git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux-2.6 into perf/core
It was x86 specific and imcomplete at that, improve the situation by
making it clear where the example provided applies and by adding the
URLs for the Intel and AMD manuals where this is discussed in depth.
Acked-by: Robert Richter <robert.richter@amd.com>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
Cc: Frédéric Weisbecker <fweisbec@gmail.com>
Cc: Tom Zanussi <tzanussi@gmail.com>
Cc: Robert Richter <robert.richter@amd.com>
Reported-by: Robert Richter <robert.richter@amd.com
LKML-Reference: <new-submission>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Rename perf_event_attr::precise to perf_event_attr::precise_ip and
widen it to 2 bits. This new field describes the required precision of
the PERF_SAMPLE_IP field:
0 - SAMPLE_IP can have arbitrary skid
1 - SAMPLE_IP must have constant skid
2 - SAMPLE_IP requested to have 0 skid
3 - SAMPLE_IP must have 0 skid
And modify the Intel PEBS code accordingly. The PEBS implementation
now supports up to precise_ip == 2, where we perform the IP fixup.
Also s/PERF_RECORD_MISC_EXACT/&_IP/ to clarify its meaning, this bit
should be set for each PERF_SAMPLE_IP field known to match the actual
instruction triggering the event.
This new scheme allows for a PEBS mode that uses the buffer for more
than a single event.
Cc: Stephane Eranian <eranian@google.com>
Using explanation given by Ingo Molnar in the oprofile mailing list.
Suggested-by: Nick Black <dank@qemfd.net>
Cc: Nick Black <dank@qemfd.net>
The parse_single_tracepoint_event() was setting some attributes
before it validated the event was indeed a tracepoint event. This
caused problems with other initialization routines like in the
builtin-top.c module whereby sample_period is not set if not 0.
Signed-off-by: Stephane Eranian <eranian@google.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <4bcf232b.698fd80a.6fbe.ffffb737@mx.google.com>
Trace events are mostly used for tracing and then require not to
be lost when possible. As opposite to hardware events that really
require to trigger after a given sample period, trace events mostly
need to trigger everytime.
It is a frustrating experience to trace with perf and realize we
lost a lot of events because we forgot the "-c 1" option.
Then default sample_period to 1 for trace events but let the user
override it.
Trace events are mostly used for tracing rather than simple
counting. Don't bother anymore with adding -R when using them,
just record raw samples of trace events every time.
Mostly used in symbol.c so move them there to reduce the number
of files needed to use the symbol system.
Also do some header adjustments with the same intent.
LKML-Reference: <1269557941-15617-5-git-send-email-acme@infradead.org>
Minimal userspace interface to the new 'precise' events flag.
Can be used like "perf top -e r00c0p" which will use PEBS to sample
retired instructions.
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
Cc: paulus@samba.org
Cc: eranian@google.com
Cc: robert.richter@amd.com
Cc: fweisbec@gmail.com
LKML-Reference: <20100304140100.468665803@chello.nl>
Support glob wildcard when selecting tracepoint events by -e
option. Without this patch, perf-tools supports 'GROUP:*:record'
syntax for selecting all tracepoints under GROUP group.
With this patch, user can choose tracepoints more flexibly by using
partial wildcards, e.g. 'block:*bio*:record'.
Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com>
Cc: systemtap <systemtap@sources.redhat.com>
Cc: DLE <dle-develop@lists.sourceforge.net>
LKML-Reference: <20100105224717.19431.68972.stgit@dhcp-100-2-132.bos.redhat.com>
Just propagate eventual errors.
LKML-Reference: <1262047716-23171-2-git-send-email-acme@infradead.org>
make event type description to a unified array and
the array index consistent to perf_type_id.
Signed-off-by: Liming Wang <liming.wang@windriver.com>
Cc: Masami Hiramatsu <mhiramat@redhat.com>
LKML-Reference: <1262075829-16257-1-git-send-email-liming.wang@windriver.com>
Uses of strcat are almost always signs that someone is too lazy
to think about the code a bit more carefully. One always has to
know about the lengths of the strings involved to avoid buffer
overflows.
This is one case where the size of the object code for me is
reduced by 38 bytes. The code should also be faster, especially
if flags is non-NULL.
