commit 6fcd5ddc3b1467b3586972ef785d0d926ae4cdf4 upstream.
Hagen reported broken strings in python3 tracepoint scripts:
make PYTHON=python3
perf record -e sched:sched_switch -a -- sleep 5
perf script --gen-script py
perf script -s ./perf-script.py
sched__sched_switch 7 563231.759525792 0 swapper prev_comm=bytearray(b'swapper/7\x00\x00\x00\x00\x00\x00\x00'), prev_pid=0, prev_prio=120, prev_state=, next_comm=bytearray(b'mutex-thread-co\x00'),
The problem is in the is_printable_array function that does not take the
zero byte into account and claim such string as not printable, so the
code will create byte array instead of string.
Committer testing:
After this fix:
sched__sched_switch 3 484522.497072626 1158680 kworker/3:0-eve prev_comm=kworker/3:0, prev_pid=1158680, prev_prio=120, prev_state=I, next_comm=swapper/3, next_pid=0, next_prio=120
Sample: {addr=0, cpu=3, datasrc=84410401, datasrc_decode=N/A|SNP N/A|TLB N/A|LCK N/A, ip=18446744071841817196, period=1, phys_addr=0, pid=1158680, tid=1158680, time=484522497072626, transaction=0, values=[(0, 0)], weight=0}
sched__sched_switch 4 484522.497085610 1225814 perf prev_comm=perf, prev_pid=1225814, prev_prio=120, prev_state=, next_comm=migration/4, next_pid=30, next_prio=0
Sample: {addr=0, cpu=4, datasrc=84410401, datasrc_decode=N/A|SNP N/A|TLB N/A|LCK N/A, ip=18446744071841817196, period=1, phys_addr=0, pid=1225814, tid=1225814, time=484522497085610, transaction=0, values=[(0, 0)], weight=0}
Fixes: 249de6e07458 ("perf script python: Fix string vs byte array resolving")
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Tested-by: Hagen Paul Pfeifer <hagen@jauu.net>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Michael Petlan <mpetlan@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: stable@vger.kernel.org
Link: http://lore.kernel.org/lkml/20200928201135.3633850-1-jolsa@kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[ Upstream commit 002a3d690f95804bdef6b70b26154103518e13d9 ]
Some metrics (such as DRAM_BW_Use) consists of uncore events and
duration_time. For uncore events, counter->core.system_wide is true. But
for duration_time, counter->core.system_wide is false so
target.system_wide is set to false.
Then 'enable_on_exec' is set in perf_event_attr of uncore event. Kernel
will return error when trying to open the uncore event.
This patch skips the duration_time in setup_system_wide then
target.system_wide will be set to true for the evlist of uncore events +
duration_time.
Before (tested on skylake desktop):
# perf stat -M DRAM_BW_Use -- sleep 1
Error:
The sys_perf_event_open() syscall returned with 22 (Invalid argument) for event (arb/event=0x84,umask=0x1/).
/bin/dmesg | grep -i perf may provide additional information.
After:
Performance counter stats for 'system wide':
169 arb/event=0x84,umask=0x1/ # 0.00 DRAM_BW_Use
40,427 arb/event=0x81,umask=0x1/
1,000,902,197 ns duration_time
1.000902197 seconds time elapsed
Fixes: e3ba76deef23064f ("perf tools: Force uncore events to system wide monitoring")
Signed-off-by: Jin Yao <yao.jin@linux.intel.com>
Cc: Jin Yao <yao.jin@intel.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Kan Liang <kan.liang@linux.intel.com>
Link: http://lore.kernel.org/lkml/20200922015004.30114-1-yao.jin@linux.intel.com
[ Upstream commit 7d537a8d2e76bc4fc71e34545ceaa463ac2cd928 ]
A context_switch event can have no tid because pids can be detached from
a task while the task is still running (in do_exit()). Note this won't
happen with per-task contexts because then tracing stops at
perf_event_exit_task()
If a task with no tid gets preempted, or a dying task gets preempted and
its parent releases it, when it subsequently gets switched back in,
Intel PT will not be able to determine what task is running and prints
an error "context_switch event has no tid". However, it is not really an
error because the task is in kernel space and the decoder can continue
to decode successfully. Fix by changing the error to be only a logged
message, and make allowance for tid == -1.
Example:
Using 5.9-rc4 with Preemptible Kernel (Low-Latency Desktop) e.g.
$ uname -r
5.9.0-rc4
$ grep PREEMPT .config
# CONFIG_PREEMPT_NONE is not set
# CONFIG_PREEMPT_VOLUNTARY is not set
CONFIG_PREEMPT=y
CONFIG_PREEMPT_COUNT=y
CONFIG_PREEMPTION=y
CONFIG_PREEMPT_RCU=y
CONFIG_PREEMPT_NOTIFIERS=y
CONFIG_DRM_I915_PREEMPT_TIMEOUT=640
CONFIG_DEBUG_PREEMPT=y
# CONFIG_PREEMPT_TRACER is not set
# CONFIG_PREEMPTIRQ_DELAY_TEST is not set
Before:
$ cat forkit.c
#include <sys/types.h>
#include <unistd.h>
#include <sys/wait.h>
int main()
pid_t child;
int status = 0;
child = fork();
if (child == 0)
return 123;
wait(&status);
return 0;
$ gcc -o forkit forkit.c
$ sudo ~/bin/perf record --kcore -a -m,64M -e intel_pt/cyc/k &
[1] 11016
$ taskset 2 ./forkit
$ sudo pkill perf
$ [ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 17.262 MB perf.data ]
[1]+ Terminated sudo ~/bin/perf record --kcore -a -m,64M -e intel_pt/cyc/k
$ sudo ~/bin/perf script --show-task-events --show-switch-events --itrace=iqqe-o -C 1 --ns | grep -C 2 forkit
taskset 11019 [001] 66663.270045029: 1 instructions:k: ffffffffb1d9f844 strnlen_user+0xb4 ([kernel.kallsyms])
taskset 11019 [001] 66663.270201816: 1 instructions:k: ffffffffb1a83121 unmap_page_range+0x561 ([kernel.kallsyms])
forkit 11019 [001] 66663.270327553: PERF_RECORD_COMM exec: forkit:11019/11019
forkit 11019 [001] 66663.270420028: 1 instructions:k: ffffffffb1db9537 __clear_user+0x27 ([kernel.kallsyms])
forkit 11019 [001] 66663.270648704: 1 instructions:k: ffffffffb18829e6 do_user_addr_fault+0xf6 ([kernel.kallsyms])
forkit 11019 [001] 66663.270833163: 1 instructions:k: ffffffffb230a825 irqentry_exit_to_user_mode+0x15 ([kernel.kallsyms])
forkit 11019 [001] 66663.271092359: 1 instructions:k: ffffffffb1aea3d9 lock_page_memcg+0x9 ([kernel.kallsyms])
forkit 11019 [001] 66663.271207092: PERF_RECORD_FORK(11020:11020):(11019:11019)
forkit 11019 [001] 66663.271234775: PERF_RECORD_SWITCH_CPU_WIDE OUT next pid/tid: 11020/11020
forkit 11020 [001] 66663.271238407: PERF_RECORD_SWITCH_CPU_WIDE IN prev pid/tid: 11019/11019
forkit 11020 [001] 66663.271312066: 1 instructions:k: ffffffffb1a88140 handle_mm_fault+0x10 ([kernel.kallsyms])
forkit 11020 [001] 66663.271476225: PERF_RECORD_EXIT(11020:11020):(11019:11019)
forkit 11020 [001] 66663.271497488: PERF_RECORD_SWITCH_CPU_WIDE OUT preempt next pid/tid: 11019/11019
forkit 11019 [001] 66663.271500523: PERF_RECORD_SWITCH_CPU_WIDE IN prev pid/tid: 11020/11020
forkit 11019 [001] 66663.271517241: 1 instructions:k: ffffffffb24012cd error_entry+0x6d ([kernel.kallsyms])
forkit 11019 [001] 66663.271664080: PERF_RECORD_EXIT(11019:11019):(1386:1386)
After:
forkit 11019 [001] 66663.271688752: PERF_RECORD_SWITCH_CPU_WIDE OUT next pid/tid: -1/-1
:-1 -1 [001] 66663.271692086: PERF_RECORD_SWITCH_CPU_WIDE IN prev pid/tid: 11019/11019
:-1 -1 [001] 66663.271707466: 1 instructions:k: ffffffffb18eb096 update_load_avg+0x306 ([kernel.kallsyms])
Fixes: 86c2786994bd7c ("perf intel-pt: Add support for PERF_RECORD_SWITCH")
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Yu-cheng Yu <yu-cheng.yu@intel.com>
Link: http://lore.kernel.org/lkml/20200909084923.9096-3-adrian.hunter@intel.com
commit 168200b6d6ea0cb5765943ec5da5b8149701f36a upstream.
