[ Upstream commit e7ede72a6d40cb3a30c087142d79381ca8a31dab ]
The current symbols__fixup_end() heuristic for the last entry in the rb
tree is suboptimal as it leads to not being able to recognize the symbol
in the call graph in a couple of corner cases, for example:
i) If the symbol has a start address (f.e. exposed via kallsyms)
that is at a page boundary, then the roundup(curr->start, 4096)
for the last entry will result in curr->start == curr->end with
a symbol length of zero.
ii) If the symbol has a start address that is shortly before a page
boundary, then also here, curr->end - curr->start will just be
very few bytes, where it's unrealistic that we could perform a
match against.
Instead, change the heuristic to roundup(curr->start, 4096) + 4096, so
that we can catch such corner cases and have a better chance to find
that specific symbol. It's still just best effort as the real end of the
symbol is unknown to us (and could even be at a larger offset than the
current range), but better than the current situation.
Alexei reported that he recently run into case i) with a JITed eBPF
program (these are all page aligned) as the last symbol which wasn't
properly shown in the call graph (while other eBPF program symbols in
the rb tree were displayed correctly). Since this is a generic issue,
lets try to improve the heuristic a bit.
Reported-and-Tested-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Fixes: 2e538c4a1847 ("perf tools: Improve kernel/modules symbol lookup")
Link: http://lkml.kernel.org/r/bb5c80d27743be6f12afc68405f1956a330e1bc9.1489614365.git.daniel@iogearbox.net
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[ Upstream commit 22905582f6dd4bbd0c370fe5732c607452010c04 ]
Command perf test -v 16 (Setup struct perf_event_attr test) always
reports success even if the test case fails. It works correctly if you
also specify -F (for don't fork).
root@s35lp76 perf]# ./perf test -v 16
15: Setup struct perf_event_attr :
--- start ---
running './tests/attr/test-record-no-delay'
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.002 MB /tmp/tmp4E1h7R/perf.data
(1 samples) ]
expected task=0, got 1
expected precise_ip=0, got 3
expected wakeup_events=1, got 0
FAILED './tests/attr/test-record-no-delay' - match failure
test child finished with 0
---- end ----
Setup struct perf_event_attr: Ok
The reason for the wrong error reporting is the return value of the
system() library call. It is called in run_dir() file tests/attr.c and
returns the exit status, in above case 0xff00.
This value is given as parameter to the exit() function which can only
handle values 0-0xff.
The child process terminates with exit value of 0 and the parent does
not detect any error.
This patch corrects the error reporting and prints the correct test
result.
Signed-off-by: Thomas-Mich Richter <tmricht@linux.vnet.ibm.com>
Acked-by: Jiri Olsa <jolsa@kernel.org>
Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Cc: Thomas-Mich Richter <tmricht@linux.vnet.ibm.com>
LPU-Reference: 20170913081209.39570-2-tmricht@linux.vnet.ibm.com
Link: http://lkml.kernel.org/n/tip-rdube6rfcjsr1nzue72c7lqn@git.kernel.org
[ Upstream commit 75fc5ae5cc53fff71041ecadeb3354a2b4c9fe42 ]
Signed-off-by: Taeung Song <treeze.taeung@gmail.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Wang Nan <wangnan0@huawei.com>
Link: http://lkml.kernel.org/r/1485952447-7013-2-git-send-email-treeze.taeung@gmail.com
commit b581c01fff646b5075d65359c8667de9c667da9e upstream.
On my Archlinux machine, perf faild to build like below:
CC scripts/perl/Perf-Trace-Util/Context.o
In file included from /usr/lib/perl5/core/perl/CORE/perl.h:3905:0,
from Context.xs:23:
/usr/lib/perl5/core/perl/CORE/inline.h: In function :
/usr/lib/perl5/core/perl/CORE/cop.h:612:13: warning: declaration of 'av'
shadows a previous local [-Werror-shadow]
AV *av =3D GvAV(PL_defgv);
/usr/lib/perl5/core/perl/CORE/inline.h:526:5: note: in expansion of
macro 'CX_POP_SAVEARRAY'
CX_POP_SAVEARRAY(cx);
In file included from /usr/lib/perl5/core/perl/CORE/perl.h:5853:0,
from Context.xs:23:
/usr/lib/perl5/core/perl/CORE/inline.h:518:9: note:
shadowed declaration is here
AV *av;
What I did to fix is adding '-Wno-shadow' as the error message said it's
the cause of the failure. Since it's from the perl (not perf) code
base, we don't have the control so I just wanted to ignore the warning
when compiling perl scripting code.
Committer note:
This also fixes the build on Fedora Rawhide.
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Link: http://lkml.kernel.org/r/20160802024317.31725-1-namhyung@kernel.org
Cc: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
[ Upstream commit 7934c98a6e04028eb34c1293bfb5a6b0ab630b66 ]
Markus reported that perf segfaults when reading /sys/kernel/notes from
a kernel linked with GNU gold, due to what looks like a gold bug, so do
some bounds checking to avoid crashing in that case.
