path: root/tools/perf/perf.c
2011-03-15perf evlist: New command to list the names of events present in a perf.data fileArnaldo Carvalho de Melo
[root@emilia ~]# perf record -a -e sched:* -e timer:timer* sleep 5 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.172 MB perf.data (~7530 samples) ] [root@emilia ~]# perf evlist sched:sched_kthread_stop sched:sched_kthread_stop_ret sched:sched_wakeup sched:sched_wakeup_new sched:sched_switch sched:sched_migrate_task sched:sched_process_free sched:sched_process_exit sched:sched_wait_task sched:sched_process_wait sched:sched_process_fork sched:sched_stat_wait sched:sched_stat_sleep sched:sched_stat_iowait sched:sched_stat_runtime sched:sched_pi_setprio timer:timer_init timer:timer_start timer:timer_expire_entry timer:timer_expire_exit timer:timer_cancel [root@emilia ~]# Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-11perf evsel: Fix order of event list deletionArnaldo Carvalho de Melo
We need to defer calling perf_evsel_list__delete() till after atexit registered routines, because we need to traverse the events being recorded at that time at least on 'perf record'. This fixes the problem reported by Thomas Renninger where cmd_record called by cmd_timechart would not write the tracing data to the perf.data file header because the evsel_list at atexit (control+C on 'perf timechart record') time would be empty, being already deleted by run_builtin(), and thus 'perf timechart' when trying to process such perf.data file would die with: "no trace data in the file" Problem introduced in 70d544d. Reported-by: Thomas Renninger <trenn@suse.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Renninger <trenn@suse.de> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-03perf evsel: Delete the event selectors at exitArnaldo Carvalho de Melo
Freeing all the possibly allocated resources, reducing complexity on each tool exit path. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-11-16perf: Rename 'perf trace' to 'perf script'Ingo Molnar
Free the perf trace name space and rename the trace to 'script' which is a better match for the scripting engine. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-06-05perf buildid: add perfconfig option to specify buildid cache dirStephane Eranian
This patch adds the ability to specify an alternate directory to store the buildid cache (buildids, copy of binaries). By default, it is hardcoded to $HOME/.debug. This directory contains immutable data. The layout of the directory is such that no conflicts in filenames are possible. A modification in a file, yields a different buildid and thus a different location in the subdir hierarchy. You may want to put the buildid cache elsewhere because of disk space limitation or simply to share the cache between users. It is also useful for remote collect vs. local analysis of profiles. This patch adds a new config option to the perfconfig file. Under the tag 'buildid', there is a dir option. For instance, if you have: $ cat /etc/perfconfig [buildid] dir = /var/cache/perf-buildid All buildids and binaries are be saved in the directory specified. The perf record, buildid-list, buildid-cache, report, annotate, and archive commands will it to pull information out. The option can be set in the system-wide perfconfig file or in the $HOME/.perfconfig file. Cc: David S. Miller <davem@davemloft.net> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <4c055fb7.df0ce30a.5f0d.ffffae52@mx.google.com> Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-20perf tui: Allow disabling the TUI on a per command basis in ~/.perfconfigArnaldo Carvalho de Melo
Using the same scheme as for git's/perf's pager setup, i.e. if one doesn't want to, on a newt enabled perf binary, to disable the TUI for 'perf report', its just a matter of doing: [root@doppio linux-2.6-tip]# printf "[tui]\n\nreport = off\n" > /root/.perfconfig [root@doppio linux-2.6-tip]# cat /root/.perfconfig [tui] report = off [root@doppio linux-2.6-tip]# System wide settings are also possible, by editing /etc/perfconfig, etc, i.e. the git machinery for config files applies to perf as well, so when in doubt where to put your settings, consult the git documentation, if it fails, please let us know. Suggested-by: Ingo Molnar <mingo@elte.hu> Discussed-with: Stephane Eranian <eranian@google.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-02perf: add perf-inject builtinTom Zanussi
