boot/vmlinux-2.6.34-rc4-tip+, ignoring it Using /lib/modules/2.6.34-rc4-tip+/build/vmlinux for symbols Maps only in vmlinux: ffffffff81cb81b1-ffffffff81e1149b 0 [kernel].init.text ffffffff81e1149c-ffffffff9fffffff 0 [kernel].exit.text ffffffffff600000-ffffffffff6000ff 0 [kernel].vsyscall_0 ffffffffff600100-ffffffffff6003ff 0 [kernel].vsyscall_fn ffffffffff600400-ffffffffff6007ff 0 [kernel].vsyscall_1 ffffffffff600800-ffffffffffffffff 0 [kernel].vsyscall_2 Maps in vmlinux with a different name in kallsyms: ffffffffff600000-ffffffffff6000ff 0 [kernel].vsyscall_0 in kallsyms as [kernel].0 ffffffffff600100-ffffffffff6003ff 0 [kernel].vsyscall_fn in kallsyms as: *ffffffffff600100-ffffffffff60012f 0 [kernel].2 ffffffffff600400-ffffffffff6007ff 0 [kernel].vsyscall_1 in kallsyms as [kernel].6 ffffffffff600800-ffffffffffffffff 0 [kernel].vsyscall_2 in kallsyms as [kernel].8 Maps only in kallsyms: ffffffffff600130-ffffffffff6003ff 0 [kernel].4 ---- end ---- vmlinux symtab matches kallsyms: Ok [acme@doppio linux-2.6-tip]$ In the above case we only know the name of the non contiguous kernel ranges in the address space when reading the symbol information from the ELF symtab in vmlinux. The /proc/kallsyms file lack this, we only notice they are separate because there are modules after the kernel and after that more kernel functions, so we need to have a module rbtree backed by the module .ko path to get symtabs in the vmlinux case. The tool uses it to match by address to emit appropriate warning, but don't considers this fatal. The .init.text and .exit.text ines, of course, aren't in kallsyms, so I left these cases just as extra info in verbose mode. The end of the sections also aren't in kallsyms, so we the symbols layer does another pass and sets the end addresses as the next map start minus one, which sometimes pads, causing harmless mismatches. But at least the symbols match, tested it by copying /proc/kallsyms to /tmp/kallsyms and doing changes to see if they were detected. This first test also should serve as a first stab at documenting the symbol library by providing a self contained example that exercises it together with comments about what is being done. More tests to check if actions done on a monitored app, like doing mmaps, etc, makes the kernel generate the expected events should be added next. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-04-19perf: 'perf kvm' tool for monitoring guest performance from hostZhang, Yanmin
Here is the patch of userspace perf tool. Signed-off-by: Zhang Yanmin <yanmin_zhang@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-01-31perf lock: Introduce new tool "perf lock", for analyzing lock statisticsHitoshi Mitake
Adding new subcommand "perf lock" to perf. I have a lot of remaining ToDos, but for now perf lock can already provide minimal functionality for analyzing lock statistics. Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1264851813-8413-12-git-send-email-mitake@dcl.info.waseda.ac.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-21perf buildid-cache: Add new command to manage build-id cacheArnaldo Carvalho de Melo
For now it just has operations to examine a given file, find its build-id and add or remove it to/from the cache. Useful, for instance, when adding binaries sent together with a perf.data file, so that we can add them to the cache and have the tools find it when resolving symbols. It'll also manage the size of the cache like 'ccache' does. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1264008525-29025-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf diff: Introduce tool to show performance differenceArnaldo Carvalho de Melo
