path: root/tools
2014-08-29Merge branch 'akpm' (fixes from Andrew Morton)Linus Torvalds
Merge patches from Andrew Morton: "22 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (22 commits) kexec: purgatory: add clean-up for purgatory directory Documentation/kdump/kdump.txt: add ARM description flush_icache_range: export symbol to fix build errors tools: selftests: fix build issue with make kselftests target ocfs2: quorum: add a log for node not fenced ocfs2: o2net: set tcp user timeout to max value ocfs2: o2net: don't shutdown connection when idle timeout ocfs2: do not write error flag to user structure we cannot copy from/to x86/purgatory: use approprate -m64/-32 build flag for arch/x86/purgatory drivers/rtc/rtc-s5m.c: re-add support for devices without irq specified xattr: fix check for simultaneous glibc header inclusion kexec: remove CONFIG_KEXEC dependency on crypto kexec: create a new config option CONFIG_KEXEC_FILE for new syscall x86,mm: fix pte_special versus pte_numa hugetlb_cgroup: use lockdep_assert_held rather than spin_is_locked mm/zpool: use prefixed module loading zram: fix incorrect stat with failed_reads lib: turn CONFIG_STACKTRACE into an actual option. mm: actually clear pmd_numa before invalidating memblock, memhotplug: fix wrong type in memblock_find_in_range_node(). ...
2014-08-29tools: selftests: fix build issue with make kselftests targetPhong Tran
Fix the typo of ARCH when running 'make kselftests'. Change the 'X86' to 'x86'. Test by compilation. Signed-off-by: Phong Tran <tranmanphong@gmail.com> Cc: David Herrmann <dh.herrmann@gmail.com> Cc: Hugh Dickins <hughd@google.com> Cc: Shuah Khan <shuah.kh@samsung.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-25usbip: move usbip userspace code out of stagingValentina Manea
At this point, USB/IP userspace code is fully functional and can be moved out of staging. Signed-off-by: Valentina Manea <valentina.manea.m@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-16Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull idle update from Len Brown: "Two Intel-platform-specific updates to intel_idle, and a cosmetic tweak to the turbostat utility" * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: tools/power turbostat: tweak whitespace in output format intel_idle: Broadwell support intel_idle: Disable Baytrail Core and Module C6 auto-demotion
2014-08-15tools/power turbostat: tweak whitespace in output formatLen Brown
turbostat -S output was off by 1 space before this patch. Signed-off-by: Len Brown <len.brown@intel.com>
2014-08-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull namespace updates from Eric Biederman: "This is a bunch of small changes built against 3.16-rc6. The most significant change for users is the first patch which makes setns drmatically faster by removing unneded rcu handling. The next chunk of changes are so that "mount -o remount,.." will not allow the user namespace root to drop flags on a mount set by the system wide root. Aks this forces read-only mounts to stay read-only, no-dev mounts to stay no-dev, no-suid mounts to stay no-suid, no-exec mounts to stay no exec and it prevents unprivileged users from messing with a mounts atime settings. I have included my test case as the last patch in this series so people performing backports can verify this change works correctly. The next change fixes a bug in NFS that was discovered while auditing nsproxy users for the first optimization. Today you can oops the kernel by reading /proc/fs/nfsfs/{servers,volumes} if you are clever with pid namespaces. I rebased and fixed the build of the !CONFIG_NFS_FS case yesterday when a build bot caught my typo. Given that no one to my knowledge bases anything on my tree fixing the typo in place seems more responsible that requiring a typo-fix to be backported as well. The last change is a small semantic cleanup introducing /proc/thread-self and pointing /proc/mounts and /proc/net at it. This prevents several kinds of problemantic corner cases. It is a user-visible change so it has a minute chance of causing regressions so the change to /proc/mounts and /proc/net are individual one line commits that can be trivially reverted. Unfortunately I lost and could not find the email of the original reporter so he is not credited. From at least one perspective this change to /proc/net is a refgression fix to allow pthread /proc/net uses that were broken by the introduction of the network