path: root/tools
2009-12-18perf session: Make events_stats u64 to avoid overflow on 32-bit archesArnaldo Carvalho de Melo
Pekka Enberg reported weird percentages in perf report. It turns out we are overflowing a 32-bit variables in struct events_stats on 32-bit architectures. Before: [acme@ana linux-2.6-tip]$ perf report -i pekka.perf.data 2> /dev/null | head -10 281.96% Xorg b710a561 [.] 0x000000b710a561 140.15% Xorg [kernel] [k] __initramfs_end 51.56% metacity libgobject-2.0.so.0.2000.1 [.] 0x00000000026e46 35.12% evolution libcairo.so.2.10800.6 [.] 0x000000000203bd 33.84% metacity libpthread-2.9.so [.] 0x00000000007a3d After: [acme@ana linux-2.6-tip]$ perf report -i pekka.perf.data 2> /dev/null | head -10 30.04% Xorg b710a561 [.] 0x000000b710a561 14.93% Xorg [kernel] [k] __initramfs_end 5.49% metacity libgobject-2.0.so.0.2000.1 [.] 0x00000000026e46 3.74% evolution libcairo.so.2.10800.6 [.] 0x000000000203bd 3.61% metacity libpthread-2.9.so [.] 0x00000000007a3d Reported-by: Pekka Enberg <penberg@cs.helsinki.fi> Tested-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1261148583-20395-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-17perf probe: Check new event nameMasami Hiramatsu
Check new event name is same syntax as a C symbol in perf command. In other words, checking the name is as like as other tracepoint events. This can prevent user to create an event with useless name (e.g. foo|bar, foo*bar). Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> LKML-Reference: <20091216222415.14459.71383.stgit@dhcp-100-2-132.bos.redhat.com> [ v2: minor cleanups ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-17perf probe: Check whether debugfs path is correctMasami Hiramatsu
Check whether the debugfs path is correct before executing a command, because perf-probe depends on debugfs. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> LKML-Reference: <20091216222400.14459.48162.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-17perf probe: Fix libdwarf include path for DebianMasami Hiramatsu
Fix libdwarf include path to fit debian-like systems too. Borislav Petkov reported: > even after installing libdwarf-dev on my debian box here, > make in tools/perf/ still complains that it cannot find libdwarf: > > Makefile:491: No libdwarf.h found or old libdwarf.h found, disables dwarf > support. Please install libdwarf-dev/libdwarf-devel >= 20081231 > > The problem is that the include path on debian is not > /usr/include/libdwarf/ but simply /usr/include because the debian > package libdwarf-dev puts the headers straight into > /usr/include. This patch adds -I/usr/include/libdwarf to BASIC_CFLAGS and fix probe-finder.h to include just libdwarf.h/dwarf.h. This patch also adds a workaround for the undefined _MIPS_SZLONG bug in libdwarf.h. Reported-by: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Gabor Gombas <gombasg@sztaki.hu> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> LKML-Reference: <20091216221618.13816.83296.stgit@dhcp-100-2-132.bos.redhat.com> [ v2: small stylistic fixlets to probe-finder.h ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf record: Use per-task-per-cpu events for inherited eventsPeter Zijlstra
Create events with a pid and cpu contraint for inherited events so that we get a stream per cpu, instead of all cpus contending on a single stream. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: fweisbec@gmail.com Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <20091216165904.987643843@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf record: Properly synchronize child creationPeter Zijlstra
Remove that ugly usleep and provide proper serialization between parent and child just like perf-stat does. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: fweisbec@gmail.com Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <20091216165904.908184135@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf diff: Percent calcs should use double valuesArnaldo Carvalho de Melo
