[ Upstream commit c5c08bed843c2b2c048c16d1296d7631d7c1620e ]
Fixes: d38499530e5 ("fs: decouple READ and WRITE from the block layer ops")
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
trivial fix to spelling mistake in an error message.
Acked-by: Jason Wang <jasowang@redhat.com>
Use the param flag for that.
Add a new flag for passing test-specific parameters.
Previous commit ("virtio: add context flag to find vqs")
added a new 'context' flag to vring_new_virtqueue(), but the
corresponding API in tools/virtio/ is not updated causing
build errors due to conflicting declarations.
Bring code in tools/virtio in sync with that in kernel.
I have used 'false' for the value of the new boolean 'context'
flag as that seems to be the best way to preserve existing
behavior.
Tested with:
$ make -C tools/virtio clean all ARCH=x86
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
There is an || vs && typo so the assert can never be triggered.
Make ringtest work on s390 too.
Signed-off-by: Halil Pasic <pasic@linux.vnet.ibm.com>
Acked-by: Sascha Silbe <silbe@linux.vnet.ibm.com>
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Since ef1b144d ("tools/virtio/ringtest: fix run-on-all.sh to work
without /dev/cpu") run-on-all.sh uses seq 0 $HOST_AFFINITY as the list
of ids of the CPUs to run the command on (assuming ids of online CPUs
are consecutive and start from 0), where $HOST_AFFINITY is the highest
CPU id in the system previously determined using lscpu. This can fail
on systems with offline CPUs.
Instead let's use lscpu to determine the list of online CPUs.
Fixes: ef1b144d ("tools/virtio/ringtest: fix run-on-all.sh to work without
/dev/cpu")
Reviewed-by: Sascha Silbe <silbe@linux.vnet.ibm.com>
As a step towards killing off ACCESS_ONCE, use {READ,WRITE}_ONCE() for the
virtio tools uaccess primitives, pulling these in from <linux/compiler.h>.
With this done, we can kill off the now-unused ACCESS_ONCE() definition.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Jason Wang <jasowang@redhat.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: virtualization@lists.linux-foundation.org
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Reviewed-by: Jason Wang <jasowang@redhat.com>
The virtio tools implementation of READ_ONCE() has a single parameter called
'var', but erroneously refers to 'val' for its cast, and thus won't work unless
there's a variable of the correct type that happens to be called 'var'.
Fix this with s/var/val/, making READ_ONCE() work as expected regardless.
Fixes: a7c490333df3cff5 ("tools/virtio: use virt_xxx barriers")
Updating the event index has a memory barrier and causes more work
on the other side to actually signal the event. It is unnecessary
if a new buffer has already appeared on the ring, so poll once before
doing the update.
The effect of this on the 0.9 ring implementation is pretty much
invisible, but on the new-style ring it provides a consistent 3%
performance improvement.
Provide new primitives used_empty/avail_empty and
build poll_avail/poll_used on top of it.
By using -flto and -fwhole-program, all functions from the ring implementation
can be treated as static and possibly inlined. Force this to happen through
the GCC flatten attribute.
Fixes build after recent IOMMU-related changes,
mustly by adding more stubs.
Recent changes to ptr_ring broke the ringtest
which lacks a likely() stub. Fix it up.
Fixes: 982fb490c298896d15e9323a882f34a57c11ff56
("ptr_ring: support zero length ring")
Sometimes, we need support resizing multiple queues at once. This is
because it was not easy to recover to recover from a partial failure
of multiple queues resizing.
Signed-off-by: Jason Wang <jasowang@redhat.com>
Several cases of overlapping changes, except the packet scheduler
conflicts which deal with the addition of the free list parameter
to qdisc_enqueue().
Add ringtest based unit test for ptr ring.
Useful to measure testing framework overhead.
/dev/cpu is only available on x86 with certain modules (e.g. msr) enabled.
Using lscpu to get processors count is more portable.
Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com>
Having typical usage example in the README file is more convinient than in
the git history...
just a stub pointer for now.
skips ring accesses but drops out of order support
virtio_ring currently sends the device (usually a hypervisor)
physical addresses of its I/O buffers. This is okay when DMA
addresses and physical addresses are the same thing, but this isn't
always the case. For example, this never works on Xen guests, and
it is likely to fail if a physical "virtio" device ever ends up
behind an IOMMU or swiotlb.
The immediate use case for me is to enable virtio on Xen guests.
For that to work, we need vring to support DMA address translation
as well as a corresponding change to virtio_pci or to another
driver.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
This adds micro-benchmarks useful for tuning virtio ring layouts.
Three layouts are currently implemented:
- virtio 0.9 compatible one
- an experimental extension bypassing the ring index, polling ring
itself instead
- an experimental extension bypassing avail and used ring completely
Typical use:
sh run-on-all.sh perf stat -r 10 --log-fd 1 -- ./ring
It doesn't depend on the kernel directly, but it's handy
to have as much virtio stuff as possible in one tree.
Fix build after API changes.
Reported-by: Kamal Mostafa <kamal@canonical.com>
commit cf561f0d2eb74574ad9985a2feab134267a9d298 ("virtio: introduce
virtio_is_little_endian() helper") changed byteswap logic to
skip feature bit checks for LE platforms, but didn't
update tools/virtio, so vring_bench started failing.
Update the copy under tools/virtio/ (TODO: find a way to avoid this code
duplication).
Cc: Greg Kurz <gkurz@linux.vnet.ibm.com>
Makes them more generally available.
more stubs, mostly
Seems to mostly be a positive.
Missed one place where vringh_test used
long to pass features. Fix it up to u64.