namespace" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: proc: Point /proc/mounts at /proc/thread-self/mounts instead of /proc/self/mounts proc: Point /proc/net at /proc/thread-self/net instead of /proc/self/net proc: Implement /proc/thread-self to point at the directory of the current thread proc: Have net show up under /proc/<tgid>/task/<tid> NFS: Fix /proc/fs/nfsfs/servers and /proc/fs/nfsfs/volumes mnt: Add tests for unprivileged remount cases that have found to be faulty mnt: Change the default remount atime from relatime to the existing value mnt: Correct permission checks in do_remount mnt: Move the test for MNT_LOCK_READONLY from change_mount_flags into do_remount mnt: Only change user settable mount flags in remount namespaces: Use task_lock and not rcu to protect nsproxy
2014-08-08selftests: add memfd/sealing page-pinning testsDavid Herrmann
Setting SEAL_WRITE is not possible if there're pending GUP users. This commit adds selftests for memfd+sealing that use FUSE to create pending page-references. FUSE is very helpful here in that it allows us to delay direct-IO operations for an arbitrary amount of time. This way, we can force the kernel to pin pages and then run our normal selftests. Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Ryan Lortie <desrt@desrt.ca> Cc: Lennart Poettering <lennart@poettering.net> Cc: Daniel Mack <zonque@gmail.com> Cc: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08selftests: add memfd_create() + sealing testsDavid Herrmann
Some basic tests to verify sealing on memfds works as expected and guarantees the advertised semantics. Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Ryan Lortie <desrt@desrt.ca> Cc: Lennart Poettering <lennart@poettering.net> Cc: Daniel Mack <zonque@gmail.com> Cc: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08tools/testing/selftests/ptrace/peeksiginfo.c: add PAGE_SIZE definitionThierry Fauck
On IBM powerpc where multiple page size value are supported, current ppc64 and ppc64el distro don't define the PAGE_SIZE variable in /usr/include as this is a dynamic value retrieved by the getpagesize() or sysconf() defined in unistd.h. The PAGE_SIZE variable sounds defined when only one value is supported by the kernel. As such, when the PAGE_SIZE definition doesn't exist system should retrieve the dynamic value. Signed-off-by: Thierry Fauck <thierry@linux.vnet.ibm.com> Cc: Andrey Vagin <avagin@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-07Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Ben Herrenschmidt: "This is the powerpc new goodies for 3.17. The short story: The biggest bit is Michael removing all of pre-POWER4 processor support from the 64-bit kernel. POWER3 and rs64. This gets rid of a ton of old cruft that has been bitrotting in a long while. It was broken for quite a few versions already and nobody noticed. Nobody uses those machines anymore. While at it, he cleaned up a bunch of old dusty cabinets, getting rid of a skeletton or two. Then, we have some base VFIO support for KVM, which allows assigning of PCI devices to KVM guests, support for large 64-bit BARs on "powernv" platforms, support for HMI (Hardware Management Interrupts) on those same platforms, some sparse-vmemmap improvements (for memory hotplug), There is the usual batch of Freescale embedded updates (summary in the merge commit) and fixes here or there, I think that's it for the highlights" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (102 commits) powerpc/eeh: Export eeh_iommu_group_to_pe() powerpc/eeh: Add missing #ifdef CONFIG_IOMMU_API powerpc: Reduce scariness of interrupt frames in stack traces powerpc: start loop at section start of start in vmemmap_populated() powerpc: implement vmemmap_free() powerpc: implement vmemmap_remove_mapping() for BOOK3S powerpc: implement vmemmap_list_free() powerpc: Fail remap_4k_pfn() if PFN doesn't fit inside PTE powerpc/book3s: Fix endianess issue for HMI handling on napping cpus. powerpc/book3s: handle HMIs for cpus in nap mode. powerpc/powernv: Invoke opal call to handle hmi. powerpc/book3s: Add basic infrastructure to handle HMI in Linux. powerpc/iommu: Fix comments with it_page_shift powerpc/powernv: Handle compound PE in config accessors powerpc/powernv: Handle compound PE for EEH powerpc/powernv: Handle compound PE powerpc/powernv: Split ioda_eeh_get_state() powerpc/powernv: Allow to freeze PE powerpc/powernv: Enable M64 aperatus for PHB3 powerpc/eeh: Aux PE data for error log ...
