path: root/tools
2020-04-24objtool: Fix switch table detection in .text.unlikelyJosh Poimboeuf
commit b401efc120a399dfda1f4d2858a4de365c9b08ef upstream. If a switch jump table's indirect branch is in a ".cold" subfunction in .text.unlikely, objtool doesn't detect it, and instead prints a false warning: drivers/media/v4l2-core/v4l2-ioctl.o: warning: objtool: v4l_print_format.cold()+0xd6: sibling call from callable instruction with modified stack frame drivers/hwmon/max6650.o: warning: objtool: max6650_probe.cold()+0xa5: sibling call from callable instruction with modified stack frame drivers/media/dvb-frontends/drxk_hard.o: warning: objtool: init_drxk.cold()+0x16f: sibling call from callable instruction with modified stack frame Fix it by comparing the function, instead of the section and offset. Fixes: 13810435b9a7 ("objtool: Support GCC 8's cold subfunctions") Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Borislav Petkov <bp@suse.de> Reviewed-by: Miroslav Benes <mbenes@suse.cz> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Link: https://lkml.kernel.org/r/157c35d42ca9b6354bbb1604fe9ad7d1153ccb21.1585761021.git.jpoimboe@redhat.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-24tools: gpio: Fix out-of-tree build regressionAnssi Hannula
commit 82f04bfe2aff428b063eefd234679b2d693228ed upstream. Commit 0161a94e2d1c7 ("tools: gpio: Correctly add make dependencies for gpio_utils") added a make rule for gpio-utils-in.o but used $(output) instead of the correct $(OUTPUT) for the output directory, breaking out-of-tree build (O=xx) with the following error: No rule to make target 'out/tools/gpio/gpio-utils-in.o', needed by 'out/tools/gpio/lsgpio-in.o'. Stop. Fix that. Fixes: 0161a94e2d1c ("tools: gpio: Correctly add make dependencies for gpio_utils") Cc: <stable@vger.kernel.org> Cc: Laura Abbott <labbott@redhat.com> Signed-off-by: Anssi Hannula <anssi.hannula@bitwise.fi> Link: https://lore.kernel.org/r/20200325103154.32235-1-anssi.hannula@bitwise.fi Reviewed-by: Bartosz Golaszewski <bgolaszewski@baylibre.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-24selftests/x86/ptrace_syscall_32: Fix no-vDSO segfaultAndy Lutomirski
[ Upstream commit 630b99ab60aa972052a4202a1ff96c7e45eb0054 ] If AT_SYSINFO is not present, don't try to call a NULL pointer. Reported-by: kbuild test robot <lkp@intel.com> Signed-off-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Borislav Petkov <bp@suse.de> Link: https://lkml.kernel.org/r/faaf688265a7e1a5b944d6f8bc0f6368158306d3.1584052409.git.luto@kernel.org Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-04-13tools/accounting/getdelays.c: fix netlink attribute lengthDavid Ahern
commit 4054ab64e29bb05b3dfe758fff3c38a74ba753bb upstream. A recent change to the netlink code: 6e237d099fac ("netlink: Relax attr validation for fixed length types") logs a warning when programs send messages with invalid attributes (e.g., wrong length for a u32). Yafang reported this error message for tools/accounting/getdelays.c. send_cmd() is wrongly adding 1 to the attribute length. As noted in include/uapi/linux/netlink.h nla_len should be NLA_HDRLEN + payload length, so drop the +1. Fixes: 9e06d3f9f6b1 ("per task delay accounting taskstats interface: documentation fix") Reported-by: Yafang Shao <laoar.shao@gmail.com> Signed-off-by: David Ahern <dsahern@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Tested-by: Yafang Shao <laoar.shao@gmail.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/20200327173111.63922-1-dsahern@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02perf map: Fix off by one in strncpy() size argumentdisconnect3d
commit db2c549407d4a76563c579e4768f7d6d32afefba upstream. This patch fixes an off-by-one error in strncpy size argument in tools/perf/util/map.c. The issue is that in: strncmp(filename, "/system/lib/", 11) the passed string literal: "/system/lib/" has 12 bytes (without the NULL byte) and the passed size argument is 11. As a result, the logic won't match the ending "/" byte and will pass filepaths that are stored in other directories e.g. "/system/libmalicious/bin" or just "/system/libmalicious". This functionality seems to be present only on Android. I assume the /system/ directory is only writable by the root user, so I don't think this bug has much (or any) security impact. Fixes: eca818369996 ("perf tools: Add automatic remapping of Android libraries") Signed-off-by: disconnect3d <dominik.b.czarnota@gmail.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Changbin Du <changbin.du@intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: John Keeping <john@metanate.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Michael Lentine <mlentine@google.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Song Liu <songliubraving@fb.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lore.kernel.org/lkml/20200309104855.3775-1-dominik.b.czarnota@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02tools: Let O= makes handle a relative path with -C optionMasami Hiramatsu
[ Upstream commit be40920fbf1003c38ccdc02b571e01a75d890c82 ] When I tried to compile tools/perf from the top directory with the -C option, the O= option didn't work correctly if I passed a relative path: $ make O=BUILD -C tools/perf/ make: Entering directory '/home/mhiramat/ksrc/linux/tools/perf' BUILD: Doing 'make -j8' parallel build ../scripts/Makefile.include:4: *** O=/home/mhiramat/ksrc/linux/tools/perf/BUILD does not exist. Stop. make: *** [Makefile:70: all] Error 2 make: Leaving directory '/home/mhiramat/ksrc/linux/tools/perf' The O= directory existence check failed because the check script ran in the build target directory instead of the directory where I ran the make command. To fix that, once change directory to $(PWD) and check O= directory, since the PWD is set to where the make command runs. Fixes: c883122acc0d ("perf tools: Let O= makes handle relative paths") Reported-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Masahiro Yamada <masahiroy@kernel.org> Cc: Michal Marek <michal.lkml@markovi.net> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sasha Levin <sashal@kernel.org> Cc: Steven Rostedt (VMware) <rostedt@goodmis.org> Cc: stable@vger.kernel.org Link: http://lore.kernel.org/lkml/158351957799.3363.15269768530697526765.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-04-02perf probe: Do not depend on dwfl_module_addrsym()Masami Hiramatsu
commit 1efde2754275dbd9d11c6e0132a4f09facf297ab upstream. Do not depend on dwfl_module_addrsym() because it can fail on user-space shared libraries. Actually, same bug was fixed by commit 664fee3dc379 ("perf probe: Do not use dwfl_module_addrsym if dwarf_diename finds symbol name"), but commit 07d369857808 ("perf probe: Fix wrong address verification) reverted to get actual symbol address from symtab. This fixes it again by getting symbol address from DIE, and only if the DIE has only address range, it uses dwfl_module_addrsym(). Fixes: 07d369857808 ("perf probe: Fix wrong address verification) Reported-by: Alexandre Ghiti <alex@ghiti.fr> Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Alexandre Ghiti <alex@ghiti.fr> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sasha Levin <sashal@kernel.org> Link: http://lore.kernel.org/lkml/158281812176.476.14164573830975116234.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02cpupower: avoid multiple definition with gcc -fno-commonMike Gilbert
[ Upstream commit 2de7fb60a4740135e03cf55c1982e393ccb87b6b ] Building cpupower with -fno-common in CFLAGS results in errors due to multiple definitions of the 'cpu_count' and 'start_time' variables. ./utils/idle_monitor/snb_idle.o:./utils/idle_monitor/cpupower-monitor.h:28: multiple definition of `cpu_count'; ./utils/idle_monitor/nhm_idle.o:./utils/idle_monitor/cpupower-monitor.h:28: first defined here ... ./utils/idle_monitor/cpuidle_sysfs.o:./utils/idle_monitor/cpuidle_sysfs.c:22: multiple definition of `start_time'; ./utils/idle_monitor/amd_fam14h_idle.o:./utils/idle_monitor/amd_fam14h_idle.c:85: first defined here The -fno-common option will be enabled by default in GCC 10. Bug: https://bugs.gentoo.org/707462 Signed-off-by: Mike Gilbert <floppym@gentoo.org> Signed-off-by: Shuah Khan <skhan@linuxfoundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-03-11perf hists browser: Restore ESC as "Zoom out" of DSO/thread/etcArnaldo Carvalho de Melo