Signed-off-by: Ulrich Drepper <drepper@redhat.com>
Cc: a.p.zijlstra@chello.nl
Cc: jaswinderrajput@gmail.com
LKML-Reference: <200912061825.nB6IPUa1023306@hs20-bc2-1.build.redhat.com>
The size argument to zalloc should be the size of desired
structure, not the pointer to it.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@expression@
expression *x;
x =
-sizeof(x)
+sizeof(*x)
...+>// </smpl>
LKML-Reference: <Pine.LNX.4.64.0912061016120.20858@ask.diku.dk>
This way we type less characters and it looks more like the
kzalloc kernel counterpart.
LKML-Reference: <1259071517-3242-3-git-send-email-acme@infradead.org>
Add the breakpoint events support with this new sysnopsis:
mem:addr[:access]
Where addr is a raw addr value in the kernel and access can be
either [r][w][x]
Example to profile tasklist_lock:
$ grep tasklist_lock /proc/kallsyms
ffffffff8189c000 D tasklist_lock
$ perf record -e mem:0xffffffff8189c000:rw -a -f -c 1
$ perf report
# Samples: 62
# Overhead Command Shared Object Symbol
29.03% swapper [kernel] [k] _raw_read_trylock
29.03% swapper [kernel] [k] _raw_read_unlock
19.35% init [kernel] [k] _raw_read_trylock
19.35% init [kernel] [k] _raw_read_unlock
1.61% events/0 [kernel] [k] _raw_read_trylock
1.61% events/0 [kernel] [k] _raw_read_unlock
Coming soon:
- Support for symbols in the event definition.
- Default period to 1 for breakpoint events because these are
not high frequency events. The same thing is needed for trace
events.
Cc: Prasad <prasad@linux.vnet.ibm.com>
LKML-Reference: <1258987355-8751-4-git-send-email-fweisbec@gmail.com>
Merge reason: Both 'perf bench' and the pending PowerPC changes
are now ready for the next merge window.
modify perf.c get_debugfs_mntpnt() to use the util/debugfs.c
debugfs_find_mountpoint()
modify util/parse-events.c to use debugfs_valid_mountpoint().
Signed-off-by: Clark Williams <williams@redhat.com>
LKML-Reference: <20091101155720.624cc87e@torg>
Add two more software events that are common to many cpus.
Alignment faults: When a load or store is not aligned properly.
Emulation faults: When an instruction is emulated in software.
Both cause a very significant slowdown (100x or worse), so identifying and
fixing them is very important.
Writing to stdout is probably the expected behavior because the
user explicitly asked for a list.
Signed-off-by: Marti Raudsepp <marti@juffo.org>
LKML-Reference: <4ebb59420ef057972167.1256603585@localhost>
Previously no indication was given about what went wrong.
LKML-Reference: <03ec9ee96f17cef05424.1256603584@localhost>
Add a new option "--filter <filter_str>" to perf record, and
it should be right after "-e trace_point":
#./perf record -R -f -e irq:irq_handler_entry --filter irq==18
^C
# ./perf trace
perf-4303 ... irq_handler_entry: irq=18 handler=eth0
init-0 ... irq_handler_entry: irq=18 handler=eth0
See Documentation/trace/events.txt for the syntax of filter
expressions.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
LKML-Reference: <4AD6955F.90602@cn.fujitsu.com>
Timechart doesn't work if debugfs is not in /sys/kernel/debug/.
Fixed by using global debugfs_path which is filled in by perf.
Signed-off-by: Ashwin Chaugule <ashwinc@quicinc.com>
Cc: "Arjan van de Ven" <arjan@linux.intel.com>
LKML-Reference: <a751bdc6978478de6d10440e587a2cc7.squirrel@www.codeaurora.org>
openat() is still a young glibc facility, better to not use it in a
non performance critical program (perf list)
Many machines have older glibc (RHEL 4 Update 5 -> glibc-2.3.4-2.36
on my dev machine for example).
Cc: Ulrich Drepper <drepper@redhat.com>
LKML-Reference: <4ABB767D.6080004@gmail.com>
Bye-bye Performance Counters, welcome Performance Events!
In the past few months the perfcounters subsystem has grown out its
initial role of counting hardware events, and has become (and is
becoming) a much broader generic event enumeration, reporting, logging,
monitoring, analysis facility.
Naming its core object 'perf_counter' and naming the subsystem
'perfcounters' has become more and more of a misnomer. With pending
code like hw-breakpoints support the 'counter' name is less and
less appropriate.
All in one, we've decided to rename the subsystem to 'performance
events' and to propagate this rename through all fields, variables
and API names. (in an ABI compatible fashion)
The word 'event' is also a bit shorter than 'counter' - which makes
it slightly more convenient to write/handle as well.
