path: root/tools
2011-07-23Merge branches 'x86-urgent-for-linus', 'core-debug-for-linus', ↵Linus Torvalds
'irq-core-for-linus' and 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: um: Make rwsem.S depend on CONFIG_RWSEM_XCHGADD_ALGORITHM * 'core-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: debug: Make CONFIG_EXPERT select CONFIG_DEBUG_KERNEL to unhide debug options * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Remove unused CHECK_IRQ_PER_CPU() * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf tools, x86: Fix 32-bit compile on 64-bit system
2011-07-21perf tools, x86: Fix 32-bit compile on 64-bit systemDavid Ahern
Builds for 32-bit perf binaries on a 64-bit host currently fail with this error: [...] bench/../../../arch/x86/lib/memcpy_64.S: Assembler messages: bench/../../../arch/x86/lib/memcpy_64.S:29: Error: bad register name `%rdi' bench/../../../arch/x86/lib/memcpy_64.S:34: Error: invalid instruction suffix for `movs' bench/../../../arch/x86/lib/memcpy_64.S:50: Error: bad register name `%rdi' bench/../../../arch/x86/lib/memcpy_64.S:61: Error: bad register name `%rdi' ... The problem is the detection of the host arch without considering passed in flags. This change fixes 32-bit builds via: make EXTRA_CFLAGS=-m32 and 64-bit builds still reference the memcpy_64.S. Signed-off-by: David Ahern <dsahern@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <stable@kernel.org> Link: http://lkml.kernel.org/r/1310420304-21452-1-git-send-email-dsahern@gmail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-21perf tools: Make test use the preset debugfs pathJiri Olsa
Use preset debugfs path instead of hardcoded one. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: acme@redhat.com Cc: a.p.zijlstra@chello.nl Cc: paulus@samba.org Link: http://lkml.kernel.org/r/1310635534-4013-4-git-send-email-jolsa@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-21perf tools: Add automated tests for events parsingJiri Olsa
Adding builtin test for parse_events function, which is responsible for parsing/processing "-e" option for stat/top/record commands. This new test will run within the builtin test command suite (perf test). One or several tests were added for each type of event. More tests could be added easily if needed. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: acme@redhat.com Cc: a.p.zijlstra@chello.nl Cc: paulus@samba.org Link: http://lkml.kernel.org/r/1310635534-4013-3-git-send-email-jolsa@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-21perf tools: De-opt the parse_events functionJiri Olsa
Moving out the option parameter from parse_events function, and adding new parse_events_option function instead. The option parameter is used only to carry "struct perf_evlist" pointer for chaining new events. Putting it away, enable us to call parse_events from other places without using the option parameter. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: acme@redhat.com Cc: a.p.zijlstra@chello.nl Cc: paulus@samba.org Link: http://lkml.kernel.org/r/1310635534-4013-2-git-send-email-jolsa@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-21perf script: Fix display of IP address for non-callchain pathDavid Ahern
Non-callchain path is using al.addr which prints as: openssl 14564 17672.003587: 7862d _x86_64_AES_encrypt_compact This should be sample->ip to print as: openssl 14564 17672.003587: 3f7867862d _x86_64_AES_encrypt_compact Signed-off-by: David Ahern <dsahern@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: acme@ghostprotocols.net Cc: peterz@infradead.org Cc: paulus@samba.org Link: http://lkml.kernel.org/r/1306768587-15376-1-git-send-email-dsahern@gmail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-21perf tools: Fix endian conversion reading event attr from file headerDavid Ahern
The perf_event_attr struct has two __u32's at the top and they need to be swapped individually. With this change I was able to analyze a perf.data collected in a 32-bit PPC VM on an x86 system. I tested both 32-bit and 64-bit binaries for the Intel analysis side; both read the PPC perf.data file correctly. -v2: - changed the existing perf_event__attr_swap() to swap only elements of perf_event_attr and exported it for use in swapping the attributes in the file header - updated swap_ops used for processing events Signed-off-by: David Ahern <dsahern@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: acme@ghostprotocols.net Cc: peterz@infradead.org Cc: paulus@samba.org Cc: <stable@kernel.org> Link: http://lkml.kernel.org/r/1310754849-12474-1-git-send-email-dsahern@gmail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-21perf tools: Add missing 'node' alias to the hw_cache[] arrayJiri Olsa