2014-08-06Merge tag 'pm+acpi-3.17-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "Again, ACPICA leads the pack (47 commits), followed by cpufreq (18 commits) and system suspend/hibernation (9 commits). From the new code perspective, the ACPICA update brings ACPI 5.1 to the table, including a new device configuration object called _DSD (Device Specific Data) that will hopefully help us to operate device properties like Device Trees do (at least to some extent) and changes related to supporting ACPI on ARM. Apart from that we have hibernation changes making it use radix trees to store memory bitmaps which should speed up some operations carried out by it quite significantly. We also have some power management changes related to suspend-to-idle (the "freeze" sleep state) support and more preliminary changes needed to support ACPI on ARM (outside of ACPICA). The rest is fixes and cleanups pretty much everywhere. Specifics: - ACPICA update to upstream version 20140724. That includes ACPI 5.1 material (support for the _CCA and _DSD predefined names, changes related to the DMAR and PCCT tables and ARM support among other things) and cleanups related to using ACPICA's header files. A major part of it is related to acpidump and the core code used by that utility. Changes from Bob Moore, David E Box, Lv Zheng, Sascha Wildner, Tomasz Nowicki, Hanjun Guo. - Radix trees for memory bitmaps used by the hibernation core from Joerg Roedel. - Support for waking up the system from suspend-to-idle (also known as the "freeze" sleep state) using ACPI-based PCI wakeup signaling (Rafael J Wysocki). - Fixes for issues related to ACPI button events (Rafael J Wysocki). - New device ID for an ACPI-enumerated device included into the Wildcat Point PCH from Jie Yang. - ACPI video updates related to backlight handling from Hans de Goede and Linus Torvalds. - Preliminary changes needed to support ACPI on ARM from Hanjun Guo and Graeme Gregory. - ACPI PNP core cleanups from Arjun Sreedharan and Zhang Rui. - Cleanups related to ACPI_COMPANION() and ACPI_HANDLE() macros (Rafael J Wysocki). - ACPI-based device hotplug cleanups from Wei Yongjun and Rafael J Wysocki. - Cleanups and improvements related to system suspend from Lan Tianyu, Randy Dunlap and Rafael J Wysocki. - ACPI battery cleanup from Wei Yongjun. - cpufreq core fixes from Viresh Kumar. - Elimination of a deadband effect from the cpufreq ondemand governor and intel_pstate driver cleanups from Stratos Karafotis. - 350MHz CPU support for the powernow-k6 cpufreq driver from Mikulas Patocka. - Fix for the imx6 cpufreq driver from Anson Huang. - cpuidle core and governor cleanups from Daniel Lezcano, Sandeep Tripathy and Mohammad Merajul Islam Molla. - Build fix for the big_little cpuidle driver from Sachin Kamat. - Configuration fix for the Operation Performance Points (OPP) framework from Mark Brown. - APM cleanup from Jean Delvare. - cpupower utility fixes and cleanups from Peter Senna Tschudin, Andrey Utkin, Himangi Saraogi, Rickard Strandqvist, Thomas Renninger" * tag 'pm+acpi-3.17-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (118 commits) ACPI / LPSS: add LPSS device for Wildcat Point PCH ACPI / PNP: Replace faulty is_hex_digit() by isxdigit() ACPICA: Update version to 20140724. ACPICA: ACPI 5.1: Update for PCCT table changes. ACPICA/ARM: ACPI 5.1: Update for GTDT table changes. ACPICA/ARM: ACPI 5.1: Update for MADT changes. ACPICA/ARM: ACPI 5.1: Update for FADT changes. ACPICA: ACPI 5.1: Support for the _CCA predifined name. ACPICA: ACPI 5.1: New notify value for System Affinity Update. ACPICA: ACPI 5.1: Support for the _DSD predefined name. ACPICA: Debug object: Add current value of Timer() to debug line prefix. ACPICA: acpihelp: Add UUID support, restructure some existing files. ACPICA: Utilities: Fix local printf issue. ACPICA: Tables: Update for DMAR table changes. ACPICA: Remove some extraneous printf arguments. ACPICA: Update for comments/formatting. No functional changes. ACPICA: Disassembler: Add support for the ToUUID opererator (macro). ACPICA: Remove a redundant cast to acpi_size for ACPI_OFFSET() macro. ACPICA: Work around an ancient GCC bug. ACPI / processor: Make it possible to get local x2apic id via _MAT ...
2014-08-05Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer and time updates from Thomas Gleixner: "A rather large update of timers, timekeeping & co - Core timekeeping code is year-2038 safe now for 32bit machines. Now we just need to fix all in kernel users and the gazillion of user space interfaces which rely on timespec/timeval :) - Better cache layout for the timekeeping internal data structures. - Proper nanosecond based interfaces for in kernel users. - Tree wide cleanup of code which wants nanoseconds but does hoops and loops to convert back and forth from timespecs. Some of it definitely belongs into the ugly code museum. - Consolidation of the timekeeping interface zoo. - A fast NMI safe accessor to clock monotonic for tracing. This is a long standing request to support correlated user/kernel space traces. With proper NTP frequency correction it's also suitable for correlation of traces accross separate machines. - Checkpoint/restart support for timerfd. - A few NOHZ[_FULL] improvements in the [hr]timer code. - Code move from kernel to kernel/time of all time* related code. - New clocksource/event drivers from the ARM universe. I'm really impressed that despite an architected timer in the newer chips SoC manufacturers insist on inventing new and differently broken SoC specific timers. [ Ed. "Impressed"? I don't think that word means what you think it means ] - Another round of code move from arch to drivers. Looks like most of the legacy mess in ARM regarding timers is sorted out except for a few obnoxious strongholds. - The usual updates and fixlets all over the place" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (114 commits) timekeeping: Fixup typo in update_vsyscall_old definition clocksource: document some basic timekeeping concepts timekeeping: Use cached ntp_tick_length when accumulating error timekeeping: Rework frequency adjustments to work better w/ nohz timekeeping: Minor fixup for timespec64->timespec assignment ftrace: Provide trace clocks monotonic timekeeping: Provide fast and NMI safe access to CLOCK_MONOTONIC seqcount: Add raw_write_seqcount_latch() seqcount: Provide raw_read_seqcount() timekeeping: Use tk_read_base as argument for timekeeping_get_ns() timekeeping: Create struct tk_read_base and use it in struct timekeeper timekeeping: Restructure the timekeeper some more clocksource: Get rid of cycle_last clocksource: Move cycle_last validation to core code clocksource: Make delta calculation a function wireless: ath9k: Get rid of timespec conversions drm: vmwgfx: Use nsec based interfaces drm: i915: Use nsec based interfaces timekeeping: Provide ktime_get_raw() hangcheck-timer: Use ktime_get_ns() ...
