path: root/tools
2014-04-21tools/power/acpi: Minor bugfixesThomas Renninger
- bindir is created, but sbindir is used -> fix that - the debug parts are there twice (copy paste bug?). Remove one of the exact same parts Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-04-20Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf tooling fixes from Ingo Molnar: "Three small tooling fixes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf tools: Improve error reporting perf tools: Adjust symbols in VDSO perf kvm: Fix 'Min time' counting in report command
2014-04-20perf tools: Improve error reportingAdrien BAK
In the current version, when using perf record, if something goes wrong in tools/perf/builtin-record.c:375 session = perf_session__new(file, false, NULL); The error message: "Not enough memory for reading per file header" is issued. This error message seems to be outdated and is not very helpful. This patch proposes to replace this error message by "Perf session creation failed" I believe this issue has been brought to lkml: https://lkml.org/lkml/2014/2/24/458 although this patch only tackles a (small) part of the issue. Additionnaly, this patch improves error reporting in tools/perf/util/data.c open_file_write. Currently, if the call to open fails, the user is unaware of it. This patch logs the error, before returning the error code to the caller. Reported-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Adrien BAK <adrien.bak@metascale.org> Link: http://lkml.kernel.org/r/1397786443.3093.4.camel@beast [ Reorganize the changelog into paragraphs ] [ Added empty line after fd declaration in open_file_write ] Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-20perf tools: Adjust symbols in VDSOVladimir Nikulichev
pert-report doesn't resolve function names in VDSO: $ perf report --stdio -g flat,0.0,15,callee --sort pid ... 8.76% 0x7fff6b1fe861 __gettimeofday ACE_OS::gettimeofday() ... In this case symbol values should be adjusted the same way as for executables, relocatable objects and prelinked libraries. After fix: $ perf report --stdio -g flat,0.0,15,callee --sort pid ... 8.76% __vdso_gettimeofday __gettimeofday ACE_OS::gettimeofday() Signed-off-by: Vladimir Nikulichev <nvs@tbricks.com> Tested-by: Namhyung Kim <namhyung@kernel.org> Reviewed-by: Adrian Hunter <adrian.hunter@intel.com> Link: http://lkml.kernel.org/r/969812.163009436-sendEmail@nvs Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-20perf kvm: Fix 'Min time' counting in report commandAlexander Yarygin
Every event in the perf-kvm has a 'stats' structure, which contains max/min/average/etc times of handling this event. The problem is that the 'perf-kvm stat report' command always shows that 'min time' is 0us for every event. Example: # perf kvm stat report Analyze events for all VCPUs: VM-EXIT Samples Samples% Time% Min Time Max Time Avg time [..] 0xB2 MSCH 12 0.07% 0.00% 0us 8us 7.31us ( +- 2.11% ) 0xB2 CHSC 12 0.07% 0.00% 0us 18us 9.39us ( +- 9.49% ) 0xB2 STPX 8 0.05% 0.00% 0us 2us 1.88us ( +- 7.18% ) 0xB2 STSI 7 0.04% 0.00% 0us 44us 16.49us ( +- 38.20% ) [..] This happens because the 'stats' structure is not initialized and stats->min equals to 0. Lets initialize the structure for every event after its allocation using init_stats() function. This initializes stats->min to -1 and makes 'Min time' statistics counting work: # perf kvm stat report Analyze events for all VCPUs: VM-EXIT Samples Samples% Time% Min Time Max Time Avg time [..] 0xB2 MSCH 12 0.07% 0.00% 6us 8us 7.31us ( +- 2.11% ) 0xB2 CHSC 12 0.07% 0.00% 7us 18us 9.39us ( +- 9.49% ) 0xB2 STPX 8 0.05% 0.00% 1us 2us 1.88us ( +- 7.18% ) 0xB2 STSI 7 0.04% 0.00% 1us 44us 16.49us ( +- 38.20% ) [..] Signed-off-by: Alexander Yarygin <yarygin@linux.vnet.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Reviewed-by: David Ahern <dsahern@gmail.com> Link: http://lkml.kernel.org/r/1397053319-2130-3-git-send-email-borntraeger@de.ibm.com [ Fixing the perf examples changelog output ] Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-18Merge tag 'char-misc-3.15-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver fixes from Greg KH: "Here are a few driver fixes for char/misc drivers that resolve reported issues. All have been in linux-next successfully for a few days" * tag 'char-misc-3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: Drivers: hv: vmbus: Negotiate version 3.0 when running on ws2012r2 hosts Tools: hv: Handle the case when the target file exists correctly vme_tsi148: Utilize to_pci_dev() macro vme_tsi148: Fix PCI address mapping assumption vme_tsi148: Fix typo in tsi148_slave_get() w1: avoid recursive device_add w1: fix netlink refcnt leak on error path misc: Grammar s/addition/additional/ drivers: mcb: fix memory leak in chameleon_parse_cells() error path mei: ignore client writing state during cb completion mei: me: do not load the driver if the FW doesn't support MEI interface GenWQE: Increase driver version number GenWQE: Fix multithreading problems GenWQE: Ensure rc is not returning an uninitialized value GenWQE: Add wmb before DDCB is started GenWQE: Enable access to VPD flash area
2014-04-16Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Tooling fixes, plus a simple hardware-enablement patch for the Intel RAPL PMU (energy use measurement) on Haswell CPUs, which I hope is still fine at this stage" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf tools: Instead of redirecting flex output, use -o perf tools: Fix double free in perf test 21 (code-reading.c) perf stat: Initialize statistics correctly perf bench: Set more defaults in the 'numa' suite perf bench: Fix segfault at the end of an 'all' execution perf bench: Update manpage to mention numa and futex perf probe: Use dwarf_getcfi_elf() instead of dwarf_getcfi() perf probe: Fix to handle errors in line_range searching perf probe: Fix --line option behavior perf tools: Pick up libdw without explicit LIBDW_DIR MAINTAINERS: Change e-mail to kernel.org one perf callchains: Disable unwind libraries when libelf isn't found tools lib traceevent: Do not call warning() directly tools lib traceevent: Print event name when show warning if possible perf top: Fix documentation of invalid -s option perf/x86: Enable DRAM RAPL support on Intel Haswell