Thanks goes to Stephane Eranian who first observed this misnomer and
suggested a rename.
User-space tooling and ABI compatibility is not affected - this patch
should be function-invariant. (Also, defconfigs were not touched to
keep the size down.)
This patch has been generated via the following script:
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/PERF_EVENT_/PERF_RECORD_/g' \
-e 's/PERF_COUNTER/PERF_EVENT/g' \
-e 's/perf_counter/perf_event/g' \
-e 's/nb_counters/nb_events/g' \
-e 's/swcounter/swevent/g' \
-e 's/tpcounter_event/tp_event/g' \
$FILES
for N in $(find . -name perf_counter.[ch]); do
M=$(echo $N | sed 's/perf_counter/perf_event/g')
mv $N $M
done
FILES=$(find . -name perf_event.*)
sed -i \
-e 's/COUNTER_MASK/REG_MASK/g' \
-e 's/COUNTER/EVENT/g' \
-e 's/\<event\>/event_id/g' \
-e 's/counter/event/g' \
-e 's/Counter/Event/g' \
$FILES
... to keep it as correct as possible. This script can also be
used by anyone who has pending perfcounters patches - it converts
a Linux kernel tree over to the new naming. We tried to time this
change to the point in time where the amount of pending patches
is the smallest: the end of the merge window.
Namespace clashes were fixed up in a preparatory patch - and some
stylistic fallout will be fixed up in a subsequent patch.
( NOTE: 'counters' are still the proper terminology when we deal
with hardware registers - and these sed scripts are a bit
over-eager in renaming them. I've undone some of that, but
in case there's something left where 'counter' would be
better than 'event' we can undo that on an individual basis
instead of touching an otherwise nicely automated patch. )
Suggested-by: Stephane Eranian <eranian@google.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Acked-by: Paul Mackerras <paulus@samba.org>
Reviewed-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: <linux-arch@vger.kernel.org>
The trace event name<->id mapping is dynamic for each kernel
compile. In order for perf.data to be useable outside the actual
system, we thus need to store a table of this mapping for later
use.
This patch adds this table to perf.data, and provides helper
functions for lookup up fields from this table.
To avoid mistakes, lookup-from-table is kept completely seprate
from lookup-from-local-debugfs.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
LKML-Reference: <20090912130405.6960d099@infradead.org>
Sample timestamp and cpu just like the -R option.
Before:
init-0 [-01] 1266874889.17179869184709551615: irq_handler_entry: irq=18 handler=eth0
init-0 [-01] 1266874889.17179869184709551615: irq_handler_entry: irq=1 handler=i8042
After:
init-0 [001] 7364.568965353: irq_handler_entry: irq=18 handler=eth0
init-0 [001] 7365.530226877: irq_handler_entry: irq=1 handler=i8042
init-0 [001] 7365.542831563: irq_handler_entry: irq=18 handler=eth0
init-0 [001] 7365.644156299: irq_handler_entry: irq=18 handler=eth0
init-0 [001] 7365.694556201: irq_handler_entry: irq=18 handler=eth0
LKML-Reference: <4AB1F827.8040905@cn.fujitsu.com>
The name length of some trace events is longer than 30, like
sys_enter_sched_get_priority_max and
ext4_mb_discard_preallocations.
Passing those events to perf-record will fail, try:
# ./perf record -f -e syscalls:sys_enter_sched_get_priority_max -F 1 -a
LKML-Reference: <4AB1F4AB.7050205@cn.fujitsu.com>
Implement the 'perf sched record' subcommand that adds a
default list of events, turns on raw sampling and system-wide
tracing and passes off the rest of the command to perf record.
This is more convenient than having to specify the events all
the time.
Before:
$ perf record -a -R -e sched:sched_switch:r -e sched:sched_stat_wait:r -e sched:sched_stat_sleep:r -e sched:sched_stat_iowait:r -e sched:sched_process_exit:r -e sched:sched_process_fork:r -e sched:sched_wakeup:r -e sched:sched_migrate_task:r -c 1 sleep 1
After:
$ perf sched record -f sleep 1
Also fix an assumption in the event string parser that assumed
that strings passed in can be modified. (In this case they wont
be as they come from a readonly constant section.)
Currently, when one wants to activate every tracepoint
counters of a subsystem from perf record, the current sequence
is needed:
perf record -e subsys:ev1 -e subsys:ev2 -e subsys:ev3
This may annoy the most patient of us.