2014-08-05Merge branch 'pm-tools'Rafael J. Wysocki
* pm-tools: cpupower: Remove redundant error check cpupower: bench: parse.c: Fix several minor errors cpupower: mperf monitor: Correct use of ! and & cpupower: Adjust MAINTAINERS file PM / tools: cpupower: drop negativity check on unsigned value
2014-08-04Merge tag 'usb-3.17-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB updates from Greg KH: "Here is the big USB driver update for 3.17-rc1. Loads of gadget driver changes in here, including some big file movements to make things easier to manage over time. There's also the usual xhci and uas driver updates, and a handful of other changes in here. The changelog has the full details. All of these have been in linux-next for a while" * tag 'usb-3.17-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (211 commits) USB: devio: fix issue with log flooding uas: Log a warning when we cannot use uas because the hcd lacks streams uas: Only complain about missing sg if all other checks succeed xhci: Add missing checks for xhci_alloc_command failure xhci: Rename Asrock P67 pci product-id to EJ168 xhci: Blacklist using streams on the Etron EJ168 controller uas: Limit qdepth to 32 when connected over usb-2 uwb/whci: use correct structure type name in sizeof usb-core bInterval quirk USB: serial: ftdi_sio: Add support for new Xsens devices USB: serial: ftdi_sio: Annotate the current Xsens PID assignments usb: chipidea: debug: fix sparse non static symbol warnings usb: ci_hdrc_imx doc: fsl,usbphy is required usb: ci_hdrc_imx: Return -EINVAL for missing USB PHY usb: core: allow zero packet flag for interrupt urbs usb: lvstest: Fix sparse warnings generated by kbuild test bot USB: core: hcd-pci: free IRQ before disabling PCI device when shutting down phy: miphy365x: Represent each PHY channel as a DT subnode phy: miphy365x: Provide support for the MiPHY356x Generic PHY phy: miphy365x: Add Device Tree bindings for the MiPHY365x ...
2014-08-04Merge tag 'driver-core-3.17-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg KH: "Here's the big driver-core pull request for 3.17-rc1. Largest thing in here is the dma-buf rework and fence code, that touched many different subsystems so it was agreed it should go through this tree to handle merge issues. There's also some firmware loading updates, as well as tests added, and a few other tiny changes, the changelog has the details. All have been in linux-next for a long time" * tag 'driver-core-3.17-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (32 commits) ARM: imx: Remove references to platform_bus in mxc code firmware loader: Fix _request_firmware_load() return val for fw load abort platform: Remove most references to platform_bus device test: add firmware_class loader test doc: fix minor typos in firmware_class README staging: android: Cleanup style issues Documentation: devres: Sort managed interfaces Documentation: devres: Add devm_kmalloc() et al fs: debugfs: remove trailing whitespace kernfs: kernel-doc warning fix debugfs: Fix corrupted loop in debugfs_remove_recursive stable_kernel_rules: Add pointer to netdev-FAQ for network patches driver core: platform: add device binding path 'driver_override' driver core/platform: remove unused implicit padding in platform_object firmware loader: inform direct failure when udev loader is disabled firmware: replace ALIGN(PAGE_SIZE) by PAGE_ALIGN firmware: read firmware size using i_size_read() firmware loader: allow disabling of udev as firmware loader reservation: add suppport for read-only access using rcu reservation: update api and add some helpers ... Conflicts: drivers/base/platform.c
2014-08-04Merge tag 'char-misc-3.17-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char / misc driver patches from Greg KH: "Here's the big driver misc / char pull request for 3.17-rc1. Lots of things in here, the thunderbolt support for Apple laptops, some other new drivers, testing fixes, and other good things. All have been in linux-next for a long time" * tag 'char-misc-3.17-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (119 commits) misc: bh1780: Introduce the use of devm_kzalloc Lattice ECP3 FPGA: Correct endianness drivers/misc/ti-st: Load firmware from ti-connectivity directory. dt-bindings: extcon: Add support for SM5502 MUIC device extcon: sm5502: Change internal hardware switch according to cable type extcon: sm5502: Detect cable state after completing platform booting extcon: sm5502: Add support new SM5502 extcon device driver extcon: arizona: Get MICVDD against extcon device extcon: Remove unnecessary OOM messages misc: vexpress: Fix sparse non static symbol warnings mei: drop unused hw dependent fw status functions misc: bh1770glc: Use managed functions pcmcia: remove DEFINE_PCI_DEVICE_TABLE usage misc: remove DEFINE_PCI_DEVICE_TABLE usage ipack: Replace DEFINE_PCI_DEVICE_TABLE macro use drivers/char/dsp56k.c: drop check for negativity of unsigned parameter mei: fix return value on disconnect timeout mei: don't schedule suspend in pm idle mei: start disconnect request timer consistently mei: reset client connection state on timeout ...