Currently, perf 'live mode' writes build-ids at the end of the session, which isn't actually useful for processing live mode events. What would be better would be to have the build-ids sent before any of the samples that reference them, which can be done by processing the event stream and retrieving the build-ids on the first hit. Doing that in perf-record itself, however, is off-limits. This patch introduces perf-inject, which does the same job while leaving perf-record untouched. Normal mode perf still records the build-ids at the end of the session as it should, but for live mode, perf-inject can be injected in between the record and report steps e.g.: perf record -o - ./hackbench 10 | perf inject -v -b | perf report -v -i - perf-inject reads a perf-record event stream and repipes it to stdout. At any point the processing code can inject other events into the event stream - in this case build-ids (-b option) are read and injected as needed into the event stream. Build-ids are just the first user of perf-inject - potentially anything that needs userspace processing to augment the trace stream with additional information could make use of this facility. Cc: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frédéric Weisbecker <fweisbec@gmail.com> LKML-Reference: <1272696080-16435-3-git-send-email-tzanussi@gmail.com> Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-04-29perf test: Initial regression testing commandArnaldo Carvalho de Melo
First an example with the first internal test: [acme@doppio linux-2.6-tip]$ perf test 1: vmlinux symtab matches kallsyms: Ok So it run just one test, that is "vmlinux symtab matches kallsyms", and it was successful. If we run it in verbose mode, we'll see details about errors and extra warnings for non-fatal problems: [acme@doppio linux-2.6-tip]$ perf test -v 1: vmlinux symtab matches kallsyms: --- start --- Looking at the vmlinux_path (5 entries long) No build_id in vmlinux, ignoring it No build_id in /boot/vmlinux, ignoring it No build_id in /boot/vmlinux-2.6.34-rc4-tip+, ignoring it Using /lib/modules/2.6.34-rc4-tip+/build/vmlinux for symbols Maps only in vmlinux: ffffffff81cb81b1-ffffffff81e1149b 0 [kernel].init.text ffffffff81e1149c-ffffffff9fffffff 0 [kernel].exit.text ffffffffff600000-ffffffffff6000ff 0 [kernel].vsyscall_0 ffffffffff600100-ffffffffff6003ff 0 [kernel].vsyscall_fn ffffffffff600400-ffffffffff6007ff 0 [kernel].vsyscall_1 ffffffffff600800-ffffffffffffffff 0 [kernel].vsyscall_2 Maps in vmlinux with a different name in kallsyms: ffffffffff600000-ffffffffff6000ff 0 [kernel].vsyscall_0 in kallsyms as [kernel].0 ffffffffff600100-ffffffffff6003ff 0 [kernel].vsyscall_fn in kallsyms as: *ffffffffff600100-ffffffffff60012f 0 [kernel].2 ffffffffff600400-ffffffffff6007ff 0 [kernel].vsyscall_1 in kallsyms as [kernel].6 ffffffffff600800-ffffffffffffffff 0 [kernel].vsyscall_2 in kallsyms as [kernel].8 Maps only in kallsyms: ffffffffff600130-ffffffffff6003ff 0 [kernel].4 ---- end ---- vmlinux symtab matches kallsyms: Ok [acme@doppio linux-2.6-tip]$ In the above case we only know the name of the non contiguous kernel ranges in the address space when reading the symbol information from the ELF symtab in vmlinux. The /proc/kallsyms file lack this, we only notice they are separate because there are modules after the kernel and after that more kernel functions, so we need to have a module rbtree backed by the module .ko path to get symtabs in the vmlinux case. The tool uses it to match by address to emit appropriate warning, but don't considers this fatal. The .init.text and .exit.text ines, of course, aren't in kallsyms, so I left these