The variable 'traceid_list' is defined in the header file cs-etm.h,
if multiple C files include cs-etm.h the compiler might complaint for
multiple definition of 'traceid_list'.
To fix multiple definition error, move the definition of 'traceid_list'
into cs-etm.c.
Fixes: cd8bfd8c973e ("perf tools: Add processing of coresight metadata")
Reported-by: Thomas Backlund <tmb@mageia.org>
Signed-off-by: Leo Yan <leo.yan@linaro.org>
Reviewed-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Reviewed-by: Mike Leach <mike.leach@linaro.org>
Tested-by: Mike Leach <mike.leach@linaro.org>
Tested-by: Thomas Backlund <tmb@mageia.org>
Cc: Suzuki Poulouse <suzuki.poulose@arm.com>
Cc: Tor Jeremiassen <tor@ti.com>
Link: http://lore.kernel.org/lkml/20200505133642.4756-1-leo.yan@linaro.org
Cc: Paul Barker <pbarker@konsulko.com>
commit 29b4f5f188571c112713c35cc87eefb46efee612 upstream.
Since glibc 2.28 when running 'perf top --stdio', input handling no
longer works, but hitting any key always just prints the "Mapped keys"
help text.
To fix it, call clearerr() in the display_thread() loop to clear any EOF
sticky errors, as instructed in the glibc NEWS file
(https://sourceware.org/git/?p=glibc.git;a=blob;f=NEWS):
* All stdio functions now treat end-of-file as a sticky condition. If you
read from a file until EOF, and then the file is enlarged by another
process, you must call clearerr or another function with the same effect
(e.g. fseek, rewind) before you can read the additional data. This
corrects a longstanding C99 conformance bug. It is most likely to affect
programs that use stdio to read interactive input from a terminal.
(Bug #1190.)
Signed-off-by: Tommi Rantala <tommi.t.rantala@nokia.com>
Link: http://lore.kernel.org/lkml/20200305083714.9381-2-tommi.t.rantala@nokia.com
commit dbd660e6b2884b864d2642d930a163d3bcebe4be upstream.
Commit 2d4f27999b88 ("perf data: Add global path holder") missed path
conversion in tests/topology.c, causing the "Session topology" testcase
to "hang" (waits forever for input from stdin) when doing "ssh $VM perf
test".
Can be reproduced by running "cat | perf test topo", and crashed by
replacing cat with true:
$ true | perf test -v topo
40: Session topology :
--- start ---
test child forked, pid 3638
templ file: /tmp/perf-test-QPvAch
incompatible file format
incompatible file format (rerun with -v to learn more)
free(): invalid pointer
test child interrupted
---- end ----
Session topology: FAILED!
Committer testing:
Reproduced the above result before the patch and after it is back
working:
# true | perf test -v topo
41: Session topology :
--- start ---
test child forked, pid 19374
templ file: /tmp/perf-test-YOTEQg
CPU 0, core 0, socket 0
CPU 1, core 1, socket 0
CPU 2, core 2, socket 0
CPU 3, core 3, socket 0
CPU 4, core 0, socket 0
CPU 5, core 1, socket 0
CPU 6, core 2, socket 0
CPU 7, core 3, socket 0
test child finished with 0
---- end ----
Session topology: Ok
Fixes: 2d4f27999b88 ("perf data: Add global path holder")
Acked-by: Jiri Olsa <jolsa@redhat.com>
Cc: Mamatha Inamdar <mamatha4@linux.vnet.ibm.com>
Cc: Ravi Bangoria <ravi.bangoria@linux.ibm.com>
Link: http://lore.kernel.org/lkml/20200423115341.562782-1-tommi.t.rantala@nokia.com
[ Upstream commit 8510895bafdbf7c4dd24c22946d925691135c2b2 ]
A big uncore event group is split into multiple small groups which only
include the uncore events from the same PMU. This has been supported in
the commit 3cdc5c2cb924a ("perf parse-events: Handle uncore event
aliases in small groups properly").
If the event's PMU name starts to repeat, it must be a new event.
That can be used to distinguish the leader from other members.
But now it only compares the pointer of pmu_name
(leader->pmu_name == evsel->pmu_name).
If we use "perf stat -M LLC_MISSES.PCIE_WRITE -a" on cascadelakex,
the event list is:
evsel->name evsel->pmu_name
unc_iio_data_req_of_cpu.mem_write.part0 uncore_iio_4 (as leader)
unc_iio_data_req_of_cpu.mem_write.part0 uncore_iio_2
unc_iio_data_req_of_cpu.mem_write.part0 uncore_iio_0
unc_iio_data_req_of_cpu.mem_write.part0 uncore_iio_5
unc_iio_data_req_of_cpu.mem_write.part0 uncore_iio_3
unc_iio_data_req_of_cpu.mem_write.part0 uncore_iio_1
unc_iio_data_req_of_cpu.mem_write.part1 uncore_iio_4
For the event "unc_iio_data_req_of_cpu.mem_write.part1" with
"uncore_iio_4", it should be the event from PMU "uncore_iio_4".
It's not a new leader for this PMU.
But if we use "(leader->pmu_name == evsel->pmu_name)", the check
would be failed and the event is stored to leaders[] as a new
PMU leader.
So this patch uses strcmp to compare the PMU name between events.
Fixes: d4953f7ef1a2 ("perf parse-events: Fix 3 use after frees found with clang ASAN")
Link: http://lore.kernel.org/lkml/20200430003618.17002-1-yao.jin@linux.intel.com
[ Upstream commit 463538a383a27337cb83ae195e432a839a52d639 ]
Commit 5aa98879efe7 ("s390/cpum_sf: prohibit callchain data collection")
prohibits call graph sampling for hardware events on s390. The
information recorded is out of context and does not match.
On s390 this commit now breaks test case 68 Zstd perf.data
compression/decompression.
Therefore omit call graph sampling on s390 in this test.
Output before:
[root@t35lp46 perf]# ./perf test -Fv 68
68: Zstd perf.data compression/decompression :
--- start ---
Collecting compressed record file:
Error:
cycles: PMU Hardware doesn't support sampling/overflow-interrupts.
Try 'perf stat'
---- end ----
Zstd perf.data compression/decompression: FAILED!
Output after:
--- start ---
500+0 records in
500+0 records out
256000 bytes (256 kB, 250 KiB) copied, 0.00615638 s, 41.6 MB/s
[ perf record: Captured and wrote 0.004 MB /tmp/perf.data.X3M,
compressed (original 0.002 MB, ratio is 3.609) ]
Checking compressed events stats:
# compressed : Zstd, level = 1, ratio = 4
COMPRESSED events: 1
2ELIFREPh---- end ----
Zstd perf.data compression/decompression: Ok
Signed-off-by: Thomas Richter <tmricht@linux.ibm.com>
Reviewed-by: Sumanth Korikkar <sumanthk@linux.ibm.com>
Cc: Sven Schnelle <svens@linux.ibm.com>
Cc: Vasily Gorbik <gor@linux.ibm.com>
Link: http://lore.kernel.org/lkml/20200729135314.91281-1-tmricht@linux.ibm.com
[ Upstream commit 61f82e3fb697a8e85f22fdec786528af73dc36d1 ]
In the absence of any modules, no "modules" map is created, but there
are other executable pages to map, due to eBPF JIT, kprobe or ftrace.