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Report-Link: http://lkml.kernel.org/r/20161219161821.GA294@x4
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Link: http://lkml.kernel.org/n/tip-ryhgs6a6jxvz207j2636w31c@git.kernel.org
[ Upstream commit 30a9c6444810429aa2b7cbfbd453ce339baaadbf ]
Those are binaries as well, so should be installed by:
make -C tools/perf install-bin'
too.
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Daniel Bristot de Oliveira <bristot@redhat.com>
Link: http://lkml.kernel.org/n/tip-3841b37u05evxrs1igkyu6ks@git.kernel.org
commit f952eaceb089b691eba7c4e13686e742a8f26bf5 upstream.
Intel PT uses IP compression based on the last IP. For decoding purposes,
'last IP' is not updated when a branch target has been suppressed, which is
indicated by IPBytes == 0. IPBytes is stored in the packet 'count', so
ensure never to set 'last_ip' when packet 'count' is zero.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Link: http://lkml.kernel.org/r/1495786658-18063-7-git-send-email-adrian.hunter@intel.com
commit 622b7a47b843c78626f40c1d1aeef8483383fba2 upstream.
The decoder will try to use branch packets to find an IP to start decoding
or to recover from errors. Currently the FUP packet is used only in the
case of an overflow, however there is no reason for that to be a special
case. So just use FUP always when scanning for an IP.
Link: http://lkml.kernel.org/r/1495786658-18063-8-git-send-email-adrian.hunter@intel.com
commit ee14ac0ef6827cd6f9a572cc83dd0191ea17812c upstream.
purposes, 'last IP' is considered to be reset to zero whenever there is
a synchronization packet (PSB). The decoder wasn't doing that, and was
treating the zero value to mean that there was no last IP, whereas
compression can be done against the zero value. Fix by setting last_ip
to zero when a PSB is received and keep track of have_last_ip.
Link: http://lkml.kernel.org/r/1495786658-18063-6-git-send-email-adrian.hunter@intel.com
commit e1717e0485af4f47fc4da1e979ac817f9ad61b0f upstream.
The June 2015 Intel SDM introduced IP Compression types 4 and 6. Refer
to section 36.4.2.2 Target IP (TIP) Packet - IP Compression.
Existing Intel PT packet decoder did not support type 4, and got type 6
wrong. Because type 3 and type 4 have the same number of bytes, the
packet 'count' has been changed from being the number of ip bytes to
being the type code. That allows the Intel PT decoder to correctly
decide whether to sign-extend or use the last ip. However that also
meant the code had to be adjusted in a number of places.
Currently hardware is not using the new compression types, so this fix
has no effect on existing hardware.
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/1469005206-3049-1-git-send-email-adrian.hunter@intel.com
target
commit 80f62589fa52f530cffc50e78c0b5a2ae572d61e upstream.
When the jump instruction is displayed at the row 0 in annotate view,
the arrow is broken. An example:
16.86 │ ┌──je 82
0.01 │ movsd (%rsp),%xmm0
│ movsd 0x8(%rsp),%xmm4
│ movsd 0x8(%rsp),%xmm1
│ movsd (%rsp),%xmm3
│ divsd %xmm4,%xmm0
│ divsd %xmm3,%xmm1
│ movsd (%rsp),%xmm2
│ addsd %xmm1,%xmm0
│ addsd %xmm2,%xmm0
│ movsd %xmm0,(%rsp)
│82: sub $0x1,%ebx
83.03 │ ↑ jne 38
│ add $0x10,%rsp
│ xor %eax,%eax
│ pop %rbx
│ ← retq
The patch increments the row number before checking with 0.
Signed-off-by: Yao Jin <yao.jin@linux.intel.com>
Cc: Kan Liang <kan.liang@intel.com>
Fixes: 944e1abed9e1 ("perf ui browser: Add method to draw up/down arrow line")
Link: http://lkml.kernel.org/r/1496901704-30275-1-git-send-email-yao.jin@linux.intel.com
commit 6a558f12dbe85437acbdec5e149ea07b5554eced upstream.
Sometimes a FUP packet is associated with a TSX transaction and a flag is
set to indicate that. Ensure that flag is cleared on any error condition
because at that point the decoder can no longer assume it is correct.
Link: http://lkml.kernel.org/r/1495786658-18063-9-git-send-email-adrian.hunter@intel.com
commit ad7167a8cd174ba7d8c0d0ed8d8410521206d104 upstream.
A value of zero is used to indicate that there is no IP. Ensure the
value is zero when the state is INTEL_PT_STATE_NO_IP.
Link: http://lkml.kernel.org/r/1495786658-18063-5-git-send-email-adrian.hunter@intel.com
commit 12b7080609097753fd8198cc1daf589be3ec1cca upstream.
The return compression stack must be cleared whenever there is a PSB. Fix
one case where that was not happening.
