path: root/tools/scripts
2013-12-19tools lib traceevent: Add global QUIET_CC_FPIC build outputJiri Olsa
Adding global QUIET_CC_FPIC build output variable and getting rid of local print_fpic_compile and print_plugin_obj_compile. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1387460527-15030-6-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-19perf tools: Making QUIET_(CLEAN|INSTAL) variables globalJiri Olsa
Moving QUIET_(CLEAN|INSTAL) variables into: tools/scripts/Makefile.include to be usable by other tools. The change to use them in libtraceevent is in following patches. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1387460527-15030-3-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-11tools: Harmonize the various build messages in perf, lib-traceevent, lib-lkIngo Molnar
The various build lines from libtraceevent and perf mix up during a parallel build and produce unaligned output like: CC builtin-buildid-list.o CC builtin-buildid-cache.o CC builtin-list.o CC FPIC trace-seq.o CC builtin-record.o CC FPIC parse-filter.o CC builtin-report.o CC builtin-stat.o CC FPIC parse-utils.o CC FPIC kbuffer-parse.o CC builtin-timechart.o CC builtin-top.o CC builtin-script.o BUILD STATIC LIB libtraceevent.a CC builtin-probe.o CC builtin-kmem.o CC builtin-lock.o To solve this, harmonize all the build message alignments to be similar to the kernel's kbuild output: prefixed by two spaces and 11-char wide. After the patch the output looks pretty tidy, even if output lines get mixed up: CC builtin-annotate.o FLAGS: * new build flags or cross compiler CC builtin-bench.o AR liblk.a CC bench/sched-messaging.o CC FPIC event-parse.o CC bench/sched-pipe.o CC FPIC trace-seq.o CC bench/mem-memcpy.o CC bench/mem-memset.o CC FPIC parse-filter.o CC builtin-diff.o CC builtin-evlist.o CC builtin-help.o Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1381312169-17354-3-git-send-email-mingo@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-11perf tools: Implement summary output for 'make clean'Ingo Molnar
'make clean' used to show all the rm lines, which isn't really informative in any way and spams the console. Implement summary output: comet:~/tip/tools/perf> make clean CLEAN libtraceevent CLEAN liblk CLEAN config CLEAN core-objs CLEAN core-progs CLEAN core-gen CLEAN Documentation CLEAN python 'make clean V=1' will still show the old, detailed output. Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1381312169-17354-2-git-send-email-mingo@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-07-08tools: Get only verbose output with V=1Robert Richter
Fix having verbose build with V=0, e.g: make V=0 -C tools/ perf Signed-off-by: Robert Richter <robert.richter@calxeda.com> Link: http://lkml.kernel.org/r/20130503134953.GU8356@rric.localhost Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-03-15perf tools: Correct Makefile.includeBorislav Petkov
It looks at O= and adjusts the $(OUTPUT) variable based on what the output directory will be. However, when O is defined but empty, it wrongly becomes the user's $HOME dir which is not what we want. So check it is not empty before working with it further. Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1361374353-30385-4-git-send-email-bp@alien8.de Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-03-15perf tools: Honor parallel jobsBorislav Petkov
We need to hand down parallel build options like the internal make --jobserver-fds one so that parallel builds can also happen when building perf from the toplevel directory. Make it so #1! Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1361374353-30385-3-git-send-email-bp@alien8.de Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-11-19tools: Pass the target in descendDavid Howells
Fixing: [acme@sandy linux]$ cd tools [acme@sandy tools]$ make clean DESCEND power/cpupower CC lib/cpufreq.o CC lib/sysfs.o LD libcpupower.so.0.0.0 CC utils/helpers/amd.o utils/helpers/amd.c:7:21: error: pci/pci.h: No such file or directory In file included from utils/helpers/amd.c:9: ./utils/helpers/helpers.h:137: warning: ‘struct pci_access’ declared inside parameter list ./utils/helpers/helpers.h:137: warning: its scope is only this definition or declaration, which is probably not what you want ./utils/helpers/helpers.h:139: warning: ‘struct pci_access’ declared inside parameter list utils/helpers/amd.c: In function ‘amd_pci_get_num_boost_states’: utils/helpers/amd.c:120: warning: passing argument 1 of ‘pci_slot_func_init’ from incompatible pointer type ./utils/helpers/helpers.h:138: note: expected ‘struct pci_access **’ but argument is of type ‘struct pci_access **’ utils/helpers/amd.c:125: warning: implicit declaration of function ‘pci_read_byte’ utils/helpers/amd.c:132: warning: implicit declaration of function ‘pci_cleanup’ make[1]: *** [utils/helpers/amd.o] Error 1 make: *** [cpupower_clean] Error 2 [acme@sandy tools]$ Reported-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David Howells <dhowells@redhat.com> Cc: Borislav Petkov <bp@amd64.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/n/tip-tviyimq6x6nm77sj5lt4t19f@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-11-19tools: Honour the O= flag when tool build called from a higher MakefileDavid Howells