2014-08-04Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf changes from Ingo Molnar: "Kernel side changes: - Consolidate the PMU interrupt-disabled code amongst architectures (Vince Weaver) - misc fixes Tooling changes (new features, user visible changes): - Add support for pagefault tracing in 'trace', please see multiple examples in the changeset messages (Stanislav Fomichev). - Add pagefault statistics in 'trace' (Stanislav Fomichev) - Add header for columns in 'top' and 'report' TUI browsers (Jiri Olsa) - Add pagefault statistics in 'trace' (Stanislav Fomichev) - Add IO mode into timechart command (Stanislav Fomichev) - Fallback to syscalls:* when raw_syscalls:* is not available in the perl and python perf scripts. (Daniel Bristot de Oliveira) - Add --repeat global option to 'perf bench' to be used in benchmarks such as the existing 'futex' one, that was modified to use it instead of a local option. (Davidlohr Bueso) - Fix fd -> pathname resolution in 'trace', be it using /proc or a vfs_getname probe point. (Arnaldo Carvalho de Melo) - Add suggestion of how to set perf_event_paranoid sysctl, to help non-root users trying tools like 'trace' to get a working environment. (Arnaldo Carvalho de Melo) - Updates from trace-cmd for traceevent plugin_kvm plus args cleanup (Steven Rostedt, Jan Kiszka) - Support S/390 in 'perf kvm stat' (Alexander Yarygin) Tooling infrastructure changes: - Allow reserving a row for header purposes in the hists browser (Arnaldo Carvalho de Melo) - Various fixes and prep work related to supporting Intel PT (Adrian Hunter) - Introduce multiple debug variables control (Jiri Olsa) - Add callchain and additional sample information for python scripts (Joseph Schuchart) - More prep work to support Intel PT: (Adrian Hunter) - Polishing 'script' BTS output - 'inject' can specify --kallsym - VDSO is per machine, not a global var - Expose data addr lookup functions previously private to 'script' - Large mmap fixes in events processing - Include standard stringify macros in power pc code (Sukadev Bhattiprolu) Tooling cleanups: - Convert open coded equivalents to asprintf() (Andy Shevchenko) - Remove needless reassignments in 'trace' (Arnaldo Carvalho de Melo) - Cache the is_exit syscall test in 'trace) (Arnaldo Carvalho de Melo) - No need to reimplement err() in 'perf bench sched-messaging', drop barf(). (Davidlohr Bueso). - Remove ev_name argument from perf_evsel__hists_browse, can be obtained from the other parameters. (Jiri Olsa) Tooling fixes: - Fix memory leak in the 'sched-messaging' perf bench test. (Davidlohr Bueso) - The -o and -n 'perf bench mem' options are mutually exclusive, emit error when both are specified. (Davidlohr Bueso) - Fix scrollbar refresh row index in the ui browser, problem exposed now that headers will be added and will be allowed to be switched on/off. (Jiri Olsa) - Handle the num array type in python properly (Sebastian Andrzej Siewior) - Fix wrong condition for allocation failure (Jiri Olsa) - Adjust callchain based on DWARF debug info on powerpc (Sukadev Bhattiprolu) - Fix a risk for doing free on uninitialized pointer in traceevent lib (Rickard Strandqvist) - Update attr test with PERF_FLAG_FD_CLOEXEC flag (Jiri Olsa) - Enable close-on-exec flag on perf file descriptor (Yann Droneaud) - Fix build on gcc 4.4.7 (Arnaldo Carvalho de Melo) - Event ordering fixes (Jiri Olsa)" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (123 commits) Revert "perf tools: Fix jump label always changing during tracing" perf tools: Fix perf usage string leftover perf: Check permission only for parent tracepoint event perf record: Store PERF_RECORD_FINISHED_ROUND only for nonempty rounds perf record: Always force PERF_RECORD_FINISHED_ROUND event perf inject: Add --kallsyms parameter perf tools: Expose 'addr' functions so they can be reused perf session: Fix accounting of ordered samples queue perf powerpc: Include util/util.h and remove stringify macros perf tools: Fix build on gcc 4.4.7 perf tools: Add thread parameter to vdso__dso_findnew() perf tools: Add dso__type() perf tools: Separate the VDSO map name from the VDSO dso name perf tools: Add vdso__new() perf machine: Fix the lifetime of the VDSO temporary file perf tools: Group VDSO global variables into a structure perf session: Add ability to skip 4GiB or more perf session: Add ability to 'skip' a non-piped event stream perf tools: Pass machine to vdso__dso_findnew() perf tools: Add dso__data_size() ...
