path: root/tools
2010-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (229 commits) USB: remove unused usb_buffer_alloc and usb_buffer_free macros usb: musb: update gfp/slab.h includes USB: ftdi_sio: fix legacy SIO-device header USB: kl5usb105: reimplement using generic framework USB: kl5usb105: minor clean ups USB: kl5usb105: fix memory leak USB: io_ti: use kfifo to implement write buffering USB: io_ti: remove unsused private counter USB: ti_usb: use kfifo to implement write buffering USB: ir-usb: fix incorrect write-buffer length USB: aircable: fix incorrect write-buffer length USB: safe_serial: straighten out read processing USB: safe_serial: reimplement read using generic framework USB: safe_serial: reimplement write using generic framework usb-storage: always print quirks USB: usb-storage: trivial debug improvements USB: oti6858: use port write fifo USB: oti6858: use kfifo to implement write buffering USB: cypress_m8: use kfifo to implement write buffering USB: cypress_m8: remove unused drain define ... Fix up conflicts (due to usb_buffer_alloc/free renaming) in drivers/input/tablet/acecad.c drivers/input/tablet/kbtab.c drivers/input/tablet/wacom_sys.c drivers/media/video/gspca/gspca.c sound/usb/usbaudio.c
2010-05-20USB: testusb: testusb compatibility with FunctionFS gadgetMichal Nazarewicz
The FunctionFS gadget may provide the source/sink interface not as the first interface (with id == 0) but some different interface hence a code to find the interface number is required. (Note that you will still configure the gadget to report idProduct == 0xa4a4 (an "echo 0xa4a4 >/sys/module/g_ffs/parameters/usb_product" should suffice) or configure host to handle 0x0525:0xa4ac devices using the usbtest driver.) Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: testusb: an USB testing applicationDavid Brownell
The testusb program just issues ioctls to perform the tests implemented by the kernel driver. It can generate a variety of transfer patterns; you should make sure to test both regular streaming and mixes of transfer sizes (including short transfers). For more information on how this can be used and on USB testing refer to <URL:http://www.linux-usb.org/usbtest/>. Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: ffs-test: FunctionFS testing programMichal Nazarewicz
This adds an example user-space FunctionFS driver which implements a source/sink interface used for testing. Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-18Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (311 commits) perf tools: Add mode to build without newt support perf symbols: symbol inconsistency message should be done only at verbose=1 perf tui: Add explicit -lslang option perf options: Type check all the remaining OPT_ variants perf options: Type check OPT_BOOLEAN and fix the offenders perf options: Check v type in OPT_U?INTEGER perf options: Introduce OPT_UINTEGER perf tui: Add workaround for slang < 2.1.4 perf record: Fix bug mismatch with -c option definition perf options: Introduce OPT_U64 perf tui: Add help window to show key associations perf tui: Make <- exit menus too perf newt: Add single key shortcuts for zoom into DSO and threads perf newt: Exit browser unconditionally when CTRL+C, q or Q is pressed perf newt: Fix the 'A'/'a' shortcut for annotate perf newt: Make <- exit the ui_browser x86, perf: P4 PMU - fix counters management logic perf newt: Make <- zoom out filters perf report: Report number of events, not samples perf hist: Clarify events_stats fields usage ... Fix up trivial conflicts in kernel/fork.c and tools/perf/builtin-record.c
2010-05-17perf tools: Add mode to build without newt supportArnaldo Carvalho de Melo
make NO_NEWT=1 Will avoid building the newt (tui) support. Suggested-by: Ingo Molnar <mingo@elte.hu> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-17perf symbols: symbol inconsistency message should be done only at verbose=1Arnaldo Carvalho de Melo
That happened for an old perf.data file that had no fake MMAP events for the kernel modules, but even then it should warn once for each module, not one time for every symbol in every module not found. Reported-by: Ingo Molnar <mingo@elte.hu> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-17perf tui: Add explicit -lslang optionArnaldo Carvalho de Melo
At least on rawhide using -lnewt is not enough if we use SLang routines directly, so add an explicit -lslang since we use SLang routines. Reported-by: Ingo Molnar <mingo@elte.hu> Tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-17perf options: Type check all the remaining OPT_ variantsArnaldo Carvalho de Melo
OPT_SET_INT was renamed to OPT_SET_UINT since the only use in these tools is to set something that has an enum type, that is builtin compatible with unsigned int. Several string constifications were done to make OPT_STRING require a const char * type. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-17perf options: Type check OPT_BOOLEAN and fix the offendersArnaldo Carvalho de Melo
2010-05-17perf options: Check v type in OPT_U?INTEGERArnaldo Carvalho de Melo
To avoid problems like the one fixed by Stephane Eranian in 3de29ca, now we'll got this instead: bench/sched-messaging.c:259: error: negative width in bit-field ‘<anonymous>’ bench/sched-messaging.c:261: error: negative width in bit-field ‘<anonymous>’ Which is rather cryptic, but is how BUILD_BUG_ON_ZERO works, so kernel hackers should be already used to this. With it in place found some problems, fixed by changing the affected variables to sensible types or changed some OPT_INTEGER to OPT_UINTEGER. Next csets will go thru converting each of the remaining OPT_ so that review can be made easier by grouping changes per type per patch. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-17perf options: Introduce OPT_UINTEGERArnaldo Carvalho de Melo