2014-04-16Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking fixes from Ingo Molnar: "liblockdep fixes and mutex debugging fixes" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: locking/mutex: Fix debug_mutexes tools/liblockdep: Add proper versioning to the shared obj tools/liblockdep: Ignore asmlinkage and visible
2014-04-16Tools: hv: Handle the case when the target file exists correctlyK. Y. Srinivasan
Return the appropriate error code and handle the case when the target file exists correctly. This fixes a bug. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Cc: <stable@vger.kernel.org> [3.14] Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-15perf tools: Instead of redirecting flex output, use -oCody P Schafer
This gives us a real filename instead of having '<stdout>' show up all over the place when debugging. Signed-off-by: Cody P Schafer <cody@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1396652539-2416-1-git-send-email-cody@linux.vnet.ibm.com Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-15perf tools: Fix double free in perf test 21 (code-reading.c)Adrian Hunter
perf_evlist__delete() deletes attached cpu and thread maps but the test is still using them, so remove them from the evlist before deleting it. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Link: http://lkml.kernel.org/r/53465E3E.8070201@intel.com Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14Merge branch 'perf-core-for-mingo' into perf/urgentIngo Molnar
Conflicts: tools/perf/bench/numa.c Pull perf fixes from Jiri Olsa. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-14Merge branch 'liblockdep-fixes' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/sashal/linux into core/urgent Pull liblockdep fixes from Sasha Levin: " 1. There was a build breakage caused by marking a function 'asmlinkage' in lockdep.h. Fix that by ignoring asmlinkage and visible annotations. 2. Josh Boyer mentioned that Fedora would like to include liblockdep as a package, so we had to fix our versioning methods from being dumb and pointless to something actually usable. So now liblockdep.so tracks the kernel version which makes lives of distro folks much easier. " Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-14perf stat: Initialize statistics correctlyAndi Kleen
perf stat did initialize the stats structure used to compute stddev etc. incorrectly. It merely zeroes it. But one member (min) needs to be set to a non zero value. This causes min to be not computed at all. Call init_stats() correctly. It doesn't matter for stat currently because it doesn't use min, but it's still better to do it correctly. The other users of statistics are already correct. Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1395768699-16060-1-git-send-email-andi@firstfloor.org Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14perf bench: Set more defaults in the 'numa' suiteRamkumar Ramachandra
Currently, $ perf bench numa mem errors out with usage information. To make this more user-friendly, let us provide a minimum set of default values required for a test run. As an added bonus, $ perf bench all now goes all the way to completion. Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1395964219-22173-2-git-send-email-artagnon@gmail.com Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14perf bench: Fix segfault at the end of an 'all' executionRamkumar Ramachandra
At the end of $ perf bench all the program segfaults because it attempts to dereference a NULL pointer. Fix this fault. Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1395964219-22173-4-git-send-email-artagnon@gmail.com Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14perf bench: Update manpage to mention numa and futexRamkumar Ramachandra
Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1395964219-22173-3-git-send-email-artagnon@gmail.com Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14perf probe: Use dwarf_getcfi_elf() instead of dwarf_getcfi()Namhyung Kim
The dwarf_getcfi() only checks .debug_frame section for CFI, but as most binaries only have .eh_frame it'd return NULL and it makes some variables inaccessible. Using dwarf_getcfi_elf (along with dwarf_getelf()) allows to show and add probe to more variables. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Link: http://lkml.kernel.org/r/1396854348-9296-1-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14perf probe: Fix to handle errors in line_range searchingMasami Hiramatsu
As Namhyung reported(https://lkml.org/lkml/2014/4/1/89), current perf-probe -L option doesn't handle errors in line-range searching correctly. It causes a SEGV if an error occured in the line-range searching. ---- $ perf probe -x ./perf -v -L map__load Open Debuginfo file: /home/namhyung/project/linux/tools/perf/perf fname: util/map.c, lineno:153 New line range: 153 to 2147483647 path: (null) Segmentation fault (core dumped) ---- This is because line_range_inline_cb() ignores errors from find_line_range_by_line() which means that lr->path is already freed on the error path in find_line_range_by_line(). As a result, get_real_path() accesses the lr->path and it causes a NULL pointer exception. This fixes line_range_inline_cb() to handle the error correctly, and report it to the caller. Anyway, this just fixes a possible SEGV bug, Namhyung's patch is also required. Reported-by: Namhyung Kim <namhyung@kernel.org> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20140402054831.19080.27006.stgit@ltc230.yrl.intra.hitachi.co.jp Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14perf probe: Fix --line option behaviorNamhyung Kim