commit 3f7774033e6820d25beee5cf7aefa11d4968b951 upstream. We need to set actions->ms.map since 599a2f38a989 ("perf hists browser: Check sort keys before hot key actions"), as in that patch we bail out if map is NULL. Reviewed-by: Jiri Olsa <jolsa@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Namhyung Kim <namhyung@kernel.org> Fixes: 599a2f38a989 ("perf hists browser: Check sort keys before hot key actions") Link: https://lkml.kernel.org/n/tip-wp1ssoewy6zihwwexqpohv0j@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-02-28x86/decoder: Add TEST opcode to Group3-2Masami Hiramatsu
[ Upstream commit 8b7e20a7ba54836076ff35a28349dabea4cec48f ] Add TEST opcode to Group3-2 reg=001b as same as Group3-1 does. Commit 12a78d43de76 ("x86/decoder: Add new TEST instruction pattern") added a TEST opcode assignment to f6 XX/001/XXX (Group 3-1), but did not add f7 XX/001/XXX (Group 3-2). Actually, this TEST opcode variant (ModRM.reg /1) is not described in the Intel SDM Vol2 but in AMD64 Architecture Programmer's Manual Vol.3, Appendix A.2 Table A-6. ModRM.reg Extensions for the Primary Opcode Map. Without this fix, Randy found a warning by insn_decoder_test related to this issue as below. HOSTCC arch/x86/tools/insn_decoder_test HOSTCC arch/x86/tools/insn_sanity TEST posttest arch/x86/tools/insn_decoder_test: warning: Found an x86 instruction decoder bug, please report this. arch/x86/tools/insn_decoder_test: warning: ffffffff81000bf1: f7 0b 00 01 08 00 testl $0x80100,(%rbx) arch/x86/tools/insn_decoder_test: warning: objdump says 6 bytes, but insn_get_length() says 2 arch/x86/tools/insn_decoder_test: warning: Decoded and checked 11913894 instructions with 1 failures TEST posttest arch/x86/tools/insn_sanity: Success: decoded and checked 1000000 random instructions with 0 errors (seed:0x871ce29c) To fix this error, add the TEST opcode according to AMD64 APM Vol.3. [ bp: Massage commit message. ] Reported-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Randy Dunlap <rdunlap@infradead.org> Tested-by: Randy Dunlap <rdunlap@infradead.org> Link: https://lkml.kernel.org/r/157966631413.9580.10311036595431878351.stgit@devnote2 Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-02-28usbip: Fix unsafe unaligned pointer usageShuah Khan
[ Upstream commit 585c91f40d201bc564d4e76b83c05b3b5363fe7e ] Fix unsafe unaligned pointer usage in usbip network interfaces. usbip tool build fails with new gcc -Werror=address-of-packed-member checks. usbip_network.c: In function ‘usbip_net_pack_usb_device’: usbip_network.c:79:32: error: taking address of packed member of ‘struct usbip_usb_device’ may result in an unaligned pointer value [-Werror=address-of-packed-member] 79 | usbip_net_pack_uint32_t(pack, &udev->busnum); Fix with minor changes to pass by value instead of by address. Signed-off-by: Shuah Khan <skhan@linuxfoundation.org> Link: https://lore.kernel.org/r/20200109012416.2875-1-skhan@linuxfoundation.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-02-28tools lib api fs: Fix gcc9 stringop-truncation compilation errorAndrey Zhizhikin
[ Upstream commit 6794200fa3c9c3e6759dae099145f23e4310f4f7 ] GCC9 introduced string hardening mechanisms, which exhibits the error during fs api compilation: error: '__builtin_strncpy' specified bound 4096 equals destination size [-Werror=stringop-truncation] This comes when the length of copy passed to strncpy is is equal to destination size, which could potentially lead to buffer overflow. There is a need to mitigate this potential issue by limiting the size of destination by 1 and explicitly terminate the destination with NULL. Signed-off-by: Andrey Zhizhikin <andrey.zhizhikin@leica-geosystems.com> Reviewed-by: Petr Mladek <pmladek@suse.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Andrii Nakryiko <andriin@fb.com> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: Kefeng Wang <wangkefeng.wang@huawei.com> Cc: Martin KaFai Lau <kafai@fb.com> Cc: Petr Mladek <pmladek@suse.com> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Song Liu <songliubraving@fb.com> Cc: Yonghong Song <yhs@fb.com> Cc: bpf@vger.kernel.org Cc: netdev@vger.kernel.org Link: http://lore.kernel.org/lkml/20191211080109.18765-1-andrey.zhizhikin@leica-geosystems.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-02-14tools/power/acpi: fix compilation errorZhengyuan Liu
commit 1985f8c7f9a42a651a9750d6fcadc74336d182df upstream. If we compile tools/acpi target in the top source directory, we'd get a compilation error showing as bellow: # make tools/acpi DESCEND power/acpi DESCEND tools/acpidbg CC tools/acpidbg/acpidbg.o Assembler messages: Fatal error: can't create /home/lzy/kernel-upstream/power/acpi/\ tools/acpidbg/acpidbg.o: No such file or directory ../../Makefile.rules:26: recipe for target '/home/lzy/kernel-upstream/\ power/acpi/tools/acpidbg/acpidbg.o' failed make[3]: *** [/home/lzy/kernel-upstream//power/acpi/tools/acpidbg/\ acpidbg.o] Error 1 Makefile:19: recipe for target 'acpidbg' failed make[2]: *** [acpidbg] Error 2 Makefile:54: recipe for target 'acpi' failed make[1]: *** [acpi] Error 2 Makefile:1607: recipe for target 'tools/acpi' failed make: *** [tools/acpi] Error 2 Fixes: d5a4b1a540b8 ("tools/power/acpi: Remove direct kernel source include reference") Signed-off-by: Zhengyuan Liu <liuzhengyuan@kylinos.cn> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-02-05tools lib: Fix builds when glibc contains strlcpy()Vitaly Chikunov
commit 6c4798d3f08b81c2c52936b10e0fa872590c96ae upstream. Disable a couple of compilation warnings (which are treated as errors) on strlcpy() definition and declaration, allowing users to compile perf and kernel (objtool) when: 1. glibc have strlcpy() (such as in ALT Linux since 2004) objtool and perf build fails with this (in gcc): In file included from exec-cmd.c:3: tools/include/linux/string.h:20:15: error: redundant redeclaration of ‘strlcpy’ [-Werror=redundant-decls] 20 | extern size_t strlcpy(char *dest, const char *src, size_t size); 2. clang ignores `-Wredundant-decls', but produces another warning when building perf: CC util/string.o ../lib/string.c:99:8: error: attribute declaration must precede definition [-Werror,-Wignored-attributes] size_t __weak strlcpy(char *dest, const char *src, size_t size) ../../tools/include/linux/compiler.h:66:34: note: expanded from macro '__weak' # define __weak __attribute__((weak)) /usr/include/bits/string_fortified.h:151:8: note: previous definition is here __NTH (strlcpy (char *__restrict __dest, const char *__restrict __src, Committer notes: The #pragma GCC diagnostic directive was introduced in gcc 4.6, so check for that as well. Fixes: ce99091 ("perf tools: Move strlcpy() from perf to tools/lib/string.c") Fixes: 0215d59 ("tools lib: Reinstate strlcpy() header guard with __UCLIBC__") Resolves: https://bugzilla.kernel.org/show_bug.cgi?id=118481 Signed-off-by: Vitaly Chikunov <vt@altlinux.org> Reviewed-by: Dmitry Levin <ldv@altlinux.org> Cc: Dmitry Levin <ldv@altlinux.org> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: kbuild test robot <lkp@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: stable@vger.kernel.org Cc: Vineet Gupta <vineet.gupta1@synopsys.com> Link: http://lore.kernel.org/lkml/20191224172029.19690-1-vt@altlinux.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-01-23perf probe: Fix wrong address verificationMasami Hiramatsu
