The session object is released prematurely when processing events for
latency command. The session's thread objects are used within the
output_lat_thread function.
Runnning following commands:
# perf sched record
# perf sched latency
the latter displays incorrect data and might cause access violation.
Link: http://lkml.kernel.org/r/1312837414-3819-1-git-send-email-jolsa@redhat.com
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Just like we do already for perf.data files.
Requested-by: Ingo Molnar <mingo@elte.hu>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Christian Ohm <chr.ohm@gmx.net>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jonathan Nieder <jrnieder@gmail.com>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/n/tip-qgokmxsmvppwpc5404qhyk7e@git.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent
Adding install-python_ext target to install python extension related
files. Installation directory is governed by python distutils package
and follows the DESTDIR variable settings.
Also moving python extension build output into '$(O)python_ext_build'
directory and making it configurable via PYTHON_EXTBUILD variable.
Keeping the '$(O)python/perf.so' file, so it could be used for testing
as of until now.
Link: http://lkml.kernel.org/r/20110722113307.GA1931@jolsa.brq.redhat.com
In addition to /etc/perfconfig and $HOME/.perfconfig, perf looks for
configuration in the file ./config, imitating git which looks at
$GIT_DIR/config. If ./config is not a perf configuration file, it
fails, or worse, treats it as a configuration file and changes behavior
in some unexpected way.
"config" is not an unusual name for a file to be lying around and perf
does not have a private directory dedicated for its own use, so let's
just stop looking for configuration in the cwd. Callers needing
context-sensitive configuration can use the PERF_CONFIG environment
variable.
Requested-by: Christian Ohm <chr.ohm@gmx.net>
Cc: 632923@bugs.debian.org
Link: http://lkml.kernel.org/r/20110805165838.GA7237@elie.gateway.2wire.net
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
Use LIB_OBJS and BUILTIN_OBJS for .o files.
LIB_FILE is already prefixed with OUTPUT.
Link: http://lkml.kernel.org/r/20110807083932.9C0E514C03B@msa103.auone-net.jp
Signed-off-by: Kusanagi Kouichi <slash@ac.auone-net.jp>
Looks to me like the :r modifier is not supported anymore, so remove it
from the list of events. Without this fix 'perf lock record' doesn't
work.
Cc: Zhu Yanhai <gaoyang.zyh@taobao.com>
Link: http://lkml.kernel.org/r/1312035232-9534-1-git-send-email-gaoyang.zyh@taobao.com
Signed-off-by: Zhu Yanhai <gaoyang.zyh@taobao.com>
perf will coredump if the user doesn't give the "-m" option in probe
command, this patch fixes it.
[root@localhost perf]# ./perf probe --add='PROBE'
Segmentation fault (core dumped)
Link: http://lkml.kernel.org/r/1311602888-2389-1-git-send-email-bookjovi@gmail.com
Signed-off-by: Jovi Zhang <bookjovi@gmail.com>
So that we get a proper warning in the TUI in cases like:
$ perf report --stdio -g fractal,0.5,caller --sort pid
Selected -g but no callchain data. Did you call 'perf record' without -g?
The --stdio case is ok because it uses fprintf, ui__warning is needed to
figure out if --stdio or --tui is being used.
Cc: Arun Sharma <asharma@fb.com>
Cc: Sam Liao <phyomh@gmail.com>
Link: http://lkml.kernel.org/n/tip-ag9fz2wd17mbbfjsbznq1wms@git.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6
* 'tools-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6:
tools/power turbostat: fit output into 80 columns on snb-ep
tools/power x86_energy_perf_policy: fix print of uninitialized string
Reduce columns for package number to 1.
