commit ba4aa02b417f08a0bee5e7b8ed70cac788a7c854 upstream.
So that we reduce the difference of tools/include/linux/bitops.h to the
original kernel file, include/linux/bitops.h, trying to remove the need
to define BITS_PER_LONG, to avoid clashes with asm/bitsperlong.h.
And the things removed from tools/include/linux/bitops.h are really in
linux/bits.h, so that we can have a copy and then
tools/perf/check_headers.sh will tell us when new stuff gets added to
linux/bits.h so that we can check if it is useful and if any adjustment
needs to be done to the tools/{include,arch}/ copies.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Alexander Sverdlin <alexander.sverdlin@nokia.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Wang Nan <wangnan0@huawei.com>
Link: https://lkml.kernel.org/n/tip-y1sqyydvfzo0bjjoj4zsl562@git.kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
The changes to fix the CVE 2019-7308 make the bpf verifier stricter
with respect to operations that were allowed earlier in unprivileged
mode. Fixup the test cases so that the error messages now correctly
reflect pointer arithmetic going out of range for tests.
Signed-off-by: Balbir Singh <sblbir@amzn.com>
[ Upstream commit e0a2e73e501c77037c8756137e87b12c7c3c9793 ]
Without this usbip fails on a machine with devices
that lexicographically come after vhci_hcd.
ie.
$ ls -l /sys/devices/platform
drwxr-xr-x. 4 root root 0 Sep 19 16:21 serial8250
-rw-r--r--. 1 root root 4096 Sep 19 23:50 uevent
drwxr-xr-x. 6 root root 0 Sep 20 13:15 vhci_hcd.0
drwxr-xr-x. 4 root root 0 Sep 19 16:22 w83627hf.656
Because it detects 'w83627hf.656' as another vhci_hcd controller,
and then fails to be able to talk to it.
Note: this doesn't actually fix usbip's support for multiple
controllers... that's still broken for other reasons
("vhci_hcd.0" is hardcoded in a string macro), but is enough to
actually make it work on the above machine.
See also:
https://bugzilla.redhat.com/show_bug.cgi?id=1631148
Cc: Jonathan Dieter <jdieter@gmail.com>
Cc: Valentina Manea <valentina.manea.m@gmail.com>
Cc: Shuah Khan <shuah@kernel.org>
Cc: linux-usb@vger.kernel.org
Signed-off-by: Maciej Żenczykowski <zenczykowski@gmail.com>
Acked-by: Shuah Khan (Samsung OSG) <shuah@kernel.org>
Tested-by: Jonathan Dieter <jdieter@gmail.com>
[ Upstream commit d982b33133284fa7efa0e52ae06b88f9be3ea764 ]
==20875==ERROR: LeakSanitizer: detected memory leaks
Direct leak of 1160 byte(s) in 1 object(s) allocated from:
#0 0x7f1b6fc84138 in calloc (/usr/lib/x86_64-linux-gnu/libasan.so.5+0xee138)
#1 0x55bd50005599 in zalloc util/util.h:23
#2 0x55bd500068f5 in perf_evsel__newtp_idx util/evsel.c:327
#3 0x55bd4ff810fc in perf_evsel__newtp /home/work/linux/tools/perf/util/evsel.h:216
#4 0x55bd4ff81608 in test__perf_evsel__tp_sched_test tests/evsel-tp-sched.c:69
#5 0x55bd4ff528e6 in run_test tests/builtin-test.c:358
#6 0x55bd4ff52baf in test_and_print tests/builtin-test.c:388
#7 0x55bd4ff543fe in __cmd_test tests/builtin-test.c:583
#8 0x55bd4ff5572f in cmd_test tests/builtin-test.c:722
#9 0x55bd4ffc4087 in run_builtin /home/changbin/work/linux/tools/perf/perf.c:302
#10 0x55bd4ffc45c6 in handle_internal_command /home/changbin/work/linux/tools/perf/perf.c:354
#11 0x55bd4ffc49ca in run_argv /home/changbin/work/linux/tools/perf/perf.c:398
#12 0x55bd4ffc5138 in main /home/changbin/work/linux/tools/perf/perf.c:520
#13 0x7f1b6e34809a in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2409a)
Indirect leak of 19 byte(s) in 1 object(s) allocated from:
#0 0x7f1b6fc83f30 in __interceptor_malloc (/usr/lib/x86_64-linux-gnu/libasan.so.5+0xedf30)
#1 0x7f1b6e3ac30f in vasprintf (/lib/x86_64-linux-gnu/libc.so.6+0x8830f)
Signed-off-by: Changbin Du <changbin.du@gmail.com>
Reviewed-by: Jiri Olsa <jolsa@kernel.org>
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Steven Rostedt (VMware) <rostedt@goodmis.org>
Fixes: 6a6cd11d4e57 ("perf test: Add test for the sched tracepoint format fields")
Link: http://lkml.kernel.org/r/20190316080556.3075-17-changbin.du@gmail.com
[ Upstream commit f97a8991d3b998e518f56794d879f645964de649 ]
==7506==ERROR: LeakSanitizer: detected memory leaks
Direct leak of 13 byte(s) in 3 object(s) allocated from:
#0 0x7f03339d6070 in __interceptor_strdup (/usr/lib/x86_64-linux-gnu/libasan.so.5+0x3b070)
#1 0x5625e53aaef0 in expr__find_other util/expr.y:221
#2 0x5625e51bcd3f in test__expr tests/expr.c:52
#3 0x5625e51528e6 in run_test tests/builtin-test.c:358
#4 0x5625e5152baf in test_and_print tests/builtin-test.c:388
#5 0x5625e51543fe in __cmd_test tests/builtin-test.c:583
#6 0x5625e515572f in cmd_test tests/builtin-test.c:722
#7 0x5625e51c3fb8 in run_builtin /home/changbin/work/linux/tools/perf/perf.c:302
#8 0x5625e51c44f7 in handle_internal_command /home/changbin/work/linux/tools/perf/perf.c:354
#9 0x5625e51c48fb in run_argv /home/changbin/work/linux/tools/perf/perf.c:398
