[ Upstream commit 7934c98a6e04028eb34c1293bfb5a6b0ab630b66 ]
Markus reported that perf segfaults when reading /sys/kernel/notes from
a kernel linked with GNU gold, due to what looks like a gold bug, so do
some bounds checking to avoid crashing in that case.
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Report-Link: http://lkml.kernel.org/r/20161219161821.GA294@x4
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Wang Nan <wangnan0@huawei.com>
Link: http://lkml.kernel.org/n/tip-ryhgs6a6jxvz207j2636w31c@git.kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
target
[ Upstream commit 80f62589fa52f530cffc50e78c0b5a2ae572d61e ]
When the jump instruction is displayed at the row 0 in annotate view,
the arrow is broken. An example:
16.86 │ ┌──je 82
0.01 │ movsd (%rsp),%xmm0
│ movsd 0x8(%rsp),%xmm4
│ movsd 0x8(%rsp),%xmm1
│ movsd (%rsp),%xmm3
│ divsd %xmm4,%xmm0
│ divsd %xmm3,%xmm1
│ movsd (%rsp),%xmm2
│ addsd %xmm1,%xmm0
│ addsd %xmm2,%xmm0
│ movsd %xmm0,(%rsp)
│82: sub $0x1,%ebx
83.03 │ ↑ jne 38
│ add $0x10,%rsp
│ xor %eax,%eax
│ pop %rbx
│ ← retq
The patch increments the row number before checking with 0.
Signed-off-by: Yao Jin <yao.jin@linux.intel.com>
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Kan Liang <kan.liang@intel.com>
Cc: stable@vger.kernel.org
Fixes: 944e1abed9e1 ("perf ui browser: Add method to draw up/down arrow line")
Link: http://lkml.kernel.org/r/1496901704-30275-1-git-send-email-yao.jin@linux.intel.com
[ Upstream commit 3ed5ca2efff70e9f589087c2013789572901112d ]
We catch this record to provide a visual indication that events are
getting lost, then call the default method to allow extra logging shared
with the other tools to take place.
This extra logging was done twice because we were continuing to the
"default" clause where machine__process_event() will end up calling
machine__process_lost_event() again, fix it.
Link: http://lkml.kernel.org/n/tip-wus2zlhw3qo24ye84ewu4aqw@git.kernel.org
[ Upstream commit d85ce830eef6c10d1e9617172dea4681f02b8424 ]
One line in perf_pmu__parse_unit() is indented wrongly, leading to a
warning (=> error) from gcc 6:
util/pmu.c:156:3: error: statement is indented as if it were guarded by... [-Werror=misleading-indentation]
sret = read(fd, alias->unit, UNIT_MAX_LEN);
util/pmu.c:153:2: note: ...this 'if' clause, but it is not
if (fd == -1)
Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Fixes: 410136f5dd96 ("tools/perf/stat: Add event unit and scale support")
Link: http://lkml.kernel.org/r/20151214154440.GC1409@x4
[ Upstream commit d4913cbd05bab685e49c8174896e563b2487d054 ]
The issue was pointed out by gcc-6's -Wmisleading-indentation.
Fixes: c97cf42219b7 ("perf top: Live TUI Annotation")
Link: http://lkml.kernel.org/r/20151214154403.GB1409@x4
[ Upstream commit 3b556bced46aa6b1873da7faa18eff235e896adc ]
Signed-off-by: Eric Engestrom <eric.engestrom@imgtec.com>
Link: http://lkml.kernel.org/r/1461577678-29517-1-git-send-email-eric.engestrom@imgtec.com
[ Upstream commit a5e8e825bd1704c488bf6a46936aaf3b9f203d6a ]
The readdir() function is thread safe as long as just one thread uses a
DIR, which is the case in 'perf script', so, to avoid breaking the build
with glibc-2.23.90 (upcoming 2.24), use it instead of readdir_r().
See: http://man7.org/linux/man-pages/man3/readdir.3.html
"However, in modern implementations (including the glibc implementation),
concurrent calls to readdir() that specify different directory streams
are thread-safe. In cases where multiple threads must read from the
same directory stream, using readdir() with external synchronization is
still preferable to the use of the deprecated readdir_r(3) function."
Noticed while building on a Fedora Rawhide docker container.
Link: http://lkml.kernel.org/n/tip-mt3xz7n2hl49ni2vx7kuq74g@git.kernel.org
[ Upstream commit 7093b4c963cc4e344e490c774924a180602a7092 ]
DIR, which is the case when synthesizing events for pre-existing threads
by traversing /proc, so, to avoid breaking the build with glibc-2.23.90
CC /tmp/build/perf/util/event.o
util/event.c: In function '__event__synthesize_thread':
util/event.c:466:2: error: 'readdir_r' is deprecated [-Werror=deprecated-declarations]
while (!readdir_r(tasks, &dirent, &next) && next) {
In file included from /usr/include/features.h:368:0,
from /usr/include/stdint.h:25,
from /usr/lib/gcc/x86_64-redhat-linux/6.0.0/include/stdint.h:9,
from /git/linux/tools/include/linux/types.h:6,
from util/event.c:1:
/usr/include/dirent.h:189:12: note: declared here
Link: http://lkml.kernel.org/n/tip-i1vj7nyjp2p750rirxgrfd3c@git.kernel.org
[ Upstream commit 2e2bbc039fad9eabad6c4c1a473c8b2554cdd2d4 ]
Addressing a few cases spotted by a new warning in gcc 7:
tests/parse-events.c: In function 'test_pmu_events':
tests/parse-events.c:1790:39: error: '%s' directive output may be truncated writing up to 255 bytes into a region of size 90 [-Werror=format-truncation=]
snprintf(name, MAX_NAME, "cpu/event=%s/u", ent->d_name);
In file included from /usr/include/stdio.h:939:0,
from /git/linux/tools/perf/util/map.h:9,
from /git/linux/tools/perf/util/symbol.h:7,
from /git/linux/tools/perf/util/evsel.h:10,
from tests/parse-events.c:3:
/usr/include/bits/stdio2.h:64:10: note: '__builtin___snprintf_chk' output between 13 and 268 bytes into a destination of size 100
return __builtin___snprintf_chk (__s, __n, __USE_FORTIFY_LEVEL - 1,
__bos (__s), __fmt, __va_arg_pack ());
tests/parse-events.c:1798:29: error: '%s' directive output may be truncated writing up to 255 bytes into a region of size 100 [-Werror=format-truncation=]
snprintf(name, MAX_NAME, "%s:u,cpu/event=%s/u", ent->d_name, ent->d_name);
Fixes: 945aea220bb8 ("perf tests: Move test objects into 'tests' directory")
Link: http://lkml.kernel.org/n/tip-ty4q2p8zp1dp3mskvubxskm5@git.kernel.org