For unsigned int options to be parsed, next patches will make use of it. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-17perf tui: Add workaround for slang < 2.1.4Arnaldo Carvalho de Melo
Older versions of the slang library didn't used the 'const' specifier, causing problems with modern compilers of this kind: util/newt.c:252: error: passing argument 1 of ‘SLsmg_printf’ discards qualifiers from pointer target type Fix it by using some wrappers that when needed const the affected parameters back to plain (char *). Reported-by: Lin Ming <ming.m.lin@intel.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Lin Ming <ming.m.lin@intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <20100517145421.GD29052@ghostprotocols.net> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-17perf record: Fix bug mismatch with -c option definitionStephane Eranian
The -c option defines the user requested sampling period. It was implemented using an unsigned int variable but the type of the option was OPT_LONG. Thus, the option parser was overwriting memory belonging to other variables, namely the mmap_pages leading to a zero page sampling buffer. The bug was exposed only when compiling at -O0, probably because the compiler was padding variables at higher optimization levels. This patch fixes this problem by declaring user_interval as u64. This also avoids wrap-around issues for large period on 32-bit systems. Commiter note: Made it use OPT_U64(user_interval) after implementing OPT_U64 in the previous patch. Cc: David S. Miller <davem@davemloft.net> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <4bf11ae9.e88cd80a.06b0.ffffa8e3@mx.google.com> Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-17perf options: Introduce OPT_U64Arnaldo Carvalho de Melo
We have things like user_interval (-c/--count) in 'perf record' that needs this. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-16perf tui: Add help window to show key associationsArnaldo Carvalho de Melo
Suggested-by: Ingo Molnar <mingo@elte.hu> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-16perf tui: Make <- exit menus tooArnaldo Carvalho de Melo
In fact it is now added to the hot key list when newt_form__new is used, allowing us to remove the explicit assignment in all its users. The visible change is that <- will exit the menu that pops up when -> is pressed (and Enter when callchains are not being used). Suggested-by: Ingo Molnar <mingo@elte.hu> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-15perf newt: Add single key shortcuts for zoom into DSO and threadsArnaldo Carvalho de Melo
'D'/'d' for zooming into the DSO in the current highlighted hist entry, 'T'/'t' for zooming into the current thread. Suggested-by: Ingo Molnar <mingo@elte.hu> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-15perf newt: Exit browser unconditionally when CTRL+C, q or Q is pressedArnaldo Carvalho de Melo
ESC still asks for confirmation. Suggested-by: Ingo Molnar <mingo@elte.hu> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-15perf newt: Fix the 'A'/'a' shortcut for annotateArnaldo Carvalho de Melo
Reported-by: Ingo Molnar <mingo@elte.hu> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-15perf newt: Make <- exit the ui_browserArnaldo Carvalho de Melo
Right now that means that pressing the left arrow willl make the symbol annotation window to exit back to the main symbol histogram browser. This is another improvement on the UI fastpath, i.e. just the arrows and enter are enough for most browsing. Suggested-by: Ingo Molnar <mingo@elte.hu> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-14perf newt: Make <- zoom out filtersArnaldo Carvalho de Melo
After we use the filters to zoom into DSOs or threads, we can use <- (left arrow) to zoom out from the last filter applied. It is still possible to zoom out of order by using the popup menu. With this we now have the zoom out operation on the browsing fast path, by allowing fast navigation using just the four arrors and the enter key to expand collapse callchains. Suggested-by: Ingo Molnar <mingo@elte.hu> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-14perf report: Report number of events, not samplesArnaldo Carvalho de Melo
Number of samples is meaningless after we switched to auto-freq, so report the number of events, i.e. not the sum of the different periods, but the number PERF_RECORD_SAMPLE emitted by the kernel. While doing this I noticed that naming "count" to the sum of all the event periods can be confusing, so rename it to .period, just like in struct sample.data, so that we become more consistent. This helps with the next step, that was to record in struct hist_entry the number of sample events for each instance, we need that because we use it to generate the number of events when applying filters to the tree of hist entries like it is being done in the TUI report browser. Suggested-by: Ingo Molnar <mingo@elte.hu> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-14perf hist: Clarify events_stats fields usageArnaldo Carvalho de Melo
The events_stats.total field is too generic, rename it to .total_period, and also add a comment explaining that it is the sum of all the .period fields in samples, that is needed because we use auto-freq to avoid sampling artifacts. Ditto for events_stats.lost, that is the sum of all lost_event.lost fields, i.e. the number of events the kernel dropped. Looking at the users, builtin-sched.c can make use of these fields and stop doing it again. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-14perf hist: Make event__totals per histsArnaldo Carvalho de Melo