cases just as extra info in verbose mode. The end of the sections also aren't in kallsyms, so we the symbols layer does another pass and sets the end addresses as the next map start minus one, which sometimes pads, causing harmless mismatches. But at least the symbols match, tested it by copying /proc/kallsyms to /tmp/kallsyms and doing changes to see if they were detected. This first test also should serve as a first stab at documenting the symbol library by providing a self contained example that exercises it together with comments about what is being done. More tests to check if actions done on a monitored app, like doing mmaps, etc, makes the kernel generate the expected events should be added next. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-04-19perf: 'perf kvm' tool for monitoring guest performance from hostZhang, Yanmin
Here is the patch of userspace perf tool. Signed-off-by: Zhang Yanmin <yanmin_zhang@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-04-03perf tools: Move the prototypes in util/string.h to util.hArnaldo Carvalho de Melo
So that we avoid conflict with libc's string.h header. Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Suggested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-03-22perf newt: Properly restore the screen when error exitingArnaldo Carvalho de Melo
Show an OK message box with the last message sent via pr_err, etc. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1269274229-20442-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-22Merge commit 'v2.6.34-rc2' into perf/coreIngo Molnar
Merge reason: Pick up latest perf fixes from upstream. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-13perf tools: Fix non-newt buildArnaldo Carvalho de Melo
The use_browser needs to be in a file that is always built and also we need a browser__show_help stub in that case. Reported-by: Anton Blanchard <anton@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1268438710-32697-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-12perf report: Implement initial UI using newtArnaldo Carvalho de Melo
Newt has widespread availability and provides a rather simple API as can be seen by the size of this patch. The work needed to support it will benefit other frontends too. In this initial patch it just checks if the output is a tty, if not it falls back to the previous behaviour, also if newt-devel/libnewt-dev is not installed the previous behaviour is maintaned. Pressing enter on a symbol will annotate it, ESC in the annotation window will return to the report symbol list. More work will be done to remove the special casing in color_fprintf, stop using fmemopen/FILE in the printing of hist_entries, etc. Also the annotation doesn't need to be done via spawning "perf annotate" and then browsing its output, we can do better by calling directly the builtin-annotate.c functions, that would then be moved to tools/perf/util/annotate.c and shared with perf top, etc But lets go by baby steps, this patch already improves perf usability by allowing to quickly do annotations on symbols from the report screen and provides a first experimentation with libnewt/TUI integration of tools. Tested on RHEL5 and Fedora12 X86_64 and on Debian PARISC64 to browse a perf.data file collected on a Fedora12 x86_64 box. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Avi Kivity <avi@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1268349164-5822-5-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-05fix typos "precidence" -> "precedence" in commentsUwe Kleine-König
This patch was generated by git grep -E -i -l 'precidence' | xargs -r perl -p -i -e 's/precidence/precedence/' Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-31perf lock: Introduce new tool "perf lock", for analyzing lock statisticsHitoshi Mitake
Adding new subcommand "perf lock" to perf. I have a lot of remaining ToDos, but for now perf lock can already provide minimal functionality for analyzing lock statistics. Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1264851813-8413-12-git-send-email-mitake@dcl.info.waseda.ac.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-29tools/perf/perf.c: Clean up trivial style issuesThiago Farina