If you can afford more than 9 packages,
you can also afford a terminal with more than 80 columns:-)
Also shave a column also off the package C-states
Signed-off-by: Len Brown <len.brown@intel.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/cpupowerutils:
cpupower: Do detect IDA (opportunistic processor performance) via cpuid
cpupower: Show Intel turbo ratio support via ./cpupower frequency-info
cpupowerutils: increase MAX_LINE_LEN
cpupower: Rename package from cpupowerutils to cpupower
cpupowerutils: Rename: libcpufreq->libcpupower
cpupowerutils: use kernel version-derived version string
cpupowerutils: utils - ConfigStyle bugfixes
cpupowerutils: helpers - ConfigStyle bugfixes
cpupowerutils: idle_monitor - ConfigStyle bugfixes
cpupowerutils: lib - ConfigStyle bugfixes
cpupowerutils: bench - ConfigStyle bugfixes
cpupowerutils: do not update po files on each and every compile
cpupowerutils: remove ccdv, use kernel quiet/verbose mechanism
cpupowerutils: use COPYING, CREDITS from top-level directory
cpupowerutils - cpufrequtils extended with quite some features
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6
* 'slub/lockless' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: (21 commits)
slub: When allocating a new slab also prep the first object
slub: disable interrupts in cmpxchg_double_slab when falling back to pagelock
Avoid duplicate _count variables in page_struct
Revert "SLUB: Fix build breakage in linux/mm_types.h"
slub: slabinfo update for cmpxchg handling
slub: Not necessary to check for empty slab on load_freelist
slub: fast release on full slab
slub: Add statistics for the case that the current slab does not match the node
slub: Get rid of the another_slab label
slub: Avoid disabling interrupts in free slowpath
slub: Disable interrupts in free_debug processing
slub: Invert locking and avoid slab lock
slub: Rework allocator fastpaths
slub: Pass kmem_cache struct to lock and freeze slab
slub: explicit list_lock taking
slub: Add cmpxchg_double_slab()
mm: Rearrange struct page
slub: Move page->frozen handling near where the page->freelist handling occurs
slub: Do not use frozen page flag but a bit in the page counters
IA32-Intel Devel guide Volume 3A - 14.3.2.1
Opportunistic processor performance operation can be disabled by setting bit 38 of
IA32_MISC_ENABLES. This mechanism is intended for BIOS only. If
IA32_MISC_ENABLES[38] is set, CPUID.06H:EAX[1] will return 0.
Better detect things via cpuid, this cleans up the code a bit
and the MSR parts were not working correctly anyway.
Signed-off-by: Thomas Renninger <trenn@suse.de>
CC: lenb@kernel.org
CC: linux@dominikbrodowski.net
CC: cpufreq@vger.kernel.org
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
This adds the last piece missing from turbostat (if called with -v).
It shows on Intel machines supporting Turbo Boost how many cores
have to be active/idle to enter which boost mode (frequency).
Whether the HW really enters these boost modes can be verified via
./cpupower monitor.
CC: lenb@kernel.org
larger sysfs data (>255 bytes) was truncated and thus used improperly
[linux@dominikbrodowski.net: adapted to cpupowerutils]
Signed-off-by: Roman Vasiyarov <rvasiyarov@gmail.com>
[linux@dominikbrodowski.net: fix .gitignore]
As cpupowerutils is intended to be included into the kernel sources,
use the kernel versioning instead of a custom version.
The script utils/version-gen.sh is largely based on the script already
found in tools/perf/util/PERF-VERSION-GEN .
Use the quiet/verbose mechanism found in kernel tools, without
relying on the special tool "ccdv"
CPU power consumption vs performance tuning is no longer
limited to CPU frequency switching anymore: deep sleep states,
traditional dynamic frequency scaling and hidden turbo/boost
frequencies are tied close together and depend on each other.
The first two exist on different architectures like PPC, Itanium and
ARM, the latter (so far) only on X86. On X86 the APU (CPU+GPU) will
only run most efficiently if CPU and GPU has proper power management
in place.
Users and Developers want to have *one* tool to get an overview what
their system supports and to monitor and debug CPU power management
in detail. The tool should compile and work on as many architectures
as possible.
Once this tool stabilizes a bit, it is intended to replace the
Intel-specific tools in tools/power/x86
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-ktest
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-ktest:
ktest: Fix bug when ADD_CONFIG is set but MIN_CONFIG is not
ktest: Keep fonud configs separate from default configs
ktest: Add prompt to use OUTPUT_MIN_CONFIG
ktest: Use Kconfig dependencies to shorten time to make min_config
ktest: Add test type make_min_config
ktest: Require one TEST_START in config file
ktest: Add helper function to avoid duplicate code
ktest: Add IGNORE_WARNINGS to ignore warnings in some patches
ktest: Fix tar extracting of modules to target
ktest: Have the testing tmp dir include machine name
ktest: Add POST/PRE_BUILD options
ktest: Allow initrd processing without modules defined
ktest: Have LOG_FILE evaluate options as well
ktest: Have wait on stdio honor bug timeout
ktest: Implement our own force min config
ktest: Add TEST_NAME option
ktest: Add CONFIG_BISECT_GOOD option
ktest: Add detection of triple faults
ktest: Notify reason to break out of monitoring boot
So those friggin "spurious" PERF_RECORD_MMAP events were actually a
brain fart copy'n'paste error in the python binding, doh. I.e. they
weren't MMAPs, just SAMPLEs.
Fix it by providing routines for these events instead of using the MMAP
ones.
Link: http://lkml.kernel.org/n/tip-b0rc8y5jd03f9f11kftodvkm@git.kernel.org
To remove the last case of access to the FD() macro outside the library.
Inspired by a patch by Borislav that moved the FD() macro to util.h, for
namespace concerns I rather preferred to constrain it to ev{sel,list}.c.