Map them by recognizing that the first "module" symbol is not
necessarily from a module, and adjust the map accordingly.
Cc: Leo Yan <leo.yan@linaro.org>
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Cc: Steven Rostedt (VMware) <rostedt@goodmis.org>
Cc: x86@kernel.org
Link: http://lore.kernel.org/lkml/20200512121922.8997-10-adrian.hunter@intel.com
[ Upstream commit a159e2fe89b4d1f9fb54b0ae418b961e239bf617 ]
Avoid a simple memory leak.
Signed-off-by: Ian Rogers <irogers@google.com>
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Andrii Nakryiko <andriin@fb.com>
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Jin Yao <yao.jin@linux.intel.com>
Cc: John Fastabend <john.fastabend@gmail.com>
Cc: John Garry <john.garry@huawei.com>
Cc: Kajol Jain <kjain@linux.ibm.com>
Cc: Kim Phillips <kim.phillips@amd.com>
Cc: Martin KaFai Lau <kafai@fb.com>
Cc: Song Liu <songliubraving@fb.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: Yonghong Song <yhs@fb.com>
Cc: bpf@vger.kernel.org
Cc: kp singh <kpsingh@chromium.org>
Cc: netdev@vger.kernel.org
Link: http://lore.kernel.org/lkml/20200508053629.210324-10-irogers@google.com
[ Upstream commit 07e9a6f538cbeecaf5c55b6f2991416f873cdcbd ]
Need to free "str" before return when asprintf() failed to avoid memory
leak.
Signed-off-by: Xie XiuQi <xiexiuqi@huawei.com>
Cc: Hongbo Yao <yaohongbo@huawei.com>
Cc: Li Bin <huawei.libin@huawei.com>
Link: http://lore.kernel.org/lkml/20200521133218.30150-4-liwei391@huawei.com
[ Upstream commit ea9eb1f456a08c18feb485894185f7a4e31cc8a4 ]
Joakim reported wrong duration_time value for interval bigger
than 4000 [1].
The problem is in the interval value we pass to update_stats
function, which is typed as 'unsigned int' and overflows when
we get over 2^32 (happens between intervals 4000 and 5000).
Retyping the passed value to unsigned long long.
[1] https://www.spinics.net/lists/linux-perf-users/msg11777.html
Fixes: b90f1333ef08 ("perf stat: Update walltime_nsecs_stats in interval mode")
Reported-by: Joakim Zhang <qiangqing.zhang@nxp.com>
Link: http://lore.kernel.org/lkml/20200518131445.3745083-1-jolsa@kernel.org
tables
[ Upstream commit 7597ce89b3ed239f7a3408b930d2a6c7a4c938a1 ]
Make the architecture test directory agree with the code comment.
Committer notes:
This was split from a larger patch.
The code was assuming the developer always worked from tools/perf/, so make sure we
do the test -d having $toolsdir/perf/arch/$arch, to match the intent expressed in the comment,
just above that loop.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Alexios Zavras <alexios.zavras@intel.com>
Cc: Igor Lubashev <ilubashe@akamai.com>
Cc: Nick Desaulniers <ndesaulniers@google.com>
Cc: Wei Li <liwei391@huawei.com>
Link: http://lore.kernel.org/lkml/20200306071110.130202-4-irogers@google.com
[ Upstream commit 3efc899d9afb3d03604f191a0be9669eabbfc4aa ]
If allocated, perf_pkg_mask and metric_events need freeing.
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Link: http://lore.kernel.org/lkml/20200512235918.10732-1-irogers@google.com
[ Upstream commit 266150c94c69429cf6d18e130237224a047f5061 ]
Realloc of size zero is a free not an error, avoid this causing a double
free. Caught by clang's address sanitizer:
==2634==ERROR: AddressSanitizer: attempting double-free on 0x6020000015f0 in thread T0:
#0 0x5649659297fd in free llvm/llvm-project/compiler-rt/lib/asan/asan_malloc_linux.cpp:123:3
#1 0x5649659e9251 in __zfree tools/lib/zalloc.c:13:2
#2 0x564965c0f92c in mem2node__exit tools/perf/util/mem2node.c:114:2
#3 0x564965a08b4c in perf_c2c__report tools/perf/builtin-c2c.c:2867:2
#4 0x564965a0616a in cmd_c2c tools/perf/builtin-c2c.c:2989:10
#5 0x564965944348 in run_builtin tools/perf/perf.c:312:11
#6 0x564965943235 in handle_internal_command tools/perf/perf.c:364:8
#7 0x5649659440c4 in run_argv tools/perf/perf.c:408:2
#8 0x564965942e41 in main tools/perf/perf.c:538:3
0x6020000015f0 is located 0 bytes inside of 1-byte region [0x6020000015f0,0x6020000015f1)
freed by thread T0 here:
#0 0x564965929da3 in realloc third_party/llvm/llvm-project/compiler-rt/lib/asan/asan_malloc_linux.cpp:164:3
#1 0x564965c0f55e in mem2node__init tools/perf/util/mem2node.c:97:16
#2 0x564965a08956 in perf_c2c__report tools/perf/builtin-c2c.c:2803:8
#3 0x564965a0616a in cmd_c2c tools/perf/builtin-c2c.c:2989:10
#4 0x564965944348 in run_builtin tools/perf/perf.c:312:11
#5 0x564965943235 in handle_internal_command tools/perf/perf.c:364:8
#6 0x5649659440c4 in run_argv tools/perf/perf.c:408:2
#7 0x564965942e41 in main tools/perf/perf.c:538:3
previously allocated by thread T0 here:
#0 0x564965929c42 in calloc third_party/llvm/llvm-project/compiler-rt/lib/asan/asan_malloc_linux.cpp:154:3
#1 0x5649659e9220 in zalloc tools/lib/zalloc.c:8:9
#2 0x564965c0f32d in mem2node__init tools/perf/util/mem2node.c:61:12
#3 0x564965a08956 in perf_c2c__report tools/perf/builtin-c2c.c:2803:8
v2: add a WARN_ON_ONCE when the free condition arises.
Cc: clang-built-linux@googlegroups.com
Link: http://lore.kernel.org/lkml/20200320182347.87675-1-irogers@google.com
[ Upstream commit bec49a9e05db3dbdca696fa07c62c52638fb6371 ]
When it is not possible for a non-privilege perf command to monitor at
the kernel level (:k), the fallback code forces a :u. That works if the
event was previously monitoring both levels. But if the event was
already constrained to kernel only, then it does not make sense to
restrict it to user only.
Given the code works by exclusion, a kernel only event would have:
attr->exclude_user = 1
The fallback code would add:
attr->exclude_kernel = 1
In the end the end would not monitor in either the user level or kernel
level. In other words, it would count nothing.
An event programmed to monitor kernel only cannot be switched to user
only without seriously warning the user.
This patch forces an error in this case to make it clear the request
cannot really be satisfied.
Behavior with paranoid 1:
$ sudo bash -c "echo 1 > /proc/sys/kernel/perf_event_paranoid"
$ perf stat -e cycles:k sleep 1
Performance counter stats for 'sleep 1':
1,520,413 cycles:k
1.002361664 seconds time elapsed
0.002480000 seconds user
0.000000000 seconds sys
Old behavior with paranoid 2:
$ sudo bash -c "echo 2 > /proc/sys/kernel/perf_event_paranoid"
0 cycles:ku
1.002358127 seconds time elapsed
0.002384000 seconds user
New behavior with paranoid 2:
Error:
You may not have permission to collect stats.
Consider tweaking /proc/sys/kernel/perf_event_paranoid,
which controls use of the performance events system by
unprivileged users (without CAP_PERFMON or CAP_SYS_ADMIN).