Checked with: ./../scripts/checkpatch.pl --terse --file perf.c perf.c: 51: ERROR: open brace '{' following function declarations go on the next line perf.c: 73: ERROR: "foo*** bar" should be "foo ***bar" perf.c:112: ERROR: space prohibited before that close parenthesis ')' perf.c:127: ERROR: space prohibited before that close parenthesis ')' perf.c:171: ERROR: "foo** bar" should be "foo **bar" perf.c:213: ERROR: "(foo*)" should be "(foo *)" perf.c:216: ERROR: "(foo*)" should be "(foo *)" perf.c:217: ERROR: space required before that '*' (ctx:OxV) perf.c:452: ERROR: do not initialise statics to 0 or NULL perf.c:453: ERROR: do not initialise statics to 0 or NULL Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> LKML-Reference: <1264633557-17597-7-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-21perf buildid-cache: Add new command to manage build-id cacheArnaldo Carvalho de Melo
For now it just has operations to examine a given file, find its build-id and add or remove it to/from the cache. Useful, for instance, when adding binaries sent together with a perf.data file, so that we can add them to the cache and have the tools find it when resolving symbols. It'll also manage the size of the cache like 'ccache' does. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1264008525-29025-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-28perf tools: Mount debugfs automaticallyXiao Guangrong
Mount debugfs filesystem under '/sys/kernel/debug', if it's not mounted. Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Clark Williams <williams@redhat.com> Cc: John Kacur <jkacur@redhat.com> LKML-Reference: <4B387090.7080407@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf diff: Introduce tool to show performance differenceArnaldo Carvalho de Melo
I guess it is enough to show some examples: [root@doppio linux-2.6-tip]# rm -f perf.data* [root@doppio linux-2.6-tip]# ls -la perf.data* ls: cannot access perf.data*: No such file or directory [root@doppio linux-2.6-tip]# perf record -f find / > /dev/null [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.062 MB perf.data (~2699 samples) ] [root@doppio linux-2.6-tip]# ls -la perf.data* -rw------- 1 root root 74440 2009-12-14 20:03 perf.data [root@doppio linux-2.6-tip]# perf record -f find / > /dev/null [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.062 MB perf.data (~2692 samples) ] [root@doppio linux-2.6-tip]# ls -la perf.data* -rw------- 1 root root 74280 2009-12-14 20:03 perf.data -rw------- 1 root root 74440 2009-12-14 20:03 perf.data.old [root@doppio linux-2.6-tip]# perf diff | head -5 1 -34994580 /lib64/libc-2.10.1.so _IO_vfprintf_internal 2 -15307806 [kernel.kallsyms] __kmalloc 3 +1 +3665941 /lib64/libc-2.10.1.so __GI_memmove 4 +4 +23508995 /lib64/libc-2.10.1.so _int_malloc 5 +7 +38538813 [kernel.kallsyms] __d_lookup [root@doppio linux-2.6-tip]# perf diff -p | head -5 1 +1.00% /lib64/libc-2.10.1.so _IO_vfprintf_internal 2 [kernel.kallsyms] __kmalloc 3 +1 /lib64/libc-2.10.1.so __GI_memmove 4 +4 /lib64/libc-2.10.1.so _int_malloc 5 +7 -1.00% [kernel.kallsyms] __d_lookup [root@doppio linux-2.6-tip]# perf diff -v | head -5 1 361449551 326454971 -34994580 /lib64/libc-2.10.1.so _IO_vfprintf_internal 2 151009241 135701435 -15307806 [kernel.kallsyms] __kmalloc 3 +1 101805328 105471269 +3665941 /lib64/libc-2.10.1.so __GI_memmove 4 +4 78041440 101550435 +23508995 /lib64/libc-2.10.1.so _int_malloc 5 +7 59536172 98074985 +38538813 [kernel.kallsyms] __d_lookup [root@doppio linux-2.6-tip]# perf diff -vp | head -5 1 9.00% 8.00% +1.00% /lib64/libc-2.10.1.so _IO_vfprintf_internal 2 3.00% 3.00% [kernel.kallsyms] __kmalloc 3 +1 2.00% 2.00% /lib64/libc-2.10.1.so __GI_memmove 4 +4 2.00% 2.00% /lib64/libc-2.10.1.so _int_malloc 5 +7 1.00% 2.00% -1.00% [kernel.kallsyms] __d_lookup [root@doppio linux-2.6-tip]# This should be enough for diffs where the system is non volatile, i.e. when one doesn't updates binaries. For volatile environments, stay tuned for the next perf tool feature: a buildid cache populated by 'perf record', managed by 'perf buildid-cache' a-la ccache, and used by all the report tools. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> LKML-Reference: <1260828571-3613-3-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-20perf: Add 'perf kmem' toolLi Zefan