Add "node" as a simple alias for NODE cache events. The addition of NODE cache events broke the parse_alias function, so any mismatched event caused the segfault, like: # ./perf stat -e krava ls The hw_cache/hw_cache_op/hw_cache_result arrays needs to follow PERF_COUNT_HW_CACHE_*MAX enums. Adding those MAXs to be size of those arrays, so possible ommision in future wil not lead to segfault. Adding read/write/prefetch as allowed operations for node cache event. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: acme@redhat.com Link: http://lkml.kernel.org/r/20110713205818.GB7827@jolsa.brq.redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-15perf probe: Support adding probes on offline kernel modulesMasami Hiramatsu
Support adding probes on offline kernel modules. This enables perf-probe to trace kernel-module init functions via perf-probe. If user gives the path of module with -m option, perf-probe expects the module is offline. This feature works with --add, --funcs, and --vars. E.g) # perf probe -m /lib/modules/`uname -r`/kernel/fs/btrfs/btrfs.ko \ -a "extent_io_init:5 extent_state_cache" Add new events: probe:extent_io_init (on extent_io_init:5 with extent_state_cache) probe:extent_io_init_1 (on extent_io_init:5 with extent_state_cache) You can now use it on all perf tools, such as: perf record -e probe:extent_io_init_1 -aR sleep 1 Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Link: http://lkml.kernel.org/r/20110627072751.6528.10230.stgit@fedora15 Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-15perf probe: Add probed module in front of functionMasami Hiramatsu
Add probed module name and ":" in front of function name if -m module option is given. In the result, the symbol name passed to kprobe-tracer becomes MODULE:FUNCTION, so that kallsyms can solve it as a symbol in the module correctly. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Link: http://lkml.kernel.org/r/20110627072745.6528.26416.stgit@fedora15 Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-15perf probe: Introduce debuginfo to encapsulate dwarf informationMasami Hiramatsu
Introduce debuginfo to encapsulate dwarf information. This new object allows us to reuse and expand debuginfo easily. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Link: http://lkml.kernel.org/r/20110627072739.6528.12438.stgit@fedora15 Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-15perf-probe: Move dwarf library routines to dwarf-aux.{c, h}Masami Hiramatsu
Move dwarf library related routines to dwarf-aux.{c,h}. This includes several minor changes. - Add simple documents for each API. - Rename die_find_real_subprogram() to die_find_realfunc() - Rename line_walk_handler_t to line_walk_callback_t. - Minor cleanups. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Link: http://lkml.kernel.org/r/20110627072727.6528.57647.stgit@fedora15 Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-15perf probe: Remove redundant dwarf functionsMasami Hiramatsu
Since there are dwarf_bitsize, dwarf_bitoffset and dwarf_bytesize defined in libdw, we don't need die_get_bit_size, die_get_bit_offset and die_get_byte_size anymore. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Link: http://lkml.kernel.org/r/20110627072721.6528.2747.stgit@fedora15 Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-15perf probe: Move strtailcmp to string.cMasami Hiramatsu
Since strtailcmp() is enough generic, it should be defined in string.c. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Link: http://lkml.kernel.org/r/20110627072715.6528.10677.stgit@fedora15 Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-15perf probe: Rename DIE_FIND_CB_FOUND to DIE_FIND_CB_ENDMasami Hiramatsu
Since die_find/walk* callbacks use DIE_FIND_CB_FOUND for both of failed and found cases, it should be "END" instead "FOUND" for avoiding confusion. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Reported-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Link: http://lkml.kernel.org/r/20110627072709.6528.45706.stgit@fedora15 Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-14perf: Robustify proc and debugfs file recordingSonny Rao
While attempting to create a timechart of boot up I found perf didn't tolerate modules being loaded/unloaded. This patch fixes this by reading the file once and then writing the size read at the correct point in the file. It also simplifies the code somewhat. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: Sonny Rao <sonnyrao@chromium.org> Signed-off-by: Michael Neuling <mikey@neuling.org> Link: http://lkml.kernel.org/r/10011.1310614483@neuling.org Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-05perf report/annotate/script: Add option to specify a CPU rangeAnton Blanchard