The commit 5a62257a3ddd1 ("perf probe: Replace line_list with intlist") replaced line_list to intlist but it has a problem that if a same line was added again, it'd return -EEXIST rather than 1. Since line_range_walk_cb() only checks the result being negative, it resulted in failure or segfault sometimes. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Link: http://lkml.kernel.org/r/1396327677-3657-1-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14perf tools: Pick up libdw without explicit LIBDW_DIRRamkumar Ramachandra
The Makefile logic sets FEATURE_CHECKS_CFLAGS-libdw-dwarf-unwind and FEATURE_CHECKS_LDFLAGS-libdw-dwarf-unwind only if LIBDW_DIR is defined. This means that under a normal setup, $ make NO_LIBUNWIND=1 won't automatically pick up libdw. Fix this. Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> Acked-by: Jean Pihet <jean.pihet@linaro.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1395873845-466-1-git-send-email-artagnon@gmail.com Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14perf callchains: Disable unwind libraries when libelf isn't foundArnaldo Carvalho de Melo
I.e. do the same as when NO_LIBELF is explicitely passed in the 'make' command line, fixing this: Auto-detecting system features: ... dwarf: [ OFF ] ... glibc: [ on ] ... gtk2: [ OFF ] ... libaudit: [ OFF ] ... libbfd: [ OFF ] ... libelf: [ OFF ] ... libunwind: [ OFF ] ... libdw-dwarf-unwind: [ OFF ] ... DWARF post unwind library: libdw <SNIP> CC /tmp/build/perf/util/symbol-minimal.o CC /tmp/build/perf/util/unwind-libdw.o arch/x86/util/unwind-libdw.c:1:30: fatal error: elfutils/libdwfl.h: No such file or directory compilation terminated. CC /tmp/build/perf/tests/keep-tracking.o util/unwind-libdw.c:2:28: fatal error: elfutils/libdw.h: No such file or directory compilation terminated. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-e39j1yxanltjx4t0msse63ax@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14tools lib traceevent: Do not call warning() directlyNamhyung Kim
The patch 3a3ffa2e82205 ("tools lib traceevent: Report better error message on bad function args") added the error message but it seems there's no reason to call warning() directly. So change it to do_warning_event() to provide event information too. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1395192174-26273-2-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14tools lib traceevent: Print event name when show warning if possibleNamhyung Kim
It's sometimes useful to know where the parse failure was occurred. Add do_warning_event() macro to see the failing event. It now shows the messages like below: $ perf test 5 5: parse events tests : Warning: [kvmmmu:kvm_mmu_get_page] bad op token { Warning: [kvmmmu:kvm_mmu_sync_page] bad op token { Warning: [kvmmmu:kvm_mmu_unsync_page] bad op token { Warning: [kvmmmu:kvm_mmu_prepare_zap_page] bad op token { Warning: [kvmmmu:fast_page_fault] function is_writable_pte not defined Warning: [xen:xen_mmu_ptep_modify_prot_commit] function sizeof not defined Warning: [xen:xen_mmu_ptep_modify_prot_start] function sizeof not defined Warning: [xen:xen_mmu_set_pgd] function sizeof not defined Warning: [xen:xen_mmu_set_pud] function sizeof not defined Warning: [xen:xen_mmu_set_pmd] function sizeof not defined ... Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ramkumar Ramachandra <artagnon@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1395192174-26273-1-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14perf top: Fix documentation of invalid -s optionNamhyung Kim
On perf top, the -s option is used for --sort, but the man page contains invalid documentation of -s option for --sym-annotate. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1395193578-27098-1-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-11Merge tag 'pm+acpi-3.15-rc1-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more ACPI and power management fixes and updates from Rafael Wysocki: "This is PM and ACPI material that has emerged over the last two weeks and one fix for a CPU hotplug regression introduced by the recent CPU hotplug notifiers registration series. Included are intel_idle and turbostat updates from Len Brown (these have been in linux-next for quite some time), a new cpufreq driver for powernv (that might spend some more time in linux-next, but BenH was asking me so nicely to push it for 3.15 that I couldn't resist), some cpufreq fixes and cleanups (including fixes for some silly breakage in a couple of cpufreq drivers introduced during the 3.14 cycle), assorted ACPI cleanups, wakeup framework documentation fixes, a new sysfs attribute for cpuidle and a new command line argument for power domains diagnostics. Specifics: - Fix for a recently introduced CPU hotplug regression in ARM KVM from Ming Lei. - Fixes for breakage in the at32ap, loongson2_cpufreq, and unicore32 cpufreq drivers introduced during the 3.14 cycle (-stable material) from Chen Gang and Viresh Kumar. - New powernv cpufreq driver from Vaidyanathan Srinivasan, with bits from Gautham R Shenoy and Srivatsa S Bhat. - Exynos cpufreq driver fix preventing it from being included into multiplatform builds that aren't supported by it from Sachin Kamat. - cpufreq cleanups related to the usage of the driver_data field in struct