This tool is mostly a perf version of kmemtrace-user. The following information is provided by this tool: - the total amount of memory allocated and fragmentation per call-site - the total amount of memory allocated and fragmentation per allocation - total memory allocated and fragmentation in the collected dataset - ... Sample output: # ./perf kmem record ^C # ./perf kmem --stat caller --stat alloc -l 10 ------------------------------------------------------------------------------ Callsite | Total_alloc/Per | Total_req/Per | Hit | Fragmentation ------------------------------------------------------------------------------ 0xc052f37a | 790528/4096 | 790528/4096 | 193 | 0.000% 0xc0541d70 | 524288/4096 | 524288/4096 | 128 | 0.000% 0xc051cc68 | 481600/200 | 481600/200 | 2408 | 0.000% 0xc0572623 | 297444/676 | 297440/676 | 440 | 0.001% 0xc05399f1 | 73476/164 | 73472/164 | 448 | 0.005% 0xc05243bf | 51456/256 | 51456/256 | 201 | 0.000% 0xc0730d0e | 31844/497 | 31808/497 | 64 | 0.113% 0xc0734c4e | 17152/256 | 17152/256 | 67 | 0.000% 0xc0541a6d | 16384/128 | 16384/128 | 128 | 0.000% 0xc059c217 | 13120/40 | 13120/40 | 328 | 0.000% 0xc0501ee6 | 11264/88 | 11264/88 | 128 | 0.000% 0xc04daef0 | 7504/682 | 7128/648 | 11 | 5.011% 0xc04e14a3 | 4216/191 | 4216/191 | 22 | 0.000% 0xc05041ca | 3524/44 | 3520/44 | 80 | 0.114% 0xc0734fa3 | 2104/701 | 1620/540 | 3 | 23.004% 0xc05ec9f1 | 2024/289 | 2016/288 | 7 | 0.395% 0xc06a1999 | 1792/256 | 1792/256 | 7 | 0.000% 0xc0463b9a | 1584/144 | 1584/144 | 11 | 0.000% 0xc0541eb0 | 1024/16 | 1024/16 | 64 | 0.000% 0xc06a19ac | 896/128 | 896/128 | 7 | 0.000% 0xc05721c0 | 772/12 | 768/12 | 64 | 0.518% 0xc054d1e6 | 288/57 | 280/56 | 5 | 2.778% 0xc04b562e | 157/31 | 154/30 | 5 | 1.911% 0xc04b536f | 80/16 | 80/16 | 5 | 0.000% 0xc05855a0 | 64/64 | 36/36 | 1 | 43.750% ------------------------------------------------------------------------------ ------------------------------------------------------------------------------ Alloc Ptr | Total_alloc/Per | Total_req/Per | Hit | Fragmentation ------------------------------------------------------------------------------ 0xda884000 | 1052672/4096 | 1052672/4096 | 257 | 0.000% 0xda886000 | 262144/4096 | 262144/4096 | 64 | 0.000% 0xf60c7c00 | 16512/128 | 16512/128 | 129 | 0.000% 0xf59a4118 | 13120/40 | 13120/40 | 328 | 0.000% 0xdfd4b2c0 | 11264/88 | 11264/88 | 128 | 0.000% 0xf5274600 | 7680/256 | 7680/256 | 30 | 0.000% 0xe8395000 | 5948/594 | 5464/546 | 10 | 8.137% 0xe59c3c00 | 5748/479 | 5712/476 | 12 | 0.626% 0xf4cd1a80 | 3524/44 | 3520/44 | 80 | 0.114% 0xe5bd1600 | 2892/482 | 2856/476 | 6 | 1.245% ... | ... | ... | ... | ... ------------------------------------------------------------------------------ SUMMARY ======= Total bytes requested: 2333626 Total bytes allocated: 2353712 Total bytes wasted on internal fragmentation: 20086 Internal fragmentation: 0.853375% TODO: - show sym+offset in 'callsite' column - show cross node allocation stats - collect more useful stats? - ... Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: linux-mm@kvack.org <linux-mm@kvack.org> LKML-Reference: <4B064AF5.9060208@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-17Merge branch 'perf/core' into perf/probesIngo Molnar
Resolved merge conflict in tools/perf/Makefile Merge reason: we want to queue up a dependent patch. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-16perf buildid-list: New plumbing commandArnaldo Carvalho de Melo