[ Upstream commit d7dd112ea5cacf91ae72c0714c3b911eb6016fea ]
Fix below compile error:
CC util/scripting-engines/trace-event-perl.o
In file included from /usr/lib/perl5/5.22.2/i686-linux/CORE/perl.h:5673:0,
from util/scripting-engines/trace-event-perl.c:31:
/usr/lib/perl5/5.22.2/i686-linux/CORE/inline.h: In function 'S__is_utf8_char_slow':
/usr/lib/perl5/5.22.2/i686-linux/CORE/inline.h:270:5: error: nested extern declaration of 'Perl___notused' [-Werror=nested-externs]
dTHX; /* The function called below requires thread context */
cc1: all warnings being treated as errors
After digging perl5 repository, I find out that we will meet this
compile error with perl from v5.21.1 to v5.25.4
Signed-off-by: Wang YanQing <udknight@gmail.com>
Acked-by: Jiri Olsa <jolsa@kernel.org>
Link: http://lkml.kernel.org/r/20170212024655.GA15997@udknight
[ Upstream commit bdf23a9a190d7ecea092fd5c4aabb7d4bd0a9980 ]
The size of dirent->dt_name is NAME_MAX + 1, but the size for the 'path'
buffer is hard coded at 256, which may truncate it because we also
prepend "/proc/", so that all that into account and thank gcc 7 for this
warning:
/git/linux/tools/perf/util/thread_map.c: In function 'thread_map__new_by_uid':
/git/linux/tools/perf/util/thread_map.c:119:39: error: '%s' directive output may be truncated writing up to 255 bytes into a region of size 250 [-Werror=format-truncation=]
snprintf(path, sizeof(path), "/proc/%s", dirent->d_name);
from /git/linux/tools/perf/util/thread_map.c:5:
/usr/include/bits/stdio2.h:64:10: note: '__builtin___snprintf_chk' output between 7 and 262 bytes into a destination of size 256
Link: http://lkml.kernel.org/n/tip-csy0r8zrvz5efccgd4k12c82@git.kernel.org
[ Upstream commit 7b0214b702ad8e124e039a317beeebb3f020d125 ]
The implicit fall through case label here is intended, so let us inform
that to gcc >= 7:
CC /tmp/build/perf/builtin-top.o
builtin-top.c: In function 'display_thread':
builtin-top.c:644:7: error: this statement may fall through [-Werror=implicit-fallthrough=]
if (errno == EINTR)
builtin-top.c:647:3: note: here
default:
Link: http://lkml.kernel.org/n/tip-lmcfnnyx9ic0m6j0aud98p4e@git.kernel.org
[ Upstream commit 94bdd5edb34e472980d1e18b4600d6fb92bd6b0a ]
that to gcc >= 7:
CC /tmp/build/perf/util/string.o
util/string.c: In function 'perf_atoll':
util/string.c:22:7: error: this statement may fall through [-Werror=implicit-fallthrough=]
if (*p)
util/string.c:24:3: note: here
case '\0':
Link: http://lkml.kernel.org/n/tip-0ophb30v9apkk6o95el0rqlq@git.kernel.org
[ Upstream commit f594bae08183fb6b57db55387794ece3e1edf6f6 ]
I'm surprised this remained undocumented since at least 2011. And it is
actually a very useful switch, as Steve and I came to realize recently.
Add the text from
2cba3ffb9a9d ("perf stat: Add -d -d and -d -d -d options to show more CPU events")
which added the incrementing aspect to -d.
Cc: Davidlohr Bueso <dbueso@suse.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Mel Gorman <mgorman@suse.com>
Fixes: 2cba3ffb9a9d ("perf stat: Add -d -d and -d -d -d options to show more CPU events")
Link: http://lkml.kernel.org/r/1457347294-32546-1-git-send-email-bp@alien8.de
[ Upstream commit 89fee59b504f86925894fcc9ba79d5c933842f93 ]
Steam frequently puts game binaries in folders with spaces.
Note: "(deleted)" markers are now treated as part of the file name.
Signed-off-by: Marcin Ślusarz <marcin.slusarz@gmail.com>
Acked-by: Namhyung Kim <namhyung@kernel.org>
Fixes: 6064803313ba ("perf tools: Use sscanf for parsing /proc/pid/maps")
Link: http://lkml.kernel.org/r/20160119190303.GA17579@marcin-Inspiron-7720
[ Upstream commit 940db6dcd3f4659303fdf6befe7416adc4d24118 ]
When an error happens during alias parsing currently the complete
parsing of all attributes of the PMU is stopped. This is breaks old perf
on a newer kernel that may have not-yet-know alias attributes (such as
.scale or .per-pkg).
Continue when some attribute is unparseable.
This is IMHO a stable candidate and should be backported to older
versions to avoid problems with newer kernels.
v2: Print warnings when something goes wrong.
v3: Change warning to debug output
Cc: stable@vger.kernel.org # v3.6+
Link: http://lkml.kernel.org/r/1455749095-18358-1-git-send-email-andi@firstfloor.org
[ Upstream commit c8ad7063626406181a7ebab10cb31b4f741b13d4 ]
Building perf out of kernel tree is currently broken because the
MANIFEST file refers to kernel files that have been removed. With this
patch make perf-targz-src-pkg succeeds as does building perf using the
generated tarfile.
Signed-off-by: David Ahern <david.ahern@oracle.com>
Link: http://lkml.kernel.org/r/1433526173-172332-1-git-send-email-david.ahern@oracle.com
recording/reporting guest data
[ Upstream commit 3caeaa562733c4836e61086ec07666635006a787 ]
While recording guest samples in host using perf kvm record, it will
populate unprocessable sample error, though samples will be recorded
properly. While generating report using perf kvm report, no samples will
be processed and same error will populate. We have seen this behaviour
with upstream perf(4.4-rc3) on x86 and ppc64 hardware.
Reason behind this failure is, when it tries to fetch machine from
rb_tree of machines, it fails. As a part of tracing a bug, we figured
out that this code was incorrectly refactored in commit 54245fdc3576
("perf session: Remove wrappers to machines__find").
This patch will change the functionality such that if it can't fetch
machine in first trial, it will create one node of machine and add that to
rb_tree. So next time when it tries to fetch same machine from rb_tree,
it won't fail. Actually it was the case before refactoring of code in
aforementioned commit.
This patch is generated from acme perf/core branch.
Below I've mention an example that demonstrate the behaviour before and
after applying patch.