Link: http://lkml.kernel.org/r/1495786658-18063-4-git-send-email-adrian.hunter@intel.com
commit 3f04d98e972b59706bd43d6cc75efac91f8fba50 upstream.
The decoder uses its current timestamp in samples. Usually that is a
timestamp that has already passed, but in some cases it is a timestamp
for a branch that the decoder is walking towards, and consequently
hasn't reached. Improve that situation by using the pkt_state to
determine when to use the current or previous timestamp.
Link: http://lkml.kernel.org/r/1495786658-18063-3-git-send-email-adrian.hunter@intel.com
commit 22c06892332d8916115525145b78e606e9cc6492 upstream.
Move decoder error setting into one condition.
Cc'ed to stable because later fixes depend on it.
Link: http://lkml.kernel.org/r/1495786658-18063-2-git-send-email-adrian.hunter@intel.com
commit 22a9f41b555673e7499b97acf3ffb07bf0af31ad upstream.
The readdir() function is thread safe as long as just one thread uses a
DIR, which is the case when parsing tracepoint event definitions, to
avoid breaking the build with glibc-2.23.90 (upcoming 2.24), use it
instead of readdir_r().
See: http://man7.org/linux/man-pages/man3/readdir.3.html
"However, in modern implementations (including the glibc implementation),
concurrent calls to readdir() that specify different directory streams
are thread-safe. In cases where multiple threads must read from the
same directory stream, using readdir() with external synchronization is
still preferable to the use of the deprecated readdir_r(3) function."
Noticed while building on a Fedora Rawhide docker container.
Link: http://lkml.kernel.org/n/tip-wddn49r6bz6wq4ee3dxbl7lo@git.kernel.org
commit cf89813a5b514bff9b3b5e7eaf2090f22fba62e0 upstream.
The while loop was spinning. Fix by removing a semicolon.
The issue was pointed out by gcc-6's -Wmisleading-indentation.
Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Reviewed-by: Matt Fleming <matt@codeblueprint.co.uk>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Ben Hutchings <ben@decadent.org.uk>
Fixes: 035827e9f2bd ("perf tests: Add Intel CQM test")
Link: http://lkml.kernel.org/r/20151214154335.GA1409@x4
commit 3ed5ca2efff70e9f589087c2013789572901112d upstream.
We catch this record to provide a visual indication that events are
getting lost, then call the default method to allow extra logging shared
with the other tools to take place.
This extra logging was done twice because we were continuing to the
"default" clause where machine__process_event() will end up calling
machine__process_lost_event() again, fix it.
Link: http://lkml.kernel.org/n/tip-wus2zlhw3qo24ye84ewu4aqw@git.kernel.org
commit 62aa0e177d278462145a29c30d3c8501ae57e200 upstream.
To fix the build on Fedora Rawhide (gcc 6.0.0 20160311 (Red Hat 6.0.0-0.17):
CC /tmp/build/perf/arch/x86/util/dwarf-regs.o
arch/x86/util/dwarf-regs.c:66:36: error: 'x86_32_regoffset_table' defined but not used [-Werror=unused-const-variable=]
static const struct pt_regs_offset x86_32_regoffset_table[] = {
cc1: all warnings being treated as errors
Link: http://lkml.kernel.org/n/tip-fghuksc1u8ln82bof4lwcj0o@git.kernel.org
commit d85ce830eef6c10d1e9617172dea4681f02b8424 upstream.
One line in perf_pmu__parse_unit() is indented wrongly, leading to a
warning (=> error) from gcc 6:
util/pmu.c:156:3: error: statement is indented as if it were guarded by... [-Werror=misleading-indentation]
sret = read(fd, alias->unit, UNIT_MAX_LEN);
util/pmu.c:153:2: note: ...this 'if' clause, but it is not
if (fd == -1)
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Fixes: 410136f5dd96 ("tools/perf/stat: Add event unit and scale support")
Link: http://lkml.kernel.org/r/20151214154440.GC1409@x4
commit d4913cbd05bab685e49c8174896e563b2487d054 upstream.
Fixes: c97cf42219b7 ("perf top: Live TUI Annotation")
Link: http://lkml.kernel.org/r/20151214154403.GB1409@x4
commit 3b556bced46aa6b1873da7faa18eff235e896adc upstream.
Signed-off-by: Eric Engestrom <eric.engestrom@imgtec.com>
Link: http://lkml.kernel.org/r/1461577678-29517-1-git-send-email-eric.engestrom@imgtec.com
commit a5e8e825bd1704c488bf6a46936aaf3b9f203d6a upstream.
DIR, which is the case in 'perf script', so, to avoid breaking the build
with glibc-2.23.90 (upcoming 2.24), use it instead of readdir_r().
Link: http://lkml.kernel.org/n/tip-mt3xz7n2hl49ni2vx7kuq74g@git.kernel.org
commit 3354cf71104de49326d19d2f9bdb1f66eea52ef4 upstream.