cpufreq_frequency_table from Viresh Kumar. - cpufreq ppc driver cleanup from Sachin Kamat. - Intel BayTrail support for intel_idle and ACPI idle from Len Brown. - Intel CPU model 54 (Atom N2000 series) support for intel_idle from Jan Kiszka. - intel_idle fix for Intel Ivy Town residency targets from Len Brown. - turbostat updates (Intel Broadwell support and output cleanups) from Len Brown. - New cpuidle sysfs attribute for exporting C-states' target residency information to user space from Daniel Lezcano. - New kernel command line argument to prevent power domains enabled by the bootloader from being turned off even if they are not in use (for diagnostics purposes) from Tushar Behera. - Fixes for wakeup sysfs attributes documentation from Geert Uytterhoeven. - New ACPI video blacklist entry for ThinkPad Helix from Stephen Chandler Paul. - Assorted ACPI cleanups and a Kconfig help update from Jonghwan Choi, Zhihui Zhang, Hanjun Guo" * tag 'pm+acpi-3.15-rc1-3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (28 commits) ACPI: Update the ACPI spec information in Kconfig arm, kvm: fix double lock on cpu_add_remove_lock cpuidle: sysfs: Export target residency information cpufreq: ppc: Remove duplicate inclusion of fsl_soc.h cpufreq: create another field .flags in cpufreq_frequency_table cpufreq: use kzalloc() to allocate memory for cpufreq_frequency_table cpufreq: don't print value of .driver_data from core cpufreq: ia64: don't set .driver_data to index cpufreq: powernv: Select CPUFreq related Kconfig options for powernv cpufreq: powernv: Use cpufreq_frequency_table.driver_data to store pstate ids cpufreq: powernv: cpufreq driver for powernv platform cpufreq: at32ap: don't declare local variable as static cpufreq: loongson2_cpufreq: don't declare local variable as static cpufreq: unicore32: fix typo issue for 'clk' cpufreq: exynos: Disable on multiplatform build PM / wakeup: Correct presence vs. emptiness of wakeup_* attributes PM / domains: Add pd_ignore_unused to keep power domains enabled ACPI / dock: Drop dock_device_ids[] table ACPI / video: Favor native backlight interface for ThinkPad Helix ACPI / thermal: Fix wrong variable usage in debug statement ...
2014-04-08Merge branch 'pm-cpuidle'Rafael J. Wysocki
* pm-cpuidle: cpuidle: sysfs: Export target residency information intel_idle: fine-tune IVT residency targets tools/power turbostat: Run on Broadwell tools/power turbostat: simplify output, add Avg_MHz intel_idle: Add CPU model 54 (Atom N2000 series) intel_idle: support Bay Trail intel_idle: allow sparse sub-state numbering, for Bay Trail ACPI idle: permit sparse C-state sub-state numbers
2014-04-08Merge branch 'release' of ↵Rafael J. Wysocki
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux into pm-cpuidle Pull intel_idle and turbostat material for v3.15-rc1 from Len Brown. * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: intel_idle: fine-tune IVT residency targets tools/power turbostat: Run on Broadwell tools/power turbostat: simplify output, add Avg_MHz intel_idle: Add CPU model 54 (Atom N2000 series) intel_idle: support Bay Trail intel_idle: allow sparse sub-state numbering, for Bay Trail ACPI idle: permit sparse C-state sub-state numbers
2014-04-07tools/vm/page-types.c: page-cache sniffing featureKonstantin Khlebnikov
After this patch 'page-types' can walk over a file's mappings and analyze populated page cache pages mostly without disturbing its state. It maps chunk of file, marks VMA as MADV_RANDOM to turn off readahead, pokes VMA via mincore() to determine cached pages, triggers page-fault only for them, and finally gathers information via pagemap/kpageflags. Before unmap it marks VMA as MADV_SEQUENTIAL for ignoring reference bits. usage: page-types -f <path> If <path> is directory it will analyse all files in all subdirectories. Symlinks are not followed as well as mount points. Hardlinks aren't handled, they'll be dumped as many times as they are found. Recursive walk brings all dentries into dcache and populates page cache of block-devices aka 'Buffers'. Probably it's worth to add ioctl for dumping file page cache as array of PFNs as a replacement for this hackish juggling with mmap/madvise/mincore/pagemap. Also recursive walk could be replaced with dumping cached inodes via some ioctl or debugfs interface followed by openning them via open_by_handle_at, this would fix hardlinks handling and unneeded population of dcache and buffers. This interface might be used as data source for constructing readahead plans and for background optimizations of actively used files. collateral changes: + fix 64-bit LFS: define _FILE_OFFSET_BITS instead of _LARGEFILE64_SOURCE + replace lseek + read with single pread + make show_page_range() reusable after flush usage example: ~/src/linux/tools/vm$ sudo ./page-types -L -f page-types foffset offset flags page-types Inode: 2229277 Size: 89065 (22 pages) Modify: Tue Feb 25 12:00:59 2014 (162 seconds ago) Access: Tue Feb 25 12:01:00 2014 (161 seconds ago) 0 3cbf3b __RU_lA____M________________________ 1 38946a __RU_lA____M________________________ 2 1a3cec __RU_lA____M________________________ 3 1a8321 __RU_lA____M________________________ 4 3af7cc __RU_lA____M________________________ 5 1ed532 __RU_lA_____________________________ 6 2e436a __RU_lA_____________________________ 7 29a35e ___U_lA_____________________________ 8 2de86e ___U_lA_____________________________ 9 3bdfb4 ___U_lA_____________________________ 10 3cd8a3 ___U_lA_____________________________ 11 2afa50 ___U_lA_____________________________ 12 2534c2 ___U_lA_____________________________ 13 1b7a40 ___U_lA_____________________________ 14 17b0be ___U_lA_____________________________ 15 392b0c ___U_lA_____________________________ 