Before applying patch:
[Note: One needs to run guest before recording data in host]
ravi@ravi-bangoria:~$ ./perf kvm record -a
Warning:
5903 unprocessable samples recorded.
Do you have a KVM guest running and not using 'perf kvm'?
[ perf record: Captured and wrote 1.409 MB perf.data.guest (285 samples) ]
ravi@ravi-bangoria:~$ ./perf kvm report --stdio
Warning:
# To display the perf.data header info, please use --header/--header-only options.
# Total Lost Samples: 0
# Samples: 285 of event 'cycles'
# Event count (approx.): 88715406
# Overhead Command Shared Object Symbol
# (For a higher level overview, try: perf report --sort comm,dso)
After applying patch:
[ perf record: Captured and wrote 1.188 MB perf.data.guest (17 samples) ]
# Samples: 17 of event 'cycles'
# Event count (approx.): 700746
34.19% :5758 [unknown] [g] 0xffffffff818682ab
22.79% :5758 [unknown] [g] 0xffffffff812dc7f8
22.79% :5758 [unknown] [g] 0xffffffff818650d0
14.83% :5758 [unknown] [g] 0xffffffff8161a1b6
2.49% :5758 [unknown] [g] 0xffffffff818692bf
0.48% :5758 [unknown] [g] 0xffffffff81869253
0.05% :5758 [unknown] [g] 0xffffffff81869250
Signed-off-by: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
Cc: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Cc: stable@vger.kernel.org # v3.19+
Fixes: 54245fdc3576 ("perf session: Remove wrappers to machines__find")
Link: http://lkml.kernel.org/r/1449471302-11283-1-git-send-email-ravi.bangoria@linux.vnet.ibm.com
commit caa470475d9b59eeff093ae650800d34612c4379 upstream.
The original patch introducing this header wrote the number of CPUs available
and online in one order and then swapped those values when reading, fix it.
Before:
# perf record usleep 1
# perf report --header-only | grep 'nrcpus \(online\|avail\)'
# nrcpus online : 4
# nrcpus avail : 4
# echo 0 > /sys/devices/system/cpu/cpu2/online
# nrcpus online : 4
# nrcpus avail : 3
# echo 0 > /sys/devices/system/cpu/cpu1/online
# nrcpus online : 4
# nrcpus avail : 2
After the fix, bringing back the CPUs online:
# nrcpus online : 2
# nrcpus avail : 4
# echo 1 > /sys/devices/system/cpu/cpu2/online
# nrcpus online : 3
# nrcpus avail : 4
# echo 1 > /sys/devices/system/cpu/cpu1/online
# nrcpus online : 4
# nrcpus avail : 4
Cc: Borislav Petkov <bp@suse.de>
Cc: Stephane Eranian <eranian@google.com>
Fixes: fbe96f29ce4b ("perf tools: Make perf.data more self-descriptive (v8)")
Link: http://lkml.kernel.org/r/20150911153323.GP23511@kernel.org
commit 93df8a1ed6231727c5db94a80b1a6bd5ee67cec3 upstream.
perf currently fails to build on MIPS as there is no
tools/perf/arch/mips/Build file. Adding an empty file fixes this as
there are no MIPS-specific sources to build.
It looks like the same is needed for Alpha and PA-RISC, though I
haven't been able to test those.
Fixes: 5e8c0fb6a957 ("perf build: Add arch x86 objects building")
Link: http://lkml.kernel.org/r/1438704627.7315.2.camel@decadent.org.uk
commit 601083cffb7cabdcc55b8195d732f0f7028570fa upstream.
print_aggr() fails to print per-core/per-socket statistics after commit
582ec0829b3d ("perf stat: Fix per-socket output bug for uncore events")
if events have differnt cpus. Because in print_aggr(), aggr_get_id needs
index (not cpu id) to find core/pkg id. Also, evsel cpu maps should be
used to get aggregated id.
Here is an example:
Counting events cycles,uncore_imc_0/cas_count_read/. (Uncore event has
cpumask 0,18)
$ perf stat -e cycles,uncore_imc_0/cas_count_read/ -C0,18 --per-core sleep 2
Without this patch, it failes to get CPU 18 result.
Performance counter stats for 'CPU(s) 0,18':
S0-C0 1 7526851 cycles
S0-C0 1 1.05 MiB uncore_imc_0/cas_count_read/
S1-C0 0 <not counted> cycles
S1-C0 0 <not counted> MiB uncore_imc_0/cas_count_read/
With this patch, it can get both CPU0 and CPU18 result.
S0-C0 1 6327768 cycles
S0-C0 1 0.47 MiB uncore_imc_0/cas_count_read/
S1-C0 1 330228 cycles
S1-C0 1 0.29 MiB uncore_imc_0/cas_count_read/
Signed-off-by: Kan Liang <kan.liang@intel.com>
Acked-by: Stephane Eranian <eranian@google.com>
Fixes: 582ec0829b3d ("perf stat: Fix per-socket output bug for uncore events")
Link: http://lkml.kernel.org/r/1435820925-51091-1-git-send-email-kan.liang@intel.com
commit e8e6d37e73e6b950c891c780745460b87f4755b6 upstream.
When we introduce a new sort key, we need to update the
hists__calc_col_len() function accordingly, otherwise the width
will be limited to strlen(header).
We can't update it when obtaining a line value for a column (for
instance, in sort__srcline_cmp()), because we reset it all when doing a
resort (see hists__output_recalc_col_len()), so we need to, from what is
in the hist_entry fields, set each of the column widths.
Fixes: 409a8be61560 ("perf tools: Add sort by src line/number")
Link: http://lkml.kernel.org/n/tip-jgbe0yx8v1gs89cslr93pvz2@git.kernel.org
commit b5cabbcbd157a4bf5a92dfc85134999a3b55342d upstream.
A copy of /proc/kcore containing the kernel text can be made to the
buildid cache. e.g.
perf buildid-cache -v -k /proc/kcore
To workaround objdump limitations, a copy is also made when annotating
against /proc/kcore.
The copying process stops working from libelf about v1.62 onwards (the
problem was found with v1.63).
The cause is that a call to gelf_getphdr() in kcore__add_phdr() fails
because additional validation has been added to gelf_getphdr().
The use of gelf_getphdr() is a misguided attempt to get default
initialization of the Gelf_Phdr structure. That should not be
necessary because every member of the Gelf_Phdr structure is
subsequently assigned. So just remove the call to gelf_getphdr().
Similarly, a call to gelf_getehdr() in gelf_kcore__init() can be
removed also.