2014-08-04Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU changes from Ingo Molar: "The main changes: - torture-test updates - callback-offloading changes - maintainership changes - update RCU documentation - miscellaneous fixes" * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (32 commits) rcu: Allow for NULL tick_nohz_full_mask when nohz_full= missing rcu: Fix a sparse warning in rcu_report_unblock_qs_rnp() rcu: Fix a sparse warning in rcu_initiate_boost() rcu: Fix __rcu_reclaim() to use true/false for bool rcu: Remove CONFIG_PROVE_RCU_DELAY rcu: Use __this_cpu_read() instead of per_cpu_ptr() rcu: Don't use NMIs to dump other CPUs' stacks rcu: Bind grace-period kthreads to non-NO_HZ_FULL CPUs rcu: Simplify priority boosting by putting rt_mutex in rcu_node rcu: Check both root and current rcu_node when setting up future grace period rcu: Allow post-unlock reference for rt_mutex rcu: Loosen __call_rcu()'s rcu_head alignment constraint rcu: Eliminate read-modify-write ACCESS_ONCE() calls rcu: Remove redundant ACCESS_ONCE() from tick_do_timer_cpu rcu: Make rcu node arrays static const char * const signal: Explain local_irq_save() call rcu: Handle obsolete references to TINY_PREEMPT_RCU rcu: Document deadlock-avoidance information for rcu_read_unlock() scripts: Teach get_maintainer.pl about the new "R:" tag rcu: Update rcu torture maintainership filename patterns ...
2014-08-04Merge tag 'ktest-v3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest Pull config-bisect changes from Steven Rostedt: "The big change here is the rewrite of config-bisect. The old way never worked properly as it assumed the bad config was a subset of the good config, and just found the config that would break the build. The new way does a diff of the bad config verses the good config and makes the similar until it finds that one config works and the other does not and reports the config that makes that difference. The two configs do not need to be related. It is much more useful now: * tag 'ktest-v3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest: ktest: Update documentation on config_bisect ktest: Add the config bisect manual back ktest: Remove unused functions ktest: Put back in the CONFIG_BISECT_CHECK ktest: Rewrite the config-bisect to actually work ktest: Some cleanup for improving readability ktest: add 2nd parameter of run_command() to set the redirect target file
2014-07-31mnt: Add tests for unprivileged remount cases that have found to be faultyEric W. Biederman
Kenton Varda <kenton@sandstorm.io> discovered that by remounting a read-only bind mount read-only in a user namespace the MNT_LOCK_READONLY bit would be cleared, allowing an unprivileged user to the remount a read-only mount read-write. Upon review of the code in remount it was discovered that the code allowed nosuid, noexec, and nodev to be cleared. It was also discovered that the code was allowing the per mount atime flags to be changed. The first naive patch to fix these issues contained the flaw that using default atime settings when remounting a filesystem could be disallowed. To avoid this problems in the future add tests to ensure unprivileged remounts are succeeding and failing at the appropriate times. Cc: stable@vger.kernel.org Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2014-07-30cpupower: Remove redundant error checkPeter Senna Tschudin
Remove double checks, and move the call to print_error to the first check. Replace break by return, and return 0 on success. The simplified version of the coccinelle semantic patch that fixes this issue is as follows: // <smpl> @@ expression E; identifier pr; expression list es; @@ for(...;...;...){ ... - if (E) break; + if (E){ + pr(es); + break; + } ... } - if(E) pr(es); // </smpl> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-07-30cpupower: bench: parse.c: Fix several minor errorsRickard Strandqvist
Resolved several minor errors in prepare_config() and made some additional improvements. Earlier, the risk of file stream that was not closed. Misuse of strncpy, and the use of strncmp with strlen that makes it pointless. I also check that sscanf has been successful, otherwise continue to the next line. And minimized the use of magic numbers. This was found using a static code analysis program called cppcheck. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-07-30cpupower: mperf monitor: Correct use of ! and &Himangi Saraogi
In commit ae91d60ba88ef0bdb1b5e9b2363bd52fc45d2af7, a bug was fixed that involved converting !x & y to !(x & y). The code below shows the same pattern, and thus should perhaps be fixed in the same way. The Coccinelle semantic patch that makes this change is as follows: // <smpl> @@ expression E1,E2; @@ ( !E1 & !E2 | - !E1 & E2 + !(E1 & E2) ) // </smpl> Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-07-28Revert "perf tools: Fix jump label always changing during tracing"Jiri Olsa
This reverts commit deaff8b659cf4d34181c087b8cdf74f1eb17b02b. This commit makes CLOEXEC feature undetected for normal users, because per-cpu events are priviledged. Reported-by: Peter Zijlstra <peterz@infradead.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/20140728065844.GK6758@twins.programming.kicks-ass.net Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-07-28perf tools: Fix perf usage string leftoverJiri Olsa