DIR, which is the case in thread_map, so, to avoid breaking the build
Link: http://lkml.kernel.org/n/tip-del8h2a0f40z75j4r42l96l0@git.kernel.org
commit 7093b4c963cc4e344e490c774924a180602a7092 upstream.
DIR, which is the case when synthesizing events for pre-existing threads
by traversing /proc, so, to avoid breaking the build with glibc-2.23.90
CC /tmp/build/perf/util/event.o
util/event.c: In function '__event__synthesize_thread':
util/event.c:466:2: error: 'readdir_r' is deprecated [-Werror=deprecated-declarations]
while (!readdir_r(tasks, &dirent, &next) && next) {
In file included from /usr/include/features.h:368:0,
from /usr/include/stdint.h:25,
from /usr/lib/gcc/x86_64-redhat-linux/6.0.0/include/stdint.h:9,
from /git/linux/tools/include/linux/types.h:6,
from util/event.c:1:
/usr/include/dirent.h:189:12: note: declared here
Link: http://lkml.kernel.org/n/tip-i1vj7nyjp2p750rirxgrfd3c@git.kernel.org
commit 3aff8ba0a4c9c9191bb788171a1c54778e1246a2 upstream.
Addressing this warning from gcc 7:
CC /tmp/build/perf/bench/numa.o
bench/numa.c: In function '__bench_numa':
bench/numa.c:1582:42: error: '%d' directive output may be truncated writing between 1 and 10 bytes into a region of size between 8 and 17 [-Werror=format-truncation=]
snprintf(tname, 32, "process%d:thread%d", p, t);
bench/numa.c:1582:25: note: directive argument in the range [0, 2147483647]
In file included from /usr/include/stdio.h:939:0,
from bench/../util/util.h:47,
from bench/../builtin.h:4,
from bench/numa.c:11:
/usr/include/bits/stdio2.h:64:10: note: '__builtin___snprintf_chk' output between 17 and 35 bytes into a destination of size 32
return __builtin___snprintf_chk (__s, __n, __USE_FORTIFY_LEVEL - 1,
__bos (__s), __fmt, __va_arg_pack ());
Cc: Petr Holasek <pholasek@redhat.com>
Link: http://lkml.kernel.org/n/tip-twa37vsfqcie5gwpqwnjuuz9@git.kernel.org
commit 2e2bbc039fad9eabad6c4c1a473c8b2554cdd2d4 upstream.
Addressing a few cases spotted by a new warning in gcc 7:
tests/parse-events.c: In function 'test_pmu_events':
tests/parse-events.c:1790:39: error: '%s' directive output may be truncated writing up to 255 bytes into a region of size 90 [-Werror=format-truncation=]
snprintf(name, MAX_NAME, "cpu/event=%s/u", ent->d_name);
from /git/linux/tools/perf/util/map.h:9,
from /git/linux/tools/perf/util/symbol.h:7,
from /git/linux/tools/perf/util/evsel.h:10,
from tests/parse-events.c:3:
/usr/include/bits/stdio2.h:64:10: note: '__builtin___snprintf_chk' output between 13 and 268 bytes into a destination of size 100
tests/parse-events.c:1798:29: error: '%s' directive output may be truncated writing up to 255 bytes into a region of size 100 [-Werror=format-truncation=]
snprintf(name, MAX_NAME, "%s:u,cpu/event=%s/u", ent->d_name, ent->d_name);
Fixes: 945aea220bb8 ("perf tests: Move test objects into 'tests' directory")
Link: http://lkml.kernel.org/n/tip-ty4q2p8zp1dp3mskvubxskm5@git.kernel.org
commit d7dd112ea5cacf91ae72c0714c3b911eb6016fea upstream.
Fix below compile error:
CC util/scripting-engines/trace-event-perl.o
In file included from /usr/lib/perl5/5.22.2/i686-linux/CORE/perl.h:5673:0,
from util/scripting-engines/trace-event-perl.c:31:
/usr/lib/perl5/5.22.2/i686-linux/CORE/inline.h: In function 'S__is_utf8_char_slow':
/usr/lib/perl5/5.22.2/i686-linux/CORE/inline.h:270:5: error: nested extern declaration of 'Perl___notused' [-Werror=nested-externs]
dTHX; /* The function called below requires thread context */
After digging perl5 repository, I find out that we will meet this
compile error with perl from v5.21.1 to v5.25.4
Signed-off-by: Wang YanQing <udknight@gmail.com>
Link: http://lkml.kernel.org/r/20170212024655.GA15997@udknight
commit bdf23a9a190d7ecea092fd5c4aabb7d4bd0a9980 upstream.