Committer notes:
Note to stable@kernel.org, from Adrian in the cover letter for this
patchkit:
The "Fix copying of /proc/kcore" problem goes back to v3.13 if you think
it is important enough for stable.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Link: http://lkml.kernel.org/r/1443089122-19082-3-git-send-email-adrian.hunter@intel.com
commit 0bc2f2f7d080561cc484d2d0a162a9396bed3383 upstream.
When setting yup the symbols library we setup several filter lists,
for dsos, comms, symbols, etc, and there is code that, if there are
filters, do certain operations, like recalculate the number of non
filtered histogram entries in the top/report TUI.
But they were considering just the "Zoom" filters, when they need to
take into account as well the above mentioned filters (perf top --comms,
--dsos, etc).
So store in symbol_conf.has_filter true if any of those filters is in
place.
Link: http://lkml.kernel.org/n/tip-f5edfmhq69vfvs1kmikq1wep@git.kernel.org
Cc: Andre Tomt <lkml@tomt.net>
commit 9c0fa8dd3d58de8b688fda758eea1719949c7f0a upstream.
At some point:
commit 2c86c7ca7606
Author: Namhyung Kim <namhyung@kernel.org>
Date: Mon Mar 17 18:18:54 2014 -0300
perf report: Merge al->filtered with hist_entry->filtered
We stopped dropping samples for things filtered via the --comms, --dsos,
--symbols, etc, i.e. things marked as filtered in the symbol resolution
routines (thread__find_addr_map(), perf_event__preprocess_sample(),
etc).
But then, in:
commit 268397cb2a47
Date: Tue Apr 22 14:49:31 2014 +0900
perf top/tui: Update nr_entries properly after a filter is applied
We don't take into account entries that were filtered in
perf_event__preprocess_sample() and friends, which leads to
inconsistency in the browser seek routines, that expects the number of
hist_entry->filtered entries to match what it thinks is the number of
unfiltered, browsable entries.
So, for instance, when we do:
perf top --symbols ___non_existent_symbol___
the hist_browser__nr_entries() routine thinks there are no filters in
place, uses the hists->nr_entries but all entries are filtered, leading
to a segfault.
Tested with:
perf top --symbols malloc,free --percentage=relative
Freezing, by pressing 'f', at any time and doing the math on the
percentages ends up with 100%, ditto for:
perf top --dsos libpthread-2.20.so,libxul.so --percentage=relative
Both were segfaulting, all fixed now.
More work needed to do away with checking if filters are in place, we
should just use the nr_non_filtered_samples counter, no need to
conditionally use it or hists.nr_filter, as what the browser does is
just show unfiltered stuff. An audit of how it is being accounted is
needed, this is the minimal fix.
Reported-by: Michael Petlan <mpetlan@redhat.com>
Fixes: 268397cb2a47 ("perf top/tui: Update nr_entries properly after a filter is applied")
Link: http://lkml.kernel.org/n/tip-6w01d5q97qk0d64kuojme5in@git.kernel.org
commit 2b42b09b88c831ba4da2d669581dde371c38c2af upstream.
With commit: e1e455f4f4d3 (perf tools: Work around lack of sched_getcpu
in glibc < 2.6), perf_bench numa mem with -c or -m option is not able to
correctly calculate convergence.
With the above commit, sched_getcpu always seems to return -1. The
intention of commit e1e455f was to add a sched_getcpu in glibc < 2.6.
Hence keep the sched_getcpu definition under an ifdef.
This regression happened occurred between v4.0 and v4.1
Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Vinson Lee <vlee@twitter.com>
Fixes: e1e455f4f4d3 ("perf tools: Work around lack of sched_getcpu in glibc < 2.6")
Link: http://lkml.kernel.org/r/20150624111004.GA5220@linux.vnet.ibm.com
Parsing /proc/cpuinfo is a fiddly, arch-dependent business and a recent
change to get it working for Sparc broke arm and arm64 platforms.
Use sysconf to determine the number of online CPUs only parsing
/proc/cpuinfo when sysconf is not available.
Cc: David Ahern <david.ahern@oracle.com>
Cc: Mark Rutland <Mark.Rutland@arm.com>
Link: http://lkml.kernel.org/r/20150423140454.GJ1652@arm.com
[ Made it fall back to parsing /proc when getconf not found ]
Pull perf fixes from Ingo Molnar:
"Mostly tooling fixes, but also an uncore PMU driver fix and an uncore
PMU driver hardware-enablement addition"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf probe: Fix segfault if passed with ''.
perf report: Fix -T/--threads option to work again
perf bench numa: Fix immediate meeting of convergence condition
perf bench numa: Fixes of --quiet argument
perf bench futex: Fix hung wakeup tasks after requeueing
perf probe: Fix bug with global variables handling
perf top: Fix a segfault when kernel map is restricted.
tools lib traceevent: Fix build failure on 32-bit arch
perf kmem: Fix compiles on RHEL6/OL6
tools lib api: Undefine _FORTIFY_SOURCE before setting it
perf kmem: Consistently use PRIu64 for printing u64 values
perf trace: Disable events and drain events when forked workload ends
perf trace: Enable events when doing system wide tracing and starting a workload
perf/x86/intel/uncore: Move PCI IDs for IMC to uncore driver
perf/x86/intel/uncore: Add support for Intel Haswell ULT (lower power Mobile Processor) IMC uncore PMUs
perf/x86/intel: Add cpu_(prepare|starting|dying) for core_pmu
Since parse_perf_probe_point() deals with a user passed argument, we
should not assume it to be a valid string.
Without this patch, if pass '' to perf probe, a segfault raises:
$ perf probe -a ''
Segmentation fault
This patch checks argument of parse_perf_probe_point() before
string processing.
After this patch:
$ perf probe -a ''
usage: perf probe [<options>] 'PROBEDEF' ['PROBEDEF' ...]
or: perf probe [<options>] --add 'PROBEDEF' [--add 'PROBEDEF' ...]
Signed-off-by: Wang Nan <wangnan0@huawei.com>
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Zefan Li <lizefan@huawei.com>
Link: http://lkml.kernel.org/r/1430210769-94177-1-git-send-email-wangnan0@huawei.com
The commit 512ae1bd6acb ("perf tools: Consolidate management of default
sort orders") changed default value of the 'sort_order' variable to NULL
indicating that users don't set any sort keys on the command line.
However it missed to update a check in perf_evlist__tty_browse_hists()
so that 'perf report -T' cannot show the per-thread values after the
normal output. This patch fixes it to work again.
Note that the -T option only works on --stdio and neither --sort nor
--parent option was given.
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/1430309328-28317-1-git-send-email-namhyung@kernel.org
This patch fixes the race in the beginning of benchmark run when some
threads hasn't got assigned curr_cpu yet so they don't occur in
nodes-of-process stats and benchmark concludes that all remaining
threads are converged already.