With this we can list the buildids in a perf.data file so that we can pipe them to other, distro specific tools that from the buildids can figure out separate packages (foo-debuginfo) where we can find the matching symtabs so that perf report can do its job. E.g: [acme@doppio linux-2.6-tip]$ perf buildid-list | head -5 8e08b117e5458ad3f85da16d42d0fc5cd21c5869 520c2387a587cc5acfcf881e27dba1caaeab4b1f ec8dd400904ddfcac8b1c343263a790f977159dc 7caedbca5a6d8ab39a7fe44bd28c07d3e14a3f3f 379bb828fd08859dbea73279f04abefabc95a6a3 [acme@doppio linux-2.6-tip]$ perf buildid-list -v | head -5 8e08b117e5458ad3f85da16d42d0fc5cd21c5869 /sbin/init 520c2387a587cc5acfcf881e27dba1caaeab4b1f /lib64/ld-2.10.1.so ec8dd400904ddfcac8b1c343263a790f977159dc /lib64/libc-2.10.1.so 7caedbca5a6d8ab39a7fe44bd28c07d3e14a3f3f /sbin/udevd 379bb828fd08859dbea73279f04abefabc95a6a3 /lib64/libdl-2.10.1.so [acme@doppio linux-2.6-tip]$ Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1258396365-29217-5-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-15Merge branches 'perf/powerpc' and 'perf/bench' into perf/coreIngo Molnar
Merge reason: Both 'perf bench' and the pending PowerPC changes are now ready for the next merge window. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-08perf tools: Modify perf routines to use new debugfs routinesClark Williams
modify perf.c get_debugfs_mntpnt() to use the util/debugfs.c debugfs_find_mountpoint() modify util/parse-events.c to use debugfs_valid_mountpoint(). Signed-off-by: Clark Williams <williams@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20091101155720.624cc87e@torg> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-08perf bench: Add new subcommand 'bench' to perf.cHitoshi Mitake
This patch modifies perf.c for invoking 'bench' subcommand. Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: fweisbec@gmail.com Cc: Jiri Kosina <jkosina@suse.cz> LKML-Reference: <1257381097-4743-7-git-send-email-mitake@dcl.info.waseda.ac.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-23Merge branch 'perf/core' into perf/probesIngo Molnar
Conflicts: tools/perf/Makefile Merge reason: - fix the conflict - pick up the pr_*() infrastructure to queue up dependent patch Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-13perf tools: Do not manually count string lengthsVincent Legoll
Use strlen & macros instead of manually counting string lengths as this is error prone and may lend to bugs. Signed-off-by: Vincent Legoll <vincent.legoll@gmail.com> Cc: Linus Torvalds <torvalds@osdl.org> LKML-Reference: <4727185d0910130118m5387058dndb02ac9b384af9f0@mail.gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-12perf probe: Add perf probe command support without libdwarfMasami Hiramatsu
Enables 'perf probe' even if libdwarf is not installed. If libdwarf is not found, 'perf probe' just disables dwarf support. Users can use 'perf probe' to set up new events by using kprobe_events format. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Hellwig <hch@infradead.org> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Frank Ch. Eigler <fche@redhat.com> LKML-Reference: <20091007222830.1684.25665.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-10-12perf: Add perf probe subcommand, a kprobe-event setup helperMasami Hiramatsu
Add perf probe subcommand that implements a kprobe-event setup helper to the perf command. This allows user to define kprobe events using C expressions (C line numbers, C function names, and C local variables). Usage ----- perf probe [<options>] -P 'PROBEDEF' [-P 'PROBEDEF' ...] -k, --vmlinux <file> vmlinux/module pathname -P, --probe <p|r:[GRP/]NAME FUNC[+OFFS][@SRC]|@SRC:LINE [ARG ...]> probe point definition, where p: kprobe probe r: kretprobe probe GRP: Group name (optional) NAME: Event name FUNC: Function name OFFS: Offset from function entry (in byte) SRC: Source code path LINE: Line number ARG: Probe argument (local variable name or kprobe-tracer argument format is supported.) Changes in v4: - Add _GNU_SOURCE macro for strndup(). Changes in v3: - Remove -r option because perf always be used for online kernel. - Check malloc/calloc results. Changes in v2: - Check synthesized string length. - Rename perf kprobe to perf probe. - Use spaces for separator and update usage comment. - Check error paths in parse_probepoint(). - Check optimized-out variables. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Hellwig <hch@infradead.org> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Frank Ch. Eigler <fche@redhat.com> LKML-Reference: <20091008211737.29299.14784.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-09-19perf: Add the timechart toolArjan van de Ven