#10 0x5625e51c5069 in main /home/changbin/work/linux/tools/perf/perf.c:520
#11 0x7f033214d09a in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2409a)
Fixes: 075167363f8b ("perf tools: Add a simple expression parser for JSON")
Link: http://lkml.kernel.org/r/20190316080556.3075-16-changbin.du@gmail.com
openat_syscall_event_on_all_cpus test
[ Upstream commit 93faa52e8371f0291ee1ff4994edae2b336b6233 ]
==7497==ERROR: LeakSanitizer: detected memory leaks
Direct leak of 40 byte(s) in 1 object(s) allocated from:
#0 0x7f0333a88f30 in __interceptor_malloc (/usr/lib/x86_64-linux-gnu/libasan.so.5+0xedf30)
#1 0x5625e5326213 in cpu_map__trim_new util/cpumap.c:45
#2 0x5625e5326703 in cpu_map__read util/cpumap.c:103
#3 0x5625e53267ef in cpu_map__read_all_cpu_map util/cpumap.c:120
#4 0x5625e5326915 in cpu_map__new util/cpumap.c:135
#5 0x5625e517b355 in test__openat_syscall_event_on_all_cpus tests/openat-syscall-all-cpus.c:36
#6 0x5625e51528e6 in run_test tests/builtin-test.c:358
#7 0x5625e5152baf in test_and_print tests/builtin-test.c:388
#8 0x5625e51543fe in __cmd_test tests/builtin-test.c:583
#9 0x5625e515572f in cmd_test tests/builtin-test.c:722
#10 0x5625e51c3fb8 in run_builtin /home/changbin/work/linux/tools/perf/perf.c:302
#11 0x5625e51c44f7 in handle_internal_command /home/changbin/work/linux/tools/perf/perf.c:354
#12 0x5625e51c48fb in run_argv /home/changbin/work/linux/tools/perf/perf.c:398
#13 0x5625e51c5069 in main /home/changbin/work/linux/tools/perf/perf.c:520
#14 0x7f033214d09a in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2409a)
Fixes: f30a79b012e5 ("perf tools: Add reference counting for cpu_map object")
Link: http://lkml.kernel.org/r/20190316080556.3075-15-changbin.du@gmail.com
[ Upstream commit 42dfa451d825a2ad15793c476f73e7bbc0f9d312 ]
Using gcc's ASan, Changbin reports:
==7494==ERROR: LeakSanitizer: detected memory leaks
Direct leak of 48 byte(s) in 1 object(s) allocated from:
#0 0x7f0333a89138 in calloc (/usr/lib/x86_64-linux-gnu/libasan.so.5+0xee138)
#1 0x5625e5330a5e in zalloc util/util.h:23
#2 0x5625e5330a9b in perf_counts__new util/counts.c:10
#3 0x5625e5330ca0 in perf_evsel__alloc_counts util/counts.c:47
#4 0x5625e520d8e5 in __perf_evsel__read_on_cpu util/evsel.c:1505
#5 0x5625e517a985 in perf_evsel__read_on_cpu /home/work/linux/tools/perf/util/evsel.h:347
#6 0x5625e517ad1a in test__openat_syscall_event tests/openat-syscall.c:47
#7 0x5625e51528e6 in run_test tests/builtin-test.c:358
#8 0x5625e5152baf in test_and_print tests/builtin-test.c:388
#9 0x5625e51543fe in __cmd_test tests/builtin-test.c:583
#10 0x5625e515572f in cmd_test tests/builtin-test.c:722
#11 0x5625e51c3fb8 in run_builtin /home/changbin/work/linux/tools/perf/perf.c:302
#12 0x5625e51c44f7 in handle_internal_command /home/changbin/work/linux/tools/perf/perf.c:354
#13 0x5625e51c48fb in run_argv /home/changbin/work/linux/tools/perf/perf.c:398
#14 0x5625e51c5069 in main /home/changbin/work/linux/tools/perf/perf.c:520
#15 0x7f033214d09a in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2409a)
Indirect leak of 72 byte(s) in 1 object(s) allocated from:
#1 0x5625e532560d in zalloc util/util.h:23
#2 0x5625e532566b in xyarray__new util/xyarray.c:10
#3 0x5625e5330aba in perf_counts__new util/counts.c:15
#4 0x5625e5330ca0 in perf_evsel__alloc_counts util/counts.c:47
#5 0x5625e520d8e5 in __perf_evsel__read_on_cpu util/evsel.c:1505
#6 0x5625e517a985 in perf_evsel__read_on_cpu /home/work/linux/tools/perf/util/evsel.h:347
#7 0x5625e517ad1a in test__openat_syscall_event tests/openat-syscall.c:47
#8 0x5625e51528e6 in run_test tests/builtin-test.c:358
#9 0x5625e5152baf in test_and_print tests/builtin-test.c:388
#10 0x5625e51543fe in __cmd_test tests/builtin-test.c:583
#11 0x5625e515572f in cmd_test tests/builtin-test.c:722
#12 0x5625e51c3fb8 in run_builtin /home/changbin/work/linux/tools/perf/perf.c:302
#13 0x5625e51c44f7 in handle_internal_command /home/changbin/work/linux/tools/perf/perf.c:354
#14 0x5625e51c48fb in run_argv /home/changbin/work/linux/tools/perf/perf.c:398
#15 0x5625e51c5069 in main /home/changbin/work/linux/tools/perf/perf.c:520
#16 0x7f033214d09a in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2409a)
His patch took care of evsel->prev_raw_counts, but the above backtraces
are about evsel->counts, so fix that instead.
Reported-by: Changbin Du <changbin.du@gmail.com>
Link: https://lkml.kernel.org/n/tip-hd1x13g59f0nuhe4anxhsmfp@git.kernel.org
[ Upstream commit cb6186aeffda4d27e56066c79e9579e7831541d3 ]
We need to map__put() before returning from failure of
sample__resolve_callchain().
Detected with gcc's ASan.
Cc: Krister Johansen <kjlx@templeofstupid.com>
Fixes: 9c68ae98c6f7 ("perf callchain: Reference count maps")
Link: http://lkml.kernel.org/r/20190316080556.3075-10-changbin.du@gmail.com
[ Upstream commit 70c819e4bf1c5f492768b399d898d458ccdad2b6 ]
We should go to the cleanup path, to avoid leaks, detected using gcc's
ASan.