The size of dirent->dt_name is NAME_MAX + 1, but the size for the 'path'
buffer is hard coded at 256, which may truncate it because we also
prepend "/proc/", so that all that into account and thank gcc 7 for this
warning:
/git/linux/tools/perf/util/thread_map.c: In function 'thread_map__new_by_uid':
/git/linux/tools/perf/util/thread_map.c:119:39: error: '%s' directive output may be truncated writing up to 255 bytes into a region of size 250 [-Werror=format-truncation=]
snprintf(path, sizeof(path), "/proc/%s", dirent->d_name);
from /git/linux/tools/perf/util/thread_map.c:5:
/usr/include/bits/stdio2.h:64:10: note: '__builtin___snprintf_chk' output between 7 and 262 bytes into a destination of size 256
Link: http://lkml.kernel.org/n/tip-csy0r8zrvz5efccgd4k12c82@git.kernel.org
commit 7ea6856d6f5629d742edc23b8b76e6263371ef45 upstream.
To address new warnings emmited by gcc 7, e.g.::
CC /tmp/build/perf/util/intel-pt-decoder/intel-pt-pkt-decoder.o
CC /tmp/build/perf/tests/parse-events.o
util/intel-pt-decoder/intel-pt-pkt-decoder.c: In function 'intel_pt_pkt_desc':
util/intel-pt-decoder/intel-pt-pkt-decoder.c:499:6: error: this statement may fall through [-Werror=implicit-fallthrough=]
if (!(packet->count))
util/intel-pt-decoder/intel-pt-pkt-decoder.c:501:2: note: here
case INTEL_PT_CYC:
CC /tmp/build/perf/util/intel-pt-decoder/intel-pt-decoder.o
Acked-by: Andi Kleen <ak@linux.intel.com>
Link: http://lkml.kernel.org/n/tip-mf0hw789pu9x855us5l32c83@git.kernel.org
commit 7b0214b702ad8e124e039a317beeebb3f020d125 upstream.
The implicit fall through case label here is intended, so let us inform
that to gcc >= 7:
CC /tmp/build/perf/builtin-top.o
builtin-top.c: In function 'display_thread':
builtin-top.c:644:7: error: this statement may fall through [-Werror=implicit-fallthrough=]
if (errno == EINTR)
builtin-top.c:647:3: note: here
default:
Link: http://lkml.kernel.org/n/tip-lmcfnnyx9ic0m6j0aud98p4e@git.kernel.org
commit d64b721d27aef3fbeb16ecda9dd22ee34818ff70 upstream.
that to gcc >= 7:
util/strfilter.c: In function 'strfilter_node__sprint':
util/strfilter.c:270:6: error: this statement may fall through [-Werror=implicit-fallthrough=]
if (len < 0)
util/strfilter.c:272:2: note: here
case '!':
Link: http://lkml.kernel.org/n/tip-z2dpywg7u8fim000hjfbpyfm@git.kernel.org
commit 94bdd5edb34e472980d1e18b4600d6fb92bd6b0a upstream.
that to gcc >= 7:
CC /tmp/build/perf/util/string.o
util/string.c: In function 'perf_atoll':
util/string.c:22:7: error: this statement may fall through [-Werror=implicit-fallthrough=]
if (*p)
util/string.c:24:3: note: here
case '\0':
Link: http://lkml.kernel.org/n/tip-0ophb30v9apkk6o95el0rqlq@git.kernel.org
[ Upstream commit d2d4edbebe07ddb77980656abe7b9bc7a9e0cdf7 ]
Fix to show correct locations for events on modules by relocating given
address instead of retrying after failure.
This happens when the module text size is big enough, bigger than
sh_addr, because the original code retries with given address + sh_addr
if it failed to find CU DIE at the given address.
Any address smaller than sh_addr always fails and it retries with the
correct address, but addresses bigger than sh_addr will get a CU DIE
which is on the given address (not adjusted by sh_addr).
In my environment(x86-64), the sh_addr of ".text" section is 0x10030.
Since i915 is a huge kernel module, we can see this issue as below.
$ grep "[Tt] .*\[i915\]" /proc/kallsyms | sort | head -n1
ffffffffc0270000 t i915_switcheroo_can_switch [i915]
ffffffffc0270000 + 0x10030 = ffffffffc0280030, so we'll check
symbols cross this boundary.
$ grep "[Tt] .*\[i915\]" /proc/kallsyms | grep -B1 ^ffffffffc028\
| head -n 2
ffffffffc027ff80 t haswell_init_clock_gating [i915]
ffffffffc0280110 t valleyview_init_clock_gating [i915]
So setup probes on both function and see what happen.
$ sudo ./perf probe -m i915 -a haswell_init_clock_gating \
-a valleyview_init_clock_gating
Added new events:
probe:haswell_init_clock_gating (on haswell_init_clock_gating in i915)
probe:valleyview_init_clock_gating (on valleyview_init_clock_gating in i915)
You can now use it in all perf tools, such as:
perf record -e probe:valleyview_init_clock_gating -aR sleep 1
$ sudo ./perf probe -l
probe:haswell_init_clock_gating (on haswell_init_clock_gating@gpu/drm/i915/intel_pm.c in i915)
probe:valleyview_init_clock_gating (on i915_vga_set_decode:4@gpu/drm/i915/i915_drv.c in i915)
As you can see, haswell_init_clock_gating is correctly shown,
but valleyview_init_clock_gating is not.