This is one more thing that started global but are more useful per hist or per session. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-13perf trace scripts: Fix typos in perf-trace-python.txtKirill Smelkov
option option -> option special special -> special Signed-off-by: Kirill Smelkov <kirr@mns.spb.ru> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <1273747165-17242-1-git-send-email-kirr@mns.spb.ru> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-13perf tools: change event inheritance logic in stat and recordStephane Eranian
By default, event inheritance across fork and pthread_create was on but the -i option of stat and record, which enabled inheritance, led to believe it was off by default. This patch fixes this logic by inverting the meaning of the -i option. By default inheritance is on whether you attach to a process (-p), a thread (-t) or start a process. If you pass -i, then you turn off inheritance. Turning off inheritance if you don't need it, helps limit perf resource usage as well. The patch also fixes perf stat -t xxxx and perf record -t xxxx which did not start the counters. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: David S. Miller <davem@davemloft.net> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <4bea9d2f.d60ce30a.0b5b.08e1@mx.google.com> Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-13perf hist: Fix missing getline declarationFrederic Weisbecker
hist.c needs to include util.h so that it gets stdio.h inclusion with __GNU_SOURCE defined. Fixes: util/hist.c: In function ‘hist_entry__parse_objdump_line’: util/hist.c:931: erreur: implicit declaration of function ‘getline’ util/hist.c:931: erreur: nested extern declaration of ‘getline’ Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1273772836-11533-1-git-send-regression-fweisbec@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-13perf hist: Fix hists__browse no-newt caseFrederic Weisbecker
Fix mistake in a parameter type of the no-newt hists__browse() version. Fixes: builtin-report.c: In function ‘__cmd_report’: builtin-report.c:314: erreur: incompatible type for argument 1 of ‘hists__browse’ Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1273771378-8577-1-git-send-regression-fweisbec@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-13perf record: Add a fallback to the reference relocation symbolArnaldo Carvalho de Melo
Usually "_text" is enough, but I received reports that its not always available, so fallback to "_stext" for the symbol we use to check if we need to apply any relocation to all the symbols in the kernel symtab, for when, for instance, kexec is being used. Reported-by: Darren Hart <dvhltc@us.ibm.com> Reported-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-11perf report: Librarize the annotation code and use it in the newt browserArnaldo Carvalho de Melo
Now we don't anymore use popen to run 'perf annotate' for the selected symbol, instead we collect per address samplings when processing samples in 'perf report' if we're using the newt browser, then we use this data directly to do annotation. Done this way we can actually traverse the objdump_line objects directly, matching the addresses to the collected samples and colouring them appropriately using lower level slang routines. The new ui_browser class will be reused for the main, callchain aware, histogram browser, when it will be made generic and don't assume that the objects are always instances of the objdump_line class maintained using list_heads. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-11perf ui: Add ui_helpline methodsArnaldo Carvalho de Melo
Initially this was just to be able to have a printf like method to prepare the formatted string and then pass to newtPushHelpLine, but as we already have for ui_progress, etc, its a step in identifying a restricted, highlevel set of widgets we can then have implementations for multiple widget sets (GTK, etc). Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-11perf symbols: allow forcing use of cplus_demangleKyle McMartin
For Fedora, I want to force perf to link against libiberty.a for cplus_demangle, rather than libbfd.a for bfd_demangle due to licensing insanity on binutils. (libiberty is LGPL2, libbfd is GPL3.) If we just rely on autodetection, we'll end up with libbfd linked against us, since they're both in binutils-static in the buildroot. Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <20100510204335.GA7565@bombadil.infradead.org> Signed-off-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-11perf probe: Check older elfutils and set NO_DWARFMasami Hiramatsu
Check whether elfutils is older than 0.138 (from which version checking routine has been introduced). And if so, set NO_DWARF because it is hard to check the API dependency without version checking. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Reported-by: Robert Richter <robert.richter@amd.com> Cc: Robert Richter <robert.richter@amd.com> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <20100511045953.9913.19485.stgit@localhost6.localdomain6> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-11perf hist: Adopt filter by dso and by thread methods from the newt browserArnaldo Carvalho de Melo
Those are really not specific to the newt code, can be used by other UI frontends. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-11perf: Fix static strings treated like dynamic onesFrederic Weisbecker
The raw_field_ptr() helper, used to retrieve the address of a field inside a trace event, treats every strings as if they were dynamic ie: having a secondary level of indirection to retrieve their contents. FIELD_IS_STRING doesn't mean FIELD_IS_DYNAMIC, we only need to compute the secondary dereference for the latter case. This fixes perf sched segfaults, bad cmdline report and may be some other bugs. Reported-by: Jason Baron <jbaron@redhat.com> Reported-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Tom Zanussi <tzanussi@gmail.com>
