path: root/tools
2011-01-12Merge branch 'tools' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'tools' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: tools: create power/x86/x86_energy_perf_policy tools: create power/x86/turbostat
2011-01-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-ktestLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-ktest: (30 commits) ktest: Ask for the manditory config options instead of just failing ktest: Copy the last good and bad configs in config_bisect ktest: For grub reboot, use run_ssh instead of run_command ktest: Added force stop after success and failure ktest: Parse off the directory name in useconfig for failures ktest: Use different temp config name for minconfig ktest: Updated the sample.conf for the latest options ktest: Added compare script to test ktest.pl to sample.conf ktest: Added config_bisect test type ktest/cleanups: Added version 0.2, ssh as options ktest: Output something easy to parse for failure or success ktest: Allow a test case to undefine a default value ktest: Use $output_config instead of typing $outputdir/.config ktest: Write to stdout if no log file is given ktest: Use oldnoconfig instead of yes command ktest: Update the sample config file with more documentation ktest: New TEST_START instead of using [], and use real SHA1s ktest: Add poweroff after halt and powercycle after reboot ktest: Add POST_INSTALL to allow initrds to be created ktest: Added sample.conf, new %default option format ...
2011-01-11Merge branches 'turbostat' and 'x86_energy_perf_policy' into toolsLen Brown
2011-01-11tools: create power/x86/x86_energy_perf_policyLen Brown
MSR_IA32_ENERGY_PERF_BIAS first became available on Westmere Xeon. It is implemented in all Sandy Bridge processors -- mobile, desktop and server. It is expected to become increasingly important in subsequent generations. x86_energy_perf_policy is a user-space utility to set the hardware energy vs performance policy hint in the processor. Most systems would benefit from "x86_energy_perf_policy normal" at system startup, as the hardware default is maximum performance at the expense of energy efficiency. See x86_energy_perf_policy.8 man page for more information. Background: Linux-2.6.36 added "epb" to /proc/cpuinfo to indicate if an x86 processor supports MSR_IA32_ENERGY_PERF_BIAS, without actually modifying the MSR. In March, 2010, Venkatesh Pallipadi proposed a small driver that programmed MSR_IA32_ENERGY_PERF_BIAS, based on the cpufreq governor in use. It also offered a boot-time cmdline option to override. http://lkml.org/lkml/2010/3/4/457 But hiding the hardware policy behind the governor choice was deemed "kinda icky". In June, 2010, I proposed a generic user/kernel API to generalize the power/performance policy trade-off. "RFC: /sys/power/policy_preference" http://lkml.org/lkml/2010/6/16/399 That is my preference for implementing this capability, but I received no support on the list. So in September, 2010, I sent x86_energy_perf_policy.c to LKML, a user-space utility that scribbles directly to the MSR. http://lkml.org/lkml/2010/9/28/246 Here is that same utility, after responding to some review feedback, to live in tools/power/, where it is easily found. Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-11tools: create power/x86/turbostatLen Brown
turbostat is a Linux tool to observe proper operation of Intel(R) Turbo Boost Technology. turbostat displays the actual processor frequency on x86 processors that include APERF and MPERF MSRs. Note that turbostat is of limited utility on Linux kernels 2.6.29 and older, as acpi_cpufreq cleared APERF/MPERF up through that release. On Intel Core i3/i5/i7 (Nehalem) and newer processors, turbostat also displays residency in idle power saving states, which are necessary for diagnosing any cpuidle issues that may have an effect on turbo-mode. See the turbostat.8 man page for example usage. Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-11Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits) perf session: Fix infinite loop in __perf_session__process_events perf evsel: Support perf_evsel__open(cpus > 1 && threads > 1) perf sched: Use PTHREAD_STACK_MIN to avoid pthread_attr_setstacksize() fail perf tools: Emit clearer message for sys_perf_event_open ENOENT return perf stat: better error message for unsupported events perf sched: Fix allocation result check perf, x86: P4 PMU - Fix unflagged overflows handling dynamic debug: Fix build issue with older gcc tracing: Fix TRACE_EVENT power tracepoint creation tracing: Fix preempt count leak tracepoint: Add __rcu annotation tracing: remove duplicate null-pointer check in skb tracepoint tracing/trivial: Add missing comma in TRACE_EVENT comment tracing: Include module.h in define_trace.h x86: Save rbp in pt_regs on irq entry x86, dumpstack: Fix unused variable warning x86, NMI: Clean-up default_do_nmi() x86, NMI: Allow NMI reason io port (0x61) to be processed on any CPU x86, NMI: Remove DIE_NMI_IPI x86, NMI: Add priorities to handlers ...