I guess it is enough to show some examples: [root@doppio linux-2.6-tip]# rm -f perf.data* [root@doppio linux-2.6-tip]# ls -la perf.data* ls: cannot access perf.data*: No such file or directory [root@doppio linux-2.6-tip]# perf record -f find / > /dev/null [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.062 MB perf.data (~2699 samples) ] [root@doppio linux-2.6-tip]# ls -la perf.data* -rw------- 1 root root 74440 2009-12-14 20:03 perf.data [root@doppio linux-2.6-tip]# perf record -f find / > /dev/null [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.062 MB perf.data (~2692 samples) ] [root@doppio linux-2.6-tip]# ls -la perf.data* -rw------- 1 root root 74280 2009-12-14 20:03 perf.data -rw------- 1 root root 74440 2009-12-14 20:03 perf.data.old [root@doppio linux-2.6-tip]# perf diff | head -5 1 -34994580 /lib64/libc-2.10.1.so _IO_vfprintf_internal 2 -15307806 [kernel.kallsyms] __kmalloc 3 +1 +3665941 /lib64/libc-2.10.1.so __GI_memmove 4 +4 +23508995 /lib64/libc-2.10.1.so _int_malloc 5 +7 +38538813 [kernel.kallsyms] __d_lookup [root@doppio linux-2.6-tip]# perf diff -p | head -5 1 +1.00% /lib64/libc-2.10.1.so _IO_vfprintf_internal 2 [kernel.kallsyms] __kmalloc 3 +1 /lib64/libc-2.10.1.so __GI_memmove 4 +4 /lib64/libc-2.10.1.so _int_malloc 5 +7 -1.00% [kernel.kallsyms] __d_lookup [root@doppio linux-2.6-tip]# perf diff -v | head -5 1 361449551 326454971 -34994580 /lib64/libc-2.10.1.so _IO_vfprintf_internal 2 151009241 135701435 -15307806 [kernel.kallsyms] __kmalloc 3 +1 101805328 105471269 +3665941 /lib64/libc-2.10.1.so __GI_memmove 4 +4 78041440 101550435 +23508995 /lib64/libc-2.10.1.so _int_malloc 5 +7 59536172 98074985 +38538813 [kernel.kallsyms] __d_lookup [root@doppio linux-2.6-tip]# perf diff -vp | head -5 1 9.00% 8.00% +1.00% /lib64/libc-2.10.1.so _IO_vfprintf_internal 2 3.00% 3.00% [kernel.kallsyms] __kmalloc 3 +1 2.00% 2.00% /lib64/libc-2.10.1.so __GI_memmove 4 +4 2.00% 2.00% /lib64/libc-2.10.1.so _int_malloc 5 +7 1.00% 2.00% -1.00% [kernel.kallsyms] __d_lookup [root@doppio linux-2.6-tip]# This should be enough for diffs where the system is non volatile, i.e. when one doesn't updates binaries. For volatile environments, stay tuned for the next perf tool feature: a buildid cache populated by 'perf record', managed by 'perf buildid-cache' a-la ccache, and used by all the report tools. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> LKML-Reference: <1260828571-3613-3-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-20perf: Add 'perf kmem' toolLi Zefan
This tool is mostly a perf version of kmemtrace-user. The following information is provided by this tool: - the total amount of memory allocated and fragmentation per call-site - the total amount of memory allocated and fragmentation per allocation - total memory allocated and fragmentation in the collected dataset - ... Sample output: # ./perf kmem record ^C # ./perf kmem --stat caller --stat alloc -l 10 ------------------------------------------------------------------------------ Callsite | Total_alloc/Per | Total_req/Per | Hit | Fragmentation ------------------------------------------------------------------------------ 0xc052f37a | 790528/4096 | 790528/4096 | 193 | 0.000% 0xc0541d70 | 524288/4096 | 524288/4096 | 128 | 0.000% 0xc051cc68 | 481600/200 | 481600/200 | 2408 | 0.000% 0xc0572623 | 297444/676 | 297440/676 | 440 | 0.001% 0xc05399f1 | 73476/164 | 73472/164 | 448 | 0.005% 0xc05243bf | 51456/256 | 51456/256 | 201 | 0.000% 0xc0730d0e | 31844/497 | 31808/497 | 64 | 0.113% 0xc0734c4e | 17152/256 | 17152/256 | 67 | 0.000% 0xc0541a6d | 16384/128 | 16384/128 | 128 | 0.000% 0xc059c217 | 13120/40 | 13120/40 | 328 | 0.000% 0xc0501ee6 | 11264/88 | 11264/88 | 128 | 0.000% 0xc04daef0 | 7504/682 | 7128/648 | 11 | 5.011% 0xc04e14a3 | 4216/191 | 4216/191 | 22 | 0.000% 0xc05041ca | 3524/44 | 3520/44 | 80 | 0.114% 0xc0734fa3 | 2104/701 | 1620/540 | 3 | 23.004% 0xc05ec9f1 | 2024/289 | 2016/288 | 7 | 0.395% 0xc06a1999 | 1792/256 | 1792/256 | 7 | 0.000% 0xc0463b9a | 1584/144 | 1584/144 | 11 | 0.000% 0xc0541eb0 | 1024/16 | 1024/16 | 64 | 0.000% 0xc06a19ac | 896/128 | 896/128 | 7 | 0.000% 0xc05721c0 | 772/12 | 768/12 | 64 | 0.518% 0xc054d1e6 | 288/57 | 280/56 | 5 | 2.778% 0xc04b562e | 157/31 | 154/30 | 5 | 1.911% 0xc04b536f | 80/16 | 80/16 | 5 | 0.000% 0xc05855a0 | 64/64 | 36/36 | 1 | 43.750% ------------------------------------------------------------------------------ ------------------------------------------------------------------------------ Alloc Ptr | Total_alloc/Per | Total_req/Per | Hit | Fragmentation ------------------------------------------------------------------------------ 0xda884000 | 1052672/4096 | 1052672/4096 | 257 | 0.000% 0xda886000 | 262144/4096 | 262144/4096 | 64 | 0.000% 0xf60c7c00 | 16512/128 | 16512/128 | 129 | 0.000% 0xf59a4118 | 13120/40 | 13120/40 | 328 | 0.000% 0xdfd4b2c0 | 11264/88 | 11264/88 | 128 | 0.000% 0xf5274600 | 7680/256 | 7680/256 | 30 | 0.000% 0xe8395000 | 5948/594 | 5464/546 | 10 | 8.137% 0xe59c3c00 | 5748/479 | 5712/476 | 12 | 0.626% 0xf4cd1a80 | 3524/44 | 3520/44 | 80 | 0.114% 0xe5bd1600 | 2892/482 | 2856/476 | 6 | 1.245% ... | ... | ... | ... | ... ------------------------------------------------------------------------------ SUMMARY ======= Total bytes requested: 2333626 Total bytes allocated: 2353712 Total bytes wasted on internal fragmentation: 20086 Internal fragmentation: 0.853375% TODO: - show sym+offset in 'callsite' column - show cross node allocation stats - collect more useful stats? - ... Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: linux-mm@kvack.org <linux-mm@kvack.org> LKML-Reference: <4B064AF5.9060208@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-17Merge branch 'perf/core' into perf/probesIngo Molnar
Resolved merge conflict in tools/perf/Makefile Merge reason: we want to queue up a dependent patch. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-16perf buildid-list: New plumbing commandArnaldo Carvalho de Melo
With this we can list the buildids in a perf.data file so that we can pipe them to other, distro specific tools that from the buildids can figure out separate packages (foo-debuginfo) where we can find the matching symtabs so that perf report can do its job. E.g: [acme@doppio linux-2.6-tip]$ perf buildid-list | head -5 8e08b117e5458ad3f85da16d42d0fc5cd21c5869 520c2387a587cc5acfcf881e27dba1caaeab4b1f ec8dd400904ddfcac8b1c343263a790f977159dc 7caedbca5a6d8ab39a7fe44bd28c07d3e14a3f3f 379bb828fd08859dbea73279f04abefabc95a6a3 [acme@doppio linux-2.6-tip]$ perf buildid-list -v | head -5 8e08b117e5458ad3f85da16d42d0fc5cd21c5869 /sbin/init 520c2387a587cc5acfcf881e27dba1caaeab4b1f /lib64/ld-2.10.1.so ec8dd400904ddfcac8b1c343263a790f977159dc /lib64/libc-2.10.1.so 7caedbca5a6d8ab39a7fe44bd28c07d3e14a3f3f /sbin/udevd 379bb828fd08859dbea73279f04abefabc95a6a3 /lib64/libdl-2.10.1.so [acme@doppio linux-2.6-tip]$ Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1258396365-29217-5-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-08perf bench: Modify builtin.h for new prototypeHitoshi Mitake