Otherwise we do integer math and the delta values round up to multiples of 1.0%. Also, calculate absolute values. Things look precise now: $ perf report -i perf.data.old --sort dso,symbol | head -13 9.02% libc-2.10.1.so [.] _IO_vfprintf_internal 4.88% find [.] 0x00000000014af0 2.91% [kernel] [k] __kmalloc 2.85% [kernel] [k] ext4_htree_store_dirent 2.50% libc-2.10.1.so [.] __GI_memmove 2.44% [kernel] [k] half_md4_transform 2.43% [kernel] [k] _spin_lock 2.33% [kernel] [k] system_call $ perf report -i perf.data --sort dso,symbol | head -13 8.55% libc-2.10.1.so [.] _IO_vfprintf_internal 3.11% [kernel] [k] __kmalloc 3.07% [kernel] [k] ext4_htree_store_dirent 2.66% find [.] 0x00000000016bcf 2.61% [kernel] [k] _atomic_dec_and_lock 2.46% [kernel] [k] half_md4_transform 2.41% libc-2.10.1.so [.] __GI_memmove 2.30% find [.] 0x00000000009219 $ perf diff | head -13 9.02% -0.47% libc-2.10.1.so [.] _IO_vfprintf_internal 2.91% +0.20% [kernel] [k] __kmalloc 2.85% +0.23% [kernel] [k] ext4_htree_store_dirent 1.99% +0.62% [kernel] [k] _atomic_dec_and_lock 2.44% +0.02% [kernel] [k] half_md4_transform 2.50% -0.09% libc-2.10.1.so [.] __GI_memmove 1.88% +0.01% [kernel] [k] __d_lookup 2.43% -0.75% [kernel] [k] _spin_lock 0.97% +0.62% [kernel] [k] path_get 1.99% -0.42% libc-2.10.1.so [.] _int_malloc $ Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260981109-2621-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf diff: Change the default sort order to "dso,symbol"Arnaldo Carvalho de Melo
This is a more intuitive / more meaningful default: $ perf diff | head -8 9.02% +1.00% libc-2.10.1.so [.] _IO_vfprintf_internal 2.91% -1.00% [kernel] [k] __kmalloc 2.85% -1.00% [kernel] [k] ext4_htree_store_dirent 1.99% -1.00% [kernel] [k] _atomic_dec_and_lock 2.44% [kernel] $ Suggested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260979793-1981-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf diff: Use perf_session__fprintf_hists just like 'perf record'Arnaldo Carvalho de Melo
That means that almost everything you can do with 'perf report' can be done with 'perf diff', for instance: $ perf record -f find / > /dev/null [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.062 MB perf.data (~2699 samples) ] $ perf record -f find / > /dev/null [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.062 MB perf.data (~2687 samples) ] perf diff | head -8 9.02% +1.00% find libc-2.10.1.so [.] _IO_vfprintf_internal 2.91% -1.00% find [kernel] [k] __kmalloc 2.85% -1.00% find [kernel] [k] ext4_htree_store_dirent 1.99% -1.00% find [kernel] [k] _atomic_dec_and_lock 2.44% find [kernel] [k] half_md4_transform $ So if you want to zoom into libc: $ perf diff --dsos libc-2.10.1.so | head -8 37.34% find [.] _IO_vfprintf_internal 10.34% find [.] __GI_memmove 8.25% +2.00% find [.] _int_malloc 5.07% -1.00% find [.] __GI_mempcpy 7.62% +2.00% find [.] _int_free $ And if there were multiple commands using libc, it is also possible to aggregate them all by using --sort symbol: $ perf diff --dsos libc-2.10.1.so --sort symbol | head -8 37.34% [.] _IO_vfprintf_internal 10.34% [.] __GI_memmove 8.25% +2.00% [.] _int_malloc 5.07% -1.00% [.] __GI_mempcpy 7.62% +2.00% [.] _int_free $ The displacement column now is off by default, to use it: perf diff -m --dsos libc-2.10.1.so --sort symbol | head -8 37.34% [.] _IO_vfprintf_internal 10.34% [.] __GI_memmove 8.25% +2.00% [.] _int_malloc 5.07% -1.00% +2 [.] __GI_mempcpy 7.62% +2.00% -1 [.] _int_free $ Using -t/--field-separator can be used for scripting: $ perf diff -t, -m --dsos libc-2.10.1.so --sort symbol | head -8 37.34, , ,[.] _IO_vfprintf_internal 10.34, , ,[.] __GI_memmove 8.25,+2.00%, ,[.] _int_malloc 5.07,-1.00%, +2,[.] __GI_mempcpy 7.62,+2.00%, -1,[.] _int_free 6.99,+1.00%, -1,[.] _IO_new_file_xsputn 1.89,-2.00%, +4,[.] __readdir64 $ Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260978567-550-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf report: Fix cut'n'paste error recently introducedArnaldo Carvalho de Melo
Introduced in: d599db3fc5dd4f1e8432fdbc6d899584b25f4dff "perf report: Generalize perf_session__fprintf_hists()" Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260973631-28035-3-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf session: Move perf report specific hits out of perf_session__fprintf_histsArnaldo Carvalho de Melo
Those don't make sense for tools such as 'perf diff'. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260973631-28035-2-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf tools: Move hist entries printing routines from perf reportArnaldo Carvalho de Melo
Will be used in other tools such as 'perf diff'. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260973631-28035-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf report: Generalize perf_session__fprintf_hists()Arnaldo Carvalho de Melo
Pull it out of builtin-report - further changes will be made and it will then be reusable in 'perf diff' as well. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260914682-29652-4-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf symbols: Move symbol filtering to event__preprocess_sample()Arnaldo Carvalho de Melo