With this patch, both events are shown correctly.
probe:valleyview_init_clock_gating (on valleyview_init_clock_gating@gpu/drm/i915/intel_pm.c in i915)
Committer notes:
In my case:
# perf probe -m i915 -a haswell_init_clock_gating -a valleyview_init_clock_gating
Added new events:
# perf probe -l
probe:haswell_init_clock_gating (on i915_getparam+432@gpu/drm/i915/i915_drv.c in i915)
probe:valleyview_init_clock_gating (on __i915_printk+240@gpu/drm/i915/i915_drv.c in i915)
# readelf -SW /lib/modules/4.9.0+/build/vmlinux | egrep -w '.text|Name'
[Nr] Name Type Address Off Size ES Flg Lk Inf Al
[ 1] .text PROGBITS ffffffff81000000 200000 822fd3 00 AX 0 0 4096
So both are b0rked, now with the fix:
Added new events:
# perf probe -l
Both looks correct.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Link: http://lkml.kernel.org/r/148411436777.9978.1440275861947194930.stgit@devbox
commit cf346d5bd4b9d61656df2f72565c9b354ef3ca0d upstream.
Both register_perl_scripting() and register_python_scripting() allocate
this variable, fix it by checking if it already was.
Cc: Tom Zanussi <tzanussi@gmail.com>
Fixes: 7e4b21b84c43 ("perf/scripts: Add Python scripting engine")
commit 67befc652845c8ffbefc8d173a6e6ced14d472f1 upstream.
Ingo reported following build failure:
$ make clean install
CC plugin_kmem.o
fixdep: error opening depfile: ./.plugin_hrtimer.o.d: No such file or directory
/home/mingo/tip/tools/build/Makefile.build:77: recipe for target
'plugin_hrtimer.o' failed
make[3]: *** [plugin_hrtimer.o] Error 2
Makefile:189: recipe for target 'plugin_hrtimer-in.o' failed
make[2]: *** [plugin_hrtimer-in.o] Error 2
Makefile.perf:414: recipe for target 'libtraceevent_plugins' failed
make[1]: *** [libtraceevent_plugins] Error 2
make[1]: *** Waiting for unfinished jobs....
Currently we have the install-traceevent-plugins target being dependent
on $(LIBTRACEEVENT), which will actualy not build any plugin. So the
install-traceevent-plugins target itself will try to build plugins,
but..
Plugins built is also triggered by perf build itself via
libtraceevent_plugins target.
This might cause a race having one make thread removing temp files from
another and result in above error. Fixing this by having proper plugins
build dependency before installing plugins.
Reported-and-Tested-by:: Ingo Molnar <mingo@kernel.org>
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Link: http://lkml.kernel.org/r/1448546044-28973-3-git-send-email-jolsa@kernel.org
Cc: Thomas Backlund <tmb@mageia.org>
commit 432746f8e0b6a82ba832b771afe31abd51af6752 upstream.
When we call symbol__fixup_duplicate() we use algorithms to pick the
"best" symbols for cases where there are various functions/aliases to an
address, and those check zero size symbols, which, before calling
symbol__fixup_end() are _all_ symbols in a just parsed kallsyms file.
So first fixup the end, then fixup the duplicates.
Found while trying to figure out why 'perf test vmlinux' failed, see the
output of 'perf test -v vmlinux' to see cases where the symbols picked
as best for vmlinux don't match the ones picked for kallsyms.
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Fixes: 694bf407b061 ("perf symbols: Add some heuristics for choosing the best duplicate symbol")
Link: http://lkml.kernel.org/n/tip-rxqvdgr0mqjdxee0kf8i2ufn@git.kernel.org
commit c97b40e4d15f13a36cd037d598e45cbe9e1e5757 upstream.
We can allow aliases to be kept, but we were checking this just when
loading vmlinux files, be consistent, do it for any symbol table loading
code that calls symbol__fixup_duplicate() by making this function check
.allow_aliases instead.
Fixes: 680d926a8cb0 ("perf symbols: Allow symbol alias when loading map for symbol name")
Link: http://lkml.kernel.org/n/tip-z0avp0s6cfjckc4xj3pdfjdz@git.kernel.org
commit d9ea48bc4e7cc297ca1073fa3f90ed80d964b7b4 upstream.
Milian reported that the event group on TUI shows duplicated overhead.
This was due to a bug on calculating hpp->buf position. The
hpp_advance() was called from __hpp__slsmg_color_printf() on TUI but
it's already called from the hpp__call_print_fn macro in __hpp__fmt().
The end result is that the print function returns number of bytes it
printed but the buffer advanced twice of the length.