2011-01-10perf session: Fix infinite loop in __perf_session__process_eventsArnaldo Carvalho de Melo
In this if statement: if (head + event->header.size >= mmap_size) { if (mmaps[map_idx]) { munmap(mmaps[map_idx], mmap_size); mmaps[map_idx] = NULL; } page_offset = page_size * (head / page_size); file_offset += page_offset; head -= page_offset; goto remap; } With, for instance, these values: head=2992 event->header.size=48 mmap_size=3040 We end up endlessly looping back to remap. Off by one. Problem introduced in 55b4462. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Reported-by: Ingo Molnar <mingo@elte.hu> Reported-by: David Ahern <daahern@cisco.com> Bisected-by: David Ahern <daahern@cisco.com> Tested-by: David Ahern <daahern@cisco.com> Cc: David Ahern <daahern@cisco.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-10perf evsel: Support perf_evsel__open(cpus > 1 && threads > 1)Arnaldo Carvalho de Melo
And a test for it: [acme@felicio linux]$ perf test 1: vmlinux symtab matches kallsyms: Ok 2: detect open syscall event: Ok 3: detect open syscall event on all cpus: Ok [acme@felicio linux]$ Translating C the test does: 1. generates different number of open syscalls on each CPU by using sched_setaffinity 2. Verifies that the expected number of events is generated on each CPU It works as expected. LKML-Reference: <new-submission> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: slub: Fix a crash during slabinfo -v tracing/slab: Move kmalloc tracepoint out of inline code slub: Fix slub_lock down/up imbalance slub: Fix build breakage in Documentation/vm slub tracing: move trace calls out of always inlined functions to reduce kernel code size slub: move slabinfo.c to tools/slub/slabinfo.c
2011-01-10perf sched: Use PTHREAD_STACK_MIN to avoid pthread_attr_setstacksize() failJiri Pirko
on ppc64: /usr/include/bits/local_lim.h:#define PTHREAD_STACK_MIN 131072 therefore following set of commands: gives: perf.2.6.37test: builtin-sched.c:493: create_tasks: Assertion `!(err)' failed. So make sure we do not set stack size lower than PTHREAD_STACK_MIN. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20110110160417.GB2685@psychotron.brq.redhat.com> Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-10perf tools: Emit clearer message for sys_perf_event_open ENOENT returnArnaldo Carvalho de Melo
Improve sys_perf_event_open ENOENT return handling in top and record, just like 5a3446b does for stat. Cc: David Ahern <daahern@cisco.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-10perf stat: better error message for unsupported eventsDavid Ahern
For unsupported events (e.g., H/W events when running in a VM) perf stat currently fails with the error message: Error: open_counter returned with 2 (No such file or directory). /bin/dmesg may provide additional information. Fatal: Not all events could be opened. dmesg is of no help and it is not clear as to why it fails to open the counter. This patch changes the error message to Error: cache-misses event is not supported. Fatal: Not all events could be opened. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: a.p.zijlstra@chello.nl LPU-Reference: <1294597272-17335-1-git-send-email-daahern@cisco.com> Signed-off-by: David Ahern <daahern@cisco.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-10perf sched: Fix allocation result checkArnaldo Carvalho de Melo
Bug introduced in ce47dc56. Reported-by: Mike Galbraith <efault@gmx.de> Cc: Chris Samuel <chris@csamuel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-09Merge branch 'slab/next' into for-linusPekka Enberg
2011-01-07Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (65 commits) [S390] prevent unneccesary loops_per_jiffy recalculation [S390] cpuinfo: use get_online_cpus() instead of preempt_disable() [S390] smp: remove cpu hotplug messages [S390] mutex: enable spinning mutex on s390 [S390] mutex: Introduce arch_mutex_cpu_relax() [S390] cio: fix ccwgroup unregistration race condition [S390] perf: add DWARF register lookup for s390 [S390] cleanup ftrace backend functions [S390] ptrace cleanup [S390] smp/idle: call init_idle() before starting a new cpu [S390] smp: delay idle task creation [S390] dasd: Correct retry counter for terminated I/O. [S390] dasd: Add support for raw ECKD access. [S390] dasd: Prevent deadlock during suspend/resume. [S390] dasd: Improve handling of stolen DASD reservation [S390] dasd: do path verification for paths added at runtime [S390] dasd: add High Performance FICON multitrack support [S390] cio: reduce memory consumption of itcw structures [S390] nmi: enable machine checks early [S390] qeth: buffer count imbalance ...