Now we can just do:
perf record -e subsys:*
* 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (105 commits)
ring-buffer: only enable ring_buffer_swap_cpu when needed
ring-buffer: check for swapped buffers in start of committing
tracing: report error in trace if we fail to swap latency buffer
tracing: add trace_array_printk for internal tracers to use
tracing: pass around ring buffer instead of tracer
tracing: make tracing_reset safe for external use
tracing: use timestamp to determine start of latency traces
tracing: Remove mentioning of legacy latency_trace file from documentation
tracing/filters: Defer pred allocation, fix memory leak
tracing: remove users of tracing_reset
tracing: disable buffers and synchronize_sched before resetting
tracing: disable update max tracer while reading trace
tracing: print out start and stop in latency traces
ring-buffer: disable all cpu buffers when one finds a problem
ring-buffer: do not count discarded events
ring-buffer: remove ring_buffer_event_discard
ring-buffer: fix ring_buffer_read crossing pages
ring-buffer: remove unnecessary cpu_relax
ring-buffer: do not swap buffers during a commit
ring-buffer: do not reset while in a commit
Merge reason: move from -rc5 to -rc9.
This patch improves some (common) inefficiencies in the
handling of directory lookups:
- not using the d_type information returned by the kernel
- constructing (absolute) paths for file operation even though
directory-relative operations using the *at functions is
possible
There are more places to fix but this is a start.
LKML-Reference: <20090904193951.GB6186@ghostprotocols.net>
While opening a trace event counter, every events are saved in
the trace.info file. But we only want to save the
specifications of the events we are using.
LKML-Reference: <1251421798-9101-1-git-send-email-fweisbec@gmail.com>
Related to a shadowed variable bug fix Valdis Kletnieks noticed
that perf does not get built with -Wshadow, which could have
helped us avoid the bug.
So enable -Wshadow and also enable the following warnings on
perf builds, in addition to the already enabled -Wall -Wextra
-std=gnu99 warnings:
-Wcast-align
-Wformat=2
-Wshadow
-Winit-self
-Wpacked
-Wredundant-decls
-Wstack-protector
-Wstrict-aliasing=3
-Wswitch-default
-Wswitch-enum
-Wno-system-headers
-Wundef
-Wvolatile-register-var
-Wwrite-strings
-Wbad-function-cast
-Wmissing-declarations
-Wmissing-prototypes
-Wnested-externs
-Wold-style-definition
-Wstrict-prototypes
-Wdeclaration-after-statement
And change/fix the perf code to build cleanly under GCC 4.3.2.
The list of warnings enablement is rather arbitrary: it's based
on my (quick) reading of the GCC manpages and trying them on
perf.
I categorized the warnings based on individually enabling them
and looking whether they trigger something in the perf build.
If i liked those warnings (i.e. if they trigger for something
that arguably could be improved) i enabled the warning.
If the warnings seemed to come from language laywers spamming
the build with tons of nuisance warnings i generally kept them
off. Most of the sign conversion related warnings were in
this category. (A second patch enabling some of the sign
warnings might be welcome - sign bugs can be nasty.)
I also kept warnings that seem to make sense from their manpage
description and which produced no actual warnings on our code
base. These warnings might still be turned off if they end up
being a nuisance.
I also left out a few warnings that are not supported in older
compilers.
[ Note that these changes might break the build on older
compilers i did not test, or on non-x86 architectures that
produce different warnings, so more testing would be welcome. ]
Reported-by: Valdis.Kletnieks@vt.edu
Add a new flag field while opening a tracepoint perf counter:
-e tracepoint_subsystem:tracepoint_name:flags
This is intended to be generic although for now it only supports the
r[e[c[o[r[d]]]]] flag:
./perf record -e workqueue:workqueue_insertion:record
will have the same effect: enabling the raw samples record for
the given tracepoint counter.
In the future, we may want to support further flags, separated
by commas.
LKML-Reference: <1250152039-7284-1-git-send-email-fweisbec@gmail.com>
The new syscall tracepoints names can be too long for the 'perf list'
output.
Add a few more characters.
Signed-off-by: Jason Baron <jbaron@redhat.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Jiaying Zhang <jiayingz@google.com>
Cc: Martin Bligh <mbligh@google.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Stop perf list from displaying tracepoints without an id file,
those are special tracepoints that are not interfaced to
perfcounters so listing them is erroneous and passing them as
events will produce no output.
Acked-by: Jason Baron <jbaron@redhat.com>
Cc: Chris Mason <chris.mason@oracle.com>
Brice Goglin reported:
> I can easily sort them by thread id, but I don't know how to match
> my 4 events with each group of 4 lines.