commit 07d369857808b7e8e471bbbbb0074a6718f89b31 upstream. Since there are some DIE which has only ranges instead of the combination of entrypc/highpc, address verification must use dwarf_haspc() instead of dwarf_entrypc/dwarf_highpc. Also, the ranges only DIE will have a partial code in different section (e.g. unlikely code will be in text.unlikely as "FUNC.cold" symbol). In that case, we can not use dwarf_entrypc() or die_entrypc(), because the offset from original DIE can be a minus value. Instead, this simply gets the symbol and offset from symtab. Without this patch; # perf probe -D clear_tasks_mm_cpumask:1 Failed to get entry address of clear_tasks_mm_cpumask Error: Failed to add events. And with this patch: # perf probe -D clear_tasks_mm_cpumask:1 p:probe/clear_tasks_mm_cpumask clear_tasks_mm_cpumask+0 p:probe/clear_tasks_mm_cpumask_1 clear_tasks_mm_cpumask+5 p:probe/clear_tasks_mm_cpumask_2 clear_tasks_mm_cpumask+8 p:probe/clear_tasks_mm_cpumask_3 clear_tasks_mm_cpumask+16 p:probe/clear_tasks_mm_cpumask_4 clear_tasks_mm_cpumask+82 Committer testing: I managed to reproduce the above: [root@quaco ~]# perf probe -D clear_tasks_mm_cpumask:1 p:probe/clear_tasks_mm_cpumask _text+919968 p:probe/clear_tasks_mm_cpumask_1 _text+919973 p:probe/clear_tasks_mm_cpumask_2 _text+919976 [root@quaco ~]# But then when trying to actually put the probe in place, it fails if I use :0 as the offset: [root@quaco ~]# perf probe -L clear_tasks_mm_cpumask | head -5 <clear_tasks_mm_cpumask@/usr/src/debug/kernel-5.2.fc30/linux-5.2.18-200.fc30.x86_64/kernel/cpu.c:0> 0 void clear_tasks_mm_cpumask(int cpu) 1 { 2 struct task_struct *p; [root@quaco ~]# perf probe clear_tasks_mm_cpumask:0 Probe point 'clear_tasks_mm_cpumask' not found. Error: Failed to add events. [root@quaco The next patch is needed to fix this case. Fixes: 576b523721b7 ("perf probe: Fix probing symbols with optimization suffix") Reported-by: Arnaldo Carvalho de Melo <acme@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157199318513.8075.10463906803299647907.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-01-23perf report: Fix incorrectly added dimensions as switch perf data fileJin Yao
commit 0feba17bd7ee3b7e03d141f119049dcc23efa94e upstream. We observed an issue that was some extra columns displayed after switching perf data file in browser. The steps to reproduce: 1. perf record -a -e cycles,instructions -- sleep 3 2. perf report --group 3. In browser, we use hotkey 's' to switch to another perf.data 4. Now in browser, the extra columns 'Self' and 'Children' are displayed. The issue is setup_sorting() executed again after repeat path, so dimensions are added again. This patch checks the last key returned from __cmd_report(). If it's K_SWITCH_INPUT_DATA, skips the setup_sorting(). Fixes: ad0de0971b7f ("perf report: Enable the runtime switching of perf data file") Signed-off-by: Jin Yao <yao.jin@linux.intel.com> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Feng Tang <feng.tang@intel.com> Cc: Jin Yao <yao.jin@intel.com> Cc: Kan Liang <kan.liang@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lore.kernel.org/lkml/20191220013722.20592-1-yao.jin@linux.intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-01-23perf hists: Fix variable name's inconsistency in hists__for_each() macroYuya Fujita
commit 55347ec340af401437680fd0e88df6739a967f9f upstream. Variable names are inconsistent in hists__for_each macro(). Due to this inconsistency, the macro replaces its second argument with "fmt" regardless of its original name. So far it works because only "fmt" is passed to the second argument. However, this behavior is not expected and should be fixed. Fixes: f0786af536bb ("perf hists: Introduce hists__for_each_format macro") Fixes: aa6f50af822a ("perf hists: Introduce hists__for_each_sort_list macro") Signed-off-by: Yuya Fujita <fujita.yuya@fujitsu.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lore.kernel.org/lkml/OSAPR01MB1588E1C47AC22043175DE1B2E8520@OSAPR01MB1588.jpnprd01.prod.outlook.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-01-23rseq/selftests: Turn off timeout settingMathieu Desnoyers
[ Upstream commit af9cb29c5488381083b0b5ccdfb3cd931063384a ] As the rseq selftests can run for a long period of time, disable the timeout that the general selftests have. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Shuah Khan <skhan@linuxfoundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: "Paul E. McKenney" <paulmck@linux.ibm.com> Cc: Boqun Feng <boqun.feng@gmail.com> Cc: "H . Peter Anvin" <hpa@zytor.com> Cc: Paul Turner <pjt@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Shuah Khan <skhan@linuxfoundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-12Revert "perf report: Add warning when libunwind not compiled in"Sasha Levin
This reverts commit 59b706ce44dbfd35a428f2cbad47794ce5dce1eb. This change depends on more changes that didn't exist in 4.9 and older. Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04perf strbuf: Remove redundant va_end() in strbuf_addv()Mattias Jacobsson
commit 099be748865eece21362aee416c350c0b1ae34df upstream. Each call to va_copy() should have one, and only one, corresponding call to va_end(). In strbuf_addv() some code paths result in va_end() getting called multiple times. Remove the superfluous va_end(). Signed-off-by: Mattias Jacobsson <2pi@mok.nu> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sanskriti Sharma <sansharm@redhat.com> Link: http://lkml.kernel.org/r/20181229141750.16945-1-2pi@mok.nu Fixes: ce49d8436cff ("perf strbuf: Match va_{add,copy} with va_end") Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro1.iwamatsu@toshiba.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-01-04perf regs: Make perf_reg_name() return "unknown" instead of NULLArnaldo Carvalho de Melo
[ Upstream commit 5b596e0ff0e1852197d4c82d3314db5e43126bf7 ] To avoid breaking the build on arches where this is not wired up, at least all the other features should be made available and when using this specific routine, the "unknown" should point the user/developer to the need to wire this up on this particular hardware architecture. Detected in a container mipsel debian cross build environment, where it shows up as: In file included from /usr/mipsel-linux-gnu/include/stdio.h:867, from /git/linux/tools/perf/lib/include/perf/cpumap.h:6, from util/session.c:13: In function 'printf', inlined from 'regs_dump__printf' at util/session.c:1103:3, inlined from 'regs__printf' at util/session.c:1131:2: /usr/mipsel-linux-gnu/include/bits/stdio2.h:107:10: error: '%-5s' directive argument is null [-Werror=format-overflow=] 107 | return __printf_chk (__USE_FORTIFY_LEVEL - 1, __fmt, __va_arg_pack ()); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ cross compiler details: mipsel-linux-gnu-gcc (Debian 9.2.1-8) 9.2.1 20190909 Also on mips64: In file included from /usr/mips64-linux-gnuabi64/include/stdio.h:867, from /git/linux/tools/perf/lib/include/perf/cpumap.h:6, from util/session.c:13: In function 'printf', inlined from 'regs_dump__printf' at util/session.c:1103:3, inlined from 'regs__printf' at util/session.c:1131:2, inlined from 'regs_user__printf' at util/session.c:1139:3, inlined from 'dump_sample' at util/session.c:1246:3, inlined from 'machines__deliver_event' at util/session.c:1421:3: /usr/mips64-linux-gnuabi64/include/bits/stdio2.h:107:10: error: '%-5s' directive argument is null [-Werror=format-overflow=] 107 | return __printf_chk (__USE_FORTIFY_LEVEL - 1, __fmt, __va_arg_pack ()); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ In function 'printf', inlined from 'regs_dump__printf' at util/session.c:1103:3, inlined from 'regs__printf' at util/session.c:1131:2, inlined from 'regs_intr__printf' at util/session.c:1147:3, inlined from 'dump_sample' at util/session.c:1249:3, inlined from 'machines__deliver_event' at util/session.c:1421:3: /usr/mips64-linux-gnuabi64/include/bits/stdio2.h:107:10: error: '%-5s' directive argument is null [-Werror=format-overflow=] 107 | return __printf_chk (__USE_FORTIFY_LEVEL - 1, __fmt, __va_arg_pack ()); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ cross compiler details: mips64-linux-gnuabi64-gcc (Debian 9.2.1-8) 9.2.1 20190909 Fixes: 2bcd355b71da ("perf tools: Add interface to arch registers sets") Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Link: https://lkml.kernel.org/n/tip-95wjyv4o65nuaeweq31t7l1s@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04perf probe: Fix to show function entry line as probe-ableMasami Hiramatsu