The current value is 2:
-1: Allow use of (almost) all events by all users
Ignore mlock limit after perf_event_mlock_kb without CAP_IPC_LOCK
>= 0: Disallow ftrace function tracepoint by users without CAP_PERFMON or CAP_SYS_ADMIN
Disallow raw tracepoint access by users without CAP_SYS_PERFMON or CAP_SYS_ADMIN
>= 1: Disallow CPU event access by users without CAP_PERFMON or CAP_SYS_ADMIN
>= 2: Disallow kernel profiling by users without CAP_PERFMON or CAP_SYS_ADMIN
To make this setting permanent, edit /etc/sysctl.conf too, e.g.:
kernel.perf_event_paranoid = -1
v2 of this patch addresses the review feedback from jolsa@redhat.com.
Signed-off-by: Stephane Eranian <eranian@google.com>
Reviewed-by: Ian Rogers <irogers@google.com>
Link: http://lore.kernel.org/lkml/20200414161550.225588-1-irogers@google.com
[ Upstream commit d74b181a028bb5a468f0c609553eff6a8fdf4887 ]
'snprintf' returns the number of characters which would be generated for
the given input.
If the returned value is *greater than* or equal to the buffer size, it
means that the output has been truncated.
Fix the overflow test accordingly.
Fixes: 7780c25bae59f ("perf tools: Allow ability to map cpus to nodes easily")
Fixes: 92a7e1278005b ("perf cpumap: Add cpu__max_present_cpu()")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Suggested-by: David Laight <David.Laight@ACULAB.COM>
Cc: Don Zickus <dzickus@redhat.com>
Cc: He Zhe <zhe.he@windriver.com>
Cc: Jan Stancek <jstancek@redhat.com>
Cc: kernel-janitors@vger.kernel.org
Link: http://lore.kernel.org/lkml/20200324070319.10901-1-christophe.jaillet@wanadoo.fr
[ Upstream commit d4953f7ef1a2e87ef732823af35361404d13fea8 ]
Reproducible with a clang asan build and then running perf test in
particular 'Parse event definition strings'.
Link: http://lore.kernel.org/lkml/20200314170356.62914-1-irogers@google.com
[ Upstream commit c9f5baa136777b2c982f6f7a90c9da69a88be148 ]
When 'etm->instructions_sample_period' is less than
'tidq->period_instructions', the function cs_etm__sample() cannot handle
this case properly with its logic.
Let's see below flow as an example:
- If we set itrace option '--itrace=i4', then function cs_etm__sample()
has variables with initialized values:
tidq->period_instructions = 0
etm->instructions_sample_period = 4
- When the first packet is coming:
packet->instr_count = 10; the number of instructions executed in this
packet is 10, thus update period_instructions as below:
tidq->period_instructions = 0 + 10 = 10
instrs_over = 10 - 4 = 6
offset = 10 - 6 - 1 = 3
tidq->period_instructions = instrs_over = 6
- When the second packet is coming:
packet->instr_count = 10; in the second pass, assume 10 instructions
in the trace sample again:
tidq->period_instructions = 6 + 10 = 16
instrs_over = 16 - 4 = 12
offset = 10 - 12 - 1 = -3 -> the negative value
tidq->period_instructions = instrs_over = 12
So after handle these two packets, there have below issues:
The first issue is that cs_etm__instr_addr() returns the address within
the current trace sample of the instruction related to offset, so the
offset is supposed to be always unsigned value. But in fact, function
cs_etm__sample() might calculate a negative offset value (in handling
the second packet, the offset is -3) and pass to cs_etm__instr_addr()
with u64 type with a big positive integer.
The second issue is it only synthesizes 2 samples for sample period = 4.
In theory, every packet has 10 instructions so the two packets have
total 20 instructions, 20 instructions should generate 5 samples
(4 x 5 = 20). This is because cs_etm__sample() only calls once
cs_etm__synth_instruction_sample() to generate instruction sample per
range packet.
This patch fixes the logic in function cs_etm__sample(); the basic
idea for handling coming packet is:
- To synthesize the first instruction sample, it combines the left
instructions from the previous packet and the head of the new
packet; then generate continuous samples with sample period;
- At the tail of the new packet, if it has the rest instructions,
these instructions will be left for the sequential sample.
Suggested-by: Mike Leach <mike.leach@linaro.org>
Cc: Robert Walker <robert.walker@arm.com>
Cc: coresight ml <coresight@lists.linaro.org>
Link: http://lore.kernel.org/lkml/20200219021811.20067-4-leo.yan@linaro.org
[ Upstream commit d01751563caf0dec7be36f81de77cc0197b77e59 ]
If use option '--itrace=iNNN' with Arm CoreSight trace data, perf tool
fails inject instruction samples; the root cause is the packets are only
swapped for branch samples and last branches but not for instruction
samples, so the new coming packets cannot be properly handled for only
synthesizing instruction samples.
To fix this issue, this patch refactors the code with a new function
cs_etm__packet_swap() which is used to swap packets and adds the
condition for instruction samples.
Link: http://lore.kernel.org/lkml/20200219021811.20067-2-leo.yan@linaro.org
[ Upstream commit 3f5777fbaf04c58d940526a22a2e0c813c837936 ]
The memory for global pointer is never freed during normal program
execution, so let's do that in the main function exit as a good
programming practice.
A stray blank line is also removed.
Reported-by: Jiri Olsa <jolsa@redhat.com>
Signed-off-by: John Garry <john.garry@huawei.com>
Cc: James Clark <james.clark@arm.com>
Cc: Joakim Zhang <qiangqing.zhang@nxp.com>
Cc: Will Deacon <will@kernel.org>
Cc: linuxarm@huawei.com
Link: http://lore.kernel.org/lkml/1583406486-154841-2-git-send-email-john.garry@huawei.com
[ Upstream commit 2bbc83537614517730e9f2811195004b712de207 ]
This test places a kprobe to function getname_flags() in the kernel
which has the following prototype:
struct filename *getname_flags(const char __user *filename, int flags, int *empty)
The 'filename' argument points to a filename located in user space memory.
Looking at commit 88903c464321c ("tracing/probe: Add ustring type for
user-space string") the kprobe should indicate that user space memory is
accessed.
Output before:
[root@m35lp76 perf]# ./perf test 66 67
66: Use vfs_getname probe to get syscall args filenames : FAILED!
67: Check open filename arg using perf trace + vfs_getname: FAILED!
Output after:
66: Use vfs_getname probe to get syscall args filenames : Ok
67: Check open filename arg using perf trace + vfs_getname: Ok
Comments from Masami Hiramatsu:
This bug doesn't happen on x86 or other archs on which user address
space and kernel address space is the same. On some arches (ppc64 in
this case?) user address space is partially or completely the same as
kernel address space.
(Yes, they switch the world when running into the kernel) In this case,
we need to use different data access functions for each space.
That is why I introduced the "ustring" type for kprobe events.
As far as I can see, Thomas's patch is sane. Thomas, could you show us
your result on your test environment?
Comments from Thomas Richter:
Test results for s/390 included above.