16 3ba46a __RU_lA_____________________________ 17 397dc8 ___U_lA_____________________________ 18 1f2a36 ___U_lA_____________________________ 19 21fd30 __RU_lA_____________________________ 20 2c35ba __RU_l______________________________ 21 20f181 __RU_l______________________________ flags page-count MB symbolic-flags long-symbolic-flags 0x000000000000002c 2 0 __RU_l______________________________ referenced,uptodate,lru 0x0000000000000068 11 0 ___U_lA_____________________________ uptodate,lru,active 0x000000000000006c 4 0 __RU_lA_____________________________ referenced,uptodate,lru,active 0x000000000000086c 5 0 __RU_lA____M________________________ referenced,uptodate,lru,active,mmap total 22 0 ~/src/linux/tools/vm$ sudo ./page-types -f / flags page-count MB symbolic-flags long-symbolic-flags 0x0000000000000028 21761 85 ___U_l______________________________ uptodate,lru 0x000000000000002c 127279 497 __RU_l______________________________ referenced,uptodate,lru 0x0000000000000068 74160 289 ___U_lA_____________________________ uptodate,lru,active 0x000000000000006c 84469 329 __RU_lA_____________________________ referenced,uptodate,lru,active 0x000000000000007c 1 0 __RUDlA_____________________________ referenced,uptodate,dirty,lru,active 0x0000000000000228 370 1 ___U_l___I__________________________ uptodate,lru,reclaim 0x0000000000000828 49 0 ___U_l_____M________________________ uptodate,lru,mmap 0x000000000000082c 126 0 __RU_l_____M________________________ referenced,uptodate,lru,mmap 0x0000000000000868 137 0 ___U_lA____M________________________ uptodate,lru,active,mmap 0x000000000000086c 12890 50 __RU_lA____M________________________ referenced,uptodate,lru,active,mmap total 321242 1254 Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Borislav Petkov <bp@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
Pull arch/tile updates from Chris Metcalf: "These fix a few stray build issues seen in linux-next, and also add the minimal required support for perf to tilegx" * git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: arch/tile: remove unused variable 'devcap' tile: Fix vDSO compilation issue with allyesconfig perf tools: Allow building for tile tile/perf: Support perf_events on tilegx and tilepro tile: Enable NMIs on return from handle_nmi() without errors tile: Add support for handling PMC hardware tile: don't use __get_cpu_var() with structure-typed arguments tile: avoid overflow in ns2cycles
2014-04-04Merge tag 'ktest-v3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest Pull single ktest fix from Steven Rostedt: "This just contains a single update by Satoru Takeuchi, which adds CLOSE_CONSOLE_SIGNAL to the kvm.conf file, as the kvm guest requires a different signal than a normal console uses" * tag 'ktest-v3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest: ktest: Set CLOSE_CONSOLE_SIGNAL in the kvm.conf
2014-04-04Merge branches 'turbostat' and 'intel_idle' into releaseLen Brown
2014-04-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Here is my initial pull request for the networking subsystem during this merge window: 1) Support for ESN in AH (RFC 4302) from Fan Du. 2) Add full kernel doc for ethtool command structures, from Ben Hutchings. 3) Add BCM7xxx PHY driver, from Florian Fainelli. 4) Export computed TCP rate information in netlink socket dumps, from Eric Dumazet. 5) Allow IPSEC SA to be dumped partially using a filter, from Nicolas Dichtel. 6) Convert many drivers to pci_enable_msix_range(), from Alexander Gordeev. 7) Record SKB timestamps more efficiently, from Eric Dumazet. 8) Switch to microsecond resolution for TCP round trip times, also from Eric Dumazet. 9) Clean up and fix 6lowpan fragmentation handling by making use of the existing inet_frag api for it's implementation. 10) Add TX grant mapping to xen-netback driver, from Zoltan Kiss. 11) Auto size SKB lengths when composing netlink messages based upon past message sizes used, from Eric Dumazet. 12) qdisc dumps can take a long time, add a cond_resched(), From Eric Dumazet. 13) Sanitize netpoll core and drivers wrt. SKB handling semantics. Get rid of never-used-in-tree netpoll RX handling. From Eric W Biederman. 14) Support inter-address-family and namespace changing in VTI tunnel driver(s). From Steffen Klassert. 15) Add Altera TSE driver, from Vince Bridgers. 16) Optimizing csum_replace2() so that it doesn't adjust the checksum by checksumming the entire header, from Eric Dumazet. 17) Expand BPF internal implementation for faster interpreting, more direct translations into JIT'd code, and much cleaner uses of BPF filtering in non-socket ocntexts. From Daniel Borkmann and Alexei Starovoitov" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1976 commits) netpoll: Use skb_irq_freeable to make zap_completion_queue safe. net: Add a test to see if a skb is freeable in irq context qlcnic: Fix build failure due to undefined reference to `vxlan_get_rx_port' net: ptp: move PTP classifier in its own file net: sxgbe: make "core_ops" static net: sxgbe: fix logical vs bitwise operation net: sxgbe: sxgbe_mdio_register() frees the bus Call efx_set_channels() before efx->type->dimension_resources() xen-netback: disable rogue vif in kthread context net/mlx4: Set proper build dependancy with vxlan be2net: fix build dependency on VxLAN mac802154: make csma/cca parameters per-wpan mac802154: allow only one WPAN to be up at any given time net: filter: minor: fix kdoc in __sk_run_filter netlink: don't compare the nul-termination in nla_strcmp can: c_can: Avoid led toggling for every packet. can: c_can: Simplify TX interrupt cleanup can: c_can: Store dlc private can: c_can: Reduce register access can: c_can: Make the code readable ...