2011-01-07perf tools: Pass whole attr to event selectorsLin Ming
Since commit 69aad6f1(perf tools: Introduce event selectors), only perf_event_attr::type and ::config are passed to event selector, which makes perf tool not work correctly. For example, PEBS does not work because perf_event_attr::precise_ip is not passed to the syscall. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1294369869.20563.19.camel@minggr.sh.intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1436 commits) cassini: Use local-mac-address prom property for Cassini MAC address net: remove the duplicate #ifdef __KERNEL__ net: bridge: check the length of skb after nf_bridge_maybe_copy_header() netconsole: clarify stopping message netconsole: don't announce stopping if nothing happened cnic: Fix the type field in SPQ messages netfilter: fix export secctx error handling netfilter: fix the race when initializing nf_ct_expect_hash_rnd ipv4: IP defragmentation must be ECN aware net: r6040: Return proper error for r6040_init_one dcb: use after free in dcb_flushapp() dcb: unlock on error in dcbnl_ieee_get() net: ixp4xx_eth: Return proper error for eth_init_one include/linux/if_ether.h: Add #define ETH_P_LINK_CTL for HPNA and wlan local tunnel net: add POLLPRI to sock_def_readable() af_unix: Avoid socket->sk NULL OOPS in stream connect security hooks. net_sched: pfifo_head_drop problem mac80211: remove stray extern mac80211: implement off-channel TX using hw r-o-c offload mac80211: implement hardware offload for remain-on-channel ...
2011-01-06perf tools: Build with frame pointerFrederic Weisbecker
It seems that some gcc versions build by default with frame pointers and some others omit them. Just build the tools with frame pointers as the callchains can be an important part of the perf workflow. Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <1294325513-14276-3-git-send-email-fweisbec@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-06perf tools: Fix buffer overflow error when specifying all tracepointsHan Pingtian
I found when specifying all tracepoints with -e to one of subcommand, such as 'stat', the program will trigger a buffer overflow error, like this: *** buffer overflow detected ***: ./perf terminated ======= Backtrace: ========= /lib64/libc.so.6(__fortify_fail+0x37)[0x382cefb2c7] .... The tracepoints are separated by comma, something like this: $ perf stat -a -e `perf list |grep Tracepoint|awk -F'[' '{gsub(/[[:space:]]+/,"",$1);array[FNR]=$1}END{outputs=array[1];for (i=2;i<=FNR;i++){ outputs=outputs "," array[i];};print outputs}'` The root reason of this problem is that store_event_type() is called for all events, and will overflow the 'filename' at: strncat(filename, orgname, strlen(orgname)); This patch fixes it by calling store_event_type() only when the event name has been found. LKML-Reference: <20110106093922.GB6713@hpt.nay.redhat.com> Signed-off-by: Han Pingtian <phan@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-05perf script: Make some lists staticArnaldo Carvalho de Melo
Not accessed outside builtin-script, so make them static. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-05perf script: Use the default lost event handlerArnaldo Carvalho de Melo
That already does what was being done here. The warning is now unconditionally given by __perf_session__process_pipe_events, just like for non pipe processing. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-05perf session: Warn about errors when processing pipe events tooArnaldo Carvalho de Melo
Just like we do at __perf_session__process_events Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-05perf tools: Fix perf_event.h header usageStephane Eranian
This patch fixes the usage of the perf_event.h header file between command modules and the supporting code in util. It is necessary to ensure that ALL files use the SAME perf_event.h header from the kernel source tree. There were a couple of #include <linux/perf_event.h> mixed with #include "../../perf_event.h". This caused issues on some distros because of mismatch in the layout of struct perf_event_attr. That eventually led perf stat to segfault. Cc: David S. Miller <davem@davemloft.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@gmail.com> LKML-Reference: <4d233cf0.2308e30a.7b00.ffffc187@mx.google.com> Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-05perf test: Clarify some error reports in the open syscall testArnaldo Carvalho de Melo
Rebooted my devel machine, first thing I ran was perf test, that expects debugfs to be mounted, test fails. Be more clear about it. Also add missing newlines and add more informative message when sys_perf_event_open fails. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-05Merge commit 'v2.6.37' into perf/coreIngo Molnar
Merge reason: Add the final .37 tree. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-05[S390] perf: add DWARF register lookup for s390Heiko Carstens
Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-04perf timechart: Adjust perf timechart to the new power eventsThomas Renninger