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Sumanth Korikkar <sumanthk@linux.ibm.com>
Link: http://lore.kernel.org/lkml/20200217102111.61137-1-tmricht@linux.ibm.com
[ Upstream commit d26383dcb2b4b8629fde05270b4e3633be9e3d4b ]
The following leaks were detected by ASAN:
Indirect leak of 360 byte(s) in 9 object(s) allocated from:
#0 0x7fecc305180e in calloc (/lib/x86_64-linux-gnu/libasan.so.5+0x10780e)
#1 0x560578f6dce5 in perf_pmu__new_format util/pmu.c:1333
#2 0x560578f752fc in perf_pmu_parse util/pmu.y:59
#3 0x560578f6a8b7 in perf_pmu__format_parse util/pmu.c:73
#4 0x560578e07045 in test__pmu tests/pmu.c:155
#5 0x560578de109b in run_test tests/builtin-test.c:410
#6 0x560578de109b in test_and_print tests/builtin-test.c:440
#7 0x560578de401a in __cmd_test tests/builtin-test.c:661
#8 0x560578de401a in cmd_test tests/builtin-test.c:807
#9 0x560578e49354 in run_builtin /home/namhyung/project/linux/tools/perf/perf.c:312
#10 0x560578ce71a8 in handle_internal_command /home/namhyung/project/linux/tools/perf/perf.c:364
#11 0x560578ce71a8 in run_argv /home/namhyung/project/linux/tools/perf/perf.c:408
#12 0x560578ce71a8 in main /home/namhyung/project/linux/tools/perf/perf.c:538
#13 0x7fecc2b7acc9 in __libc_start_main ../csu/libc-start.c:308
Fixes: cff7f956ec4a1 ("perf tests: Move pmu tests into separate object")
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Cc: Ian Rogers <irogers@google.com>
Link: http://lore.kernel.org/lkml/20200915031819.386559-12-namhyung@kernel.org
[ Upstream commit b12eea5ad8e77f8a380a141e3db67c07432dde16 ]
The evsel->unit borrows a pointer of pmu event or alias instead of
owns a string. But tool event (duration_time) passes a result of
strdup() caused a leak.
It was found by ASAN during metric test:
Direct leak of 210 byte(s) in 70 object(s) allocated from:
#0 0x7fe366fca0b5 in strdup (/lib/x86_64-linux-gnu/libasan.so.5+0x920b5)
#1 0x559fbbcc6ea3 in add_event_tool util/parse-events.c:414
#2 0x559fbbcc6ea3 in parse_events_add_tool util/parse-events.c:1414
#3 0x559fbbd8474d in parse_events_parse util/parse-events.y:439
#4 0x559fbbcc95da in parse_events__scanner util/parse-events.c:2096
#5 0x559fbbcc95da in __parse_events util/parse-events.c:2141
#6 0x559fbbc28555 in check_parse_id tests/pmu-events.c:406
#7 0x559fbbc28555 in check_parse_id tests/pmu-events.c:393
#8 0x559fbbc28555 in check_parse_cpu tests/pmu-events.c:415
#9 0x559fbbc28555 in test_parsing tests/pmu-events.c:498
#10 0x559fbbc0109b in run_test tests/builtin-test.c:410
#11 0x559fbbc0109b in test_and_print tests/builtin-test.c:440
#12 0x559fbbc03e69 in __cmd_test tests/builtin-test.c:695
#13 0x559fbbc03e69 in cmd_test tests/builtin-test.c:807
#14 0x559fbbc691f4 in run_builtin /home/namhyung/project/linux/tools/perf/perf.c:312
#15 0x559fbbb071a8 in handle_internal_command /home/namhyung/project/linux/tools/perf/perf.c:364
#16 0x559fbbb071a8 in run_argv /home/namhyung/project/linux/tools/perf/perf.c:408
#17 0x559fbbb071a8 in main /home/namhyung/project/linux/tools/perf/perf.c:538
#18 0x7fe366b68cc9 in __libc_start_main ../csu/libc-start.c:308
Fixes: f0fbb114e3025 ("perf stat: Implement duration_time as a proper event")
Link: http://lore.kernel.org/lkml/20200915031819.386559-6-namhyung@kernel.org
[ Upstream commit bfd1b83d75e44a9f65de30accb3dd3b5940bd3ac ]
Asan reported leak of cpu and thread maps as they have one more refcount
than released. I found that after setting evlist maps it should release
it's refcount.
It seems to be broken from the beginning so I chose the original commit
as the culprit. But not sure how it's applied to stable trees since
there are many changes in the code after that.
Fixes: 7e2ed097538c5 ("perf evlist: Store pointer to the cpu and thread maps")
Fixes: 4112eb1899c0e ("perf evlist: Default to syswide target when no thread/cpu maps set")
Link: http://lore.kernel.org/lkml/20200915031819.386559-4-namhyung@kernel.org
[ Upstream commit 8a39e8c4d9baf65d88f66d49ac684df381e30055 ]
When compiling with DEBUG=1 on Fedora 32 I'm getting crash for 'perf
test signal':
Program received signal SIGSEGV, Segmentation fault.
0x0000000000c68548 in __test_function ()
(gdb) bt
#0 0x0000000000c68548 in __test_function ()
#1 0x00000000004d62e9 in test_function () at tests/bp_signal.c:61
#2 0x00000000004d689a in test__bp_signal (test=0xa8e280 <generic_ ...
#3 0x00000000004b7d49 in run_test (test=0xa8e280 <generic_tests+1 ...
#4 0x00000000004b7e7f in test_and_print (t=0xa8e280 <generic_test ...
#5 0x00000000004b8927 in __cmd_test (argc=1, argv=0x7fffffffdce0, ...
It's caused by the symbol __test_function being in the ".bss" section:
$ readelf -a ./perf | less
[Nr] Name Type Address Offset
Size EntSize Flags Link Info Align
[28] .bss NOBITS 0000000000c356a0 008346a0
00000000000511f8 0000000000000000 WA 0 0 32
$ nm perf | grep __test_function
0000000000c68548 B __test_function
I guess most of the time we're just lucky the inline asm ended up in the
".text" section, so making it specific explicit with push and pop
section clauses.
[13] .text PROGBITS 0000000000431240 00031240
0000000000306faa 0000000000000000 AX 0 0 16
00000000004d62c8 T __test_function
Committer testing:
$ readelf -wi ~/bin/perf | grep producer -m1
<c> DW_AT_producer : (indirect string, offset: 0x254a): GNU C99 10.2.1 20200723 (Red Hat 10.2.1-1) -mtune=generic -march=x86-64 -ggdb3 -std=gnu99 -fno-omit-frame-pointer -funwind-tables -fstack-protector-all
Before:
$ perf test signal
20: Breakpoint overflow signal handler : FAILED!
After:
$ perf test signal
20: Breakpoint overflow signal handler : Ok
Fixes: 8fd34e1cce18 ("perf test: Improve bp_signal")
Cc: Wang Nan <wangnan0@huawei.com>
Link: http://lore.kernel.org/lkml/20200911130005.1842138-1-jolsa@kernel.org
commit a060c1f12b525ba828f871eff3127dabf8daa1e6 upstream.
The help info of option "--no-bpf-event" is wrongly described as "record
bpf events", correct it.
Committer testing:
$ perf record -h bpf
Usage: perf record [<options>] [<command>]
or: perf record [<options>] -- <command> [<options>]
--clang-opt <clang options>
options passed to clang when compiling BPF scriptlets
--clang-path <clang path>
clang binary to use for compiling BPF scriptlets
--no-bpf-event do not record bpf events
Fixes: 71184c6ab7e6 ("perf record: Replace option --bpf-event with --no-bpf-event")
Signed-off-by: Wei Li <liwei391@huawei.com>
Acked-by: Song Liu <songliubraving@fb.com>
Cc: Hanjun Guo <guohanjun@huawei.com>
Link: http://lore.kernel.org/lkml/20200819031947.12115-1-liwei391@huawei.com
[ Upstream commit e62458e3940eb3dfb009481850e140fbee183b04 ]
The new string should have enough space for the original string and the
back slashes IMHO.
Fixes: fbc2844e84038ce3 ("perf vendor events: Use more flexible pattern matching for CPU identification for mapfile.csv")
Cc: William Cohen <wcohen@redhat.com>
Link: http://lore.kernel.org/lkml/20200903152510.489233-1-namhyung@kernel.org
commit e48a73a312ebf19cc3d72aa74985db25c30757c1 upstream.
Event modifiers are not mentioned in the perf record or perf stat
manpages. Add them to orient new users more effectively by pointing
them to the perf list manpage for details.