Honour the O= flag that was passed to a higher level Makefile and then passed down as part of a tool build. To make this work, the top-level Makefile passes the original O= flag and subdir=tools to the tools/Makefile, and that in turn passes subdir=$(O)/$(subdir)/foodir when building tool foo in directory $(O)/$(subdir)/foodir (where the intervening slashes aren't added if an element is missing). For example, take perf. This is found in tools/perf/. Assume we're building into directory ~/zebra/, so we pass O=~/zebra to make. Dependening on where we run the build from, we see: make run in dir $(OUTPUT) dir ======================= ================== linux ~/zebra/tools/perf/ linux/tools ~/zebra/perf/ linux/tools/perf ~/zebra/ and if O= is not set, we get: make run in dir $(OUTPUT) dir ======================= ================== linux linux/tools/perf/ linux/tools linux/tools/perf/ linux/tools/perf linux/tools/perf/ The output directories are created by the descend function if they don't already exist. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Borislav Petkov <bp@amd64.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1378.1352379110@warthog.procyon.org.uk Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-11-19tools: Define a Makefile function to do subdir processingDavid Howells
Define a Makefile function that can be called with $(call ...) to wrap the subdir make invocations in tools/Makefile. This will allow us in the next patch to insert bits in there to honour O= flags when called from the top-level Makefile. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Borislav Petkov <bp@amd64.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1378.1352379110@warthog.procyon.org.uk Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-08-16perf tools: Let O= makes handle relative pathsSteven Rostedt
When I did a compile of perf using a relative path for the output directory, the build failed when it tried to compile libtraceevent. This is because it continues to use the same relative path when the new working directory is in a different path. SUBDIR ../lib/traceevent/ /bin/sh: line 0: cd: ../../../nobackup/perf/: No such file or directory Makefile:74: *** output directory "../../../nobackup/perf/" does not exist. Stop. make: *** [../../../nobackup/perf///libtraceevent.a] Error 2 Make the path used an absolute path when building perf with O=. Boris: Teach Makefile to check whether the supplied O= directory exists and bail out if not. Reportedly, kernel dudes are idiots and need to be guarded so as not to shoot themselves in the foot when playing in the sandbox. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20120815163923.GD15989@aftab.osrc.amd.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-25perf: Build libtraceevent.aSteven Rostedt
Have building perf also build libtraceevent.a. Currently, perf does not use the code within libtraceevent.a, but it soon will. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Arun Sharma <asharma@fb.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2012-04-11tools: Cleanup EXTRA_WARNINGSBorislav Petkov
Use += instead of the bash syntax, as Sam Ravnborg suggests. Also, sort the -W options alphabetically and (... keep them sorted). Suggested-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Sam Ravnborg <sam@ravnborg.org> Link: http://lkml.kernel.org/r/1334162178-17152-3-git-send-email-bp@amd64.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-11tools: Add Makefile.includeBorislav Petkov
Put generic enough build settings which could be reused by other tools into a common Makefile.include file. This commit reintroduces QUIET_SUBDIR{0,1} (see a3d1ee10d1bf) which are going to be used in the following patches. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Sam Ravnborg <sam@ravnborg.org> Link: http://lkml.kernel.org/r/1334162178-17152-2-git-send-email-bp@amd64.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