commit 91e2f539eeda26ab00bd03fae8dc434c128c85ed upstream. Fix die_walk_lines() to list the function entry line correctly. Since the dwarf_entrypc() does not return the entry pc if the DIE has only range attribute, __die_walk_funclines() fails to list the declaration line (entry line) in that case. To solve this issue, this introduces die_entrypc() which correctly returns the entry PC (the first address range) even if the DIE has only range attribute. With this fix die_walk_lines() shows the function entry line is able to probe correctly. Fixes: 4cc9cec636e7 ("perf probe: Introduce lines walker interface") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157190837419.1859.4619125803596816752.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Thomas Backlund <tmb@mageia.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-01-04libtraceevent: Fix memory leakage in copy_filter_typeHewenliang
[ Upstream commit 10992af6bf46a2048ad964985a5b77464e5563b1 ] It is necessary to free the memory that we have allocated when error occurs. Fixes: ef3072cd1d5c ("tools lib traceevent: Get rid of die in add_filter_type()") Signed-off-by: Hewenliang <hewenliang4@huawei.com> Reviewed-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Cc: Tzvetomir Stoyanov <tstoyanov@vmware.com> Link: http://lore.kernel.org/lkml/20191119014415.57210-1-hewenliang4@huawei.com Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04x86/insn: Add some Intel instructions to the opcode mapAdrian Hunter
[ Upstream commit b980be189c9badba50634671e2303e92bf28e35a ] Add to the opcode map the following instructions: cldemote tpause umonitor umwait movdiri movdir64b enqcmd enqcmds encls enclu enclv pconfig wbnoinvd For information about the instructions, refer Intel SDM May 2019 (325462-070US) and Intel Architecture Instruction Set Extensions May 2019 (319433-037). The instruction decoding can be tested using the perf tools' "x86 instruction decoder - new instructions" test as folllows: $ perf test -v "new " 2>&1 | grep -i cldemote Decoded ok: 0f 1c 00 cldemote (%eax) Decoded ok: 0f 1c 05 78 56 34 12 cldemote 0x12345678 Decoded ok: 0f 1c 84 c8 78 56 34 12 cldemote 0x12345678(%eax,%ecx,8) Decoded ok: 0f 1c 00 cldemote (%rax) Decoded ok: 41 0f 1c 00 cldemote (%r8) Decoded ok: 0f 1c 04 25 78 56 34 12 cldemote 0x12345678 Decoded ok: 0f 1c 84 c8 78 56 34 12 cldemote 0x12345678(%rax,%rcx,8) Decoded ok: 41 0f 1c 84 c8 78 56 34 12 cldemote 0x12345678(%r8,%rcx,8) $ perf test -v "new " 2>&1 | grep -i tpause Decoded ok: 66 0f ae f3 tpause %ebx Decoded ok: 66 0f ae f3 tpause %ebx Decoded ok: 66 41 0f ae f0 tpause %r8d $ perf test -v "new " 2>&1 | grep -i umonitor Decoded ok: 67 f3 0f ae f0 umonitor %ax Decoded ok: f3 0f ae f0 umonitor %eax Decoded ok: 67 f3 0f ae f0 umonitor %eax Decoded ok: f3 0f ae f0 umonitor %rax Decoded ok: 67 f3 41 0f ae f0 umonitor %r8d $ perf test -v "new " 2>&1 | grep -i umwait Decoded ok: f2 0f ae f0 umwait %eax Decoded ok: f2 0f ae f0 umwait %eax Decoded ok: f2 41 0f ae f0 umwait %r8d $ perf test -v "new " 2>&1 | grep -i movdiri Decoded ok: 0f 38 f9 03 movdiri %eax,(%ebx) Decoded ok: 0f 38 f9 88 78 56 34 12 movdiri %ecx,0x12345678(%eax) Decoded ok: 48 0f 38 f9 03 movdiri %rax,(%rbx) Decoded ok: 48 0f 38 f9 88 78 56 34 12 movdiri %rcx,0x12345678(%rax) $ perf test -v "new " 2>&1 | grep -i movdir64b Decoded ok: 66 0f 38 f8 18 movdir64b (%eax),%ebx Decoded ok: 66 0f 38 f8 88 78 56 34 12 movdir64b 0x12345678(%eax),%ecx Decoded ok: 67 66 0f 38 f8 1c movdir64b (%si),%bx Decoded ok: 67 66 0f 38 f8 8c 34 12 movdir64b 0x1234(%si),%cx Decoded ok: 66 0f 38 f8 18 movdir64b (%rax),%rbx Decoded ok: 66 0f 38 f8 88 78 56 34 12 movdir64b 0x12345678(%rax),%rcx Decoded ok: 67 66 0f 38 f8 18 movdir64b (%eax),%ebx Decoded ok: 67 66 0f 38 f8 88 78 56 34 12 movdir64b 0x12345678(%eax),%ecx $ perf test -v "new " 2>&1 | grep -i enqcmd Decoded ok: f2 0f 38 f8 18 enqcmd (%eax),%ebx Decoded ok: f2 0f 38 f8 88 78 56 34 12 enqcmd 0x12345678(%eax),%ecx Decoded ok: 67 f2 0f 38 f8 1c enqcmd (%si),%bx Decoded ok: 67 f2 0f 38 f8 8c 34 12 enqcmd 0x1234(%si),%cx Decoded ok: f3 0f 38 f8 18 enqcmds (%eax),%ebx Decoded ok: f3 0f 38 f8 88 78 56 34 12 enqcmds 0x12345678(%eax),%ecx Decoded ok: 67 f3 0f 38 f8 1c enqcmds (%si),%bx Decoded ok: 67 f3 0f 38 f8 8c 34 12 enqcmds 0x1234(%si),%cx Decoded ok: f2 0f 38 f8 18 enqcmd (%rax),%rbx Decoded ok: f2 0f 38 f8 88 78 56 34 12 enqcmd 0x12345678(%rax),%rcx Decoded ok: 67 f2 0f 38 f8 18 enqcmd (%eax),%ebx Decoded ok: 67 f2 0f 38 f8 88 78 56 34 12 enqcmd 0x12345678(%eax),%ecx Decoded ok: f3 0f 38 f8 18 enqcmds (%rax),%rbx Decoded ok: f3 0f 38 f8 88 78 56 34 12 enqcmds 0x12345678(%rax),%rcx Decoded ok: 67 f3 0f 38 f8 18 enqcmds (%eax),%ebx Decoded ok: 67 f3 0f 38 f8 88 78 56 34 12 enqcmds 0x12345678(%eax),%ecx $ perf test -v "new " 2>&1 | grep -i enqcmds Decoded ok: f3 0f 38 f8 18 enqcmds (%eax),%ebx Decoded ok: f3 0f 38 f8 88 78 56 34 12 enqcmds 0x12345678(%eax),%ecx Decoded ok: 67 f3 0f 38 f8 1c enqcmds (%si),%bx Decoded ok: 67 f3 0f 38 f8 8c 34 12 enqcmds 0x1234(%si),%cx Decoded ok: f3 0f 38 f8 18 enqcmds (%rax),%rbx Decoded ok: f3 0f 38 f8 88 78 56 34 12 enqcmds 0x12345678(%rax),%rcx Decoded ok: 67 f3 0f 38 f8 18 enqcmds (%eax),%ebx Decoded ok: 67 f3 0f 38 f8 88 78 56 34 12 enqcmds 0x12345678(%eax),%ecx $ perf test -v "new " 2>&1 | grep -i encls Decoded ok: 0f 01 cf encls Decoded ok: 0f 01 cf encls $ perf test -v "new " 2>&1 | grep -i enclu Decoded ok: 0f 01 d7 enclu Decoded ok: 0f 01 d7 enclu $ perf test -v "new " 2>&1 | grep -i enclv Decoded ok: 0f 01 c0 enclv Decoded ok: 0f 01 c0 enclv $ perf test -v "new " 2>&1 | grep -i pconfig Decoded ok: 0f 01 c5 pconfig Decoded ok: 0f 01 c5 pconfig $ perf test -v "new " 2>&1 | grep -i wbnoinvd Decoded ok: f3 0f 09 wbnoinvd Decoded ok: f3 0f 09 wbnoinvd Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Reviewed-by: Andi Kleen <ak@linux.intel.com> Acked-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: x86@kernel.org Link: http://lore.kernel.org/lkml/20191115135447.6519-3-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04perf probe: Filter out instances except for inlined subroutine and subprogramMasami Hiramatsu
[ Upstream commit da6cb952a89efe24bb76c4971370d485737a2d85 ] Filter out instances except for inlined_subroutine and subprogram DIE in die_walk_instances() and die_is_func_instance(). This fixes an issue that perf probe sets some probes on calling address instead of a target function itself. When perf probe walks on instances of an abstruct origin (a kind of function prototype of inlined function), die_walk_instances() can also pass a GNU_call_site (a GNU extension for call site) to callback. Since it is not an inlined instance of target function, we have to filter out when searching a probe point. Without this patch, perf probe sets probes on call site address too.This can happen on some function which is marked "inlined", but has actual symbol. (I'm not sure why GCC mark it "inlined"): # perf probe -D vfs_read p:probe/vfs_read _text+2500017 p:probe/vfs_read_1 _text+2499468 p:probe/vfs_read_2 _text+2499563 p:probe/vfs_read_3 _text+2498876 p:probe/vfs_read_4 _text+2498512 p:probe/vfs_read_5 _text+2498627 With this patch: Slightly different results, similar tho: # perf probe -D vfs_read p:probe/vfs_read _text+2498512 Committer testing: # uname -a Linux quaco 5.3.8-200.fc30.x86_64 #1 SMP Tue Oct 29 14:46:22 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux Before: # perf probe -D vfs_read p:probe/vfs_read _text+3131557 p:probe/vfs_read_1 _text+3130975 p:probe/vfs_read_2 _text+3131047 p:probe/vfs_read_3 _text+3130380 p:probe/vfs_read_4 _text+3130000 # uname -a Linux quaco 5.3.8-200.fc30.x86_64 #1 SMP Tue Oct 29 14:46:22 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux # After: # perf probe -D vfs_read p:probe/vfs_read _text+3130000 # Fixes: db0d2c6420ee ("perf probe: Search concrete out-of-line instances") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157241937063.32002.11024544873990816590.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04perf probe: Skip end-of-sequence and non statement linesMasami Hiramatsu