So that --dsos, --comm, --symbols can bem used in more tools, like in perf diff: $ perf record -f find / > /dev/null $ perf record -f find / > /dev/null $ perf diff --dsos /lib64/libc-2.10.1.so | head -5 1 +22392124 /lib64/libc-2.10.1.so _IO_vfprintf_internal 2 +6410655 /lib64/libc-2.10.1.so __GI_memmove 3 +1 +9192692 /lib64/libc-2.10.1.so _int_malloc 4 -1 -15158605 /lib64/libc-2.10.1.so _int_free 5 +45669 /lib64/libc-2.10.1.so _IO_new_file_xsputn $ Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260914682-29652-3-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf symbols: Adopt the strlists for dso, commArnaldo Carvalho de Melo
Will be used in perf diff too. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260914682-29652-2-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf symbols: Make symbol_conf globalArnaldo Carvalho de Melo
This simplifies a lot of functions, less stuff to be done by tool writers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260914682-29652-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Fix to show which probe point is not foundMasami Hiramatsu
Fix perf probe to show which probe point is not found. With out this patch, it shows just "No probe point found." This doesn't help users if they specify several probes. e.g. # perf probe -f --add schedule --add test Fatal: No probe point found. This patch makes error message more helpful as below. # perf probe --add schedule --add test Fatal: Probe point 'test' not found. - probe not added. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153247.17436.49068.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Check symbols in symtab/kallsymsMasami Hiramatsu
Check symbols in symtab/kallsyms when no debuginfo is available. e.g. # perf probe test Fatal: Kernel symbol 'test' not found - probe not added. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153239.17436.55034.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Check build-id of vmlinuxMasami Hiramatsu
Check build-id of vmlinux by using functions in symbol.c. This also exposes map__load() for getting vmlinux path, and removes vmlinux path list in builtin-probe.c, because symbol.c already has that. Checking build-id prevents users to open old or different debuginfo from current running kernel. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153232.17436.45539.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Reject second attempt of adding same-name eventMasami Hiramatsu
Reject second attempt of adding same-name event. This patch also provides --force option which allows user to add additional probe events on the same-name event. e.g. (the first attempt : success) ./perf probe schedule Added new event: probe:schedule (on schedule+0) (the second attempt : failure) ./perf probe schedule:11 Error: event "schedule" already exists. (Use -f to force duplicates.) Fatal: Can't add new event. (the second attempt with -f : successfully added) ./perf probe -f schedule:11 Added new event: probe:schedule_1 (on schedule+45) Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153225.17436.15166.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Support event name for --add optionMasami Hiramatsu
Support event name syntax for --add option. This allows users to specify event name for each new event. The --add syntax is: perf probe --add '[EVENT=]SRC:LINE ARGS' or perf probe --add '[EVENT=]FUNC[+OFFS|%return|:RLN][@SRC] ARGS' e.g. ./perf probe --add myprobe1=schedule Note: currently group name is not supported yet, because it can cause name-space confliction with other tracepoint/ hw-breakpoint events. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153218.17436.84675.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Add glob matching support on --delMasami Hiramatsu
Add glob-expression matching support on --del option. You can use wildcards for specifying deleting events. e.g. Clear all probe events: # perf probe --del '*' Clear probes on schedule(): # perf probe --del 'schedule*' Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153210.17436.12327.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Use strlist__for_each macros in probe-event.cMasami Hiramatsu
Use strlist__for_each macros instead of using strlist__entry() and index variable. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153203.17436.52039.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf tools: Add for_each macros for strlistMasami Hiramatsu
Add for_each iteration macros for strlist. This patch introduces strlist__for_each() and strlist__for_each_safe(), both are similar to list_for_each() and list_for_each_safe(). Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153156.17436.49157.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Fix --del to update current event listMasami Hiramatsu