Fixes: 2055fdaf8703 ("perf list: Document precise event sampling for AMD IBS")
Signed-off-by: Kim Phillips <kim.phillips@amd.com>
Cc: Alexey Budankov <alexey.budankov@linux.intel.com>
Cc: Paul Clarke <pc@us.ibm.com>
Cc: Tony Jones <tonyj@suse.de>
Link: http://lore.kernel.org/lkml/20200901215853.276234-1-kim.phillips@amd.com
[ Upstream commit 12d572e785b15bc764e956caaa8a4c846fd15694 ]
Fix the memory leakage in debuginfo__find_trace_events() when the probe
point is not found in the debuginfo. If there is no probe point found in
the debuginfo, debuginfo__find_probes() will NOT return -ENOENT, but 0.
Thus the caller of debuginfo__find_probes() must check the tf.ntevs and
release the allocated memory for the array of struct probe_trace_event.
The current code releases the memory only if the debuginfo__find_probes()
hits an error but not checks tf.ntevs. In the result, the memory allocated
on *tevs are not released if tf.ntevs == 0.
This fixes the memory leakage by checking tf.ntevs == 0 in addition to
ret < 0.
Fixes: ff741783506c ("perf probe: Introduce debuginfo to encapsulate dwarf information")
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Reviewed-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Link: http://lore.kernel.org/lkml/159438668346.62703.10887420400718492503.stgit@devnote2
[ Upstream commit 1beaef29c34154ccdcb3f1ae557f6883eda18840 ]
For memcpy, the source pages are memset to zero only when --cycles is
used. This leads to wildly different results with or without --cycles,
since all sources pages are likely to be mapped to the same zero page
without explicit writes.
Before this fix:
$ export cmd="./perf stat -e LLC-loads -- ./perf bench \
mem memcpy -s 1024MB -l 100 -f default"
$ $cmd
2,935,826 LLC-loads
3.821677452 seconds time elapsed
$ $cmd --cycles
217,533,436 LLC-loads
8.616725985 seconds time elapsed
After this fix:
$ $cmd
214,459,686 LLC-loads
8.674301124 seconds time elapsed
$ $cmd --cycles
214,758,651 LLC-loads
8.644480006 seconds time elapsed
Fixes: 47b5757bac03c338 ("perf bench mem: Move boilerplate memory allocation to the infrastructure")
Signed-off-by: Vincent Whitchurch <vincent.whitchurch@axis.com>
Cc: kernel@axis.com
Link: http://lore.kernel.org/lkml/20200810133404.30829-1-vincent.whitchurch@axis.com
commit a58a057ce65b52125dd355b7d8b0d540ea267a5f upstream.
CBR events can result in a duplicate branch event, because the state
type defaults to a branch. Fix by clearing the state type.
Example: trace 'sleep' and hope for a frequency change
Before:
$ perf record -e intel_pt//u sleep 0.1
[ perf record: Captured and wrote 0.034 MB perf.data ]
$ perf script --itrace=bpe > before.txt
After:
$ perf script --itrace=bpe > after.txt
$ diff -u before.txt after.txt
# --- before.txt 2020-07-07 14:42:18.191508098 +0300
# +++ after.txt 2020-07-07 14:42:36.587891753 +0300
@@ -29673,7 +29673,6 @@
sleep 93431 [007] 15411.619905: 1 branches:u: 0 [unknown] ([unknown]) => 7f0818abb2e0 clock_nanosleep@@GLIBC_2.17+0x0 (/usr/lib/x86_64-linux-gnu/libc-2.31.so)
sleep 93431 [007] 15411.619905: 1 branches:u: 7f0818abb30c clock_nanosleep@@GLIBC_2.17+0x2c (/usr/lib/x86_64-linux-gnu/libc-2.31.so) => 0 [unknown] ([unknown])
sleep 93431 [007] 15411.720069: cbr: cbr: 15 freq: 1507 MHz ( 56%) 7f0818abb30c clock_nanosleep@@GLIBC_2.17+0x2c (/usr/lib/x86_64-linux-gnu/libc-2.31.so)
- sleep 93431 [007] 15411.720069: 1 branches:u: 7f0818abb30c clock_nanosleep@@GLIBC_2.17+0x2c (/usr/lib/x86_64-linux-gnu/libc-2.31.so) => 0 [unknown] ([unknown])
sleep 93431 [007] 15411.720076: 1 branches:u: 0 [unknown] ([unknown]) => 7f0818abb30e clock_nanosleep@@GLIBC_2.17+0x2e (/usr/lib/x86_64-linux-gnu/libc-2.31.so)
sleep 93431 [007] 15411.720077: 1 branches:u: 7f0818abb323 clock_nanosleep@@GLIBC_2.17+0x43 (/usr/lib/x86_64-linux-gnu/libc-2.31.so) => 7f0818ac0eb7 __nanosleep+0x17 (/usr/lib/x86_64-linux-gnu/libc-2.31.so)
sleep 93431 [007] 15411.720077: 1 branches:u: 7f0818ac0ebf __nanosleep+0x1f (/usr/lib/x86_64-linux-gnu/libc-2.31.so) => 55cb7e4c2827 rpl_nanosleep+0x97 (/usr/bin/sleep)
Fixes: 91de8684f1cff ("perf intel-pt: Cater for CBR change in PSB+")
Fixes: abe5a1d3e4bee ("perf intel-pt: Decoder to output CBR changes immediately")
Link: http://lore.kernel.org/lkml/20200710151104.15137-3-adrian.hunter@intel.com
commit 401136bb084fd021acd9f8c51b52fe0a25e326b2 upstream.
While walking code towards a FUP ip, the packet state is
INTEL_PT_STATE_FUP or INTEL_PT_STATE_FUP_NO_TIP. That was mishandled
resulting in the state becoming INTEL_PT_STATE_IN_SYNC prematurely. The
result was an occasional lost EXSTOP event.
Link: http://lore.kernel.org/lkml/20200710151104.15137-2-adrian.hunter@intel.com
commit e4d9b04b973b2dbce7b42af95ea70d07da1c936d upstream.
Noticed with gcc 10 (fedora rawhide) that those variables were not being
declared as static, so end up with:
ld: /tmp/build/perf/bench/epoll-wait.o:/git/perf/tools/perf/bench/epoll-wait.c:93: multiple definition of `end'; /tmp/build/perf/bench/futex-hash.o:/git/perf/tools/perf/bench/futex-hash.c:40: first defined here
ld: /tmp/build/perf/bench/epoll-wait.o:/git/perf/tools/perf/bench/epoll-wait.c:93: multiple definition of `start'; /tmp/build/perf/bench/futex-hash.o:/git/perf/tools/perf/bench/futex-hash.c:40: first defined here
ld: /tmp/build/perf/bench/epoll-wait.o:/git/perf/tools/perf/bench/epoll-wait.c:93: multiple definition of `runtime'; /tmp/build/perf/bench/futex-hash.o:/git/perf/tools/perf/bench/futex-hash.c:40: first defined here
ld: /tmp/build/perf/bench/epoll-ctl.o:/git/perf/tools/perf/bench/epoll-ctl.c:38: multiple definition of `end'; /tmp/build/perf/bench/futex-hash.o:/git/perf/tools/perf/bench/futex-hash.c:40: first defined here
ld: /tmp/build/perf/bench/epoll-ctl.o:/git/perf/tools/perf/bench/epoll-ctl.c:38: multiple definition of `start'; /tmp/build/perf/bench/futex-hash.o:/git/perf/tools/perf/bench/futex-hash.c:40: first defined here
ld: /tmp/build/perf/bench/epoll-ctl.o:/git/perf/tools/perf/bench/epoll-ctl.c:38: multiple definition of `runtime'; /tmp/build/perf/bench/futex-hash.o:/git/perf/tools/perf/bench/futex-hash.c:40: first defined here
make[4]: *** [/git/perf/tools/build/Makefile.build:145: /tmp/build/perf/bench/perf-in.o] Error 1
Prefix those with bench__ and add them to bench/bench.h, so that we can
share those on the tools needing to access those variables from signal
handlers.
Cc: Davidlohr Bueso <dave@stgolabs.net>
Link: http://lore.kernel.org/lkml/20200303155811.GD13702@kernel.org
Cc: Ben Hutchings <ben@decadent.org.uk>
commit ebcb9464a2ae3a547e97de476575c82ece0e93e2 upstream.