Link: http://lkml.kernel.org/r/20190316080556.3075-9-changbin.du@gmail.com
[ Upstream commit 8bde8516893da5a5fdf06121f74d11b52ab92df5 ]
Detected with gcc's ASan:
Direct leak of 4356 byte(s) in 120 object(s) allocated from:
#0 0x7ff1a2b5a070 in __interceptor_strdup (/usr/lib/x86_64-linux-gnu/libasan.so.5+0x3b070)
#1 0x55719aef4814 in build_id_cache__origname util/build-id.c:215
#2 0x55719af649b6 in print_sdt_events util/parse-events.c:2339
#3 0x55719af66272 in print_events util/parse-events.c:2542
#4 0x55719ad1ecaa in cmd_list /home/changbin/work/linux/tools/perf/builtin-list.c:58
#5 0x55719aec745d in run_builtin /home/changbin/work/linux/tools/perf/perf.c:302
#6 0x55719aec7d1a in handle_internal_command /home/changbin/work/linux/tools/perf/perf.c:354
#7 0x55719aec8184 in run_argv /home/changbin/work/linux/tools/perf/perf.c:398
#8 0x55719aeca41a in main /home/changbin/work/linux/tools/perf/perf.c:520
#9 0x7ff1a07ae09a in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2409a)
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Fixes: 40218daea1db ("perf list: Show SDT and pre-cached events")
Link: http://lkml.kernel.org/r/20190316080556.3075-7-changbin.du@gmail.com
[ Upstream commit 54569ba4b06d5baedae4614bde33a25a191473ba ]
Direct leak of 66 byte(s) in 5 object(s) allocated from:
#0 0x7ff3b1f32070 in __interceptor_strdup (/usr/lib/x86_64-linux-gnu/libasan.so.5+0x3b070)
#1 0x560c8761034d in collect_config util/config.c:597
#2 0x560c8760d9cb in get_value util/config.c:169
#3 0x560c8760dfd7 in perf_parse_file util/config.c:285
#4 0x560c8760e0d2 in perf_config_from_file util/config.c:476
#5 0x560c876108fd in perf_config_set__init util/config.c:661
#6 0x560c87610c72 in perf_config_set__new util/config.c:709
#7 0x560c87610d2f in perf_config__init util/config.c:718
#8 0x560c87610e5d in perf_config util/config.c:730
#9 0x560c875ddea0 in main /home/changbin/work/linux/tools/perf/perf.c:442
#10 0x7ff3afb8609a in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2409a)
Cc: Taeung Song <treeze.taeung@gmail.com>
Fixes: 20105ca1240c ("perf config: Introduce perf_config_set class")
Link: http://lkml.kernel.org/r/20190316080556.3075-6-changbin.du@gmail.com
[ Upstream commit 9b40dff7ba3caaf0d1919f98e136fa3400bd34aa ]
The option 'sort-order' should be 'sort_order'.
Cc: Milian Wolff <milian.wolff@kdab.com>
Fixes: 893c5c798be9 ("perf config: Show default report configuration in example and docs")
Link: http://lkml.kernel.org/r/20190316080556.3075-5-changbin.du@gmail.com
[ Upstream commit 39df730b09774bd860e39ea208a48d15078236cb ]
Detected via gcc's ASan:
Direct leak of 2048 byte(s) in 64 object(s) allocated from:
6 #0 0x7f606512e370 in __interceptor_realloc (/usr/lib/x86_64-linux-gnu/libasan.so.5+0xee370)
7 #1 0x556b0f1d7ddd in thread_map__realloc util/thread_map.c:43
8 #2 0x556b0f1d84c7 in thread_map__new_by_tid util/thread_map.c:85
9 #3 0x556b0f0e045e in is_event_supported util/parse-events.c:2250
10 #4 0x556b0f0e1aa1 in print_hwcache_events util/parse-events.c:2382
11 #5 0x556b0f0e3231 in print_events util/parse-events.c:2514
12 #6 0x556b0ee0a66e in cmd_list /home/changbin/work/linux/tools/perf/builtin-list.c:58
13 #7 0x556b0f01e0ae in run_builtin /home/changbin/work/linux/tools/perf/perf.c:302
14 #8 0x556b0f01e859 in handle_internal_command /home/changbin/work/linux/tools/perf/perf.c:354
15 #9 0x556b0f01edc8 in run_argv /home/changbin/work/linux/tools/perf/perf.c:398
16 #10 0x556b0f01f71f in main /home/changbin/work/linux/tools/perf/perf.c:520
17 #11 0x7f6062ccf09a in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2409a)
Fixes: 89896051f8da ("perf tools: Do not put a variable sized type not at the end of a struct")
Link: http://lkml.kernel.org/r/20190316080556.3075-3-changbin.du@gmail.com
[ Upstream commit 2a95496634a017c19641f26f00907af75b962f01 ]
turbostat failed to return a non-zero exit status even though the
supplied command (turbostat <command>) failed. Currently when turbostat
forks a command it returns zero instead of the actual exit status of the
command. Modify the code to return the exit status.
Signed-off-by: David Arcari <darcari@redhat.com>
Acked-by: Len Brown <len.brown@intel.com>
[ Upstream commit 03d309711d687460d1345de8a0363f45b1c8cd11 ]
Commit 489338a717a0 ("perf tests evsel-tp-sched: Fix bitwise operator")
causes test case 14 "Parse sched tracepoints fields" to fail on s390.
This test succeeds on x86.
In fact this test now fails on all architectures with type char treated
as type unsigned char.
The root cause is the signed-ness of character arrays in the tracepoints
sched_switch for structure members prev_comm and next_comm.
On s390 the output of:
[root@m35lp76 perf]# cat /sys/kernel/debug/tracing/events/sched/sched_switch/format
format:
field:unsigned short common_type; offset:0; size:2; signed:0;
field:char prev_comm[16]; offset:8; size:16; signed:0;
field:char next_comm[16]; offset:40; size:16; signed:0;
reveals the character arrays prev_comm and next_comm are per
default unsigned char and have values in the range of 0..255.
On x86 both fields are signed as this output shows:
[root@f29]# cat /sys/kernel/debug/tracing/events/sched/sched_switch/format
format:
field:char prev_comm[16]; offset:8; size:16; signed:1;
field:char next_comm[16]; offset:40; size:16; signed:1;
and the character arrays prev_comm and next_comm are per default signed
char and have values in the range of -1..127. The implementation of
type char is architecture specific.
Since the character arrays in both tracepoints sched_switch and
sched_wakeup should contain ascii characters, simply omit the check for
signedness in the test case.
Output before:
[root@m35lp76 perf]# ./perf test -F 14
14: Parse sched tracepoints fields :
--- start ---
sched:sched_switch: "prev_comm" signedness(0) is wrong, should be 1
sched:sched_switch: "next_comm" signedness(0) is wrong, should be 1
sched:sched_wakeup: "comm" signedness(0) is wrong, should be 1
---- end ----
14: Parse sched tracepoints fields : FAILED!
Output after:
[root@m35lp76 perf]# ./perf test -Fv 14
--- start ---
---- end ----
Parse sched tracepoints fields: Ok
Fixes: 489338a717a0 ("perf tests evsel-tp-sched: Fix bitwise operator")
Signed-off-by: Thomas Richter <tmricht@linux.ibm.com>
Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20190219153639.31267-1-tmricht@linux.ibm.com
[ Upstream commit 7c5b019e3a638a5a290b0ec020f6ca83d2ec2aaa ]
Fix buffer overflow observed when running perf test.
The overflow is when trying to evaluate "1ULL << (64 - 1)" which is
resulting in -9223372036854775808 which overflows the 20 character
buffer.