Fixing perf usage string leftover pointed out by Namhyung. Reported-by: Namhyung Kim <namhyung@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-vkcf53oultknsh3ue9fhin94@git.kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-07-28Merge tag 'perf-core-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/core Pull perf/core improvements and fixes from Arnaldo Carvalho de Melo: Infrastructure changes: o More prep work to support Intel PT: (Adrian Hunter) - Polishing 'script' BTS output - 'inject' can specify --kallsym - VDSO is per machine, not a global var - Expose data addr lookup functions previously private to 'script' - Large mmap fixes in events processing o Fix build on gcc 4.4.7 (Arnaldo Carvalho de Melo) o Event ordering fixes (Jiri Olsa) o Include standard stringify macros in power pc code (Sukadev Bhattiprolu) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-07-28Merge tag 'v3.16-rc7' into perf/core, to merge in the latest fixes before ↵Ingo Molnar
applying new changes Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-07-28selftests/powerpc: Add test of per-event excludesMichael Ellerman
Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-07-28selftests/powerpc: Add a routine for retrieving an AUXV entryMichael Ellerman
2014-07-28selftests/powerpc: Add cycles test with MMCR2 handlingMichael Ellerman
2014-07-28selftests/powerpc: Dump MMCR2 as part of the EBB HW stateMichael Ellerman
2014-07-28selftests/powerpc: Count more instructions & use decimalMichael Ellerman
Although we expect some small discrepancies for very large counts, we seem to be able to count up to 64 billion instructions without too much skew, so do so. Also switch to using decimals for the instruction counts. This just makes it easier to visually compare the expected vs actual values, as well as the raw result from instructions. Before: instructions: result 68719476753 running/enabled 13101961654 cycles: result 38077343785 running/enabled 13101725752 Looped for 68719476736 instructions, overhead 17 Expected 68719476753 Actual 68719476753 Delta 0, 0.000000% success: count_instructions After: instructions: result 64000000016 running/enabled 12197599964 cycles: result 35412471674 running/enabled 12197534110 Looped for 64000000000 instructions, overhead 16 Expected 64000000016 Actual 64000000016 Delta 0, 0.000000% success: count_instructions Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-07-28selftests/powerpc: Count instructions under scheduler pressureMichael Ellerman
Have a task eat some cpu while we are counting instructions to create some scheduler pressure. The idea being to try and unearth any bugs we have in counting that only appear when context switching is happening. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-07-28selftests/powerpc: Add test of L3 bank handlingMichael Ellerman
2014-07-28selftests/powerpc: Move core_busy_loop() into asmMichael Ellerman
There is at least one bug in core_busy_loop(), we use r0, but it's not in the clobber list. We were getting away with this it seems but that was luck. It's also fishy to be touching the stack, even if we do it below the stack pointer. It seems we get away with it, but looking at the generated code that may just be luck. So move it into assembler, do all the stack handling by hand. We create a stack frame to save the non-volatiles in, so we can muck around with them. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-07-28selftests/powerpc: Fix parse_proc_maps()Michael Ellerman
start and end should be unsigned long. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-07-28selftests/powerpc: Don't ignore errors from sub MakefilesMichael Ellerman
Currently we ignore errors from our sub Makefiles. We inherited that from the top-level selftests Makefile which aims to build and run as many tests as possible and damn the torpedoes. For the powerpc tests we'd instead like any errors to fail the build, so we can automatically catch build failures. We can achieve the best of both worlds by using -k, which tells make to keep building when it hits an error, but still reports the error. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-07-27Merge branch 'acpica'Rafael J. Wysocki
* acpica: (30 commits) ACPICA: Add new GPE public interface - acpi_mark_gpe_for_wake. ACPICA: GPEs: Do not allow enable for GPEs that have no handler(s). ACPICA: Fix a regression for deletion of Alias() objects. ACPICA: Update version to 20140627 ACPICA: Tables: Merge DMAR table structure updates ACPICA: Hardware: back port of a recursive locking fix ACPICA: utprint/oslibcfs: cleanup - no functional change ACPICA: Executer: Fix trivial issues in acpi_get_serial_access_bytes() ACPICA: OSL: Update acpidump to reduce source code differences ACPICA: acpidump: Reduce freopen() invocations to improve portability ACPICA: acpidump: Replace file IOs with new APIs to improve portability ACPICA: acpidump: Remove exit() from generic layer to improve portability ACPICA: acpidump: Add memory/string OSL usage to improve portability ACPICA: Common: Enhance acpi_getopt() to improve portability ACPICA: Common: Enhance cm_get_file_size() to improve portability ACPICA: Application: Enhance ACPI_USAGE_xxx/ACPI_OPTION with acpi_os_printf() to improve portability ACPICA: Utilities: Introduce acpi_log_error() to improve portability ACPICA: Utilities: Add formatted printing APIs ACPICA: OSL: Add portable file IO to improve portability ACPICA: OSL: Clean up acpi_os_printf()/acpi_os_vprintf() stubs ...