It is possible to return a pointer to a local variable when looking up
the architecture name for the running system and no normalization is
done on that value, i.e. we may end up returning the uts.machine local
variable.
While this doesn't happen on most arches, as normalization takes place,
lets fix this by making that a static variable and optimize it a bit by
not always running uname(), only the first time.
Noticed in fedora rawhide running with:
[perfbuilder@a5ff49d6e6e4 ~]$ gcc --version
gcc (GCC) 10.0.1 20200216 (Red Hat 10.0.1-0.8)
Reported-by: Jiri Olsa <jolsa@kernel.org>
commit cff20b3151ccab690715cb6cf0f5da5cccb32adf upstream.
To fix the build with newer gccs, that without this patch exit with:
LD /tmp/build/perf/tests/perf-in.o
ld: /tmp/build/perf/tests/bp_account.o:/git/perf/tools/perf/tests/bp_account.c:22: multiple definition of `the_var'; /tmp/build/perf/tests/bp_signal.o:/git/perf/tools/perf/tests/bp_signal.c:38: first defined here
make[4]: *** [/git/perf/tools/build/Makefile.build:145: /tmp/build/perf/tests/perf-in.o] Error 1
First noticed in fedora:rawhide/32 with:
[ Upstream commit bd3c628f8fafa6cbd6a1ca440034b841f0080160 ]
When recording with cache-misses and arm_spe_x event, I found that it
will just fail without showing any error info if i put cache-misses
after 'arm_spe_x' event.
[root@localhost 0620]# perf record -e cache-misses \
-e arm_spe_0/ts_enable=1,pct_enable=1,pa_enable=1,load_filter=1,jitter=1,store_filter=1,min_latency=0/ sleep 1
[ perf record: Captured and wrote 0.067 MB perf.data ]
[root@localhost 0620]# perf record -e arm_spe_0/ts_enable=1,pct_enable=1,pa_enable=1,load_filter=1,jitter=1,store_filter=1,min_latency=0/ \
-e cache-misses sleep 1
The current code can only work if the only event to be traced is an
'arm_spe_x', or if it is the last event to be specified. Otherwise the
last event type will be checked against all the arm_spe_pmus[i]->types,
none will match and an out of bound 'i' index will be used in
arm_spe_recording_init().
We don't support concurrent multiple arm_spe_x events currently, that
is checked in arm_spe_recording_options(), and it will show the relevant
info. So add the check and record of the first found 'arm_spe_pmu' to
fix this issue here.
Fixes: ffd3d18c20b8 ("perf tools: Add ARM Statistical Profiling Extensions (SPE) support")
Tested-by-by: Leo Yan <leo.yan@linaro.org>
Cc: Kim Phillips <kim.phillips@arm.com>
Cc: Mike Leach <mike.leach@linaro.org>
Link: http://lore.kernel.org/lkml/20200724071111.35593-2-liwei391@huawei.com
commit 0e0bf1ea1147fcf74eab19c2d3c853cc3740a72f upstream.
As the code comments in perf_stat_process_counter() say, we calculate
counter's data every interval, and the display code shows ps->res_stats
avg value. We need to zero the stats for interval mode.
But the current code only zeros the res_stats[0], it doesn't zero the
res_stats[1] and res_stats[2], which are for ena and run of counter.
This patch zeros the whole res_stats[] for interval mode.
Fixes: 51fd2df1e882 ("perf stat: Fix interval output values")
Link: http://lore.kernel.org/lkml/20200409070755.17261-1-yao.jin@linux.intel.com
commit 3a3cf7c570a486b07d9a6e68a77548aea6a8421f upstream.
Using Python version 3.8.2 and PySide2 version 5.14.0, ctrl-F ('Find')
would not expand the tree to the result. Fix by using setExpanded().
Example:
$ perf record -e intel_pt//u uname
Linux
$ perf script --itrace=bep -s ~/libexec/perf-core/scripts/python/export-to-sqlite.py perf.data.db branches calls
2020-06-26 15:32:14.928997 Creating database ...
2020-06-26 15:32:14.933971 Writing records...
2020-06-26 15:32:15.535251 Adding indexes
2020-06-26 15:32:15.542993 Dropping unused tables
2020-06-26 15:32:15.549716 Done
$ python3 ~/libexec/perf-core/scripts/python/exported-sql-viewer.py perf.data.db
Select: Reports -> Context-Sensitive Call Graph or Reports -> Call Tree
Press: Ctrl-F
Enter: main
Press: Enter
Before: line showing 'main' does not display
After: tree is expanded to line showing 'main'
Fixes: ebd70c7dc2f5f ("perf scripts python: exported-sql-viewer.py: Add ability to find symbols in the call-graph")
Link: http://lore.kernel.org/lkml/20200629091955.17090-4-adrian.hunter@intel.com
result
commit 031c8d5edb1ddeb6d398f7942ce2a01a1a51ada9 upstream.
Using ctrl-F ('Find') would not find 'unknown' because it matches id
zero. Fix by excluding id zero from selection.
Example:
Linux
Select: Reports -> Call Tree
Press: Ctrl-F
Enter: unknown
Press: Enter
Before: displays 'unknown' not found
After: tree is expanded to line showing 'unknown'
Fixes: ae8b887c00d3f ("perf scripts python: exported-sql-viewer.py: Add call tree")
Link: http://lore.kernel.org/lkml/20200629091955.17090-6-adrian.hunter@intel.com
'Find' result
commit 7ff520b0a71dd2db695b52ad117d81b7eaf6ff9d upstream.
Using ctrl-F ('Find') would not find 'unknown' because it matches id zero.
Example:
Linux
Press: Ctrl-F
Enter: unknown
Press: Enter
Before: gets stuck
Fixes: 254c0d820b86d ("perf scripts python: exported-sql-viewer.py: Factor out CallGraphModelBase")
Link: http://lore.kernel.org/lkml/20200629091955.17090-5-adrian.hunter@intel.com
commit 640432e6bed08e9d5d2ba26856ba3f55008b07e3 upstream.
Python 3.8 is requiring that arguments being packed as integers are also
integers. Add int() accordingly.
Before:
$ perf script --itrace=bep -s ~/libexec/perf-core/scripts/python/export-to-postgresql.py perf_data_db branches calls
2020-06-25 16:09:10.547256 Creating database...
2020-06-25 16:09:10.733185 Writing to intermediate files...
Traceback (most recent call last):
File "/home/ahunter/libexec/perf-core/scripts/python/export-to-postgresql.py", line 1106, in synth_data
cbr(id, raw_buf)
File "/home/ahunter/libexec/perf-core/scripts/python/export-to-postgresql.py", line 1058, in cbr
value = struct.pack("!hiqiiiiii", 4, 8, id, 4, cbr, 4, MHz, 4, percent)
struct.error: required argument is not an integer
Fatal Python error: problem in Python trace event handler
Python runtime state: initialized
Current thread 0x00007f35d3695780 (most recent call first):
<no Python frame>
Aborted (core dumped)
After:
$ dropdb perf_data_db
$ rm -rf perf_data_db-perf-data
2020-06-25 16:09:40.990267 Creating database...
2020-06-25 16:09:41.207009 Writing to intermediate files...
2020-06-25 16:09:41.270915 Copying to database...
2020-06-25 16:09:41.382030 Removing intermediate files...
2020-06-25 16:09:41.384630 Adding primary keys
2020-06-25 16:09:41.541894 Adding foreign keys
2020-06-25 16:09:41.677044 Dropping unused tables
2020-06-25 16:09:41.703761 Done
Fixes: aba44287a224 ("perf scripts python: export-to-postgresql.py: Export Intel PT power and ptwrite events")
Link: http://lore.kernel.org/lkml/20200629091955.17090-2-adrian.hunter@intel.com
[ Upstream commit 4c95ad261cfac120dd66238fcae222766754c219 ]
The condition to add XMM registers was missing, the regs array needed to
be in the outer scope, and the size of the regs array was too small.