Cc: Borislav Petkov <bp@amd64.org>
Link: http://lkml.kernel.org/n/tip-qn893qsstcg366tkucu649qj@git.kernel.org
'irq-core-for-linus' and 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
um: Make rwsem.S depend on CONFIG_RWSEM_XCHGADD_ALGORITHM
* 'core-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
debug: Make CONFIG_EXPERT select CONFIG_DEBUG_KERNEL to unhide debug options
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
genirq: Remove unused CHECK_IRQ_PER_CPU()
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf tools, x86: Fix 32-bit compile on 64-bit system
The readlink() function doesn't append a null byte to buf. So we should
zero out buf with zalloc(). Or we'll see sometimes error like this:
[root@intel-s3e36-01]~# /usr/bin/perf buildid-cache -a /lib/modules/2.6.32-130.el6.x86_64/kernel/crypto/twofish_common.ko -v
Adding f64ba8efd5f53c7ad332fc17db1d21de309038e1 /lib/modules/2.6.32-130.el6.x86_64/kernel/crypto/twofish_common.ko: Ok
[root@intel-s3e36-01]~# /usr/bin/perf buildid-cache -r /lib/modules/2.6.32-130.el6.x86_64/kernel/crypto/twofish_common.ko -v
Removing f64ba8efd5f53c7ad332fc17db1d21de309038e1 /lib/modules/2.6.32-130.el6.x86_64/kernel/crypto/twofish_common.ko: FAIL
/lib/modules/2.6.32-130.el6.x86_64/kernel/crypto/twofish_common.ko wasn't in the cache
The change in build_id_cache__add_s() is a defense.
Tested-by: Jiri Olsa <jolsa@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/20110718031314.GA5802@hpt.nay.redhat.com
Signed-off-by: Han Pingtian <phan@redhat.com>
Builds for 32-bit perf binaries on a 64-bit host currently fail
with this error:
bench/../../../arch/x86/lib/memcpy_64.S: Assembler messages:
bench/../../../arch/x86/lib/memcpy_64.S:29: Error: bad register name `%rdi'
bench/../../../arch/x86/lib/memcpy_64.S:34: Error: invalid instruction suffix for `movs'
bench/../../../arch/x86/lib/memcpy_64.S:50: Error: bad register name `%rdi'
bench/../../../arch/x86/lib/memcpy_64.S:61: Error: bad register name `%rdi'
The problem is the detection of the host arch without considering passed in
flags. This change fixes 32-bit builds via:
make EXTRA_CFLAGS=-m32
and 64-bit builds still reference the memcpy_64.S.
Signed-off-by: David Ahern <dsahern@gmail.com>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Cc: <stable@kernel.org>
Link: http://lkml.kernel.org/r/1310420304-21452-1-git-send-email-dsahern@gmail.com
Use preset debugfs path instead of hardcoded one.
Cc: acme@redhat.com
Cc: a.p.zijlstra@chello.nl
Cc: paulus@samba.org
Link: http://lkml.kernel.org/r/1310635534-4013-4-git-send-email-jolsa@redhat.com
Adding builtin test for parse_events function, which is
responsible for parsing/processing "-e" option for
stat/top/record commands.
This new test will run within the builtin test command suite
(perf test).
One or several tests were added for each type of event.
More tests could be added easily if needed.
Cc: acme@redhat.com
Link: http://lkml.kernel.org/r/1310635534-4013-3-git-send-email-jolsa@redhat.com
Moving out the option parameter from parse_events function,
and adding new parse_events_option function instead.
The option parameter is used only to carry "struct perf_evlist"
pointer for chaining new events. Putting it away, enable us
to call parse_events from other places without using the
option parameter.
Cc: acme@redhat.com
Link: http://lkml.kernel.org/r/1310635534-4013-2-git-send-email-jolsa@redhat.com
Non-callchain path is using al.addr which prints as:
openssl 14564 17672.003587: 7862d _x86_64_AES_encrypt_compact
This should be sample->ip to print as:
openssl 14564 17672.003587: 3f7867862d _x86_64_AES_encrypt_compact
Cc: acme@ghostprotocols.net
Cc: peterz@infradead.org
Link: http://lkml.kernel.org/r/1306768587-15376-1-git-send-email-dsahern@gmail.com
The perf_event_attr struct has two __u32's at the top and
they need to be swapped individually.
With this change I was able to analyze a perf.data collected in a
32-bit PPC VM on an x86 system. I tested both 32-bit and 64-bit
binaries for the Intel analysis side; both read the PPC perf.data
file correctly.
-v2:
- changed the existing perf_event__attr_swap() to swap only elements
of perf_event_attr and exported it for use in swapping the
attributes in the file header
- updated swap_ops used for processing events
Link: http://lkml.kernel.org/r/1310754849-12474-1-git-send-email-dsahern@gmail.com
Add "node" as a simple alias for NODE cache events.