Fix --del option to update current existing event list after perf probe deleted an event. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153149.17436.61265.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Fix --del to show info instead of warningMasami Hiramatsu
Fix --del option to show info message instead of warning if failing to find specified event. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153142.17436.7793.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Show need-dwarf message only if it is really neededMasami Hiramatsu
Show need-dwarf message only if the probe is really requires debuginfo analysis. This also use pr_debug for debugging message instead of pr_warning. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153135.17436.99052.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Check hyphen only argumentMasami Hiramatsu
Check hyphen only command argument, because perf-probe doesn't support event recording feature yet. e.g. # perf probe - Error: '-' is not supported. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153128.17436.9266.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Check the result of e_snprintf()Masami Hiramatsu
Fix show_perf_probe_event() to check the result of e_snprintf(). Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153121.17436.34674.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Cleanup struct session in builtin-probe.cMasami Hiramatsu
Clean up struct session in builtin-probe.c, including change need_dwarf to bool and move listing flag into struct session as list_events flag. This also changes parse_perf_probe_event() interface due to code readability. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153114.17436.77000.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf diff: Fix documentationArnaldo Carvalho de Melo
Add a newline do fix this problem: ERROR: perf-diff.txt: line 31: closing [blockdef-listing] delimiter expected Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260882082-10007-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf diff: Improve the help textIngo Molnar
Fix the short line displayed by 'perf' and also fix some other details in the longer text. Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf trace/scripting: Update DocumentationTom Zanussi
Update the perf-trace page with new and missing options and remove some unused ones. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: fweisbec@gmail.com Cc: rostedt@goodmis.org LKML-Reference: <1260867220-15699-7-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf trace/scripting: Add 'record' and 'report' optionsTom Zanussi
Allow scripts to be recorded/executed by simply specifying the script root name (the script name minus extension) along with 'record' or 'report' to 'perf trace'. The script names shown by 'perf trace -l' can be directly used to run the command-line contained within the corresponding '-record' and '-report' versions of scripts in the scripts/*/bin directories. For example, to record the trace data needed to run the wakeup-latency.pl script, the user can easily find the name of the corresponding script from the script list and invoke it using 'perf trace record', without having to remember the details of how to do the same thing using the lower-level perf trace command-line options: root@tropicana:~# perf trace -l List of available trace scripts: workqueue-stats workqueue stats (ins/exe/create/destroy) wakeup-latency system-wide min/max/avg wakeup latency rw-by-file <comm> r/w activity for a program, by file check-perf-trace useless but exhaustive test script rw-by-pid system-wide r/w activity root@tropicana:~# perf trace record wakeup-latency ^C[ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.296 MB perf.data (~12931 samples) ] To run the wakeup-latency.pl script using the captured data, change 'record' to 'report' in the command-line: root@tropicana:~# perf trace report wakeup-latency wakeup_latency stats: total_wakeups: 65 avg_wakeup_latency (ns): 22417 min_wakeup_latency (ns): 3470 max_wakeup_latency (ns): 223311 perf trace Perl script stopped If the script takes options, thay can be simply added to the end of the 'report' invocation: root@tropicana:~# perf trace record rw-by-file ^C[ perf record: Woken up 2 times to write data ] [ perf record: Captured and wrote 0.782 MB perf.data (~34171 samples) ] root@tropicana:~# perf trace report rw-by-file perf file read counts for perf: fd # reads bytes_requested ------ ---------- ----------- 122 1934 1980416 120 1 32 file write counts for perf: fd # writes bytes_written ------ ---------- ----------- 3 4006 280568 perf trace Perl script stopped Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: fweisbec@gmail.com Cc: rostedt@goodmis.org LKML-Reference: <1260867220-15699-6-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf trace/scripting: List available scriptsTom Zanussi