timechart is a tool to visualize what is going on in the system. The user makes a trace of what is going on with > perf record --timechart /usr/bin/some_command and then can turn the output of this into an svg file > perf timechart which then can be viewed with any SVG view; inkscape works well enough for me. The idea behind timechart is to create a "infinitely zoomable" picture; something that has high level information on a 1:1 zoom level, but which exposes more details every time you zoom into a specific area. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090912130713.6a77bbc0@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-13perf: Add 'perf sched' toolIngo Molnar
This turn-key tool allows scheduler measurements to be conducted and the results be displayed numerically. First baby step towards that goal: clone the new command off of perf trace. Fix a few other details along the way: - add (minimal) perf trace documentation - reorder a few places - list perf trace in the mainporcelain list as well as it's a very useful utility. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-17perf tools: Add perf traceFrederic Weisbecker
This adds perf trace into the set of perf tools. It is written to fetch the tracepoint samples from perf events and display them, according to the events information given by the debugfs files through the util/trace* tools. It is a rough first shot and doesn't yet handle the cpu, timestamps fields and some other things. Example: perf record -f -e workqueue:workqueue_execution:record -F 1 -a perf trace kblockd/0-236 [000] 0.000000: workqueue_execution: thread=:236 func=cfq_kick_queue+0x0 kondemand/0-360 [000] 0.000000: workqueue_execution: thread=:360 func=do_dbs_timer+0x0 kondemand/0-360 [000] 0.000000: workqueue_execution: thread=:360 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 Todo: - A lot of things! Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: "Luis Claudio R. Goncalves" <lclaudio@uudg.org> Cc: Clark Williams <williams@redhat.com> Cc: Jon Masters <jonathan@jonmasters.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Christoph Hellwig <hch@infradead.org> Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Cc: Zhaolei <zhaolei@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Jiaying Zhang <jiayingz@google.com> Cc: Anton Blanchard <anton@samba.org> LKML-Reference: <1250518688-7207-4-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-22perf_counter: Detect debugfs locationJason Baron
If "/sys/kernel/debug" is not a debugfs mount point, search for the debugfs filesystem in /proc/mounts, but also allows the user to specify '--debugfs-dir=blah' or set the environment variable: 'PERF_DEBUGFS_DIR' Signed-off-by: Jason Baron <jbaron@redhat.com> [ also made it probe "/debug" by default ] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20090721181629.GA3094@redhat.com>
2009-07-01perf_counter tools: Add more warnings and fix/annotate themIngo Molnar
Enable -Wextra. This found a few real bugs plus a number of signed/unsigned type mismatches/uncleanlinesses. It also required a few annotations All things considered it was still worth it so lets try with this enabled for now. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-06perf_counter tools: Move from Documentation/perf_counter/ to tools/perf/Ingo Molnar
Several people have suggested that 'perf' has become a full-fledged tool that should be moved out of Documentation/. Move it to the (new) tools/ directory. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