Add an option to perf report/annotate/script to specify which CPUs to operate on. This enables us to take a single system wide profile and analyse each CPU (or group of CPUs) in isolation. This was useful when profiling a multiprocess workload where the bottleneck was on one CPU but this was hidden in the overall profile. Per process and per thread breakdowns didn't help because multiple processes were running on each CPU and no single process consumed an entire CPU. The patch converts the list of CPUs returned by cpu_map__new into a bitmap for fast lookup. I wanted to use -C to be consistent with perf top/record/stat, but unfortunately perf report already uses -C <comms>. v2: Incorporate suggestions from David Ahern: - Added -c to perf script - Check that SAMPLE_CPU is set when -c is used - Update documentation v3: Create perf_session__cpu_bitmap() Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: David Ahern <dsahern@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Link: http://lkml.kernel.org/r/20110704215750.11647eb9@kryten Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01perf stat: Add noise output for csv modeZhengyu He
Previously, when you want perf-stat to output the statistics in csv mode, no information of the noise will be printed out. For example right now we output this --repeat information: ./perf stat -r3 -x, sleep 1 1.164789,task-clock 8,context-switches 0,CPU-migrations 219,page-faults 3337800,cycles With this patch, the output will be appended with an additional entry for the noise value: ./perf stat -r3 -x, sleep 1 1.164789,task-clock,3.75% 8,context-switches,75.00% 0,CPU-migrations,100.00% 219,page-faults,0.00% 3337800,cycles,3.36% Signed-off-by: Zhengyu He <zhengyuh@google.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Stephane Eranian <eranian@google.com> Cc: Venkatesh Pallipadi <venki@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/1308861942-4945-1-git-send-email-zhengyuh@google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01Merge branch 'perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into perf/core
2011-07-01Merge commit 'v3.0-rc5' into perf/coreIngo Molnar
Merge reason: Pick up the latest fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-30perf tools: Only display parent field if explictly sortedFrederic Weisbecker
We don't need to display the parent field if the parent sorting machinery is only used for parent filtering (as in "-p foo"). However if parent filtering is used in combination with explicit parent sorting ( -s parent), we want to display it. Result with: perf report -p kernel_thread -s parent Before: # Overhead Parent symbol # ........ ............. # 0.07% | --- ioread8 ata_sff_check_status ata_sff_tf_load ata_sff_qc_issue ata_bmdma_qc_issue ata_qc_issue ata_scsi_translate ata_scsi_queuecmd scsi_dispatch_cmd scsi_request_fn __blk_run_queue __make_request generic_make_request submit_bio submit_bh journal_submit_commit_record jbd2_journal_commit_transaction kjournald2 kthread kernel_thread_helpe After: # Overhead Parent symbol # ........ ............. # 0.07% kernel_thread_helper | --- ioread8 ata_sff_check_status ata_sff_tf_load ata_sff_qc_issue ata_bmdma_qc_issue ata_qc_issue ata_scsi_translate ata_scsi_queuecmd scsi_dispatch_cmd scsi_request_fn __blk_run_queue __make_request generic_make_request submit_bio submit_bh journal_submit_commit_record jbd2_journal_commit_transaction kjournald2 kthread kernel_thread_helper Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Stephane Eranian <eranian@google.com> Cc: David Ahern <dsahern@gmail.com> Cc: Sam Liao <phyomh@gmail.com>
2011-06-30perf tools: Allow sort dimensions to be registered more than onceFrederic Weisbecker
So that the parent sort dimension can be registered twice: once if we add it as an explicit sort dimension (-s parent) and twice if we request a parent filter (-p foo). We'll have only one parent sort dimension in the end but this allows to override the default parent filter with we gave in "-p" option. The goal of this is to prepare to allow the use of "-s parent" and "-p foo" at the same time, ie: sort by filtered parent. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Stephane Eranian <eranian@google.com> Cc: David Ahern <dsahern@gmail.com> Cc: Sam Liao <phyomh@gmail.com>
2011-06-30perf tools: Don't display ignored entries on stdio uiFrederic Weisbecker
As for newt ui, don't display entries that have been marked as ignored. The practical current effect of this is to make parent filtering really working. Before, entries that were ignored were given a null parent but were still displayed. This resulted in some weird effects: # Overhead Command Shared Object Symbol # ........ ........... ................. ............ # ^A | --- __lock_acquire | |--95.97%-- lock_acquire | | | |--30.75%-- _raw_spin_lock Discard these from the stdio display. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Stephane Eranian <eranian@google.com> Cc: David Ahern <dsahern@gmail.com> Cc: Sam Liao <phyomh@gmail.com>