Lists the available perf trace scripts, one per line e.g.: root@tropicana:~# perf trace -l List of available trace scripts: workqueue-stats workqueue stats (ins/exe/create/destroy) wakeup-latency system-wide min/max/avg wakeup latency rw-by-file <comm> r/w activity for a program, by file check-perf-trace useless but exhaustive test script rw-by-pid system-wide r/w activity To be consistent with the other listing options in perf, the current latency trace option was changed to '-L', and '-l' is now used to access the script listing as: To create the list, it searches each scripts/*/bin directory for files ending with "-report" and reads information found in certain comment lines contained in those shell scripts: - if the comment line starts with "description:", the rest of the line is used as a 'half-line' description. To keep each line in the list to a single line, the description should be limited to 40 characters (the rest of the line contains the script name and args) - if the comment line starts with "args:", the rest of the line names the args the script supports. Required args should be surrounded by <> brackets, optional args by [] brackets. The current scripts in scripts/perl/bin have also been updated with description: and args: comments. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: fweisbec@gmail.com Cc: rostedt@goodmis.org LKML-Reference: <1260867220-15699-5-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf trace/scripting: Check return val of perl_run()Tom Zanussi
The return value from perl_run() is currently ignored, but it should be checked and used to exit perf if there are problems loading the script. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: fweisbec@gmail.com Cc: rostedt@goodmis.org LKML-Reference: <1260867220-15699-4-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf trace/scripting: Don't install unneeded filesTom Zanussi
README and Makefile.PL don't need to be installed for Perl run-time support. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: fweisbec@gmail.com Cc: rostedt@goodmis.org LKML-Reference: <1260867220-15699-3-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf trace/scripting: Add support for script argsTom Zanussi
One oversight of the original scripting_ops patch was a lack of support for passing args to handler scripts. This adds argc/argv to the start_script() scripting_op, and changes the rw-by-file script to take 'comm' arg rather than the 'perf' value currently hard-coded. It also takes the opportunity to do some related minor cleanup. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: fweisbec@gmail.com Cc: rostedt@goodmis.org LKML-Reference: <1260867220-15699-2-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf tools: Make symbol_conf staticFrederic Weisbecker
perf top, report and annotate all define their own symbol_conf, it should be static. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260843322-6602-1-git-send-regression-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf diff: Introduce tool to show performance differenceArnaldo Carvalho de Melo
I guess it is enough to show some examples: [root@doppio linux-2.6-tip]# rm -f perf.data* [root@doppio linux-2.6-tip]# ls -la perf.data* ls: cannot access perf.data*: No such file or directory [root@doppio linux-2.6-tip]# perf record -f find / > /dev/null [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.062 MB perf.data (~2699 samples) ] [root@doppio linux-2.6-tip]# ls -la perf.data* -rw------- 1 root root 74440 2009-12-14 20:03 perf.data [root@doppio linux-2.6-tip]# perf record -f find / > /dev/null [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.062 MB perf.data (~2692 samples) ] [root@doppio linux-2.6-tip]# ls -la perf.data* -rw------- 1 root root 74280 2009-12-14 20:03 perf.data -rw------- 1 root root 74440 2009-12-14 20:03 perf.data.old [root@doppio linux-2.6-tip]# perf diff | head -5 1 -34994580 /lib64/libc-2.10.1.so _IO_vfprintf_internal 2 -15307806 [kernel.kallsyms] __kmalloc 3 +1 +3665941 /lib64/libc-2.10.1.so __GI_memmove 4 +4 +23508995 /lib64/libc-2.10.1.so _int_malloc 5 +7 +38538813 [kernel.kallsyms] __d_lookup [root@doppio linux-2.6-tip]# perf diff -p | head -5 1 +1.00% /lib64/libc-2.10.1.so _IO_vfprintf_internal 2 [kernel.kallsyms] __kmalloc 