This is generally not a problem since it doesn't need to access the
buffer again. But with event group, overhead needs to be printed
multiple times and hist_entry__snprintf_alignment() tries to fill the
space with buffer after it printed. So it (brokenly) showed the last
overhead again.
The bug was there from the beginning, but I think it's only revealed
when the alignment function was added.
Reported-by: Milian Wolff <milian.wolff@kdab.com>
Fixes: 89fee7094323 ("perf hists: Do column alignment on the format iterator")
Link: http://lkml.kernel.org/r/20160912061958.16656-2-namhyung@kernel.org
commit 51fd2df1e882a3c2a3f4b6c9ff243a93c9046dba upstream.
We broke interval data displays with commit:
3f416f22d1e2 ("perf stat: Do not clean event's private stats")
This commit removed stats cleaning, which is important for '-r' option
to carry counters data over the whole run. But it's necessary to clean
it for interval mode, otherwise the displayed value is avg of all
previous values.
Before:
$ perf stat -e cycles -a -I 1000 record
# time counts unit events
1.000240796 75,216,287 cycles
2.000512791 107,823,524 cycles
$ perf stat report
2.000512791 91,519,906 cycles
Now:
$ perf stat report
Notice the second value being bigger (91,.. < 107,..).
This could be easily verified by using perf script which displays raw
stat data:
$ perf script
CPU THREAD VAL ENA RUN TIME EVENT
0 -1 23855779 1000209530 1000209530 1000240796 cycles
1 -1 33340397 1000224964 1000224964 1000240796 cycles
2 -1 15835415 1000226695 1000226695 1000240796 cycles
3 -1 2184696 1000228245 1000228245 1000240796 cycles
0 -1 97014312 2000514533 2000514533 2000512791 cycles
1 -1 46121497 2000543795 2000543795 2000512791 cycles
2 -1 32269530 2000543566 2000543566 2000512791 cycles
3 -1 7634472 2000544108 2000544108 2000512791 cycles
The sum of the first 4 values is the first interval aggregated value:
23855779 + 33340397 + 15835415 + 2184696 = 75,216,287
The sum of the second 4 values minus first value is the second interval
aggregated value:
97014312 + 46121497 + 32269530 + 7634472 - 75216287 = 107,823,524
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1454485436-20639-1-git-send-email-jolsa@kernel.org
Cc: Jeremy Linton <jeremy.linton@arm.com>
commit 3bccbe20f6d188ce7b00326e776b745cfd35b10a upstream.
The MTC packet provides a 8-bit slice of CTC which is related to TSC by
the TMA packet, however the TMA packet only provides the lower 16 bits
of CTC. If mtc_shift > 8 then some of the MTC bits are not in the CTC
provided by the TMA packet. Fix-up the last_mtc calculated from the TMA
packet by copying the missing bits from the current MTC assuming the
least difference between the two, and that the current MTC comes after
last_mtc.
Link: http://lkml.kernel.org/r/1475062896-22274-2-git-send-email-adrian.hunter@intel.com
commit 51ee6481fa8e879cc942bcc1b0af713e158b7a98 upstream.
In cycle-accurate mode, timestamps can be calculated from CYC packets.
The decoder also estimates timestamps based on the number of
instructions since the last timestamp. For that to work in
cycle-accurate mode, the instruction count needs to be reset to zero
when a timestamp is calculated from a CYC packet, but that wasn't
happening, so fix it.
Link: http://lkml.kernel.org/r/1475062896-22274-1-git-send-email-adrian.hunter@intel.com
commit 810c398bc09b2f2dfde52a7d2483a710612c5fb8 upstream.
Fix occasional decoder errors decoding trace data collected in snapshot
mode.
Snapshot mode can take successive snapshots of trace which might overlap.
The decoder checks whether there is an overlap but only looks at the
current and previous buffer. However buffers that do not contain
synchronization (i.e. PSB) packets cannot be decoded or used for overlap
checking. That means the decoder actually needs to check overlaps between
the current buffer and the previous buffer that contained usable data.
Make that change.
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Link: http://lkml.kernel.org/r/1474641528-18776-10-git-send-email-adrian.hunter@intel.com
commit 3d918fb13abdbeca7947578f5d7e426eafad7f5e upstream.
In order to successfully decode Intel PT traces, context switch events
are needed from the moment the trace starts. Currently that is ensured
by using the 'immediate' flag which enables the switch event when it is
opened.
However, since commit 86c2786994bd ("perf intel-pt: Add support for
PERF_RECORD_SWITCH") that might not always happen. When tracing
system-wide the context switch event is added to the tracking event
which was not set as 'immediate'. Change that so it is.
Fixes: 86c2786994bd ("perf intel-pt: Add support for PERF_RECORD_SWITCH")
Link: http://lkml.kernel.org/r/1471245784-22580-1-git-send-email-adrian.hunter@intel.com
commit 916d4092a1d2d7bb50630497be71ee4c4c2807fa upstream.