Fixes: 143d34a6b387b ("perf intel-pt: Add XMM registers to synthesized PEBS sample")
Cc: Luwei Kang <luwei.kang@intel.com>
Link: http://lore.kernel.org/lkml/20200630133935.11150-4-adrian.hunter@intel.com
[ Upstream commit 75bcb8776dc987538f267ba4ba05ca43fc2b1676 ]
When recording PEBS-via-PT, the kernel will not accept the intel_pt
event with register sampling e.g.
# perf record --kcore -c 10000 -e '{intel_pt/branch=0/,branch-loads/aux-output/ppp}' -I -- ls -l
Error:
intel_pt/branch=0/: PMU Hardware doesn't support sampling/overflow-interrupts. Try 'perf stat'
Fix by suppressing register sampling on the intel_pt evsel.
Committer notes:
Adrian informed that this is only available from Tremont onwards, so on
older processors the error continues the same as before.
Fixes: 9e64cefe4335b ("perf intel-pt: Process options for PEBS event synthesis")
Link: http://lore.kernel.org/lkml/20200630133935.11150-2-adrian.hunter@intel.com
[ Upstream commit d61cbb859b45fdb6b4997f2d51834fae41af0e94 ]
The segmentation fault can be reproduced as following steps:
1) Executing perf report in tui.
2) Typing '/xxxxx' to filter the symbol to get nothing matched.
3) Pressing enter with no entry selected.
Then it will report a segmentation fault.
It is caused by the lack of check of browser->he_selection when
accessing it's member res_samples in perf_evsel__hists_browse().
These processes are meaningful for specified samples, so we can skip
these when nothing is selected.
Fixes: 4968ac8fb7c3 ("perf report: Implement browsing of individual samples")
Acked-by: Namhyung Kim <namhyung@kernel.org>
Link: http://lore.kernel.org/lkml/20200612094322.39565-1-liwei391@huawei.com
[ Upstream commit c0c652fc705de75f4ba52e93053acc1ed3933e74 ]
If config->aggr_map is NULL and config->aggr_get_id is not NULL,
the function print_aggr() will still calling arrg_update_shadow(),
which can result in accessing the invalid pointer.
Fixes: 088519f318be ("perf stat: Move the display functions to stat-display.c")
Signed-off-by: Hongbo Yao <yaohongbo@huawei.com>
Link: https://lore.kernel.org/lkml/20200608163625.GC3073@kernel.org
[ Upstream commit 11b6e5482e178055ec1f2444b55f2518713809d1 ]
The 'evname' variable can be NULL, as it is checked a few lines back,
check it before using.
Fixes: 9e207ddfa207 ("perf report: Show call graph from reference events")
Cc: Kan Liang <kan.liang@intel.com>
Signed-off-by: Gaurav Singh <gaurav1086@gmail.com>
commit 0affd0e5262b6d40f5f63466d88933e99698e240 upstream.
Adjust 'map->pgoff' also when moving a map's start address.
Example with v5.4.34 based kernel:
Before:
$ sudo tools/perf/perf record -a --kcore -e intel_pt//k sleep 1
[ perf record: Captured and wrote 1.958 MB perf.data ]
$ sudo tools/perf/perf script --itrace=e >/dev/null
Warning:
961 instruction trace errors
After:
Committer testing:
# uname -a
Linux seventh 5.6.10-100.fc30.x86_64 #1 SMP Mon May 4 15:36:44 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
Before:
# perf record -a --kcore -e intel_pt//k sleep 1
[ perf record: Captured and wrote 0.923 MB perf.data ]
# perf script --itrace=e >/dev/null
Warning:
295 instruction trace errors
After:
[ perf record: Captured and wrote 0.919 MB perf.data ]
Fixes: fb5a88d4131a ("perf tools: Preserve eBPF maps when loading kcore")
Link: http://lore.kernel.org/lkml/20200602112505.1406-1-adrian.hunter@intel.com
commit 85afd35575a3c1a3a905722dde5ee70b49282e70 upstream.
Reportedly, from 19.10 Ubuntu has begun mixing up the location of some
debug symbol files, putting files expected to be in
/usr/lib/debug/usr/lib into /usr/lib/debug/lib instead. Fix by adding
another dso_binary_type.
Example on Ubuntu 20.04
Before:
Linux
[ perf record: Captured and wrote 0.030 MB perf.data ]
$ perf script --call-trace | head -5
uname 14003 [005] 15321.764958566: cbr: 42 freq: 4219 MHz (156%)
uname 14003 [005] 15321.764958566: (/usr/lib/x86_64-linux-gnu/ld-2.31.so ) 7f1e71cc4100
uname 14003 [005] 15321.764961566: (/usr/lib/x86_64-linux-gnu/ld-2.31.so ) 7f1e71cc4df0
uname 14003 [005] 15321.764961900: (/usr/lib/x86_64-linux-gnu/ld-2.31.so ) 7f1e71cc4e18
uname 14003 [005] 15321.764963233: (/usr/lib/x86_64-linux-gnu/ld-2.31.so ) 7f1e71cc5128
After:
uname 14003 [005] 15321.764958566: (/usr/lib/x86_64-linux-gnu/ld-2.31.so ) _start
uname 14003 [005] 15321.764961566: (/usr/lib/x86_64-linux-gnu/ld-2.31.so ) _dl_start
uname 14003 [005] 15321.764961900: (/usr/lib/x86_64-linux-gnu/ld-2.31.so ) _dl_start
uname 14003 [005] 15321.764963233: (/usr/lib/x86_64-linux-gnu/ld-2.31.so ) _dl_start
Reported-by: Travis Downs <travis.downs@gmail.com>
Link: http://lore.kernel.org/lkml/20200526155207.9172-1-adrian.hunter@intel.com
commit 2ae5d0d7d8868df7c05c2013c0b9cddd4d40610e upstream.
Since commit 03db8b583d1c ("perf tools: Fix
maps__find_symbol_by_name()") introduced map address range check in
maps__find_symbol_by_name(), we can not get "_etext" from kernel map
because _etext is placed on the edge of the kernel .text section (=
kernel map in perf.)
To fix this issue, this checks the address correctness by map address
range information (map->start and map->end) instead of using _etext
address.
This can cause an error if the target inlined function is embedded in
both __init function and normal function.
For exaample, request_resource() is a normal function but also embedded
in __init reserve_setup(). In this case, the probe point in
reserve_setup() must be skipped.
However, without this fix, it failes to setup all probe points:
# ./perf probe -v request_resource
probe-definition(0): request_resource
symbol:request_resource file:(null) line:0 offset:0 return:0 lazy:(null)
0 arguments
Looking at the vmlinux_path (8 entries long)
Using /usr/lib/debug/lib/modules/5.5.17-200.fc31.x86_64/vmlinux for symbols
Open Debuginfo file: /usr/lib/debug/lib/modules/5.5.17-200.fc31.x86_64/vmlinux
Try to find probe point from debuginfo.
Matched function: request_resource [15e29ad]
found inline addr: 0xffffffff82fbf892
Probe point found: reserve_setup+204
found inline addr: 0xffffffff810e9790
Probe point found: request_resource+0
Found 2 probe_trace_events.
Opening /sys/kernel/debug/tracing//kprobe_events write=1
Opening /sys/kernel/debug/tracing//README write=0
Writing event: p:probe/request_resource _text+33290386
Failed to write event: Invalid argument
Error: Failed to add events. Reason: Invalid argument (Code: -22)
With this fix,
# ./perf probe request_resource
reserve_setup is out of .text, skip it.
Added new events:
(null):(null) (on request_resource)
probe:request_resource (on request_resource)
You can now use it in all perf tools, such as:
perf record -e probe:request_resource -aR sleep 1
Fixes: 03db8b583d1c ("perf tools: Fix maps__find_symbol_by_name()")
Reported-by: Arnaldo Carvalho de Melo <acme@kernel.org>
Link: http://lore.kernel.org/lkml/158763967332.30755.4922496724365529088.stgit@devnote2