[ Upstream commit f4d99bdfd124823a81878b44b5e8750b97f73902 ] Skip end-of-sequence and non-statement lines while walking through lines list. The "end-of-sequence" line information means: "the current address is that of the first byte after the end of a sequence of target machine instructions." (DWARF version 4 spec 6.2.2) This actually means out of scope and we can not probe on it. On the other hand, the statement lines (is_stmt) means: "the current instruction is a recommended breakpoint location. A recommended breakpoint location is intended to “represent” a line, a statement and/or a semantically distinct subpart of a statement." (DWARF version 4 spec 6.2.2) So, non-statement line info also should be skipped. These can reduce unneeded probe points and also avoid an error. E.g. without this patch: # perf probe -a "clear_tasks_mm_cpumask:1" Added new events: probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask:1) probe:clear_tasks_mm_cpumask_1 (on clear_tasks_mm_cpumask:1) probe:clear_tasks_mm_cpumask_2 (on clear_tasks_mm_cpumask:1) probe:clear_tasks_mm_cpumask_3 (on clear_tasks_mm_cpumask:1) probe:clear_tasks_mm_cpumask_4 (on clear_tasks_mm_cpumask:1) You can now use it in all perf tools, such as: perf record -e probe:clear_tasks_mm_cpumask_4 -aR sleep 1 # This puts 5 probes on one line, but acutally it's not inlined function. This is because there are many non statement instructions at the function prologue. With this patch: # perf probe -a "clear_tasks_mm_cpumask:1" Added new event: probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask:1) You can now use it in all perf tools, such as: perf record -e probe:clear_tasks_mm_cpumask -aR sleep 1 # Now perf-probe skips unneeded addresses. Committer testing: Slightly different results, but similar: Before: # uname -a Linux quaco 5.3.8-200.fc30.x86_64 #1 SMP Tue Oct 29 14:46:22 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux # # perf probe -a "clear_tasks_mm_cpumask:1" Added new events: probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask:1) probe:clear_tasks_mm_cpumask_1 (on clear_tasks_mm_cpumask:1) probe:clear_tasks_mm_cpumask_2 (on clear_tasks_mm_cpumask:1) You can now use it in all perf tools, such as: perf record -e probe:clear_tasks_mm_cpumask_2 -aR sleep 1 # After: # perf probe -a "clear_tasks_mm_cpumask:1" Added new event: probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask:1) You can now use it in all perf tools, such as: perf record -e probe:clear_tasks_mm_cpumask -aR sleep 1 # perf probe -l probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask@kernel/cpu.c) # Fixes: 4cc9cec636e7 ("perf probe: Introduce lines walker interface") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157241936090.32002.12156347518596111660.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04perf probe: Fix to show calling lines of inlined functionsMasami Hiramatsu
[ Upstream commit 86c0bf8539e7f46d91bd105e55eda96e0064caef ] Fix to show calling lines of inlined functions (where an inline function is called). die_walk_lines() filtered out the lines inside inlined functions based on the address. However this also filtered out the lines which call those inlined functions from the target function. To solve this issue, check the call_file and call_line attributes and do not filter out if it matches to the line information. Without this fix, perf probe -L doesn't show some lines correctly. (don't see the lines after 17) # perf probe -L vfs_read <vfs_read@/home/mhiramat/ksrc/linux/fs/read_write.c:0> 0 ssize_t vfs_read(struct file *file, char __user *buf, size_t count, loff_t *pos) 1 { 2 ssize_t ret; 4 if (!(file->f_mode & FMODE_READ)) return -EBADF; 6 if (!(file->f_mode & FMODE_CAN_READ)) return -EINVAL; 8 if (unlikely(!access_ok(buf, count))) return -EFAULT; 11 ret = rw_verify_area(READ, file, pos, count); 12 if (!ret) { 13 if (count > MAX_RW_COUNT) count = MAX_RW_COUNT; 15 ret = __vfs_read(file, buf, count, pos); 16 if (ret > 0) { fsnotify_access(file); add_rchar(current, ret); } With this fix: # perf probe -L vfs_read <vfs_read@/home/mhiramat/ksrc/linux/fs/read_write.c:0> 0 ssize_t vfs_read(struct file *file, char __user *buf, size_t count, loff_t *pos) 1 { 2 ssize_t ret; 4 if (!(file->f_mode & FMODE_READ)) return -EBADF; 6 if (!(file->f_mode & FMODE_CAN_READ)) return -EINVAL; 8 if (unlikely(!access_ok(buf, count))) return -EFAULT; 11 ret = rw_verify_area(READ, file, pos, count); 12 if (!ret) { 13 if (count > MAX_RW_COUNT) count = MAX_RW_COUNT; 15 ret = __vfs_read(file, buf, count, pos); 16 if (ret > 0) { 17 fsnotify_access(file); 18 add_rchar(current, ret); } 20 inc_syscr(current); } Fixes: 4cc9cec636e7 ("perf probe: Introduce lines walker interface") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157241937995.32002.17899884017011512577.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04perf probe: Return a better scope DIE if there is no best scopeMasami Hiramatsu
[ Upstream commit c701636aeec4c173208697d68da6e4271125564b ] Make find_best_scope() returns innermost DIE at given address if there is no best matched scope DIE. Since Gcc sometimes generates intuitively strange line info which is out of inlined function address range, we need this fixup. Without this, sometimes perf probe failed to probe on a line inside an inlined function: # perf probe -D ksys_open:3 Failed to find scope of probe point. Error: Failed to add events. With this fix, 'perf probe' can probe it: # perf probe -D ksys_open:3 p:probe/ksys_open _text+25707308 p:probe/ksys_open_1 _text+25710596 p:probe/ksys_open_2 _text+25711114 p:probe/ksys_open_3 _text+25711343 p:probe/ksys_open_4 _text+25714058 p:probe/ksys_open_5 _text+2819653 p:probe/ksys_open_6 _text+2819701 Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Ravi Bangoria <ravi.bangoria@linux.ibm.com> Cc: Steven Rostedt (VMware) <rostedt@goodmis.org> Cc: Tom Zanussi <tom.zanussi@linux.intel.com> Link: http://lore.kernel.org/lkml/157291300887.19771.14936015360963292236.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04perf probe: Skip overlapped location on searching variablesMasami Hiramatsu
[ Upstream commit dee36a2abb67c175265d49b9a8c7dfa564463d9a ] Since debuginfo__find_probes() callback function can be called with the location which already passed, the callback function must filter out such overlapped locations. add_probe_trace_event() has already done it by commit 1a375ae7659a ("perf probe: Skip same probe address for a given line"), but add_available_vars() doesn't. Thus perf probe -v shows same address repeatedly as below: # perf probe -V vfs_read:18 Available variables at vfs_read:18 @<vfs_read+217> char* buf loff_t* pos ssize_t ret struct file* file @<vfs_read+217> char* buf loff_t* pos ssize_t ret struct file* file @<vfs_read+226> char* buf loff_t* pos ssize_t ret struct file* file With this fix, perf probe -V shows it correctly: # perf probe -V vfs_read:18 Available variables at vfs_read:18 @<vfs_read+217> char* buf loff_t* pos ssize_t ret struct file* file @<vfs_read+226> char* buf loff_t* pos ssize_t ret struct file* file Fixes: cf6eb489e5c0 ("perf probe: Show accessible local variables") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157241938927.32002.4026859017790562751.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04perf probe: Fix to probe a function which has no entry pcMasami Hiramatsu