2014-04-02Merge tag 'virtio-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio updates from Rusty Russell: "Nothing exciting: virtio-blk users might see a bit of a boost from the doubling of the default queue length though" * tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: virtio-blk: base queue-depth on virtqueue ringsize or module param Revert a02bbb1ccfe8: MAINTAINERS: add virtio-dev ML for virtio virtio: fail adding buffer on broken queues. virtio-rng: don't crash if virtqueue is broken. virtio_balloon: don't crash if virtqueue is broken. virtio_blk: don't crash, report error if virtqueue is broken. virtio_net: don't crash if virtqueue is broken. virtio_balloon: don't softlockup on huge balloon changes. virtio: Use pci_enable_msix_exact() instead of pci_enable_msix() MAINTAINERS: virtio-dev is subscribers only tools/virtio: add a missing ) tools/virtio: fix missing kmemleak_ignore symbol tools/virtio: update internal copies of headers
2014-04-02Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull main powerpc updates from Ben Herrenschmidt: "This time around, the powerpc merges are going to be a little bit more complicated than usual. This is the main pull request with most of the work for this merge window. I will describe it a bit more further down. There is some additional cpuidle driver work, however I haven't included it in this tree as it depends on some work in tip/timer-core which Thomas accidentally forgot to put in a topic branch. Since I didn't want to carry all of that tip timer stuff in powerpc -next, I setup a separate branch on top of Thomas tree with just that cpuidle driver in it, and Stephen has been carrying that in next separately for a while now. I'll send a separate pull request for it. Additionally, two new pieces in this tree add users for a sysfs API that Tejun and Greg have been deprecating in drivers-core-next. Thankfully Greg reverted the patch that removes the old API so this merge can happen cleanly, but once merged, I will send a patch adjusting our new code to the new API so that Greg can send you the removal patch. Now as for the content of this branch, we have a lot of perf work for power8 new counters including support for our new "nest" counters (also called 24x7) under pHyp (not natively yet). We have new functionality when running under the OPAL firmware (non-virtualized or KVM host), such as access to the firmware error logs and service processor dumps, system parameters and sensors, along with a hwmon driver for the latter. There's also a bunch of bug fixes accross the board, some LE fixes, and a nice set of selftests for validating our various types of copy loops. On the Freescale side, we see mostly new chip/board revisions, some clock updates, better support for machine checks and debug exceptions, etc..." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (70 commits) powerpc/book3s: Fix CFAR clobbering issue in machine check handler. powerpc/compat: 32-bit little endian machine name is ppcle, not ppc powerpc/le: Big endian arguments for ppc_rtas() powerpc: Use default set of netfilter modules (CONFIG_NETFILTER_ADVANCED=n) powerpc/defconfigs: Enable THP in pseries defconfig powerpc/mm: Make sure a local_irq_disable prevent a parallel THP split powerpc: Rate-limit users spamming kernel log buffer powerpc/perf: Fix handling of L3 events with bank == 1 powerpc/perf/hv_{gpci, 24x7}: Add documentation of device attributes powerpc/perf: Add kconfig option for hypervisor provided counters powerpc/perf: Add support for the hv 24x7 interface powerpc/perf: Add support for the hv gpci (get performance counter info) interface powerpc/perf: Add macros for defining event fields & formats powerpc/perf: Add a shared interface to get gpci version and capabilities powerpc/perf: Add 24x7 interface headers powerpc/perf: Add hv_gpci interface header powerpc: Add hvcalls for 24x7 and gpci (Get Performance Counter Info) sysfs: create bin_attributes under the requested group powerpc/perf: Enable BHRB access for EBB events powerpc/perf: Add BHRB constraint and IFM MMCRA handling for EBB ...