The race can be reproduced with small amount of threads and some bigger
amount of shared process memory, e.g. one process, two threads and 5GB
of process memory.
Signed-off-by: Petr Holasek <pholasek@redhat.com>
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Link: http://lkml.kernel.org/r/1429198699-25039-4-git-send-email-pholasek@redhat.com
Corrected description and fixed function of --quiet argument.
Link: http://lkml.kernel.org/r/1429198699-25039-2-git-send-email-pholasek@redhat.com
The futex-requeue benchmark can hang because of missing wakeups once the
benchmark is done, ie:
[Run 1]: Requeued 1024 of 1024 threads in 0.3290 ms
perf: couldn't wakeup all tasks (135/1024)
This bug, while perhaps suggesting missing wakeups in kernel futex code,
is merely a consequence of the crappy FUTEX_CMP_REQUEUE man page,
incorrectly mentioning that the number of requeued tasks is in fact
returned, not the wakeups.
This patch acknowledges this and updates the corresponding futex_wake
code around it.
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Link: http://lkml.kernel.org/r/1429894848.10273.44.camel@stgolabs.net
There are missing curly braces which causes find_variable() return wrong
value when probing with global variables.
This problem can be reproduced as following:
$ perf probe -v --add='generic_perform_write global_variable_for_test'
Try to find probe point from debuginfo.
Probe point found: generic_perform_write+0
Searching 'global_variable_for_test' variable in context.
An error occurred in debuginfo analysis (-2).
Error: Failed to add events. Reason: No such file or directory (Code: -2)
After this patch:
Converting variable global_variable_for_test into trace event.
global_variable_for_test type is int.
Found 1 probe_trace_events.
Opening /sys/kernel/debug/tracing/kprobe_events write=1
Added new event:
Writing event: p:probe/generic_perform_write _stext+1237464
global_variable_for_test=@global_variable_for_test+0:s32
probe:generic_perform_write (on generic_perform_write with
global_variable_for_test)
You can now use it in all perf tools, such as:
perf record -e probe:generic_perform_write -aR sleep 1
Signed-off-by: He Kuang <hekuang@huawei.com>
Link: http://lkml.kernel.org/r/1429949338-18678-1-git-send-email-hekuang@huawei.com
Perf top raise a warning if a kernel sample is collected but kernel map
is restricted. The warning message needs to dereference al.map->dso...
However, previous perf_event__preprocess_sample() doesn't always
guarantee al.map != NULL, for example, when kernel map is restricted.
This patch validates al.map before dereferencing, avoid the segfault.
Before this patch:
$ cat /proc/sys/kernel/kptr_restrict
1
$ perf top -p 120183
perf: Segmentation fault
-------- backtrace --------
/path/to/perf[0x509868]
/lib64/libc.so.6(+0x3545f)[0x7f9a1540045f]
/path/to/perf[0x448820]
/path/to/perf(cmd_top+0xe3c)[0x44a5dc]
/path/to/perf[0x4766a2]
/path/to/perf(main+0x5f5)[0x42e545]
/lib64/libc.so.6(__libc_start_main+0xf4)[0x7f9a153ecbd4]
/path/to/perf[0x42e674]
And gdb call trace:
Program received signal SIGSEGV, Segmentation fault.
perf_event__process_sample (machine=0xa44030, sample=0x7fffffffa4c0, evsel=0xa43b00, event=0x7ffff41c3000, tool=0x7fffffffa8a0)
at builtin-top.c:736
736 !RB_EMPTY_ROOT(&al.map->dso->symbols[MAP__FUNCTION]) ?
(gdb) bt
#0 perf_event__process_sample (machine=0xa44030, sample=0x7fffffffa4c0, evsel=0xa43b00, event=0x7ffff41c3000, tool=0x7fffffffa8a0)
#1 perf_top__mmap_read_idx (top=top@entry=0x7fffffffa8a0, idx=idx@entry=0) at builtin-top.c:855
#2 0x000000000044a5dd in perf_top__mmap_read (top=0x7fffffffa8a0) at builtin-top.c:872
#3 __cmd_top (top=0x7fffffffa8a0) at builtin-top.c:997
#4 cmd_top (argc=<optimized out>, argv=<optimized out>, prefix=<optimized out>) at builtin-top.c:1267
#5 0x00000000004766a3 in run_builtin (p=p@entry=0x8a6ce8 <commands+264>, argc=argc@entry=3, argv=argv@entry=0x7fffffffdf70)
at perf.c:371
#6 0x000000000042e546 in handle_internal_command (argv=0x7fffffffdf70, argc=3) at perf.c:430
#7 run_argv (argv=0x7fffffffdcf0, argcp=0x7fffffffdcfc) at perf.c:474
#8 main (argc=3, argv=0x7fffffffdf70) at perf.c:589
(gdb)
Link: http://lkml.kernel.org/r/1429946703-80807-1-git-send-email-wangnan0@huawei.com
0d68bc92c48 breaks compiles on RHEL6/OL6:
cc1: warnings being treated as errors
builtin-kmem.c: In function ‘search_page_alloc_stat’:
builtin-kmem.c:322: error: declaration of ‘stat’ shadows a global declaration
node = &parent->rb_left;
/usr/include/sys/stat.h:455: error: shadowed declaration is here
builtin-kmem.c: In function ‘perf_evsel__process_page_alloc_event’:
builtin-kmem.c:378: error: declaration of ‘stat’ shadows a global declaration
builtin-kmem.c: In function ‘perf_evsel__process_page_free_event’:
builtin-kmem.c:431: error: declaration of ‘stat’ shadows a global declaration
Rename local variable to pstat to avoid the name conflict.
Link: http://lkml.kernel.org/r/1429033773-31383-1-git-send-email-david.ahern@oracle.com
Building the perf tool for 32-bit ARM results in the following build
error due to a combination of an incorrect conversion specifier and
compiling with -Werror:
builtin-kmem.c: In function ‘print_page_summary’:
builtin-kmem.c:644:9: error: format ‘%lu’ expects argument of type ‘long unsigned int’, but argument 3 has type ‘u64’ [-Werror=format=]
nr_alloc_freed, (total_alloc_freed_bytes) / 1024);
builtin-kmem.c:647:9: error: format ‘%lu’ expects argument of type ‘long unsigned int’, but argument 3 has type ‘u64’ [-Werror=format=]
(total_page_alloc_bytes - total_alloc_freed_bytes) / 1024);
This patch fixes the problem by consistently using PRIu64 for printing
out u64 values.