2011-06-30perf tools: Remove sort print helpers declarationsFrederic Weisbecker
These are probably some old leftovers. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Stephane Eranian <eranian@google.com> Cc: David Ahern <dsahern@gmail.com> Cc: Sam Liao <phyomh@gmail.com>
2011-06-30perf tools: Make sort operations staticFrederic Weisbecker
These don't need to be globally visible. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Stephane Eranian <eranian@google.com> Cc: David Ahern <dsahern@gmail.com> Cc: Sam Liao <phyomh@gmail.com>
2011-06-30perf tools: Add inverted call graph report support.Sam Liao
Add "caller/callee" option to support inverted butterfly report, in the inverted report (with caller option), the call graph start from the callee's ancestor. Users can use such view to catch system's performance bottleneck from a sysprof like view. Using this option with specified sort order like pid gives us high level view of call graph statistics. Also add "-G" alias for inverted call graph. Signed-off-by: Sam Liao <phyomh@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Stephane Eranian <eranian@google.com> Cc: David Ahern <dsahern@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2011-06-19Merge branches 'perf-urgent-for-linus', 'sched-urgent-for-linus', ↵Linus Torvalds
'timers-urgent-for-linus' and 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tools/perf: Fix static build of perf tool tracing: Fix regression in printk_formats file * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: generic-ipi: Fix kexec boot crash by initializing call_single_queue before enabling interrupts * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: clocksource: Make watchdog robust vs. interruption timerfd: Fix wakeup of processes when timer is cancelled on clock change * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, MAINTAINERS: Add x86 MCE people x86, efi: Do not reserve boot services regions within reserved areas
2011-06-19Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: Move RCU_BOOST #ifdefs to header file rcu: use softirq instead of kthreads except when RCU_BOOST=y rcu: Use softirq to address performance regression rcu: Simplify curing of load woes
2011-06-16Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: kbuild: Call depmod.sh via shell perf: clear out make flags when calling kernel make kernelver
2011-06-16Merge commit 'v3.0-rc3' into perf/coreIngo Molnar
Merge reason: add the latest fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-16tools/perf: Fix static build of perf toolMathias Krause
To build a statically linked version of the perf tool all needed libraries must be added in the correct order to get the symbols resolved. Currently this is broken when, e.g. python or newt support is enabled -- libpython needs libpthread which is an unconditional link dependency of the perf tool; libslang needs libm, another unconditional dependency. To solve the problem in the long run without the need to keep track of transitive library dependencies, simply make the linker look at the EXTLIBS multiple times until it has all symbols resolved. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Link: http://lkml.kernel.org/r/1308171818-20370-1-git-send-email-minipli@googlemail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-15perf: clear out make flags when calling kernel make kernelverAndy Whitcroft
When generating the perf version from the kernel version using 'make kernelver' it is necessary to clear out any MAKEFLAGS otherwise they may trigger additional output which pollute the contents. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-06-14rcu: Use softirq to address performance regressionShaohua Li
Commit a26ac2455ffcf3(rcu: move TREE_RCU from softirq to kthread) introduced performance regression. In an AIM7 test, this commit degraded performance by about 40%. The commit runs rcu callbacks in a kthread instead of softirq. We observed high rate of context switch which is caused by this. Out test system has 64 CPUs and HZ is 1000, so we saw more than 64k context switch per second which is caused by RCU's per-CPU kthread. A trace showed that most of the time the RCU per-CPU kthread doesn't actually handle any callbacks, but instead just does a very small amount of work handling grace periods. This means that RCU's per-CPU kthreads are making the scheduler do quite a bit of work in order to allow a very small amount of RCU-related processing to be done. Alex Shi's analysis determined that this slowdown is due to lock contention within the scheduler. Unfortunately, as Peter Zijlstra points out, the scheduler's real-time semantics require global action, which means that this contention is inherent in real-time scheduling. (Yes, perhaps someone will come up with a workaround -- otherwise, -rt is not going to do well on large SMP systems -- but this patch will work around this issue in the meantime. And "the meantime" might well be forever.) This patch therefore re-introduces softirq processing to RCU, but only for core RCU work. RCU callbacks are still executed in kthread context, so that only a small amount of RCU work runs in softirq context in the common case. This should minimize ksoftirqd execution, allowing us to skip boosting of ksoftirqd for CONFIG_RCU_BOOST=y kernels. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Tested-by: "Alex,Shi" <alex.shi@intel.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-06-09Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: perf: Use make kernelversion instead of parsing the Makefile kbuild: Hack for depmod not handling X.Y versions kbuild: Move depmod call to a separate script kbuild: Fix <linux/version.h> for empty SUBLEVEL or PATCHLEVEL kbuild: Fix KERNELVERSION for empty SUBLEVEL or PATCHLEVEL kbuild: silence Nothing to be done for 'all' message
2011-06-09perf: Use make kernelversion instead of parsing the MakefileMichal Marek
Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-06-08Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf: Fix comments in include/linux/perf_event.h perf: Comment /proc/sys/kernel/perf_event_paranoid to be part of user ABI perf python: Fix argument name list of read_on_cpu() perf evlist: Don't die if sample_{id_all|type} is invalid perf python: Use exception to propagate errors perf evlist: Remove dependency on debug routines perf, cgroups: Fix up for new API
2011-06-04Merge branch 'perf/urgent' into perf/coreIngo Molnar
Conflicts: tools/perf/util/python.c Merge reason: resolve the conflict with perf/urgent. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-ktest * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-ktest: ktest: Ignore unset values of the minconfig in config_bisect ktest: Fix result of rebooting the kernel ktest: Fix off-by-one in config bisect result
2011-06-03perf python: Fix argument name list of read_on_cpu()Frederic Weisbecker
Mandatory arguments need to be present in the argument name list, as well as optional arguments, otherwise python barfs: # ./python/twatch.py Traceback (most recent call last): File "./python/twatch.py", line 41, in <module> main() File "./python/twatch.py", line 32, in main event = evlist.read_on_cpu(cpu) RuntimeError: more argument specifiers than keyword list entries Hence, add cpu to the name list. Cc: David Ahern <daahern@cisco.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Link: http://lkml.kernel.org/r/1301588863-20210-1-git-send-email-fweisbec@gmail.com Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-06-03perf evlist: Don't die if sample_{id_all|type} is invalidArnaldo Carvalho de Melo
Fixes two more cases where the python binding would not load: . Not finding die(), which it shouldn't anyway, not good to just stop the world because some particular perf.data file is invalid, just propagate the error to the caller. . Not finding perf_sample_size: fix it by moving it from event.c to evsel, where it belongs, as most cases are moving to operate on an evsel object.o One of the fixed problems: [root@emilia ~]# python >>> import perf Traceback (most recent call last): File "<stdin>", line 1, in <module> ImportError: /home/acme/git/build/perf/python/perf.so: undefined symbol: perf_sample_size >>> [root@emilia ~]# Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-1hkj7b2cvgbfnoizsekjb6c9@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-06-03perf python: Use exception to propagate errorsArnaldo Carvalho de Melo
We were using pr_debug to tell the user about not being able to parse a sample where we should really use the python way of reporting errors: exceptions. Fixes this problem: [root@emilia ~]# python >>> import perf Traceback (most recent call last): File "<stdin>", line 1, in <module> ImportError: /home/acme/git/build/perf/python/perf.so: undefined symbol: eprintf >>> [root@emilia ~] As we want to keep the objects linked in the python binding (and in the future in a shared library) minimal. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-m9dba9kaluas0kq8r58z191c@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-06-03perf evlist: Remove dependency on debug routinesArnaldo Carvalho de Melo
So far we avoided having to link debug.o in the python binding, keep it that way by not using ui__warning() in evlist.c. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-4wtew8hd3g7ejnlehtspys2t@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-06-02perf script: Add printing of sample addressDavid Ahern