3 +1 /lib64/libc-2.10.1.so __GI_memmove 4 +4 /lib64/libc-2.10.1.so _int_malloc 5 +7 -1.00% [kernel.kallsyms] __d_lookup [root@doppio linux-2.6-tip]# perf diff -v | head -5 1 361449551 326454971 -34994580 /lib64/libc-2.10.1.so _IO_vfprintf_internal 2 151009241 135701435 -15307806 [kernel.kallsyms] __kmalloc 3 +1 101805328 105471269 +3665941 /lib64/libc-2.10.1.so __GI_memmove 4 +4 78041440 101550435 +23508995 /lib64/libc-2.10.1.so _int_malloc 5 +7 59536172 98074985 +38538813 [kernel.kallsyms] __d_lookup [root@doppio linux-2.6-tip]# perf diff -vp | head -5 1 9.00% 8.00% +1.00% /lib64/libc-2.10.1.so _IO_vfprintf_internal 2 3.00% 3.00% [kernel.kallsyms] __kmalloc 3 +1 2.00% 2.00% /lib64/libc-2.10.1.so __GI_memmove 4 +4 2.00% 2.00% /lib64/libc-2.10.1.so _int_malloc 5 +7 1.00% 2.00% -1.00% [kernel.kallsyms] __d_lookup [root@doppio linux-2.6-tip]# This should be enough for diffs where the system is non volatile, i.e. when one doesn't updates binaries. For volatile environments, stay tuned for the next perf tool feature: a buildid cache populated by 'perf record', managed by 'perf buildid-cache' a-la ccache, and used by all the report tools. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> LKML-Reference: <1260828571-3613-3-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf record: Rename perf.data to perf.data.old if --force/-f is usedArnaldo Carvalho de Melo
Suggested-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260828571-3613-2-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf util: Remove setup_sorting dupsArnaldo Carvalho de Melo
And it is also needed by 'perf diff'. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260828571-3613-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf session: Event statistics also are per sessionArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260810361-22828-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-14perf session: Adopt the sample_type variableArnaldo Carvalho de Melo
All tools had copies, and perf diff would have to specify a sample_type_check method just for copying it. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260807780-19377-2-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-14perf session: Adopt resolve_callchainArnaldo Carvalho de Melo
This is really a generic library routine, so declutter builtin-report.c a bit by moving it to the library. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260807780-19377-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-14perf session: Move the hist_entries rb tree to perf_sessionArnaldo Carvalho de Melo
As we'll need to sort multiple times for multiple perf sessions, so that we can then do a diff. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260803439-16783-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-14perf tools: No need for three rb_trees for sorting hist entriesArnaldo Carvalho de Melo
All hist entries are in only one of them, so use just one and a temporary rb_root while sorting/collapsing. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260797831-11220-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-14perf session: Move kmaps to perf_sessionArnaldo Carvalho de Melo
There is still some more work to do to disentangle map creation from DSO loading, but this happens only for the kernel, and for the early adopters of perf diff, where this disentanglement matters most, we'll be testing different kernels, so no problem here. Further clarification: right now we create the kernel maps for the various modules and discontiguous kernel text maps when loading the DSO, we should do it as a two step process, first creating the maps, for multiple mappings with the same DSO store, then doing the dso load just once, for the first hit on one of the maps sharing this DSO backing store. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260741029-4430-6-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-14perf session: Move the global threads list to perf_sessionArnaldo Carvalho de Melo
So that we can process two perf.data files. We still need to add a O_MMAP mode for perf_session so that we can do all the mmap stuff in it. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260741029-4430-5-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-14perf session: Reduce the number of parms to perf_session__process_eventsArnaldo Carvalho de Melo
By having the cwd/cwdlen in the perf_session struct and full_paths in perf_event_ops. Now its just a matter of passing the ops. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260741029-4430-4-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