Include missing virtio_config.h
As usual, add more stubs to fix test build after main
codebase changes.
Change u32 to u64, and use BIT_ULL and 1ULL everywhere.
Note: transports are unchanged, and only set low 32 bit.
This guarantees that no transport sets e.g. VERSION_1
by mistake without proper support.
Based on patch by Rusty.
Reviewed-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
It seemed like a good idea to use bitmap for features
in struct virtio_device, but it's actually a pain,
and seems to become even more painful when we get more
than 32 feature bits. Just change it to a u32 for now.
Suggested-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Combine all definitions into a common tools/include/linux/types.h and
kill the wild growth elsewhere. Move DECLARE_BITMAP to its proper
bitmap.h header.
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Link: http://lkml.kernel.org/n/tip-azczs7qcv6h9xek9od10hiv2@git.kernel.org
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
So tools/ has been growing three, at a different stage of their
development export.h headers and so we should unite into one. Add
tools/include/ to the include path of virtio and liblockdep to pick the
shared header now.
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: virtio-dev@lists.oasis-open.org
Link: http://lkml.kernel.org/r/1397493185-19521-2-git-send-email-bp@alien8.de
Fixes the following build failure:
cc -g -O2 -Wall -I. -I ../../usr/include/ -Wno-pointer-sign
-fno-strict-overflow -fno-strict-aliasing -fno-common -MMD
-U_FORTIFY_SOURCE -c -o virtio_test.o virtio_test.c
virtio_test.c: In function ‘run_test’:
virtio_test.c:176:7: error: expected ‘)’ before ‘r’
r = -1;
Fixes: 53c18c9906441 (virtio_test: verify if virtqueue_kick() succeeded)
Cc: Heinz Graalfs <graalfs@linux.vnet.ibm.com>
Signed-off-by: Joel Stanley <joel@jms.id.au>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
In commit bb478d8b167 virtio_ring: plug kmemleak false positive,
kmemleak_ignore was introduced. This broke compilation of virtio_test:
-U_FORTIFY_SOURCE -c -o virtio_ring.o ../../drivers/virtio/virtio_ring.c
../../drivers/virtio/virtio_ring.c: In function ‘vring_add_indirect’:
../../drivers/virtio/virtio_ring.c:177:2: warning: implicit declaration
of function ‘kmemleak_ignore’ [-Wimplicit-function-declaration]
kmemleak_ignore(desc);
cc virtio_test.o virtio_ring.o -o virtio_test
virtio_ring.o: In function `vring_add_indirect':
tools/virtio/../../drivers/virtio/virtio_ring.c:177:
undefined reference to `kmemleak_ignore'
Add a dummy header for tools/virtio, and add #incldue <linux/kmemleak.h>
to drivers/virtio/virtio_ring.c so it is picked up by the userspace
tools.
The virtio headers have changed recently:
5b1bf7cb673 virtio_ring: let virtqueue_{kick()/notify()} return a bool
46f9c2b925a virtio_ring: change host notification API
Update the internal copies to fix the build of virtio_test:
-fno-strict-overflow -fno-strict-aliasing -fno-common -MMD -U_FORTIFY_SOURCE
In file included from virtio_test.c:15:0:
./linux/virtio.h:76:19: error: conflicting types for ‘vring_new_virtqueue’
struct virtqueue *vring_new_virtqueue(unsigned int index,
In file included from ./linux/virtio_ring.h:1:0,
from ../../usr/include/linux/vhost.h:17,
from virtio_test.c:14:
./linux/../../../include/linux/virtio_ring.h:68:19: note: previous
declaration of ‘vring_new_virtqueue’ was here
virtio_test.c: In function ‘vq_info_add’:
virtio_test.c:103:12: warning: passing argument 7 of ‘vring_new_virtqueue’
from incompatible pointer type [enabled by default]
vq_notify, vq_callback, "test");
./linux/virtio.h:76:19: note: expected ‘void (*)(struct virtqueue *)’ but
argument is of type ‘_Bool (*)(struct virtqueue *)’
Verify if a host kick succeeded by checking return value of virtqueue_kick().
Signed-off-by: Heinz Graalfs <graalfs@linux.vnet.ibm.com>
Currently a host kick error is silently ignored and not reflected in
the virtqueue of a particular virtio device.
Changing the notify API for guest->host notification seems to be one
prerequisite in order to be able to handle such errors in the context
where the kick is triggered.
This patch changes the notify API. The notify function must return a
bool return value. It returns false if the host notification failed.
Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com>
This fixes build for the vringh test:
[linux]$ make -C tools/virtio/
make: Entering directory `/home/mst/scm/linux/tools/virtio'
-U_FORTIFY_SOURCE -c -o vringh.o ../../drivers/vhost/vringh.c
../../drivers/vhost/vringh.c:1010:16: error: expected declaration
specifiers or ‘...’ before string constant
Make the rest of the paths use virtqueue_add_sgs or add_outbuf.
As expected, the simplified accessors are faster.
for i in `seq 50`; do /usr/bin/time -f 'Wall time:%e' ./vringh_test --indirect --eventidx --parallel --fast-vringh; done 2>&1 | stats --trim-outliers:
Before:
Using CPUS 0 and 3
Guest: notified 0, pinged 39062-39063(39063)
Host: notified 39062-39063(39063), pinged 0
Wall time:1.760000-2.220000(1.789167)
After:
Using CPUS 0 and 3
Guest: notified 0, pinged 39037-39063(39062)
Host: notified 39037-39063(39062), pinged 0
Wall time:1.640000-1.810000(1.676875)