2014-07-25perf record: Store PERF_RECORD_FINISHED_ROUND only for nonempty roundsJiri Olsa
Currently we store PERF_RECORD_FINISHED_ROUND event each time we go throught mmap buffers no matter if it contains any data, which is useless. Forcing the PERF_RECORD_FINISHED_ROUND event to be stored any time we finished the round AND wrote at least one event. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Adrian Hunter <adrian.hunter@intel.com> Acked-by: David Ahern <dsahern@gmail.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1406300177-31805-19-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-07-25perf record: Always force PERF_RECORD_FINISHED_ROUND eventJiri Olsa
The PERF_RECORD_FINISHED_ROUND synthetic record governs queue flushing in reporting, so it needs to be stored for any kind of event. The lack of such periodic flushing made the tools use more memory than needed, as the reordering was being done only after processing all events. This was the case when no tracepoints were in the mix. Forcing the PERF_RECORD_FINISHED_ROUND event to be stored for all event types. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Adrian Hunter <adrian.hunter@intel.com> Acked-by: David Ahern <dsahern@gmail.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1406300177-31805-18-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-07-25perf inject: Add --kallsyms parameterAdrian Hunter
Let perf inject take --kallsyms parameter the same as perf script and perf report do. That is needed for decoding Instruction Trace data using a copy of /proc/kcore for the kernel object because the kallsyms path is used to locate that copy. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1406035081-14301-30-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-07-25perf tools: Expose 'addr' functions so they can be reusedAdrian Hunter
Move some functions and functionality related to the use of 'addr' out of builtin-script so they can be reused. The moved functions are: is_bts_event() and sample_addr_correlates_sym() and a new function perf_event__preprocess_sample_addr() is created from bits of print_sample_addr(). perf_event__preprocess_sample_addr() is the equivalent of perf_event__preprocess_sample() but for 'addr' instead of 'ip'. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1406035081-14301-31-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-07-24perf session: Fix accounting of ordered samples queueJiri Olsa
Properly account flushed samples within the ordered samples queue. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Adrian Hunter <adrian.hunter@intel.com> Acked-by: David Ahern <dsahern@gmail.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1405893363-21967-2-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-07-24perf powerpc: Include util/util.h and remove stringify macrosSukadev Bhattiprolu
The stringify macros are defined in tools/perf/util/util.h and don't need to be redfined specfiically for powerpc. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Michael Ellerman <michaele@au1.ibm.com> Link: http://lkml.kernel.org/r/20140724074718.GB18829@us.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-07-23perf tools: Fix build on gcc 4.4.7Arnaldo Carvalho de Melo
[acme@sandy linux]$ gcc --version gcc (GCC) 4.4.7 20120313 (Red Hat 4.4.7-3) Copyright (C) 2010 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. [acme@sandy linux]$ make O=/tmp/build/perf -C tools/perf install-bin <SNIP> CC /tmp/build/perf/builtin-trace.o builtin-trace.c: In function ‘perf_evlist__add_pgfault’: builtin-trace.c:1997: error: unknown field ‘sample_period’ specified in initializer make[1]: *** [/tmp/build/perf/builtin-trace.o] Error 1 make: *** [install-bin] Error 2 make: Leaving directory `/home/acme/git/linux/tools/perf' [acme@sandy linux]$ make O=/tmp/build/perf -C tools/perf install-bin make O=/tmp/build/perf -C tools/perf install-bin make: Entering directory `/home/acme/git/linux/tools/perf' Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-qt7h2g5fcf42qiw5hv7mgpjk@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-07-23perf tools: Add thread parameter to vdso__dso_findnew()Adrian Hunter
The thread will be needed to determine the VDSO type. Reviewed-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1406035081-14301-52-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-07-23perf tools: Add dso__type()Adrian Hunter
dso__type() determines wheather a dso is 32-bit, x32 (32-bit with 64-bit registers) or 64-bit. dso__type() will be used to determine the VDSO a program maps. Reviewed-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1406035081-14301-51-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-07-23perf tools: Separate the VDSO map name from the VDSO dso nameAdrian Hunter
This is in preparation for supporting 32-bit compatibility VDSOs. Reviewed-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1406035081-14301-49-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-07-23perf tools: Add vdso__new()Adrian Hunter
This is preparation for adding support for compat VDSOs. Reviewed-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1406035081-14301-48-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-07-23perf machine: Fix the lifetime of the VDSO temporary fileAdrian Hunter
The VDSO temporary file is unlinked when a session is deleted. That precludes the possibilities that there is no session or there is more than one session. Correctly the vdso belongs to the machine so put the information on 'struct machine' and get rid of the global variables. Reviewed-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/53CF9B14.7040408@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