2014-04-01Merge tag 'char-misc-3.15-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver patches from Greg KH: "Here's the big char/misc driver updates for 3.15-rc1. Lots of various things here, including the new mcb driver subsystem. All of these have been in linux-next for a while" * tag 'char-misc-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (118 commits) extcon: Move OF helper function to extcon core and change function name extcon: of: Remove unnecessary function call by using the name of device_node extcon: gpio: Use SIMPLE_DEV_PM_OPS macro extcon: palmas: Use SIMPLE_DEV_PM_OPS macro mei: don't use deprecated DEFINE_PCI_DEVICE_TABLE macro mei: amthif: fix checkpatch error mei: client.h fix checkpatch errors mei: use cl_dbg where appropriate mei: fix Unnecessary space after function pointer name mei: report consistently copy_from/to_user failures mei: drop pr_fmt macros mei: make me hw headers private to me hw. mei: fix memory leak of pending write cb objects mei: me: do not reset when less than expected data is received drivers: mcb: Fix build error discovered by 0-day bot cs5535-mfgpt: Simplify dependencies spmi: pm: drop bus-level PM suspend/resume routines spmi: pmic_arb: make selectable on ARCH_QCOM Drivers: hv: vmbus: Increase the limit on the number of pfns we can handle pch_phub: Report error writing MAC back to user ...
2014-04-01tools/liblockdep: Add proper versioning to the shared objSasha Levin
Add proper versioning to the shared obj so that distros would be able to ship this lib without having to worry about versioning. Suggested-by: Josh Boyer <jwboyer@fedoraproject.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2014-04-01tools/liblockdep: Ignore asmlinkage and visibleSasha Levin
Commit 63f9a7fde7 "asmlinkage: Make lockdep_sys_exit asmlinkage" has added asmlinkage annotation to lockdep_sys_exit, which broke build of liblockdep. Since we don't need asmlinkage in liblockep, just ignore it. Reported-by: Eunbong Song <eunb.song@samsung.com> Reported-by: Robin Hack <rhack@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2014-03-31Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf changes from Ingo Molnar: "Main changes: Kernel side changes: - Add SNB/IVB/HSW client uncore memory controller support (Stephane Eranian) - Fix various x86/P4 PMU driver bugs (Don Zickus) Tooling, user visible changes: - Add several futex 'perf bench' microbenchmarks (Davidlohr Bueso) - Speed up thread map generation (Don Zickus) - Introduce 'perf kvm --list-cmds' command line option for use by scripts (Ramkumar Ramachandra) - Print the evsel name in the annotate stdio output, prep to fix support outputting annotation for multiple events, not just for the first one (Arnaldo Carvalho de Melo) - Allow setting preferred callchain method in .perfconfig (Jiri Olsa) - Show in what binaries/modules 'perf probe's are set (Masami Hiramatsu) - Support distro-style debuginfo for uprobe in 'perf probe' (Masami Hiramatsu) Tooling, internal changes and fixes: - Use tid in mmap/mmap2 events to find maps (Don Zickus) - Record the reason for filtering an address_location (Namhyung Kim) - Apply all filters to an addr_location (Namhyung Kim) - Merge al->filtered with hist_entry->filtered in report/hists (Namhyung Kim) - Fix memory leak when synthesizing thread records (Namhyung Kim) - Use ui__has_annotation() in 'report' (Namhyung Kim) - hists browser refactorings to reuse code accross UIs (Namhyung Kim) - Add support for the new DWARF unwinder library in elfutils (Jiri Olsa) - Fix build race in the generation of bison files (Jiri Olsa) - Further streamline the feature detection display, trimming it a bit to show just the libraries detected, using VF=1 gets a more verbose output, showing the less interesting feature checks as well (Jiri Olsa). - Check compatible symtab type before loading dso (Namhyung Kim) - Check return value of filename__read_debuglink() (Stephane Eranian) - Move some hashing and fs related code from tools/perf/util/ to tools/lib/ so that it can be used by more tools/ living utilities (Borislav Petkov) - Prepare DWARF unwinding code for using an elfutils alternative unwinding library (Jiri Olsa) - Fix DWARF unwind max_stack processing (Jiri Olsa) - Add dwarf unwind 'perf test' entry (Jiri Olsa) - 'perf probe' improvements including memory leak fixes, sharing the intlist class with other tools, uprobes/kprobes code sharing and use of ref_reloc_sym (Masami Hiramatsu) - Shorten sample symbol resolving by adding cpumode to struct addr_location (Arnaldo Carvalho de Melo) - Fix synthesizing mmaps for threads (Don Zickus) - Fix invalid output on event group stdio report (Namhyung Kim) - Fixup header alignment in 'perf sched latency' output (Ramkumar Ramachandra) - Fix off-by-one error in 'perf timechart record' argv handling (Ramkumar Ramachandra) Tooling, cleanups: - Remove unused thread__find_map function (Jiri Olsa) - Remove unused simple_strtoul() function (Ramkumar Ramachandra) Tooling, documentation updates: - Update function names in debug messages (Ramkumar Ramachandra) - Update some code references in design.txt (Ramkumar Ramachandra) - Clarify load-latency information in the 'perf mem' docs (Andi Kleen) - Clarify x86 register naming in 'perf probe' docs (Andi Kleen)" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (96 commits) perf tools: Remove unused simple_strtoul() function perf tools: Update some code references in design.txt perf evsel: Update function names in debug messages perf tools: Remove thread__find_map function perf annotate: Print the evsel name in the stdio output perf report: Use ui__has_annotation() perf tools: Fix memory leak when synthesizing thread records perf tools: Use tid in mmap/mmap2 events to find maps perf report: Merge al->filtered with hist_entry->filtered perf symbols: Apply all filters to an addr_location perf symbols: Record the reason for filtering an address_location perf sched: Fixup header alignment in 'latency' output perf timechart: Fix off-by-one error in 'record' argv handling perf machine: Factor machine__find_thread to take tid argument perf tools: Speed up thread map generation perf kvm: introduce --list-cmds for use by scripts perf ui hists: Pass evsel to hpp->header/width functions explicitly perf symbols: Introduce thread__find_cpumode_addr_location perf session: Change header.misc dump from decimal to hex perf ui/tui: Reuse generic __hpp__fmt() code ...