builtin-timechart must only pass -e power:xy events if they are supported by the running kernel, otherwise try to fetch the old power:power{start,end} events. For this I added the tiny helper function: int is_valid_tracepoint(const char *event_string) to parse-events.[hc], which could be more generic as an interface and support hardware/software/... events, not only tracepoints, but someone else could extend that if needed... Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Jean Pihet <j-pihet@ti.com> LKML-Reference: <1294073445-14812-4-git-send-email-trenn@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-04Merge branch 'perf/test' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux-2.6 into perf/core
2011-01-04Merge commit 'v2.6.37-rc8' into perf/coreIngo Molnar
Merge reason: pick up latest -rc. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-04perf test: Add test for counting open syscallsArnaldo Carvalho de Melo
To test the use of the perf_evsel class on something other than the tools from where we refactored code to create it. It calls open() N times and then checks if the event created to monitor it returns N events. [acme@felicio linux]$ perf test 1: vmlinux symtab matches kallsyms: Ok 2: detect open syscall event: Ok [acme@felicio linux]$ It does. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Han Pingtian <phan@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-04perf evsel: Auto allocate resources needed for some methodsArnaldo Carvalho de Melo
While writing the first user of the routines created from the ad-hoc routines in the existing builtins I noticed that the resulting set of calls was too long, reduce it by doing some best effort allocations. Tools that need to operate on multiple threads and cpus should pre-allocate enough resources by explicitely calling the perf_evsel__alloc_{fd,counters} methods. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-04perf evsel: Use {cpu,thread}_map to shorten list of parametersArnaldo Carvalho de Melo
2011-01-04perf tools: Refactor all_tids to hold nr and the mapArnaldo Carvalho de Melo
So that later, we can pass the thread_map instance instead of (thread_num, thread_map) for things like perf_evsel__open and friends, just like was done with cpu_map. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-04perf tools: Refactor cpumap to hold nr and the mapArnaldo Carvalho de Melo
So that later, we can pass the cpu_map instance instead of (nr_cpus, cpu_map) for things like perf_evsel__open and friends. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-04perf evsel: Introduce per cpu and per thread open helpersArnaldo Carvalho de Melo
Abstracting away the loops needed to create the various event fd handlers. The users have to pass a confiruged perf->evsel.attr field, which is already usable after perf_evsel__new (constructor) time, using defaults. Comes out of the ad-hoc routines in builtin-stat, that now uses it. Fixed a small silly bug where we were die()ing before killing our children, dysfunctional family this one 8-) Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-04perf evsel: Steal the counter reading routines from statArnaldo Carvalho de Melo
Making them hopefully generic enough to be used in 'perf test', well see. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-03perf evsel: Delete the event selectors at exitArnaldo Carvalho de Melo
Freeing all the possibly allocated resources, reducing complexity on each tool exit path. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-03perf util: Move do_read from session to utilArnaldo Carvalho de Melo
Not really something to be exported from session.c. Rename it to 'readn' as others did in the past. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-03perf evsel: Adopt MATCH_EVENT macro from 'stat'Arnaldo Carvalho de Melo
2011-01-03perf tools: Introduce event selectorsArnaldo Carvalho de Melo
Out of ad-hoc code and global arrays with hard coded sizes. This is the first step on having a library that will be first used on regression tests in the 'perf test' tool. [acme@felicio linux]$ size /tmp/perf.before text data bss dec hex filename 1273776 97384 5104416 6475576 62cf38 /tmp/perf.before [acme@felicio linux]$ size /tmp/perf.new text data bss dec hex filename 1275422 97416 1392416 2765254 2a31c6 /tmp/perf.new Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-03perf: Fix callchain hit bad cast on ascii displayFrederic Weisbecker
ipchain__fprintf_graph() casts the number of hits in a branch as an int, which means we lose its highests bits. This results in meaningless number of callchain hits in perf.data that have a high number of hits recorded, typically those that have callchain branches hits appearing more than INT_MAX. This happens easily as those are pondered by the event period. Reported-by: Nick Piggin <npiggin@kernel.dk> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org>
2010-12-27perf probe: Fix short file name probe location reportingFranck Bui-Huu
After adding probes, perf-probe(1) reports the probes locations which include filenames for certain cases. But for short file names (whose length < 32), perf-probe didn't display the name correctly. It actually skipped the first character. Here's an example where 'icmp.c' was screwed: $ perf probe -n -a "icmp.c;sk=*" Add new events: probe:icmp_push_reply (on @cmp.c) probe:icmp_reply (on @cmp.c) probe:icmp_reply_1 (on @cmp.c) probe:icmp_send (on @cmp.c) probe:icmp_send_1 (on @cmp.c) probe:icmp_error (on @cmp.c) probe:icmp_error_1 (on @cmp.c) probe:icmp_error_2 (on @cmp.c) probe:icmp_error_3 (on @cmp.c) This patch fixes this bug in synthesize_perf_probe_point(). Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> LKML-Reference: <m31v588r9k.fsf@gmail.com> Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/fib_frontend.c