Cc: Joonsoo Kim <js1304@gmail.com>
Cc: Minchan Kim <minchan@kernel.org>
Link: http://lkml.kernel.org/r/1429796437-1790-1-git-send-email-will.deacon@arm.com
We were not checking in the inner event processing loop if the forked workload
had finished, which, on a busy system, may make it take a long time trying to
drain events, entering a seemingly neverending loop, waiting for the system to
get idle enough to make it drain the buffers.
Fix it by disabling the events when 'done' is true, in the inner loop, to start
draining what is in the buffers.
Now:
[root@ssdandy ~]# time trace --filter-pids 14003 -a sleep 1 | tail
996.748 ( 0.002 ms): sh/30296 rt_sigprocmask(how: SETMASK, nset: 0x7ffc83418160, sigsetsize: 8) = 0
996.751 ( 0.002 ms): sh/30296 rt_sigprocmask(how: BLOCK, nset: 0x7ffc834181f0, oset: 0x7ffc83418270, sigsetsize: 8) = 0
996.755 ( 0.002 ms): sh/30296 rt_sigaction(sig: INT, act: 0x7ffc83417f50, oact: 0x7ffc83417ff0, sigsetsize: 8) = 0
1004.543 ( 0.362 ms): tail/30198 ... [continued]: read()) = 4096
1004.548 ( 7.791 ms): sh/30296 wait4(upid: -1, stat_addr: 0x7ffc834181a0) ...
1004.975 ( 0.427 ms): tail/30198 read(buf: 0x7633f0, count: 8192) = 4096
1005.390 ( 0.410 ms): tail/30198 read(buf: 0x765410, count: 8192) = 4096
1005.743 ( 0.348 ms): tail/30198 read(buf: 0x7633f0, count: 8192) = 4096
1006.197 ( 0.449 ms): tail/30198 read(buf: 0x765410, count: 8192) = 4096
1006.492 ( 0.290 ms): tail/30198 read(buf: 0x7633f0, count: 8192) = 4096
real 0m1.219s
user 0m0.704s
sys 0m0.331s
[root@ssdandy ~]#
Suggested-by: Jiri Olsa <jolsa@redhat.com>
Acked-by: Jiri Olsa <jolsa@redhat.com>
Cc: Don Zickus <dzickus@redhat.com>
Link: http://lkml.kernel.org/n/tip-p6kpn1b26qcbe47pufpw0tex@git.kernel.org
commit f7aa222ff397
Author: Arnaldo Carvalho de Melo <acme@redhat.com>
Date: Tue Feb 3 13:25:39 2015 -0300
perf trace: No need to enable evsels for workload started from perf
The assumption was that whenever a workload is specified, the
attr.enable_on_exec evsel flag would be set, but that is not happening
when perf_record_opts.system_wide is set, for instance
That resulted in both perf_evlist__enable() and attr.enable_on_exec
being not called/set, which made the events to remain disabled while the
workload runs, producing no output.
Fix it, by calling perf_evlist__enable() in the 'trace' tool
when forking and not targetting a workload started from trace
v2: Test against !target__none(), as suggested by Namhyung Kim, that is
what is used in perf_evsel__config() when deciding if the
attr.enable_on_exec flag to be set. More work is needed to cover other
cases such as opts->initial_delay.
Link: http://lkml.kernel.org/n/tip-27z7169pvfxgj8upic636syv@git.kernel.org
Pull perf updates from Ingo Molnar:
"This update has mostly fixes, but also other bits:
- perf tooling fixes
- PMU driver fixes
- Intel Broadwell PMU driver HW-enablement for LBR callstacks
- a late coming 'perf kmem' tool update that enables it to also
analyze page allocation data. Note, this comes with MM tracepoint
changes that we believe to not break anything: because it changes
the formerly opaque 'struct page *' field that uniquely identifies
pages to 'pfn' which identifies pages uniquely too, but isn't as
opaque and can be used for other purposes as well"
perf/x86/intel/pt: Fix and clean up error handling in pt_event_add()
perf/x86/intel: Add Broadwell support for the LBR callstack
perf/x86/intel/rapl: Fix energy counter measurements but supporing per domain energy units
perf/x86/intel: Fix Core2,Atom,NHM,WSM cycles:pp events
perf/x86: Fix hw_perf_event::flags collision
perf probe: Fix segfault when probe with lazy_line to file
perf probe: Find compilation directory path for lazy matching
perf probe: Set retprobe flag when probe in address-based alternative mode
perf kmem: Analyze page allocator events also
tracing, mm: Record pfn instead of pointer to struct page
Pull perf changes from Ingo Molnar:
"Core kernel changes:
- One of the more interesting features in this cycle is the ability
to attach eBPF programs (user-defined, sandboxed bytecode executed
by the kernel) to kprobes.
This allows user-defined instrumentation on a live kernel image
that can never crash, hang or interfere with the kernel negatively.
(Right now it's limited to root-only, but in the future we might
allow unprivileged use as well.)
(Alexei Starovoitov)
- Another non-trivial feature is per event clockid support: this
allows, amongst other things, the selection of different clock
sources for event timestamps traced via perf.
This feature is sought by people who'd like to merge perf generated
events with external events that were measured with different
clocks:
- cluster wide profiling
- for system wide tracing with user-space events,
- JIT profiling events
etc. Matching perf tooling support is added as well, available via
the -k, --clockid <clockid> parameter to perf record et al.
(Peter Zijlstra)
Hardware enablement kernel changes:
- x86 Intel Processor Trace (PT) support: which is a hardware tracer
on steroids, available on Broadwell CPUs.
The hardware trace stream is directly output into the user-space
ring-buffer, using the 'AUX' data format extension that was added
to the perf core to support hardware constraints such as the
necessity to have the tracing buffer physically contiguous.
This patch-set was developed for two years and this is the result.
A simple way to make use of this is to use BTS tracing, the PT
driver emulates BTS output - available via the 'intel_bts' PMU.
More explicit PT specific tooling support is in the works as well -
will probably be ready by 4.2.
(Alexander Shishkin, Peter Zijlstra)
- x86 Intel Cache QoS Monitoring (CQM) support: this is a hardware
feature of Intel Xeon CPUs that allows the measurement and
allocation/partitioning of caches to individual workloads.
These kernel changes expose the measurement side as a new PMU
driver, which exposes various QoS related PMU events. (The
partitioning change is work in progress and is planned to be merged
as a cgroup extension.)
(Matt Fleming, Peter Zijlstra; CPU feature detection by Peter P
Waskiewicz Jr)
- x86 Intel Haswell LBR call stack support: this is a new Haswell
feature that allows the hardware recording of call chains, plus
tooling support. To activate this feature you have to enable it
via the new 'lbr' call-graph recording option:
perf record --call-graph lbr
perf report
or:
perf top --call-graph lbr
This hardware feature is a lot faster than stack walk or dwarf
based unwinding, but has some limitations:
- It reuses the current LBR facility, so LBR call stack and
branch record can not be enabled at the same time.