The addition of NODE cache events broke the parse_alias
function, so any mismatched event caused the segfault, like:
# ./perf stat -e krava ls
The hw_cache/hw_cache_op/hw_cache_result arrays needs to follow
PERF_COUNT_HW_CACHE_*MAX enums. Adding those MAXs to be size
of those arrays, so possible ommision in future wil not lead to
segfault.
Adding read/write/prefetch as allowed operations for node cache
event.
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: acme@redhat.com
Link: http://lkml.kernel.org/r/20110713205818.GB7827@jolsa.brq.redhat.com
Looks like I was going to stick the brand string
in the verbose ouput, but didn't get around to it.
The MIN_CONFIG is a single config that is considered to have all the
configs that are required to boot the box.
ADD_CONFIG is a list of configs that we add that may contain configs
known to be broken (set off) or just configs that we want every box to
have and this can include shared configs.
If a config has no MIN_CONFIG defined, but has multiple files defined
for the ADD_CONFIG, the test will die, because the MIN_CONFIG will
default to ADD_CONFIG. The problem is the code to open MIN_CONFIG
expects a string of one file, not multiple, and the open will fail.
Since the real minconfig that is used is a concatination of MIN_CONFIG
and ADD_CONFIG files, we change the code to open that instead of
whatever MIN_CONFIG defaults to.
The IGNORE_CONFIG file holds the configs that we don't want to change
(with their proper settings). But on start up, the make noconfig is
executed, and the configs that are on are also put into the ignore
config category. But these are configs that were forced on by the
kconfig scripts and not something that we found must be enabled to boot
our machine. By keeping the configs that are forced on by default,
separate from the configs we found that are required to boot the box, we
can get a much more interesting IGNORE_CONFIG. In fact, the
IGNORE_CONFIG can usually end up being the must have configs to boot,
and only have 6 or 7 configs set.
If the defined OUTPUT_MIN_CONFIG in the make_min_config test exists,
then give a prompt to ask the user if they want to use that config
instead, as it is very often the case, especially when the test has been
interrupted. The OUTPUT_MIN_CONFIG is usually the config that one wants
to use to continue the test where they left off.
But if START_MIN_CONFIG is defined (thus the MIN_CONFIG is not the
default), then do not prompt, as it will be annoying if the user has
this as one of many tests, and the test pauses waiting for input, while
the user is sleeping.
To save time, the test does not just grab any option and test
it. The Kconfig files are examined to determine the dependencies
of the configs. If a config is chosen that depends on another
config, that config will be checked first. By checking the
parents first, we can eliminate whole groups of configs that
may have been enabled.
For example, if a USB device config is chosen and depends on
CONFIG_USB, the CONFIG_USB will be tested before the device.
If CONFIG_USB is found not to be needed, it, as well as all
configs that depend on it, will be disabled and removed from
the current min_config.
Note, the code from streamline_config (make localmodconfig)
was copied and used to find the dependencies in the Kconfig file.
After doing a make localyesconfig, your kernel configuration may
not be the most useful minimum configuration. Having a true minimum
config that you can use against other configs is very useful if
someone else has a config that breaks on your code. By only forcing
those configurations that are truly required to boot your machine
will give you less of a chance that one of your set configurations
will make the bug go away. This will give you a better chance to
be able to reproduce the reported bug matching the broken config.
Note, this does take some time, and may require you to run the
test over night, or perhaps over the weekend. But it also allows
you to interrupt it, and gives you the current minimum config
that was found till that time.
Note, this test automatically assumes a BUILD_TYPE of oldconfig
and its test type acts like boot.
TODO: add a test version that makes the config do more than just
boot, like having network access.
Support adding probes on offline kernel modules. This enables
perf-probe to trace kernel-module init functions via perf-probe.
If user gives the path of module with -m option, perf-probe
expects the module is offline.
This feature works with --add, --funcs, and --vars.
E.g)
# perf probe -m /lib/modules/`uname -r`/kernel/fs/btrfs/btrfs.ko \
-a "extent_io_init:5 extent_state_cache"
Add new events:
probe:extent_io_init (on extent_io_init:5 with extent_state_cache)
probe:extent_io_init_1 (on extent_io_init:5 with extent_state_cache)
You can now use it on all perf tools, such as:
perf record -e probe:extent_io_init_1 -aR sleep 1
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/20110627072751.6528.10230.stgit@fedora15
Add probed module name and ":" in front of function name
if -m module option is given. In the result, the symbol
name passed to kprobe-tracer becomes MODULE:FUNCTION,
so that kallsyms can solve it as a symbol in the module
correctly.
Link: http://lkml.kernel.org/r/20110627072745.6528.26416.stgit@fedora15
Introduce debuginfo to encapsulate dwarf information.
This new object allows us to reuse and expand debuginfo easily.
Link: http://lkml.kernel.org/r/20110627072739.6528.12438.stgit@fedora15