If is possible this bug has been reported before but I still don't see
any fix checked in:
See: https://www.spinics.net/lists/linux-perf-users/msg07714.html
Reported-by: Michael Sartain <mikesart@fastmail.com>
Reported-by: Mathias Krause <minipli@googlemail.com>
Signed-off-by: Tony Jones <tonyj@suse.de>
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Fixes: f7d82350e597 ("tools/events: Add files to create libtraceevent.a")
Link: http://lkml.kernel.org/r/20190228015532.8941-1-tonyj@suse.de
[ Upstream commit e34c940245437f36d2c492edd1f8237eff391064 ]
Ravi Bangoria reported that we fail with an empty NUMA node with the
following message:
$ lscpu
NUMA node0 CPU(s):
NUMA node1 CPU(s): 0-4
$ sudo ./perf c2c report
node/cpu topology bugFailed setup nodes
Fix this by detecting the empty node and keeping its CPU set empty.
Reported-by: Nageswara R Sastry <nasastry@in.ibm.com>
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Tested-by: Ravi Bangoria <ravi.bangoria@linux.ibm.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Jonas Rabenstein <jonas.rabenstein@studium.uni-erlangen.de>
Link: http://lkml.kernel.org/r/20190305152536.21035-2-jolsa@kernel.org
commit f3b4e06b3bda759afd042d3d5fa86bea8f1fe278 upstream.
A TSC packet can slip past MTC packets so that the timestamp appears to
go backwards. One estimate is that can be up to about 40 CPU cycles,
which is certainly less than 0x1000 TSC ticks, but accept slippage an
order of magnitude more to be on the safe side.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: stable@vger.kernel.org
Fixes: 79b58424b821c ("perf tools: Add Intel PT support for decoding MTC packets")
Link: http://lkml.kernel.org/r/20190325135135.18348-1-adrian.hunter@intel.com
commit 0c671812f152b628bd87c0af49da032cc2a2c319 upstream.
Objtool uses over 512k of stack, thanks to the hash table embedded in
the objtool_file struct. This causes an unnecessarily large stack
allocation and breaks users with low stack limits.
Move the struct off the stack.
Fixes: 042ba73fe7eb ("objtool: Add several performance improvements")
Reported-by: Vassili Karpov <moosotc@gmail.com>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Link: https://lkml.kernel.org/r/df92dcbc4b84b02ffa252f46876df125fb56e2d7.1552954176.git.jpoimboe@redhat.com
commit eaeffeb9838a7c0dec981d258666bfcc0fa6a947 upstream.
Since commit 4d99e4136580 ("perf machine: Workaround missing maps for
x86 PTI entry trampolines"), perf tools has been creating more than one
kernel map, however 'perf probe' assumed there could be only one.
Fix by using machine__kernel_map() to get the main kernel map.
Tested-by: Joseph Qi <joseph.qi@linux.alibaba.com>
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Jiufei Xue <jiufei.xue@linux.alibaba.com>
Cc: Xu Yu <xuyu@linux.alibaba.com>
Fixes: 4d99e4136580 ("perf machine: Workaround missing maps for x86 PTI entry trampolines")
Fixes: d83212d5dd67 ("kallsyms, x86: Export addresses of PTI entry trampolines")
Link: http://lkml.kernel.org/r/2ed432de-e904-85d2-5c36-5897ddc5b23b@intel.com
commit 076333870c2f5bdd9b6d31e7ca1909cf0c84cbfa upstream.
When TSC is not available, "timeless" decoding is used but a divide by
zero occurs if perf_time_to_tsc() is called.
Ensure the divisor is not zero.
Cc: stable@vger.kernel.org # v4.9+
Link: https://lkml.kernel.org/n/tip-1i4j0wqoc8vlbkcizqqxpsf4@git.kernel.org
commit 5a99d99e3310a565b0cf63f785b347be9ee0da45 upstream.
Auxtrace records might have up to 7 bytes of padding appended. Adjust
the overlap accordingly.
Link: http://lkml.kernel.org/r/20190206103947.15750-3-adrian.hunter@intel.com
commit c3fcadf0bb765faf45d6d562246e1d08885466df upstream.
Define auxtrace record alignment so that it can be referenced elsewhere.
Note this is preparation for patch "perf intel-pt: Fix overlap calculation
for padding"
Link: http://lkml.kernel.org/r/20190206103947.15750-2-adrian.hunter@intel.com
commit 03997612904866abe7cdcc992784ef65cb3a4b81 upstream.
CYC packet timestamp calculation depends upon CBR which was being
cleared upon overflow (OVF). That can cause errors due to failing to
synchronize with sideband events. Even if a CBR change has been lost,
the old CBR is still a better estimate than zero. So remove the clearing
of CBR.
Link: http://lkml.kernel.org/r/20190206103947.15750-4-adrian.hunter@intel.com
commit 44df1afdb174fd6038e419f80efd914c0b5f2f85 upstream.
Fix a compile error:
CC util/libunwind/x86_32.o
In file included from util/libunwind/x86_32.c:33:0:
util/libunwind/../../arch/x86/util/unwind-libunwind.c: In function 'libunwind__x86_reg_id':
util/libunwind/../../arch/x86/util/unwind-libunwind.c:110:11: error: 'EINVAL' undeclared (first use in this function)
return -EINVAL;
util/libunwind/../../arch/x86/util/unwind-libunwind.c:110:11: note: each undeclared identifier is reported only once for each function it appears in
mv: cannot stat 'util/libunwind/.x86_32.o.tmp': No such file or directory
make[4]: *** [util/libunwind/x86_32.o] Error 1
make[3]: *** [util] Error 2
make[2]: *** [libperf-in.o] Error 2
make[1]: *** [sub-make] Error 2
make: *** [all] Error 2
It happens when libunwind-x86 feature is detected.