[ Upstream commit 5d16dbcc311d91267ddb45c6da4f187be320ecee ] Fix 'perf probe' to probe a function which has no entry pc or low pc but only has ranges attribute. probe_point_search_cb() uses dwarf_entrypc() to get the probe address, but that doesn't work for the function DIE which has only ranges attribute. Use die_entrypc() instead. Without this fix: # perf probe -k ../build-x86_64/vmlinux -D clear_tasks_mm_cpumask:0 Probe point 'clear_tasks_mm_cpumask' not found. Error: Failed to add events. With this: # perf probe -k ../build-x86_64/vmlinux -D clear_tasks_mm_cpumask:0 p:probe/clear_tasks_mm_cpumask clear_tasks_mm_cpumask+0 Committer testing: Before: [root@quaco ~]# perf probe clear_tasks_mm_cpumask:0 Probe point 'clear_tasks_mm_cpumask' not found. Error: Failed to add events. [root@quaco ~]# After: [root@quaco ~]# perf probe clear_tasks_mm_cpumask:0 Added new event: probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask) You can now use it in all perf tools, such as: perf record -e probe:clear_tasks_mm_cpumask -aR sleep 1 [root@quaco ~]# Using it with 'perf trace': [root@quaco ~]# perf trace -e probe:clear_tasks_mm_cpumask Doesn't seem to be used in x86_64: $ find . -name "*.c" | xargs grep clear_tasks_mm_cpumask ./kernel/cpu.c: * clear_tasks_mm_cpumask - Safely clear tasks' mm_cpumask for a CPU ./kernel/cpu.c:void clear_tasks_mm_cpumask(int cpu) ./arch/xtensa/kernel/smp.c: clear_tasks_mm_cpumask(cpu); ./arch/csky/kernel/smp.c: clear_tasks_mm_cpumask(cpu); ./arch/sh/kernel/smp.c: clear_tasks_mm_cpumask(cpu); ./arch/arm/kernel/smp.c: clear_tasks_mm_cpumask(cpu); ./arch/powerpc/mm/nohash/mmu_context.c: clear_tasks_mm_cpumask(cpu); $ find . -name "*.h" | xargs grep clear_tasks_mm_cpumask ./include/linux/cpu.h:void clear_tasks_mm_cpumask(int cpu); $ find . -name "*.S" | xargs grep clear_tasks_mm_cpumask $ Fixes: e1ecbbc3fa83 ("perf probe: Fix to handle optimized not-inlined functions") Reported-by: Arnaldo Carvalho de Melo <acme@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157199319438.8075.4695576954550638618.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04perf probe: Fix to show inlined function callsite without entry_pcMasami Hiramatsu
[ Upstream commit 18e21eb671dc87a4f0546ba505a89ea93598a634 ] Fix 'perf probe --line' option to show inlined function callsite lines even if the function DIE has only ranges. Without this: # perf probe -L amd_put_event_constraints ... 2 { 3 if (amd_has_nb(cpuc) && amd_is_nb_event(&event->hw)) __amd_put_nb_event_constraints(cpuc, event); 5 } With this patch: # perf probe -L amd_put_event_constraints ... 2 { 3 if (amd_has_nb(cpuc) && amd_is_nb_event(&event->hw)) 4 __amd_put_nb_event_constraints(cpuc, event); 5 } Committer testing: Before: [root@quaco ~]# perf probe -L amd_put_event_constraints <amd_put_event_constraints@/usr/src/debug/kernel-5.2.fc30/linux-5.2.18-200.fc30.x86_64/arch/x86/events/amd/core.c:0> 0 static void amd_put_event_constraints(struct cpu_hw_events *cpuc, struct perf_event *event) 2 { 3 if (amd_has_nb(cpuc) && amd_is_nb_event(&event->hw)) __amd_put_nb_event_constraints(cpuc, event); 5 } PMU_FORMAT_ATTR(event, "config:0-7,32-35"); PMU_FORMAT_ATTR(umask, "config:8-15" ); [root@quaco ~]# After: [root@quaco ~]# perf probe -L amd_put_event_constraints <amd_put_event_constraints@/usr/src/debug/kernel-5.2.fc30/linux-5.2.18-200.fc30.x86_64/arch/x86/events/amd/core.c:0> 0 static void amd_put_event_constraints(struct cpu_hw_events *cpuc, struct perf_event *event) 2 { 3 if (amd_has_nb(cpuc) && amd_is_nb_event(&event->hw)) 4 __amd_put_nb_event_constraints(cpuc, event); 5 } PMU_FORMAT_ATTR(event, "config:0-7,32-35"); PMU_FORMAT_ATTR(umask, "config:8-15" ); [root@quaco ~]# perf probe amd_put_event_constraints:4 Added new event: probe:amd_put_event_constraints (on amd_put_event_constraints:4) You can now use it in all perf tools, such as: perf record -e probe:amd_put_event_constraints -aR sleep 1 [root@quaco ~]# [root@quaco ~]# perf probe -l probe:amd_put_event_constraints (on amd_put_event_constraints:4@arch/x86/events/amd/core.c) probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask@kernel/cpu.c) [root@quaco ~]# Using it: [root@quaco ~]# perf trace -e probe:* ^C[root@quaco ~]# Ok, Intel system here... :-) Fixes: 4cc9cec636e7 ("perf probe: Introduce lines walker interface") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157199322107.8075.12659099000567865708.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04perf probe: Fix to show ranges of variables in functions without entry_pcMasami Hiramatsu
[ Upstream commit af04dd2f8ebaa8fbd46f698714acbf43da14da45 ] Fix to show ranges of variables (--range and --vars option) in functions which DIE has only ranges but no entry_pc attribute. Without this fix: # perf probe --range -V clear_tasks_mm_cpumask Available variables at clear_tasks_mm_cpumask @<clear_tasks_mm_cpumask+0> (No matched variables) With this fix: # perf probe --range -V clear_tasks_mm_cpumask Available variables at clear_tasks_mm_cpumask @<clear_tasks_mm_cpumask+0> [VAL] int cpu @<clear_tasks_mm_cpumask+[0-35,317-317,2052-2059]> Committer testing: Before: [root@quaco ~]# perf probe --range -V clear_tasks_mm_cpumask Available variables at clear_tasks_mm_cpumask @<clear_tasks_mm_cpumask+0> (No matched variables) [root@quaco ~]# After: [root@quaco ~]# perf probe --range -V clear_tasks_mm_cpumask Available variables at clear_tasks_mm_cpumask @<clear_tasks_mm_cpumask+0> [VAL] int cpu @<clear_tasks_mm_cpumask+[0-23,23-105,105-106,106-106,1843-1850,1850-1862]> [root@quaco ~]# Using it: [root@quaco ~]# perf probe clear_tasks_mm_cpumask cpu Added new event: probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask with cpu) You can now use it in all perf tools, such as: perf record -e probe:clear_tasks_mm_cpumask -aR sleep 1 [root@quaco ~]# perf probe -l probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask@kernel/cpu.c with cpu) [root@quaco ~]# [root@quaco ~]# perf trace -e probe:*cpumask ^C[root@quaco ~]# Fixes: 349e8d261131 ("perf probe: Add --range option to show a variable's location range") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157199323018.8075.8179744380479673672.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04perf probe: Fix to probe an inline function which has no entry pcMasami Hiramatsu
[ Upstream commit eb6933b29d20bf2c3053883d409a53f462c1a3ac ] Fix perf probe to probe an inlne function which has no entry pc or low pc but only has ranges attribute. This seems very rare case, but I could find a few examples, as same as probe_point_search_cb(), use die_entrypc() to get the entry address in probe_point_inline_cb() too. Without this patch: # perf probe -D __amd_put_nb_event_constraints Failed to get entry address of __amd_put_nb_event_constraints. Probe point '__amd_put_nb_event_constraints' not found. Error: Failed to add events. With this patch: # perf probe -D __amd_put_nb_event_constraints p:probe/__amd_put_nb_event_constraints amd_put_event_constraints+43 Committer testing: Before: [root@quaco ~]# perf probe -D __amd_put_nb_event_constraints Failed to get entry address of __amd_put_nb_event_constraints. Probe point '__amd_put_nb_event_constraints' not found. Error: Failed to add events. [root@quaco ~]# After: [root@quaco ~]# perf probe -D __amd_put_nb_event_constraints p:probe/__amd_put_nb_event_constraints _text+33789 [root@quaco ~]# Fixes: 4ea42b181434 ("perf: Add perf probe subcommand, a kprobe-event setup helper") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157199320336.8075.16189530425277588587.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04perf probe: Walk function lines in lexical blocksMasami Hiramatsu