$ rpm -q glibc
glibc-2.12-1.166.el6_7.1.x86_64
<SNIP>
CC /tmp/build/perf/tests/llvm.o
cc1: warnings being treated as errors
tests/llvm.c: In function ‘test_llvm__fetch_bpf_obj’:
tests/llvm.c:53: error: declaration of ‘index’ shadows a global declaration
/usr/include/string.h:489: error: shadowed declaration is here
<SNIP>
CC /tmp/build/perf/tests/bpf.o
tests/bpf.c: In function ‘__test__bpf’:
tests/bpf.c:149: error: declaration of ‘index’ shadows a global declaration
<SNIP>
Cc: He Kuang <hekuang@huawei.com>
Cc: pi3orama@163.com
Cc: Zefan Li <lizefan@huawei.com>
Fixes: b31de018a628 ("perf test: Enhance the LLVM test: update basic BPF test program")
Fixes: ba1fae431e74 ("perf test: Add 'perf test BPF'")
Link: http://lkml.kernel.org/n/tip-akpo4r750oya2phxoh9e3447@git.kernel.org
Cc: Nikolay Borisov <kernel@kyup.com>
commit f594bae08183fb6b57db55387794ece3e1edf6f6 upstream.
I'm surprised this remained undocumented since at least 2011. And it is
actually a very useful switch, as Steve and I came to realize recently.
Add the text from
2cba3ffb9a9d ("perf stat: Add -d -d and -d -d -d options to show more CPU events")
which added the incrementing aspect to -d.
Cc: Davidlohr Bueso <dbueso@suse.com>
Cc: Mel Gorman <mgorman@suse.com>
Fixes: 2cba3ffb9a9d ("perf stat: Add -d -d and -d -d -d options to show more CPU events")
Link: http://lkml.kernel.org/r/1457347294-32546-1-git-send-email-bp@alien8.de
commit 89fee59b504f86925894fcc9ba79d5c933842f93 upstream.
Steam frequently puts game binaries in folders with spaces.
Note: "(deleted)" markers are now treated as part of the file name.
Signed-off-by: Marcin Ślusarz <marcin.slusarz@gmail.com>
Acked-by: Namhyung Kim <namhyung@kernel.org>
Fixes: 6064803313ba ("perf tools: Use sscanf for parsing /proc/pid/maps")
Link: http://lkml.kernel.org/r/20160119190303.GA17579@marcin-Inspiron-7720
cursor
commit c221acb0f970d3b80d72c812cda19c121acf5d52 upstream.
When this feature was introduced a check was made if there was a
resolved symbol under the cursor, it got lost in commit ea7cd5923309
("perf hists browser: Split popup menu actions - part 2"), reinstate it.
Cc: Jiri Olsa <jolsa@kernel.org>,
Fixes: ea7cd5923309 ("perf hists browser: Split popup menu actions - part 2")
Link: http://lkml.kernel.org/r/1452960197-5323-9-git-send-email-namhyung@kernel.org
[ Carved out from a larger patch ]
commit a55e5663761366fb883f6f25375dd68bc958b9db upstream.
We were dropping the reference we possibly held but not obtaining one
for the new maps, which we will drop at perf_evlist__delete(), fix it.
This was caught by Steven Noonan in some of the machines which would
produce this output when caught by glibc debug mechanisms:
$ sudo perf test 21
21: Test object code reading :***
Error in `perf': corrupted double-linked list: 0x00000000023ffcd0 ***
======= Backtrace: =========
/usr/lib/libc.so.6(+0x72055)[0x7f25be0f3055]
/usr/lib/libc.so.6(+0x779b6)[0x7f25be0f89b6]
/usr/lib/libc.so.6(+0x7a0ed)[0x7f25be0fb0ed]
/usr/lib/libc.so.6(__libc_calloc+0xba)[0x7f25be0fceda]
perf(parse_events_lex_init_extra+0x38)[0x4cfff8]
perf(parse_events+0x55)[0x4a0615]
perf(perf_evlist__config+0xcf)[0x4eeb2f]
perf[0x479f82]
perf(test__code_reading+0x1e)[0x47ad4e]
perf(cmd_test+0x5dd)[0x46452d]
perf[0x47f4e3]
perf(main+0x603)[0x42c723]
/usr/lib/libc.so.6(__libc_start_main+0xf0)[0x7f25be0a1610]
perf(_start+0x29)[0x42c859]
Further investigation using valgrind led to the reference count imbalance fixed
in this patch.
Reported-and-Tested-by: Steven Noonan <steven@uplinklabs.net>
Report-Link: http://lkml.kernel.org/r/CAKbGBLjC2Dx5vshxyGmQkcD+VwiAQLbHoXA9i7kvRB2-2opHZQ@mail.gmail.com
Fixes: f30a79b012e5 ("perf tools: Add reference counting for cpu_map object")
Link: http://lkml.kernel.org/n/tip-j0u1bdhr47sa511sgg76kb8h@git.kernel.org