Signed-off-by: Wang Nan <wangnan0@huawei.com>
Link: http://lkml.kernel.org/r/20171206015040.114574-1-wangnan0@huawei.com
Cc: Daniel Díaz <daniel.diaz@linaro.org>
[ Upstream commit 6ab3bc240ade47a0f52bc16d97edd9accbe0024e ]
With a suitably defined "probe:vfs_getname" probe, 'perf trace' can
"beautify" its output, so syscalls like open() or openat() can print the
"filename" argument instead of just its hex address, like:
$ perf trace -e open -- touch /dev/null
0.590 ( 0.014 ms): touch/18063 open(filename: /dev/null, flags: CREAT|NOCTTY|NONBLOCK|WRONLY, mode: IRUGO|IWUGO) = 3
The output without such beautifier looks like:
0.529 ( 0.011 ms): touch/18075 open(filename: 0xc78cf288, flags: CREAT|NOCTTY|NONBLOCK|WRONLY, mode: IRUGO|IWUGO) = 3
However, when the vfs_getname probe expands to multiple probes and it is
not the first one that is hit, the beautifier fails, as following:
0.326 ( 0.010 ms): touch/18072 open(filename: , flags: CREAT|NOCTTY|NONBLOCK|WRONLY, mode: IRUGO|IWUGO) = 3
Fix it by hooking into all the expanded probes (inlines), now, for instance:
[root@quaco ~]# perf probe -l
probe:vfs_getname (on getname_flags:73@fs/namei.c with pathname)
probe:vfs_getname_1 (on getname_flags:73@fs/namei.c with pathname)
[root@quaco ~]# perf trace -e open* sleep 1
0.010 ( 0.005 ms): sleep/5588 openat(dfd: CWD, filename: /etc/ld.so.cache, flags: RDONLY|CLOEXEC) = 3
0.029 ( 0.006 ms): sleep/5588 openat(dfd: CWD, filename: /lib64/libc.so.6, flags: RDONLY|CLOEXEC) = 3
0.194 ( 0.008 ms): sleep/5588 openat(dfd: CWD, filename: /usr/lib/locale/locale-archive, flags: RDONLY|CLOEXEC) = 3
[root@quaco ~]#
Works, further verified with:
[root@quaco ~]# perf test vfs
65: Use vfs_getname probe to get syscall args filenames : Ok
66: Add vfs_getname probe to get syscall args filenames : Ok
67: Check open filename arg using perf trace + vfs_getname: Ok
[root@quaco ~]#
Reported-by: Michael Petlan <mpetlan@redhat.com>
Tested-by: Michael Petlan <mpetlan@redhat.com>
Link: https://lkml.kernel.org/n/tip-mv8kolk17xla1smvmp3qabv1@git.kernel.org
[ Upstream commit 59a17706915fe5ea6f711e1f92d4fb706bce07fe ]
When perf is built with the annobin plugin (RHEL8 build) extra symbols
are added to its binary:
# nm perf | grep annobin | head -10
0000000000241100 t .annobin_annotate.c
0000000000326490 t .annobin_annotate.c
0000000000249255 t .annobin_annotate.c_end
00000000003283a8 t .annobin_annotate.c_end
00000000001bce18 t .annobin_annotate.c_end.hot
00000000001bc3e2 t .annobin_annotate.c_end.unlikely
00000000001bc400 t .annobin_annotate.c_end.unlikely
00000000001bce18 t .annobin_annotate.c.hot
Those symbols have no use for report or annotation and should be
skipped. Moreover they interfere with the DWARF unwind test on the PPC
arch, where they are mixed with checked symbols and then the test fails:
# perf test dwarf -v
59: Test dwarf unwind :
--- start ---
test child forked, pid 8515
unwind: .annobin_dwarf_unwind.c:ip = 0x10dba40dc (0x2740dc)
got: .annobin_dwarf_unwind.c 0x10dba40dc, expecting test__arch_unwind_sample
unwind: failed with 'no error'
The annobin symbols are defined as NOTYPE/LOCAL/HIDDEN:
# readelf -s ./perf | grep annobin | head -1
40: 00000000001bce4f 0 NOTYPE LOCAL HIDDEN 13 .annobin_init.c
They can still pass the check for the label symbol. Adding check for
HIDDEN and INTERNAL (as suggested by Nick below) visibility and filter
out such symbols.
> Just to be awkward, if you are going to ignore STV_HIDDEN
> symbols then you should probably also ignore STV_INTERNAL ones
> as well... Annobin does not generate them, but you never know,
> one day some other tool might create some.
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Michael Petlan <mpetlan@redhat.com>
Cc: Nick Clifton <nickc@redhat.com>
Link: http://lkml.kernel.org/r/20190128133526.GD15461@krava
[ Upstream commit 98bfc3414bda335dbd7fec58bde6266f991801d7 ]
Check basic nat/redirect/masquerade for ipv4 and ipv6.
[ Upstream commit 952b72f89ae23b316da8c1021b18d0c388ad6cc4 ]
In selftests the config fragment for netfilter was added as
NF_TABLES_INET=y and this patch correct it as CONFIG_NF_TABLES_INET=y
Signed-off-by: Naresh Kamboju <naresh.kamboju@linaro.org>
Acked-by: Florian Westphal <fw@strlen.de>
[ Upstream commit 1bb54c4071f585ebef56ce8fdfe6026fa2cbcddd ]
Previously, bpf_num_possible_cpus() had a bug when calculating a
number of possible CPUs in the case of sparse CPU allocations, as
it was considering only the first range or element of
/sys/devices/system/cpu/possible.
E.g. in the case of "0,2-3" (CPU 1 is not available), the function
returned 1 instead of 3.
This patch fixes the function by making it parse all CPU ranges and
elements.
Signed-off-by: Martynas Pumputis <m@lambda.lt>
Acked-by: Yonghong Song <yhs@fb.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 7d4e591bc051d3382c45caaa2530969fb42ed23d ]
posix_timers fails to build due to undefined reference errors:
aarch64-linaro-linux-gcc --sysroot=/build/tmp-rpb-glibc/sysroots/hikey
-O2 -pipe -g -feliminate-unused-debug-types -O3 -Wl,-no-as-needed -Wall
-DKTEST -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -lrt -lpthread
posix_timers.c
-o /build/tmp-rpb-glibc/work/hikey-linaro-linux/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/timers/posix_timers
/tmp/cc1FTZzT.o: In function `check_timer_create':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/timers/posix_timers.c:157:
undefined reference to `timer_create'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/timers/posix_timers.c:170:
undefined reference to `timer_settime'
collect2: error: ld returned 1 exit status
It's GNU Make and linker specific.
The default Makefile rule looks like:
$(CC) $(CFLAGS) $(LDFLAGS) $@ $^ $(LDLIBS)
When linking is done by gcc itself, no issue, but when it needs to be passed
to proper ld, only LDLIBS follows and then ld cannot know what libs to link
with.
More detail:
https://www.gnu.org/software/make/manual/html_node/Implicit-Variables.html
LDFLAGS
Extra flags to give to compilers when they are supposed to invoke the linker,
‘ld’, such as -L. Libraries (-lfoo) should be added to the LDLIBS variable
instead.
LDLIBS
Library flags or names given to compilers when they are supposed to invoke the
linker, ‘ld’. LOADLIBES is a deprecated (but still supported) alternative to
LDLIBS. Non-library linker flags, such as -L, should go in the LDFLAGS
variable.
https://lkml.org/lkml/2010/2/10/362
tools/perf: libraries must come after objects
Link order matters, use LDLIBS instead of LDFLAGS to properly link against
libpthread.
Signed-off-by: Denys Dmytriyenko <denys@ti.com>
Signed-off-by: Fathi Boudra <fathi.boudra@linaro.org>
Signed-off-by: Shuah Khan <shuah@kernel.org>
[ Upstream commit 2b531b6137834a55857a337ac17510d6436b6fbb ]
The cpu-hotplug test assumes that we can offline the maximum CPU as
described by /sys/devices/system/cpu/offline. However, in the case
where the number of CPUs exceeds like kernel configuration then
the offline count can be greater than the present count and we end
up trying to test the offlining of a CPU that is not available to
offline. Fix this by testing the maximum present CPU instead.