2014-03-31Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU updates from Ingo Molnar: "Main changes: - Torture-test changes, including refactoring of rcutorture and introduction of a vestigial locktorture. - Real-time latency fixes. - Documentation updates. - Miscellaneous fixes" * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (77 commits) rcu: Provide grace-period piggybacking API rcu: Ensure kernel/rcu/rcu.h can be sourced/used stand-alone rcu: Fix sparse warning for rcu_expedited from kernel/ksysfs.c notifier: Substitute rcu_access_pointer() for rcu_dereference_raw() Documentation/memory-barriers.txt: Clarify release/acquire ordering rcutorture: Save kvm.sh output to log rcutorture: Add a lock_busted to test the test rcutorture: Place kvm-test-1-run.sh output into res directory rcutorture: Rename TREE_RCU-Kconfig.txt locktorture: Add kvm-recheck.sh plug-in for locktorture rcutorture: Gracefully handle NULL cleanup hooks locktorture: Add vestigial locktorture configuration rcutorture: Introduce "rcu" directory level underneath configs rcutorture: Rename kvm-test-1-rcu.sh rcutorture: Remove RCU dependencies from ver_functions.sh API rcutorture: Create CFcommon file for common Kconfig parameters rcutorture: Create config files for scripted test-the-test testing rcutorture: Add an rcu_busted to test the test locktorture: Add a lock-torture kernel module rcutorture: Abstract kvm-recheck.sh ...
2014-03-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: Documentation/devicetree/bindings/net/micrel-ks8851.txt net/core/netpoll.c The net/core/netpoll.c conflict is a bug fix in 'net' happening to code which is completely removed in 'net-next'. In micrel-ks8851.txt we simply have overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-18perf tools: Remove unused simple_strtoul() functionRamkumar Ramachandra
Moreover, the corresponding function in include/linux/kernel.h is marked obsolete. Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1395176715-4465-1-git-send-email-artagnon@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf tools: Update some code references in design.txtRamkumar Ramachandra
Update the names of some functions and enums in design.txt. The document still has some stale information, but the motivation behind this patch is to allow a developer to quickly grep and learn about the associated structures. Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1395169804-1293-1-git-send-email-artagnon@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf evsel: Update function names in debug messagesRamkumar Ramachandra
perf_event_open() was renamed to sys_perf_event_open(); update the debug messages to reflect this. Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1395169842-1399-1-git-send-email-artagnon@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf tools: Remove thread__find_map functionJiri Olsa
Because it's not used any more. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1395154016-26709-3-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf annotate: Print the evsel name in the stdio outputArnaldo Carvalho de Melo
So that when showing multiple events annotations, we can figure out which is which: # perf record -a -e instructions,cycles sleep 1 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.826 MB perf.data (~36078 samples) ] # perf evlist instructions cycles # perf annotate intel_idle 2> /dev/null | head -1 Percent | Source code & Disassembly of vmlinux for instructions # Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-n1r51l329434js84qtb2c6l9@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf report: Use ui__has_annotation()Namhyung Kim
Since we introduced the ui__has_annotation() for that, don't open code it. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1395124359-11744-2-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf tools: Fix memory leak when synthesizing thread recordsNamhyung Kim
Checking default guest machine should be done before allocating event structures otherwise it'll leak memory. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Don Zickus <dzickus@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Joe Mario <jmario@redhat.com> Link: http://lkml.kernel.org/r/87ob15tx6a.fsf@sejong.aot.lge.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf tools: Use tid in mmap/mmap2 events to find mapsDon Zickus
Now that we can properly synthesize threads system-wide, make sure the mmap and mmap2 events use tids instead of pids to locate their maps. Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1393429527-167840-3-git-send-email-dzickus@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf report: Merge al->filtered with hist_entry->filteredNamhyung Kim
I.e. don't drop al->filtered entries, create the hist_entries and use its ->filtered bitmap, that is kept with the same semantics for its bitmap, leaving the filtering to be done at the hist_entry level, i.e. in the UIs. This will allow zooming in/out the filters. Signed-off-by: Namhyung Kim <namhyung.kim@lge.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-xeyhkepu7plw716lrtb0zlnu@git.kernel.org [ yanked this out of a previous patch ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