This patch modifies builtin.h to add prototype of cmd_bench(). Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: fweisbec@gmail.com Cc: Jiri Kosina <jkosina@suse.cz> LKML-Reference: <1257381097-4743-6-git-send-email-mitake@dcl.info.waseda.ac.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-12perf: Add perf probe subcommand, a kprobe-event setup helperMasami Hiramatsu
Add perf probe subcommand that implements a kprobe-event setup helper to the perf command. This allows user to define kprobe events using C expressions (C line numbers, C function names, and C local variables). Usage ----- perf probe [<options>] -P 'PROBEDEF' [-P 'PROBEDEF' ...] -k, --vmlinux <file> vmlinux/module pathname -P, --probe <p|r:[GRP/]NAME FUNC[+OFFS][@SRC]|@SRC:LINE [ARG ...]> probe point definition, where p: kprobe probe r: kretprobe probe GRP: Group name (optional) NAME: Event name FUNC: Function name OFFS: Offset from function entry (in byte) SRC: Source code path LINE: Line number ARG: Probe argument (local variable name or kprobe-tracer argument format is supported.) Changes in v4: - Add _GNU_SOURCE macro for strndup(). Changes in v3: - Remove -r option because perf always be used for online kernel. - Check malloc/calloc results. Changes in v2: - Check synthesized string length. - Rename perf kprobe to perf probe. - Use spaces for separator and update usage comment. - Check error paths in parse_probepoint(). - Check optimized-out variables. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Hellwig <hch@infradead.org> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Frank Ch. Eigler <fche@redhat.com> LKML-Reference: <20091008211737.29299.14784.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-09-19perf: Add the timechart toolArjan van de Ven
timechart is a tool to visualize what is going on in the system. The user makes a trace of what is going on with > perf record --timechart /usr/bin/some_command and then can turn the output of this into an svg file > perf timechart which then can be viewed with any SVG view; inkscape works well enough for me. The idea behind timechart is to create a "infinitely zoomable" picture; something that has high level information on a 1:1 zoom level, but which exposes more details every time you zoom into a specific area. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090912130713.6a77bbc0@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-13perf: Add 'perf sched' toolIngo Molnar
This turn-key tool allows scheduler measurements to be conducted and the results be displayed numerically. First baby step towards that goal: clone the new command off of perf trace. Fix a few other details along the way: - add (minimal) perf trace documentation - reorder a few places - list perf trace in the mainporcelain list as well as it's a very useful utility. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-12perf tools: Factorize high level dso helpersFrederic Weisbecker
Factorize multiple definitions of high level dso helpers into the symbol source file. The side effect is a general export of the verbose and eprintf debugging helpers into a new file dedicated to debugging purposes. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Brice Goglin <Brice.Goglin@inria.fr>
2009-06-06perf_counter tools: Move from Documentation/perf_counter/ to tools/perf/Ingo Molnar
Several people have suggested that 'perf' has become a full-fledged tool that should be moved out of Documentation/. Move it to the (new) tools/ directory. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