Also, the test currently offlines the CPU and does not online it,
so fix this by onlining the CPU after the test.
Fixes: d89dffa976bc ("fault-injection: add selftests for cpu and memory hotplug")
[ Upstream commit 1497e804d1a6e2bd9107ddf64b0310449f4673eb ]
This patch fixes an issue in cpumap.c when used with the TOPOLOGY
header. In some configurations, some NUMA nodes may have no CPU (empty
cpulist). Yet a cpumap map must be created otherwise perf abort with an
error. This patch handles this case by creating a dummy map.
Before:
$ perf record -o - -e cycles noploop 2 | perf script -i -
0x6e8 [0x6c]: failed to process type: 80
After:
noploop for 2 seconds
Signed-off-by: Stephane Eranian <eranian@google.com>
Acked-by: Jiri Olsa <jolsa@kernel.org>
Cc: Kan Liang <kan.liang@linux.intel.com>
Link: http://lkml.kernel.org/r/1547885559-1657-1-git-send-email-eranian@google.com
[ Upstream commit 508cacd7da6659ae7b7bdd0a335f675422277758 ]
With gcc 7.3.0:
gpio-mockup-chardev.c: In function ‘get_debugfs’:
gpio-mockup-chardev.c:62:3: warning: ignoring return value of ‘asprintf’, declared with attribute warn_unused_result [-Wunused-result]
asprintf(path, "%s/gpio", mnt_fs_get_target(fs));
Handle asprintf() failures to fix this.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
[ Upstream commit 5bbc73a841d7f0bbe025a342146dde462a796a5a ]
seccomp_bpf fails to build due to undefined reference errors:
-O2 -pipe -g -feliminate-unused-debug-types -Wl,-no-as-needed -Wall
-Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -lpthread seccomp_bpf.c -o
/build/tmp-rpb-glibc/work/hikey-linaro-linux/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf
/tmp/ccrlR3MW.o: In function `tsync_sibling':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1920: undefined reference to `sem_post'
/tmp/ccrlR3MW.o: In function `TSYNC_setup':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1863: undefined reference to `sem_init'
/tmp/ccrlR3MW.o: In function `TSYNC_teardown':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1904: undefined reference to `sem_destroy'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1897: undefined reference to `pthread_kill'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1898: undefined reference to `pthread_cancel'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1899: undefined reference to `pthread_join'
/tmp/ccrlR3MW.o: In function `tsync_start_sibling':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1941: undefined reference to `pthread_create'
/tmp/ccrlR3MW.o: In function `TSYNC_siblings_fail_prctl':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1978: undefined reference to `sem_wait'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1990: undefined reference to `pthread_join'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1992: undefined reference to `pthread_join'
/tmp/ccrlR3MW.o: In function `TSYNC_two_siblings_with_ancestor':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2016: undefined reference to `sem_wait'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2032: undefined reference to `pthread_join'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2034: undefined reference to `pthread_join'
/tmp/ccrlR3MW.o: In function `TSYNC_two_sibling_want_nnp':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2046: undefined reference to `sem_wait'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2058: undefined reference to `pthread_join'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2060: undefined reference to `pthread_join'
/tmp/ccrlR3MW.o: In function `TSYNC_two_siblings_with_no_filter':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2073: undefined reference to `sem_wait'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2098: undefined reference to `pthread_join'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2100: undefined reference to `pthread_join'
/tmp/ccrlR3MW.o: In function `TSYNC_two_siblings_with_one_divergence':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2125: undefined reference to `sem_wait'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2143: undefined reference to `pthread_join'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2145: undefined reference to `pthread_join'
/tmp/ccrlR3MW.o: In function `TSYNC_two_siblings_not_under_filter':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2169: undefined reference to `sem_wait'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2202: undefined reference to `pthread_join'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2227: undefined reference to `pthread_join'
with.
More detail:
LDFLAGS
instead.
LDLIBS
variable.
libpthread.
[ Upstream commit 03fa483821c0b4db7c2b1453d3332f397d82313f ]
Some kernels, like 4.19.13-300.fc29.x86_64 in fedora 29, fail with the
existing probe definition asking for the contents of result->name,
working when we ask for the 'filename' variable instead, so add a
fallback to that.
Now those tests are back working on fedora 29 systems with that kernel:
# perf test vfs_getname
Link: https://lkml.kernel.org/n/tip-klt3n0i58dfqttveti09q3fi@git.kernel.org
commit 692f5a22cd284bb8233a38e3ed86881d2d9c89d4 upstream.
Otherwise we fail on virtual machines with no support for specific HW
events.
Link: http://lkml.kernel.org/r/20171009130712.14747-1-jolsa@kernel.org
Cc: "Rantala, Tommi T. (Nokia - FI/Espoo)" <tommi.t.rantala@nokia.com>
commit f6a9820d572bd8384d982357cbad214b3a6c04bb upstream.
We started to use group read whenever it's possible:
82bf311e15d2 perf stat: Use group read for event groups
That breaks some of attr tests, this change adds the new possible
read_format value.
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Thomas-Mich Richter <tmricht@linux.vnet.ibm.com>
LPU-Reference: 20170928160633.GA26973@krava
Link: http://lkml.kernel.org/n/tip-1ko2zc4nph93d8lfwjyk9ivz@git.kernel.org
commit 10836d9f9ac63d40ccfa756f871ce4ed51ae3b52 upstream.
The perf_event_attr::task is 1 by default for first (tracking) event in
the session. Setting task=1 as default and adding task=0 for cases that
need it.
Link: http://lkml.kernel.org/r/20170703145030.12903-16-jolsa@kernel.org
commit 489338a717a0dfbbd5a3fabccf172b78f0ac9015 upstream.
Notice that the use of the bitwise OR operator '|' always leads to true
in this particular case, which seems a bit suspicious due to the context
in which this expression is being used.
Fix this by using bitwise AND operator '&' instead.
This bug was detected with the help of Coccinelle.
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Link: http://lkml.kernel.org/r/20190122233439.GA5868@embeddedor
[ Upstream commit bef0b8970f27da5ca223e522a174d03e2587761d ]
The strncpy() function may leave the destination string buffer
unterminated, better use strlcpy() that we have a __weak fallback
implementation for systems without it.
In this case the 'target' buffer is coming from a list of build-ids that
are expected to have a len of at most (SBUILD_ID_SIZE - 1) chars, so
probably we're safe, but since we're using strncpy() here, use strlcpy()
instead to provide the intended safety checking without the using the
problematic strncpy() function.