- It is only available for user-space callchains.
(Yan, Zheng)
- x86 Intel Broadwell CPU support and various event constraints and
event table fixes for earlier models.
(Andi Kleen)
- x86 Intel HT CPUs event scheduling workarounds. This is a complex
CPU bug affecting the SNB,IVB,HSW families that results in counter
value corruption. The mitigation code is automatically enabled and
is transparent.
(Maria Dimakopoulou, Stephane Eranian)
The perf tooling side had a ton of changes in this cycle as well, so
I'm only able to list the user visible changes here, in addition to
the tooling changes outlined above:
User visible changes affecting all tools:
- Improve support of compressed kernel modules (Jiri Olsa)
- Save DSO loading errno to better report errors (Arnaldo Carvalho de Melo)
- Bash completion for subcommands (Yunlong Song)
- Add 'I' event modifier for perf_event_attr.exclude_idle bit (Jiri Olsa)
- Support missing -f to override perf.data file ownership. (Yunlong Song)
- Show the first event with an invalid filter (David Ahern, Arnaldo Carvalho de Melo)
User visible changes in individual tools:
'perf data':
New tool for converting perf.data to other formats, initially
for the CTF (Common Trace Format) from LTTng (Jiri Olsa,
Sebastian Siewior)
'perf diff':
Add --kallsyms option (David Ahern)
'perf list':
Allow listing events with 'tracepoint' prefix (Yunlong Song)
Sort the output of the command (Yunlong Song)
'perf kmem':
Respect -i option (Jiri Olsa)
Print big numbers using thousands' group (Namhyung Kim)
Allow -v option (Namhyung Kim)
Fix alignment of slab result table (Namhyung Kim)
'perf probe':
Support multiple probes on different binaries on the same command line (Masami Hiramatsu)
Support unnamed union/structure members data collection. (Masami Hiramatsu)
Check kprobes blacklist when adding new events. (Masami Hiramatsu)
'perf record':
Teach 'perf record' about perf_event_attr.clockid (Peter Zijlstra)
Support recording running/enabled time (Andi Kleen)
'perf sched':
Improve the performance of 'perf sched replay' on high CPU core count machines (Yunlong Song)
'perf report' and 'perf top':
Allow annotating entries in callchains in the hists browser (Arnaldo Carvalho de Melo)
Indicate which callchain entries are annotated in the
TUI hists browser (Arnaldo Carvalho de Melo)
Add pid/tid filtering to 'report' and 'script' commands (David Ahern)
Consider PERF_RECORD_ events with cpumode == 0 in 'perf top', removing one
cause of long term memory usage buildup, i.e. not processing PERF_RECORD_EXIT
events (Arnaldo Carvalho de Melo)
'perf stat':
Report unsupported events properly (Suzuki K. Poulose)
Output running time and run/enabled ratio in CSV mode (Andi Kleen)
'perf trace':
Handle legacy syscalls tracepoints (David Ahern, Arnaldo Carvalho de Melo)
Only insert blank duration bracket when tracing syscalls (Arnaldo Carvalho de Melo)
Filter out the trace pid when no threads are specified (Arnaldo Carvalho de Melo)
Dump stack on segfaults (Arnaldo Carvalho de Melo)
No need to explicitely enable evsels for workload started from perf, let it
be enabled via perf_event_attr.enable_on_exec, removing some events that take
place in the 'perf trace' before a workload is really started by it.
Allow mixing with tracepoints and suppressing plain syscalls. (Arnaldo Carvalho de Melo)
There's also been a ton of infrastructure work done, such as the
split-out of perf's build system into tools/build/ and other changes -
see the shortlog and changelog for details"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (358 commits)
perf/x86/intel/pt: Clean up the control flow in pt_pmu_hw_init()
perf evlist: Fix type for references to data_head/tail
perf probe: Check the orphaned -x option
perf probe: Support multiple probes on different binaries
perf buildid-list: Fix segfault when show DSOs with hits
perf tools: Fix cross-endian analysis
perf tools: Fix error path to do closedir() when synthesizing threads
perf tools: Fix synthesizing fork_event.ppid for non-main thread
perf tools: Add 'I' event modifier for exclude_idle bit
perf report: Don't call map__kmap if map is NULL.
perf tests: Fix attr tests
perf probe: Fix ARM 32 building error
perf tools: Merge all perf_event_attr print functions
perf record: Add clockid parameter
perf sched replay: Use replay_repeat to calculate the runavg of cpu usage instead of the default value 10
perf sched replay: Support using -f to override perf.data file ownership
perf sched replay: Fix the EMFILE error caused by the limitation of the maximum open files
perf sched replay: Handle the dead halt of sem_wait when create_tasks() fails for any task
perf sched replay: Fix the segmentation fault problem caused by pr_err in threads
perf sched replay: Realloc the memory of pid_to_task stepwise to adapt to the different pid_max configurations
Pull trivial tree from Jiri Kosina:
"Usual trivial tree updates. Nothing outstanding -- mostly printk()
and comment fixes and unused identifier removals"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
goldfish: goldfish_tty_probe() is not using 'i' any more
powerpc: Fix comment in smu.h
qla2xxx: Fix printks in ql_log message
lib: correct link to the original source for div64_u64
si2168, tda10071, m88ds3103: Fix firmware wording
usb: storage: Fix printk in isd200_log_config()
qla2xxx: Fix printk in qla25xx_setup_mode
init/main: fix reset_device comment
ipwireless: missing assignment
goldfish: remove unreachable line of code
coredump: Fix do_coredump() comment
stacktrace.h: remove duplicate declaration task_struct
smpboot.h: Remove unused function prototype
treewide: Fix typo in printk messages
mod_devicetable: fix comment for match_flags
The first argument passed to find_probe_point_lazy() should be CU die,
which will be passed to die_walk_lines() when lazy_line matches.
Currently, when we probe with lazy_line pattern to file without function
name, NULL pointer is passed and causes a segment fault.
Can be reproduced as following:
$ perf probe -k vmlinux --add='fs/super.c;s->s_count=1;'
[ 1958.984658] perf[1020]: segfault at 10 ip 00007fc6e10d8c71 sp
00007ffcbfaaf900 error 4 in libdw-0.161.so[7fc6e10ce000+34000]
Segmentation fault
After this patch:
Added new event:
probe:_stext (on @fs/super.c)
perf record -e probe:_stext -aR sleep 1
Link: http://lkml.kernel.org/r/1428925290-5623-3-git-send-email-hekuang@huawei.com
If we use lazy matching, it failed to open a souce file if perf command
is invoked outside of compilation directory:
$ perf probe -a '__schedule;clear_*'
Failed to open kernel/sched/core.c: No such file or directory
Error: Failed to add events. (-2)
OTOH, other commands like "probe -L" can solve the souce directory by
themselves. Let's make it possible for lazy matching too!