Also report the counter id and the time running/enabled
stats (in case the counter got time-shared).
Reported-by: Brice Goglin <Brice.Goglin@inria.fr>
Tested-by: Brice Goglin <Brice.Goglin@inria.fr>
If "/sys/kernel/debug" is not a debugfs mount point, search for the debugfs
filesystem in /proc/mounts, but also allows the user to specify
'--debugfs-dir=blah' or set the environment variable: 'PERF_DEBUGFS_DIR'
[ also made it probe "/debug" by default ]
LKML-Reference: <20090721181629.GA3094@redhat.com>
Add support to 'perf list' and 'perf stat' for kernel tracepoints. The
implementation creates a 'for_each_subsystem' and 'for_each_event' for
easy iteration over the tracepoints.
LKML-Reference: <426129bf9fcc8ee63bb094cf736e7316a7dcd77a.1248190728.git.jbaron@redhat.com>
Keep index within event_type_descriptors[]
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
LKML-Reference: <4A5A7F0B.4070106@gmail.com>
The cache events contain '$' which will hit shell variable
expansion. To avoid confusion change this to 'cache', ie
L1-d$-loads becomes L1-dcache-loads.
Cc: Roland Dreier <rdreier@cisco.com>
Cc: Jaswinder Singh Rajput <jaswinder@kernel.org>
LKML-Reference: <20090706120131.GB4391@kryten>
After:
$ ./perf list
List of pre-defined events (to be used in -e):
cpu-cycles OR cycles [Hardware event]
instructions [Hardware event]
cache-references [Hardware event]
cache-misses [Hardware event]
branch-instructions OR branches [Hardware event]
branch-misses [Hardware event]
bus-cycles [Hardware event]
cpu-clock [Software event]
task-clock [Software event]
page-faults OR faults [Software event]
minor-faults [Software event]
major-faults [Software event]
context-switches OR cs [Software event]
cpu-migrations OR migrations [Software event]
L1-d$-loads [Hardware cache event]
L1-d$-load-misses [Hardware cache event]
L1-d$-stores [Hardware cache event]
L1-d$-store-misses [Hardware cache event]
L1-d$-prefetches [Hardware cache event]
L1-d$-prefetch-misses [Hardware cache event]
L1-i$-loads [Hardware cache event]
L1-i$-load-misses [Hardware cache event]
L1-i$-prefetches [Hardware cache event]
L1-i$-prefetch-misses [Hardware cache event]
LLC-loads [Hardware cache event]
LLC-load-misses [Hardware cache event]
LLC-stores [Hardware cache event]
LLC-store-misses [Hardware cache event]
LLC-prefetches [Hardware cache event]
LLC-prefetch-misses [Hardware cache event]
dTLB-loads [Hardware cache event]
dTLB-load-misses [Hardware cache event]
dTLB-stores [Hardware cache event]
dTLB-store-misses [Hardware cache event]
dTLB-prefetches [Hardware cache event]
dTLB-prefetch-misses [Hardware cache event]
iTLB-loads [Hardware cache event]
iTLB-load-misses [Hardware cache event]
branch-loads [Hardware cache event]
branch-load-misses [Hardware cache event]
rNNN [raw hardware event descriptor]
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
LKML-Reference: <1246453578.3072.1.camel@ht.satnam>
Enable -Wextra. This found a few real bugs plus a number
of signed/unsigned type mismatches/uncleanlinesses. It
also required a few annotations
All things considered it was still worth it so lets try with
this enabled for now.
This reworks the parser for event descriptors to make it more
consistent in what it accepts. It is now structured as a
recursive descent parser for the following grammar:
events ::= event ( ("," | space) space* event )*
event ::= ( raw_event | numeric_event | symbolic_event |
generic_hw_event ) [ event_modifier ]
raw_event ::= "r" hex_number
numeric_event ::= number ":" number
number ::= decimal_number | "0x" hex_number | "0" octal_number
symbolic_event ::= string_from_event_symbols_array
generic_hw_event::= cache_type ( "-" ( cache_op | cache_result ) )*
event_modifier ::= ":" ( "u" | "k" | "h" )+
with the extra restriction that you can have at most one
cache_op and at most one cache_result.
We pass the current string pointer by reference (i.e. as a
const char **) to the various parsing functions so that they
can advance the pointer to indicate how much they consumed.
They return 0 if they didn't recognize the thing at the pointer
or 1 if they did (and advance the pointer past it).