Resolve to a function or variable if possible and if the sym option is enabled. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1306782503-22002-1-git-send-email-dsahern@gmail.com Signed-off-by: David Ahern <dsahern@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-06-02perf script: Make printing of dso a separate field optionDavid Ahern
The 'sym' option displays both the function name and the DSO it comes from. Split the display of the dso into a separate option. This allows display of the ip address and symbol without the dso, thus shortening line lengths - and decluttering the output a bit. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1306528124-25861-3-git-send-email-dsahern@gmail.com Signed-off-by: David Ahern <dsahern@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-06-02perf script: "sym" field really means show IP dataDavid Ahern
Currently the "sym" output field is used to dump instruction pointers and callchain stack. Sample addresses can also be converted to symbols, so the meaning of "sym" needs to be fixed. This patch adds an "ip" option and if it is selected the user can also opt to dump symbols for them. If the user opts to dump IP without syms only the address is shown. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1306528124-25861-2-git-send-email-dsahern@gmail.com Signed-off-by: David Ahern <dsahern@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-06-02perf stat: clarify unsupported events from uncounted eventsDavid Ahern
perf stat continues running even if the event list contains counters that are not supported. The resulting output then contains <not counted> for those events which gets confusing as to which events are supported, but not counted and which are not supported. Before: perf stat -ddd -- sleep 1 Performance counter stats for 'sleep 1': 0.571283 task-clock # 0.001 CPUs utilized 1 context-switches # 0.002 M/sec 0 CPU-migrations # 0.000 M/sec 157 page-faults # 0.275 M/sec 1,037,707 cycles # 1.816 GHz <not counted> stalled-cycles-frontend <not counted> stalled-cycles-backend 654,499 instructions # 0.63 insns per cycle 136,129 branches # 238.286 M/sec <not counted> branch-misses <not counted> L1-dcache-loads <not counted> L1-dcache-load-misses <not counted> LLC-loads <not counted> LLC-load-misses <not counted> L1-icache-loads <not counted> L1-icache-load-misses <not counted> dTLB-loads <not counted> dTLB-load-misses <not counted> iTLB-loads <not counted> iTLB-load-misses <not counted> L1-dcache-prefetches <not counted> L1-dcache-prefetch-misses 1.001004836 seconds time elapsed After: perf stat -ddd -- sleep 1 Performance counter stats for 'sleep 1': 1.350326 task-clock # 0.001 CPUs utilized 2 context-switches # 0.001 M/sec 0 CPU-migrations # 0.000 M/sec 157 page-faults # 0.116 M/sec 11,986 cycles # 0.009 GHz <not supported> stalled-cycles-frontend <not supported> stalled-cycles-backend 496,986 instructions # 41.46 insns per cycle 138,065 branches # 102.246 M/sec 7,245 branch-misses # 5.25% of all branches <not counted> L1-dcache-loads <not counted> L1-dcache-load-misses <not counted> LLC-loads <not counted> LLC-load-misses <not counted> L1-icache-loads <not counted> L1-icache-load-misses <not counted> dTLB-loads <not counted> dTLB-load-misses <not counted> iTLB-loads <not counted> iTLB-load-misses <not counted> L1-dcache-prefetches <not supported> L1-dcache-prefetch-misses 1.002397333 seconds time elapsed v1->v2: changed supported type from int to bool v2->v3 fixed vertical alignment of new struct element Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1306767359-13221-1-git-send-email-dsahern@gmail.com Signed-off-by: David Ahern <dsahern@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-06-02perf python: Cleanup useless double NULL termination in method arg namesFrederic Weisbecker
The list of methods argument names only needs to be NULL terminated once. Remove the second ones. Cc: David Ahern <daahern@cisco.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Link: http://lkml.kernel.org/r/1301588863-20210-2-git-send-email-fweisbec@gmail.com Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-06-02perf python: Fix argument name list of read_on_cpu()Frederic Weisbecker
2011-06-02ktest: Ignore unset values of the minconfig in config_bisectSteven Rostedt
By ignoring the unset values of the minconfig in deciding what to test in the config_bisect can cause the problem config from being tested too. Just do not test the configs that are set in the minconfig. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-02ktest: Fix result of rebooting the kernelSteven Rostedt
The command that is called that reboots the kernel may fail but the return code is not passed back to the ktest.pl script. This is because a ';' is used between the two commands and if the second command fails, only the first command's return code is returned. Using a '&&' between the two commands fixes this. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