Signed-off-by: Naohiro Aota <naota@elisp.net>
Cc: He Kuang <hekuang@huawei.com>
Link: http://lkml.kernel.org/r/1426223923-1493-1-git-send-email-naota@elisp.net
When perf probe searched in a debuginfo file and failed, it tried with
an alternative, in function get_alternative_probe_event():
memcpy(tmp, &pev->point, sizeof(*tmp));
memset(&pev->point, 0, sizeof(pev->point));
In this case, it drops the retprobe flag and forgets to set it back in
find_alternative_probe_point(), so the problem occurs.
$ perf probe -v -k vmlinux --add='sys_write%return'
Added new event:
Writing event: p:probe/sys_write _stext+1584952
probe:sys_write (on sys_write%return)
$ cat /sys/kernel/debug/tracing/kprobe_events
After this patch:
Added new event:
Writing event: r:probe/sys_write SyS_write+0
Link: http://lkml.kernel.org/r/1428925290-5623-1-git-send-email-hekuang@huawei.com
The perf kmem command records and analyze kernel memory allocation only
for SLAB objects. This patch implement a simple page allocator analyzer
using kmem:mm_page_alloc and kmem:mm_page_free events.
It adds two new options of --slab and --page. The --slab option is for
analyzing SLAB allocator and that's what perf kmem currently does.
The new --page option enables page allocator events and analyze kernel
memory usage in page unit. Currently, 'stat --alloc' subcommand is
implemented only.
If none of these --slab nor --page is specified, --slab is implied.
First run 'perf kmem record' to generate a suitable perf.data file:
# perf kmem record --page sleep 5
Then run 'perf kmem stat' to postprocess the perf.data file:
# perf kmem stat --page --alloc --line 10
PFN | Total alloc (KB) | Hits | Order | Mig.type | GFP flags
4045014 | 16 | 1 | 2 | RECLAIM | 00285250
4143980 | 16 | 1 | 2 | RECLAIM | 00285250
3938658 | 16 | 1 | 2 | RECLAIM | 00285250
4045400 | 16 | 1 | 2 | RECLAIM | 00285250
3568708 | 16 | 1 | 2 | RECLAIM | 00285250
3729824 | 16 | 1 | 2 | RECLAIM | 00285250
3657210 | 16 | 1 | 2 | RECLAIM | 00285250
4120750 | 16 | 1 | 2 | RECLAIM | 00285250
3678850 | 16 | 1 | 2 | RECLAIM | 00285250
3693874 | 16 | 1 | 2 | RECLAIM | 00285250
SUMMARY (page allocator)
Total allocation requests : 44,260 [ 177,256 KB ]
Total free requests : 117 [ 468 KB ]
Total alloc+freed requests : 49 [ 196 KB ]
Total alloc-only requests : 44,211 [ 177,060 KB ]
Total free-only requests : 68 [ 272 KB ]
Total allocation failures : 0 [ 0 KB ]
Order Unmovable Reclaimable Movable Reserved CMA/Isolated
0 32 . 44,210 . .
1 . . . . .
2 . 18 . . .
3 . . . . .
4 . . . . .
5 . . . . .
6 . . . . .
7 . . . . .
8 . . . . .
9 . . . . .
10 . . . . .
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/1428298576-9785-4-git-send-email-namhyung@kernel.org
The data_head and data_tail fields are defined as __u64 in
linux/perf_event.h, but perf userspace uses int and unsigned int.
Convert all references to u64 for consistency.
Signed-off-by: David Ahern <dsahern@gmail.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1428420037-26599-1-git-send-email-dsahern@gmail.com
To avoid probing in unintended binary, the orphaned -x option must be
checked and warned.
Without this patch, following command sets up the probe in the kernel.
# perf probe -a strcpy -x ./perf
Added new event:
probe:strcpy (on strcpy)
perf record -e probe:strcpy -aR sleep 1
But in this case, it seems that the user may want to probe in the perf
binary. With this patch, perf-probe correctly handles the orphaned -x.
Error: -x/-m must follow the probe definitions.
Reported-by: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/20150401102541.17137.75477.stgit@localhost.localdomain
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Support multiple probes on different binaries with just
one command.
In the result, this example sets up the probes on icmp_rcv in
kernel, on main and set_target in perf, and on pcspkr_event
in pcspker.ko driver.
# perf probe -a icmp_rcv -x ./perf -a main -a set_target \
-m /lib/modules/4.0.0-rc5+/kernel/drivers/input/misc/pcspkr.ko \
-a pcspkr_event
Added new event:
probe:icmp_rcv (on icmp_rcv)
perf record -e probe:icmp_rcv -aR sleep 1
Added new event:
probe_perf:main (on main in /home/mhiramat/ksrc/linux-3/tools/perf/perf)
perf record -e probe_perf:main -aR sleep 1
Added new event:
probe_perf:set_target (on set_target in /home/mhiramat/ksrc/linux-3/tools/perf/perf)
perf record -e probe_perf:set_target -aR sleep 1
Added new event:
probe:pcspkr_event (on pcspkr_event in pcspkr)
perf record -e probe:pcspkr_event -aR sleep 1
Reported-by: Arnaldo Carvalho de Melo <acme@infradead.org>
Link: http://lkml.kernel.org/r/20150401102539.17137.46454.stgit@localhost.localdomain
commit: f3b623b8490a ("perf tools: Reference count struct thread")
appends every thread->node to dead_threads in machine__remove_thread()
and list_del_init() this node in thread__put().
perf_event__exit_del_thread() releases thread wihout using
machine__remove_thread(), and causes a NULL pointer crash when
list_del_init(&thread->node) is called. Fix this by using
machine_remove_thread() instead of using thread__put() directly.
$ perf record ls
$ perf buildid-list --with-hits
[ 3874.195070] perf[1018]: segfault at 0 ip 00000000004b0b15 sp
00007ffc35b44780 error 6 in perf[400000+166000]
Segmentation fault
After this patch:
$ perf record ls
bc23e7c3281e542650ba4324421d6acf78f4c23e /proc/kcore
643324cb0e969f30c56d660f167f84a150845511 [vdso]
0000000000000000000000000000000000000000 /bin/busybox
Link: http://lkml.kernel.org/r/1428658500-6483-1-git-send-email-hekuang@huawei.com