This fixes this warning on an Alpine Linux Edge system with gcc 8.2:
util/probe-file.c: In function 'probe_cache__open.isra.5':
util/probe-file.c:427:3: error: 'strncpy' specified bound 41 equals destination size [-Werror=stringop-truncation]
strncpy(sbuildid, target, SBUILD_ID_SIZE);
cc1: all warnings being treated as errors
Fixes: 1f3736c9c833 ("perf probe: Show all cached probes")
Link: https://lkml.kernel.org/n/tip-l7n8ggc9kl38qtdlouke5yp5@git.kernel.org
[ Upstream commit 7572588085a13d5db02bf159542189f52fdb507e ]
util/header.c: In function 'perf_event__synthesize_event_update_unit':
util/header.c:3586:2: error: 'strncpy' output truncated before terminating nul copying as many bytes from a string as its length [-Werror=stringop-truncation]
strncpy(ev->data, evsel->unit, size);
util/header.c:3579:16: note: length computed here
size_t size = strlen(evsel->unit);
Fixes: a6e5281780d1 ("perf tools: Add event_update event unit type")
Link: https://lkml.kernel.org/n/tip-fiikh5nay70bv4zskw2aa858@git.kernel.org
[ Upstream commit 741dad88dde296999da30332157ca47f0543747d ]
Fix inconsistent use of tabs and spaces error:
# perf test 16 -v
16: Setup struct perf_event_attr :
--- start ---
test child forked, pid 20224
File "/usr/libexec/perf-core/tests/attr.py", line 119
log.warning("expected %s=%s, got %s" % (t, self[t], other[t]))
TabError: inconsistent use of tabs and spaces in indentation
test child finished with -1
---- end ----
Setup struct perf_event_attr: FAILED!
Link: http://lkml.kernel.org/r/20181122140456.16817-1-adrian.hunter@intel.com
[ Upstream commit a0517a0f7ef23550b4484c37e2b9c2d32abebf64 ]
For some reason, my older GCC (< 4.8) isn't smart enough to optimize the
!__builtin_constant_p() branch in bpf_htons, I see:
error: implicit declaration of function '__builtin_bswap16'
Let's use __bpf_constant_htons as suggested by Daniel Borkmann.
I tried to use simple htons, but it produces the following:
test_progs.c:54:17: error: braced-group within expression allowed only
inside a function
.eth.h_proto = htons(ETH_P_IP),
Signed-off-by: Stanislav Fomichev <sdf@google.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
[ Upstream commit 4787eff3fa88f62fede6ed7afa06477ae6bf984d ]
The tool perf is useful for the performance analysis on the Hygon Dhyana
platform. But right now there is no Hygon support for it to analyze the
KVM guest os data. So add Hygon Dhyana support to it by checking vendor
string to share the code path of AMD.
Signed-off-by: Pu Wen <puwen@hygon.cn>
Acked-by: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/1542008451-31735-1-git-send-email-puwen@hygon.cn
[ Upstream commit 4fcba7802c3e15a6e56e255871d6c72f829b9dd8 ]
The patch fixes:
hv_kvp_daemon.c: In function 'kvp_set_ip_info':
hv_kvp_daemon.c:1305:2: note: 'snprintf' output between 41 and 4136 bytes
into a destination of size 4096
The "(unsigned int)str_len" is to avoid:
hv_kvp_daemon.c:1309:30: warning: comparison of integer expressions of
different signedness: 'int' and 'long unsigned int' [-Wsign-compare]
Signed-off-by: Dexuan Cui <decui@microsoft.com>
Cc: K. Y. Srinivasan <kys@microsoft.com>
Cc: Haiyang Zhang <haiyangz@microsoft.com>
Cc: Stephen Hemminger <sthemmin@microsoft.com>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
commit ed5f13261cb65b02c611ae9971677f33581d4286 upstream.
Passing EPERM during syscall skipping was confusing since the test wasn't
actually exercising the errno evaluation -- it was just passing a literal
"1" (EPERM). Instead, expand the tests to check both direct value returns
(positive, 45000 in this case), and errno values (negative, -ESRCH in this
case) to check both fake success and fake failure during syscall skipping.
Reported-by: Colin Ian King <colin.king@canonical.com>
Fixes: a33b2d0359a0 ("selftests/seccomp: Add tests for basic ptrace actions")
This reverts commit e65cd9a20343ea90f576c24c38ee85ab6e7d5fec.
Tommi T. Rrantala notes:
PTRACE_SECCOMP_GET_METADATA was only added in 4.16
(26500475ac1b499d8636ff281311d633909f5d20)
And it's also breaking seccomp_bpf.c compilation for me:
seccomp_bpf.c: In function ‘get_metadata’:
seccomp_bpf.c:2878:26: error: storage size of ‘md’ isn’t known
struct seccomp_metadata md;
[ Upstream commit 1fe627da30331024f453faef04d500079b901107 ]
libdwfl parses an ELF file itself and creates mappings for the
individual sections. perf on the other hand sees raw mmap events which
represent individual sections. When we encounter an address pointing
into a mapping with pgoff != 0, we must take that into account and
report the file at the non-offset base address.
This fixes unwinding with libdwfl in some cases. E.g. for a file like:
using namespace std;
mutex g_mutex;
double worker()
lock_guard<mutex> guard(g_mutex);
uniform_real_distribution<double> uniform(-1E5, 1E5);
default_random_engine engine;
double s = 0;
for (int i = 0; i < 1000; ++i) {
s += norm(complex<double>(uniform(engine), uniform(engine)));
cout << s << endl;
return s;
int main()
vector<std::future<double>> results;
for (int i = 0; i < 10000; ++i) {
results.push_back(async(launch::async, worker));
return 0;
Compile it with `g++ -g -O2 -lpthread cpp-locking.cpp -o cpp-locking`,
then record it with `perf record --call-graph dwarf -e
sched:sched_switch`.