[ Upstream commit acb6a7047ac2146b723fef69ee1ab6b7143546bf ] Since some inlined functions are in lexical blocks of given function, we have to recursively walk through the DIE tree. Without this fix, perf-probe -L can miss the inlined functions which is in a lexical block (like if (..) { func() } case.) However, even though, to walk the lines in a given function, we don't need to follow the children DIE of inlined functions because those do not have any lines in the specified function. We need to walk though whole trees only if we walk all lines in a given file, because an inlined function can include another inlined function in the same file. Fixes: b0e9cb2802d4 ("perf probe: Fix to search nested inlined functions in CU") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157190836514.1859.15996864849678136353.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04perf probe: Fix to list probe event with correct line numberMasami Hiramatsu
[ Upstream commit 3895534dd78f0fd4d3f9e05ee52b9cdd444a743e ] Since debuginfo__find_probe_point() uses dwarf_entrypc() for finding the entry address of the function on which a probe is, it will fail when the function DIE has only ranges attribute. To fix this issue, use die_entrypc() instead of dwarf_entrypc(). Without this fix, perf probe -l shows incorrect offset: # perf probe -l probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask+18446744071579263632@work/linux/linux/kernel/cpu.c) probe:clear_tasks_mm_cpumask_1 (on clear_tasks_mm_cpumask+18446744071579263752@work/linux/linux/kernel/cpu.c) With this: # perf probe -l probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask@work/linux/linux/kernel/cpu.c) probe:clear_tasks_mm_cpumask_1 (on clear_tasks_mm_cpumask:21@work/linux/linux/kernel/cpu.c) Committer testing: Before: [root@quaco ~]# perf probe -l probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask+18446744071579765152@kernel/cpu.c) [root@quaco ~]# After: [root@quaco ~]# perf probe -l probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask@kernel/cpu.c) [root@quaco ~]# Fixes: 1d46ea2a6a40 ("perf probe: Fix listing incorrect line number with inline function") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157199321227.8075.14655572419136993015.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04perf probe: Fix to find range-only function instanceMasami Hiramatsu
[ Upstream commit b77afa1f810f37bd8a36cb1318178dfe2d7af6b6 ] Fix die_is_func_instance() to find range-only function instance. In some case, a function instance can be made without any low PC or entry PC, but only with address ranges by optimization. (e.g. cold text partially in "text.unlikely" section) To find such function instance, we have to check the range attribute too. Fixes: e1ecbbc3fa83 ("perf probe: Fix to handle optimized not-inlined functions") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157190835669.1859.8368628035930950596.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04perf report: Add warning when libunwind not compiled inJin Yao
[ Upstream commit 800d3f561659b5436f8c57e7c26dd1f6928b5615 ] We received a user report that call-graph DWARF mode was enabled in 'perf record' but 'perf report' didn't unwind the callstack correctly. The reason was, libunwind was not compiled in. We can use 'perf -vv' to check the compiled libraries but it would be valuable to report a warning to user directly (especially valuable for a perf newbie). The warning is: Warning: Please install libunwind development packages during the perf build. Both TUI and stdio are supported. Signed-off-by: Jin Yao <yao.jin@linux.intel.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lore.kernel.org/lkml/20191011022122.26369-1-yao.jin@linux.intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04perf test: Report failure for mmap eventsLeo Yan
[ Upstream commit 6add129c5d9210ada25217abc130df0b7096ee02 ] When fail to mmap events in task exit case, it misses to set 'err' to -1; thus the testing will not report failure for it. This patch sets 'err' to -1 when fails to mmap events, thus Perf tool can report correct result. Fixes: d723a55096b8 ("perf test: Add test case for checking number of EXIT events") Signed-off-by: Leo Yan <leo.yan@linaro.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/20191011091942.29841-1-leo.yan@linaro.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04tools/power/cpupower: Fix initializer override in hsw_ext_cstatesNathan Chancellor
[ Upstream commit 7e5705c635ecfccde559ebbbe1eaf05b5cc60529 ] When building cpupower with clang, the following warning appears: utils/idle_monitor/hsw_ext_idle.c:42:16: warning: initializer overrides prior initialization of this subobject [-Winitializer-overrides] .desc = N_("Processor Package C2"), ^~~~~~~~~~~~~~~~~~~~~~ ./utils/helpers/helpers.h:25:33: note: expanded from macro 'N_' #define N_(String) gettext_noop(String) ^~~~~~ ./utils/helpers/helpers.h:23:30: note: expanded from macro 'gettext_noop' #define gettext_noop(String) String ^~~~~~ utils/idle_monitor/hsw_ext_idle.c:41:16: note: previous initialization is here .desc = N_("Processor Package C9"), ^~~~~~~~~~~~~~~~~~~~~~ ./utils/helpers/helpers.h:25:33: note: expanded from macro 'N_' #define N_(String) gettext_noop(String) ^~~~~~ ./utils/helpers/helpers.h:23:30: note: expanded from macro 'gettext_noop' #define gettext_noop(String) String ^~~~~~ 1 warning generated. This appears to be a copy and paste or merge mistake because the name and id fields both have PC9 in them, not PC2. Remove the second assignment to fix the warning. Fixes: 7ee767b69b68 ("cpupower: Add Haswell family 0x45 specific idle monitor to show PC8,9,10 states") Link: https://github.com/ClangBuiltLinux/linux/issues/718 Signed-off-by: Nathan Chancellor <natechancellor@gmail.com> Signed-off-by: Shuah Khan <skhan@linuxfoundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-11-28usbip: tools: fix fd leakage in the function of read_attr_usbip_statusHewenliang
commit 26a4d4c00f85cb844dd11dd35e848b079c2f5e8f upstream. We should close the fd before the return of read_attr_usbip_status. Fixes: 3391ba0e2792 ("usbip: tools: Extract generic code to be shared with vudc backend") Signed-off-by: Hewenliang <hewenliang4@huawei.com> Cc: stable <stable@vger.kernel.org> Link: https://lore.kernel.org/r/20191025043515.20053-1-hewenliang4@huawei.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-28x86/insn: Fix awk regexp warningsAlexander Kapshuk
commit 700c1018b86d0d4b3f1f2d459708c0cdf42b521d upstream. gawk 5.0.1 generates the following regexp warnings: GEN /home/sasha/torvalds/tools/objtool/arch/x86/lib/inat-tables.c awk: ../arch/x86/tools/gen-insn-attr-x86.awk:260: warning: regexp escape sequence `\:' is not a known regexp operator awk: ../arch/x86/tools/gen-insn-attr-x86.awk:350: (FILENAME=../arch/x86/lib/x86-opcode-map.txt FNR=41) warning: regexp escape sequence `\&' is not a known regexp operator Ealier versions of gawk are not known to generate these warnings. The gawk manual referenced below does not list characters ':' and '&' as needing escaping, so 'unescape' them. See https://www.gnu.org/software/gawk/manual/html_node/Escape-Sequences.html for more info. Running diff on the output generated by the script before and after applying the patch reported no differences. [ bp: Massage commit message. ] [ Caught the respective tools header discrepancy. ] Reported-by: kbuild test robot <lkp@intel.com> Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Peter Zijlstra (Intel)" <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: x86-ml <x86@kernel.org> Link: https://lkml.kernel.org/r/20190924044659.3785-1-alexander.kapshuk@gmail.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-28ACPICA: Use %d for signed int print formatting instead of %uColin Ian King
[ Upstream commit f8ddf49b420112e28bdd23d7ad52d7991a0ccbe3 ] Fix warnings found using static analysis with cppcheck, use %d printf format specifier for signed ints rather than %u Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Erik Schmauss <erik.schmauss@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-11-28selftests/ftrace: Fix to test kprobe $comm arg only if availableMasami Hiramatsu