2010-12-25perf script: Fix event ordering settings to work with older kernelsArnaldo Carvalho de Melo
If we don't use .ordering_requires_timestamps we'll end up trying to order events with no timestamps when running on older kernels. Problem introduced in eac23d1c. After the last three fixes, perf scripting is back working, tested with new perf userspace on old and new (with sample_id_all) kernels. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ian Munsie <imunsie@au1.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Torok Edwin <edwintorok@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-25perf record: Fix use of sample_id_all userspace with !sample_id_all kernelsArnaldo Carvalho de Melo
Check if parse_single_tracepoint_event has already asked for PERF_SAMPLE_TIME. This is kludgy but short term fix for problems introduced by eac23d1c that broke 'perf script' by having different sample_types when using multiple tracepoint events when we use a perf binary that tries to use sample_id_all on an older kernel. We need to move counter creation to perf_session, support different sample_types, etc. Ongoing work on the perf test infrastructure needs this so that we can create counters to monitor threads generating specific events, etc. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Torok Edwin <edwintorok@gmail.com> Cc: Ian Munsie <imunsie@au1.ibm.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-25perf script: Finish the rename from trace to scriptArnaldo Carvalho de Melo
The scripts have calls to 'perf trace' that need to be converted to 'perf script', do it. This problem was introduced in 133dc4c. Reported-by: Torok Edwin <edwintorok@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Torok Edwin <edwintorok@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-22perf probe: Fix wrong warning in __show_one_line() if read(1) errors happenFranck Bui-Huu
This was introduced by commit fde52dbd7f71934aba4e150f3d1d51e826a08850. Cc: H. Peter Anvin <hpa@zytor.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <m3y67hsr0m.fsf@gmail.com> Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-22perf test: Look forward for symbol aliasesArnaldo Carvalho de Melo
Not just before, fixing these false positives: [acme@mica linux]$ perf test -v 1 1: vmlinux symtab matches kallsyms: --- start --- Looking at the vmlinux_path (6 entries long) Using //lib/modules/2.6.37-rc5-00180-ge06b6bf/build/vmlinux for symbols 0xffffffff81058dc0: diff name v: sys_vm86old k: sys_ni_syscall 0xffffffff81058dc0: diff name v: sys_vm86 k: sys_ni_syscall 0xffffffff81058dc0: diff name v: sys_subpage_prot k: sys_ni_syscall 0xffffffff810b5f7c: diff name v: probe_kernel_write k: __probe_kernel_write 0xffffffff810b5fe5: diff name v: probe_kernel_read k: __probe_kernel_read 0xffffffff811bc380: diff name v: __memset k: memset 0xffffffff81384a98: diff name v: __sched_text_start k: sleep_on_common 0xffffffff81386750: diff name v: __sched_text_end k: _raw_spin_trylock 0xffffffff8138cee8: diff name v: __irqentry_text_start k: do_IRQ 0xffffffff8138f079: diff name v: __start_notes k: _etext 0xffffffff8138f079: diff name v: __stop_notes k: _etext ---- end ---- vmlinux symtab matches kallsyms: FAILED! [acme@mica linux]$ Some are weak functions, others are just markers, etc. They get in the rb tree with the same addr, so we need to look around to find the symbol with the same name. We were looking just at the previous entries with the same addr, look forward too. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Han Pingtian <phan@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-22perf symbols: Improve kallsyms symbol end addr calculationArnaldo Carvalho de Melo
For kallsyms we don't have the symbol address end, so we do an extra pass and set the symbol end addr as being the start of the next minus one. But this was being done just after we filtered the symbols of a particular type (functions, variables), so the symbol end was sometimes after what it really is. Fixing up symbol end also was falling apart when we have symbol aliases, then the end address of all but the last alias was being set to be before its start. Fix it up by checking for symbol aliases and making the kallsyms__parse routine use the next symbol, whatever its type, as the limit for the previous symbol, passing that end address to the callback. This was detected by the 'perf test' synthetic paranoid regression tests, fix it up so that even that case doesn't mislead us. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-21perf probe: Fix to support libdwfl older than 0.148Masami Hiramatsu
Since the libdwfl library before 0.148 fails to analyze live kernel debuginfo, 'perf probe --list' compiled with those old libdwfl sometimes crashes. To avoid that bug, perf probe does not use libdwfl's live kernel analysis routine when it is compiled with older libdwfl. Side effect: perf with older libdwfl doesn't support listing probe in modules with source code line. Those could be shown by symbol+offset. Cc: 2nddept-manager@sdl.hitachi.co.jp Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20101217131218.24123.62424.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