2010-05-10perf/trace/scripting: syscall-counts script cleanupTom Zanussi
A small fix for the syscall counts script: - silence the match output in the shell script Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1273466820-9330-10-git-send-email-tzanussi@gmail.com> Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-10perf/trace/scripting: syscall-counts-by-pid script cleanupTom Zanussi
A small fix for the syscall counts by pid script: - silence the match output in the shell script Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1273466820-9330-9-git-send-email-tzanussi@gmail.com> Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-10perf/trace/scripting: failed-syscalls-by-pid script cleanupTom Zanussi
A small fixe for the failed syscalls by pid script: - silence the match output in the shell script Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1273466820-9330-8-git-send-email-tzanussi@gmail.com> Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-10perf/trace/scripting: don't show script start/stop messages by defaultTom Zanussi
Only print the script start/stop messages in verbose mode - users normally don't care and it just clutters up the output. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1273466820-9330-7-git-send-email-tzanussi@gmail.com> Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-10perf/trace/scripting: workqueue-stats script cleanupTom Zanussi
Some minor fixes for the workqueue-stats script: - Fix nuisance 'use of uninitialized value' warnings Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1273466820-9330-6-git-send-email-tzanussi@gmail.com> Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-10perf/trace/scripting: wakeup-latency script cleanupTom Zanussi
Some minor fixes for the wakeup-latency script: - Fix nuisance 'use of uninitialized value' warnings - Avoid divide-by-zero error Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1273466820-9330-5-git-send-email-tzanussi@gmail.com> Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-10perf/trace/scripting: rwtop script cleanupTom Zanussi
A couple of fixes for the rwtop script: - printing the totals and clearing the hashes in the signal handler eventually leads to various random and serious problems when running the rwtop script continuously. Moving the print_totals() calls to the event handlers solves that problem, and the event handlers are invoked frequently enough that it doesn't affect the timeliness of the output. - Fix nuisance 'use of uninitialized value' warnings Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Message-Id: <1273466820-9330-4-git-send-email-tzanussi@gmail.com> Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-10perf/trace/scripting: rw-by-pid script cleanupTom Zanussi
Some minor fixes for the rw-by-pid script: - Fix nuisance 'use of uninitialized value' warnings - Change the failed read/write sections to sort by error counts Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1273466820-9330-3-git-send-email-tzanussi@gmail.com> Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-10perf/trace/scripting: failed-syscalls script cleanupTom Zanussi
A couple small fixes for the failed syscalls script: - The script description says it can be restricted to a specific comm, make it so. - silence the match output in the shell script Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1273466820-9330-2-git-send-email-tzanussi@gmail.com> Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-10perf hist: Calculate max_sym name len and nr_entriesArnaldo Carvalho de Melo
Better done when we are adding entries, be it initially of when we're re-sorting the histograms. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-10perf hist: Introduce hists class and move lots of methods to itArnaldo Carvalho de Melo
In cbbc79a we introduced support for multiple events by introducing a new "event_stat_id" struct and then made several perf_session methods receive a point to it instead of a pointer to perf_session, and kept the event_stats and hists rb_tree in perf_session. While working on the new newt based browser, I realised that it would be better to introduce a new class, "hists" (short for "histograms"), renaming the "event_stat_id" struct and the perf_session methods that were really "hists" methods, as they manipulate only struct hists members, not touching anything in the other perf_session members. Other optimizations, such as calculating the maximum lenght of a symbol name present in an hists instance will be possible as we add them, avoiding a re-traversal just for finding that information. The rationale for the name "hists" to replace "event_stat_id" is that we may have multiple sets of hists for the same event_stat id, as, for instance, the 'perf diff' tool has, so event stat id is not what characterizes what this struct and the functions that manipulate it do. Cc: Eric B Munson <ebmunson@us.ibm.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-10perf session: create_kernel_maps should use ->host_machineArnaldo Carvalho de Melo
Using machines__create_kernel_maps(..., HOST_KERNEL_ID) it would create another machine instance for the host machine, and since 1f626bc we have it out of the machines rb_tree. Fix it by using machine__create_kernel_maps(&self->host_machine) directly. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-10perf callchains: Use zalloc to allocate objectsArnaldo Carvalho de Melo
2010-05-10perf newt: Use newtAddComponent()Arnaldo Carvalho de Melo
Instead of newtAddComponents(just-one-entry, NULL), that is not needed if, like in this browser, we're adding just one component at a time. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