[ Upstream commit 2452c96e617a0ff6fb2692e55217a3fa57a7322c ] Test $comm in kprobe-event argument syntax testcase only if it is supported on the kernel because $comm has been introduced 4.8 kernel. So on older stable kernel, it should be skipped. Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Shuah Khan (Samsung OSG) <shuah@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-11-28usbip: tools: fix atoi() on non-null terminated stringColin Ian King
[ Upstream commit e325808c0051b16729ffd472ff887c6cae5c6317 ] Currently the call to atoi is being passed a single char string that is not null terminated, so there is a potential read overrun along the stack when parsing for an integer value. Fix this by instead using a 2 char string that is initialized to all zeros to ensure that a 1 char read into the string is always terminated with a \0. Detected by cppcheck: "Invalid atoi() argument nr 1. A nul-terminated string is required." Fixes: 3391ba0e2792 ("usbip: tools: Extract generic code to be shared with vudc backend") Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-11-28tools: gpio: Correctly add make dependencies for gpio_utilsLaura Abbott
commit 0161a94e2d1c713bd34d72bc0239d87c31747bf7 upstream. gpio tools fail to build correctly with make parallelization: $ make -s -j24 ld: gpio-utils.o: file not recognized: file truncated make[1]: *** [/home/labbott/linux_upstream/tools/build/Makefile.build:145: lsgpio-in.o] Error 1 make: *** [Makefile:43: lsgpio-in.o] Error 2 make: *** Waiting for unfinished jobs.... This is because gpio-utils.o is used across multiple targets. Fix this by making gpio-utios.o a proper dependency. Cc: <stable@vger.kernel.org> Signed-off-by: Laura Abbott <labbott@redhat.com> Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-12perf tools: Fix time sortingJiri Olsa
commit 722ddfde366fd46205456a9c5ff9b3359dc9a75e upstream. The final sort might get confused when the comparison is done over bigger numbers than int like for -s time. Check the following report for longer workloads: $ perf report -s time -F time,overhead --stdio Fix hist_entry__sort() to properly return int64_t and not possible cut int. Fixes: 043ca389a318 ("perf tools: Use hpp formats to sort final output") Signed-off-by: Jiri Olsa <jolsa@kernel.org> Reviewed-by: Andi Kleen <ak@linux.intel.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Michael Petlan <mpetlan@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: stable@vger.kernel.org # v3.16+ Link: http://lore.kernel.org/lkml/20191104232711.16055-1-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-10selftests: net: reuseport_dualstack: fix uninitalized parameterWei Wang
[ Upstream commit d64479a3e3f9924074ca7b50bd72fa5211dca9c1 ] This test reports EINVAL for getsockopt(SOL_SOCKET, SO_DOMAIN) occasionally due to the uninitialized length parameter. Initialize it to fix this, and also use int for "test_family" to comply with the API standard. Fixes: d6a61f80b871 ("soreuseport: test mixed v4/v6 sockets") Reported-by: Maciej Żenczykowski <maze@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Wei Wang <weiwan@google.com> Cc: Craig Gallek <cgallek@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-10perf kmem: Fix memory leak in compact_gfp_flags()Yunfeng Ye
[ Upstream commit 1abecfcaa7bba21c9985e0136fa49836164dd8fd ] The memory @orig_flags is allocated by strdup(), it is freed on the normal path, but leak to free on the error path. Fix this by adding free(orig_flags) on the error path. Fixes: 0e11115644b3 ("perf kmem: Print gfp flags in human readable string") Signed-off-by: Yunfeng Ye <yeyunfeng@huawei.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Feilong Lin <linfeilong@huawei.com> Cc: Hu Shiyuan <hushiyuan@huawei.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lore.kernel.org/lkml/f9e9f458-96f3-4a97-a1d5-9feec2420e07@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-11-06perf jevents: Fix period for Intel fixed countersAndi Kleen
[ Upstream commit 6bdfd9f118bd59cf0f85d3bf4b72b586adea17c1 ] The Intel fixed counters use a special table to override the JSON information. During this override the period information from the JSON file got dropped, which results in inst_retired.any and similar running with frequency mode instead of a period. Just specify the expected period in the table. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Jiri Olsa <jolsa@kernel.org> Link: http://lore.kernel.org/lkml/20190927233546.11533-2-andi@firstfloor.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-11-06perf map: Fix overlapped map handlingSteve MacLean
[ Upstream commit ee212d6ea20887c0ef352be8563ca13dbf965906 ] Whenever an mmap/mmap2 event occurs, the map tree must be updated to add a new entry. If a new map overlaps a previous map, the overlapped section of the previous map is effectively unmapped, but the non-overlapping sections are still valid. maps__fixup_overlappings() is responsible for creating any new map entries from the previously overlapped map. It optionally creates a before and an after map. When creating the after map the existing code failed to adjust the map.pgoff. This meant the new after map would incorrectly calculate the file offset for the ip. This results in incorrect symbol name resolution for any ip in the after region. Make maps__fixup_overlappings() correctly populate map.pgoff. Add an assert that new mapping matches old mapping at the beginning of the after map. Committer-testing: Validated correct parsing of libcoreclr.so symbols from .NET Core 3.0 preview9 (which didn't strip symbols). Preparation: ~/dotnet3.0-preview9/dotnet new webapi -o perfSymbol cd perfSymbol ~/dotnet3.0-preview9/dotnet publish perf record ~/dotnet3.0-preview9/dotnet \ bin/Debug/netcoreapp3.0/publish/perfSymbol.dll ^C Before: perf script --show-mmap-events 2>&1 | grep -e MMAP -e unknown |\ grep libcoreclr.so | head -n 4 dotnet 1907 373352.698780: PERF_RECORD_MMAP2 1907/1907: \ [0x7fe615726000(0x768000) @ 0 08:02 5510620 765057155]: \ r-xp .../3.0.0-preview9-19423-09/libcoreclr.so dotnet 1907 373352.701091: PERF_RECORD_MMAP2 1907/1907: \ [0x7fe615974000(0x1000) @ 0x24e000 08:02 5510620 765057155]: \ rwxp .../3.0.0-preview9-19423-09/libcoreclr.so dotnet 1907 373352.701241: PERF_RECORD_MMAP2 1907/1907: \ [0x7fe615c42000(0x1000) @ 0x51c000 08:02 5510620 765057155]: \ rwxp .../3.0.0-preview9-19423-09/libcoreclr.so dotnet 1907 373352.705249: 250000 cpu-clock: \ 7fe6159a1f99 [unknown] \ (.../3.0.0-preview9-19423-09/libcoreclr.so) After: perf script --show-mmap-events 2>&1 | grep -e MMAP -e unknown |\ grep libcoreclr.so | head -n 4 dotnet 1907 373352.698780: PERF_RECORD_MMAP2 1907/1907: \ [0x7fe615726000(0x768000) @ 0 08:02 5510620 765057155]: \ r-xp .../3.0.0-preview9-19423-09/libcoreclr.so dotnet 1907 373352.701091: PERF_RECORD_MMAP2 1907/1907: \ [0x7fe615974000(0x1000) @ 0x24e000 08:02 5510620 765057155]: \ rwxp .../3.0.0-preview9-19423-09/libcoreclr.so dotnet 1907 373352.701241: PERF_RECORD_MMAP2 1907/1907: \ [0x7fe615c42000(0x1000) @ 0x51c000 08:02 5510620 765057155]: \ rwxp .../3.0.0-preview9-19423-09/libcoreclr.so All the [unknown] symbols were resolved. Signed-off-by: Steve MacLean <Steve.MacLean@Microsoft.com> Tested-by: Brian Robbins <brianrob@microsoft.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Eric Saint-Etienne <eric.saint.etienne@oracle.com> Cc: John Keeping <john@metanate.com> Cc: John Salem <josalem@microsoft.com> Cc: Leo Yan <leo.yan@linaro.org> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Song Liu <songliubraving@fb.com> Cc: Stephane Eranian <eranian@google.com> Cc: Tom McDonald <thomas.mcdonald@microsoft.com> Link: http://lore.kernel.org/lkml/BN8PR21MB136270949F22A6A02335C238F7800@BN8PR21MB1362.namprd21.prod.outlook.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