When you analyze it with `perf script` and libunwind, you should see:
cpp-locking 20038 [005] 54830.236589: sched:sched_switch: prev_comm=cpp-locking prev_pid=20038 prev_prio=120 prev_state=T ==> next_comm=swapper/5 next_pid=0 next_prio=120
ffffffffb166fec5 __sched_text_start+0x545 (/lib/modules/4.14.78-1-lts/build/vmlinux)
ffffffffb1670208 schedule+0x28 (/lib/modules/4.14.78-1-lts/build/vmlinux)
ffffffffb16737cc rwsem_down_read_failed+0xec (/lib/modules/4.14.78-1-lts/build/vmlinux)
ffffffffb1665e04 call_rwsem_down_read_failed+0x14 (/lib/modules/4.14.78-1-lts/build/vmlinux)
ffffffffb1672a03 down_read+0x13 (/lib/modules/4.14.78-1-lts/build/vmlinux)
ffffffffb106bd85 __do_page_fault+0x445 (/lib/modules/4.14.78-1-lts/build/vmlinux)
ffffffffb18015f5 page_fault+0x45 (/lib/modules/4.14.78-1-lts/build/vmlinux)
7f38e4252591 new_heap+0x101 (/usr/lib/libc-2.28.so)
7f38e4252d0b arena_get2.part.4+0x2fb (/usr/lib/libc-2.28.so)
7f38e4255b1c tcache_init.part.6+0xec (/usr/lib/libc-2.28.so)
7f38e42569e5 __GI___libc_malloc+0x115 (inlined)
7f38e4241790 __GI__IO_file_doallocate+0x90 (inlined)
7f38e424fbbf __GI__IO_doallocbuf+0x4f (inlined)
7f38e424ee47 __GI__IO_file_overflow+0x197 (inlined)
7f38e424df36 _IO_new_file_xsputn+0x116 (inlined)
7f38e4242bfb __GI__IO_fwrite+0xdb (inlined)
7f38e463fa6d std::basic_streambuf<char, std::char_traits<char> >::sputn(char const*, long)+0x1cd (inlined)
7f38e463fa6d std::ostreambuf_iterator<char, std::char_traits<char> >::_M_put(char const*, long)+0x1cd (inlined)
7f38e463fa6d std::ostreambuf_iterator<char, std::char_traits<char> > std::__write<char>(std::ostreambuf_iterator<char, std::char_traits<char> >, char const*, int)+0x1cd (inlined)
7f38e463fa6d std::ostreambuf_iterator<char, std::char_traits<char> > std::num_put<char, std::ostreambuf_iterator<char, std::char_traits<char> > >::_M_insert_float<double>(std::ostreambuf_iterator<c>
7f38e464bd70 std::num_put<char, std::ostreambuf_iterator<char, std::char_traits<char> > >::put(std::ostreambuf_iterator<char, std::char_traits<char> >, std::ios_base&, char, double) const+0x90 (inl>
7f38e464bd70 std::ostream& std::ostream::_M_insert<double>(double)+0x90 (/usr/lib/libstdc++.so.6.0.25)
563b9cb502f7 std::ostream::operator<<(double)+0xb7 (inlined)
563b9cb502f7 worker()+0xb7 (/ssd/milian/projects/kdab/rnd/hotspot/build/tests/test-clients/cpp-locking/cpp-locking)
563b9cb506fb double std::__invoke_impl<double, double (*)()>(std::__invoke_other, double (*&&)())+0x2b (inlined)
563b9cb506fb std::__invoke_result<double (*)()>::type std::__invoke<double (*)()>(double (*&&)())+0x2b (inlined)
563b9cb506fb decltype (__invoke((_S_declval<0ul>)())) std::thread::_Invoker<std::tuple<double (*)()> >::_M_invoke<0ul>(std::_Index_tuple<0ul>)+0x2b (inlined)
563b9cb506fb std::thread::_Invoker<std::tuple<double (*)()> >::operator()()+0x2b (inlined)
563b9cb506fb std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<double>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<double (*)()> >, dou>
563b9cb506fb std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_>
563b9cb507e8 std::function<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> ()>::operator()() const+0x28 (inlined)
563b9cb507e8 std::__future_base::_State_baseV2::_M_do_set(std::function<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> ()>*, bool*)+0x28 (/ssd/milian/>
7f38e46d24fe __pthread_once_slow+0xbe (/usr/lib/libpthread-2.28.so)
563b9cb51149 __gthread_once+0xe9 (inlined)
563b9cb51149 void std::call_once<void (std::__future_base::_State_baseV2::*)(std::function<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> ()>*, bool*)>
563b9cb51149 std::__future_base::_State_baseV2::_M_set_result(std::function<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> ()>, bool)+0xe9 (inlined)
563b9cb51149 std::__future_base::_Async_state_impl<std::thread::_Invoker<std::tuple<double (*)()> >, double>::_Async_state_impl(std::thread::_Invoker<std::tuple<double (*)()> >&&)::{lambda()#1}::op>
563b9cb51149 void std::__invoke_impl<void, std::__future_base::_Async_state_impl<std::thread::_Invoker<std::tuple<double (*)()> >, double>::_Async_state_impl(std::thread::_Invoker<std::tuple<double>
563b9cb51149 std::__invoke_result<std::__future_base::_Async_state_impl<std::thread::_Invoker<std::tuple<double (*)()> >, double>::_Async_state_impl(std::thread::_Invoker<std::tuple<double (*)()> >>
563b9cb51149 decltype (__invoke((_S_declval<0ul>)())) std::thread::_Invoker<std::tuple<std::__future_base::_Async_state_impl<std::thread::_Invoker<std::tuple<double (*)()> >, double>::_Async_state_>
563b9cb51149 std::thread::_Invoker<std::tuple<std::__future_base::_Async_state_impl<std::thread::_Invoker<std::tuple<double (*)()> >, double>::_Async_state_impl(std::thread::_Invoker<std::tuple<dou>
563b9cb51149 std::thread::_State_impl<std::thread::_Invoker<std::tuple<std::__future_base::_Async_state_impl<std::thread::_Invoker<std::tuple<double (*)()> >, double>::_Async_state_impl(std::thread>
7f38e45f0062 execute_native_thread_routine+0x12 (/usr/lib/libstdc++.so.6.0.25)
7f38e46caa9c start_thread+0xfc (/usr/lib/libpthread-2.28.so)
7f38e42ccb22 __GI___clone+0x42 (inlined)
Before this patch, using libdwfl, you would see:
a041161e77950c5c [unknown] ([unknown])
With this patch applied, we get a bit further in unwinding:
6eab825c1ee3e4ff [unknown] ([unknown])
Note that the backtrace is still stopping too early, when compared to
the nice results obtained via libunwind. It's unclear so far what the
reason for that is.
Committer note:
Further comment by Milian on the thread started on the Link: tag below:
The remaining issue is due to a bug in elfutils:
https://sourceware.org/ml/elfutils-devel/2018-q4/msg00089.html
With both patches applied, libunwind and elfutils produce the same output for
the above scenario.
Signed-off-by: Milian Wolff <milian.wolff@kdab.com>
Link: http://lkml.kernel.org/r/20181029141644.3907-1-milian.wolff@kdab.com
[ Upstream commit 3d20c6246690219881786de10d2dda93f616d0ac ]
Path passed to libdw for unwinding doesn't include symfs path
if specified, so unwinding fails because ELF file is not found.
Similar to unwinding with libunwind, pass symsrc_filename instead
of long_name. If there is no symsrc_filename, fallback to long_name.
Signed-off-by: Martin Vuille <jpmv27@aim.com>
Link: http://lkml.kernel.org/r/20180211212420.18388-1-jpmv27@aim.com
