path: root/tools/perf/util/cpumap.h
2011-01-22perf tools: Add missing cpu_map__delete()Arnaldo Carvalho de Melo
Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-04perf tools: Refactor cpumap to hold nr and the mapArnaldo Carvalho de Melo
So that later, we can pass the cpu_map instance instead of (nr_cpus, cpu_map) for things like perf_evsel__open and friends. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-06-05perf tools: Add the ability to specify list of cpus to monitorStephane Eranian
This patch adds a -C option to stat, record, top to designate a list of CPUs to monitor. CPUs can be specified as a comma-separated list or ranges, no space allowed. Examples: $ perf record -a -C0-1,4-7 sleep 1 $ perf top -C0-4 $ perf stat -a -C1,2,3,4 sleep 1 With perf record in per-thread mode with inherit mode on, samples are collected only when the thread runs on the designated CPUs. The -C option does not turn on system-wide mode automatically. Cc: David S. Miller <davem@davemloft.net> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <4bff9496.d345d80a.41fe.7b00@mx.google.com> Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-03-11perf tools: Fix sparse CPU numbering related bugsPaul Mackerras
At present, the perf subcommands that do system-wide monitoring (perf stat, perf record and perf top) don't work properly unless the online cpus are numbered 0, 1, ..., N-1. These tools ask for the number of online cpus with sysconf(_SC_NPROCESSORS_ONLN) and then try to create events for cpus 0, 1, ..., N-1. This creates problems for systems where the online cpus are numbered sparsely. For example, a POWER6 system in single-threaded mode (i.e. only running 1 hardware thread per core) will have only even-numbered cpus online. This fixes the problem by reading the /sys/devices/system/cpu/online file to find out which cpus are online. The code that does that is in tools/perf/util/cpumap.[ch], and consists of a read_cpu_map() function that sets up a cpumap[] array and returns the number of online cpus. If /sys/devices/system/cpu/online can't be read or can't be parsed successfully, it falls back to using sysconf to ask how many cpus are online and sets up an identity map in cpumap[]. The perf record, perf stat and perf top code then calls read_cpu_map() in the system-wide monitoring case (instead of sysconf) and uses cpumap[] to get the cpu numbers to pass to perf_event_open. Signed-off-by: Paul Mackerras <paulus@samba.org> Cc: Anton Blanchard <anton@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> LKML-Reference: <20100310093609.GA3959@brick.ozlabs.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