This also fixes parse_aliases to take the longest matching
alias from the table, not the first one. Otherwise "l1-data"
would match the "l1-d" alias and the "ata" would not be
consumed.
This allows event modifiers indicating what processor modes to
count in to be applied to any event, not just numeric events,
and adds a ":h" modifier to indicate counting in hypervisor
mode. Specifying ":u" now sets both exclude_kernel and
exclude_hv, and so on. Multiple modes can be specified, e.g.
":uk" will count in user or hypervisor mode (i.e. only
exclude_kernel will be set).
LKML-Reference: <19018.53826.843815.189847@cargo.ozlabs.ibm.com>
Add 'l1d' and 'l1i' aliases again as shortcuts - just dont make them
the primary display alias.
LKML-Reference: <1245945462.9157.11.camel@hpdv5.satnam>
Added new alias for events.
On AMD box:
$ ./perf stat -e l1d -e l1d-misses -e l1d-write -e l1d-prefetch -e l1d-prefetch-miss -e l1i -e l1i-misses -e l1i-prefetch -e l2 -e l2-misses -e l2-write -e dtlb -e dtlb-misses -e itlb -e itlb-misses -e bpu -e bpu-misses -- ls -lR /usr/include/ > /dev/null
Before :
Performance counter stats for 'ls -lR /usr/include/':
248064467 L1-data-Cache-Load-Referencees (scaled from 23.27%)
1001433 L1-data-Cache-Load-Misses (scaled from 23.34%)
153691 L1-data-Cache-Store-Referencees (scaled from 23.34%)
423248 L1-data-Cache-Prefetch-Referencees (scaled from 23.33%)
302138 L1-data-Cache-Prefetch-Misses (scaled from 23.25%)
251217546 L1-instruction-Cache-Load-Referencees (scaled from 23.25%)
5757005 L1-instruction-Cache-Load-Misses (scaled from 23.23%)
93435 L1-instruction-Cache-Prefetch-Referencees (scaled from 23.24%)
6496073 L2-Cache-Load-Referencees (scaled from 23.32%)
609485 L2-Cache-Load-Misses (scaled from 23.45%)
6876991 L2-Cache-Store-Referencees (scaled from 23.71%)
248922840 Data-TLB-Cache-Load-Referencees (scaled from 23.94%)
5828386 Data-TLB-Cache-Load-Misses (scaled from 24.17%)
257613506 Instruction-TLB-Cache-Load-Referencees (scaled from 24.20%)
6833 Instruction-TLB-Cache-Load-Misses (scaled from 23.88%)
109043606 Branch-Cache-Load-Referencees (scaled from 23.64%)
5552296 Branch-Cache-Load-Misses (scaled from 23.42%)
0.413702461 seconds time elapsed.
After :
Peformance counter stats for 'ls -lR /usr/include/':
266590464 L1-d$-loads (scaled from 23.03%)
1222273 L1-d$-load-misses (scaled from 23.58%)
146204 L1-d$-stores (scaled from 23.83%)
406344 L1-d$-prefetches (scaled from 24.09%)
283748 L1-d$-prefetch-misses (scaled from 24.10%)
249650965 L1-i$-loads (scaled from 23.80%)
3353961 L1-i$-load-misses (scaled from 23.82%)
104599 L1-i$-prefetches (scaled from 23.68%)
4836405 LLC-loads (scaled from 23.67%)
498214 LLC-load-misses (scaled from 23.66%)
4953994 LLC-stores (scaled from 23.64%)
243354097 dTLB-loads (scaled from 23.77%)
6468584 dTLB-load-misses (scaled from 23.74%)
249719549 iTLB-loads (scaled from 23.25%)
5060 iTLB-load-misses (scaled from 23.00%)
112343016 branch-loads (scaled from 22.76%)
5528876 branch-load-misses (scaled from 22.54%)
0.427154051 seconds time elapsed.
Reported-by : Ingo Molnar <mingo@elte.hu>
LKML-Reference: <1245934522.5308.39.camel@hpdv5.satnam>
Made new table for cache operartion stat 'hw_cache_stat' as:
L1I : Read and prefetch only
ITLB and BPU : Read-only
introduce is_cache_op_valid() for cache operation validity
And checks for valid cache operations.
LKML-Reference: <1245930367.5308.33.camel@localhost.localdomain>
"faults" should be alias for "page-faults"
Also fixed alignment and 80 characters issue
LKML-Reference: <1245683846.12092.1.camel@localhost.localdomain>
